  4. eBus Adapter Vaillant
    6.3k
ebusebus adapterproblemerrorerste schritte
395 Beiträge 50 Kommentatoren 166.4k Aufrufe 51 Beobachtet
  • F floret88
    @glasfaser Man glaubt es kaum, aber nach abnehmen des VRC700/4 und neu rauf stecken, ergibt sich nun eine neue Ansicht ;-)
    pi@raspberrypi:~ $ ebusctl i
    version: ebusd 21.2.v21.2
    signal: acquired
    symbol rate: 109
    max symbol rate: 122
    reconnects: 0
    masters: 4
    conditional: 0
    poll: 0
    update: 10
    address 03: master #11
    address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0308;HW=0403", loaded "vaillant/08.hmu.csv"
    address 10: master #2
    address 26: slave, scanned "MF=Vaillant;ID=VR_71;SW=0104;HW=0503"
    address 31: master #8, ebusd
    address 36: slave #8, ebusd
    address 71: master #9
    address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0308;HW=0403"
    pi@raspberrypi:~ $ ebusctl scan result
    1 scan(s) still running
    08;Vaillant;HMU00;0308;0403
    26;Vaillant;VR_71;0104;0503
    76;Vaillant;VWZ00;0308;0403
    pi@raspberrypi:~ $ ebusctl grab result
    1008b507010a / 03828202 = 1
    1008b5110100 / 09d90113000008000100 = 6
    1008b5160111 / 09010506100634060a06 = 1
    1026b5160111 / 090103010e0130010301 = 1
    1026b5230106 / 10ec01f401d5012202df0100800080003c = 34
    1026b5230107 / 0f008000800080008000008000805705 = 34
    1076b5110101 / 09ff3b6010ff690000ff = 33
    1076b5160111 / 00 = 1
    10feb505025c00 = 6
    10feb510020601 = 1
    1008b507020900 / 029f02 = 1
    1008b507020946 / 020202 = 5
    1008b512020464 / 0101 = 1
    1008b5120204ff / 0101 = 1
    1008b513020528 / 0101 = 1
    1076b512030f0000 / 074a030000801302 = 1
    1076b512030f0201 / 0748030000801302 = 33
    1076b51303040d00 / 02ffff = 6
    1008b516081000ffff0200212a / 0b0000ff02001a2b88f5014b = 4
    1008b516081002ffff02008129 / 0b12ffff0200812900000000 = 52
    1026b5030c0700ffffffffffffffffffff / 0101 = 1
    1026b516081000ffff0304212a / 0b2000ff03041a2b00000000 = 3
    1026b516081002ffff0304e12a / 0b2201ff0304e12a00000000 = 28
    1026b5230402000000 / 020105 = 1
    1026b5230402010000 / 020100 = 1
    1026b5230402020000 / 020105 = 1
    1026b5230b0401010100002022000000 / 0101 = 1
    1026b523040201013c / 020105 = 31
    1026b5230402000140 / 020105 = 31
    1026b5230402020146 / 020105 = 31
    1026b5230f05ffffff000000ffffffffffff0000 / 0101 = 32
    1076b51009000000ffffff010000 / 0101 = 31
    1076b510090000ffffffff050000 / 0101 = 1
    Was ist nun alles möglich? oder fehlen hier noch wichtige CSV Konfigurationen?
    Danke und LG
    GlasfaserG Offline
    GlasfaserG Offline
    #243
    @floret88 sagte in eBus Adapter Vaillant:
    Er erkennt aber nur ein Vaillant VR 71 Mischermodul , aber nicht den VRC700.
    Hast du mal alles ausgeschaltet ,so wie das aussieht ist der Bus zusammen gebrochen .
    F 1 Antwort Letzte Antwort
    • C Offline
      Cino
      #244
      Ich würde den Bus mal neustarten ohne das Ersa Modul.
      IOB@RPI4
      Shelly, Zigbee, ebus
      • GlasfaserG Glasfaser
        floret88
        schrieb am zuletzt editiert von floret88
        #245
        @glasfaser Ok. Gibt es hier eine Abfolge wie das Ausschalten / Einschalten zu erfolgen hat.
        @Cino Bzw. wie kann ich den Bus getrennt neu starten? Mittlerweile habe ich auch die Baudrate und auch die Latenzzeit herunter geschraubt.
        Im FHEM Forum wird des weiteren Berichtet, dass man auch am Poti drehen soll. Was sagt Ihr dazu?
        Anscheinend "müllt" auch der USB Adapter von ESERA den Bus ziemlich voll.
        LG
        • F floret88
          LG
          GlasfaserG Offline
          GlasfaserG Offline
          #246
          Du hast aber kein Fehler in deinen Log´s , da würde ich nicht rumschrauben
          Beispiel mit Fehler im Log:
          [bus notice] signal acquired
          [bus error] signal lost
          • F floret88
            @floret88 Des Weiteren wollte ich Euch noch folgendes zeigen, um meine Aussagen zu verifizieren.
            Es sieht gut aus, findet aber keine "richtige" Config Datei :-)
            Kann es sein, dass ich einfach eine nicht unterstützte Software bzw. Hardware seitens Vaillant habe?
