  4. Adapter WM-Bus / Kampstrup Multical 21
    6.4k
153 Beiträge 12 Kommentatoren 32.4k Aufrufe 13 Beobachtet
  • W WolfgangFB
    pi@raspberrypi4:/var/log/wmbusmeters/meter_readings $ systemctl status wmbusmeters
    ● wmbusmeters.service - "wmbusmeters service"
      Loaded: loaded (/lib/systemd/system/wmbusmeters.service; disabled; vendor preset: enabled)
      Active: active (running) since Sun 2021-06-27 22:47:02 CEST; 12h ago
        Docs: https://github.com/weetmuts/wmbusmeters
              man:wmbusmeters(1)
     Process: 12243 ExecStartPre=/bin/mkdir -p /var/log/wmbusmeters/meter_readings (code=exited, status=0/SUCCESS)
     Process: 12244 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /var/log/wmbusmeters (code=exited, status=0/SUCCESS)
     Process: 12245 ExecStartPre=/bin/mkdir -p /run/wmbusmeters (code=exited, status=0/SUCCESS)
     Process: 12246 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /run/wmbusmeters (code=exited, status=0/SUCCESS)
     Process: 12247 ExecStart=/usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid (code=exited, status=0/SUCCESS)
    Main PID: 12248 (wmbusmetersd)
       Tasks: 3 (limit: 4915)
      CGroup: /system.slice/wmbusmeters.service
              └─12248 /usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12248]: (config) "alarmexpectedactivity" "mon-sun(00-23)"
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12247]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12248]: (config) "" ""
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12248]: (config) loading meter file /etc/wmbusmeters.d/MyTapWater
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12248]: (config) name=MyTapWater
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12248]: (config) type=multical21
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12248]: (config) id=57813696
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12248]: (config) key=<notprinted>
    Jun 27 22:47:02 raspberrypi4 wmbusmetersd[12248]: (wmbusmeters) using log file /var/log/wmbusmeters/wmbusmeters.log
    Jun 27 22:47:02 raspberrypi4 systemd[1]: Started "wmbusmeters service".
    und (ich glaube kaum dass jemand mit den Daten meines Wasserzählers irgendwelchen Unfug anstellen kann)
    pi@raspberrypi4:/var/log/wmbusmeters $ more wmbusmeters.log
    (wmbusmeters) logging started 2021-06-27 22:42:35 using 1.3.0-29-g3ee42c6
    Wmbus devices found but no meters supplied. You must supply which link modes to listen to. Eg. auto:c1
    (wmbusmeters) logging started 2021-06-27 22:42:37 using 1.3.0-29-g3ee42c6
    (wmbusmeters) logging started 2021-06-27 22:42:38 using 1.3.0-29-g3ee42c6
    (wmbusmeters) logging started 2021-06-27 22:42:39 using 1.3.0-29-g3ee42c6
    (wmbusmeters) logging started 2021-06-27 22:42:40 using 1.3.0-29-g3ee42c6
    (wmbusmeters) logging started 2021-06-27 22:47:02 using 1.3.0-29-g3ee42c6
    (wmbusmeters) version: 1.3.0-29-g3ee42c6
    (config) store meter files in: "/var/log/wmbusmeters/meter_readings"
    (config) using device: /dev/ttyUSB0:im871a
    (config) number of meters: 1
    (lookup) with file "/dev/ttyUSB0"
    (serial) before config: /dev/ttyUSB0 speed(B115200) input(ICRNL|IXON) output(ONLCR|OPOST) control(CLOCAL|CREAD|CSIZE|HUP
    CL) local(ECHO|ECHOCTL|ECHOE|ECHOK|ECHOKE|ICANON|IEXTEN|ISIG) special_chars(3,28,127,21,4,1,17,19,26,18,15,23,22) modem(
    DTR|RTS)
    (serial) after config:  /dev/ttyUSB0 speed(B9600) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() m
    odem(DTR|RTS)
    (serialtty) opened /dev/ttyUSB0 fd 4 (detect amb8465)
    (serial) received binary ""
    (serial /dev/ttyUSB0) sent "FF0A02008077"
    (serial) EVENT thread interrupted
    (serialtty) closed /dev/ttyUSB0 (detect amb8465)
    (amb8465) are you there? no.
