  4. Iobroker startet nach Phoscon Installation nicht mehr
    6.6k
36 Beiträge 4 Kommentatoren 2.8k Aufrufe 2 Beobachtet
    mauseb
    @thomas-braun said in Iobroker startet nach Phoscon Installation nicht mehr:
    @mauseb Bitte Konsolentext in CodeTags packen, keine Screenshots.
    wie geht das genau?
    M Thomas BraunT 2 Antworten Letzte Antwort
    • M mauseb
      wie geht das genau?
      mauseb
      @mauseb said in Iobroker startet nach Phoscon Installation nicht mehr:
      wie geht das genau?
      pi@HomeRaspi:~ $ iobroker status
       Cannot read system.config: null (OK when migrating or restoring)
      iobroker is not running on this host.
      Objects type: file
      States  type: file
      pi@HomeRaspi:~ $ iobroker list instances
      + instance is alive
      + instance is alive
      • M mauseb
        wie geht das genau?
        @mauseb
        </> Icon anklicken, Text aus der Konsole zwischen die Steuerzeichen kopieren.
          mauseb
          Objects type: file
          States  type: file
          + instance is alive
          pi@HomeRaspi:~ $
          • M mauseb
            wie geht das genau?
            Objects type: file
            States  type: file
            + instance is alive
            + instance is alive
            @mauseb
            iobroker list adapters
            iobroker start
              @mauseb
              iobroker start
              mauseb
              pi@HomeRaspi:~ $ iobroker list adapters
              pi@HomeRaspi:~ $
              Bei iobroker start passiert garnichts
              • M mauseb
                pi@HomeRaspi:~ $
                @mauseb
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                  @mauseb
                  cd /opt/iobroker
                  mauseb
                  cd /opt/iobroker
                  pi@HomeRaspi:~ $ cd /opt/iobroker
                  pi@HomeRaspi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                  > iobroker.js-controller@3.3.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  NPM version: 6.14.14
                  > iobroker.js-controller@3.3.15 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  object 0_userdata.0.example_state created
                  object 0_userdata.0 created
                  object alias.0 created
                  object system.certificates created
                  object system.repositories created
                  object system.config created
                  object enum.functions created
                  object enum.rooms created
                  object system.group.user created
                  object system.group.administrator created
                  object _design/custom created
                  object _design/system created
                  object system.meta.uuid created: e8850a24-25af-401f-f06a-d74dfd951728
                  object system.user.admin created
                  Renamed repository "default to "stable"
                  Renamed repository "latest to "beta"
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  + iobroker.js-controller@3.3.15
                  updated 1 package in 36.68s
                  74 packages are looking for funding
                    run `npm fund` for details
                  • M mauseb
                    cd /opt/iobroker
                    @mauseb
                    Den iobroker hast du aber schon länger nicht mehr aktualisiert.
                    Läuft der jetzt?
                      @mauseb
                      Läuft der jetzt?
                      mauseb
                      @mauseb
                      Läuft der jetzt?
                      ne leider läuft er noch nicht.
                      hatte gestern eigentlich noch update gemacht, nodes js 12.22.5 auch upgedatet.
                      ging alles, bis auf den Neustart gestern Abend da sich ein Skript wegen WLed Lampen aufgegangen hatte.
                      Danach kam ich nicht mehr im iobroker rein
                      • M mauseb
                        @mauseb
                        Läuft der jetzt?
                        @mauseb
                        Und was kommt jetzt zurück?
                        iobroker restart
                        iobroker status
                        which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                          @mauseb
                          iobroker restart
                          iobroker status
                          mauseb
                          pi@HomeRaspi:~ $ iobroker restart
                          Objects type: file
                          States  type: file
                          pi@HomeRaspi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v12.22.5
                          v12.22.5
                          6.14.14
                          nodejs:
                            Installiert:           12.22.5-1nodesource1
                            Installationskandidat: 12.22.5-1nodesource1
                            Versionstabelle:
                           *** 12.22.5-1nodesource1 500
                                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                               10.24.0~dfsg-1~deb10u1 500
                          pi@HomeRaspi:~ $
                          • M mauseb
                            Objects type: file
                            States  type: file
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v12.22.5
                            v12.22.5
                            6.14.14
                            nodejs:
                              Versionstabelle:
                            pi@HomeRaspi:~ $
                            @mauseb
                            Läuft doch.
                              @mauseb
                              Läuft doch.
                              mauseb
                              @mauseb
                              Läuft doch.
                              anscheinend, aber über Safari mit der ip :8081 kommt leider nichts
                              • M mauseb
                                @mauseb
                                Läuft doch.
                                @mauseb Verschlüsselt per https?
                                Das funktioniert soweit ich weiß im Moment nicht.
                                  mauseb
                                  https ist es nicht.
                                  + instance is alive
                                  pi@HomeRaspi:~ $
                                  Das schmeißt er raus, aber warum kein zugriff mit dem Explorer?
                                  • M mauseb
                                    https ist es nicht.
                                    + instance is alive
                                    pi@HomeRaspi:~ $
                                    @mauseb Da läuft halt der Admin nicht.
                                    iobroker start admin
                                      mauseb
                                      pi@HomeRaspi:~ $ iobroker start admin
                                      Cannot find any instances of "admin"!
                                      pi@HomeRaspi:~ $
                                        mauseb
                                        Hallo Thomas, vielen Dank für dein Mühe. Ich weiß echt nicht was mit meinen System los ist.
                                        Jetzt sagt er keine Instanz von "Admin"
                                        pi@HomeRaspi:~ $
                                        • M mauseb
                                          pi@HomeRaspi:~ $
                                          @mauseb
                                          iobroker install admin
