  4. eBus Adapter Vaillant
    6.3k
ebusebus adapterproblemerrorerste schritte
395 Beiträge 50 Kommentatoren 166.4k Aufrufe 51 Beobachtet
  • F floret88
    @glasfaser
    # /etc/default/ebusd:
    # config file for ebusd service.
    # Options to pass to ebusd (run "ebusd -?" for more info):
    #EBUSD_OPTS="--scanconfig"
    #EBUSD_OPTS="--scanconfig=full --enablehex -d /dev/serial/by-id/usb-ESERA-Automation_eBus_Coupler_12001_AL6L0X59-if00-port0 --receivetimeout=100000 --port=8888 --logfile=/var/log/ebusd.log --loglevel d$
    EBUSD_OPTS="--scanconfig=full -d /dev/serial/by-id/usb-ESERA-Automation_eBus_Coupler_12001_AL6L0X59-if00-port0 --configpath=http://ebusd.eu/config/"
    # MULTIPLE EBUSD INSTANCES WITH SYSV
    # In order to run multiple ebusd instances on a SysV enabled system, simply
    # define several EBUSD_OPTS with a unique suffix for each. Recommended is to
    # use a number as suffix for all EBUSD_OPTS settings. That number will then be
    # taken as additional "instance" parameter to the init.d script in order to
    # start/stop an individual ebusd instance instead of all instances.
    # Example: (uncomment the EBUSD_OPTS above)
    #EBUSD_OPTS1="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 -p 8888 -l /var/log/ebusd1.log"
    #EBUSD_OPTS2="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900acTF-if00-port0 -p 8889 -l /var/log/ebusd2.log"
    #EBUSD_OPTS3="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900beCG-if00-port0 -p 8890 -l /var/log/ebusd3.log"
    # MULTIPLE EBUSD INSTANCES WITH SYSTEMD
    # In order to run muiltiple ebusd instances on a systemd enabled system, just
    # copy the /usr/lib/systemd/system/ebusd.service file to /etc/systemd/system/
    # with a different name (e.g. ebusd-2.service), remove the line starting with
    # 'EnvironmentFile=', and replace the '$EBUSD_OPTS' with the options for that
    # particular ebusd instance.
    GlasfaserG Offline
    GlasfaserG Offline
    #238
    @floret88
    Letzter Versuch ... mehr weiß ich auch nicht .
    EBUSD_OPTS="--scanconfig=full --enablehex -d /dev/serial/by-id/usb-ESERA-Automation_eBus_Coupler_12001_AL6L0X59-if00-port0 --httpport 8890 --configpath=http://ebusd.eu/config/"
    • GlasfaserG Glasfaser
      @floret88
      GlasfaserG Offline
      GlasfaserG Offline
      #239
      @glasfaser sagte in eBus Adapter Vaillant:
      usb-ESERA
      Stop den habe ich auch .... aber auf /dev/ttyUSB0
      Die Konfig wäre dann so bei mir und funktioniert auch :
      EBUSD_OPTS="-d /dev/ttyUSB0 --httpport=8889 --scanconfig=full --enablehex --latency=0 --configpath=http://ebusd.eu/config/ "
      F 2 Antworten Letzte Antwort
        usb-ESERA
        floret88
        schrieb am zuletzt editiert von floret88
        #240
        @glasfaser Ich glaube, ich gebe es für den Moment auf, egal ob mit lokalen Config Dateien (mit root Rechten oder auch pi von Github gezogen) oder auch Online - es will nicht funktionieren.
        Ich habe bei Github einen Issue aufgemacht (siehe hier: https://github.com/john30/ebusd-configuration/issues/229) und warte dort auch auf eine Rückmeldung.
        Fakt ist, die Verbindung von ebus zur Heizung funktioniert, aber ich bekomme nur "Nonsense" an Daten weil nicht decodierbar.
        Vielen Dank dennoch an alle, die versucht haben mir zu helfen.
        Falls noch jemand weitere Ideen und Gedankensprünge hat, bin ich jederzeit froh über Euren Input.
        LG
        F 1 Antwort Letzte Antwort
        • F floret88
          LG
          floret88
          #241
          @floret88 Des Weiteren wollte ich Euch noch folgendes zeigen, um meine Aussagen zu verifizieren.
          Es sieht gut aus, findet aber keine "richtige" Config Datei :-)
          Kann es sein, dass ich einfach eine nicht unterstützte Software bzw. Hardware seitens Vaillant habe?
          pi@raspberrypi:~ $ sudo ebusd --scanconfig=full --logfile=/var/log/ebusd.log --configpath=/etc/ebusd --loglevel=debug -f
          2021-08-26 12:27:26.977 [main notice] ebusd 21.2.v21.2 started with full scan on device /dev/ttyUSB0
          2021-08-26 12:27:26.977 [main info] loading configuration files from /etc/ebusd
          2021-08-26 12:27:26.977 [main info] reading templates /
          2021-08-26 12:27:26.978 [main info] read templates in /
          2021-08-26 12:27:26.979 [main info] reading file broadcast.csv
          2021-08-26 12:27:26.980 [main info] successfully read file broadcast.csv
          2021-08-26 12:27:26.980 [main info] reading file memory.csv
          2021-08-26 12:27:26.981 [main info] successfully read file memory.csv
          2021-08-26 12:27:26.981 [main info] read config files
          2021-08-26 12:27:26.988 [bus notice] bus started with own address 31/36
          2021-08-26 12:27:26.989 [main info] registering data handlers
          2021-08-26 12:27:26.989 [main info] registered data handlers
          2021-08-26 12:27:26.991 [bus debug] ERR: SYN received during no signal, switching to ready
          2021-08-26 12:27:26.992 [bus notice] signal acquired
          2021-08-26 12:27:29.199 [bus notice] new master 10, master count 2
          2021-08-26 12:27:29.259 [bus notice] new master 03, master count 3
          2021-08-26 12:27:29.259 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:27:29.259 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:27:29.526 [bus notice] new master 71, master count 4
          2021-08-26 12:27:29.526 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:27:29.526 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:27:29.792 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:27:29.792 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:27:30.089 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
          2021-08-26 12:27:30.089 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
          2021-08-26 12:27:30.381 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:27:30.381 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:27:30.647 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:27:30.647 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:27:30.914 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:27:30.914 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:27:31.003 [bus notice] max. symbols per second: 103
          2021-08-26 12:27:32.398 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:27:32.398 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:27:32.643 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:27:32.643 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:27:32.888 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:27:32.888 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:27:33.132 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:27:33.133 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:27:36.989 [main debug] performing regular tasks
          2021-08-26 12:27:36.989 [main notice] starting initial full scan
          2021-08-26 12:27:36.989 [bus info] scan 02 cmd: 3102070400
          2021-08-26 12:27:36.990 [bus debug] start request 31
          2021-08-26 12:27:36.990 [bus debug] arbitration start with 31
          2021-08-26 12:27:39.175 [bus debug] arbitration lost
          2021-08-26 12:27:39.176 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:39.260 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:27:39.261 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:27:39.263 [bus debug] start request 31
          2021-08-26 12:27:39.263 [bus debug] arbitration start with 31
          2021-08-26 12:27:39.441 [bus debug] arbitration lost
          2021-08-26 12:27:39.441 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:39.527 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:27:39.528 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:27:39.529 [bus debug] start request 31
          2021-08-26 12:27:39.529 [bus debug] arbitration start with 31
          2021-08-26 12:27:39.707 [bus debug] arbitration lost
          2021-08-26 12:27:39.707 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:39.793 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:27:39.793 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:27:39.796 [bus debug] start request 31
