  4. Rega Fehler
    6.4k
Rega Fehler
141 Beiträge 7 Kommentatoren 19.0k Aufrufe 5 Beobachtet
    @chris-d-0 iobroker list instances
    Chris-D 0
    @homoran said in Rega Fehler:
      system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0              : backitup              -  enabled
    + system.adapter.discovery.0             : discovery             -  enabled
    + system.adapter.echarts.0               : echarts               -  enabled
      system.adapter.email.0                 : email                 - disabled
      system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
      system.adapter.fritzdect.0             : fritzdect             - disabled
      system.adapter.habpanel.0              : habpanel              -  enabled
    + system.adapter.history.0               : history               -  enabled
    + system.adapter.hm-rega.0               : hm-rega               -  enabled
    + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
    + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
      system.adapter.ical.0                  : ical                  -  enabled
    + system.adapter.info.0                  : info                  -  enabled
    + system.adapter.iot.0                   : iot                   -  enabled
    + system.adapter.javascript.0            : javascript            -  enabled
      system.adapter.material.0              : material              -  enabled
      system.adapter.mobile.0                : mobile                - disabled
      system.adapter.openweathermap.0        : openweathermap        -  enabled
    + system.adapter.ping.0                  : ping                  -  enabled
    + system.adapter.samsung.0               : samsung               -  enabled
    + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonos.0                 : sonos                 -  enabled
      system.adapter.synology.0              : synology              - disabled, port: 5000
    + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                : tr-064                -  enabled
    + system.adapter.tr-064.1                : tr-064                -  enabled
      system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
      system.adapter.vis.0                   : vis                   - disabled
      system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    • C Chris-D 0
      + instance is alive
      @chris-d-0 sagte in Rega Fehler:
      + instance is alive
      iobroker start admin
      C 1 Antwort Letzte Antwort
        + instance is alive
        Chris-D 0
        keine Verbesserung
        • C Chris-D 0
          keine Verbesserung
          keine Verbesserung
          Das steht dann in der Konsole?
            keine Verbesserung
            Chris-D 0
            @homoran hehe nein - weiterhin 057711a8-514f-4ed4-8e2c-ee4b881926e5-image.png
            • C Chris-D 0
              willst du mich veräppeln?
              du sollst den genannten Befehl in die Konsole hämmern und die gesamte Ein- und Ausgabe posten!
              in Code-tags!
                in Code-tags!
                Chris-D 0
                @homoran Nein, ich will dich nicht veräppeln. Es kam nix in der Konsole danach
                C HomoranH 2 Antworten Letzte Antwort
                • C Chris-D 0
                  Chris-D 0
                  @chris-d-0
                  pi@raspberrypi:~ $ iobroker start admin
                  pi@raspberrypi:~ $
                  • C Chris-D 0
                    also nochmal:
                    @homoran sagte in Rega Fehler:
                    in Code-tags!
                    • C Chris-D 0
                      @chris-d-0
                      pi@raspberrypi:~ $
                        Chris-D 0
                        pi@raspberrypi:~ $ iobroker list instances
                        + instance is alive
                        • C Chris-D 0
                          + instance is alive
                          der admin läuft immer noch nicht
                          iobroker update -i
                            iobroker update -i
                            Chris-D 0
                            iobroker update -i
                            pi@raspberrypi:~ $ iobroker update -i
                            hash unchanged, use cached sources
                            update done
                            Adapter    "admin"         : 5.1.23   , installed 5.1.23
                            Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                            Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                            Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                            Adapter    "echarts"       : 0.4.13   , installed 0.4.13
                            Adapter    "email"         : 1.0.10   , installed 1.0.10
                            Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
                            Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                            Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                            Adapter    "history"       : 1.9.13   , installed 1.9.13
                            Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                            Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                            Adapter    "ical"          : 1.11.2   , installed 1.11.2
                            Adapter    "info"          : 1.9.8    , installed 1.9.8
                            Adapter    "iot"           : 1.8.22   , installed 1.8.22
                            Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                            Controller "js-controller" : 3.3.15   , installed 2.2.8 [Updateable]
                            Adapter    "material"      : 1.0.4    , installed 1.0.4
                            Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                            Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                            Adapter    "ping"          : 1.5.0    , installed 1.5.0
                            Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                            Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                            Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                            Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                            Adapter    "synology"      : 1.0.0    , installed 1.0.0
                            Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                            Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                            Adapter    "viessmann"     : 1.3.4    , installed 1.3.4
                            Adapter    "vis"           : 1.4.3    , installed 1.4.3
                            Adapter    "web"           : 3.4.7    , installed 3.4.7
                            Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
                            haselchenH HomoranH 2 Antworten Letzte Antwort
                            • C Chris-D 0
                              iobroker update -i
                              update done
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @Homoran
                              Jetzt wissen wir warum :)
                              Admin V5 und JS 2.2.8
                              • C Chris-D 0
                                iobroker update -i
                                update done
                                du hast admin v5 und eine uralte Version des Controllers. Das passt nicht zsammen
                                Bitte Controller auf v3.3 bringen
                                  Chris-D 0
                                  @homoran jaaa und wie mache ich das am besten?^^
                                  • C Chris-D 0
                                    https://forum.iobroker.net/topic/46758/js-controller-3-3-jetzt-im-stable
                                      Chris-D 0
                                      @homoran Ich danke euch!
                                      • C Chris-D 0
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @chris-d-0
                                        So leicht kommste uns nicht davon ;)
                                        Erst die funktionierende Admin Seite posten mit JS Controller Version ;)
                                        Und natürlich die Info ob mit der CCU wieder alles läuft.
                                        C 2 Antworten Letzte Antwort
                                        • haselchenH haselchen
                                          @chris-d-0
                                          Chris-D 0
                                          @haselchen hehe keine Angst, bevor es nicht läuft, lasse ich euch nicht vom Haken ;-)
                                          Installiert gerade