            pi@raspberrypi:~ $ sudo ebusd --scanconfig=full --logfile=/var/log/ebusd.log --configpath=/etc/ebusd --loglevel=debug -f
            2021-08-26 12:27:26.977 [main notice] ebusd 21.2.v21.2 started with full scan on device /dev/ttyUSB0
            2021-08-26 12:27:26.977 [main info] loading configuration files from /etc/ebusd
            2021-08-26 12:27:26.977 [main info] reading templates /
            2021-08-26 12:27:26.978 [main info] read templates in /
            2021-08-26 12:27:26.979 [main info] reading file broadcast.csv
            2021-08-26 12:27:26.980 [main info] successfully read file broadcast.csv
            2021-08-26 12:27:26.980 [main info] reading file memory.csv
            2021-08-26 12:27:26.981 [main info] successfully read file memory.csv
            2021-08-26 12:27:26.981 [main info] read config files
            2021-08-26 12:27:26.988 [bus notice] bus started with own address 31/36
            2021-08-26 12:27:26.989 [main info] registering data handlers
            2021-08-26 12:27:26.989 [main info] registered data handlers
            2021-08-26 12:27:26.991 [bus debug] ERR: SYN received during no signal, switching to ready
            2021-08-26 12:27:26.992 [bus notice] signal acquired
            2021-08-26 12:27:29.199 [bus notice] new master 10, master count 2
            2021-08-26 12:27:29.259 [bus notice] new master 03, master count 3
            2021-08-26 12:27:29.259 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:27:29.259 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:27:29.526 [bus notice] new master 71, master count 4
            2021-08-26 12:27:29.526 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:27:29.526 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:27:29.792 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:27:29.792 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:27:30.089 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
            2021-08-26 12:27:30.089 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
            2021-08-26 12:27:30.381 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:27:30.381 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:27:30.647 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:27:30.647 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:27:30.914 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:27:30.914 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:27:31.003 [bus notice] max. symbols per second: 103
            2021-08-26 12:27:32.398 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:27:32.398 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:27:32.643 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:27:32.643 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:27:32.888 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:27:32.888 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:27:33.132 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:27:33.133 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:27:36.989 [main debug] performing regular tasks
            2021-08-26 12:27:36.989 [main notice] starting initial full scan
            2021-08-26 12:27:36.989 [bus info] scan 02 cmd: 3102070400
            2021-08-26 12:27:36.990 [bus debug] start request 31
            2021-08-26 12:27:36.990 [bus debug] arbitration start with 31
            2021-08-26 12:27:39.175 [bus debug] arbitration lost
            2021-08-26 12:27:39.176 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:39.260 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:27:39.261 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:27:39.263 [bus debug] start request 31
            2021-08-26 12:27:39.263 [bus debug] arbitration start with 31
            2021-08-26 12:27:39.441 [bus debug] arbitration lost
            2021-08-26 12:27:39.441 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:39.527 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:27:39.528 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:27:39.529 [bus debug] start request 31
            2021-08-26 12:27:39.529 [bus debug] arbitration start with 31
            2021-08-26 12:27:39.707 [bus debug] arbitration lost
            2021-08-26 12:27:39.707 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:39.793 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:27:39.793 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:27:39.796 [bus debug] start request 31
            2021-08-26 12:27:39.796 [bus debug] arbitration start with 31
            2021-08-26 12:27:39.973 [bus debug] arbitration lost
            2021-08-26 12:27:39.973 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:27:39.974 [bus info] scan 04 cmd: 3104070400
            2021-08-26 12:27:40.090 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
            2021-08-26 12:27:40.090 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
            2021-08-26 12:27:40.092 [bus debug] start request 31
            2021-08-26 12:27:40.092 [bus debug] arbitration start with 31
            2021-08-26 12:27:40.270 [bus debug] arbitration lost
            2021-08-26 12:27:40.270 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:40.383 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:27:40.384 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:27:40.387 [bus debug] start request 31
            2021-08-26 12:27:40.387 [bus debug] arbitration start with 31
            2021-08-26 12:27:40.563 [bus debug] arbitration lost
            2021-08-26 12:27:40.564 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:40.648 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:27:40.649 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:27:40.650 [bus debug] start request 31
            2021-08-26 12:27:40.651 [bus debug] arbitration start with 31
            2021-08-26 12:27:40.828 [bus debug] arbitration lost
            2021-08-26 12:27:40.829 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:40.915 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:27:40.916 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:27:40.918 [bus debug] start request 31
            2021-08-26 12:27:40.918 [bus debug] arbitration start with 31
            2021-08-26 12:27:42.336 [bus debug] arbitration lost
            2021-08-26 12:27:42.337 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:27:42.337 [bus info] scan 05 cmd: 3105070400
            2021-08-26 12:27:42.443 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:27:42.443 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:27:42.446 [bus debug] start request 31
            2021-08-26 12:27:42.446 [bus debug] arbitration start with 31
            2021-08-26 12:27:42.623 [bus debug] arbitration lost
            2021-08-26 12:27:42.624 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:42.688 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:27:42.689 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:27:42.692 [bus debug] start request 31
            2021-08-26 12:27:42.692 [bus debug] arbitration start with 31
            2021-08-26 12:27:42.868 [bus debug] arbitration lost
            2021-08-26 12:27:42.868 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:42.933 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:27:42.934 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:27:42.935 [bus debug] start request 31
            2021-08-26 12:27:42.936 [bus debug] arbitration start with 31
            2021-08-26 12:27:43.113 [bus debug] arbitration lost
            2021-08-26 12:27:43.113 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:43.178 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:27:43.178 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:27:43.179 [bus debug] start request 31
            2021-08-26 12:27:43.179 [bus debug] arbitration start with 31
            2021-08-26 12:27:46.990 [main debug] performing regular tasks
            2021-08-26 12:27:46.990 [bus info] scan 08 cmd: 3108070400
            2021-08-26 12:27:49.220 [bus debug] arbitration lost
            2021-08-26 12:27:49.220 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:27:49.220 [bus info] scan 06 cmd: 3106070400
            2021-08-26 12:27:49.306 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:27:49.306 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:27:49.309 [bus debug] start request 31
            2021-08-26 12:27:49.309 [bus debug] arbitration start with 31
            2021-08-26 12:27:49.486 [bus debug] arbitration lost
            2021-08-26 12:27:49.486 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:49.572 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:27:49.572 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:27:49.574 [bus debug] start request 31
            2021-08-26 12:27:49.574 [bus debug] arbitration start with 31
            2021-08-26 12:27:49.753 [bus debug] arbitration lost
            2021-08-26 12:27:49.753 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:49.839 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:27:49.839 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:27:49.840 [bus debug] start request 31
            2021-08-26 12:27:49.840 [bus debug] arbitration start with 31
            2021-08-26 12:27:50.019 [bus debug] arbitration lost
            2021-08-26 12:27:50.019 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:50.135 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
            2021-08-26 12:27:50.135 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
            2021-08-26 12:27:50.136 [bus debug] start request 31
            2021-08-26 12:27:50.136 [bus debug] arbitration start with 31
            2021-08-26 12:27:50.314 [bus debug] arbitration lost
            2021-08-26 12:27:50.315 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:50.427 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:27:50.428 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:27:50.429 [bus debug] start request 31
            2021-08-26 12:27:50.429 [bus debug] arbitration start with 31
            2021-08-26 12:27:50.607 [bus debug] arbitration lost
            2021-08-26 12:27:50.607 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:50.693 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:27:50.694 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:27:50.694 [bus debug] start request 31