          2021-08-26 12:27:39.796 [bus debug] arbitration start with 31
          2021-08-26 12:27:39.973 [bus debug] arbitration lost
          2021-08-26 12:27:39.973 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:27:39.974 [bus info] scan 04 cmd: 3104070400
          2021-08-26 12:27:40.090 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
          2021-08-26 12:27:40.090 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
          2021-08-26 12:27:40.092 [bus debug] start request 31
          2021-08-26 12:27:40.092 [bus debug] arbitration start with 31
          2021-08-26 12:27:40.270 [bus debug] arbitration lost
          2021-08-26 12:27:40.270 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:40.383 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:27:40.384 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:27:40.387 [bus debug] start request 31
          2021-08-26 12:27:40.387 [bus debug] arbitration start with 31
          2021-08-26 12:27:40.563 [bus debug] arbitration lost
          2021-08-26 12:27:40.564 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:40.648 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:27:40.649 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:27:40.650 [bus debug] start request 31
          2021-08-26 12:27:40.651 [bus debug] arbitration start with 31
          2021-08-26 12:27:40.828 [bus debug] arbitration lost
          2021-08-26 12:27:40.829 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:40.915 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:27:40.916 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:27:40.918 [bus debug] start request 31
          2021-08-26 12:27:40.918 [bus debug] arbitration start with 31
          2021-08-26 12:27:42.336 [bus debug] arbitration lost
          2021-08-26 12:27:42.337 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:27:42.337 [bus info] scan 05 cmd: 3105070400
          2021-08-26 12:27:42.443 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:27:42.443 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:27:42.446 [bus debug] start request 31
          2021-08-26 12:27:42.446 [bus debug] arbitration start with 31
          2021-08-26 12:27:42.623 [bus debug] arbitration lost
          2021-08-26 12:27:42.624 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:42.688 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:27:42.689 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:27:42.692 [bus debug] start request 31
          2021-08-26 12:27:42.692 [bus debug] arbitration start with 31
          2021-08-26 12:27:42.868 [bus debug] arbitration lost
          2021-08-26 12:27:42.868 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:42.933 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:27:42.934 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:27:42.935 [bus debug] start request 31
          2021-08-26 12:27:42.936 [bus debug] arbitration start with 31
          2021-08-26 12:27:43.113 [bus debug] arbitration lost
          2021-08-26 12:27:43.113 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:43.178 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:27:43.178 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:27:43.179 [bus debug] start request 31
          2021-08-26 12:27:43.179 [bus debug] arbitration start with 31
          2021-08-26 12:27:46.990 [main debug] performing regular tasks
          2021-08-26 12:27:46.990 [bus info] scan 08 cmd: 3108070400
          2021-08-26 12:27:49.220 [bus debug] arbitration lost
          2021-08-26 12:27:49.220 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:27:49.220 [bus info] scan 06 cmd: 3106070400
          2021-08-26 12:27:49.306 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:27:49.306 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:27:49.309 [bus debug] start request 31
          2021-08-26 12:27:49.309 [bus debug] arbitration start with 31
          2021-08-26 12:27:49.486 [bus debug] arbitration lost
          2021-08-26 12:27:49.486 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:49.572 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:27:49.572 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:27:49.574 [bus debug] start request 31
          2021-08-26 12:27:49.574 [bus debug] arbitration start with 31
          2021-08-26 12:27:49.753 [bus debug] arbitration lost
          2021-08-26 12:27:49.753 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:49.839 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:27:49.839 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:27:49.840 [bus debug] start request 31
          2021-08-26 12:27:49.840 [bus debug] arbitration start with 31
          2021-08-26 12:27:50.019 [bus debug] arbitration lost
          2021-08-26 12:27:50.019 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:50.135 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
          2021-08-26 12:27:50.135 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
          2021-08-26 12:27:50.136 [bus debug] start request 31
          2021-08-26 12:27:50.136 [bus debug] arbitration start with 31
          2021-08-26 12:27:50.314 [bus debug] arbitration lost
          2021-08-26 12:27:50.315 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:50.427 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:27:50.428 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:27:50.429 [bus debug] start request 31
          2021-08-26 12:27:50.429 [bus debug] arbitration start with 31
          2021-08-26 12:27:50.607 [bus debug] arbitration lost
          2021-08-26 12:27:50.607 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:50.693 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:27:50.694 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:27:50.694 [bus debug] start request 31
          2021-08-26 12:27:50.694 [bus debug] arbitration start with 31
          2021-08-26 12:27:50.873 [bus debug] arbitration lost
          2021-08-26 12:27:50.873 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:50.959 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:27:50.960 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:27:50.962 [bus debug] start request 31
          2021-08-26 12:27:50.962 [bus debug] arbitration start with 31
          2021-08-26 12:27:51.007 [bus notice] max. symbols per second: 110
          2021-08-26 12:27:52.381 [bus debug] arbitration lost
          2021-08-26 12:27:52.381 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:27:52.381 [main error] scan config 08: ERR: arbitration lost
          2021-08-26 12:27:52.488 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:27:52.488 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:27:52.490 [bus debug] start request 31
          2021-08-26 12:27:52.490 [bus debug] arbitration start with 31
          2021-08-26 12:27:52.669 [bus debug] arbitration lost
          2021-08-26 12:27:52.669 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:27:52.669 [bus info] scan 08 cmd: 3108070400
          2021-08-26 12:27:52.734 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:27:52.734 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:27:52.736 [bus debug] start request 31
          2021-08-26 12:27:52.736 [bus debug] arbitration start with 31
          2021-08-26 12:27:52.914 [bus debug] arbitration lost
          2021-08-26 12:27:52.914 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:52.979 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:27:52.979 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:27:52.981 [bus debug] start request 31
          2021-08-26 12:27:52.981 [bus debug] arbitration start with 31
          2021-08-26 12:27:53.158 [bus debug] arbitration lost
          2021-08-26 12:27:53.158 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:53.223 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:27:53.223 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:27:53.225 [bus debug] start request 31
          2021-08-26 12:27:53.225 [bus debug] arbitration start with 31
          2021-08-26 12:27:54.382 [main debug] performing regular tasks
          2021-08-26 12:27:54.382 [bus info] scan 15 cmd: 3115070400
