  4. Easee Wallbox mit iobroker
easeewallboxadapter
541 Beiträge 64 Kommentatoren 240.4k Aufrufe 57 Beobachtet
  • W
    W
    warp735
    #229
    Ist wieder abgeschmiert (rot)
    Glaub ich mach das jetzt mal über die App und warte auf n Adapter Update. Zig mal am Tag das Ding reseten bringt ja auch nix.
    host.50a2896d0707	2021-07-28 14:36:01.618	warn	Do not restart adapter system.adapter.easee.0 because restart loop detected
    host.50a2896d0707	2021-07-28 14:36:01.618	info	Restart adapter system.adapter.easee.0 because enabled
    host.50a2896d0707	2021-07-28 14:36:01.617	error	instance system.adapter.easee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    easee.0	2021-07-28 14:36:01.015	warn	(22507) Terminated (UNCAUGHT_EXCEPTION): Without reason
    easee.0	2021-07-28 14:36:00.994	error	(22507) Request failed with status code 504
    easee.0	2021-07-28 14:36:00.994	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
    easee.0	2021-07-28 14:36:00.994	error	at endReadableNT (_stream_readable.js:1241:12)
    easee.0	2021-07-28 14:36:00.994	error	at IncomingMessage.emit (events.js:326:22)
    easee.0	2021-07-28 14:36:00.994	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
    easee.0	2021-07-28 14:36:00.994	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
    easee.0	2021-07-28 14:36:00.994	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
    easee.0	2021-07-28 14:36:00.994	error	(22507) Error: Request failed with status code 504
    easee.0	2021-07-28 14:36:00.992	error	(22507) unhandled promise rejection: Request failed with status code 504
    easee.0	2021-07-28 14:36:00.989	error	(22507) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.50a2896d0707	2021-07-28 14:35:49.145	info	instance system.adapter.easee.0 started with pid 22507
    host.50a2896d0707	2021-07-28 14:35:19.101	info	Restart adapter system.adapter.easee.0 because enabled
    host.50a2896d0707	2021-07-28 14:35:19.101	error	instance system.adapter.easee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    easee.0	2021-07-28 14:35:18.510	warn	(21865) Terminated (UNCAUGHT_EXCEPTION): Without reason
    easee.0	2021-07-28 14:35:18.496	error	(21865) Request failed with status code 503
    easee.0	2021-07-28 14:35:18.496	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
    easee.0	2021-07-28 14:35:18.496	error	at endReadableNT (_stream_readable.js:1241:12)
    easee.0	2021-07-28 14:35:18.496	error	at IncomingMessage.emit (events.js:326:22)
    easee.0	2021-07-28 14:35:18.496	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
    easee.0	2021-07-28 14:35:18.496	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
    easee.0	2021-07-28 14:35:18.496	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
    easee.0	2021-07-28 14:35:18.496	error	(21865) Error: Request failed with status code 503
    easee.0	2021-07-28 14:35:18.494	error	(21865) unhandled promise rejection: Request failed with status code 503
    easee.0	2021-07-28 14:35:18.492	error	(21865) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.50a2896d0707	2021-07-28 14:35:16.839	info	instance system.adapter.easee.0 started with pid 21865
    host.50a2896d0707	2021-07-28 14:34:46.789	info	Restart adapter system.adapter.easee.0 because enabled
    host.50a2896d0707	2021-07-28 14:34:46.784	error	instance system.adapter.easee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    easee.0	2021-07-28 14:34:46.173	warn	(8911) Terminated (UNCAUGHT_EXCEPTION): Without reason
    easee.0	2021-07-28 14:34:46.157	error	(8911) Cannot read property 'cableLocked' of undefined
    easee.0	2021-07-28 14:34:46.157	error	at async /opt/iobroker/node_modules/iobroker.easee/main.js:207:17
    easee.0	2021-07-28 14:34:46.157	error	at Easee.setNewStatusToCharger (/opt/iobroker/node_modules/iobroker.easee/main.js:316:85)
    easee.0	2021-07-28 14:34:46.157	error	(8911) TypeError: Cannot read property 'cableLocked' of undefined
    easee.0	2021-07-28 14:34:46.156	error	(8911) unhandled promise rejection: Cannot read property 'cableLocked' of undefined
    easee.0	2021-07-28 14:34:46.155	error	(8911) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    easee.0	2021-07-28 14:34:46.150	error	(8911) Error: Request failed with status code 503
    easee.0	2021-07-28 14:34:45.890	error	(8911) Error: Request failed with status code 502
    easee.0	2021-07-28 14:33:43.426	warn	(8911) No Chargers found!