    (serial) before config: /dev/ttyUSB0 speed(B9600) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() m
    odem(DTR|RTS)
    (serial) after config:  /dev/ttyUSB0 speed(B57600) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars()
    modem(DTR|RTS)
    (serialtty) opened /dev/ttyUSB0 fd 4 (detect im871a)
    (serial /dev/ttyUSB0) sent "A5010F00"
    (serial) received binary "A58110083300130107220000B5A6"
    (im871a) checkIM871AFrame "A58110083300130107220000B5A6"
    (im871a) has_timestamp=0 has_rssi=0 has_crc16=1
    (im871a) endpoint 1
    (im871a) msgid 16
    (im871a) got crc16 a6b5 expected a6b5
    (im871a) received full frame
    (device info bytes) "3300130107220000"
    (im871a/im170a) info: im871a other firmware=13 hci=01 uid=00002207
    (serial /dev/ttyUSB0) sent "A5010500"
    (serial) received binary "A5810617FF000200B32576071000010001FF07023200000000000039A4"
    (im871a) checkIM871AFrame "A5810617FF000200B32576071000010001FF07023200000000000039A4"
    (im871a) endpoint 1
    (im871a) msgid 6
    (im871a) got crc16 a439 expected a439
    (serialtty) closed /dev/ttyUSB0 (detect im871a)
    (device config bytes) "FF000200B32576071000010001FF070232000000000000"
    (im871a/im170a) config: other link_mode=s2 id=00100776 media=00 version=01 c_field=00 auto_rssi=00
    (im871a/im170a) are you there? yes 00100776 im871a firmware: 13
    (main) opening auto
    [2021-06-27_22:47:02] Started config im871a[00100776] on /dev/ttyUSB0 listening on none
    (im871a) on /dev/ttyUSB0
    (serial) before config: /dev/ttyUSB0 speed(B57600) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars()
    modem(DTR|RTS)
    modem(DTR|RTS)
    (serialtty) opened /dev/ttyUSB0 fd 4 (im871a)
    (im871a) get config
    (im871a) endpoint 1
    (im871a) msgid 6
    (im871a) get config completed
    (im871a) got device id 00100776
    (main) regular reset of im871a  on /dev/ttyUSB0 will happen every 82800 seconds
    [2021-06-27_22:47:02] Warning! Desired link modes none cannot be set for device /dev/ttyUSB0:im871a[00100776]
    (wmbus) set timeout im871a to "3600" with expected activity "mon-sun(00-23)"
    (serial) registered regular callback HOT_PLUG_DETECTOR(0) every 2 seconds
    (wmbusmeters) waiting for telegrams
    (serial) waiting for stop
    [2021-06-27_22:47:04] (memory) rss 1921024 peak 1.83 MiB
    (wmbus) updated_last received for im871a (/dev/ttyUSB0)
    [2021-06-27_23:47:02] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-27 23:47)
    (shell) exec "/bin/sh"
    (shell) arg "-c"
    (shell) arg "/usr/local/bin/mosquitto_pub -d -h localhost -t wmbusmeters_alarm -m "$ALARM_TYPE $ALARM_MESSAGE""
    (shell) env "ALARM_TYPE=DeviceInactivity"
    (shell) env "ALARM_MESSAGE=[ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 36
    00s expected mon-sun(00-23) now 2021-06-27 23:47)"
    (shell) waiting for child 16832 to complete.
