  4. MieleCloudService Adapter
    6.1k
mielemieleathomemielecloudservice
888 Beiträge 93 Kommentatoren 375.7k Aufrufe 99 Beobachtet
  • L larsvoedisch
    @grizzelbee
    Anbei mal der Inhalt aus SplitMieleDevices. Sieht nicht so aus, als wenn die Lüfterstufe mit kommt. Die Werte 2 und 4 unten, zeigen die Stufe des Kochfeldes. Die Lüfterstüfe war auf 3, ist aber nirgends zu erkennen.
    splitMieleDevices: 000175944516: [000175944516] *** Value: [{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":27,"value_localized":"Kochfeld"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000175944516","fabIndex":"00","techType":"KMDA7634","matNumber":"11390360","swids":["4806","20269","25122"]},"xkmIdentLabel":{"techType":"EK039W","releaseVersion":"02.72"}},"state":{"ProgramID":{"value_raw":0,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":5,"value_localized":"In Betrieb","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":0,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":3,"value_localized":"2","key_localized":"Leistungsstufe"},{"value_raw":7,"value_localized":"4","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"}],"ecoFeedback":null,"batteryLevel":null}}]
    Wollte dann auch deinen zweiten Vorschlag ausprobieren, bin aber daran gescheitert, dass ich nicht weiß was ich bei "BearerAuth" eingeben muss. Die anderen zwei Felder sind klar.
    Wäre super, wenn du mir da noch eine Hilfestellung geben könntest.
    Danke schon mal im Voraus.
    GrizzelbeeG Offline
    GrizzelbeeG Offline
    Grizzelbee
    #390
    @larsvoedisch
    Du hast absolut Recht:
    Wenn - dann müsste es hier drin stehen. das ist zumindest die Info für Dunstahauben.
    Also: Aktuell keine Chance an die Info zu kommen.
    Der BearerAuth ist alternativ - den kannst du also einfach leer lassen.
    Du könnest auch den Bearer, den der Adapter beim Start ausgibt dort eintragwen und die anderen Felder leer lassen.
    Du kannst Dir das aber sparen. Die beiden Wege waren alternativ. Da kommen keine anderen Ergebnisse bei raus. Die Seite ist nur mitunter ganz praktisch um mal gezielt Dinge auszuprobieren ohne in Kilometern von logs zu wühlen.
    L 1 Antwort Letzte Antwort
    • GrizzelbeeG Grizzelbee
      @larsvoedisch
      larsvoedisch
      #391
      @grizzelbee
      Schade. Hast du ne Mail-Adresse oder Forum, wo man Miele mal direkt anschreiben kann?
      GrizzelbeeG 1 Antwort Letzte Antwort
      • L larsvoedisch
        @grizzelbee
        GrizzelbeeG Offline
        GrizzelbeeG Offline
        Grizzelbee
        #392
        @larsvoedisch
        Ein Forum gibt es meines Wissens nach nicht. Maildraesse findest du auf: https://www.miele.com/developer
          michael 1975
          schrieb am zuletzt editiert von michael 1975
          #393
          @Grizzelbee kannst du mir die zwei datenpunkte erklären
          Da ich komischerweise über beide die Maschine mal Starten kann und mal nicht? Sorry Bild vergessen.
          • M michael 1975
            GrizzelbeeG Offline
            GrizzelbeeG Offline
            Grizzelbee
            schrieb am zuletzt editiert von Grizzelbee
            #394
            @michael-1975
            Also, die Idee ist folgende:
            In ioBroker habe ich keine Möglichkeit einen Schalter zu definieren - und ihn anschließend zu aktivieren oder zu deaktivieren. Das wäre eigentlich meine Lieblingslösung gewesen. Das Problem ist nämlich folgendes: Wenn der Schalter einmal da ist, ist er auch jederzeit klick-/schaltbar. Die Miele-API sagt mir aber - abhängig vom Zustand der Geräte - welche Aktion sich nun tatsächlich gerade auslösen lässt und welche nicht. Also habe ich einmal den eigentlichen Schalter zum Starten der Aktion implementiert (Action.Start) und direkt daneben die Statusanzeige ob der Button lt-. API gerade funktioniert - oder eben auch nicht (Action.Start_Button_Active). Damit könnte man also in der VIS die entsprechenden Schalter aktivieren bzw. deaktivieren. Soviel zur Intention dahinter.