          2021-08-26 12:27:59.264 [bus debug] arbitration lost
          2021-08-26 12:27:59.264 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:59.351 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:27:59.351 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:27:59.353 [bus debug] start request 31
          2021-08-26 12:27:59.353 [bus debug] arbitration start with 31
          2021-08-26 12:27:59.531 [bus debug] arbitration lost
          2021-08-26 12:27:59.531 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:27:59.617 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:27:59.617 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:27:59.618 [bus debug] start request 31
          2021-08-26 12:27:59.619 [bus debug] arbitration start with 31
          2021-08-26 12:27:59.799 [bus debug] arbitration lost
          2021-08-26 12:27:59.799 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:27:59.799 [bus info] scan 09 cmd: 3109070400
          2021-08-26 12:27:59.884 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:27:59.884 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:27:59.886 [bus debug] start request 31
          2021-08-26 12:27:59.886 [bus debug] arbitration start with 31
          2021-08-26 12:28:00.064 [bus debug] arbitration lost
          2021-08-26 12:28:00.064 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:00.182 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e90100800080003c
          2021-08-26 12:28:00.182 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e90100800080003c
          2021-08-26 12:28:00.185 [bus debug] start request 31
          2021-08-26 12:28:00.185 [bus debug] arbitration start with 31
          2021-08-26 12:28:00.361 [bus debug] arbitration lost
          2021-08-26 12:28:00.361 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:00.473 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:00.473 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:00.475 [bus debug] start request 31
          2021-08-26 12:28:00.475 [bus debug] arbitration start with 31
          2021-08-26 12:28:00.654 [bus debug] arbitration lost
          2021-08-26 12:28:00.654 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:00.739 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:00.739 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:00.741 [bus debug] start request 31
          2021-08-26 12:28:00.741 [bus debug] arbitration start with 31
          2021-08-26 12:28:00.918 [bus debug] arbitration lost
          2021-08-26 12:28:00.918 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:01.005 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:01.005 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:01.006 [bus debug] start request 31
          2021-08-26 12:28:01.006 [bus debug] arbitration start with 31
          2021-08-26 12:28:02.426 [bus debug] arbitration lost
          2021-08-26 12:28:02.426 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:02.427 [main error] scan config 15: ERR: arbitration lost
          2021-08-26 12:28:02.533 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:02.533 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:02.534 [bus debug] start request 31
          2021-08-26 12:28:02.534 [bus debug] arbitration start with 31
          2021-08-26 12:28:02.714 [bus debug] arbitration lost
          2021-08-26 12:28:02.714 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:02.778 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:02.778 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:02.780 [bus debug] start request 31
          2021-08-26 12:28:02.780 [bus debug] arbitration start with 31
          2021-08-26 12:28:02.958 [bus debug] arbitration lost
          2021-08-26 12:28:02.958 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:02.958 [bus info] scan 0a cmd: 310a070400
          2021-08-26 12:28:03.023 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:03.023 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:03.025 [bus debug] start request 31
          2021-08-26 12:28:03.026 [bus debug] arbitration start with 31
          2021-08-26 12:28:03.203 [bus debug] arbitration lost
          2021-08-26 12:28:03.203 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:03.268 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:03.268 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:03.271 [bus debug] start request 31
          2021-08-26 12:28:03.271 [bus debug] arbitration start with 31
          2021-08-26 12:28:04.427 [main debug] performing regular tasks
          2021-08-26 12:28:04.427 [bus info] scan 26 cmd: 3126070400
          2021-08-26 12:28:09.316 [bus debug] arbitration lost
          2021-08-26 12:28:09.316 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:09.403 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:09.403 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:09.405 [bus debug] start request 31
          2021-08-26 12:28:09.405 [bus debug] arbitration start with 31
          2021-08-26 12:28:09.582 [bus debug] arbitration lost
          2021-08-26 12:28:09.582 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:09.668 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:09.668 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:09.671 [bus debug] start request 31
          2021-08-26 12:28:09.671 [bus debug] arbitration start with 31
          2021-08-26 12:28:09.849 [bus debug] arbitration lost
          2021-08-26 12:28:09.849 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:09.935 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:28:09.936 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:28:09.938 [bus debug] start request 31
          2021-08-26 12:28:09.939 [bus debug] arbitration start with 31
          2021-08-26 12:28:10.115 [bus debug] arbitration lost
          2021-08-26 12:28:10.115 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:10.144 [update info] received BC cmd: 10feb505025c00
          2021-08-26 12:28:10.144 [update notice] received unknown BC cmd: 10feb505025c00
          2021-08-26 12:28:10.146 [bus debug] start request 31
          2021-08-26 12:28:10.146 [bus debug] arbitration start with 31
          2021-08-26 12:28:10.325 [bus debug] arbitration lost
          2021-08-26 12:28:10.325 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:10.325 [bus info] scan 0b cmd: 310b070400
          2021-08-26 12:28:10.442 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
          2021-08-26 12:28:10.443 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
          2021-08-26 12:28:10.444 [bus debug] start request 31
          2021-08-26 12:28:10.445 [bus debug] arbitration start with 31
          2021-08-26 12:28:10.621 [bus debug] arbitration lost
          2021-08-26 12:28:10.622 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:10.733 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:10.734 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:10.735 [bus debug] start request 31
          2021-08-26 12:28:10.735 [bus debug] arbitration start with 31
          2021-08-26 12:28:10.914 [bus debug] arbitration lost
          2021-08-26 12:28:10.914 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:11.001 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:11.001 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:11.004 [bus debug] start request 31
          2021-08-26 12:28:11.005 [bus debug] arbitration start with 31
          2021-08-26 12:28:11.182 [bus debug] arbitration lost
          2021-08-26 12:28:11.182 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:11.182 [main error] scan config 26: ERR: arbitration lost
          2021-08-26 12:28:11.247 [update info] received MS cmd: 1008b507020900 / 029f02
          2021-08-26 12:28:11.247 [update notice] received unknown MS cmd: 1008b507020900 / 029f02
          2021-08-26 12:28:11.249 [bus debug] start request 31
          2021-08-26 12:28:11.249 [bus debug] arbitration start with 31
          2021-08-26 12:28:11.426 [bus debug] arbitration lost
          2021-08-26 12:28:11.426 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:11.513 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:11.513 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:11.514 [bus debug] start request 31