    easee.0	2021-07-28 14:33:43.426	error	(8911) Error: Request failed with status code 504
    easee.0	2021-07-28 14:33:03.145	warn	(8911) No Chargers found!
    easee.0	2021-07-28 14:33:03.140	error	(8911) Error: Request failed with status code 504
    • NewanN
      NewanN
      Newan
      #230
      Bitte testet einmal Version 1.0.3 ob der Adapter immer noch abstürzt!
      • NewanN Newan
        S
        S
        stonemaan
        #231
        @newan ist installiert.. wird gecheckt
        • W
          W
          warp735
          #232
          habs auch drauf
          NewanN 1 Antwort Letzte Antwort
          • W warp735
            habs auch drauf
            NewanN
            NewanN
            Newan
            #233
            @warp735 Naja gestern hat er nicht 7 Stunden gehalten ;-)
            • NewanN Newan
              S
              S
              stonemaan
              #234
              @newan heute noch keine Ausfälle zu verzeichnen. Ich beobachte weiter :)
              • W
                W
                warp735
                #235
                Hatte heute zweimal folgendes im Log. Adapter läuft aber noch 👍
                easee.0	2021-07-30 05:33:17.336	warn	(31842) No Chargers found!
                easee.0	2021-07-30 05:33:17.336	error	(31842) Error: Request failed with status code 504
                • NewanN
                  NewanN
                  Newan
                  #236
                  Gut wenn nichts mehr kommt würde ich die Version als stable einchecken?
                  Scotty89S 1 Antwort Letzte Antwort
                  • NewanN Newan
                    Scotty89S
                    Scotty89S
                    Scotty89
                    #237
                    Hey,
                    ich habe mir jetzt auch die version 1.0.3 drauf gemacht und logge es die tage mal mit ...
                    bisher sieht es aber ganz gut aus..
                    eine Frage an alle .. in welchen Intervall lasst ihr ihn laufen ? was habt ihr da eingestellt wenn ihr PV laden damit macht ?
                    • Scotty89S Scotty89
                      Hey,
                      NewanN
                      NewanN
                      Newan
                      #238
                      @scotty89 Nutz doch SignalR das ist dann in echtzeit
                      • NewanN Newan
                        Scotty89S
                        Scotty89S
                        Scotty89
                        #239
                        @newan sagte in Easee Wallbox mit iobroker:
                        das habe ich aktiv leider nicht wirklich rausbekommen was es macht ;)
                        was genau steht da hinter ? und in wie weit steht das damit dem Intervall im zusammenhang ?
                        ich schreibe ja den Parameter ....config.dynamicChargerCurrent bekomme ich ihn dann auch bestätigt oder erst nach einem erneuten lesen welches dann über das Interfall kommt ?
                          NewanN
                          NewanN
                          Newan
                          #240
                          @scotty89 Also Grundsätzlich ist das Intervall ja das die Daten in einem Bestimmten Zyklus abgeholt werden.
                          Den kannst du relativ hoch setzen und da über SignalR nicht alle Daten kommen wie Energieverbräuche etc. z.b 5 mal am Tag.
                          Dann wählst du SignalR aus und der Adapter registriert sich an der Cloud, die schickt dann bei einer Änderung das Event direkt zum Adapter, also quasi live.
                          Wie gut das ganze funktioniert weiß ich nicht, da das noch nie einer getestet hat 😧
                          • NewanN Newan
                            Scotty89S
                            Scotty89S
                            Scotty89
                            #241
                            @newan
                            ok dann teste ich das doch einfach mal etwas...