            2021-08-26 12:27:50.694 [bus debug] arbitration start with 31
            2021-08-26 12:27:50.873 [bus debug] arbitration lost
            2021-08-26 12:27:50.873 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:50.959 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:27:50.960 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:27:50.962 [bus debug] start request 31
            2021-08-26 12:27:50.962 [bus debug] arbitration start with 31
            2021-08-26 12:27:51.007 [bus notice] max. symbols per second: 110
            2021-08-26 12:27:52.381 [bus debug] arbitration lost
            2021-08-26 12:27:52.381 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:27:52.381 [main error] scan config 08: ERR: arbitration lost
            2021-08-26 12:27:52.488 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:27:52.488 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:27:52.490 [bus debug] start request 31
            2021-08-26 12:27:52.490 [bus debug] arbitration start with 31
            2021-08-26 12:27:52.669 [bus debug] arbitration lost
            2021-08-26 12:27:52.669 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:27:52.669 [bus info] scan 08 cmd: 3108070400
            2021-08-26 12:27:52.734 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:27:52.734 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:27:52.736 [bus debug] start request 31
            2021-08-26 12:27:52.736 [bus debug] arbitration start with 31
            2021-08-26 12:27:52.914 [bus debug] arbitration lost
            2021-08-26 12:27:52.914 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:52.979 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:27:52.979 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:27:52.981 [bus debug] start request 31
            2021-08-26 12:27:52.981 [bus debug] arbitration start with 31
            2021-08-26 12:27:53.158 [bus debug] arbitration lost
            2021-08-26 12:27:53.158 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:53.223 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:27:53.223 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:27:53.225 [bus debug] start request 31
            2021-08-26 12:27:53.225 [bus debug] arbitration start with 31
            2021-08-26 12:27:54.382 [main debug] performing regular tasks
            2021-08-26 12:27:54.382 [bus info] scan 15 cmd: 3115070400
            2021-08-26 12:27:59.264 [bus debug] arbitration lost
            2021-08-26 12:27:59.264 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:59.351 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:27:59.351 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:27:59.353 [bus debug] start request 31
            2021-08-26 12:27:59.353 [bus debug] arbitration start with 31
            2021-08-26 12:27:59.531 [bus debug] arbitration lost
            2021-08-26 12:27:59.531 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:27:59.617 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:27:59.617 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:27:59.618 [bus debug] start request 31
            2021-08-26 12:27:59.619 [bus debug] arbitration start with 31
            2021-08-26 12:27:59.799 [bus debug] arbitration lost
            2021-08-26 12:27:59.799 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:27:59.799 [bus info] scan 09 cmd: 3109070400
            2021-08-26 12:27:59.884 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:27:59.884 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:27:59.886 [bus debug] start request 31
            2021-08-26 12:27:59.886 [bus debug] arbitration start with 31
            2021-08-26 12:28:00.064 [bus debug] arbitration lost
            2021-08-26 12:28:00.064 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:00.182 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e90100800080003c
            2021-08-26 12:28:00.182 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e90100800080003c
            2021-08-26 12:28:00.185 [bus debug] start request 31
            2021-08-26 12:28:00.185 [bus debug] arbitration start with 31
            2021-08-26 12:28:00.361 [bus debug] arbitration lost
            2021-08-26 12:28:00.361 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:00.473 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:00.473 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:00.475 [bus debug] start request 31
            2021-08-26 12:28:00.475 [bus debug] arbitration start with 31
            2021-08-26 12:28:00.654 [bus debug] arbitration lost
            2021-08-26 12:28:00.654 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:00.739 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:00.739 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:00.741 [bus debug] start request 31
            2021-08-26 12:28:00.741 [bus debug] arbitration start with 31
            2021-08-26 12:28:00.918 [bus debug] arbitration lost
            2021-08-26 12:28:00.918 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:01.005 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:01.005 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:01.006 [bus debug] start request 31
            2021-08-26 12:28:01.006 [bus debug] arbitration start with 31
            2021-08-26 12:28:02.426 [bus debug] arbitration lost
            2021-08-26 12:28:02.426 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:02.427 [main error] scan config 15: ERR: arbitration lost
            2021-08-26 12:28:02.533 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:02.533 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:02.534 [bus debug] start request 31
            2021-08-26 12:28:02.534 [bus debug] arbitration start with 31
            2021-08-26 12:28:02.714 [bus debug] arbitration lost
            2021-08-26 12:28:02.714 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:02.778 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:02.778 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:02.780 [bus debug] start request 31
            2021-08-26 12:28:02.780 [bus debug] arbitration start with 31
            2021-08-26 12:28:02.958 [bus debug] arbitration lost
            2021-08-26 12:28:02.958 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:02.958 [bus info] scan 0a cmd: 310a070400
            2021-08-26 12:28:03.023 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:03.023 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:03.025 [bus debug] start request 31
            2021-08-26 12:28:03.026 [bus debug] arbitration start with 31
            2021-08-26 12:28:03.203 [bus debug] arbitration lost
            2021-08-26 12:28:03.203 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:03.268 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:03.268 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:03.271 [bus debug] start request 31
            2021-08-26 12:28:03.271 [bus debug] arbitration start with 31
            2021-08-26 12:28:04.427 [main debug] performing regular tasks
            2021-08-26 12:28:04.427 [bus info] scan 26 cmd: 3126070400
            2021-08-26 12:28:09.316 [bus debug] arbitration lost
            2021-08-26 12:28:09.316 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:09.403 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:09.403 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:09.405 [bus debug] start request 31
            2021-08-26 12:28:09.405 [bus debug] arbitration start with 31
            2021-08-26 12:28:09.582 [bus debug] arbitration lost
            2021-08-26 12:28:09.582 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:09.668 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:09.668 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:09.671 [bus debug] start request 31
            2021-08-26 12:28:09.671 [bus debug] arbitration start with 31
            2021-08-26 12:28:09.849 [bus debug] arbitration lost
            2021-08-26 12:28:09.849 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:09.935 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:28:09.936 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:28:09.938 [bus debug] start request 31
            2021-08-26 12:28:09.939 [bus debug] arbitration start with 31
            2021-08-26 12:28:10.115 [bus debug] arbitration lost
            2021-08-26 12:28:10.115 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:10.144 [update info] received BC cmd: 10feb505025c00
            2021-08-26 12:28:10.144 [update notice] received unknown BC cmd: 10feb505025c00
            2021-08-26 12:28:10.146 [bus debug] start request 31
            2021-08-26 12:28:10.146 [bus debug] arbitration start with 31
            2021-08-26 12:28:10.325 [bus debug] arbitration lost
            2021-08-26 12:28:10.325 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:10.325 [bus info] scan 0b cmd: 310b070400
            2021-08-26 12:28:10.442 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
            2021-08-26 12:28:10.443 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
            2021-08-26 12:28:10.444 [bus debug] start request 31
            2021-08-26 12:28:10.445 [bus debug] arbitration start with 31
            2021-08-26 12:28:10.621 [bus debug] arbitration lost
            2021-08-26 12:28:10.622 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:10.733 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:10.734 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:10.735 [bus debug] start request 31
            2021-08-26 12:28:10.735 [bus debug] arbitration start with 31
            2021-08-26 12:28:10.914 [bus debug] arbitration lost
            2021-08-26 12:28:10.914 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:11.001 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:11.001 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:11.004 [bus debug] start request 31
            2021-08-26 12:28:11.005 [bus debug] arbitration start with 31
            2021-08-26 12:28:11.182 [bus debug] arbitration lost
            2021-08-26 12:28:11.182 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:11.182 [main error] scan config 26: ERR: arbitration lost
            2021-08-26 12:28:11.247 [update info] received MS cmd: 1008b507020900 / 029f02
