  4. Rega Fehler
    6.4k
Rega Fehler
141 Beiträge 7 Kommentatoren 19.0k Aufrufe 5 Beobachtet
  • C Chris-D 0
    @chris-d-0
    pi@raspberrypi:~ $ iobroker start admin
    pi@raspberrypi:~ $
    @chris-d-0 iobroker list instances
    C 1 Antwort Letzte Antwort
      Chris-D 0
      @homoran said in Rega Fehler:
      pi@raspberrypi:~ $ iobroker list instances
        system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0              : backitup              -  enabled
      + system.adapter.discovery.0             : discovery             -  enabled
      + system.adapter.echarts.0               : echarts               -  enabled
        system.adapter.email.0                 : email                 - disabled
        system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
        system.adapter.fritzdect.0             : fritzdect             - disabled
        system.adapter.habpanel.0              : habpanel              -  enabled
      + system.adapter.history.0               : history               -  enabled
      + system.adapter.hm-rega.0               : hm-rega               -  enabled
      + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
      + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
        system.adapter.ical.0                  : ical                  -  enabled
      + system.adapter.info.0                  : info                  -  enabled
      + system.adapter.iot.0                   : iot                   -  enabled
      + system.adapter.javascript.0            : javascript            -  enabled
        system.adapter.material.0              : material              -  enabled
        system.adapter.mobile.0                : mobile                - disabled
        system.adapter.openweathermap.0        : openweathermap        -  enabled
      + system.adapter.ping.0                  : ping                  -  enabled
      + system.adapter.samsung.0               : samsung               -  enabled
      + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonos.0                 : sonos                 -  enabled
        system.adapter.synology.0              : synology              - disabled, port: 5000
      + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                : tr-064                -  enabled
      + system.adapter.tr-064.1                : tr-064                -  enabled
        system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
        system.adapter.vis.0                   : vis                   - disabled
        system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      • C Chris-D 0
        + instance is alive
        @chris-d-0 sagte in Rega Fehler:
        der admin läuft immer noch nicht
        iobroker update -i
          iobroker update -i
          Chris-D 0
          iobroker update -i
          pi@raspberrypi:~ $ iobroker update -i
          hash unchanged, use cached sources
          update done
          Adapter    "admin"         : 5.1.23   , installed 5.1.23
          Adapter    "backitup"      : 2.1.13   , installed 2.1.13
          Adapter    "cloud"         : 4.1.0    , installed 4.1.0
          Adapter    "discovery"     : 2.7.0    , installed 2.7.0
          Adapter    "echarts"       : 0.4.13   , installed 0.4.13
          Adapter    "email"         : 1.0.10   , installed 1.0.10
          Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
          Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
          Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
          Adapter    "history"       : 1.9.13   , installed 1.9.13
          Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
          Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
          Adapter    "ical"          : 1.11.2   , installed 1.11.2
          Adapter    "info"          : 1.9.8    , installed 1.9.8
          Adapter    "iot"           : 1.8.22   , installed 1.8.22
          Adapter    "javascript"    : 5.2.8    , installed 5.2.8
          Controller "js-controller" : 3.3.15   , installed 2.2.8 [Updateable]
          Adapter    "material"      : 1.0.4    , installed 1.0.4
          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
          Adapter    "openweathermap": 0.1.0    , installed 0.1.0
          Adapter    "ping"          : 1.5.0    , installed 1.5.0
          Adapter    "samsung"       : 0.2.9    , installed 0.2.9
          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
          Adapter    "socketio"      : 3.1.4    , installed 3.1.4
          Adapter    "sonos"         : 2.1.1    , installed 2.1.1
          Adapter    "synology"      : 1.0.0    , installed 1.0.0
          Adapter    "telegram"      : 1.10.0   , installed 1.10.0
          Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
          Adapter    "viessmann"     : 1.3.4    , installed 1.3.4
          Adapter    "vis"           : 1.4.3    , installed 1.4.3
          Adapter    "web"           : 3.4.7    , installed 3.4.7
          Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
          haselchenH HomoranH 2 Antworten Letzte Antwort
          • C Chris-D 0
            iobroker update -i
            update done
            haselchenH Offline
            haselchenH Offline
            haselchen
            @Homoran
            Jetzt wissen wir warum :)
            Admin V5 und JS 2.2.8
            • C Chris-D 0
              iobroker update -i
              update done
              du hast admin v5 und eine uralte Version des Controllers. Das passt nicht zsammen
              Bitte Controller auf v3.3 bringen
                Chris-D 0
                @homoran jaaa und wie mache ich das am besten?^^
                • C Chris-D 0
                  https://forum.iobroker.net/topic/46758/js-controller-3-3-jetzt-im-stable
                    Chris-D 0
                    @homoran Ich danke euch!
