  4. js-controller 3.3 jetzt im Beta
    6.0k
791 Beiträge 75 Kommentatoren 285.8k Aufrufe 56 Beobachtet
  • JB_SullivanJ JB_Sullivan
    @apollon77
    Wie ich oben geschrieben habe ist es ein jqui-radiobuttons ON/OFF. Was meinst du mit "steuerbar" Im VIS ist es ein Button, den man Umsteuern kann, welcher aber in der Widget Konfig nicht separat definiert werden muss.
    Mit den Fehlermeldungen (F12) des Browsers hat es aber wohl nichts zu tun - oder?
    Uncaught (in promise) ReferenceError: socket is not defined
        at Object.getAdaptersAndcheckMessages (popupnews.js:214)
        at Object.showPopup (popupnews.js:64)
        at setData (info.js:67)
        at Object.createMessage (info.js:40)
        at info.js:30
        at sentryWrapped (helpers.ts:87)
    helpers.ts:111 Uncaught DOMException: Blocked a frame with origin "http://10.122.60.87:8082" from accessing a cross-origin frame.
        at HTMLIFrameElement.<anonymous> (http://10.122.60.87:8082/vis/js/vis.js:3067:40)
        at Function.each (http://10.122.60.87:8082/lib/js/jquery-1.11.2.min.js:2:2975)
        at m.fn.init.each (http://10.122.60.87:8082/lib/js/jquery-1.11.2.min.js:2:835)
        at Object.updateIframeZoom (http://10.122.60.87:8082/vis/js/vis.js:3066:25)
        at Object.postChangeView (http://10.122.60.87:8082/vis/js/vis.js:1947:14)
        at http://10.122.60.87:8082/vis/js/vis.js:1896:22
        at http://10.122.60.87:8082/vis/js/vis.js:971:35
        at Object.renderViews (http://10.122.60.87:8082/vis/js/vis.js:801:27)
        at http://10.122.60.87:8082/vis/js/vis.js:807:18
        at http://10.122.60.87:8082/vis/js/vis.js:990:35
        at sentryWrapped (http://10.122.60.87:8082/vis/widgets/materialdesign/lib/raw/sentry/bundle.min.js:2:53837)
    instrument.js:109 DashboardModel.on is deprecated use events.subscribe
    2helpers.ts:111 Uncaught DOMException: Blocked a frame with origin "http://10.122.60.87:8082" from accessing a cross-origin frame.
        at http://10.122.60.87:8082/vis/js/vis.js:1882:26
    DevTools failed to load source map: Could not load content for http://10.122.60.87:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    sentryWrapped @ helpers.ts:111
    setTimeout (async)
    (anonymous) @ trycatch.ts:119
    (anonymous) @ vis.js:988
    subscribeStates @ vis.js:2857
    renderView @ vis.js:844
    renderViews @ vis.js:806
    (anonymous) @ vis.js:807
    (anonymous) @ vis.js:990
    sentryWrapped @ helpers.ts:87
    setTimeout (async)
    (anonymous) @ vis.js:962
    changeView @ vis.js:1855
    (anonymous) @ vis.js:2696
    #549
    @jb_sullivan sagte in js-controller 3.3 jetzt im Beta:
    Der erste Fehler ist unrelated und würde auf Info Adapter tippen.
    Der Rest kommt von
    materialdesign
      @apollon77 sagte in js-controller 3.3 jetzt im Beta:
      Was sonst noch offen?
      Nuki-Extended (https://github.com/Zefau/ioBroker.nuki-extended/issues/145) unverändert bisher (v2.3.0).
      Dr. BakteriusD Online
      Dr. Bakterius
      #550
      @dr-bakterius sagte in js-controller 3.3 jetzt im Beta:
      Nuki-Extended
      @apollon77 Leider hat die Anpassung nichts geändert (https://github.com/iobroker-community-adapters/ioBroker.nuki-extended/issues/132).
      apollon77A 2 Antworten Letzte Antwort
        Nuki-Extended
        #551
        @dr-bakterius Naja am Ende ist es hier wie bei roomba ... ich muss jeden State einzeln korrigieren ... schreibe im GitHub issue wenns neuen versuch gibt
        Dr. BakteriusD 1 Antwort Letzte Antwort
          Nuki-Extended
          #552
          @dr-bakterius Ok, next try please
          • apollon77A Offline
            #553
            Also es ging gerade noch info Adapter raus als 1.9.0 ...