            2021-08-26 12:28:11.247 [update notice] received unknown MS cmd: 1008b507020900 / 029f02
            2021-08-26 12:28:11.249 [bus debug] start request 31
            2021-08-26 12:28:11.249 [bus debug] arbitration start with 31
            2021-08-26 12:28:11.426 [bus debug] arbitration lost
            2021-08-26 12:28:11.426 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:11.513 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:11.513 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:11.514 [bus debug] start request 31
            2021-08-26 12:28:11.515 [bus debug] arbitration start with 31
            2021-08-26 12:28:11.693 [bus debug] arbitration lost
            2021-08-26 12:28:11.693 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:11.781 [update info] received MS cmd: 1008b5040100 / 0a03122812260804210013
            2021-08-26 12:28:11.781 [update notice] received unknown MS cmd: 1008b5040100 / 0a03122812260804210013
            2021-08-26 12:28:11.784 [bus debug] start request 31
            2021-08-26 12:28:11.784 [bus debug] arbitration start with 31
            2021-08-26 12:28:11.962 [bus debug] arbitration lost
            2021-08-26 12:28:11.962 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:11.962 [bus info] scan 0c cmd: 310c070400
            2021-08-26 12:28:12.017 [update info] received BC cmd: 10feb516080010281226080421
            2021-08-26 12:28:12.017 [update notice] received unknown BC cmd: 10feb516080010281226080421
            2021-08-26 12:28:12.018 [bus debug] start request 31
            2021-08-26 12:28:12.018 [bus debug] arbitration start with 31
            2021-08-26 12:28:12.197 [bus debug] arbitration lost
            2021-08-26 12:28:12.197 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:12.283 [update info] received MS cmd: 1008b5110100 / 09030214000000000100
            2021-08-26 12:28:12.283 [update notice] received unknown MS cmd: 1008b5110100 / 09030214000000000100
            2021-08-26 12:28:12.284 [bus debug] start request 31
            2021-08-26 12:28:12.284 [bus debug] arbitration start with 31
            2021-08-26 12:28:12.463 [bus debug] arbitration lost
            2021-08-26 12:28:12.463 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:12.529 [update info] received MS cmd: 1076b51303040d00 / 02ffff
            2021-08-26 12:28:12.529 [update notice] received unknown MS cmd: 1076b51303040d00 / 02ffff
            2021-08-26 12:28:12.530 [bus debug] start request 31
            2021-08-26 12:28:12.530 [bus debug] arbitration start with 31
            2021-08-26 12:28:12.708 [bus debug] arbitration lost
            2021-08-26 12:28:12.708 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:12.815 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:12.815 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:12.816 [bus debug] start request 31
            2021-08-26 12:28:12.816 [bus debug] arbitration start with 31
            2021-08-26 12:28:12.995 [bus debug] arbitration lost
            2021-08-26 12:28:12.995 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:12.995 [bus info] scan 0d cmd: 310d070400
            2021-08-26 12:28:13.060 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:13.060 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:13.062 [bus debug] start request 31
            2021-08-26 12:28:13.062 [bus debug] arbitration start with 31
            2021-08-26 12:28:13.182 [main debug] performing regular tasks
            2021-08-26 12:28:13.182 [bus info] scan 76 cmd: 3176070400
            2021-08-26 12:28:13.239 [bus debug] arbitration lost
            2021-08-26 12:28:13.240 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:13.303 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:13.304 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:13.305 [bus debug] start request 31
            2021-08-26 12:28:13.306 [bus debug] arbitration start with 31
            2021-08-26 12:28:13.483 [bus debug] arbitration lost
            2021-08-26 12:28:13.484 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:13.517 [update info] received BC cmd: 10feb51603010013
            2021-08-26 12:28:13.518 [update notice] received unknown BC cmd: 10feb51603010013
            2021-08-26 12:28:13.519 [bus debug] start request 31
            2021-08-26 12:28:13.519 [bus debug] arbitration start with 31
            2021-08-26 12:28:13.697 [bus debug] arbitration lost
            2021-08-26 12:28:13.697 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:13.763 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:13.764 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:13.766 [bus debug] start request 31
            2021-08-26 12:28:13.766 [bus debug] arbitration start with 31
            2021-08-26 12:28:19.343 [bus debug] arbitration lost
            2021-08-26 12:28:19.344 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:19.430 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:19.431 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:19.432 [bus debug] start request 31
            2021-08-26 12:28:19.432 [bus debug] arbitration start with 31
            2021-08-26 12:28:19.610 [bus debug] arbitration lost
            2021-08-26 12:28:19.610 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:19.697 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:19.698 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:19.699 [bus debug] start request 31
            2021-08-26 12:28:19.699 [bus debug] arbitration start with 31
            2021-08-26 12:28:19.877 [bus debug] arbitration lost
            2021-08-26 12:28:19.878 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:19.963 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:28:19.964 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:28:19.967 [bus debug] start request 31
            2021-08-26 12:28:19.967 [bus debug] arbitration start with 31
            2021-08-26 12:28:20.145 [bus debug] arbitration lost
            2021-08-26 12:28:20.146 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:20.147 [bus info] scan 0e cmd: 310e070400
            2021-08-26 12:28:20.262 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
            2021-08-26 12:28:20.263 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
            2021-08-26 12:28:20.266 [bus debug] start request 31
            2021-08-26 12:28:20.266 [bus debug] arbitration start with 31
            2021-08-26 12:28:20.441 [bus debug] arbitration lost
            2021-08-26 12:28:20.442 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:20.442 [main error] scan config 76: ERR: arbitration lost
            2021-08-26 12:28:20.554 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:20.555 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:20.558 [bus debug] start request 31
            2021-08-26 12:28:20.558 [bus debug] arbitration start with 31
            2021-08-26 12:28:20.735 [bus debug] arbitration lost
            2021-08-26 12:28:20.735 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:20.822 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:20.822 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:20.824 [bus debug] start request 31
            2021-08-26 12:28:20.824 [bus debug] arbitration start with 31
            2021-08-26 12:28:21.002 [bus debug] arbitration lost
            2021-08-26 12:28:21.002 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:21.089 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:21.089 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:21.091 [bus debug] start request 31
            2021-08-26 12:28:21.091 [bus debug] arbitration start with 31
            2021-08-26 12:28:22.443 [main debug] performing regular tasks
            2021-08-26 12:28:22.510 [bus debug] arbitration lost
            2021-08-26 12:28:22.510 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:22.617 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:22.617 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:22.619 [bus debug] start request 31
            2021-08-26 12:28:22.619 [bus debug] arbitration start with 31
            2021-08-26 12:28:22.798 [bus debug] arbitration lost
            2021-08-26 12:28:22.798 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:22.798 [bus info] scan 12 cmd: 3112070400
            2021-08-26 12:28:22.863 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:22.863 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:22.865 [bus debug] start request 31
            2021-08-26 12:28:22.865 [bus debug] arbitration start with 31
            2021-08-26 12:28:23.043 [bus debug] arbitration lost
            2021-08-26 12:28:23.043 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:23.108 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:23.108 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:23.111 [bus debug] start request 31
            2021-08-26 12:28:23.111 [bus debug] arbitration start with 31
            2021-08-26 12:28:23.288 [bus debug] arbitration lost
            2021-08-26 12:28:23.288 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:23.353 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:23.353 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:23.354 [bus debug] start request 31
            2021-08-26 12:28:23.354 [bus debug] arbitration start with 31
            2021-08-26 12:28:29.403 [bus debug] arbitration lost
            2021-08-26 12:28:29.403 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:29.488 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:29.488 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:29.489 [bus debug] start request 31
            2021-08-26 12:28:29.489 [bus debug] arbitration start with 31
            2021-08-26 12:28:29.668 [bus debug] arbitration lost
            2021-08-26 12:28:29.668 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:29.668 [bus info] scan 14 cmd: 3114070400
            2021-08-26 12:28:29.754 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:29.754 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:29.756 [bus debug] start request 31
            2021-08-26 12:28:29.756 [bus debug] arbitration start with 31
            2021-08-26 12:28:29.936 [bus debug] arbitration lost
