  4. Adapter "smartmeter"
3.6k Beiträge 281 Kommentatoren 3.1m Aufrufe 162 Beobachtet
  • Scotty89S Offline
    Scotty89S Offline
    Scotty89
    #2007
    Hey,
    sorry hab den log vergessen ;)
    hier der auszug vom Log wenn man den adapter startet in "Debug Mode"
    smartmeter.0
    2021-08-28 19:32:54.811	debug	connected set to false
    smartmeter.0
    2021-08-28 19:32:54.721	debug	SET MESSAGE TIMEOUT TIMER: 120000
    smartmeter.0
    2021-08-28 19:32:54.713	debug	CREATE SERIALPORT: 9600 8 1 none
    smartmeter.0
    2021-08-28 19:32:54.711	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"2","anotherQueryDelay":"1000","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false}
    smartmeter.0
    2021-08-28 19:32:54.676	info	starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.22.5, js-controller: 3.3.15
    smartmeter.0
    2021-08-28 19:32:54.626	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    smartmeter.0
    2021-08-28 19:32:54.620	debug	Plugin sentry Initialize Plugin (enabled=true)
    smartmeter.0
    2021-08-28 19:32:54.216	debug	statesDB connected
    smartmeter.0
    2021-08-28 19:32:54.214	debug	States connected to redis: 127.0.0.1:9000
    smartmeter.0
    2021-08-28 19:32:54.158	debug	States create User PubSub Client
    smartmeter.0
    2021-08-28 19:32:54.157	debug	States create System PubSub Client
    smartmeter.0
    2021-08-28 19:32:54.144	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    smartmeter.0
    2021-08-28 19:32:54.142	debug	objectDB connected
    smartmeter.0
    2021-08-28 19:32:54.134	debug	Objects connected to redis: 127.0.0.1:9001
    smartmeter.0
    2021-08-28 19:32:54.111	debug	Objects client initialize lua scripts
    smartmeter.0
    2021-08-28 19:32:54.110	debug	Objects create User PubSub Client
    smartmeter.0
    2021-08-28 19:32:54.109	debug	Objects create System PubSub Client
    smartmeter.0
    2021-08-28 19:32:54.107	debug	Objects client ready ... initialize now
    smartmeter.0
    2021-08-28 19:32:54.073	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    MOD-Edit: Code in code-tags gesetzt!
    • Scotty89S Scotty89
      Hey,
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      #2008
      @scotty89 bissl mehr log sollte es schon sein
      Scotty89S 1 Antwort Letzte Antwort
      • apollon77A apollon77
        Scotty89S Offline
        Scotty89S Offline
        Scotty89
        schrieb am zuletzt editiert von Scotty89
        #2009
        @apollon77
        leider kommt da nicht mehr ...
        das ist alles ...
        nach etwas Zeit kommt dann das hier in einer "loop"
          ich habe seit "kurzem" das Problem das der Adapter / das System ganz plötzlich auf gelb springt und dann entsprechend auch keine Daten mehr kommen...
          zu meinem Setup:
          Adatper version 3.2.1 womit ich einen ISKRA typ MT175... auslese
          der adapter hat follgendes Setup:
          Mein Iobroker läuft auf einer Synology DS218+ mit 10GB RAM und die USB ports sind "eigentlich" verfügbar (das regel ich über ein Skript beim hochfahren)
          nun zum Problem..
          eigentlich lief das schon seit gut 1 Jahr sehr stabil und zuverlässig...
          aber seit kurzem springt der adapter auf einmal auf gelb und alles ist tot...
          erst hatte ich den Lesekopf in verdacht, hier nutze ich einen von der Firma Wiedmann...
          aber der scheint es dann doch nicht zu sein den ich habe heute einen neue erhalten und ich bekomme es mit keinem der beiden nun mehr zum laufen ...
          hat jemand eine idee????
          interessant ist das nun der Adapter gar keine verbidung mehr aufbauen kann...
          GlasfaserG Offline
          GlasfaserG Offline
          #2010
          @scotty89 sagte in Adapter "smartmeter":
          nur wenn du DSM 7 hast .
          In der Umgebung bei ENV das eintragen
          /dev/ttyUSB0
          Habe fast den gleichen Lesekopf , es mußte die Bautrate 9600 eingetragen werden .
          Da bin ich auch schon reingefallen bei der Synology , ziehst du den Stick/Lesekopf und stecks Ihn wieder rein geht nichts mehr , obwohl er als USB erkannt wird.
          Da hilft nur ein Neustart des Containers !!!