    (shell) /bin/sh: return code 127
    [2021-06-27_23:47:02] (shell) /bin/sh exited with non-zero return code: 127
    (serial) initiate reset
    (serialtty) closed /dev/ttyUSB0 (im871a)
    [2021-06-27_23:47:02] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    (serial) reset completed
    [2021-06-27_23:47:05] (wmbus) successfully reset wmbus device
    [2021-06-28_00:47:02] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s expected mon-sun(00-23) now 2021-06-28 00:47)
    (shell) arg "-c"
    (shell) env "ALARM_MESSAGE=[ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s expected mon-sun(00-23) now 2021-06-28 00:47)"
    (shell) waiting for child 21517 to complete.
    [2021-06-28_00:47:02] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_00:47:02] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_00:47:05] (wmbus) successfully reset wmbus device
    [2021-06-28_01:47:02] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s expected mon-sun(00-23) now 2021-06-28 01:47)
    (shell) arg "-c"
    (shell) env "ALARM_MESSAGE=[ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s expected mon-sun(00-23) now 2021-06-28 01:47)"
    (shell) waiting for child 26093 to complete.
    [2021-06-28_01:47:02] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_01:47:02] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_01:47:05] (wmbus) successfully reset wmbus device
    [2021-06-28_02:47:02] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 02:47)
    (shell) arg "-c"
    00s expected mon-sun(00-23) now 2021-06-28 02:47)"
    (shell) waiting for child 30676 to complete.
    [2021-06-28_02:47:02] (shell) /bin/sh exited with non-zero return code: 127
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_02:47:05] (wmbus) successfully reset wmbus device
    [2021-06-28_03:47:02] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 03:47)
    (shell) arg "-c"
    00s expected mon-sun(00-23) now 2021-06-28 03:47)"
    (shell) waiting for child 3173 to complete.
    [2021-06-28_03:47:02] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_03:47:02] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_03:47:05] (wmbus) successfully reset wmbus device
    [2021-06-28_04:47:02] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 04:47)
    (shell) arg "-c"
    00s expected mon-sun(00-23) now 2021-06-28 04:47)"
    (shell) waiting for child 7739 to complete.
    [2021-06-28_04:47:02] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_04:47:02] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_04:47:05] (wmbus) successfully reset wmbus device
    [2021-06-28_05:47:02] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 05:47)
    (shell) arg "-c"
    00s expected mon-sun(00-23) now 2021-06-28 05:47)"
    (shell) waiting for child 12304 to complete.
    [2021-06-28_05:47:02] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_05:47:02] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_05:47:05] (wmbus) successfully reset wmbus device
    [2021-06-28_06:47:03] [ALARM DeviceInactivity] 3601 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 06:47)
    (shell) arg "-c"
    (shell) env "ALARM_MESSAGE=[ALARM DeviceInactivity] 3601 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 36
    00s expected mon-sun(00-23) now 2021-06-28 06:47)"
    (shell) waiting for child 17017 to complete.
    [2021-06-28_06:47:03] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_06:47:03] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_06:47:06] (wmbus) successfully reset wmbus device
    [2021-06-28_07:47:03] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 07:47)
    (shell) arg "-c"
    00s expected mon-sun(00-23) now 2021-06-28 07:47)"
    (shell) waiting for child 21569 to complete.
    [2021-06-28_07:47:03] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_07:47:03] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_07:47:08] (wmbus) successfully reset wmbus device
    [2021-06-28_08:47:03] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 08:47)
    (shell) arg "-c"
    00s expected mon-sun(00-23) now 2021-06-28 08:47)"
    (shell) waiting for child 26137 to complete.
    [2021-06-28_08:47:03] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_08:47:03] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_08:47:06] (wmbus) successfully reset wmbus device
    [2021-06-28_09:47:03] [ALARM DeviceInactivity] 3600 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 09:47)
    (shell) arg "-c"
    00s expected mon-sun(00-23) now 2021-06-28 09:47)"
    (shell) waiting for child 30713 to complete.
