  4. Iobroker Sicherung nicht möglich
    6.7k
35 Beiträge 5 Kommentatoren 3.7k Aufrufe 4 Beobachtet
  • T TinoNikol
    @thomas-braun said in Iobroker Sicherung nicht möglich:
    dmesg -T
    pi@raspberrypi:~ $ dmesg -T
    [Fr Jul 23 18:07:32 2021] Booting Linux on physical CPU 0x0
    [Fr Jul 23 18:07:32 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-g        nueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ub        untu) 2.34) #1421 SMP Thu May 27 14:00:13 BST 2021
    [Fr Jul 23 18:07:32 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr        =30c5383d
    [Fr Jul 23 18:07:32 2021] CPU: div instructions available: patching division cod        e
    [Fr Jul 23 18:07:32 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruct        ion cache
    [Fr Jul 23 18:07:32 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
    [Fr Jul 23 18:07:32 2021] Memory policy: Data cache writealloc
    [Fr Jul 23 18:07:32 2021] Reserved memory: created CMA memory pool at 0x00000000        1ec00000, size 256 MiB
    [Fr Jul 23 18:07:32 2021] OF: reserved mem: initialized node linux,cma, compatib        le id shared-dma-pool
    [Fr Jul 23 18:07:32 2021] Zone ranges:
    [Fr Jul 23 18:07:32 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [Fr Jul 23 18:07:32 2021]   Normal   empty
    [Fr Jul 23 18:07:32 2021]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
    [Fr Jul 23 18:07:32 2021] Movable zone start for each node
    [Fr Jul 23 18:07:32 2021] Early memory node ranges
    [Fr Jul 23 18:07:32 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff        ]
    [Fr Jul 23 18:07:32 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff        ]
    [Fr Jul 23 18:07:32 2021] Initmem setup node 0 [mem 0x0000000000000000-0x0000000        0fbffffff]
    [Fr Jul 23 18:07:32 2021] On node 0 totalpages: 1012736
    [Fr Jul 23 18:07:32 2021]   DMA zone: 2304 pages used for memmap
    [Fr Jul 23 18:07:32 2021]   DMA zone: 0 pages reserved
    [Fr Jul 23 18:07:32 2021]   DMA zone: 196608 pages, LIFO batch:63
    [Fr Jul 23 18:07:32 2021]   HighMem zone: 816128 pages, LIFO batch:63
    [Fr Jul 23 18:07:32 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u819        20
    [Fr Jul 23 18:07:32 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
    [Fr Jul 23 18:07:32 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [Fr Jul 23 18:07:32 2021] Built 1 zonelists, mobility grouping on.  Total pages:        1010432
    [Fr Jul 23 18:07:32 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:        A6:32:95:80:D2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tt        yS0,115200 console=tty1 root=PARTUUID=4977864a-02 rootfstype=ext4 elevator=deadl        ine fsck.repair=yes rootwait
    [Fr Jul 23 18:07:32 2021] Kernel parameter elevator= does not have any effect an        ymore.
                              Please use sysfs to set IO scheduler for individual de        vices.
    [Fr Jul 23 18:07:32 2021] Dentry cache hash table entries: 131072 (order: 7, 524        288 bytes, linear)
    [Fr Jul 23 18:07:32 2021] Inode-cache hash table entries: 65536 (order: 6, 26214        4 bytes, linear)
    [Fr Jul 23 18:07:32 2021] mem auto-init: stack:off, heap alloc:off, heap free:of        f
    [Fr Jul 23 18:07:32 2021] software IO TLB: mapped [mem 0x0000000017cc0000-0x0000        00001bcc0000] (64MB)
    [Fr Jul 23 18:07:32 2021] Memory: 3654940K/4050944K available (10240K kernel cod        e, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K c        ma-reserved, 3264512K highmem)
    [Fr Jul 23 18:07:32 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nod        es=1
    [Fr Jul 23 18:07:32 2021] ftrace: allocating 33942 entries in 67 pages
    [Fr Jul 23 18:07:32 2021] ftrace: allocated 67 pages with 3 groups
    [Fr Jul 23 18:07:32 2021] rcu: Hierarchical RCU implementation.
    [Fr Jul 23 18:07:32 2021]       Rude variant of Tasks RCU enabled.
    [Fr Jul 23 18:07:32 2021]       Tracing variant of Tasks RCU enabled.
    [Fr Jul 23 18:07:32 2021] rcu: RCU calculated value of scheduler-enlistment dela        y is 10 jiffies.