          2021-08-26 12:28:11.515 [bus debug] arbitration start with 31
          2021-08-26 12:28:11.693 [bus debug] arbitration lost
          2021-08-26 12:28:11.693 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:11.781 [update info] received MS cmd: 1008b5040100 / 0a03122812260804210013
          2021-08-26 12:28:11.781 [update notice] received unknown MS cmd: 1008b5040100 / 0a03122812260804210013
          2021-08-26 12:28:11.784 [bus debug] start request 31
          2021-08-26 12:28:11.784 [bus debug] arbitration start with 31
          2021-08-26 12:28:11.962 [bus debug] arbitration lost
          2021-08-26 12:28:11.962 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:11.962 [bus info] scan 0c cmd: 310c070400
          2021-08-26 12:28:12.017 [update info] received BC cmd: 10feb516080010281226080421
          2021-08-26 12:28:12.017 [update notice] received unknown BC cmd: 10feb516080010281226080421
          2021-08-26 12:28:12.018 [bus debug] start request 31
          2021-08-26 12:28:12.018 [bus debug] arbitration start with 31
          2021-08-26 12:28:12.197 [bus debug] arbitration lost
          2021-08-26 12:28:12.197 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:12.283 [update info] received MS cmd: 1008b5110100 / 09030214000000000100
          2021-08-26 12:28:12.283 [update notice] received unknown MS cmd: 1008b5110100 / 09030214000000000100
          2021-08-26 12:28:12.284 [bus debug] start request 31
          2021-08-26 12:28:12.284 [bus debug] arbitration start with 31
          2021-08-26 12:28:12.463 [bus debug] arbitration lost
          2021-08-26 12:28:12.463 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:12.529 [update info] received MS cmd: 1076b51303040d00 / 02ffff
          2021-08-26 12:28:12.529 [update notice] received unknown MS cmd: 1076b51303040d00 / 02ffff
          2021-08-26 12:28:12.530 [bus debug] start request 31
          2021-08-26 12:28:12.530 [bus debug] arbitration start with 31
          2021-08-26 12:28:12.708 [bus debug] arbitration lost
          2021-08-26 12:28:12.708 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:12.815 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:12.815 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:12.816 [bus debug] start request 31
          2021-08-26 12:28:12.816 [bus debug] arbitration start with 31
          2021-08-26 12:28:12.995 [bus debug] arbitration lost
          2021-08-26 12:28:12.995 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:12.995 [bus info] scan 0d cmd: 310d070400
          2021-08-26 12:28:13.060 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:13.060 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:13.062 [bus debug] start request 31
          2021-08-26 12:28:13.062 [bus debug] arbitration start with 31
          2021-08-26 12:28:13.182 [main debug] performing regular tasks
          2021-08-26 12:28:13.182 [bus info] scan 76 cmd: 3176070400
          2021-08-26 12:28:13.239 [bus debug] arbitration lost
          2021-08-26 12:28:13.240 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:13.303 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:13.304 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:13.305 [bus debug] start request 31
          2021-08-26 12:28:13.306 [bus debug] arbitration start with 31
          2021-08-26 12:28:13.483 [bus debug] arbitration lost
          2021-08-26 12:28:13.484 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:13.517 [update info] received BC cmd: 10feb51603010013
          2021-08-26 12:28:13.518 [update notice] received unknown BC cmd: 10feb51603010013
          2021-08-26 12:28:13.519 [bus debug] start request 31
          2021-08-26 12:28:13.519 [bus debug] arbitration start with 31
          2021-08-26 12:28:13.697 [bus debug] arbitration lost
          2021-08-26 12:28:13.697 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:13.763 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:13.764 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:13.766 [bus debug] start request 31
          2021-08-26 12:28:13.766 [bus debug] arbitration start with 31
          2021-08-26 12:28:19.343 [bus debug] arbitration lost
          2021-08-26 12:28:19.344 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:19.430 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:19.431 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:19.432 [bus debug] start request 31
          2021-08-26 12:28:19.432 [bus debug] arbitration start with 31
          2021-08-26 12:28:19.610 [bus debug] arbitration lost
          2021-08-26 12:28:19.610 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:19.697 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:19.698 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:19.699 [bus debug] start request 31
          2021-08-26 12:28:19.699 [bus debug] arbitration start with 31
          2021-08-26 12:28:19.877 [bus debug] arbitration lost
          2021-08-26 12:28:19.878 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:19.963 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:28:19.964 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:28:19.967 [bus debug] start request 31
          2021-08-26 12:28:19.967 [bus debug] arbitration start with 31
          2021-08-26 12:28:20.145 [bus debug] arbitration lost
          2021-08-26 12:28:20.146 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:20.147 [bus info] scan 0e cmd: 310e070400
          2021-08-26 12:28:20.262 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
          2021-08-26 12:28:20.263 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e80100800080003c
          2021-08-26 12:28:20.266 [bus debug] start request 31
          2021-08-26 12:28:20.266 [bus debug] arbitration start with 31
          2021-08-26 12:28:20.441 [bus debug] arbitration lost
          2021-08-26 12:28:20.442 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:20.442 [main error] scan config 76: ERR: arbitration lost
          2021-08-26 12:28:20.554 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:20.555 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:20.558 [bus debug] start request 31
          2021-08-26 12:28:20.558 [bus debug] arbitration start with 31
          2021-08-26 12:28:20.735 [bus debug] arbitration lost
          2021-08-26 12:28:20.735 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:20.822 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:20.822 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:20.824 [bus debug] start request 31
          2021-08-26 12:28:20.824 [bus debug] arbitration start with 31
          2021-08-26 12:28:21.002 [bus debug] arbitration lost
          2021-08-26 12:28:21.002 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:21.089 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:21.089 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:21.091 [bus debug] start request 31
          2021-08-26 12:28:21.091 [bus debug] arbitration start with 31
          2021-08-26 12:28:22.443 [main debug] performing regular tasks
          2021-08-26 12:28:22.510 [bus debug] arbitration lost
          2021-08-26 12:28:22.510 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:22.617 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:22.617 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:22.619 [bus debug] start request 31
          2021-08-26 12:28:22.619 [bus debug] arbitration start with 31
          2021-08-26 12:28:22.798 [bus debug] arbitration lost
          2021-08-26 12:28:22.798 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:22.798 [bus info] scan 12 cmd: 3112070400
          2021-08-26 12:28:22.863 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:22.863 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:22.865 [bus debug] start request 31
          2021-08-26 12:28:22.865 [bus debug] arbitration start with 31
          2021-08-26 12:28:23.043 [bus debug] arbitration lost
          2021-08-26 12:28:23.043 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:23.108 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:23.108 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:23.111 [bus debug] start request 31