    [2021-06-28_09:47:03] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_09:47:03] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_09:47:06] (wmbus) successfully reset wmbus device
    [2021-06-28_10:47:04] [ALARM DeviceInactivity] 3601 seconds of inactivity resetting /dev/ttyUSB0 im871a (timeout 3600s e
    xpected mon-sun(00-23) now 2021-06-28 10:47)
    (shell) arg "-c"
    00s expected mon-sun(00-23) now 2021-06-28 10:47)"
    (shell) waiting for child 3194 to complete.
    [2021-06-28_10:47:04] (shell) /bin/sh exited with non-zero return code: 127
    [2021-06-28_10:47:04] (wmbus) resetting /dev/ttyUSB0
    modem(DTR|RTS)
    modem(DTR|RTS)
    [2021-06-28_10:47:07] (wmbus) successfully reset wmbus device
    Es scheint also, dass irgendwas empfangen wird, aber es wird nichts gespeichert. Nächste Frage: Wie bekomme ich das ganze jetzt noch in IO Broker (MQTT), gibt es hier eine dummysichere Anleitung?
    Gruß Wolfgang
    matze-dev
    @wolfgangfb Hallo Wolfgang, ich kann es leider nicht so ganz vergleichen, bei mir läuft das nicht als Service und ich habe noch die Vorgängerversion des Treibers. Es sieht so aus, dass er die Telegramme nicht korrekt bekommt (macht reset).
    Mein Logoutput sieht aber eher so aus:
    (meter) MyTapWater: not for me: not my id
    (wmbus) telegram ignored by all configured meters!
    (serial) not starting timer thread since it is already running.
    (serial) received binary "A5E2032E442D2C80xxxxxxxxxxxxxxxxxxxx"
    (im871a) checkIM871AFrame "A5E2032E442D2C802780741B167A6xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
    (im871a) has_timestamp=1 has_rssi=1 has_crc16=1
    (im871a) endpoint 2
    (im871a) msgid 3
    (im871a) timestamp 00000000
    (im871a) rssi 64
    (im871a) got crc16 66ff expected 66ff
    (wmbus) parseDLL @0 47
    W 1 Antwort Letzte Antwort
    • M matze-dev
      (im871a) endpoint 2
      (im871a) msgid 3
      (im871a) rssi 64
      W Offline
      W Offline
      WolfgangFB
      @matze-dev
      Hi
      Kannst Du mir (als Linux Nicht Profi) genau verraten, was Du gemacht hast und welche Software Du installierst hast?
      • W WolfgangFB
        @matze-dev
        Hi
        matze-dev
        @wolfgangfb Hallo Wolfgang, gemaess Zeile 42 Deines Logs muessten Daten gekommen sein, später erscheinen die nicht mehr. Aktualisiert das Logfile um die Eintraege weiterhin?
        Wenn ja, sieht es gut aus.
        Das nächste waere, den MQTT (mosquitto_pub) zu installieren - ist der auch schon auf dem System?
        Installationsanleitung liegt hierunter:
        https://mosquitto.org/blog/2013/01/mosquitto-debian-repository/
        Viel Glueck.
        • M matze-dev
          Viel Glueck.
          W Offline
          W Offline
          WolfgangFB
          @matze-dev
          Hallo
          Das ganze ist für mich als Nicht-Linuxianer etwas frustrierend.
          Das fängt damit an, dass Du schreibst "bei mir läuft das nicht als Service". Was habe ich denn falsch gemacht, dass es scheinbar bei mir als Service läuft. Ich habe mich meiner Meinung nach genau an die Anleitung gehalten. Ich stoße aber immer wieder auf Punkte bei denen ich den Eindruck habe, dass erfahrene Linuxianer genau wissen, was da gemeint ist, ich aber nur raten kann und irgendwas eingebe und wahrscheinlich etwas falsches.