    [Fr Jul 23 18:07:32 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [Fr Jul 23 18:07:32 2021] GIC: Using split EOI/Deactivate mode
    [Fr Jul 23 18:07:32 2021] random: get_random_bytes called from start_kernel+0x3c        8/0x59c with crng_init=0
    [Fr Jul 23 18:07:32 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wr        aps every 2147483647500ns
    [Fr Jul 23 18:07:32 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xfff        fffff, max_idle_ns: 1911260446275 ns
    [Fr Jul 23 18:07:32 2021] bcm2835: system timer (irq = 25)
    [Fr Jul 23 18:07:32 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [Fr Jul 23 18:07:32 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff        max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [Fr Jul 23 18:07:32 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps        every 4398046511102ns
    [Fr Jul 23 18:07:32 2021] Switching to timer-based delay loop, resolution 18ns
    [Fr Jul 23 18:07:32 2021] Console: colour dummy device 80x30
    [Fr Jul 23 18:07:32 2021] printk: console [tty1] enabled
    [Fr Jul 23 18:07:32 2021] Calibrating delay loop (skipped), value calculated usi        ng timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [Fr Jul 23 18:07:32 2021] pid_max: default: 32768 minimum: 301
    [Fr Jul 23 18:07:32 2021] LSM: Security Framework initializing
    [Fr Jul 23 18:07:32 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 b        ytes, linear)
    [Fr Jul 23 18:07:32 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8        192 bytes, linear)
    [Fr Jul 23 18:07:32 2021] Disabling memory control group subsystem
    [Fr Jul 23 18:07:32 2021] CPU: Testing write buffer coherency: ok
    [Fr Jul 23 18:07:32 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [Fr Jul 23 18:07:32 2021] Setting up static identity map for 0x200000 - 0x20003c
    [Fr Jul 23 18:07:32 2021] rcu: Hierarchical SRCU implementation.
    [Fr Jul 23 18:07:32 2021] smp: Bringing up secondary CPUs ...
    [Fr Jul 23 18:07:32 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [Fr Jul 23 18:07:32 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [Fr Jul 23 18:07:32 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [Fr Jul 23 18:07:32 2021] smp: Brought up 1 node, 4 CPUs
    [Fr Jul 23 18:07:32 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS)        .
    [Fr Jul 23 18:07:32 2021] CPU: All CPU(s) started in HYP mode.
    [Fr Jul 23 18:07:32 2021] CPU: Virtualization extensions available.
    [Fr Jul 23 18:07:32 2021] devtmpfs: initialized
    [Fr Jul 23 18:07:32 2021] VFP support v0.3: implementor 41 architecture 3 part 4        0 variant 8 rev 0
    [Fr Jul 23 18:07:32 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xf        fffffff, max_idle_ns: 19112604462750000 ns
    [Fr Jul 23 18:07:32 2021] futex hash table entries: 1024 (order: 4, 65536 bytes,        linear)
    [Fr Jul 23 18:07:32 2021] pinctrl core: initialized pinctrl subsystem
    [Fr Jul 23 18:07:32 2021] NET: Registered protocol family 16
    [Fr Jul 23 18:07:32 2021] DMA: preallocated 1024 KiB pool for atomic coherent al        locations
    [Fr Jul 23 18:07:32 2021] audit: initializing netlink subsys (disabled)
    [Fr Jul 23 18:07:32 2021] audit: type=2000 audit(0.030:1): state=initialized aud        it_enabled=0 res=1
    [Fr Jul 23 18:07:32 2021] thermal_sys: Registered thermal governor 'step_wise'
    [Fr Jul 23 18:07:32 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4        watchpoint registers.