          2021-08-26 12:28:23.111 [bus debug] arbitration start with 31
          2021-08-26 12:28:23.288 [bus debug] arbitration lost
          2021-08-26 12:28:23.288 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:23.353 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:23.353 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:23.354 [bus debug] start request 31
          2021-08-26 12:28:23.354 [bus debug] arbitration start with 31
          2021-08-26 12:28:29.403 [bus debug] arbitration lost
          2021-08-26 12:28:29.403 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:29.488 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:29.488 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:29.489 [bus debug] start request 31
          2021-08-26 12:28:29.489 [bus debug] arbitration start with 31
          2021-08-26 12:28:29.668 [bus debug] arbitration lost
          2021-08-26 12:28:29.668 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:29.668 [bus info] scan 14 cmd: 3114070400
          2021-08-26 12:28:29.754 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:29.754 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:29.756 [bus debug] start request 31
          2021-08-26 12:28:29.756 [bus debug] arbitration start with 31
          2021-08-26 12:28:29.936 [bus debug] arbitration lost
          2021-08-26 12:28:29.936 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:30.021 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:28:30.021 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:28:30.022 [bus debug] start request 31
          2021-08-26 12:28:30.022 [bus debug] arbitration start with 31
          2021-08-26 12:28:30.201 [bus debug] arbitration lost
          2021-08-26 12:28:30.201 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:30.318 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
          2021-08-26 12:28:30.318 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ad01e70100800080003c
          2021-08-26 12:28:30.320 [bus debug] start request 31
          2021-08-26 12:28:30.320 [bus debug] arbitration start with 31
          2021-08-26 12:28:30.498 [bus debug] arbitration lost
          2021-08-26 12:28:30.499 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:30.611 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:30.612 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:30.613 [bus debug] start request 31
          2021-08-26 12:28:30.613 [bus debug] arbitration start with 31
          2021-08-26 12:28:30.791 [bus debug] arbitration lost
          2021-08-26 12:28:30.791 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:30.792 [bus info] scan 15 cmd: 3115070400
          2021-08-26 12:28:30.879 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:30.880 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:30.882 [bus debug] start request 31
          2021-08-26 12:28:30.882 [bus debug] arbitration start with 31
          2021-08-26 12:28:31.059 [bus debug] arbitration lost
          2021-08-26 12:28:31.059 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:31.145 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:31.145 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:31.148 [bus debug] start request 31
          2021-08-26 12:28:31.148 [bus debug] arbitration start with 31
          2021-08-26 12:28:32.444 [main debug] performing regular tasks
          2021-08-26 12:28:32.444 [bus info] scan 08 cmd: 3108070400
          2021-08-26 12:28:32.526 [bus debug] arbitration lost
          2021-08-26 12:28:32.526 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:32.633 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:32.633 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:32.634 [bus debug] start request 31
          2021-08-26 12:28:32.635 [bus debug] arbitration start with 31
          2021-08-26 12:28:32.813 [bus debug] arbitration lost
          2021-08-26 12:28:32.813 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:32.878 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:32.878 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:32.880 [bus debug] start request 31
          2021-08-26 12:28:32.880 [bus debug] arbitration start with 31
          2021-08-26 12:28:33.058 [bus debug] arbitration lost
          2021-08-26 12:28:33.058 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:33.122 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:33.122 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:33.124 [bus debug] start request 31
          2021-08-26 12:28:33.124 [bus debug] arbitration start with 31
          2021-08-26 12:28:33.302 [bus debug] arbitration lost
          2021-08-26 12:28:33.302 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:33.367 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:33.367 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:33.369 [bus debug] start request 31
          2021-08-26 12:28:33.369 [bus debug] arbitration start with 31
          2021-08-26 12:28:39.419 [bus debug] arbitration lost
          2021-08-26 12:28:39.419 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:39.419 [bus info] scan 16 cmd: 3116070400
          2021-08-26 12:28:39.505 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:39.505 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:39.508 [bus debug] start request 31
          2021-08-26 12:28:39.508 [bus debug] arbitration start with 31
          2021-08-26 12:28:39.685 [bus debug] arbitration lost
          2021-08-26 12:28:39.685 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:39.771 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:39.771 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:39.773 [bus debug] start request 31
          2021-08-26 12:28:39.773 [bus debug] arbitration start with 31
          2021-08-26 12:28:39.952 [bus debug] arbitration lost
          2021-08-26 12:28:39.952 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:40.038 [update info] received MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:28:40.038 [update notice] received unknown MS cmd: 1076b512030f0201 / 0773030000801302
          2021-08-26 12:28:40.041 [bus debug] start request 31
          2021-08-26 12:28:40.041 [bus debug] arbitration start with 31
          2021-08-26 12:28:40.218 [bus debug] arbitration lost
          2021-08-26 12:28:40.218 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:40.218 [main error] scan config 08: ERR: arbitration lost
          2021-08-26 12:28:40.334 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
          2021-08-26 12:28:40.334 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
          2021-08-26 12:28:40.335 [bus debug] start request 31
          2021-08-26 12:28:40.335 [bus debug] arbitration start with 31
          2021-08-26 12:28:40.514 [bus debug] arbitration lost
          2021-08-26 12:28:40.514 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:40.627 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:40.627 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:40.628 [bus debug] start request 31
          2021-08-26 12:28:40.628 [bus debug] arbitration start with 31
          2021-08-26 12:28:40.807 [bus debug] arbitration lost
          2021-08-26 12:28:40.807 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:40.893 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:40.893 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:40.895 [bus debug] start request 31
          2021-08-26 12:28:40.895 [bus debug] arbitration start with 31
          2021-08-26 12:28:41.072 [bus debug] arbitration lost
          2021-08-26 12:28:41.072 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:41.072 [bus info] scan 18 cmd: 3118070400
          2021-08-26 12:28:41.159 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:41.159 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:41.161 [bus debug] start request 31
          2021-08-26 12:28:41.161 [bus debug] arbitration start with 31
          2021-08-26 12:28:42.218 [main debug] performing regular tasks
          2021-08-26 12:28:42.219 [bus info] scan 15 cmd: 3115070400
          2021-08-26 12:28:42.579 [bus debug] arbitration lost