            Sonst:
            • roomba sollte fertig sein aber mir fehlen npm release rechte, sind dran
            • innogy-smarthome ... identischzu roomba
            • spotify-premium werde ich nicht anpassen können. Da muss man von einem Jahr COde changes raussuchen was es kaputt gemacht hat. Die Zeit, Lust und spotify-premium habe ich aktuell nicht. Bitte erst einmal Loglevel hoch setzen
            • nuki-extended siehe oben. Kann denke auch raus sobald @Dr-Bakterius nochmal was dazu gesagt hat :-)
            JB_SullivanJ FeuersturmF 2 Antworten Letzte Antwort
            • apollon77A apollon77
              Sonst:
              JB_SullivanJ Offline
              JB_Sullivan
              #554
              @apollon77
              Ein state im Roomba Adapter ist eben noch aufgepoppt. Habt ihr den in der 1.1.4 schon berücksichtigt?
              roomba.0	2021-07-20 14:34:13.597	info	(9004) State value to set for "roomba.0.states._connected" has to be type "string" but received type "boolean"
                Dr. Bakterius
                #555
                Erstmal vielen Dank Ingo für die tolle Arbeit und die Zeit die du investierst! 👍
                Bei mir läuft nuki-extended jetzt ohne weitere Meldungen wegen falscher Datenpunktdeklaration.
                apollon77A Dr. BakteriusD 2 Antworten Letzte Antwort
                  @apollon77
                  #556
                  _
                  zeig bitte mal Debug log ... ich hab keine Ahnung wo der state her kommt und so
                    #557
                    @dr-bakterius Danke, geht raus sobald ich rechte habe oder Bluefox zeit hat also 2.3.1
                    • JB_SullivanJ Offline
                      JB_Sullivan
                      #558
                      Ich habe gerade den Innogy Adapter in 0.3.6 angeboten bekommen und installiert. Als ich die GIT Version drauf hatte, war alles OK, mit der "offiziell" Installierten Adapter Version sieht es leider so aus.
                      innogy-smarthome.0	2021-07-20 16:56:29.797	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.TotalMowingTime" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.796	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.SubStatus" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.796	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.SituationFlags" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.795	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.OperationTimeWR" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.794	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.OperationTimeWL" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.793	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.OperationTimeBlade" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.792	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.OperatingTime" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.791	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.MowingCycles" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.790	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.MowerStatus" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.788	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.BladeServiceTime" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.787	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.TiltSlope" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.787	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.RemainingOperationTime" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.786	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.RainSensor" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.786	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.RainDelay" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.785	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.NextOperationStartTime" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.784	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.EcoMode" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.784	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.CuttingHeight" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.783	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.Action" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.782	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.ErrorDescription" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.782	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.ChargingCycles" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.781	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.ChargingCurrent" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.780	warn	(10168) State "innogy-smarthome.0.Garten.Wall-E.BatteryLevel" has no existing object, this might lead to an error in future versions