            2021-08-26 12:28:29.936 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:30.021 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:28:30.021 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:28:30.022 [bus debug] start request 31
            2021-08-26 12:28:30.022 [bus debug] arbitration start with 31
            2021-08-26 12:28:30.201 [bus debug] arbitration lost
            2021-08-26 12:28:30.201 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:30.318 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
            2021-08-26 12:28:30.318 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
            2021-08-26 12:28:30.320 [bus debug] start request 31
            2021-08-26 12:28:30.320 [bus debug] arbitration start with 31
            2021-08-26 12:28:30.498 [bus debug] arbitration lost
            2021-08-26 12:28:30.499 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:30.611 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:30.612 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:30.613 [bus debug] start request 31
            2021-08-26 12:28:30.613 [bus debug] arbitration start with 31
            2021-08-26 12:28:30.791 [bus debug] arbitration lost
            2021-08-26 12:28:30.791 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:30.792 [bus info] scan 15 cmd: 3115070400
            2021-08-26 12:28:30.879 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:30.880 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:30.882 [bus debug] start request 31
            2021-08-26 12:28:30.882 [bus debug] arbitration start with 31
            2021-08-26 12:28:31.059 [bus debug] arbitration lost
            2021-08-26 12:28:31.059 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:31.145 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:31.145 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:31.148 [bus debug] start request 31
            2021-08-26 12:28:31.148 [bus debug] arbitration start with 31
            2021-08-26 12:28:32.444 [main debug] performing regular tasks
            2021-08-26 12:28:32.444 [bus info] scan 08 cmd: 3108070400
            2021-08-26 12:28:32.526 [bus debug] arbitration lost
            2021-08-26 12:28:32.526 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:32.633 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:32.633 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:32.634 [bus debug] start request 31
            2021-08-26 12:28:32.635 [bus debug] arbitration start with 31
            2021-08-26 12:28:32.813 [bus debug] arbitration lost
            2021-08-26 12:28:32.813 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:32.878 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:32.878 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:32.880 [bus debug] start request 31
            2021-08-26 12:28:32.880 [bus debug] arbitration start with 31
            2021-08-26 12:28:33.058 [bus debug] arbitration lost
            2021-08-26 12:28:33.058 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:33.122 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:33.122 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:33.124 [bus debug] start request 31
            2021-08-26 12:28:33.124 [bus debug] arbitration start with 31
            2021-08-26 12:28:33.302 [bus debug] arbitration lost
            2021-08-26 12:28:33.302 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:33.367 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:33.367 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:33.369 [bus debug] start request 31
            2021-08-26 12:28:33.369 [bus debug] arbitration start with 31
            2021-08-26 12:28:39.419 [bus debug] arbitration lost
            2021-08-26 12:28:39.419 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:39.419 [bus info] scan 16 cmd: 3116070400
            2021-08-26 12:28:39.505 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:39.505 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:39.508 [bus debug] start request 31
            2021-08-26 12:28:39.508 [bus debug] arbitration start with 31
            2021-08-26 12:28:39.685 [bus debug] arbitration lost
            2021-08-26 12:28:39.685 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:39.771 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:39.771 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:39.773 [bus debug] start request 31
            2021-08-26 12:28:39.773 [bus debug] arbitration start with 31
            2021-08-26 12:28:39.952 [bus debug] arbitration lost
            2021-08-26 12:28:39.952 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:40.038 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:28:40.038 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
            2021-08-26 12:28:40.041 [bus debug] start request 31
            2021-08-26 12:28:40.041 [bus debug] arbitration start with 31
            2021-08-26 12:28:40.218 [bus debug] arbitration lost
            2021-08-26 12:28:40.218 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:40.218 [main error] scan config 08: ERR: arbitration lost
            2021-08-26 12:28:40.334 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
            2021-08-26 12:28:40.334 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
            2021-08-26 12:28:40.335 [bus debug] start request 31
            2021-08-26 12:28:40.335 [bus debug] arbitration start with 31
            2021-08-26 12:28:40.514 [bus debug] arbitration lost
            2021-08-26 12:28:40.514 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:40.627 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:40.627 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:40.628 [bus debug] start request 31
            2021-08-26 12:28:40.628 [bus debug] arbitration start with 31
            2021-08-26 12:28:40.807 [bus debug] arbitration lost
            2021-08-26 12:28:40.807 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:40.893 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:40.893 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:40.895 [bus debug] start request 31
            2021-08-26 12:28:40.895 [bus debug] arbitration start with 31
            2021-08-26 12:28:41.072 [bus debug] arbitration lost
            2021-08-26 12:28:41.072 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:41.072 [bus info] scan 18 cmd: 3118070400
            2021-08-26 12:28:41.159 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:41.159 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:41.161 [bus debug] start request 31
            2021-08-26 12:28:41.161 [bus debug] arbitration start with 31
            2021-08-26 12:28:42.218 [main debug] performing regular tasks
            2021-08-26 12:28:42.219 [bus info] scan 15 cmd: 3115070400
            2021-08-26 12:28:42.579 [bus debug] arbitration lost
            2021-08-26 12:28:42.579 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:42.686 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:42.687 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:42.689 [bus debug] start request 31
            2021-08-26 12:28:42.689 [bus debug] arbitration start with 31
            2021-08-26 12:28:42.866 [bus debug] arbitration lost
            2021-08-26 12:28:42.866 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:42.931 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:42.931 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:42.933 [bus debug] start request 31
            2021-08-26 12:28:42.933 [bus debug] arbitration start with 31
            2021-08-26 12:28:43.111 [bus debug] arbitration lost
            2021-08-26 12:28:43.111 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:43.176 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:43.176 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:43.178 [bus debug] start request 31
            2021-08-26 12:28:43.178 [bus debug] arbitration start with 31
            2021-08-26 12:28:43.356 [bus debug] arbitration lost
            2021-08-26 12:28:43.356 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:43.421 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:43.421 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:43.424 [bus debug] start request 31
            2021-08-26 12:28:43.424 [bus debug] arbitration start with 31
            2021-08-26 12:28:49.471 [bus debug] arbitration lost
            2021-08-26 12:28:49.471 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:49.557 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:49.557 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:49.560 [bus debug] start request 31
            2021-08-26 12:28:49.560 [bus debug] arbitration start with 31
            2021-08-26 12:28:49.738 [bus debug] arbitration lost
            2021-08-26 12:28:49.738 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:49.824 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:49.824 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:49.825 [bus debug] start request 31
            2021-08-26 12:28:49.826 [bus debug] arbitration start with 31
            2021-08-26 12:28:50.005 [bus debug] arbitration lost
            2021-08-26 12:28:50.005 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:50.005 [bus info] scan 19 cmd: 3119070400
            2021-08-26 12:28:50.090 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
            2021-08-26 12:28:50.090 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
            2021-08-26 12:28:50.091 [bus debug] start request 31
            2021-08-26 12:28:50.091 [bus debug] arbitration start with 31
            2021-08-26 12:28:50.270 [bus debug] arbitration lost
            2021-08-26 12:28:50.270 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:50.270 [main error] scan config 15: ERR: arbitration lost
            2021-08-26 12:28:50.387 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
            2021-08-26 12:28:50.387 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
            2021-08-26 12:28:50.390 [bus debug] start request 31
            2021-08-26 12:28:50.390 [bus debug] arbitration start with 31
            2021-08-26 12:28:50.567 [bus debug] arbitration lost
            2021-08-26 12:28:50.567 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:50.679 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:50.679 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:28:50.680 [bus debug] start request 31