          2021-08-26 12:28:42.579 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:42.686 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:42.687 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:42.689 [bus debug] start request 31
          2021-08-26 12:28:42.689 [bus debug] arbitration start with 31
          2021-08-26 12:28:42.866 [bus debug] arbitration lost
          2021-08-26 12:28:42.866 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:42.931 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:42.931 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:42.933 [bus debug] start request 31
          2021-08-26 12:28:42.933 [bus debug] arbitration start with 31
          2021-08-26 12:28:43.111 [bus debug] arbitration lost
          2021-08-26 12:28:43.111 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:43.176 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:43.176 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:43.178 [bus debug] start request 31
          2021-08-26 12:28:43.178 [bus debug] arbitration start with 31
          2021-08-26 12:28:43.356 [bus debug] arbitration lost
          2021-08-26 12:28:43.356 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:43.421 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:43.421 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:43.424 [bus debug] start request 31
          2021-08-26 12:28:43.424 [bus debug] arbitration start with 31
          2021-08-26 12:28:49.471 [bus debug] arbitration lost
          2021-08-26 12:28:49.471 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:49.557 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:49.557 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:49.560 [bus debug] start request 31
          2021-08-26 12:28:49.560 [bus debug] arbitration start with 31
          2021-08-26 12:28:49.738 [bus debug] arbitration lost
          2021-08-26 12:28:49.738 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:49.824 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:49.824 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:49.825 [bus debug] start request 31
          2021-08-26 12:28:49.826 [bus debug] arbitration start with 31
          2021-08-26 12:28:50.005 [bus debug] arbitration lost
          2021-08-26 12:28:50.005 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:50.005 [bus info] scan 19 cmd: 3119070400
          2021-08-26 12:28:50.090 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
          2021-08-26 12:28:50.090 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
          2021-08-26 12:28:50.091 [bus debug] start request 31
          2021-08-26 12:28:50.091 [bus debug] arbitration start with 31
          2021-08-26 12:28:50.270 [bus debug] arbitration lost
          2021-08-26 12:28:50.270 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:50.270 [main error] scan config 15: ERR: arbitration lost
          2021-08-26 12:28:50.387 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
          2021-08-26 12:28:50.387 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
          2021-08-26 12:28:50.390 [bus debug] start request 31
          2021-08-26 12:28:50.390 [bus debug] arbitration start with 31
          2021-08-26 12:28:50.567 [bus debug] arbitration lost
          2021-08-26 12:28:50.567 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:50.679 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:50.679 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:28:50.680 [bus debug] start request 31
          2021-08-26 12:28:50.680 [bus debug] arbitration start with 31
          2021-08-26 12:28:50.859 [bus debug] arbitration lost
          2021-08-26 12:28:50.859 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:50.945 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:50.945 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:28:50.948 [bus debug] start request 31
          2021-08-26 12:28:50.948 [bus debug] arbitration start with 31
          2021-08-26 12:28:51.035 [bus notice] max. symbols per second: 111
          2021-08-26 12:28:51.125 [bus debug] arbitration lost
          2021-08-26 12:28:51.125 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:51.212 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:51.212 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:28:51.213 [bus debug] start request 31
          2021-08-26 12:28:51.213 [bus debug] arbitration start with 31
          2021-08-26 12:28:52.271 [main debug] performing regular tasks
          2021-08-26 12:28:52.271 [bus info] scan 26 cmd: 3126070400
          2021-08-26 12:28:52.591 [bus debug] arbitration lost
          2021-08-26 12:28:52.591 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:28:52.591 [bus info] scan 1a cmd: 311a070400
          2021-08-26 12:28:52.698 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:52.698 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:28:52.700 [bus debug] start request 31
          2021-08-26 12:28:52.700 [bus debug] arbitration start with 31
          2021-08-26 12:28:52.879 [bus debug] arbitration lost
          2021-08-26 12:28:52.879 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:52.944 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:52.944 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:28:52.946 [bus debug] start request 31
          2021-08-26 12:28:52.946 [bus debug] arbitration start with 31
          2021-08-26 12:28:53.123 [bus debug] arbitration lost
          2021-08-26 12:28:53.123 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:53.188 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:53.188 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:28:53.189 [bus debug] start request 31
          2021-08-26 12:28:53.189 [bus debug] arbitration start with 31
          2021-08-26 12:28:53.367 [bus debug] arbitration lost
          2021-08-26 12:28:53.368 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:53.432 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:53.433 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:28:53.435 [bus debug] start request 31
          2021-08-26 12:28:53.435 [bus debug] arbitration start with 31
          2021-08-26 12:28:59.483 [bus debug] arbitration lost
          2021-08-26 12:28:59.484 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:59.570 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:59.571 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:28:59.573 [bus debug] start request 31
          2021-08-26 12:28:59.573 [bus debug] arbitration start with 31
          2021-08-26 12:28:59.751 [bus debug] arbitration lost
          2021-08-26 12:28:59.751 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:28:59.837 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:59.838 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:28:59.839 [bus debug] start request 31
          2021-08-26 12:28:59.839 [bus debug] arbitration start with 31
          2021-08-26 12:29:00.018 [bus debug] arbitration lost
          2021-08-26 12:29:00.018 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:00.103 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
          2021-08-26 12:29:00.103 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
          2021-08-26 12:29:00.104 [bus debug] start request 31
          2021-08-26 12:29:00.104 [bus debug] arbitration start with 31
          2021-08-26 12:29:00.283 [bus debug] arbitration lost
          2021-08-26 12:29:00.283 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:29:00.283 [main error] scan config 26: ERR: arbitration lost
          2021-08-26 12:29:00.400 [update info] received MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
          2021-08-26 12:29:00.400 [update notice] received unknown MS cmd: 1026b5230106 / 104502bd01bf01ac01e80100800080003c
          2021-08-26 12:29:00.403 [bus debug] start request 31
          2021-08-26 12:29:00.403 [bus debug] arbitration start with 31
          2021-08-26 12:29:00.580 [bus debug] arbitration lost
          2021-08-26 12:29:00.580 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:29:00.580 [bus info] scan 1b cmd: 311b070400
