  4. js-controller 3.3 jetzt im STABLE!
344 Beiträge 61 Kommentatoren 131.8k Aufrufe 46 Beobachtet
  • Bjoern77B Bjoern77
    Moin
    Ich habe dann auch das Update gemacht. Leider läuft es noch nicht wieder rund.
    Ich bekomme alle 30s diesen LOG:
    host.raspberrypi	2021-08-06 11:13:24.434	info	Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi	2021-08-06 11:13:24.434	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: }
    host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: ]
    host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
    host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
    host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: requireStack: [
    host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: {
    host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-08-06 11:13:24.430	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-08-06 11:13:24.430	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-08-06 11:13:24.430	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-08-06 11:13:24.430	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
    host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-08-06 11:13:24.428	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-08-06 11:13:24.428	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-08-06 11:13:24.428	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
    host.raspberrypi	2021-08-06 11:13:24.428	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-08-06 11:13:24.427	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-08-06 11:13:24.427	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.raspberrypi	2021-08-06 11:13:24.427	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
    host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
    host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: Require stack:
    host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: Error: Cannot find module 'typescript'
    host.raspberrypi	2021-08-06 11:13:24.425	error	Caught by controller[0]: ^
    host.raspberrypi	2021-08-06 11:13:24.425	error	Caught by controller[0]: throw err;
    host.raspberrypi	2021-08-06 11:13:24.424	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
    host.raspberrypi	2021-08-06 11:13:23.898	info	instance system.adapter.javascript.0 started with pid 23893
    Es ist ein Master-Slave System. Ich habe erst den Master upgedated. Diese Meldungen kommen vom Master.
    Was kann ich versuchen?
    Danke für eure Arbeit únd Gruß
    Björn
    @bjoern77 Instslliere mal javascript adapte rneu ... aus irgendeinem grund fehlt da ein paket?
    Bjoern77B 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Bjoern77B Offline
      Bjoern77B Offline
      Bjoern77
      @apollon77
      @apollon77
      Moin
      Habe ich auf verschiedenste Wege versucht.
      Der letzte Versuch war dieser:
      cd /opt/iobroker/node_modules/iobroker.javascript
      npm install --production
      Wie würdest du es versuchen?
      Gruß Björn
        @apollon77
        @apollon77
        Moin
        Gruß Björn
        @bjoern77 Hm ... komisch .... versuch mal npm install in /opt/iobroker/node_modules/virtual-tsc/
        A Bjoern77B 2 Antworten Letzte Antwort
          Ahnungsbefreit
          @apollon77 Bitte im 2.Post noch "LaMetric" ergänzen. Github Issue habe ich aufgemacht: https://github.com/klein0r/ioBroker.lametric/issues/45
            Bjoern77B Offline
            Bjoern77B Offline
            Bjoern77
            @apollon77
            Das hat geholfen. Vielen Dank. Läuft wieder auf grün und durch :-)
            Björn
              @apollon77
              Björn
              #66
              @bjoern77 Dennoch sehr komisch und ungewöhnlich
                @exitus sagte: woran kann es liegen.
                Zu alte Version (< 5.2.0) des Javascript-Adapters bzw. Version von iCal zu neu (>= 1.10.0).
                exitus
                schrieb am zuletzt editiert von exitus
                #67
                @paul53 java script ist auf 5.1.3 es ist nicht >5.2
                ical kalender ist auf 1.11.2
                • E exitus
                  #68
                  @exitus sagte: java script ist auf 5.1.3 es ist nicht >5.2
                  Dann ist iCal schon auf die Änderungen im js-controller (JSON statt Objekt) umgestellt, Javascript aber noch nicht. Passen also nicht zueinander, was zu dem Fehler führt.
                  OliverIOO E 2 Antworten Letzte Antwort
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    #69
                    Da Testsystem und nicht so oft benutzt habe ich nun nach Aktualisierung den folgenden Fehler:
                    Redis error:Error: Invalid Chunk: parse failed
                    obwohl dort redis für iobroker nicht konfiguriert ist.
                    Mehr Details hier:
                    https://forum.iobroker.net/topic/46803/redis-error-error-invalid-chunk-parse-failed?_=1628246890838
                    Meine Adapter und Widgets
                    Links im Profil
                    • OliverIOO OliverIO
                      Mehr Details hier:
                      #70
                      @oliverio Schaue dort, AUch die iobroker eigene DB nutzt seit controller 2.0 das Redis Protokoll unter der Haube
                        exitus
                        #71
                        @paul53 danke paul ich habe unter einstellung auf Beta gestellt und dann musste ich Admin Adapter Updaten damit ich Java script updaten konnte.
                        Habe Admin Adapter auf 5.1.23 und java auf 5.2.6 danach lief es .
