  4. Iobroker startet nach Phoscon Installation nicht mehr
    6.6k
36 Beiträge 4 Kommentatoren 2.8k Aufrufe 2 Beobachtet
  • M mauseb
    @mauseb said in Iobroker startet nach Phoscon Installation nicht mehr:
    @thomas-braun said in Iobroker startet nach Phoscon Installation nicht mehr:
    @mauseb Bitte Konsolentext in CodeTags packen, keine Screenshots.
    wie geht das genau?
    pi@HomeRaspi:~ $ iobroker status
     Cannot read system.config: null (OK when migrating or restoring)
    iobroker is not running on this host.
    Objects type: file
    States  type: file
    pi@HomeRaspi:~ $ iobroker list instances
    + instance is alive
    + instance is alive
    @mauseb
    iobroker list adapters
    iobroker start
      @mauseb
      iobroker start
      mauseb
      pi@HomeRaspi:~ $ iobroker list adapters
      pi@HomeRaspi:~ $
      Bei iobroker start passiert garnichts
      • M mauseb
        pi@HomeRaspi:~ $
        @mauseb
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
          @mauseb
          cd /opt/iobroker
          mauseb
          cd /opt/iobroker
          pi@HomeRaspi:~ $ cd /opt/iobroker
          pi@HomeRaspi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          > iobroker.js-controller@3.3.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.14.14
          > iobroker.js-controller@3.3.15 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          object 0_userdata.0.example_state created
          object 0_userdata.0 created
          object alias.0 created
          object system.certificates created
          object system.repositories created
          object system.config created
          object enum.functions created
          object enum.rooms created
          object system.group.user created
          object system.group.administrator created
          object _design/custom created
          object _design/system created
          object system.meta.uuid created: e8850a24-25af-401f-f06a-d74dfd951728
          object system.user.admin created
          Renamed repository "default to "stable"
          Renamed repository "latest to "beta"
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          + iobroker.js-controller@3.3.15
          updated 1 package in 36.68s
          74 packages are looking for funding
            run `npm fund` for details
          • M mauseb
            cd /opt/iobroker
            @mauseb
            Den iobroker hast du aber schon länger nicht mehr aktualisiert.
            Läuft der jetzt?
              @mauseb
              Läuft der jetzt?
              mauseb
              @mauseb
              Läuft der jetzt?
              ne leider läuft er noch nicht.
              hatte gestern eigentlich noch update gemacht, nodes js 12.22.5 auch upgedatet.
              ging alles, bis auf den Neustart gestern Abend da sich ein Skript wegen WLed Lampen aufgegangen hatte.
              Danach kam ich nicht mehr im iobroker rein
              • M mauseb
                @mauseb
                Läuft der jetzt?
                @mauseb
                Und was kommt jetzt zurück?
                iobroker restart
                iobroker status
                which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                  @mauseb
                  iobroker restart
                  iobroker status
                  mauseb
                  pi@HomeRaspi:~ $ iobroker restart
                  Objects type: file
                  States  type: file
                  pi@HomeRaspi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v12.22.5
                  v12.22.5
                  6.14.14
                  nodejs:
                    Installiert:           12.22.5-1nodesource1
                    Installationskandidat: 12.22.5-1nodesource1
                    Versionstabelle:
                   *** 12.22.5-1nodesource1 500
                          500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                       10.24.0~dfsg-1~deb10u1 500
                  pi@HomeRaspi:~ $
                  • M mauseb
                    Objects type: file
                    States  type: file
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.5
                    v12.22.5
                    6.14.14
                    nodejs:
                      Versionstabelle:
                    pi@HomeRaspi:~ $
                    @mauseb
                    Läuft doch.
                      @mauseb
                      Läuft doch.
                      mauseb
                      @mauseb
                      Läuft doch.
                      anscheinend, aber über Safari mit der ip :8081 kommt leider nichts
                      • M mauseb
                        @mauseb
                        Läuft doch.
                        @mauseb Verschlüsselt per https?
                        Das funktioniert soweit ich weiß im Moment nicht.
                          mauseb
                          https ist es nicht.
                          + instance is alive
                          pi@HomeRaspi:~ $
                          Das schmeißt er raus, aber warum kein zugriff mit dem Explorer?
                          • M mauseb
                            https ist es nicht.
                            + instance is alive
                            pi@HomeRaspi:~ $
                            @mauseb Da läuft halt der Admin nicht.
                            iobroker start admin
                              mauseb
                              pi@HomeRaspi:~ $ iobroker start admin
                              Cannot find any instances of "admin"!
                              pi@HomeRaspi:~ $
                                mauseb
                                Hallo Thomas, vielen Dank für dein Mühe. Ich weiß echt nicht was mit meinen System los ist.
                                Jetzt sagt er keine Instanz von "Admin"
                                pi@HomeRaspi:~ $
                                • M mauseb
                                  pi@HomeRaspi:~ $
                                  @mauseb
                                  iobroker install admin
                                    mauseb
                                    es bleibt verhext :-(
                                    pi@HomeRaspi:~ $ iobroker install admin
                                    adapter "admin" already installed. Use "upgrade" to upgrade to a newer version.
                                    pi@HomeRaspi:~ $
                                    • M mauseb
                                      pi@HomeRaspi:~ $
                                      @mauseb
                                      Dann versuch
                                      iobroker upgrade admin@5.1.23
                                        @mauseb
                                        @thomas-braun ein fall für das mini howto ?
                                          mauseb
                                          @homoran said in Iobroker startet nach Phoscon Installation nicht mehr:
                                          auch nicht :-)
                                          pi@HomeRaspi:~ $ iobroker upgrade admin@5.1.23
                                          Update repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                          hash changed or no sources cached => force download of new sources
                                          Would you like to downgrade admin from @5.1.24 to @5.1.23 now? [(y)es, (n)o]: y
                                          Update admin from @5.1.24 to @5.1.23
                                          npm install iobroker.admin@5.1.23 --loglevel error --prefix "/opt/iobroker" (System call)
                                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                          Adapter "admin" updated
                                          pi@HomeRaspi:~ $ sudo reboot
                                          Connection to 192.168.178.251 closed by remote host.
                                          Connection to 192.168.178.251 closed.
                                          bjornmause@Mac-mini-von-Bjorn ~ % ssh pi@192.168.178.251
                                          pi@192.168.178.251's password:
                                          Linux HomeRaspi 5.10.52-v7l+ #1441 SMP Tue Aug 3 18:11:56 BST 2021 armv7l
                                          permitted by applicable law.
                                          Last login: Sun Aug 15 13:52:38 2021 from 192.168.178.9
                                          pi@HomeRaspi:~ $
                                          Thomas BraunT M 2 Antworten Letzte Antwort