    [Fr Jul 23 18:07:32 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [Fr Jul 23 18:07:32 2021] Serial: AMBA PL011 UART driver
    [Fr Jul 23 18:07:32 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [Fr Jul 23 18:07:32 2021] raspberrypi-firmware soc:firmware: Attached to firmwar        e from 2021-05-27T14:02:15, variant start
    [Fr Jul 23 18:07:32 2021] raspberrypi-firmware soc:firmware: Firmware hash is 7d        9a298cda813f747b51fe17e1e417e7bf5ca94d
    [Fr Jul 23 18:07:32 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmac        hans=0x1
    [Fr Jul 23 18:07:32 2021] vgaarb: loaded
    [Fr Jul 23 18:07:32 2021] SCSI subsystem initialized
    [Fr Jul 23 18:07:32 2021] usbcore: registered new interface driver usbfs
    [Fr Jul 23 18:07:32 2021] usbcore: registered new interface driver hub
    [Fr Jul 23 18:07:32 2021] usbcore: registered new device driver usb
    [Fr Jul 23 18:07:32 2021] usb_phy_generic phy: supply vcc not found, using dummy        regulator
    [Fr Jul 23 18:07:32 2021] clocksource: Switched to clocksource arch_sys_counter
    [Fr Jul 23 18:07:33 2021] VFS: Disk quotas dquot_6.6.0
    [Fr Jul 23 18:07:33 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 40        96 bytes)
    [Fr Jul 23 18:07:33 2021] FS-Cache: Loaded
    [Fr Jul 23 18:07:33 2021] CacheFiles: Loaded
    [Fr Jul 23 18:07:33 2021] NET: Registered protocol family 2
    [Fr Jul 23 18:07:33 2021] tcp_listen_portaddr_hash hash table entries: 512 (orde        r: 0, 6144 bytes, linear)
    [Fr Jul 23 18:07:33 2021] TCP established hash table entries: 8192 (order: 3, 32        768 bytes, linear)
    [Fr Jul 23 18:07:33 2021] TCP bind hash table entries: 8192 (order: 4, 65536 byt        es, linear)
    [Fr Jul 23 18:07:33 2021] TCP: Hash tables configured (established 8192 bind 819        2)
    [Fr Jul 23 18:07:33 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, li        near)
    [Fr Jul 23 18:07:33 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 byte        s, linear)
    [Fr Jul 23 18:07:33 2021] NET: Registered protocol family 1
    [Fr Jul 23 18:07:33 2021] RPC: Registered named UNIX socket transport module.
    [Fr Jul 23 18:07:33 2021] RPC: Registered udp transport module.
    [Fr Jul 23 18:07:33 2021] RPC: Registered tcp transport module.
    [Fr Jul 23 18:07:33 2021] RPC: Registered tcp NFSv4.1 backchannel transport modu        le.
    [Fr Jul 23 18:07:33 2021] PCI: CLS 0 bytes, default 64
    [Fr Jul 23 18:07:33 2021] Initialise system trusted keyrings
    [Fr Jul 23 18:07:33 2021] workingset: timestamp_bits=14 max_order=20 bucket_orde        r=6
    [Fr Jul 23 18:07:33 2021] zbud: loaded
    [Fr Jul 23 18:07:33 2021] FS-Cache: Netfs 'nfs' registered for caching
    [Fr Jul 23 18:07:33 2021] NFS: Registering the id_resolver key type
    [Fr Jul 23 18:07:33 2021] Key type id_resolver registered
    [Fr Jul 23 18:07:33 2021] Key type id_legacy registered
    [Fr Jul 23 18:07:33 2021] nfs4filelayout_init: NFSv4 File Layout Driver Register        ing...
    [Fr Jul 23 18:07:33 2021] Key type asymmetric registered
    [Fr Jul 23 18:07:33 2021] Asymmetric key parser 'x509' registered
    [Fr Jul 23 18:07:33 2021] bounce: pool size: 64 pages
    [Fr Jul 23 18:07:33 2021] Block layer SCSI generic (bsg) driver version 0.4 load        ed (major 249)
    [Fr Jul 23 18:07:33 2021] io scheduler mq-deadline registered
    [Fr Jul 23 18:07:33 2021] io scheduler kyber registered
    [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d50000        0 ranges:
    [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb        /pcie@7d500000, using [bus 00-ff]
    [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063f        ffffff -> 0x00c0000000
    [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bf        ffffff -> 0x0400000000
    [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SS        C)
    [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:0        0
    [Fr Jul 23 18:07:33 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
    [Fr Jul 23 18:07:33 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x        63fffffff] (bus address [0xc0000000-0xffffffff])
    [Fr Jul 23 18:07:33 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [Fr Jul 23 18:07:33 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
    [Fr Jul 23 18:07:33 2021] PCI: bus0: Fast back to back transfers disabled
    [Fr Jul 23 18:07:33 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [Fr Jul 23 18:07:33 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff        64bit]
    [Fr Jul 23 18:07:33 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
    [Fr Jul 23 18:07:33 2021] PCI: bus1: Fast back to back transfers disabled
    [Fr Jul 23 18:07:33 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6        000fffff]
    [Fr Jul 23 18:07:33 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x6        00000fff 64bit]
    [Fr Jul 23 18:07:33 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
    [Fr Jul 23 18:07:33 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6        000fffff]
    [Fr Jul 23 18:07:33 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [Fr Jul 23 18:07:33 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
    [Fr Jul 23 18:07:33 2021] iproc-rng200 fe104000.rng: hwrng registered
    [Fr Jul 23 18:07:33 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_s        ize:0x40000000(1024 MiB)
    [Fr Jul 23 18:07:33 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registe        rs at 0xfe200000
    [Fr Jul 23 18:07:33 2021] brd: module loaded
    [Fr Jul 23 18:07:33 2021] loop: module loaded
    [Fr Jul 23 18:07:33 2021] Loading iSCSI transport class v2.0-870.