                        • E exitus
                          #72
                          @exitus Admin5 und die ganzen Deps kommen heute Abend
                            Hallo ioBroker-Community,
                            nach einer recht langen Beta-Phase kommt heute der neue js-controller 3.3 (Releasename "Hannah") ins Stable Repository (sollte im Laufe des Abends bei allen auftauchen). Ein großer Dank geht an alle User die in der letzten Zeit diese Version bereits im Beta-Test getestet und Probleme und Fehler zur Behebung gemeldet haben und natürlich die Entwickler die Ihre Adapter wenn nötig angepasst haben!
                            Wichtig
                            Bei Fragen bitte zuerst im zweiten Post nachsehen ob das Thema ggf in einem anderen Forum Thread ausgelagert wurde um besser zu fokussieren.!
                            Node.js Versions-Anforderungen
                            Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand bereits mit Node.js 16.x arbeiten möchte, dann bitte im Moment AUSSCHLIESSLICH mit npm 6 !! (Bei npm 7 gibt es noch Probleme mit GitHub Installs bei einigen Adaptern)
                            Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition
                            Informationen zur Version
                            Die neue Version fokussiert sich neben Optimierungen, Bugfixes und einigen neuen Features vor allem weiter daran den Wildwuchs in der Umsetzung einiger Adapter etwas einzugrenzen. Im Zuge dieser neuen Checks wurden eine ganze Reihe Adapter aktualisiert - zu viele um hier alle zu nennen!
                            Bitte unterstützt hier weiter für ggf. noch übriggebliebene Adapter und legt bei den relevanten Adaptern im GitHub Issues an, damit diese Dinge gefixt werden können.
                            Weiterhin zu Erwähnen ist diesmal, dass Adapter-Abhängigkeiten bei Updates besser berücksichtigt werden und das die Startreihenfolge von Adaptern nach Typ optimiert wird und auch mitbestimmen kann (mit Admin5). Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog.
                            In Summe sind in diese Version über 120 commits eingeflossen. Dafür bedenke mich diesmal besonders bei foxriver76, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern für die aktive Mitarbeit an dieser Version!
                            Der js-controller 3.3 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Nur die Node.js Version muss weiterhin mindestens 10.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
                            Installation
                            VOR der Installation
                            Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Die alte Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version (ausgeführt im ioBroker-Verzeichnis, z.B. /opt/iobroker) installiert werden und sollte alles wieder herstellen.
                            Nötige Adapter-Aktualisierungen
                            Am besten VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 3.3 hinweisen.
                            Falls nach dem Update dennoch einzelne Adapter Info-Meldungen ins Log schreiben, bitte zuerst versuchen die gemeldeten Objekt-IDs via Admin zu löschen und den Adapter neu zu starten. Wenn die Meldungen danach nicht weg sein sollten ist aktuell die einzige Option das Loglevel der betroffenen Instanz auf "Warning" zu setzen - aber erst nachdem die Logs idealerweise in einem GitHub-Issue beim entsprechendem Adapter gemeldet wurden!
                            Eine Liste der aktuell bekannten Adapter die noch Fehler ausgeben ist im zweiten Post gesammelt!
                            Achtung: Multihost-Systeme Reihenfolgen beachten!
                            Bei einem Multi-Host-System, welches auf js-controller 2.2, 3.1 oder 3.2 läuft, ist es beim Update auf Version 3.3 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                            Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 3.3 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Beim Slave Update muss der alte Master aber noch laufen. Die Slaves bleiben nach dem Update offline und können sich nicht zum Master verbinden und werden erst wieder funktionieren wenn auch der Master auf die 3.3 aktualisiert wurde!
                            Linux
                            • iobroker update
                            • ioBroker stoppen (iobroker stop)
                            • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
                            • Wie üblich wird das Update dann per iobroker upgrade self ausgeführt.
                            • ioBroker starten (iobroker start)
                            Wichtig: Falls es mit js.controller 3.2.x bei update oder upgrade einen Fehler gibt "No connection to database" dann bitte nochmals versuchen, wenn wieder passiert folgende Schritte ausführen:
                            • Editiere /opt/iobroker/iobroker-data/iobroker.json
                            • Unter objects und states gibt es ein ' "connectTimeout": 2000,`
                            • Zahl ändern in 5000 draus.
                            • Neu versuchen
                            • Nach dem Upgrade am besten den Wert wieder zurücketzen weil der js-controller 3.3 hier optimiert und länger wartet
                            Windows
                            Aus der Community kommt von @sigi234 eine Anleitung für ein Windows Update Update_Windows_ioBroker.pdf
                            Für alle "alten manuellen" Installationen gilt
                            • iobroker update
                            • ioBroker muss gestoppt sein.
                            • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
                            • iobroker upgrade self
                            • ioBroker starten
                            Bei Fehlern:
                            Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
                            Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
                            NACH der Installation
                            Nach der Installation sollte der ioBroker automatisch wieder gestartet werden. Falls doch nicht bitte mittels iobroker start starten.