                    • C Chris-D 0
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @chris-d-0
                      So leicht kommste uns nicht davon ;)
                      Erst die funktionierende Admin Seite posten mit JS Controller Version ;)
                      Und natürlich die Info ob mit der CCU wieder alles läuft.
                      C 2 Antworten Letzte Antwort
                      • haselchenH haselchen
                        @chris-d-0
                        Chris-D 0
                        @haselchen hehe keine Angst, bevor es nicht läuft, lasse ich euch nicht vom Haken ;-)
                        Installiert gerade
                          @chris-d-0
                          Chris-D 0
                          @haselchen Braucht relativ lange...
                          pi@raspberrypi:~ $ iobroker upgrade self
                          Update js-controller from @2.2.8 to @3.3.15
                          NPM version: 6.14.14
                          npm install iobroker.js-controller@3.3.15 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                          • C Chris-D 0
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @chris-d-0
                            Hast du vorher iobroker stop eingegeben?
                              @chris-d-0
                              Chris-D 0
                              @haselchen yes
                              • C Chris-D 0
                                @haselchen yes
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @chris-d-0
                                Auf keinen Fall unterbrechen oder Stromlos machen.
                                Warte einfach mal ab....
                                  @chris-d-0
                                  Chris-D 0
                                  schrieb am zuletzt editiert von Chris-D 0
                                  @haselchen danach passierte lange nichts und danach kam einfach eine neue Eingabezeile
                                  pi@raspberrypi:~ $
                                  • C Chris-D 0
                                    pi@raspberrypi:~ $
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @chris-d-0
                                    Gib mal in der Reihenfolge ein
                                    iobroker stop
                                    sudo -H -u iobroker npm install iobroker.js-controller
                                    iobroker start
                                      @chris-d-0
                                      iobroker stop
                                      iobroker start
                                      Chris-D 0
                                      @haselchen
                                      pi@raspberrypi:~ $ iobroker stop
                                      pi@raspberrypi:~ $
                                      pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                                      npm WARN checkPermissions Missing write access to /home/pi/node_modules/@iobroker
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                      npm WARN pi No description
                                      npm WARN pi No repository field.
                                      npm WARN pi No README data
                                      npm WARN pi No license field.
                                      npm ERR! code EACCES
                                      npm ERR! syscall access
                                      npm ERR! path /home/pi/node_modules/@iobroker
                                      npm ERR! errno -13
                                      npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'
                                      npm ERR!  [Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'] {
                                      npm ERR!   errno: -13,
                                      npm ERR!   code: 'EACCES',
                                      npm ERR!   syscall: 'access',
                                      npm ERR!   path: '/home/pi/node_modules/@iobroker'
                                      npm ERR! }
                                      npm ERR!
                                      npm ERR! The operation was rejected by your operating system.
                                      npm ERR! It is likely you do not have the permissions to access this file as the current user
                                      npm ERR!
                                      npm ERR! If you believe this might be a permissions issue, please double-check the
                                      npm ERR! permissions of the file and its containing directories, or try running
                                      npm ERR! the command again as root/Administrator.
                                      npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T14_20_19_283Z-debug.log
                                      HomoranH haselchenH 3 Antworten Letzte Antwort
                                      • C Chris-D 0
                                        @haselchen
                                        pi@raspberrypi:~ $
                                        npm ERR! errno -13
                                        npm ERR! }
                                        npm ERR!
                                        npm ERR!
                                        was hast du da angestellt?
                                        den npm-Befehl in /home/pi ausgeführt???
                                        der muss in /opt/iobroker ausgeführt werden
                                        • C Chris-D 0
                                          @haselchen
                                          pi@raspberrypi:~ $
                                          npm ERR! errno -13
                                          npm ERR! }
                                          npm ERR!
                                          npm ERR!
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @chris-d-0
                                          cd /opt/iobroker
                                          curl -sL https://iobroker.net/fix.sh | bash -
                                          Edit:
                                          sehe ich jetzt erst....wo zum Himmel hast du das alles hin installiert?