          • GlasfaserG Glasfaser
            /dev/ttyUSB0
            Scotty89S Offline
            Scotty89S Offline
            Scotty89
            #2011
            @glasfaser sagte in Adapter "smartmeter":
            der Umgebung bei E
            danke dir für den Tipp das ist echt Strange den es lief ja vorher ohne Probleme aber irgendwie sind die USB einstellungen aus dem Container "geflogen" es war in der tat keine USB Weiterleitung mehr aktiv..
            hab es nun follegend aufgenommen:
            nun geht es wieder... mal sehne wie lange....
            du hast "Schon" DSM 7 drauf ? lohnt das ?
            ich hab da irgendwie "Respekt" vor da ja auch USB Geräte wohl Probleme machen ... und ich habe den Lesekopf und ein USB DVBS adapter dran...
              der Umgebung bei E
              GlasfaserG Offline
              GlasfaserG Offline
              #2012
              Sehr gerne ....
              Alles gut ...
              hier in den beigefügten Thread´s kannst du es erlesen :
              https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2507
              bzw. hier:
              https://forum.iobroker.net/topic/40110/docker-install-synology-dsm-7-zigbee-stick-nicht-erkannt
                Sehr gerne ....
                Alles gut ...
                bzw. hier:
                Tobi68
                #2013
                Lese mich derzeit in Sachen Smartmeter ein.
                Funzen USB leseköpfe auch direkt am RPI4 angeschossen auch?
                Hab da auf Ebay was gefunden.
                Ebaybausatz
                • T Tobi68
                  Ebaybausatz
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #2014
                  @tobi68
                  Ja der Funktioniert sehr gut , habe ihn auch . ( an Synology)
                    @tobi68
                    Tobi68
                    #2015
                    @glasfaser
                    Danke, meine DS213+ packt keinen IOBroker.. steht auch nicht beim Zähler..
                    Also kann ich den an den RPI4 einstecken und im Smartmeter adapter ansprechen?
                    GlasfaserG K 2 Antworten Letzte Antwort
                    • T Tobi68
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #2016
                      @tobi68 sagte in Adapter "smartmeter":
                      Ja , ist der Baugleiche wie hier ( Weidmann ) :
                      https://forum.iobroker.net/topic/4685/adapter-smartmeter/871
                      • T Tobi68
                        @glasfaser
                        klassisch
                        #2017
                        @tobi68 Wenn Du Dich mit Linux auskennst und wei0t, wie man USB rebootfest mountet.
                        Wenn Du Zeit und Interesse hast, kannst Du ja meinen Guide lesen. Wobei ich als Linux-Laie und -Minimierer mich auf andere Lösungen konzentriert habe.
                        T apollon77A 2 Antworten Letzte Antwort
                        • K klassisch
                          Tobi68
                          #2018
                          @klassisch
                          Ok,
                          Nee Linux ist nicht gerade meine stärke.. werd mich dann mal einlesen.. Ist bestellt..
                          • K klassisch
                            #2019
                            @klassisch das mounted ist an sich nicht mehr nötig da der Adapter die „by-id“ Pfade nutzt
                            frana120500F 1 Antwort Letzte Antwort
                              frana120500F Online
                              frana120500F Online
                              frana120500
                              #2020
                              Guten Morgen zusammen,
                              ich bekomme keine Werte von meinem Stromzähler rein, wahrscheinlich weil ich falsche Werte in der Konfiguration habe.
                              Ich habe einen EMH mMe 4.0 Zeeirichtungszähler (diesen hier: https://emh-metering.com/wp-content/uploads/2021/06/mMe4.0-BIA-D-1.14.pdf).
                              Zudem habe ich einen IR Lesekopf der an ein USR TCP232 angeschlossen ist (GND an GND, VCC an 3,3v von einem Wemos abgegriffenm TX an RX und RX an TX).
                              Der USR macht ja einen Webserver auf, mit dem ich mich auch verbinden kann. Hier hätte ich ja die ersten Einstellungen vorzunehmen. Komme ich allerdings schon nicht weiter, da ich nicht weiß was.
                              Im Smartmeter Adapter sollten die Einstellungen mE stimmen (lediglich der TCP Port muss auf 20108 stehen). Ich bekomme so natürlich noch keine Daten rein.
                              Hat jemand den Zähler im Einsatz und kann mir hier helfen? Bin auch für andere Lösungen offen.
                              LG
                              F.
                              • frana120500F frana120500
                                LG
                                F.
