  4. [SOLVED] Zigbee läuft nach Update nicht mehr (CC2538)
    6.4k
49 Beiträge 7 Kommentatoren 4.8k Aufrufe 7 Beobachtet
  • GlasfaserG Glasfaser
    @asatru
    Findes es gerade nicht... müsse das sein :
    setze mal im Container bei ioBroker:
    chmod 777 /dev/ttyACM*
    chown root:dialout /dev/ttyACM0
    Asatru
    @glasfaser zumindest die Fehlermeldung hat sich geändert ;)
    zigbee.0 2021-08-09 08:58:40.912	error	Error herdsman start
    zigbee.0 2021-08-09 08:58:40.912	error	Failed to start Zigbee
    zigbee.0 2021-08-09 08:58:40.911	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0 2021-08-09 08:58:40.637	info	Installed Version: iobroker.zigbee
    zigbee.0 2021-08-09 08:58:40.621	info	Starting Zigbee npm ...
    zigbee.0 2021-08-09 08:58:40.620	info	Try to reconnect. 1 attempts left
    zigbee.0 2021-08-09 08:58:30.618	error	Error herdsman start
    zigbee.0 2021-08-09 08:58:30.616	error	Failed to start Zigbee
    zigbee.0 2021-08-09 08:58:30.614	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0 2021-08-09 08:58:30.613	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0 2021-08-09 08:58:30.613	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0 2021-08-09 08:58:30.612	error	Please update configuration to prevent further issues.
    zigbee.0 2021-08-09 08:58:30.612	error	- Channel List: configured=11, adapter=11
    zigbee.0 2021-08-09 08:58:30.611	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0 2021-08-09 08:58:30.610	error	- Extended PAN ID: configured=aadddddddddddddd, adapter=00124b0006104d25
    zigbee.0 2021-08-09 08:58:30.610	error	- PAN ID: configured=6754, adapter=6755
    zigbee.0 2021-08-09 08:58:30.608	error	Configuration is not consistent with adapter state/backup!
    zigbee.0 2021-08-09 08:58:28.701	info	Installed Version: iobroker.zigbee
    zigbee.0 2021-08-09 08:58:27.859	info	Starting Zigbee npm ...
    zigbee.0 2021-08-09 08:58:27.518	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.2, js-controller: 3.3.15
    zigbee.0 2021-08-09 08:58:15.118	error	Cannot read property 'getEntries' of null
    zigbee.0 2021-08-09 08:58:15.118	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0 2021-08-09 08:58:15.117	error	unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0 2021-08-09 08:58:15.116	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0 2021-08-09 08:58:15.115	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0 2021-08-09 08:58:15.114	info	terminating
    zigbee.0 2021-08-09 08:58:15.113	warn	Failed to stop zigbee during startup
    zigbee.0 2021-08-09 08:58:15.112	info	Zigbee: disabling joining new devices.
    zigbee.0 2021-08-09 08:58:15.109	info	cleaned everything up...
    zigbee.0 2021-08-09 08:58:15.106	info	Got terminate signal TERMINATE_YOURSELF
    • A Asatru
      GlasfaserG Offline
      GlasfaserG Offline
      @asatru sagte in Zigbee läuft nach Update nicht mehr (CC2538):
      Hast du es nochmal mit ... kontrolliert wie die Rechte/Benutzer jetzt sind .
      ls -l /dev/ttyACM*
        ls -l /dev/ttyACM*
        Asatru
        schrieb am zuletzt editiert von Asatru
        @glasfaser Ja, sollte jetzt passen
        root@iobroker:/opt/iobroker# ls -la /dev/ttyACM*
        crwxrwxrwx 1 root dialout 166, 0 Aug  9 08:48 /dev/ttyACM0
        edit: Nach einem reboot des containers sind die Rechte wieder weg, sind also auch nicht persitent...
        • A Asatru
          GlasfaserG Offline
          GlasfaserG Offline
          @asatru
          Was mich Wundert , das es ohne die Eintragung /dev/ttyACM0 in der Umgebung im Docker bei dir lief !?
          Hast du vorher schon mit Rechten im Container gearbeitet/gesetzt ?
          Hast du hier den Haken :
            @asatru
            Asatru
            @glasfaser Ja, der Container läuft mit erhöhten Rechten. Ich verwende Portainer, da scheint es irgendwie ein Problem mit den ENV's zu geben. Ich schaue mal, ob es vielleicht doch daran liegt (Auch, wenn ich das vorher nie eingetragen hatte)
              @asatru
              bei root@DS219Plus ist alles richtig ,
              nur bei iobroker solle es so sein:
              crw-rw---- 1 root dialout 166, 0 Aug  8 18:19 /dev/ttyACM0
              Hast du den Stick richtig durchgereicht in der Umgebung .
              Du schreibst auch von Updates , hast du eventuell DSM 7 drauf ?
              Asatru
              @glasfaser hab die ENV variable jetzt über Docker in DSM gesetzt, so funktioniert es. Die Fehlermeldung bleibt leider die gleiche
              • A Asatru
                @asatru
                PAN-Id im Adapter angepasst?