    [Fr Jul 23 18:07:33 2021] libphy: Fixed MDIO Bus: probed
    [Fr Jul 23 18:07:33 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [Fr Jul 23 18:07:33 2021] libphy: bcmgenet MII bus: probed
    [Fr Jul 23 18:07:33 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [Fr Jul 23 18:07:33 2021] usbcore: registered new interface driver r8152
    [Fr Jul 23 18:07:33 2021] usbcore: registered new interface driver lan78xx
    [Fr Jul 23 18:07:33 2021] usbcore: registered new interface driver smsc95xx
    [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
    [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne        d bus number 1
    [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci versi        on 0x100 quirks 0x0000030000000890
    [Fr Jul 23 18:07:33 2021] usb usb1: New USB device found, idVendor=1d6b, idProdu        ct=0002, bcdDevice= 5.10
    [Fr Jul 23 18:07:33 2021] usb usb1: New USB device strings: Mfr=3, Product=2, Se        rialNumber=1
    [Fr Jul 23 18:07:33 2021] usb usb1: Product: xHCI Host Controller
    [Fr Jul 23 18:07:33 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
    [Fr Jul 23 18:07:33 2021] usb usb1: SerialNumber: 0000:01:00.0
    [Fr Jul 23 18:07:33 2021] hub 1-0:1.0: USB hub found
    [Fr Jul 23 18:07:33 2021] hub 1-0:1.0: 1 port detected
    [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne        d bus number 2
    [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpee        d
    [Fr Jul 23 18:07:33 2021] usb usb2: New USB device found, idVendor=1d6b, idProdu        ct=0003, bcdDevice= 5.10
    [Fr Jul 23 18:07:33 2021] usb usb2: New USB device strings: Mfr=3, Product=2, Se        rialNumber=1
    [Fr Jul 23 18:07:33 2021] usb usb2: Product: xHCI Host Controller
    [Fr Jul 23 18:07:33 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
    [Fr Jul 23 18:07:33 2021] usb usb2: SerialNumber: 0000:01:00.0
    [Fr Jul 23 18:07:33 2021] hub 2-0:1.0: USB hub found
    [Fr Jul 23 18:07:33 2021] hub 2-0:1.0: 4 ports detected
    [Fr Jul 23 18:07:33 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [Fr Jul 23 18:07:33 2021] dwc_otg: FIQ enabled
    [Fr Jul 23 18:07:33 2021] dwc_otg: NAK holdoff enabled
    [Fr Jul 23 18:07:33 2021] dwc_otg: FIQ split-transaction FSM enabled
    [Fr Jul 23 18:07:33 2021] Module dwc_common_port init
    [Fr Jul 23 18:07:33 2021] usbcore: registered new interface driver uas
    [Fr Jul 23 18:07:33 2021] usbcore: registered new interface driver usb-storage
    [Fr Jul 23 18:07:33 2021] mousedev: PS/2 mouse device common for all mice
    [Fr Jul 23 18:07:33 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog tim        er
    [Fr Jul 23 18:07:33 2021] sdhci: Secure Digital Host Controller Interface driver
    [Fr Jul 23 18:07:33 2021] sdhci: Copyright(c) Pierre Ossman
    [Fr Jul 23 18:07:33 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferri        ng probe
    [Fr Jul 23 18:07:33 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [Fr Jul 23 18:07:33 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [Fr Jul 23 18:07:33 2021] hid: raw HID events driver (C) Jiri Kosina
    [Fr Jul 23 18:07:33 2021] usbcore: registered new interface driver usbhid
    [Fr Jul 23 18:07:33 2021] usbhid: USB HID core driver
    [Fr Jul 23 18:07:33 2021] Initializing XFRM netlink socket
    [Fr Jul 23 18:07:33 2021] NET: Registered protocol family 17
    [Fr Jul 23 18:07:33 2021] Key type dns_resolver registered
    [Fr Jul 23 18:07:33 2021] Registering SWP/SWPB emulation handler
    [Fr Jul 23 18:07:33 2021] registered taskstats version 1
    [Fr Jul 23 18:07:33 2021] Loading compiled-in X.509 certificates
    [Fr Jul 23 18:07:33 2021] Key type ._fscrypt registered
    [Fr Jul 23 18:07:33 2021] Key type .fscrypt registered
    [Fr Jul 23 18:07:33 2021] Key type fscrypt-provisioning registered
    [Fr Jul 23 18:07:33 2021] uart-pl011 fe201000.serial: there is not valid maps fo        r state default
    [Fr Jul 23 18:07:33 2021] uart-pl011 fe201000.serial: cts_event_workaround enabl        ed
    [Fr Jul 23 18:07:33 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36,        base_baud = 0) is a PL011 rev2
    [Fr Jul 23 18:07:33 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power do        mains driver
    [Fr Jul 23 18:07:33 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [Fr Jul 23 18:07:33 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [Fr Jul 23 18:07:33 2021] of_cfs_init
    [Fr Jul 23 18:07:33 2021] of_cfs_init: OK
    [Fr Jul 23 18:07:33 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [Fr Jul 23 18:07:33 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [Fr Jul 23 18:07:33 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [Fr Jul 23 18:07:33 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emm        c2] using ADMA
    [Fr Jul 23 18:07:33 2021] Waiting for root device PARTUUID=4977864a-02...