                            das Intervall werde ich mal 30 Sekunden hoch setzen und schauen wie sich meine Regelung verhält die Tage wenn das Wetter besser ist ;)
                            Danke.
                            andere frage gleich noch .. läuft der Adapter eigentlich auf Offline ? oder rein über die Cloud von denen ?
                              @newan
                              Danke.
                              NewanN
                              NewanN
                              Newan
                              #242
                              @scotty89 Nur cloud
                              • NewanN Newan
                                @scotty89 Nur cloud
                                S
                                S
                                stonemaan
                                #243
                                @newan ich habe heute morgen signalR angeschaltet. leider ist der adapter nach einiger Zeit wieder auf gelb gesprungen. Ich habe heute allerdings auch den JS controller geupdated und NodeJS auch..
                                2021-08-06 11:34:42.697 - error: easee.0 (1381) Error: Request failed with status code 503
                                2021-08-06 11:34:42.698 - error: easee.0 (1381) Error: Easee API error on charger state - stop refresh
                                2021-08-06 11:34:42.704 - error: easee.0 (1381) Error: Request failed with status code 503
                                2021-08-06 11:34:42.705 - error: easee.0 (1381) Error: Easee API error on charger state - stop refresh
                                2021-08-06 11:34:53.251 - error: easee.0 (1381) SignalR Verbindung beendet!!!- restart
                                2021-08-06 11:34:53.379 - error: easee.0 (1381) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2021-08-06 11:34:53.380 - error: easee.0 (1381) unhandled promise rejection: Service Temporarily Unavailable
                                2021-08-06 11:34:53.381 - error: easee.0 (1381) Error: Service Temporarily Unavailable
                                at new HttpError (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/Errors.js:27:24)
                                at FetchHttpClient. (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:154:35)
                                at step (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:52:23)
                                at Object.next (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:33:53)
                                at fulfilled (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:24:58)
                                at runMicrotasks ()
                                at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                2021-08-06 11:34:53.381 - error: easee.0 (1381) Service Temporarily Unavailable
                                2021-08-06 11:34:53.384 - info: easee.0 (1381) Adaptor easee cleaned up everything...
                                2021-08-06 11:34:53.384 - info: easee.0 (1381) terminating
                                2021-08-06 11:34:53.385 - warn: easee.0 (1381) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                2021-08-06 11:35:02.486 - info: easee.0 (7331) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.easee, node: v12.22.4, js-controller: 3.3.15
                                2021-08-06 11:35:02.742 - error: easee.0 (7331) Api login error - check Username and password
                                Ich beobachte mal weiter
                                • S stonemaan
                                  at runMicrotasks ()
                                  NewanN
                                  NewanN
                                  Newan
                                  #244
                                  @stonemaan ok ist aber 1.0.3?
                                  Schau mir das nochmal an
                                  S 2 Antworten Letzte Antwort
                                  • NewanN Newan
                                    S
                                    S
                                    stonemaan
                                    #245
                                    @newan jo... 1.0.3
                                    • S stonemaan
                                      @newan jo... 1.0.3
                                      A
                                      A
                                      Aiouh
                                      #246
                                      @Newan
                                      Ich bekomme seit Heute mit der 1.0.3 folg. Fehler
                                      easee.0	2021-08-06 23:14:23.569	error	(8630) Api login error - check Username and password
                                      Es wurde aber an user & passwort nichts geändert :(
                                      • A Aiouh
                                        @Newan
                                        NewanN
                                        NewanN
                                        Newan
                                        #247
                                        @aiouh mal aus der App abmelden und versuchen da wieder anzumelden. Die erros kommen ja direkt von der api
                                        • NewanN Newan
                                          A
                                          A
                                          Aiouh
                                          #248
                                          @newan said in Easee Wallbox mit iobroker:
                                          abmelden aus der App hat leider nichts gebracht, nach Neustart des ioBroker ist aber wieder alles im Lot.
                                          Ist 1.0.3 eigentlich die aktuelle?
                                          33.2k
                                          84.3k