          Ich konnte immer noch keinerlei Daten der Wasseruhr auf meinem Raspberry finden :-(
          Mosquitto habe ich vielleicht erfolgreich installiert.
          pi@raspberrypi4:/etc/apt/sources.list.d $ sudo apt-get install mosquitto
          mosquitto ist schon die neueste Version (2.0.11-0mosquitto1~stretch1).
          verstehe ich so, dass ich das vorhanden ist.
          In der Anleitung bin ich an dieser Stelle gestolpert:
          Then one of the following, depending on which version of debian you are using:
          An der Stelle frage ich mich, wie ich herausfinden kann, welche "version of debian" ich benutze. Erfahren User denken bestimmt "das ist doch ganz klar", mir ist das aber nicht klar.
          Der aktuelle Status des wmbusmasters sieht wie folgt aus:
          pi@raspberrypi4:/etc/apt/sources.list.d $ systemctl status wmbusmeters
             Active: active (running) since Sun 2021-06-27 22:47:02 CEST; 1 weeks 3 days ago
                     man:wmbusmeters(1)
          Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
          Also irgendwas scheint da immer noch nicht zu stimmen. Nur wo setze ich jetzt an?
          Frustrierte Grüße
          Wolfgang
          • W WolfgangFB
            @matze-dev
            Hallo
                       man:wmbusmeters(1)
            Frustrierte Grüße
            Wolfgang
            @wolfgangfb sagte in Adapter WM-Bus / Kampstrup Multical 21:
            Das Paket mosquito kommt für Debian Stretch. Das ist aber eine Version die ihr Lebensende seit einem Jahr überschritten hat. Vielleicht falsche Quelle angelegt, vielleicht das Ableben verpasst... Jedenfalls sollte man Stretch beerdigen.
            Die installierte Version sieht man u.a. mit
            lsb_release -a
            Für aktuelle Releases kommt mosquito aber ohnehin aus den Standard-Repos:
            echad@chet:~ $ apt policy mosquitto
            mosquitto:
              Installiert:           (keine)
              Installationskandidat: 2.0.11-1
              Versionstabelle:
                 2.0.11-1 500
            echad@chet:~ $
            Die ganze Anleitung zur Installation (aus dem Jahre des Herren 2013?) sollte also ohnehin nicht mehr erforderlich sein.
              lsb_release -a
              mosquitto:
                Versionstabelle:
                   2.0.11-1 500
              echad@chet:~ $
              W Offline
              W Offline
              WolfgangFB
              OK, ich habe also
              pi@raspberrypi4:~ $ lsb_release -a
              No LSB modules are available.
              Distributor ID: Raspbian
              Description:    Raspbian GNU/Linux 10 (buster)
              Release:        10
              Codename:       buster
              was wohl der Nachfolger von stretch ist.