                            Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
                            Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                            Was hat sich geändert, was besonders ansehen/beachten?
                            Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
                            • generell siehe Changelog, speziell auch für Features
                            • Adapter-Instanzen starten nach den definierten Tiers
                            • iobroker upgrade beachtet nun Adpater-Abhängigkeiten
                            • backitup wird automatisch installiert bei neuen Installationen
                            • Einige Adapter werden Warnungen ausgeben wenn State-Werte gesetzt werden, da nun auch Datentypen und min/max-Werte geprüft werden. Bitte bei den Adapter-Repos melden
                            Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
                            Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
                            BREAKING CHANGES
                            • None, Supported are nodejs 10.x, 12.x and 14.x (Node.js 16.x is also working WHEN USED WITH npm 6!!, but officially not yet supported because we do not have enough results)
                            • The experimental jsonl db libraries are now included in js-controller directly too
                            • (Apollon77) Do not install info adapter by default
                            • (foxriver76) change default behaviour of cli update command -> only list installed, allow --all as parameter to see all again
                            Features
                            • (foxriver76) start instances ordered by their defined tiers (details see https://github.com/ioBroker/ioBroker.js-controller#tiers-start-instances-in-an-ordered-manner)
                            • (foxriver76) respect adapter dependencies on "upgrade" CLI command
                            • (Apollon77) Create a backitup instance on initial installation
                            • (Apollon77) Also allow "iobroker url iobroker.adaptername[@version]" as command
                            Optimizations and Fixes
                            • (foxriver76) correctly encrypt native attributes from instances when set via cli
                            • (Apollon77) give DB a bit more time to startup for CLI
                            • (foxriver76) fix logging undefined w/o meta data when deleting log files
                            • (Apollon77/oweitman) prevent errors when listening for multihost messages
                            • (Apollon77) make sure to await the database destroy in all places
                            • (Apollon77) fix crash case when Lets encrypt config is not provided but LE is activated
                            • (AlCalzone) understand .tar.gz as a valid extension for github URLs
                            • (foxriver76) only renew Let's encrypt when configured that way
                            • (foxriver76) if free memory reaches threshold, also add a notification
                            • (bluefox) fix applyViewFunc if the name is a localized object
                            • (Apollon77) optimize db initialization for fileDB and enhance error case handling
                            • (bluefox/Apollon77) make sure all object types are deleted on recursive object deletion
                            • (Apollon77/foxriver76) several optimizations and fixes in database modules and update
                            • (foxriver76) Make sure getStates uses write attribute of aliases instead of read
                            • (Apollon77) prevent crash in disconnect cases on startup
                            • (foxriver76) allow defaultNewAcl updates on the fly
                            • (Apollon77) initialize new default ACLs in any case, only controller sets it for all objects
                            • (foxriver76) do not send null as diag info in error cases or if user has selected none
                            • (foxriver76) revive config.dataDir if deleted via bug in admin5 config editor
                            • (foxriver76) fixed a bug which lead to an infinite loop if the repo was invalid and no cached sources available
                            • (foxriver76) check host existence before adding instance
                            • (Apollon77) Check that password is provided when multihost discovery server should be started in secure mode
                            • (foxriver76) only send diagnose data if license and diag dialog has been confirmed on new installations
                            • (foxriver76) make sure adapters are added only once to upgrade queue if it has no dependencies
                            • (Apollon77) Optimize Database save handling on write
                            • (Apollon77) Optimize restart logic
                            • (foxriver76) optimize cli help
                            • (AlCalzone) Optimize search for adapter start file to also respect main property from package.json
                            • (Apollon77/foxriver76) Optimize Database storage behaviour for file database
                            • (Apollon77/Stabilostick) Try fix restart on Windows
                            • (bluefox) Do not delete objects recursively that have dontDelete flag
                            • (AlCalzone) Fix restart logic for linux systems to prevent processes started aside systemd
                            • (Apollon77) "upgrade self" CLI command should not start controller because we require it to be stopped before (will be effective for all upgrades from 3.3.2 to higher versions only)
                            • (Apollon77) fix "iobroker upgrade" call that crashed when no updates were available
                            • (foxriver/Apollon77) fix invalid logging in package manager
                            • (foxriver76) avoid deleting too many meta objects starting with the same name as adapter
                            • (Apollon77, foxriver, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
                            Developer relevant DEPRECATIONS/WARNINGS
                            • (foxriver76) added new checks for setState:
                              • if strictObjectChecks are activated we now perform additional checks
                              • require common.type on state objects
                              • if state is read only and we get ack false -> not allowed
                              • check type of the state.val matching the common.type of the obj
                              • if it's a number and min/max is defined on object we perform additional checks for min and max
                            • (bluefox) checkPassword(Async) is now returning two parameters in callback/resolve (first is boolean if password/user are valid, second is the final internal username in form system.user.xxx)
                            • (bluefox) add _design/custom to the controller objects - this should deprecate the own custom view over time, please update if relevant!