    [Fr Jul 23 18:07:33 2021] random: fast init done
    [Fr Jul 23 18:07:33 2021] mmc1: new high speed SDIO card at address 0001
    [Fr Jul 23 18:07:33 2021] mmc0: new ultra high speed DDR50 SDXC card at address        e624
    [Fr Jul 23 18:07:33 2021] mmcblk0: mmc0:e624 SN64G 59.5 GiB
    [Fr Jul 23 18:07:33 2021]  mmcblk0: p1 p2
    [Fr Jul 23 18:07:33 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered d        ata mode. Opts: (null)
    [Fr Jul 23 18:07:33 2021] VFS: Mounted root (ext4 filesystem) readonly on device        179:2.
    [Fr Jul 23 18:07:33 2021] devtmpfs: mounted
    [Fr Jul 23 18:07:33 2021] Freeing unused kernel memory: 2048K
    [Fr Jul 23 18:07:33 2021] Run /sbin/init as init process
    [Fr Jul 23 18:07:33 2021]   with arguments:
    [Fr Jul 23 18:07:33 2021]     /sbin/init
    [Fr Jul 23 18:07:33 2021]   with environment:
    [Fr Jul 23 18:07:33 2021]     HOME=/
    [Fr Jul 23 18:07:33 2021]     TERM=linux
    [Fr Jul 23 18:07:33 2021] usb 1-1: new high-speed USB device number 2 using xhci        _hcd
    [Fr Jul 23 18:07:33 2021] usb 1-1: New USB device found, idVendor=2109, idProduc        t=3431, bcdDevice= 4.21
    [Fr Jul 23 18:07:33 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, Ser        ialNumber=0
    [Fr Jul 23 18:07:33 2021] usb 1-1: Product: USB2.0 Hub
    [Fr Jul 23 18:07:33 2021] hub 1-1:1.0: USB hub found
    [Fr Jul 23 18:07:33 2021] hub 1-1:1.0: 4 ports detected
    [Fr Jul 23 18:07:34 2021] systemd[1]: System time before build time, advancing c        lock.
    [Fr Jul 23 18:07:34 2021] NET: Registered protocol family 10
    [Fr Jul 23 18:07:34 2021] Segment Routing with IPv6
    [Fr Jul 23 18:07:34 2021] systemd[1]: systemd 241 running in system mode. (+PAM        +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN        UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie        rarchy=hybrid)
    [Fr Jul 23 18:07:34 2021] systemd[1]: Detected architecture arm.
    [Fr Jul 23 18:07:34 2021] systemd[1]: Set hostname to <raspberrypi>.
    [Fr Jul 23 18:07:35 2021] random: systemd: uninitialized urandom read (16 bytes        read)
    [Fr Jul 23 18:07:35 2021] systemd[1]: Listening on Syslog Socket.
    [Fr Jul 23 18:07:35 2021] systemd[1]: Listening on Journal Socket (/dev/log).
    [Fr Jul 23 18:07:35 2021] systemd[1]: Listening on udev Control Socket.
    [Fr Jul 23 18:07:35 2021] systemd[1]: Created slice User and Session Slice.
    [Fr Jul 23 18:07:35 2021] systemd[1]: Listening on fsck to fsckd communication S        ocket.
    [Fr Jul 23 18:07:35 2021] systemd[1]: Created slice system-getty.slice.
    [Fr Jul 23 18:07:35 2021] systemd[1]: Listening on Journal Socket.
    [Fr Jul 23 18:07:35 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Fr Jul 23 18:07:35 2021] systemd-journald[120]: Received request to flush runti        me journal from PID 1
    [Fr Jul 23 18:07:36 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initi        alised: Registers at 0xfeb00000 length 0x00010000
    [Fr Jul 23 18:07:36 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem        initialised: Registers at 0xfeb10000 length 0x00001000
    [Fr Jul 23 18:07:36 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initi        alised: Registers at 0xfeb20000 length 0x00010000
    [Fr Jul 23 18:07:36 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initial        ised: Registers at 0xfeb30000 length 0x00010000
    [Fr Jul 23 18:07:36 2021] mc: Linux media interface: v0.10
    [Fr Jul 23 18:07:36 2021] vc_sm_cma: module is from the staging directory, the q        uality is unknown, you have been warned.