              pi@raspberrypi4:~ $ apt policy mosquitto
              mosquitto:
                Installiert:           2.0.11-0mosquitto1~stretch1
                Installationskandidat: 2.0.11-0mosquitto1~stretch1
                Versionstabelle:
               *** 2.0.11-0mosquitto1~stretch1 500
                      500 https://repo.mosquitto.org/debian stretch/main armhf Packages
                   2.0.11-0mosquitto1~buster1 500
                      500 https://repo.mosquitto.org/debian buster/main armhf Packages
                   2.0.10-0mosquitto1~stretch1 500
                   2.0.10-0mosquitto1~buster1 500
                   2.0.9-0mosquitto1~stretch1 500
                   2.0.9-0mosquitto1~buster1 500
                   2.0.8-0mosquitto2~stretch1 500
                   2.0.8-0mosquitto2~buster1 500
                   2.0.8-0mosquitto1~stretch1 500
                   2.0.8-0mosquitto1~buster1 500
                   1.6.12-0mosquitto1~stretch1 500
                   1.6.12-0mosquitto1~jessie1 500
                      500 https://repo.mosquitto.org/debian jessie/main armhf Packages
                   1.6.12-0mosquitto1~buster1 500
                   1.6.11-0mosquitto1~stretch1 500
                   1.6.11-0mosquitto1~jessie1 500
                   1.6.11-0mosquitto1~buster1 500
                   1.6.10-0mosquitto1~stretch1 500
                   1.6.10-0mosquitto1~jessie1 500
                   1.6.10-0mosquitto1~buster1 500
                   1.6.8-0mosquitto1~stretch1 500
                   1.6.8-0mosquitto1~jessie1 500
                   1.6.8-0mosquitto1~buster1 500
                   1.6.7-0mosquitto1~stretch1 500
                   1.6.7-0mosquitto1~jessie1 500
                   1.6.7-0mosquitto1~buster1 500
                   1.6.6-0mosquitto1~stretch1 500
                   1.6.6-0mosquitto1~jessie1 500
                   1.6.6-0mosquitto1~buster1 500
                   1.6.4-0mosquitto1~stretch1 500
                   1.6.4-0mosquitto1~jessie1 500
                   1.6.4-0mosquitto1~buster1 500
                   1.6.3-0mosquitto1~stretch1 500
                   1.6.3-0mosquitto1~jessie1 500
                   1.6.3-0mosquitto1~buster1 500
                   1.6.2-0mosquitto1 500
                   1.6.2-0mosquitto1~jessie1 500
                   1.6.2-0mosquitto1~buster1 500
                   1.6.1-0mosquitto1 500
                   1.6.1-0mosquitto1~jessie1 500
                   1.6.1-0mosquitto1~buster1 500
                   1.5.8-0mosquitto1 500
                   1.5.8-0mosquitto1~jessie1 500
                   1.5.7-1+deb10u1 500
                   1.5.6-0mosquitto1 500
                   1.5.6-0mosquitto1~jessie1 500
                   1.5.5-0mosquitto1 500
                   1.5.5-0mosquitto1~jessie1 500
                   1.5.4-0mosquitto2 500
                   1.5.4-0mosquitto2~jessie1 500
                   1.5.4-0mosquitto1 500
                   1.5.4-0mosquitto1~jessie1 500
                   1.5.3-0mosquitto1 500
                   1.5.3-0mosquitto1~jessie1 500
                   1.5-0mosquitto2 500
                   1.5-0mosquitto2~jessie1 500
                   1.4.15-0mosquitto4 500
                   1.4.15-0mosquitto4~jessie1 500
              N: Datei »mosquitto-stretch.list.2« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
              N: Datei »mosquitto-jessie.list.1« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
              N: Datei »mosquitto-stretch.list.1« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
              p
              Ist das jetzt gut oder schlecht?
              Bleibt aber immer noch die frage, warum ich absolut keine Daten von der Wasseruhr sehe (darum geht es mir ja im Endeffekt).
              Gruß Wolfgang
              • W WolfgangFB
                OK, ich habe also
                Release:        10
                Codename:       buster
                mosquitto:
                  Versionstabelle:
                     1.5.7-1+deb10u1 500
                     1.5-0mosquitto2 500
                p
                Gruß Wolfgang
                @wolfgangfb
                Die Quelle zu Stretch muss entfernt werden.
                Vermutlich so:
                sudo rm /etc/apt/sources.list.d/mosquitto-stretch.list
                sudo apt update
                sudo apt install mosquitto=2.0.11-0mosquitto1~buster1
                  @wolfgangfb
                  Vermutlich so:
                  sudo apt update
                  W Offline
                  W Offline
                  WolfgangFB
                  pi@raspberrypi4:/etc/apt/sources.list.d $ sudo apt install mosquitto=2.0.11-0mosquitto1~buster1
                  Die folgenden zusätzlichen Pakete werden installiert:
                    libcjson1 libmosquitto1
                  Die folgenden NEUEN Pakete werden installiert:
                  Die folgenden Pakete werden durch eine ÄLTERE VERSION ERSETZT (Downgrade):
                    mosquitto
                  0 aktualisiert, 2 neu installiert, 1 durch eine ältere Version ersetzt, 0 zu entfernen und 84 nicht aktualisiert.