                            Developer relevant new Features
                            • (AlCalzone) support executing TypeScript adapters: If the adapter main file ends with ".ts" we automatically transpile the typeScript file before starting the adapter
                            • (bluefox) Implement chownFile in adapter.js
                            • (foxriver76) introduce common.step attribute of states and round state value if needed
                            • (bluefox) Add restartController sendToHost command
                            • (bluefox) Allow npm install to be executed with debug flag
                            • (bluefox) Add messages to read logs
                            • (bluefox) Add location of ioBroker as information to getHostInfo
                            • (bluefox) Add new system config values to set a default loglevel for new created instances
                            Developer relevant Optimizations and Fixes
                            • general dependency updates
                            • code style optimizations
                            Nach dem Update am besten prüfen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
                            Wie Fehler melden?
                            Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
                            Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
                            IngoUpdate_Windows_ioBroker.pdf
                            #73
                            @apollon77
                            Vielen Dank für die stetige Aktualisierung und Weiterentwicklung!
                            Mir juckt es etwas in den Fingern, aber da doch auf einige Meldungen verwiesen wird, würde ich gerne vorab das Fallback-Szenario erfragen (Linux)?
                            Falls Die Fehlermeldungen/Probleme doch zu massiv werden, gibt es eine empfohlene und erprobte Methode außer ggf. eine komplette Neuinstallation mit dem Restore eines Backups?
                            Besten Dank!
                            apollon77A J 2 Antworten Letzte Antwort
                              @apollon77
                              Besten Dank!
                              #74
                              @pete0815 Steht zwar im ersten Post drin aber ich kopiere es gern nochmal hierher :-)
                                @apollon77
                                Besten Dank!
                                Jan1
                                #75
                                @pete0815
                                Ein Restor eines Backup empfiehlt sich auch so ab und an mal zu tätigen, weil es das System sauber hält. Somit ist das die schnellste, einfachste und beste Art. Hier sollte dann auch der IOBroker Ordner sauber gelöscht werden und außer ner IOBroker Neuinstallation samt dem Backitup Adapter nichts drauf sein ;)
                                Also alles andere als ne gefährliche Aktion bei der man ein Linux Nerd sein muss.
                                Edit:
                                Oder man machts wie apollon schon geschrieben hat, wie es im ersten Post dazu schon steht, was natürlich auch geht, aber das eventuell unsaubere System eben auch unsauber lässt.
                                W 1 Antwort Letzte Antwort
                                • F Offline
                                  Fabian1
                                  #76
                                  Dass der Admin5 und der Javascript Adapter nicht gleichzeitig mit dem js-controller ins stable gegangen sind war natürlich etwas unglücklich. :)
                                  Aber ich muss jetzt echt mal sagen, nachdem ich jetzt alle Fehler bei mir im System ausgebügelt habe läuft mein System mit dem js-controller 3.3 1000 mal stabiler als vorher! Wirklich super arbeit!
                                  • F Fabian1
                                    Ahnungsbefreit
                                    #77
                                    @fabian1 Admin5 ist noch nicht im Stable.
                                    F 1 Antwort Letzte Antwort
                                      #78
                                      @apollon77 said in js-controller 3.3 jetzt im STABLE!:
                                      Ups, vielmals sorry. Das habe ich dann mehrfach überlesen :(
                                      @Jan1
                                      Ja, das Restore ist auch weniger mein Problem. Eher die Neuinstallation wozu ich örtlichen Zugriff auf die SSD brauche(den ich erst heute Abend hab). Den Rest kann ich so übers Netzwerk erledigen/schon mal anstoßen.
                                      • A Ahnungsbefreit
                                        Fabian1
                                        #79
                                        @ahnungsbefreit ja das meine ich ja! Das ist etwas unglücklich, da der Admin5 voraussetzung für den Javascript Adapter ist, der 100%ig mit dem js-controller 3.3 funktioniert. Also alle die im Moment auf stable sind, kriegen unter umständen Probleme mit ihren skripten. Aber wie apollon geschrieben hat, ändert sich das ja heute abend.
                                          @Jan1
                                          Jan1
                                          #80
                                          @pete0815
                                          Hatte sich eben so angehört, das Du ein Restor des IOBroker als was "Großes" empfindest, deshalb auch mein Text dazu.
                                          Ich hatte im Beta auch schon das ein oder andere Mal den Weg über das Kommando gewählt, weil es wenn sonst wirklich alles sauber ist, eben doch wesentlich schneller geht und ausreichend ist um die alte Version wieder herzustellen.