            Ich bin zwar der letzte, der Programmierfehler kategorisch ausschließen will - im Augenblick fehlt mir aber tatsächlich die Fantasie, wie Start_Button_Active die Aktion selbst auslösen sollte oder könnte. Gedacht ist es aber ganz sicher nicht so.
            Hoffe deine Frage befriedigend beantwortet zu haben.
            • O Offline
              O Offline
              oxident
              schrieb am zuletzt editiert von oxident
              #395
              UPDATE: Sorry, hat sich erledigt. Scheinbar war das iobroker gespeicherte Kennwort falsch oder leer. Hat sich mysteriöserweise von selbst gelöscht ✌
              Hmm, seit heute Morgen kommen bei mir nur noch Fehlermeldung bezgl. falscher Login-Daten. Habe sie aber gegengeprüft und mir sogar neue bei Miele geben lassen. Trotzdem bleibt der Adapter "rot". Habt Ihr das auch?
              mielecloudservice.0
              2021-09-15 14:04:11.528	warn	Read-only state "mielecloudservice.0.info.connection" has been written without ack-flag with value "false"
              mielecloudservice.0
              2021-09-15 14:04:11.522	error	[main] APIGetAccessToken returned neither a token nor an errormessage. Returned value=[undefined]
              mielecloudservice.0
              2021-09-15 14:04:11.521	warn	IMPORTANT!! Mask/Delete your credentials when posting your log online!
              mielecloudservice.0
              2021-09-15 14:04:11.520	error	options country: [de-DE]
              mielecloudservice.0
              2021-09-15 14:04:11.520	error	options Client_Secret: [XXX]
              mielecloudservice.0
              2021-09-15 14:04:11.520	error	options Client_ID: [XXX]
              mielecloudservice.0
              2021-09-15 14:04:11.520	error	options Miele_Password: []
              mielecloudservice.0
              2021-09-15 14:04:11.520	error	options Miele_account: [XXX]
              mielecloudservice.0
              2021-09-15 14:04:11.520	error	Credentials used for login:
              mielecloudservice.0
              2021-09-15 14:04:11.519	error	Error: Unable to authenticate user! Your credentials seem to be invalid. Please double check and fix them.
              mielecloudservice.0
              2021-09-15 14:04:11.518	error	OAuth2 returned an error during first login!
                michael 1975
                #396
                bei mir ist alles ok
                  @michael-1975
                  michael 1975
                  #397
                  @grizzelbee sagte in MieleCloudService Adapter:
                  @michael-1975
                  Danke für deine Antwort.
                  Ich werde es mal weiter durchprobieren und dir dann die Infos geben.
                  Gruß Michael
                    michael 1975
                    #398
                    So heute habe ich es endlich das erstemal hinbekommen das die Spülmaschine selbst startet wenn ich von der PV Anlage überschuß produziere. Für die wo es interessiert folgendes habe ich gemacht, gestern abend die Maschine eingeschaltet mit Endzeit spätesdens heute um 18:00 Uhr.
                    Und sie ist heute morgen selbständig um 8:30 angegangen nach dem ich mehr wie 50 Watt von der PV Anlage kommt ist bis jetzt nur bis alles läuft dann wird optimiert mit Trockner und Waschamschine, folgendes Blockly habe ich gemacht.