    [Fr Jul 23 18:07:36 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory drive        r
    [Fr Jul 23 18:07:36 2021] [vc_sm_connected_init]: start
    [Fr Jul 23 18:07:36 2021] videodev: Linux video capture interface: v2.00
    [Fr Jul 23 18:07:36 2021] [vc_sm_connected_init]: installed successfully
    [Fr Jul 23 18:07:36 2021] snd_bcm2835: module is from the staging directory, the        quality is unknown, you have been warned.
    [Fr Jul 23 18:07:36 2021] bcm2835_mmal_vchiq: module is from the staging directo        ry, the quality is unknown, you have been warned.
    [Fr Jul 23 18:07:36 2021] bcm2835_v4l2: module is from the staging directory, th        e quality is unknown, you have been warned.
    [Fr Jul 23 18:07:36 2021] bcm2835_isp: module is from the staging directory, the        quality is unknown, you have been warned.
    [Fr Jul 23 18:07:36 2021] bcm2835_audio bcm2835_audio: card created with 8 chann        els
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Device node output[0] registe        red as /dev/video13
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Device node capture[0] regist        ered as /dev/video14
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Device node capture[1] regist        ered as /dev/video15
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Device node stats[2] register        ed as /dev/video16
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Register output node 0 with m        edia controller
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with        media controller
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with        media controller
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with        media controller
    [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [Fr Jul 23 18:07:36 2021] bcm2835_codec: module is from the staging directory, t        he quality is unknown, you have been warned.
    [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video10
    [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video11
    [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [Fr Jul 23 18:07:36 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d        on minor 0
    [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Device registered as /dev        /video12
    [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [Fr Jul 23 18:07:36 2021] [drm] No displays found. Consider forcing hotplug if H        DMI is attached
    [Fr Jul 23 18:07:36 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_        ops [vc4])
    [Fr Jul 23 18:07:36 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor        1
    [Fr Jul 23 18:07:38 2021] random: crng init done
    [Fr Jul 23 18:07:38 2021] random: 7 urandom warning(s) missed due to ratelimitin        g
    [Fr Jul 23 18:07:38 2021] 8021q: 802.1Q VLAN Support v1.8
    [Fr Jul 23 18:07:39 2021] cfg80211: Loading compiled-in X.509 certificates for r        egulatory database
    [Fr Jul 23 18:07:39 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9c        ea7'
    [Fr Jul 23 18:07:39 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents        :2 across:307200k SSFS
    [Fr Jul 23 18:07:39 2021] bcmgenet fd580000.ethernet: configuring instance for e        xternal RGMII (RX delay)
    [Fr Jul 23 18:07:39 2021] bcmgenet fd580000.ethernet eth0: Link is Down
    [Fr Jul 23 18:07:44 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Fu        ll - flow control off
    [Fr Jul 23 18:07:44 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes read        y
    [Fr Jul 23 18:07:45 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (s        yscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_        ms instead
    [Fr Jul 23 18:42:13 2021] Bluetooth: Core ver 2.22
    [Fr Jul 23 18:42:13 2021] NET: Registered protocol family 31
    [Fr Jul 23 18:42:13 2021] Bluetooth: HCI device and connection manager initializ        ed
    [Fr Jul 23 18:42:13 2021] Bluetooth: HCI socket layer initialized
    [Fr Jul 23 18:42:13 2021] Bluetooth: L2CAP socket layer initialized
    [Fr Jul 23 18:42:13 2021] Bluetooth: SCO socket layer initialized
    pi@raspberrypi:~ $
    @tinonikol
    Kannst du mal schauen wie du das ohne die ganzen Lücken kopiert bekommst?
      @tinonikol
      TinoNikol
      [Fr Jul 23 18:07:32 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1421 SMP Thu May 27 14:00:13 BST 2021
      [Fr Jul 23 18:07:32 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      [Fr Jul 23 18:07:32 2021] CPU: div instructions available: patching division code
      [Fr Jul 23 18:07:32 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      [Fr Jul 23 18:07:32 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
      [Fr Jul 23 18:07:32 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [Fr Jul 23 18:07:32 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      [Fr Jul 23 18:07:32 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
      [Fr Jul 23 18:07:32 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
      [Fr Jul 23 18:07:32 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
      [Fr Jul 23 18:07:32 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:95:80:D2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4977864a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Fr Jul 23 18:07:32 2021] Kernel parameter elevator= does not have any effect anymore.