                                klassisch
                                schrieb am zuletzt editiert von klassisch
                                #2021
                                @frana120500 Den Zähler habe ich nicht. Aber der USR muß auf TCP Server (nicht client wie bei Dir) stehen. Und die ports müssen zueinander passen
                                So z.B. (Achtung, ich habe einen zweikanaligen, nicht verwirren lassen)
                                • K klassisch
                                  frana120500F Online
                                  frana120500F Online
                                  frana120500
                                  #2022
                                  @klassisch klingt logisch. Werde ich gleich mal ändern und testen. Danke
                                    klassisch
                                    #2023
                                    @frana120500 Du findest ein Beispiel im Guide (pdf), S. 40ff.
                                    • K klassisch
                                      frana120500F Online
                                      frana120500F Online
                                      frana120500
                                      #2024
                                      @klassisch mega, danke. Hoffe das hilft mir weiter.
                                      N frana120500F 2 Antworten Letzte Antwort
                                        N Offline
                                        N Offline
                                        NicoS
                                        #2025
                                        Hi zusammen,
                                        nachdem ich kürzlich auch ein EFR SGM-C4 Smartmeter bekommen habe, das ich in iobroker anbinden wollte, bin ich zwangsweise auf diesen Thread hier gestoßen. Möchte hier meine Erfahrungen niederschreiben, die ich mit der Odysee hatte, es mittels Serial Server zum Laufen zu bringen.
                                        Iobroker auf Raspberry steht weit entfernt vom Zählerkasten, dementsprechend war mein Ansatz, einen NodeMCU mit ESPEasy als Serial Server über TCP anzubinden, um damit per Wlan die Verbindung herzustellen. Kurzum: ich hab es mit ESPEasy nicht zum Laufen gebracht.
                                        Setup: Sensor war ein zuerst nach Anleitung umgebauter TCRT-5000, dann ein Hichi IR TTL. Ein NodeMCU ESP8266 4MB it ESPEasy als Firmware; Serial Server konfiguriert mittels Communication-Device basierend auf Ser2Net aber auch in den Advanced Firmware Einstellungen; 9600N1. Sowohl probiert als Software Serial (da kam hauptsächlich Datenmüll mit ein paar lesbaren Fragmenten an), dann auch als Hardware Serial auf allen per Firmware möglichen RX ports (da kam gar nichts an). Input Pullup am RX-Pin an/aus (wo möglich als Software-Einstellung), aber auch Widerstände mit 4-10kOhm gegen V++ probiert, kein Unterschied.
                                        Geschirmte Kabel, kurze Leitungen Kurzum: ESPEasy (Release mega-20210802) hat irgendwelche Bugs oder macht irgendwas mit dem Encoding der Daten und ist für diese Anwendung scheinbar aktuell nicht geeignet. Ich hab nach drei vollen Tagen rumprobieren aufgegeben.
                                        Nach langer Suche habe ich jetzt testweise ESP-Link auf den selben NodeMCU geflashed (https://github.com/jeelabs/esp-link) - selbes Hardware-Setup, selbe Sensorik, selbe Verkabelung - und es funktioniert astrein und auf Anhieb. RX-Pin hängt jetzt am HW-RX-Pin des NodeMCU (GPIO3).
                                        Einschränkungen: TCP-Port nicht konfigurierbar (fix auf 23 - verschmerzbar) & Weboberfläche ist nicht passwortgeschützt (widerstrebt mir selbst im LAN, aber ich muss jetzt erstmal damit leben).
                                        Flashing des NodeMCU ist wegen der Toolchain-Einrichtung ein wenig komplizierter (Python muss installiert werden), aber mit der Anleitung aus der Readme machbar. (Zur Info: die Anleitung ist etwas überholt; unter Windows ist das Kommando für den 4MB/1MB ESP8266 NodeMCU: "esptool.py --port COM7 --baud 460800 write_flash -fs 4MB -ff 80m 0x00000 boot_v1.6.bin 0x1000 user1.bin 0x3FC000 esp_init_data_default.bin 0x3FE000 blank.bin").
                                        Im Anhang zur Info noch ein Output des EFR SGM-C4 Datenstreams, wie er eigentlich aussehen muss, und meine HW-Pin-Settings für den NodeMCU.
                                        Hoffe, dem ein oder anderen damit hoffentlich meinen Frust zu ersparen.
                                          frana120500F Online
                                          frana120500F Online
                                          frana120500
                                          #2026
                                          @frana120500 sagte in Adapter "smartmeter":
                                          Tut es leider nicht. Alles böhmische Dörfer für mich.
                                          Ich hab schon zig Einstellungen durch, aber bekomme gar keine Werte rein.
                                          Muss ich TX/RX kreuzen? da liest man auch unterschiedliches drüber.
                                          Ich vermute fast, dass mein Zähler gar nix sendet.