                      innogy-smarthome.0	2021-07-20 16:56:29.640	warn	(10168) setObject Garten.Wall-E.TotalMowingTime (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.640	warn	(10168) Unknown state (please report to dev):totalMowingTime {"name":"totalMowingTime","value":110590,"lastchanged":"2021-07-20T11:46:30.934Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.640	warn	(10168) setObject Garten.Wall-E.SubStatus (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.639	warn	(10168) Unknown state (please report to dev):subStatus {"name":"subStatus","value":"READY","lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.639	warn	(10168) setObject Garten.Wall-E.SituationFlags (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.639	warn	(10168) Unknown state (please report to dev):situationFlags {"name":"situationFlags","value":"{\"OperationPermitted\": true,\"BatteryWeak\": false,\"BatteryFailure\": false,\"BatteryFailureSticky\":
                      innogy-smarthome.0	2021-07-20 16:56:29.639	warn	(10168) setObject Garten.Wall-E.OperationTimeWR (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.639	warn	(10168) Unknown state (please report to dev):operationTimeWR {"name":"operationTimeWR","value":116051,"lastchanged":"2021-07-20T11:46:31.114Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.638	warn	(10168) setObject Garten.Wall-E.OperationTimeWL (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.638	warn	(10168) Unknown state (please report to dev):operationTimeWL {"name":"operationTimeWL","value":116056,"lastchanged":"2021-07-20T11:46:30.937Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.638	warn	(10168) setObject Garten.Wall-E.OperationTimeBlade (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.638	warn	(10168) Unknown state (please report to dev):operationTimeBlade {"name":"operationTimeBlade","value":105472,"lastchanged":"2021-07-20T11:44:30.583Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.638	warn	(10168) setObject Garten.Wall-E.OperatingTime (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.637	warn	(10168) Unknown state (please report to dev):operatingTime {"name":"operatingTime","value":1559668,"lastchanged":"2021-07-20T14:57:28.937Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.637	warn	(10168) setObject Garten.Wall-E.MowingCycles (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.637	warn	(10168) Unknown state (please report to dev):mowingCycles {"name":"mowingCycles","value":3192,"lastchanged":"2021-07-20T11:08:04.617Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.637	warn	(10168) setObject Garten.Wall-E.MowerStatus (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.637	warn	(10168) Unknown state (please report to dev):mowerStatus {"name":"mowerStatus","value":"IDLE_BASE_STATION","lastchanged":"2021-07-20T14:41:14.866Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.637	warn	(10168) setObject Garten.Wall-E.BladeServiceTime (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.636	warn	(10168) Unknown state (please report to dev):bladeServiceTime {"name":"bladeServiceTime","value":100,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.636	warn	(10168) setObject Garten.Wall-E.TiltSlope (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.636	warn	(10168) Unknown state (please report to dev):tiltSlope {"name":"tiltSlope","value":22,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.636	warn	(10168) setObject Garten.Wall-E.RemainingOperationTime (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.636	warn	(10168) Unknown state (please report to dev):remainingOperationTime {"name":"remainingOperationTime","value":0,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.635	warn	(10168) setObject Garten.Wall-E.RainSensor (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.635	warn	(10168) Unknown state (please report to dev):rainSensor {"name":"rainSensor","value":true,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.635	warn	(10168) setObject Garten.Wall-E.RainDelay (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.635	warn	(10168) Unknown state (please report to dev):rainDelay {"name":"rainDelay","value":90,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.635	warn	(10168) setObject Garten.Wall-E.NextOperationStartTime (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.634	warn	(10168) Unknown state (please report to dev):nextOperationStartTime {"name":"nextOperationStartTime","value":0,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.634	warn	(10168) setObject Garten.Wall-E.EcoMode (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.634	warn	(10168) Unknown state (please report to dev):ecoMode {"name":"ecoMode","value":0,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.634	warn	(10168) setObject Garten.Wall-E.CuttingHeight (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.634	warn	(10168) Unknown state (please report to dev):cuttingHeight {"name":"cuttingHeight","value":30,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.633	warn	(10168) setObject Garten.Wall-E.Action (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.633	warn	(10168) Unknown state (please report to dev):action {"name":"action","value":"STOP_HOMING","lastchanged":"2021-07-20T11:46:44.913Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.633	warn	(10168) setObject Garten.Wall-E.ErrorDescription (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.633	warn	(10168) Unknown state (please report to dev):errorDescription {"name":"errorDescription","value":"CN999;ISSUE;UNKNOWN","lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.633	