  4. Adapter Klipper-Moonraker
klippermoonrakeradapter update
163 Beiträge 26 Kommentatoren 33.8k Aufrufe 24 Beobachtet
  • G Offline
    gerald123
    Ich verwende auf meinem System den Adapter "Klipper-Moonraker v0.0.4" zur Steuerung meins 3D Druckers.
    Leider bekomme ich jetzt seid dem Systemupdate von js-controller auf 3.3 und des Admin auf 5.1.23 laufend Meldungen im Log.
    klipper-moonraker.0
    2021-08-26 18:02:09.932	info	[Error catched and send to Sentry, thank you collaborating!] error: State attribute definition missing for + stalls
    klipper-moonraker.0
    2021-08-26 18:02:09.850	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_y.position_max" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.849	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_y.microsteps" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.847	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_y.homing_speed" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.846	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_y.endstop_pin" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.844	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_y.position_endstop" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.841	info	State value to set for "klipper-moonraker.0.configfile.settings.stepper_x.endstop_pin" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.724	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_z.position_max" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.722	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_z.microsteps" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.721	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_z.position_min" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.719	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_z.endstop_pin" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.718	info	State value to set for "klipper-moonraker.0.configfile.config.stepper_z.position_endstop" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.713	info	State value to set for "klipper-moonraker.0.configfile.settings.stepper_y.endstop_pin" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.482	info	State value to set for "klipper-moonraker.0.configfile.settings.stepper_z.endstop_pin" has to be type "number" but received type "string"
    klipper-moonraker.0
    2021-08-26 18:02:09.480	info	State value to set for "klipper-moonraker.0.fan.rpm" has to be type "number" but received type "string"
    Kann mir hier wer von euch weiterhelfen wie ich diese Meldung beseitigen kann?
    Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
    MichMeinM ChaotC J DutchmanD 4 Antworten Letzte Antwort
    • G gerald123
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      klipper-moonraker.0
      MichMeinM Offline
      MichMeinM Offline
      MichMein
      @gerald123 da solltest du wohl am besten ein issue auf GitHub bei dem entsprechenden Adapter eröffnen.
      Gruß Michael
      Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
      • G gerald123
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        klipper-moonraker.0
        ChaotC Offline
        ChaotC Offline
        Chaot
        @gerald123
        1. Meldung per Github an den Entwickler damit er ein Update bereitstellt.
        2. Am Adapter den Loglevel auf warn oder höher schalten.
        G da_WoodyD 2 Antworten Letzte Antwort
        • ChaotC Chaot
          @gerald123
          gerald123
          @chaot
          Ich lege mal ein issue auf GitHub an.
          • G gerald123
            @chaot
            ChaotC Offline
            ChaotC Offline
            Chaot
            @gerald123 Den Loglevel kannst du so lange hochsetzen bis der Entwickler reagiert. Das sit ja "nur" eine Info Meldung die aktuell noch keine richtigen Auswirkungen hat, aber längerfristig natürlich gefixt werden sollte. Aber bis dahin lässt sich die Meldung im Log unterdrücken und das wird nicht so riesig groß.
            • G gerald123
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              klipper-moonraker.0
              JoergH
              @gerald123 Ich habe mir gerade einen 3D Drucker zugelegt und würde gerne die SD Karten Arie vermeiden. Mit welchem Drucker arbeitest Du denn? Was kann ich mit dem Klipper-Moonraker machen? Ist das quasi nur ein Server-Client System bei dem ich dann den Anschluss des Druckers über USB an den Computer emuliere?
              • da_WoodyD Offline
                da_WoodyD Offline
                @joergh da du neu beim 3d druck bist, solltest du erstmal mit octoprint anfangen. das kommt auf einen raspi als "zwischenstück" zum drucker.
                um mit klipper arbeiten zu können, musst du auch die drucker FW flashen. dazu sollte man sich schon auskennen...
                8beb52cf-432b-48d0-9821-2caab68f892b-grafik.png 929f1a16-3661-490a-b33a-1261b2ba24b8-grafik.png
                • da_WoodyD da_Woody
                  JoergH
                  @da_woody Ja, Klipper wie gesagt hat auch noch ein paar Nachteile bei meinem Drucker, deswegen werde ich das nicht nutzen. Octoprint liefert eigentlich was ich brauche, auch wenn das flashen easy ist dank youtube.