                                Please use sysfs to set IO scheduler for individual devices.
      [Fr Jul 23 18:07:32 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [Fr Jul 23 18:07:32 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [Fr Jul 23 18:07:32 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
      [Fr Jul 23 18:07:32 2021] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
      [Fr Jul 23 18:07:32 2021] Memory: 3654940K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K cma-reserved, 3264512K highmem)
      [Fr Jul 23 18:07:32 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [Fr Jul 23 18:07:32 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [Fr Jul 23 18:07:32 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
      [Fr Jul 23 18:07:32 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
      [Fr Jul 23 18:07:32 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
      [Fr Jul 23 18:07:32 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [Fr Jul 23 18:07:32 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [Fr Jul 23 18:07:32 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [Fr Jul 23 18:07:32 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      [Fr Jul 23 18:07:32 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      [Fr Jul 23 18:07:32 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [Fr Jul 23 18:07:32 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [Fr Jul 23 18:07:32 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
      [Fr Jul 23 18:07:32 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-05-27T14:02:15, variant start
      [Fr Jul 23 18:07:32 2021] raspberrypi-firmware soc:firmware: Firmware hash is 7d9a298cda813f747b51fe17e1e417e7bf5ca94d
      [Fr Jul 23 18:07:32 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [Fr Jul 23 18:07:33 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [Fr Jul 23 18:07:33 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [Fr Jul 23 18:07:33 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [Fr Jul 23 18:07:33 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [Fr Jul 23 18:07:33 2021] TCP: Hash tables configured (established 8192 bind 8192)
      [Fr Jul 23 18:07:33 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [Fr Jul 23 18:07:33 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [Fr Jul 23 18:07:33 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [Fr Jul 23 18:07:33 2021] workingset: timestamp_bits=14 max_order=20 bucket_order=6
      [Fr Jul 23 18:07:33 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [Fr Jul 23 18:07:33 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
      [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
      [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
      [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
      [Fr Jul 23 18:07:33 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [Fr Jul 23 18:07:33 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
      [Fr Jul 23 18:07:33 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [Fr Jul 23 18:07:33 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [Fr Jul 23 18:07:33 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [Fr Jul 23 18:07:33 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [Fr Jul 23 18:07:33 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
      [Fr Jul 23 18:07:33 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
      [Fr Jul 23 18:07:33 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [Fr Jul 23 18:07:33 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [Fr Jul 23 18:07:33 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
      [Fr Jul 23 18:07:33 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [Fr Jul 23 18:07:33 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [Fr Jul 23 18:07:33 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      [Fr Jul 23 18:07:33 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
      [Fr Jul 23 18:07:33 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [Fr Jul 23 18:07:33 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [Fr Jul 23 18:07:33 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
      [Fr Jul 23 18:07:33 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Fr Jul 23 18:07:33 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [Fr Jul 23 18:07:33 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [Fr Jul 23 18:07:33 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [Fr Jul 23 18:07:34 2021] systemd[1]: System time before build time, advancing clock.
      [Fr Jul 23 18:07:34 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [Fr Jul 23 18:07:35 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
      [Fr Jul 23 18:07:35 2021] systemd-journald[120]: Received request to flush runtime journal from PID 1
      [Fr Jul 23 18:07:36 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
      [Fr Jul 23 18:07:36 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
      [Fr Jul 23 18:07:36 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
      [Fr Jul 23 18:07:36 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [Fr Jul 23 18:07:36 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [Fr Jul 23 18:07:36 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [Fr Jul 23 18:07:36 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [Fr Jul 23 18:07:36 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
      [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [Fr Jul 23 18:07:36 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [Fr Jul 23 18:07:36 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [Fr Jul 23 18:07:36 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [Fr Jul 23 18:07:36 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
      [Fr Jul 23 18:07:36 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
      [Fr Jul 23 18:07:38 2021] random: 7 urandom warning(s) missed due to ratelimiting
      [Fr Jul 23 18:07:39 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [Fr Jul 23 18:07:39 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [Fr Jul 23 18:07:39 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:307200k SSFS
      [Fr Jul 23 18:07:39 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
      [Fr Jul 23 18:07:44 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
      [Fr Jul 23 18:07:44 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [Fr Jul 23 18:07:45 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
      [Fr Jul 23 18:42:13 2021] Bluetooth: HCI device and connection manager initialized
      pi@raspberrypi:~ $
      • T TinoNikol
        pi@raspberrypi:~ $
        @tinonikol Unauffällig.
        iobroker stop
        iobroker fix
        iobroker start
          iobroker stop
          iobroker fix
          iobroker start
          TinoNikol
          @thomas-braun hab ich schon 3 mal Probiert bringt nix
          • T TinoNikol
            @tinonikol
            Mal mit dem Backitup-Adapter versucht?