warn	(10168) setObject Garten.Wall-E.ChargingCycles (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.632	warn	(10168) Unknown state (please report to dev):chargingCycles {"name":"chargingCycles","value":1817,"lastchanged":"2021-07-20T11:46:44.388Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.632	warn	(10168) setObject Garten.Wall-E.ChargingCurrent (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.632	warn	(10168) Unknown state (please report to dev):chargingCurrent {"name":"chargingCurrent","value":1000,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.632	warn	(10168) setObject Garten.Wall-E.BatteryLevel (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.631	warn	(10168) Unknown state (please report to dev):batteryLevel {"name":"batteryLevel","value":100,"lastchanged":"2021-07-20T13:40:50.642Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.631	warn	(10168) setObject Büro.Rauchmelder-Büro.IsSmokeAlarm (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.631	warn	(10168) Unknown state (please report to dev):isSmokeAlarm {"name":"isSmokeAlarm","value":false,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.630	warn	(10168) setObject Garten.Rauchmelder-E-Bike-Ladestation.IsSmokeAlarm (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.630	warn	(10168) Unknown state (please report to dev):isSmokeAlarm {"name":"isSmokeAlarm","value":false,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.629	warn	(10168) setObject Flur.Rauchmelder-Flur-OG.IsSmokeAlarm (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.629	warn	(10168) Unknown state (please report to dev):isSmokeAlarm {"name":"isSmokeAlarm","value":false,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.629	warn	(10168) setObject Kinderzimmer-OG.Rauchmelder.IsSmokeAlarm (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.628	warn	(10168) setObject Keller.Rauchmelder-Speicher.IsSmokeAlarm (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.628	warn	(10168) Unknown state (please report to dev):isSmokeAlarm {"name":"isSmokeAlarm","value":false,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.628	warn	(10168) setObject Ankleidezimmer.Rauchmelder.IsSmokeAlarm (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.627	warn	(10168) Unknown state (please report to dev):isSmokeAlarm {"name":"isSmokeAlarm","value":false,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.627	warn	(10168) setObject Flur.Rauchmelder-Flur.IsSmokeAlarm (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.626	warn	(10168) Unknown state (please report to dev):isSmokeAlarm {"name":"isSmokeAlarm","value":false,"lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.626	warn	(10168) setObject Variable.HTTP-Anfrage.IsSending (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.625	warn	(10168) Unknown state (please report to dev):isSending {"name":"isSending","value":false,"lastchanged":"2021-07-19T19:44:56.621Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.625	warn	(10168) setObject Variable.HTTP-Anfrage.HTTPResponseStatus (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.625	warn	(10168) Unknown state (please report to dev):HTTPResponseStatus {"name":"HTTPResponseStatus","value":"Success","lastchanged":"2021-07-19T19:44:56.620Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.623	warn	(10168) setObject Garten.Alarmsirene.ActiveChannel (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.622	warn	(10168) Unknown state (please report to dev):activeChannel {"name":"activeChannel","value":"None","lastchanged":"1970-01-01T00:00:00.000Z"}
                      innogy-smarthome.0	2021-07-20 16:56:29.622	warn	(10168) setObject Garten.Alarmsirene.IsOn (type=state) property common.role missing!
                      innogy-smarthome.0	2021-07-20 16:56:29.622	warn	(10168) Unknown state (please report to dev):isOn {"name":"isOn","value":false,"lastchanged":"1970-01-01T00:00:00.000Z"}
                        #559
                        @jb_sullivan Neue innogy ist 0.3.7 ... das kommt erst später ins Latest ... da warste jetzt wohl zu schnell. Nimm Github version und fertig
                          _
                          JB_Sullivan
                          #560
                          @apollon77
                          Mehr ist über DEBUG beim Roomba nicht raus zu bekommen.
                          roomba.0	2021-07-20 20:03:29.694	info	(11856) State value to set for "roomba.0.states._connected" has to be type "string" but received type "boolean"
                          roomba.0	2021-07-20 20:03:29.693	info	(11856) State value to set for "roomba.0.states._connected" has to be type "string" but received type "boolean"
                          roomba.0	2021-07-20 20:03:29.691	debug	(11856) Updated state states._connected to value false (from null).
                          roomba.0	2021-07-20 20:03:29.690	debug	(11856) Updated state states._connected to value false (from null).
                          roomba.0	2021-07-20 20:03:29.685	debug	(11856) {"errno":-4077,"code":"ECONNRESET","syscall":"read"}
                          roomba.0	2021-07-20 20:03:29.685	warn	(11856) Unknown error! Please see debug log for details.