            2021-08-26 12:28:50.680 [bus debug] arbitration start with 31
            2021-08-26 12:28:50.859 [bus debug] arbitration lost
            2021-08-26 12:28:50.859 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:50.945 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:50.945 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:28:50.948 [bus debug] start request 31
            2021-08-26 12:28:50.948 [bus debug] arbitration start with 31
            2021-08-26 12:28:51.035 [bus notice] max. symbols per second: 111
            2021-08-26 12:28:51.125 [bus debug] arbitration lost
            2021-08-26 12:28:51.125 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:51.212 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:51.212 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:28:51.213 [bus debug] start request 31
            2021-08-26 12:28:51.213 [bus debug] arbitration start with 31
            2021-08-26 12:28:52.271 [main debug] performing regular tasks
            2021-08-26 12:28:52.271 [bus info] scan 26 cmd: 3126070400
            2021-08-26 12:28:52.591 [bus debug] arbitration lost
            2021-08-26 12:28:52.591 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:28:52.591 [bus info] scan 1a cmd: 311a070400
            2021-08-26 12:28:52.698 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:52.698 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:28:52.700 [bus debug] start request 31
            2021-08-26 12:28:52.700 [bus debug] arbitration start with 31
            2021-08-26 12:28:52.879 [bus debug] arbitration lost
            2021-08-26 12:28:52.879 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:52.944 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:52.944 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:28:52.946 [bus debug] start request 31
            2021-08-26 12:28:52.946 [bus debug] arbitration start with 31
            2021-08-26 12:28:53.123 [bus debug] arbitration lost
            2021-08-26 12:28:53.123 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:53.188 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:53.188 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:28:53.189 [bus debug] start request 31
            2021-08-26 12:28:53.189 [bus debug] arbitration start with 31
            2021-08-26 12:28:53.367 [bus debug] arbitration lost
            2021-08-26 12:28:53.368 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:53.432 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:53.433 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:28:53.435 [bus debug] start request 31
            2021-08-26 12:28:53.435 [bus debug] arbitration start with 31
            2021-08-26 12:28:59.483 [bus debug] arbitration lost
            2021-08-26 12:28:59.484 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:59.570 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:59.571 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:28:59.573 [bus debug] start request 31
            2021-08-26 12:28:59.573 [bus debug] arbitration start with 31
            2021-08-26 12:28:59.751 [bus debug] arbitration lost
            2021-08-26 12:28:59.751 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:28:59.837 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:59.838 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:28:59.839 [bus debug] start request 31
            2021-08-26 12:28:59.839 [bus debug] arbitration start with 31
            2021-08-26 12:29:00.018 [bus debug] arbitration lost
            2021-08-26 12:29:00.018 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:00.103 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
            2021-08-26 12:29:00.103 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
            2021-08-26 12:29:00.104 [bus debug] start request 31
            2021-08-26 12:29:00.104 [bus debug] arbitration start with 31
            2021-08-26 12:29:00.283 [bus debug] arbitration lost
            2021-08-26 12:29:00.283 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:29:00.283 [main error] scan config 26: ERR: arbitration lost
            2021-08-26 12:29:00.400 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
            2021-08-26 12:29:00.400 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
            2021-08-26 12:29:00.403 [bus debug] start request 31
            2021-08-26 12:29:00.403 [bus debug] arbitration start with 31
            2021-08-26 12:29:00.580 [bus debug] arbitration lost
            2021-08-26 12:29:00.580 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:29:00.580 [bus info] scan 1b cmd: 311b070400
            2021-08-26 12:29:00.692 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:29:00.692 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
            2021-08-26 12:29:00.693 [bus debug] start request 31
            2021-08-26 12:29:00.693 [bus debug] arbitration start with 31
            2021-08-26 12:29:00.872 [bus debug] arbitration lost
            2021-08-26 12:29:00.872 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:00.958 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:29:00.958 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
            2021-08-26 12:29:00.961 [bus debug] start request 31
            2021-08-26 12:29:00.961 [bus debug] arbitration start with 31
            2021-08-26 12:29:01.138 [bus debug] arbitration lost
            2021-08-26 12:29:01.138 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:01.225 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:29:01.225 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
            2021-08-26 12:29:01.226 [bus debug] start request 31
            2021-08-26 12:29:01.226 [bus debug] arbitration start with 31
            2021-08-26 12:29:02.284 [main debug] performing regular tasks
            2021-08-26 12:29:02.284 [bus info] scan 76 cmd: 3176070400
            2021-08-26 12:29:02.646 [bus debug] arbitration lost
            2021-08-26 12:29:02.646 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:02.753 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:29:02.753 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
            2021-08-26 12:29:02.755 [bus debug] start request 31
            2021-08-26 12:29:02.755 [bus debug] arbitration start with 31
            2021-08-26 12:29:02.933 [bus debug] arbitration lost
            2021-08-26 12:29:02.933 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:02.998 [update info] received MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:29:02.998 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
            2021-08-26 12:29:03.000 [bus debug] start request 31
            2021-08-26 12:29:03.000 [bus debug] arbitration start with 31
            2021-08-26 12:29:03.178 [bus debug] arbitration lost
            2021-08-26 12:29:03.178 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:29:03.178 [bus info] scan 1c cmd: 311c070400
            2021-08-26 12:29:03.243 [update info] received MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:29:03.243 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
            2021-08-26 12:29:03.244 [bus debug] start request 31
            2021-08-26 12:29:03.244 [bus debug] arbitration start with 31
            2021-08-26 12:29:03.423 [bus debug] arbitration lost
            2021-08-26 12:29:03.423 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:03.488 [update info] received MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:29:03.488 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
            2021-08-26 12:29:03.489 [bus debug] start request 31
            2021-08-26 12:29:03.489 [bus debug] arbitration start with 31
            ^C2021-08-26 12:29:03.645 [main notice] SIGINT received
            2021-08-26 12:29:09.532 [bus debug] arbitration lost
            2021-08-26 12:29:09.532 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:09.619 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:29:09.619 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
            2021-08-26 12:29:09.620 [bus debug] start request 31
            2021-08-26 12:29:09.620 [bus debug] arbitration start with 31
            received unknown MS cmd: 1008b51009000000ffffff070000 / 01012021-08-26 12:29:09.799 [bus debug] arbitration lost
            2021-08-26 12:29:09.799 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:09.885 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:29:09.885 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
            2021-08-26 12:29:09.887 [bus debug] start request 31
            2021-08-26 12:29:09.887 [bus debug] arbitration start with 31
            2021-08-26 12:29:10.066 [bus debug] arbitration lost
            2021-08-26 12:29:10.066 [bus debug] ERR: arbitration lost during ready, retry
            2021-08-26 12:29:10.152 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
            2021-08-26 12:29:10.152 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
            2021-08-26 12:29:10.153 [bus debug] start request 31
            2021-08-26 12:29:10.153 [bus debug] arbitration start with 31
            2021-08-26 12:29:10.331 [bus debug] arbitration lost
            2021-08-26 12:29:10.331 [bus debug] notify request: ERR: arbitration lost
            2021-08-26 12:29:10.331 [main error] scan config 76: ERR: arbitration lost
            2021-08-26 12:29:10.361 [update info] received BC cmd: 10feb505025c00
            2021-08-26 12:29:10.361 [update notice] received unknown BC cmd: 10feb505025c00
            2021-08-26 12:29:10.363 [bus debug] start request 31
            2021-08-26 12:29:10.363 [bus debug] arbitration start with 31
            2021-08-26 12:29:10.454 [main notice] ebusd stopped
            GlasfaserG Offline
            GlasfaserG Offline
            #247
            Diese Meldung hast du auch ,
            Schau mal bei Ihm
            https://forum.iobroker.net/topic/29359/ebus-adapter-vaillant/177
              Schau mal bei Ihm
              floret88
              #248
              @glasfaser klare Aussage von John30 99704C91-1968-4562-B32B-2EE38BB58405.png
              • C Offline
                Cino
                #249
                Verstell bloß nicht die Baudrate. Die muss stimmen.