            Sollte man eh verwenden, finde ich.
            Oder wenigstens mal ohne sudo?
            Meldungen dann?
              @tinonikol
              Meldungen dann?
              TinoNikol
              schrieb am zuletzt editiert von TinoNikol
              @thomas-braun Genau das selbe macht nur ein Backup von meinen Javascript Adapter!
              Ohne Sudo das selbe!
              • T TinoNikol
                @tinonikol
                Meldungen?
                  @tinonikol
                  Meldungen?
                  TinoNikol
                  @thomas-braun Keine er macht einfach nur reboot !
                  • T TinoNikol
                    @tinonikol
                    Wann macht die Kiste einen Reboot?
                      @tinonikol
                      TinoNikol
                      @thomas-braun Ich drücke Iobroker Backup 1 Min Später Reboot!
                      Arbeitsspeicher geht dabei bis auf 100 Runter!
                      • T TinoNikol
                        @tinonikol
                        Keine Ahnung.
                          @tinonikol
                          Keine Ahnung.
                          TinoNikol
                          @thomas-braun Gibts ne Möglichkeit anderweitig ein Backup vom System zu machen?
                          • T TinoNikol
                            @tinonikol
                            Klonen. Aber das backt die Fehlkonfiguration ja auch nur fest.
                              @tinonikol
                              TinoNikol
                              Jetzt kommt das?
                              pi@raspberrypi:~ $ iobroker backup
                              host.raspberrypi 6606 states saved
                              host.raspberrypi 7651 objects saved
                              Objects database error: read ECONNRESET
                              Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              States database error: connect ECONNREFUSED 127.0.0.1:9000
                              • T TinoNikol
                                Jetzt kommt das?
                                @tinonikol
                                iobroker status
                                  @tinonikol
                                  iobroker status
                                  TinoNikol
                                  pi@raspberrypi:~ $ iobroker status
                                  Objects type: file
                                  States  type: file
                                  • T TinoNikol
                                    Objects type: file
                                    States  type: file
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    @tinonikol
                                    Zeige mal bitte die Ausgabe von
                                    df -h
                                    • Besuche meine Github Seite
                                    • HowTo Restore ioBroker
                                    • simatecS simatec
                                      @tinonikol
                                      df -h
                                      TinoNikol
                                      @simatec
                                      pi@raspberrypi:~ $ df -h
                                      Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                                      /dev/root        59G     12G   45G   21% /
                                      devtmpfs        1,8G       0  1,8G    0% /dev
                                      tmpfs           1,9G       0  1,9G    0% /dev/shm
                                      tmpfs           1,9G    8,5M  1,9G    1% /run
                                      tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                                      tmpfs           1,9G       0  1,9G    0% /sys/fs/cgroup
                                      /dev/mmcblk0p1  253M     48M  205M   19% /boot
                                      tmpfs           383M       0  383M    0% /run/user/1000
                                      pi@raspberrypi:~ $
                                      • T TinoNikol
                                        Hi evtl. kann mir hier jemand helfen ich bekomme ständig diese Meldung beim Versuch Iobroker Sicherung zu machen!
                                        permitted by applicable law.
                                        Last login: Fri Jul 23 12:58:15 2021 from 192.168.178.46
                                        pi@raspberrypi:~ $ iobroker stop
                                        pi@raspberrypi:~ $ sudo iobroker backup
                                        host.raspberrypi 6429 states saved
                                        host.raspberrypi 7476 objects saved
                                        internal/buffer.js:956
                                            super(bufferOrLength, byteOffset, length);
                                        RangeError: Array buffer allocation failed
                                            at arrayBufferConstructor_DoNotInitialize (<anonymous>)
                                            at new Uint8Array (<anonymous>)
                                            at new FastBuffer (internal/buffer.js:956:5)
                                            at fromArrayLike (buffer.js:501:10)
                                            at fromObject (buffer.js:509:12)
                                            at Function.from (buffer.js:318:15)
                                            at RedisHandler.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-file/lib/objects/objectsInMemServerRedis.js:452:60)
                                            at RedisHandler.emit (events.js:375:28)
                                            at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js:100:37)
                                            at processImmediate (internal/timers.js:464:21)
                                        pi@raspberrypi:~ $
                                        TinoNikol
                                        @tinonikol said in Iobroker Sicherung nicht möglich:
                                        pi@raspberrypi:~ $
                                        Keiner mehr einen vorschlag?
                                        • T TinoNikol
                                          pi@raspberrypi:~ $
                                          @tinonikol
                                          Da wird nicht mit sudo herumhantiert!
