<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst]Zigbee Stick wird nach Update nicht gefunden!]]></title><description><![CDATA[<p dir="auto">Hi:<br />
Folgende Fehlermeldung:<br />
You need save and run adapter before pairing!</p>
<p dir="auto">Log:</p>
<pre><code>
v5.1.23
Log-Größe: 1.7 MB
Zeit
error
Nachricht
zigbee.0
2021-08-28 21:58:36.434	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
zigbee.0
2021-08-28 21:49:39.184	error	Error herdsman start
zigbee.0
2021-08-28 21:49:39.183	error	Failed to start Zigbee
zigbee.0
2021-08-28 21:49:39.181	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00'"
zigbee.0
2021-08-28 21:49:35.876	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
zigbee.0
2021-08-28 21:49:29.164	error	Error herdsman start
zigbee.0
2021-08-28 21:49:29.163	error	Failed to start Zigbee
zigbee.0
2021-08-28 21:49:29.162	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00'"
zigbee.0
2021-08-28 21:49:22.581	error	Cannot read property 'getEntries' of null
zigbee.0
2021-08-28 21:49:22.580	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:95:5)
zigbee.0
2021-08-28 21:49:22.579	error	unhandled promise rejection: Cannot read property 'getEntries' of null
zigbee.0
2021-08-28 21:49:22.578	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
zigbee.0
2021-08-28 21:49:11.041	error	Error herdsman start
zigbee.0
2021-08-28 21:49:11.041	error	Failed to start Zigbee
zigbee.0
2021-08-28 21:49:11.040	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00'"
zigbee.0
2021-08-28 21:49:01.033	error	Error herdsman start
zigbee.0
2021-08-28 21:49:01.033	error	Failed to start Zigbee
zigbee.0
2021-08-28 21:49:01.032	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00'"
vis.0
2021-08-28 21:48:49.071	error	License is invalid! Nothing updated. Error: invalid
</code></pre>
<p dir="auto">Wer eine Idee?</p>
<p dir="auto">Reboot schon gemacht!</p>
<p dir="auto">Danke für die Hilfe!</p>
]]></description><link>https://forum.iobroker.net/topic/47398/gelöst-zigbee-stick-wird-nach-update-nicht-gefunden</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 12:25:07 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/47398.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Aug 2021 20:01:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 09:05:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a><br />
alles gut, habs mit Backup wieder geschafft!<br />
Danke nochmals!</p>
]]></description><link>https://forum.iobroker.net/post/671118</link><guid isPermaLink="true">https://forum.iobroker.net/post/671118</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 09:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 08:45:12 GMT]]></title><description><![CDATA[<p dir="auto">So, habe eine neue Vis Lizenz bestellt, jetzt ist alles verbunden nur findet er leider meine VIS Datei nicht mehr!<br />
Ist zum Haareraufen!</p>
]]></description><link>https://forum.iobroker.net/post/671100</link><guid isPermaLink="true">https://forum.iobroker.net/post/671100</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 08:45:12 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 08:12:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Super, das wars, ist scheinbar beim Update verloren gegangen, danke!</p>
<p dir="auto">Jetzt such ich mal nach meinem VIS Problem, da ist scheinbar auch was falsch!<br />
Oder weißt Du spontan Abhilfe!</p>
<p dir="auto">Danke Dir sehr herzlich!</p>
<p dir="auto">Jürgen</p>
]]></description><link>https://forum.iobroker.net/post/671075</link><guid isPermaLink="true">https://forum.iobroker.net/post/671075</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 08:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 08:07:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">ich probiers mal und mach dann einen Reboot und melde mich, danke</p>
]]></description><link>https://forum.iobroker.net/post/671072</link><guid isPermaLink="true">https://forum.iobroker.net/post/671072</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 08:07:25 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 07:40:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a><br />
In den Einstellungen des Adapters.</p>
]]></description><link>https://forum.iobroker.net/post/671055</link><guid isPermaLink="true">https://forum.iobroker.net/post/671055</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:40:41 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 07:37:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/671047">Zigbee Stick wird nach Update nicht gefunden!</a>:</p>
<blockquote>
<p dir="auto">open dev/serial/by-id/usb-T</p>
</blockquote>
<p dir="auto">wenn ja, wie kann ich es ändern?</p>
<p dir="auto">Es hat aber vor dem Update alles wunderbar funktioniert</p>