                  @asatru
                  Asatru
                  @thomas-braun Habe ich jetzt zum testen auch mal auf die im Log genannte angepasst, leider ebenfalls der gleiche Fehler (nur mit angepasster PAN ID)
                  • A Asatru
                    @asatru
                    Die extended PAN-Id auch anpassen.
                      @asatru
                      Asatru
                      @thomas-braun Die habe ich jetzt auf nach diesem Beitrag auf 0xdddddddddddddddd gesetzt. Damit funktioniert es, vielen Dank Euch allen 😃
                      Hier nochmal zusammengefasst die Schritte zum lösen des Problems, falls jemand vor einem ähnlichen Problem steht
                      • Im Container mittels ls -la /dev/ttyACM überprüfen, ob die korrekten Rechte gesetzt sind
                        • Falls Nein:
                          • Entweder Rechte temporär anpassen (chmod 777 /dev/ttyACM* und chown root:dialout /dev/ttyACM0) Oder, wie in diesem Beitrag, persitent. Für Protainer-Nutzer, die ENV-variable USBDEVICES mit dem Wert /dev/ttyACM0 über die DSM-GUI setzen, da hier Portainer auf Synology ein Problem zu haben scheint. Damit werden die Rechte korrekt vergeben.
                      • In den Einstellungen der ZigBee-Instanz die erweiterte Pan ID, die Pan ID und den Kanal so anpassen, wie es im Log angezeigt wird. Mit 16xD werden alle erweiterten Pan IDs akzeptiert (siehe Beitrag oben)
                      ps: ttyACM0 ist natürlich jeweils als Platzhalter für Euer device zu sehen.
                      Die Geräte berauchen etwas Zeit, bis sie alle wieder da sind, aber es muss nichts neu angelernt werden, DANKE!
                      Viele Grüße
                      Jonas
                      • MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        nun, ich habe das selbe Problem auf einem Tinkerboard.
                        ich habe eingegeben:
                        ls -la /dev/ttyACM
                        Ausgabe:
                        No such file or directory
                        Da es sich wohl um einen Container einer Synology handelt, ist hier wohl eine andere Vorgehensweise nötig.
                        Ich bin für jede Hilfe dankbar.
                        Gruß,
                        Mathias
                        IObroker auf dem NUC als VM.
                        • MathiasJM MathiasJ
                          ls -la /dev/ttyACM
                          Ausgabe:
                          Gruß,
                          Mathias
                          @mathiasj
                          ls -la /dev/ttyACM
                          Die Geräte werden i.d.R. durchnummeriert.
                          ls -la /dev/ttyACM0
                          probieren. Und TabCompletion mal anschauen, das hilft bei sowas auch ungemein
                          MathiasJM 1 Antwort Letzte Antwort
                            @mathiasj
                            ls -la /dev/ttyACM
                            ls -la /dev/ttyACM0
                            MathiasJM Offline
                            MathiasJM Offline
                            MathiasJ
                            danke der Herr! 🍺
                            nur welchen User soll ich da eingeben?
                            Ist da IObroker gemeint?
                            sudo usermod -a -G dialout $USER
                            Gruß,
                            Mathias
                              danke der Herr! 🍺
                              Gruß,
                              Mathias
                              @mathiasj
                              User die das Gerät benutzen können sollen.
                                @mathiasj
                                MathiasJM Offline
                                MathiasJM Offline
                                MathiasJ
                                das ist in diesem Fall nur IObroker, weil es sich nicht um eine NAS, sondern um einen Tinkerboard handelt. Sorry, stehhe etwas auf dem Schlauch heute. 😊
                                  @mathiasj
                                  sudo usermod -a -G dialout iobroker
                                    @mathiasj
                                    MathiasJM Offline
                                    MathiasJM Offline
                                    MathiasJ
                                    habe alles soweit gemacht.
                                    Nur das Problem blieb......
                                    Gruß,
                                    Mathias
                                      Gruß,
                                      Mathias
                                      @mathiasj sagte in [SOLVED] Zigbee läuft nach Update nicht mehr (CC2538):
                                      Welches?
                                        Welches?
                                        MathiasJM Offline
                                        MathiasJM Offline
                                        MathiasJ
                                        schrieb am zuletzt editiert von MathiasJ
                                        daß IObroker den seriellen Port des Zigbee-Sticks nicht öffnen kann.
                                        zigbee.0
                                        2021-09-19 18:31:05.671	error	Error herdsman start
                                        zigbee.0
                                        2021-09-19 18:31:05.670	error	Failed to start Zigbee
                                        zigbee.0
                                        2021-09-19 18:31:05.668	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                        Thomas BraunT mickymM 2 Antworten Letzte Antwort
                                          zigbee.0
                                          zigbee.0
                                          zigbee.0
                                          @mathiasj
                                          Wo liegt denn das Gerät hier?
                                          ls -l /dev/serial/by-id
                                          Sollte so ähnlich aussehen:
                                          echad@chet:~ $ ls -l /dev/serial/by-id/
                                          insgesamt 0
                                          lrwxrwxrwx 1 root root 13 12. Sep 17:27 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                                          echad@chet:~ $
