  4. [gelöst]Zigbee Stick wird nach Update nicht gefunden!
    6.5k
15 Beiträge 5 Kommentatoren 522 Aufrufe 5 Beobachtet
  • J Offline
    jwedenig
    schrieb am zuletzt editiert von jwedenig
    Hi:
    Folgende Fehlermeldung:
    You need save and run adapter before pairing!
    Log:
    v5.1.23
    Log-Größe: 1.7 MB
    Zeit
    error
    Nachricht
    zigbee.0
    2021-08-28 21:58:36.434	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    zigbee.0
    2021-08-28 21:49:39.184	error	Error herdsman start
    zigbee.0
    2021-08-28 21:49:39.183	error	Failed to start Zigbee
    zigbee.0
    2021-08-28 21:49:39.181	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00'"
    zigbee.0
    2021-08-28 21:49:35.876	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    zigbee.0
    2021-08-28 21:49:29.164	error	Error herdsman start
    zigbee.0
    2021-08-28 21:49:29.163	error	Failed to start Zigbee
    zigbee.0
    2021-08-28 21:49:29.162	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00'"
    zigbee.0
    2021-08-28 21:49:22.581	error	Cannot read property 'getEntries' of null
    zigbee.0
    2021-08-28 21:49:22.580	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:95:5)
    zigbee.0
    2021-08-28 21:49:22.579	error	unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0
    2021-08-28 21:49:22.578	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2021-08-28 21:49:11.041	error	Error herdsman start
    zigbee.0
    2021-08-28 21:49:11.041	error	Failed to start Zigbee
    zigbee.0
    2021-08-28 21:49:11.040	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00'"
    zigbee.0
    2021-08-28 21:49:01.033	error	Error herdsman start
    zigbee.0
    2021-08-28 21:49:01.033	error	Failed to start Zigbee
    zigbee.0
    2021-08-28 21:49:01.032	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00'"
    vis.0
    2021-08-28 21:48:49.071	error	License is invalid! Nothing updated. Error: invalid
    Wer eine Idee?
    Reboot schon gemacht!
    Danke für die Hilfe!
    • J jwedenig
      Hi:
      Log:
      v5.1.23
      Log-Größe: 1.7 MB
      Zeit
      error
      Nachricht
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      vis.0
      Wer eine Idee?
      GlasfaserG Offline
      GlasfaserG Offline
      @jwedenig sagte in Zigbee Stick wird nach Update nicht gefunden!:
      cannot open
      Ausgabe von :
      ls -l /dev/serial/by-id/*
      • GlasfaserG Glasfaser
        cannot open
        Ausgabe von :
        jwedenig
        @glasfaser sagte in Zigbee Stick wird nach Update nicht gefunden!:
        Morgen:
        jwedenig@iobroker2021:~ $ ls -l /dev/serial/by-id/*
        lrwxrwxrwx 1 root root 13 Aug 28 22:06 /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00 -> ../../ttyACM0
        E P 2 Antworten Letzte Antwort
        • J jwedenig
          Morgen:
          Einstein67
          schrieb am zuletzt editiert von Einstein67
          Welches Update hast du gemacht?
          Adapter, Stick, Linux oder Proxmox auf V7 ... ?
          • J jwedenig
            Morgen:
            PsyGanja
            @jwedenig
            Was sagt
            test -w /dev/ttyACM0 && echo success || echo failure
            • E Einstein67
              jwedenig
              @einstein67
              18 Adapter aktualisiert, admin aktualisiert, js - controller aktualisiert
              • P PsyGanja
                @jwedenig
                Was sagt
                jwedenig
                @psyganja sagte in Zigbee Stick wird nach Update nicht gefunden!:
                bei dieser Eingabe passiert nichts
                J Thomas BraunT 2 Antworten Letzte Antwort
                • J jwedenig
                  jwedenig
                  Weiters funktioniert nach den Updates auch meine VIS nicht mehr:
                  Keine gültige vis Lizenz gefunden! Bitte vis Instanz prüfen.
                  Merkwürdig, bei Lizenz prüfen kommt folgendes:
                  Service ist momentan nicht erreichbar oder keine Internetverbindung vorhanden. Bitte fersuchen Sie später noch ein mal oder prüfen Sie die Internetverbindung.
                  "Versuchen mit F" :-)
                  • J jwedenig
                    @jwedenig
                    Kann es sein, dass dir da ein / vor dem Link fehlt?
                    müsste eigentlich
                    open /dev/serial/by-id/usb-T
                    lauten.
                    vis ist ein anderes Thema. Bitte danach suchen oder einen eigenen Thread dazu eröffnen.
                      @jwedenig
                      müsste eigentlich
                      lauten.
                      jwedenig
                      @thomas-braun sagte in Zigbee Stick wird nach Update nicht gefunden!:
                      wenn ja, wie kann ich es ändern?
                      Es hat aber vor dem Update alles wunderbar funktioniert
                      • J jwedenig
                        @jwedenig
                        In den Einstellungen des Adapters.
                        J 2 Antworten Letzte Antwort
                          @jwedenig
                          jwedenig
                          ich probiers mal und mach dann einen Reboot und melde mich, danke
                            @jwedenig
                            jwedenig
                            Super, das wars, ist scheinbar beim Update verloren gegangen, danke!
                            Jetzt such ich mal nach meinem VIS Problem, da ist scheinbar auch was falsch!
                            Oder weißt Du spontan Abhilfe!
                            Danke Dir sehr herzlich!
                            Jürgen
                            • J jwedenig
                              Jürgen
                              jwedenig
                              So, habe eine neue Vis Lizenz bestellt, jetzt ist alles verbunden nur findet er leider meine VIS Datei nicht mehr!
                              Ist zum Haareraufen!
                              • J jwedenig
                                jwedenig
                                @jwedenig
                                alles gut, habs mit Backup wieder geschafft!
                                Danke nochmals!