                Mach den Adapter ab und dann die Therme einmal Stromlos machen. Danach kannste den Adapter wieder verbinden.
                Ist mir auch schon passiert das der Bus abgestürzt ist. Das Polling darf auch nicht so intensiv sein vom Adapter. Damit blockierst du auch den Bus.
                Falls ein Poti vorhanden ist würde ich nicht daran drehen. Die sind schon richtig eingestellt beim Vertrieb,
                IOB@RPI4
                F 2 Antworten Letzte Antwort
                • C Cino
                  floret88
                  #250
                  @cino Standardmäßig war die Baudrate auf 9600 und lt Bedienungsanleitung von Esera soll diese bei 2400 sein! (Brachte keine Änderung!)
                  Ja ich weigere mich Wehement etwas daran zu drehen! Aber langsam will ich das zum laufen bekommen, und versuche jede Nadel im Heuhaufen zu finden!
                  Da gerade die kühle Phase anfängt, möchte ich ungern die Heizung zerstören - werde morgen dennoch den kompletten Neustart der WP probieren und Euch berichten!
                  a200A 1 Antwort Letzte Antwort
                  • F floret88
                    a200A Offline
                    a200A Offline
                    a200
                    #251
                    @floret88 Also das mit dem Drehen ist so eine Sache...
                    Bei meinem Esera-Adapter sehe ich folgende LED:
                    • Anschluss 10: Leuchtet konstant
                    • Pwr: Leuchtet konstant
                    • Data: blinkt unregelmäßig
                    Wenn es bei dir auch so ist, dann kannst du dir wenigstens sicher sein, dass dein Esera Daten empfangen kann.
                    • Sollte die Anschluss 10 LED nicht leuchten, dann hast du ein Problem in der eBus Verkabelung.
                    • Sollte die Power LED nicht leuchten, dann hast du Probleme mit der Stromversorgung bzw. dem USB-Anschluss.
                    • Sollte die Data-LED nicht blinken, dann werden keine Daten empfangen. das kann mehrere Ursachen haben.
                    1. eBus Verkabelung
                    2. Der eBus Signal-Level muss angepasst werden (war bei mir so). In dem Fall musst du an dem kleinen Potentiometer am Adapter leicht drehen. Siehe eBus Anleitungen von John30 im Netz. z.B. https://wiki.fhem.de/wiki/EBUS unter dem Punkt: Poti abgleichen.
                    Wir sind gespannt auf deine Berichte. Viel Erfolg,
                    a200.
                    IoBroker auf QNAP TS-451, Raspi und NUC
                    • C Cino
                      floret88
                      #252
                      @cino Neustart ohne eBus Adapter und anschließenden wieder verbinden, bringt keinen Erfolg!
                      @a200 Alles bereits überprüft, bis auf die Poti Einstellungen.
                      Hier ein kleines Video, damit man sieht - alles OK 🐶
                      https://www.youtube.com/watch?v=5-BFxLjh02g
                      Dann bleibt mir eigtl. nur noch Option: Einstellung am Poti verändern.
                      • F floret88
                        a200A Offline
                        a200A Offline
                        a200
                        #253
                        @floret88 Na dann ist ja aus der Hardware-Sicht alles in Ordnung. Ich hätte weiter oben lesen sollen. Da steht:
                        signal: acquired
                        symbol rate: 109
                        max symbol rate: 122
                        Sorry. Mea culpa.
                        • a200A a200
                          signal: acquired
                          symbol rate: 109
                          Sorry. Mea culpa.
                          floret88
                          #254
                          @a200 kein Problem und ich bekomme langsam einen Nervenzusammenbruch!
                          Jetzt lese ich im Wiki das der Esera USB Adapter ebenfalls Probleme mit der Latency hat. Also am Poti drehen - Die Freude ist riesig wie Ihr euch denken könnt.
                          Des Weiteren auch noch angemeldet für den eBus Adapter v3 🤡 - i don‘t like
                          Werde Euch nach Poti Dreherei auf den aktuellen Stand bringen! Trotzdem Danke an alle für die Versuche mir zu helfen! Danke.
                          • F floret88
                            floret88
                            #255
                            @floret88 nach 2 stündigen Drehen am Poti und x Neustarts des Raspberrys und X mal runter nehmen des VRC habe ich die Nase voll, und lass es bleiben! Abwarten auf den eBus Adapter v3 von John30.
                            Haben fertig, schönes Wochenende
                            • C Offline
                              Cino
                              #256
                              Ich hab den hier, funktioniert top
                              https://www.esera.de/produkte/ebus/135/1-wire-hub-platine
                              IOB@RPI4
                              • C Cino
                                floret88
                                #257
                                @cino Den habe ich auch, und funkt leider nicht zufriedenstellend.
                                C 1 Antwort Letzte Antwort
                                • F floret88
                                  Cino
                                  schrieb am zuletzt editiert von Cino
                                  #258
                                  @floret88 wenn du willst kann ich dir meine config mal schicken.