                  Es müssen 331 kB an Archiven heruntergeladen werden.
                  Nach dieser Operation werden 350 kB Plattenplatz zusätzlich benutzt.
                  Möchten Sie fortfahren? [J/n] J
                  Holen:1 https://repo.mosquitto.org/debian buster/main armhf libmosquitto1 armhf 2.0.11-0mosquitto1~buster1 [81,0 kB]
                  Holen:2 https://repo.mosquitto.org/debian buster/main armhf mosquitto armhf 2.0.11-0mosquitto1~buster1 [232 kB]
                  Holen:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcjson1 armhf 1.7.10-1.1+deb10u1 [18,6 kB]
                  Es wurden 331 kB in 1 s geholt (271 kB/s).
                  Vormals nicht ausgewähltes Paket libcjson1:armhf wird gewählt.
                  (Lese Datenbank ... 107608 Dateien und Verzeichnisse sind derzeit installiert.)
                  Vorbereitung zum Entpacken von .../libcjson1_1.7.10-1.1+deb10u1_armhf.deb ...
                  Entpacken von libcjson1:armhf (1.7.10-1.1+deb10u1) ...
                  Vormals nicht ausgewähltes Paket libmosquitto1:armhf wird gewählt.
                  Vorbereitung zum Entpacken von .../libmosquitto1_2.0.11-0mosquitto1~buster1_armhf.deb ...
                  Entpacken von libmosquitto1:armhf (2.0.11-0mosquitto1~buster1) ...
                  dpkg: Warnung: Version 2.0.11-0mosquitto1~stretch1 des Paketes mosquitto wird durch ältere Version 2.0.11-0mosquitto1~buster1 ersetzt
                  Vorbereitung zum Entpacken von .../mosquitto_2.0.11-0mosquitto1~buster1_armhf.deb ...
                  Entpacken von mosquitto (2.0.11-0mosquitto1~buster1) über (2.0.11-0mosquitto1~stretch1) ...
                  libmosquitto1:armhf (2.0.11-0mosquitto1~buster1) wird eingerichtet ...
                  libcjson1:armhf (1.7.10-1.1+deb10u1) wird eingerichtet ...
                  mosquitto (2.0.11-0mosquitto1~buster1) wird eingerichtet ...
                  Trigger für systemd (241-7~deb10u7+rpi1) werden verarbeitet ...
                  Trigger für man-db (2.8.5-2) werden verarbeitet ...
                  Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                  pi@raspberrypi4:/etc/apt/sources.list.d $ apt policy mosquitto
                  mosquitto:
                    Installiert:           2.0.11-0mosquitto1~buster1
                    Installationskandidat: 2.0.11-0mosquitto1~buster1
                    Versionstabelle:
                   *** 2.0.11-0mosquitto1~buster1 500
                       1.5.7-1+deb10u1 500
                  sieht zumindest mal "grüner" aus. Was kommt als nächstes?
                  • W WolfgangFB
                      mosquitto
                    mosquitto:
                      Versionstabelle:
                         1.5.7-1+deb10u1 500
                    @wolfgangfb
                    Mal neu gestartet?
                    Ich bin aber im Weiteren raus, von mosquito hab ich keine Ahnung.
                    Jedenfalls ist die Installation jetzt sauber.
                      matze-dev
                      schrieb am zuletzt editiert von matze-dev
                      wenn jetzt mosquitto läuft, übergibt der Treiber mittels des konfigurierten Befehls:
                      in der Datei /etc/wmbusmeters.conf
                      shell=/usr/local/bin/mosquitto_pub -d -h localhost -t wmbusmeters/$METER_ID -m "$METER_JSON"
                      die Daten an den mosquitto.