                  • ChaotC Chaot
                    @gerald123
                    da_WoodyD Offline
                    da_WoodyD Offline
                    @chaot weils mich gerade wieder nervt.
                    https://github.com/DrozmotiX/ioBroker.klipper-moonraker/issues/36
                    irgendwie tut sich bei dem adapter leider überhaupt nichts mehr.
                    drucker/raspi abgedreht, gibt endlose error meldungen. gibts bei octoprint nicht. beide auf error, logischerweise nicht verbunden.
                    soweit ich auf github sehe, ist da @Dutchman involviert... seit 13 monaten tut sich da nichts mehr. :(
                      Sushibomba
                      Weiß jemand ob der Adapter aktuell noch mit Klipper läuft? VG
                      • CarstenDerGroßeC Offline
                        CarstenDerGroße
                        Es ist mit einschränkungen noch brauchbar aber scheint nicht mehr mit updates versorgt zu werden
                          Sushibomba
                          @Dutchman
                          Hey... Wollte dich kurz was fragen. Ich finde es klasse das ich den Klipper Adapter für ioBroker habe, jedoch habe ich auch das Problem, dass wenn ich meinen Drucker ausschalte, am nächsten Tag beispieslweise etwas drucken möchte, den Drucker wieder mit Strom versorgt habe und ich einen Klipper Neustart ausgeführt habe, dass die Datenpunkte im Adapter nicht mehr aktualisiert werden.
                          Heißt erst wenn ich den Adapter in ioBroker wieder neu starte aktualisiert er die Werte.
                          Ich weiß das schon länger nichts mehr am Adapter gemacht wurde, aber wäre es vielleicht möglich das irgendwie zu fixen?
                          Bedanke mich schon mal ganz herzlich im vorraus.
                          H 1 Antwort Letzte Antwort
                          • S Sushibomba
                            @Dutchman
                            Hansi1234
                            @sushibomba
                            @Dutchman
                            selber Problem hier auch.
                            • H Hansi1234
                              @sushibomba
                              @Dutchman
                              DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              @hansi1234 sagte in Adapter Klipper-Moonraker:
                              @sushibomba
                              @Dutchman
                              Ich hätte im Herbst wieder Luft mal in den Code zu schauen. Benötige dafür aber dringends Zugang zu einer Klipper Installation da ich es selber nicht laufen habe 🫣
                              H S 2 Antworten Letzte Antwort
                              • DutchmanD Dutchman
                                @sushibomba
                                @Dutchman
                                Hansi1234
                                @dutchman kann ich dann gerne einrichten. Grüße
                                  @sushibomba
                                  @Dutchman
                                  Sushibomba
                                  @dutchman
                                  Ich natürlich auch :)
                                  • S Sushibomba
                                    @dutchman
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    schrieb am zuletzt editiert von Dutchman
                                    @sushibomba @Hansi1234
                                    Super! Ich würde Dan auch gerne auf euch zurück kommen
                                    Ich bräuchte, am liebsten per VPN oder dedicaties port freigabe, Zugang zu einem laufenden System damit ich die Nachrichten sauber implementieren kan und verstehen wie bzw. in welchen Abständen Daten ankommen
                                    Ich glaube momentan ballert der Adapter auch extrem viele Daten schnell hintereinander was schwierig sein könnte für etwas schwächere Systeme.
                                    Wen das so ist müsste zb ein buffer eingebaut werden und solchen kleine Sachen halt
                                    Aktives testen + Feedback auch sehr wichtig um das Thema erfolgreich zu Ende bringen zu können 🤗
                                      Sushibomba
                                      @dutchman sagte in Adapter Klipper-Moonraker:
                                      dedicaties
                                      Weiß zwar nicht wie das geht aber bekommen wir bestimmt hin.
                                      Vielleicht weiß ja jemand anderes hier auch wie das mit den Dedicated Servern oder VPN läuft und ich kann was anderes testen.
                                      • S Sushibomba
                                        dedicaties
                                        DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        @sushibomba sagte in Adapter Klipper-Moonraker:
                                        dedicaties
                                        VPN einrichten oder Portofreigabe kriegen wir schon hin 🤜🤛
                                        Merlin123M 1 Antwort Letzte Antwort
                                          dedicaties
                                          Merlin123M Offline
                                          Merlin123M Offline
                                          Merlin123
                                          Beim Testen kann ich auch gerne helfen. Hab jetzt auch ne Klipper Installation
                                          Beta-Tester