                                  ebusctl i
                                  version: ebusd 21.2.v21.2
                                  update check: OK
                                  signal: acquired
                                  symbol rate: 23
                                  max symbol rate: 360
                                  min arbitration micros: 319
                                  max arbitration micros: 9955
                                  min symbol latency: 0
                                  max symbol latency: 28
                                  reconnects: 0
                                  masters: 3
                                  conditional: 3
                                  poll: 1
                                  update: 10
                                  address 03: master #11
                                  address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0104;HW=7803", loaded "vaillant/bai.308523.inc", "vaillant/08.bai.csv"
                                  address 10: master #2
                                  address 15: slave #2, scanned "MF=Vaillant;ID=70000;SW=0614;HW=6903", loaded "vaillant/15.700.csv"
                                  address 31: master #8, ebusd
                                  address 36: slave #8, ebusd
                                  address ec: slave, scanned "MF=Vaillant;ID=SOL00;SW=0614;HW=6903", loaded "vaillant/ec.sol.sc.csv"
                                  a# /etc/default/ebusd:
                                  # config file for ebusd service.
                                  # Options to pass to ebusd (run "ebusd -?" for more info):
                                  #EBUSD_OPTS="--scanconfig"
                                  EBUSD_OPTS="--configpath=http://ebusd.eu/config/ -d /dev/ttyUSB0 -p 8888  --latency=0 --receivetimeout=100000 -l /var/log/ebusd.log  --scanconfig=full  --httpport=8889 --htmlpath=/var/ebusd/html"
                                  # MULTIPLE EBUSD INSTANCES WITH SYSV
                                  # In order to run multiple ebusd instances on a SysV enabled system, simply
                                  # define several EBUSD_OPTS with a unique suffix for each. Recommended is to
                                  # use a number as suffix for all EBUSD_OPTS settings. That number will then be
                                  # taken as additional "instance" parameter to the init.d script in order to
                                  # start/stop an individual ebusd instance instead of all instances.
                                  # Example: (uncomment the EBUSD_OPTS above)
                                  #EBUSD_OPTS1="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 -p 8888 -l /var/log/ebusd1.log"
                                  #EBUSD_OPTS2="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900acTF-if00-port0 -p 8889 -l /var/log/ebusd2.log"
                                  #EBUSD_OPTS3="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900beCG-if00-port0 -p 8890 -l /var/log/ebusd3.log"
                                  # MULTIPLE EBUSD INSTANCES WITH SYSTEMD
                                  # In order to run muiltiple ebusd instances on a systemd enabled system, just
                                  # copy the /usr/lib/systemd/system/ebusd.service file to /etc/systemd/system/
                                  # with a different name (e.g. ebusd-2.service), remove the line starting with
                                  # 'EnvironmentFile=', and replace the '$EBUSD_OPTS' with the options for that
                                  # particular ebusd instance.
                                  IOB@RPI4
                                  Shelly, Zigbee, ebus
                                    Dan.Master
                                    #259
                                    Also meine Config die quasi Fehlerfrei zusammen mit dem ESERA EBUS Adapter seit Januar läuft:
                                    EBUSD_OPTS="--scanconfig=full --configpath=/etc/ebusd/ -d /dev/ttyUSB0 -p 8888 --latency=0 --receivetimeout=
                                    100000 -l /var/log/ebusd.log --httpport=8889 --htmlpath=/var/www/"
                                    # MULLE EBUSD INSTANCES WITH SYSV In order to run multiple ebusd instances on a SysV enabled system,
                                    # simply define several EBUSD_OPTS with a unique suffix for each. Recommended is to use a number as
                                    # suffix for all EBUSD_OPTS settings. That number will then be taken as additional "instance"
                                    # parameter to the init.d script in order to start/stop an individual ebusd instance instead of all
                                    # instances. Example: (uncomment the EBUSD_OPTS above)
                                    /log/ebusd1.log"
                                    /log/ebusd2.log"
                                    /log/ebusd3.log"
                                    Und der Auszug aus dem ebusctl info
                                    pi@raspberrypi:~ $ ebusctl i
                                    signal: acquired
                                    symbol rate: 58
                                    max symbol rate: 150
                                    min arbitration micros: 326
                                    max arbitration micros: 573
                                    min symbol latency: 5
                                    max symbol latency: 14
                                    reconnects: 0
                                    masters: 5
                                    conditional: 0
                                    poll: 1
                                    update: 10
                                    address 00: master #1
                                    address 05: slave #1, scanned "MF=Vaillant;ID=VR921;SW=2206;HW=5703"
                                    address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0308;HW=0403", loaded "vaillant/08.hmu.csv"
                                    address 71: master #9
                                    address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0308;HW=0403"
                                    Die 921 wird nicht erkannt (Das Internetmodul).
                                    Der ESERA ist Busmäig ca 2.5m entfernt von der Wärmepumpe vond dort wird er weiter geleitet zum 921 und 700er.
                                    Ich habe den abgleich direkt am ESERA mit Laptop via HTERM gemacht. Auch ich musste das Poti anpassen.
                                    DerDani
                                    • MassiveAttackM Online
                                      MassiveAttack
                                      #260
                                      Ich hatte auch den Esera Adapter, und damit so meine Probleme. Hauptsächlich gehts da um die latency. Kurzum, nachdem ich den selbstgebastelten Adapter von John verwende, funktioniert alles tadellos.
                                      Du kannst an der Config drehen und wenden was du willst, bringt aber nur mäßigen Erfolg. Glaub mir, ich habe Stunden oder eher Tage damit verbracht :)
                                      • HasontH Offline
                                        HasontH Offline
                                        Hasont
                                        schrieb am zuletzt editiert von Hasont
                                        #261
                                        Hallo, ich verwende den EBus schon einige Jahre zum Auslesen von Werten und der Einstellung der Heizkurve.
                                        Leider gelingt es mir nicht die Auto Raumtemperatur welche an der calorMatic 430 eingestellt werden kann auch über die VIS einzustellen.
                                        Wenn ich mir die eBusDaten über [IP IoBroker]:8891/data auslese werden meine Änderungen an der calorMatic 430 als "ActualRoomTempDesiredHc1" und "DisplayedHc1RoomTempDesired" angezeigt. Diese kann ich über das Terminal mit ebusctl r ActualRoomTempDesiredHc1 oder ebusctl r DisplayedHc1RoomTempDesired ebenfalls auslesen.
                                        Eine Änderung mit ebusctl w -c 430 ActualRoomTempDesiredHc1 22 oder ebusctl w -c 430 DisplayedHc1RoomTempDesired 22 wird mit ERR: element not found beantwortet. Somit gehe ich davon aus, dass er in "ActualRoomTempDesiredHc1" und "DisplayedHc1RoomTempDesired" keine Werte schreiben kann.
                                        Ich kann mir aber auch nicht vorstellen, dass man grad diesen Komfortwert zur kurzfristigen Erhöhung oder Absenkung der Soll Zimmertemperatur nicht auch extern verstellen kann.
                                        Hat hierzu jemand eine Idee oder Lösung?
                                        LG
                                        Horst
                                        • HasontH Hasont
                                          LG
                                          Horst
                                          cactus-online
                                          #262
                                          @hasont ist das nicht eine Frage für die eBus Leute und nicht für ioBroker?
                                          Btw: Warum postest Du den absolut identischen Text hier im Forum in zwei verschiedenen Threads?