                    Gruß Michael
                    • M michael 1975
                      Gruß Michael
                      GrizzelbeeG Offline
                      GrizzelbeeG Offline
                      Grizzelbee
                      #399
                      @michael-1975
                      Cool! Freut mich sehr, dass es jetzt klappt. :)
                      Die erste Steueranweisung kannst du aber getrost rausnehmen.
                      Die wird nichts ausrichten. Der Datenpunkt ist nicht beschreibbar:
                      Du könntest bestenfalls abfragen ob der Datenpunkt gerade "wahr" ist und dann erst die Maschine starten und falls er "falsch" ist eine Benachrichtigung schicken. Dafür ist er gedacht und so sollte er funktionieren - hoffe ich jedenfalls. Das Problem ist nämlich, dass der Adapter in einen Fehler läuft, wenn eine Aktion ausgelöst wird, die gerade nicht erlaubt ist.
                        @michael-1975
                        michael 1975
                        #400
                        @grizzelbee komisch ist nur das der immer auf false steht.
                        wenn ich den raus nehme dann ginge es das letzte mal nicht, werde es aber nochmals probieren.
                        Es war ja immer das Problem wenn ich die Maschine richte und nach ca.3 Stunden konnte ich Sie nicht mehr mit dem Adapter starten und so hat es jetzt funktioniert aber ich teste es heute abend nochmal und schaue ob Sie morgen startet.
                          @larsvoedisch
                          larsvoedisch
                          #401
                          @grizzelbee
                          Hab mal Miele angeschrieben und auch eine Antwort bekommen:
                          Thank you very much for your valuable feedback on our API. The cooktop with hood is a special class of our standard cooktop. Unfortunately, the fan levels are not yet displayed there. We are working on this point and assume that we will also display the fan levels with the next API release.
                          Please be patient a little longer.
                          Könnte sich also irgendwann mal was tun. ;-)
                            michael 1975
                            #402
                            So habe das ganze Wochenende getestet, was soll ich sagen es funktioniert soweit alles ich kann die Spülmaschine, Waschmaschine oder Trockner abends richten und am Nächsten Tag starten sie sobald ich einen Überschuß der PV Anlage habe. Es gibt im Moment auch n icht sowas wie einen Tiefschlaf der Geräte.
                            Danke für den Super Adapter.
                            Gruß Michael
                            • L larsvoedisch
                              @grizzelbee
                              GrizzelbeeG Offline
                              GrizzelbeeG Offline
                              Grizzelbee
                              #403
                              @larsvoedisch
                              Ja, so etwas in der Art dachte ich mir schon. ;) Das Schöne bei Miele ist, das die wirklich gut auf konstruktive Kritik reagieren - auf der anderen Seite habe ich den Eindruck, das da nur so ein bis zwei Leute an der API arbeiten. Bisher scheint es sich zwar um ein strategisches, aber kein besonders hoch priorisiertes Projekt zu handeln. Ich würde aber sehr gerne mit meiner Einschätzung falsch liegen. ;)
                              @michael-1975
                              Das klingt doch insgesamt schon mal vielversprechend! :D
                              Auf welcher Version bist du gerade? v4.5.0?
                              S M 2 Antworten Letzte Antwort
                                @larsvoedisch
                                @michael-1975
                                schweiger2
                                #404
                                seit einiger Zeit (vielleicht 1-2 Wochen) erhalte ich folgende errors des mielecloud-Adapters. Ich habe diesen bereits eine Weile laufen und gemäß Anleitung konfiguriert. Ich muss dazu sagen, dass bisher noch kein Gerät in den Adapter integriert ist, das dieses erst im November geliefert wird.
                                Den Bestätigungslink für den Account von Miele (Activate your Miele 3rd Party API credentials) habe ich erneut betätigt und erhalte den Hinweis, dass der Token falsch wäre (Your token is invalid).
                                Was muss ich tun ?