          2021-08-26 12:29:00.692 [update info] received MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:29:00.692 [update notice] received unknown MS cmd: 1026b5230107 / 0f008000800080008000008000805705
          2021-08-26 12:29:00.693 [bus debug] start request 31
          2021-08-26 12:29:00.693 [bus debug] arbitration start with 31
          2021-08-26 12:29:00.872 [bus debug] arbitration lost
          2021-08-26 12:29:00.872 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:00.958 [update info] received MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:29:00.958 [update notice] received unknown MS cmd: 1008b51009000000ffffff070000 / 0101
          2021-08-26 12:29:00.961 [bus debug] start request 31
          2021-08-26 12:29:00.961 [bus debug] arbitration start with 31
          2021-08-26 12:29:01.138 [bus debug] arbitration lost
          2021-08-26 12:29:01.138 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:01.225 [update info] received MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:29:01.225 [update notice] received unknown MS cmd: 1076b51009000000ffffff010000 / 0101
          2021-08-26 12:29:01.226 [bus debug] start request 31
          2021-08-26 12:29:01.226 [bus debug] arbitration start with 31
          2021-08-26 12:29:02.284 [main debug] performing regular tasks
          2021-08-26 12:29:02.284 [bus info] scan 76 cmd: 3176070400
          2021-08-26 12:29:02.646 [bus debug] arbitration lost
          2021-08-26 12:29:02.646 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:02.753 [update info] received MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:29:02.753 [update notice] received unknown MS cmd: 1026b5230f05ffffff000000ffffffffffff0000 / 0101
          2021-08-26 12:29:02.755 [bus debug] start request 31
          2021-08-26 12:29:02.755 [bus debug] arbitration start with 31
          2021-08-26 12:29:02.933 [bus debug] arbitration lost
          2021-08-26 12:29:02.933 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:02.998 [update info] received MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:29:02.998 [update notice] received unknown MS cmd: 1026b5230402000000 / 02019c
          2021-08-26 12:29:03.000 [bus debug] start request 31
          2021-08-26 12:29:03.000 [bus debug] arbitration start with 31
          2021-08-26 12:29:03.178 [bus debug] arbitration lost
          2021-08-26 12:29:03.178 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:29:03.178 [bus info] scan 1c cmd: 311c070400
          2021-08-26 12:29:03.243 [update info] received MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:29:03.243 [update notice] received unknown MS cmd: 1026b5230402010000 / 02019c
          2021-08-26 12:29:03.244 [bus debug] start request 31
          2021-08-26 12:29:03.244 [bus debug] arbitration start with 31
          2021-08-26 12:29:03.423 [bus debug] arbitration lost
          2021-08-26 12:29:03.423 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:03.488 [update info] received MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:29:03.488 [update notice] received unknown MS cmd: 1026b5230402020000 / 02019c
          2021-08-26 12:29:03.489 [bus debug] start request 31
          2021-08-26 12:29:03.489 [bus debug] arbitration start with 31
          ^C2021-08-26 12:29:03.645 [main notice] SIGINT received
          2021-08-26 12:29:09.532 [bus debug] arbitration lost
          2021-08-26 12:29:09.532 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:09.619 [update info] received MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:29:09.619 [update notice] received unknown MS cmd: 1008b5110101 / 09403d0013ff6e0000ff
          2021-08-26 12:29:09.620 [bus debug] start request 31
          2021-08-26 12:29:09.620 [bus debug] arbitration start with 31
          received unknown MS cmd: 1008b51009000000ffffff070000 / 01012021-08-26 12:29:09.799 [bus debug] arbitration lost
          2021-08-26 12:29:09.799 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:09.885 [update info] received MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:29:09.885 [update notice] received unknown MS cmd: 1076b5110101 / 09ff3d0013ff6e0000ff
          2021-08-26 12:29:09.887 [bus debug] start request 31
          2021-08-26 12:29:09.887 [bus debug] arbitration start with 31
          2021-08-26 12:29:10.066 [bus debug] arbitration lost
          2021-08-26 12:29:10.066 [bus debug] ERR: arbitration lost during ready, retry
          2021-08-26 12:29:10.152 [update info] received MS cmd: 1076b512030f0201 / 0772030000801302
          2021-08-26 12:29:10.152 [update notice] received unknown MS cmd: 1076b512030f0201 / 0772030000801302
          2021-08-26 12:29:10.153 [bus debug] start request 31
          2021-08-26 12:29:10.153 [bus debug] arbitration start with 31
          2021-08-26 12:29:10.331 [bus debug] arbitration lost
          2021-08-26 12:29:10.331 [bus debug] notify request: ERR: arbitration lost
          2021-08-26 12:29:10.331 [main error] scan config 76: ERR: arbitration lost
          2021-08-26 12:29:10.361 [update info] received BC cmd: 10feb505025c00
          2021-08-26 12:29:10.361 [update notice] received unknown BC cmd: 10feb505025c00
          2021-08-26 12:29:10.363 [bus debug] start request 31
          2021-08-26 12:29:10.363 [bus debug] arbitration start with 31
          2021-08-26 12:29:10.454 [main notice] ebusd stopped
            usb-ESERA
            floret88
            #242
            @glasfaser Man glaubt es kaum, aber nach abnehmen des VRC700/4 und neu rauf stecken, ergibt sich nun eine neue Ansicht ;-)
            pi@raspberrypi:~ $ ebusctl i
            version: ebusd 21.2.v21.2
            signal: acquired
            symbol rate: 109
            max symbol rate: 122
            reconnects: 0
            masters: 4
            conditional: 0
            poll: 0
            update: 10
            address 03: master #11
            address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0308;HW=0403", loaded "vaillant/08.hmu.csv"
            address 10: master #2
            address 26: slave, scanned "MF=Vaillant;ID=VR_71;SW=0104;HW=0503"
            address 31: master #8, ebusd
            address 36: slave #8, ebusd
            address 71: master #9
            address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0308;HW=0403"
            pi@raspberrypi:~ $ ebusctl scan result
            1 scan(s) still running
            08;Vaillant;HMU00;0308;0403
            26;Vaillant;VR_71;0104;0503
            76;Vaillant;VWZ00;0308;0403
            pi@raspberrypi:~ $ ebusctl grab result
            1008b507010a / 03828202 = 1
            1008b5110100 / 09d90113000008000100 = 6
            1008b5160111 / 09010506100634060a06 = 1
            1026b5160111 / 090103010e0130010301 = 1
            1026b5230106 / 10ec01f401d5012202df0100800080003c = 34
            1026b5230107 / 0f008000800080008000008000805705 = 34
            1076b5110101 / 09ff3b6010ff690000ff = 33
            1076b5160111 / 00 = 1
            10feb505025c00 = 6
            10feb510020601 = 1
            1008b507020900 / 029f02 = 1
            1008b507020946 / 020202 = 5
            1008b512020464 / 0101 = 1
            1008b5120204ff / 0101 = 1
            1008b513020528 / 0101 = 1
            1076b512030f0000 / 074a030000801302 = 1
            1076b512030f0201 / 0748030000801302 = 33
            1076b51303040d00 / 02ffff = 6
            1008b516081000ffff0200212a / 0b0000ff02001a2b88f5014b = 4
            1008b516081002ffff02008129 / 0b12ffff0200812900000000 = 52
            1026b5030c0700ffffffffffffffffffff / 0101 = 1
            1026b516081000ffff0304212a / 0b2000ff03041a2b00000000 = 3
            1026b516081002ffff0304e12a / 0b2201ff0304e12a00000000 = 28
            1026b5230402000000 / 020105 = 1
            1026b5230402010000 / 020100 = 1
            1026b5230402020000 / 020105 = 1
            1026b5230b0401010100002022000000 / 0101 = 1
            1026b523040201013c / 020105 = 31
            1026b5230402000140 / 020105 = 31
            1026b5230402020146 / 020105 = 31
            1026b5230f05ffffff000000ffffffffffff0000 / 0101 = 32
            1076b51009000000ffffff010000 / 0101 = 31
            1076b510090000ffffffff050000 / 0101 = 1
            Was ist nun alles möglich? oder fehlen hier noch wichtige CSV Konfigurationen?