]]></description><link>https://forum.iobroker.net/post/671049</link><guid isPermaLink="true">https://forum.iobroker.net/post/671049</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:37:15 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 07:35:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a></p>
<p dir="auto">Kann es sein, dass dir da ein / vor dem Link fehlt?</p>
<pre><code>open dev/serial/by-id/usb-T
</code></pre>
<p dir="auto">müsste eigentlich</p>
<pre><code>open /dev/serial/by-id/usb-T
</code></pre>
<p dir="auto">lauten.</p>
<p dir="auto">vis ist ein anderes Thema. Bitte danach suchen oder einen eigenen Thread dazu eröffnen.</p>
]]></description><link>https://forum.iobroker.net/post/671047</link><guid isPermaLink="true">https://forum.iobroker.net/post/671047</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:35:21 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 07:33:38 GMT]]></title><description><![CDATA[<p dir="auto">Weiters funktioniert nach den Updates auch meine VIS nicht mehr:</p>
<p dir="auto">Keine gültige vis Lizenz gefunden! Bitte vis Instanz prüfen.</p>
<p dir="auto">Merkwürdig, bei Lizenz prüfen kommt folgendes:<br />
Service ist momentan nicht erreichbar oder keine Internetverbindung vorhanden. Bitte fersuchen Sie später noch ein mal oder prüfen Sie die Internetverbindung.</p>
<p dir="auto">"Versuchen mit F" :-)</p>
]]></description><link>https://forum.iobroker.net/post/671046</link><guid isPermaLink="true">https://forum.iobroker.net/post/671046</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:33:38 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 07:29:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/psyganja" aria-label="Profile: psyganja">@<bdi>psyganja</bdi></a> sagte in <a href="/post/671038">Zigbee Stick wird nach Update nicht gefunden!</a>:</p>
<blockquote>
<p dir="auto">test -w /dev/ttyACM0 &amp;&amp; echo success || echo failure</p>
</blockquote>
<p dir="auto">bei dieser Eingabe passiert nichts</p>
]]></description><link>https://forum.iobroker.net/post/671043</link><guid isPermaLink="true">https://forum.iobroker.net/post/671043</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:29:18 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 07:28:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/einstein67" aria-label="Profile: einstein67">@<bdi>einstein67</bdi></a></p>
<p dir="auto">18 Adapter aktualisiert, admin aktualisiert, js - controller aktualisiert</p>
]]></description><link>https://forum.iobroker.net/post/671041</link><guid isPermaLink="true">https://forum.iobroker.net/post/671041</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:28:09 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 07:11:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a><br />
Was sagt</p>
<pre><code>test -w /dev/ttyACM0 &amp;&amp; echo success || echo failure
</code></pre>
]]></description><link>https://forum.iobroker.net/post/671038</link><guid isPermaLink="true">https://forum.iobroker.net/post/671038</guid><dc:creator><![CDATA[PsyGanja]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:11:44 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 07:11:23 GMT]]></title><description><![CDATA[<p dir="auto">Welches Update hast du gemacht?</p>
<p dir="auto">Adapter, Stick, Linux oder Proxmox auf V7 ... ?</p>
]]></description><link>https://forum.iobroker.net/post/671037</link><guid isPermaLink="true">https://forum.iobroker.net/post/671037</guid><dc:creator><![CDATA[Einstein67]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:11:23 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sun, 29 Aug 2021 06:38:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a> sagte in <a href="/post/670983">Zigbee Stick wird nach Update nicht gefunden!</a>:</p>
<blockquote>
<p dir="auto">ls -l /dev/serial/by-id/*</p>
</blockquote>
<p dir="auto">Morgen:</p>
<pre><code>jwedenig@iobroker2021:~ $ ls -l /dev/serial/by-id/*
lrwxrwxrwx 1 root root 13 Aug 28 22:06 /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00 -&gt; ../../ttyACM0
</code></pre>
]]></description><link>https://forum.iobroker.net/post/671031</link><guid isPermaLink="true">https://forum.iobroker.net/post/671031</guid><dc:creator><![CDATA[jwedenig]]></dc:creator><pubDate>Sun, 29 Aug 2021 06:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst]Zigbee Stick wird nach Update nicht gefunden! on Sat, 28 Aug 2021 20:15:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jwedenig" aria-label="Profile: jwedenig">@<bdi>jwedenig</bdi></a> sagte in <a href="/post/670979">Zigbee Stick wird nach Update nicht gefunden!</a>:</p>
<blockquote>
<p dir="auto">cannot open</p>
</blockquote>
<p dir="auto">Ausgabe von :</p>
<pre><code>ls -l /dev/serial/by-id/*
</code></pre>
]]></description><link>https://forum.iobroker.net/post/670983</link><guid isPermaLink="true">https://forum.iobroker.net/post/670983</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Sat, 28 Aug 2021 20:15:38 GMT</pubDate></item></channel></rss>