                          roomba.0	2021-07-20 20:03:29.685	info	(11856) Roomba Connection closed.
                          roomba.0	2021-07-20 20:03:29.684	warn	(11856) Connection lost! Roomba offline.
                          roomba.0	2021-07-20 20:03:13.317	debug	(11856) system.adapter.admin.0: logging true
                          roomba.0	2021-07-20 20:03:11.759	debug	(11856) Updated state info.connection to value true (from null).
                          roomba.0	2021-07-20 20:03:11.751	debug	(11856) Updated state info.connection to value false (from null).
                          roomba.0	2021-07-20 20:03:11.651	info	(11856) Connecting to Roomba (10.122.60.10)..
                          roomba.0	2021-07-20 20:03:11.597	info	(11856) starting. Version 1.1.4 in C:/iobroker/GLT/node_modules/iobroker.roomba, node: v14.16.0, js-controller: 3.3.14
                          • M Marty56
                            @apollon77
                            Es kommt nur beim Start.
                            Aber was auch noch kommt ist,
                            tr-064.0	2021-07-18 10:03:07.552	info	(COMPACT) State value to set for "tr-064.0.callmonitor.lastCall.callee" has to be type "number" but received type "string"
                            tr-064.0	2021-07-18 10:03:01.065	info	(COMPACT) State value to set for "tr-064.0.callmonitor.inbound.callee" has to be type "number" but received type "string"
                            das ist keine Warning aber info.
                            FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #561
                            @marty56 sagte in js-controller 3.3 jetzt im Beta:
                            @apollon77
                            @apollon77 Hab ein issue hierzu angelegt. Hatte erst im Nachgang hier die Diskussion gesehen: https://github.com/iobroker-community-adapters/ioBroker.tr-064/issues/278
                            @marty56 Wenn du noch weitere Datenpunkte bei dir hast, einfach an das issue als Kommentar anfügen
                              Sonst:
                              FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              #562
                              @apollon77 Beim Info Adapter 1.9.0 gibt es noch viele Warnungen https://github.com/iobroker-community-adapters/ioBroker.info/issues/310
                                @apollon77
                                #563
                                @jb_sullivan Bitte neues GitHub issue ... Und bitte @Zefau im Issue mentionen ... ich hab keine Idee wo das her kommt. Da muss er reinschauen wenn er zeit findet
                                • FeuersturmF Feuersturm
                                  @apollon77
                                  #564
                                  @feuersturm Danke habe kommentiert. Ich brauche immer noch ein Debug Log von tr-064 ...
                                  • M Marty56
                                    @apollon77
                                    #565
                                    @marty56 Meinst Du du schaffst noch zeitnah ein Debug Log mit den callee Fehlern?
                                    • DiginixD Diginix
                                      Oha, beim sonoff wird eigentlich jedes Objekt als String geliefert obwohl es number sein sollte.
                                      Und beim statistics kommt alles als boolean obwohl es number sein müsste.
                                      Musste nach weniger als 1min beide Adapter wieder auf Loglevel warn stellen. ;-)
                                      Ich schau dann ob es bei GIT schon die entsprechenden issues gibt.
                                      DiginixD Offline
                                      DiginixD Offline
                                      Diginix
                                      #566
                                      @diginix sagte in js-controller 3.3 jetzt im Beta:
                                      @apollon77
                                      Mit sonoff 2.4.5 auf loglevel info bekomme ich bisher keinerlei Datentyp Fehler mehr gemeldet. Das sieht recht vielversprechend aus.
                                      ..:: So long! Tom ::..
                                        Marty56
                                        schrieb am zuletzt editiert von Marty56
                                        #567
                                        @apollon77 Ich habe derzeit ein Riesenproblem, dass alle meine aliases nicht mehr funktionieren und damit mein ganzes System nichts mehr tut.
                                        Ich habe derzeit keine Ahnung voran das liegt und muss jetzt den Fehler eingrenzen.
                                        HW:NUC (16 GB Ram)
                                        OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                        • M Marty56
                                          #568
                                          @marty56 Was bedeutet "alle nicht mehr tun"? Objekte sind korrekt? Mal neu gestartet?