            Danke und LG
            • F floret88
              signal: acquired
              symbol rate: 109
              reconnects: 0
              masters: 4
              conditional: 0
              poll: 0
              update: 10
              10feb505025c00 = 6
              10feb510020601 = 1
              Danke und LG
              GlasfaserG Offline
              GlasfaserG Offline
              #243
              @floret88 sagte in eBus Adapter Vaillant:
              Er erkennt aber nur ein Vaillant VR 71 Mischermodul , aber nicht den VRC700.
              Hast du mal alles ausgeschaltet ,so wie das aussieht ist der Bus zusammen gebrochen .
              • C Offline
                Cino
                #244
                Ich würde den Bus mal neustarten ohne das Ersa Modul.
                IOB@RPI4
                Shelly, Zigbee, ebus
                  floret88
                  #245
                  @glasfaser Ok. Gibt es hier eine Abfolge wie das Ausschalten / Einschalten zu erfolgen hat.
                  @Cino Bzw. wie kann ich den Bus getrennt neu starten? Mittlerweile habe ich auch die Baudrate und auch die Latenzzeit herunter geschraubt.
                  Im FHEM Forum wird des weiteren Berichtet, dass man auch am Poti drehen soll. Was sagt Ihr dazu?
                  Anscheinend "müllt" auch der USB Adapter von ESERA den Bus ziemlich voll.
                  LG
                  • F floret88
                    LG
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #246
                    Du hast aber kein Fehler in deinen Log´s , da würde ich nicht rumschrauben
                    Beispiel mit Fehler im Log:
                    [bus error] signal lost
                    • F floret88
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #247
                      Diese Meldung hast du auch ,
                      Schau mal bei Ihm
                      https://forum.iobroker.net/topic/29359/ebus-adapter-vaillant/177
                      • GlasfaserG Glasfaser
                        Schau mal bei Ihm
                        floret88
                        #248
                        @glasfaser klare Aussage von John30 99704C91-1968-4562-B32B-2EE38BB58405.png
                        • C Offline
                          Cino
                          #249
                          Verstell bloß nicht die Baudrate. Die muss stimmen.
                          Mach den Adapter ab und dann die Therme einmal Stromlos machen. Danach kannste den Adapter wieder verbinden.
                          Ist mir auch schon passiert das der Bus abgestürzt ist. Das Polling darf auch nicht so intensiv sein vom Adapter. Damit blockierst du auch den Bus.
                          Falls ein Poti vorhanden ist würde ich nicht daran drehen. Die sind schon richtig eingestellt beim Vertrieb,
                          IOB@RPI4
                          F 2 Antworten Letzte Antwort
                          • C Cino
                            floret88
                            #250
                            @cino Standardmäßig war die Baudrate auf 9600 und lt Bedienungsanleitung von Esera soll diese bei 2400 sein! (Brachte keine Änderung!)
                            Ja ich weigere mich Wehement etwas daran zu drehen! Aber langsam will ich das zum laufen bekommen, und versuche jede Nadel im Heuhaufen zu finden!
                            Da gerade die kühle Phase anfängt, möchte ich ungern die Heizung zerstören - werde morgen dennoch den kompletten Neustart der WP probieren und Euch berichten!
                            a200A 1 Antwort Letzte Antwort
                            • F floret88
                              a200A Offline
                              a200A Offline
                              a200
                              #251
                              @floret88 Also das mit dem Drehen ist so eine Sache...
                              Bei meinem Esera-Adapter sehe ich folgende LED:
                              • Anschluss 10: Leuchtet konstant
                              • Pwr: Leuchtet konstant
                              • Data: blinkt unregelmäßig
                              Wenn es bei dir auch so ist, dann kannst du dir wenigstens sicher sein, dass dein Esera Daten empfangen kann.
                              • Sollte die Anschluss 10 LED nicht leuchten, dann hast du ein Problem in der eBus Verkabelung.
                              • Sollte die Power LED nicht leuchten, dann hast du Probleme mit der Stromversorgung bzw. dem USB-Anschluss.
                              • Sollte die Data-LED nicht blinken, dann werden keine Daten empfangen. das kann mehrere Ursachen haben.
                              1. eBus Verkabelung
                              2. Der eBus Signal-Level muss angepasst werden (war bei mir so). In dem Fall musst du an dem kleinen Potentiometer am Adapter leicht drehen. Siehe eBus Anleitungen von John30 im Netz. z.B. https://wiki.fhem.de/wiki/EBUS unter dem Punkt: Poti abgleichen.
                              Wir sind gespannt auf deine Berichte. Viel Erfolg,
                              a200.
                              IoBroker auf QNAP TS-451, Raspi und NUC
                              • C Cino
                                floret88
                                schrieb am zuletzt editiert von floret88
                                #252
                                @cino Neustart ohne eBus Adapter und anschließenden wieder verbinden, bringt keinen Erfolg!
                                @a200 Alles bereits überprüft, bis auf die Poti Einstellungen.
                                Hier ein kleines Video, damit man sieht - alles OK 🐶
                                https://www.youtube.com/watch?v=5-BFxLjh02g
                                Dann bleibt mir eigtl. nur noch Option: Einstellung am Poti verändern.
                                • F floret88
                                  a200A Offline
                                  a200A Offline
                                  a200
                                  #253
                                  @floret88 Na dann ist ja aus der Hardware-Sicht alles in Ordnung. Ich hätte weiter oben lesen sollen. Da steht:
                                  signal: acquired
                                  symbol rate: 109
                                  Sorry. Mea culpa.
                                  F 1 Antwort Letzte Antwort
                                  • a200A a200
                                    signal: acquired
                                    symbol rate: 109
                                    Sorry. Mea culpa.
                                    floret88
                                    #254
                                    @a200 kein Problem und ich bekomme langsam einen Nervenzusammenbruch!
                                    Jetzt lese ich im Wiki das der Esera USB Adapter ebenfalls Probleme mit der Latency hat. Also am Poti drehen - Die Freude ist riesig wie Ihr euch denken könnt.
                                    Des Weiteren auch noch angemeldet für den eBus Adapter v3 🤡 - i don‘t like
                                    Werde Euch nach Poti Dreherei auf den aktuellen Stand bringen! Trotzdem Danke an alle für die Versuche mir zu helfen! Danke.
                                    • F floret88
                                      floret88
                                      #255
                                      @floret88 nach 2 stündigen Drehen am Poti und x Neustarts des Raspberrys und X mal runter nehmen des VRC habe ich die Nase voll, und lass es bleiben! Abwarten auf den eBus Adapter v3 von John30.
                                      Haben fertig, schönes Wochenende
                                      • C Offline
                                        Cino
                                        #256
                                        Ich hab den hier, funktioniert top
                                        https://www.esera.de/produkte/ebus/135/1-wire-hub-platine
                                        IOB@RPI4
                                        • C Cino
                                          floret88
                                          #257
                                          @cino Den habe ich auch, und funkt leider nicht zufriedenstellend.
                                          C 1 Antwort Letzte Antwort