                                Vielen Dank und beste Grüße
                                2021-09-21 00:27:33.347 - error: mielecloudservice.0 (14814) [APISendRequest] {"message":"connect ENETUNREACH 20.61.170.218:443","name":"Error","stack":"Error: connect ENETUNREACH 20.61.170.218:443\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1148:16)","config":{"url":"https://api.mcs3.miele.com/v1/devices/?language=de","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_d4ba3ecbfb0cde2e1bf8eb609e9a6781","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"dataType":"json","json":true},"code":"ENETUNREACH"} | [Stack]: Error: connect ENETUNREACH 20.61.170.218:443
                                2021-09-21 00:27:33.348 - error: mielecloudservice.0 (14814) The request was made but no response was received:
                                2021-09-21 00:27:33.348 - error: mielecloudservice.0 (14814) [refreshMieleData] [TypeError: Converting circular structure to JSON
                                --> starting at object with constructor 'TLSSocket'
                                | property '_httpMessage' -> object with constructor 'ClientRequest'
                                --- property 'socket' closes the circle] |-> JSON.stringify(error):{}
                                  @larsvoedisch
                                  @michael-1975
                                  michael 1975
                                  #405
                                  @grizzelbee Ja ich bin auf der v4.5.0 läuft super.
                                  • M michael 1975
                                    JoergH
                                    schrieb am zuletzt editiert von JoergH
                                    #406
                                    @Grizzelbee
                                    Nachdem ich heute mal wieder zum Testen kam:
                                    Erst ging nichts, da der Adapter die Objekte überhaupt nicht mehr upgedatet hat, obwohl die Instanz auf grün war. Versuche den Geschirrspüler remote zu starten funktionierten nicht - keine Reaktion. Reloads brachten nichts. Dann habe ich die APP auf dem Handy neu gestartet und siehe da, ich war nicht eingeloggt, da offensichtlich ein update installiert worden war. Ich loggte mich ein und konnte sofort den Status der Geräte korrekt erkennen. Also habe ich die Instanz komplett gestoppt und wieder gestartet und siehe da, sie zeigte wieder korrekte Daten. Das Gerät ließ sich nun auch starten, pausieren und stoppen, obwohl alle drei Stati auf "false" standen. Die funktionieren also offensichtlich nicht korrekt.
                                    • J JoergH
                                      @Grizzelbee
                                      JoergH
                                      #407
                                      @Grizzelbee
                                      Weitere Erkenntnis gewonnen heute:
                                      Das Pausieren, Starten und Stoppen funktioniert nur nach dem Starten der Instanz zuverlässig. Ich habe noch nicht herausgefunden wann genau er nicht mehr will, aber es scheint eine Art Zeitbeschränkung zu geben, nach der es dann nicht mehr funktioniert, bis man die Instanz neu gestartet hat!
                                      Nachdem ich heute Morgen getetestet hatte und es funktionierte, habe ich eben noch einmal getestet und er reagierte weder auf Pause, Start oder Stop, bis ich die Instanz neu gestartet hatte, dann ging es wieder.
                                      EDIT: "Zuverlässig" geht es auch dann nicht. Jetzt habe ich noch einmal die Geschirrspüle ausgestellt, dann wieder eingeschaltet, ein Programm gewählt und wollte nun per "Objekte Button" starten. Ging nicht, stattdessen Msg.: "Cannot read property 'message' of undefined"
                                      Es ist bisher für mich nicht systematisch nachvollziehbar wann das Gerät reagiert und wann nicht.
                                      • J JoergH
                                        @Grizzelbee
                                        JoergH
                                        #408
                                        @joergh
                                        Nächstes Update:
                                        Ich vermute das manchmal etwas störrische Verhalten hat einfach mit der Trägheit des Systems zu tun. Wenn ich zu schnell auf die Buttons drücke, dann erscheint die oben beschriebene Fehlermeldung. Inzwischen scheint es nun per Script zu funktionieren.
                                          michael 1975
                                          #409
                                          Also ich kann für meine Geräte sprechen per sricpt/Blockly starten sie ohne Probleme