                      Jetzt muss im iobroker der MQTT Broker/Client installiert werden.
                      1. die Webseite des iobroker öffnen (ist auf Port 8081).
                      2. dann auf Adapter gehen
                      3. MQTT Broker/Client auswählen und dann auf das +-Zeichen den Adapter hinzufügen.
                      4. Adapter-Konfiguration (der muss jetzt als Server/Broker laufen):
                      Danach braucht es noch folgende Adapter:
                      History
                      JS Script Engine
                      BackITUp
                      Flot Charts
                      Visualisation
                      Die einfach auch so, wie oben beschrieben, als Adapter dazufügen.
                      • M matze-dev
                        History
                        JS Script Engine
                        BackITUp
                        Flot Charts
                        Visualisation
                        @matze-dev sagte in Adapter WM-Bus / Kampstrup Multical 21:
                        Höchstwahrscheinlich der falsche Pfad. In /usr/local/bin sollte das nicht liegen
                        • W Offline
                          W Offline
                          WolfgangFB
                          Bei mir ist der Wurm drin :-(
                          Zuerst habe ich den MQTT Broker/Clinet installiert. Die Bilder sahen bei mir genauso aus wie bei matze-dev, aber der Adapter blieb auf gelb und es wurden keine Datenpunkte angelegt.
                          Ich habe den Raspberry neu gestartet (Thomas Braun: Mal neu gestartet?)
                          sudo reboot
                          danach (wie immer nach einem reboot) " Cannot find view "system" for search "host".
                          Gemäß Anleitung den letzten regulären Zustand aus den Backups wiederhergestellt.
                          pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ iobroker start
                          pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ iobroker status
                          Objects type: file
                          States  type: file
                          No connection to databases possible ...
                          pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ iobroker stop
                          iobroker is not running on this host.
                          Objects type: file
                          States  type: file
                          /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674
                                          res.forEach(aliveState => {
                          TypeError: Cannot read property 'forEach' of undefined
                              at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2674:21)
                              at processImmediate (internal/timers.js:463:21)
                          Was habe ich jetzt schon wieder falsch gemacht?
                          • W WolfgangFB
                            sudo reboot
                            Objects type: file
                            States  type: file
                            Objects type: file
                            States  type: file
                            W Offline
                            W Offline
                            WolfgangFB
                            @wolfgangfb
                            Nach diversen Neustarts läuft der IO-Broker (zum Glück) wieder).
                            Was mich stutzig macht ist:
                            pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ mosquitto
                            1626002431: mosquitto version 2.0.11 starting
                            1626002431: Using default config.
                            1626002431: Starting in local only mode. Connections will only be possible from clients running on this machine.
                            1626002431: Create a configuration file which defines a listener to allow remote access.
                            1626002431: For more details see https://mosquitto.org/documentation/authentication-methods/
                            1626002431: Opening ipv4 listen socket on port 1883.
                            1626002431: Error: Address already in use
                            1626002431: Opening ipv6 listen socket on port 1883.
                            Das klingt für mich als ob ein anderer Dienst auf dem gleichen Rechner auf Port 1883 etwas macht.
                            pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ netstat -a | grep 1883
                            tcp        0      0 localhost:1883          0.0.0.0:*               LISTEN
                            tcp6       0      0 localhost:1883          [::]:*                  LISTEN
                            außerdem sieht für mich
                            sudo systemctl start wmbusmeters
                            more /var/log/wmbusmeters/wmbusmeters.log
                            [2021-07-11_13:27:40] Started config im871a[00100776] on /dev/ttyUSB0 listening on none
                            (im871a) get config
                            (im871a) got device id 00000000
                            [2021-07-11_13:27:51] Not the expected dongle (dongle said 00000000, you said 00100776!
                            (wmbus) deleted im871a
                            No wmbus device detected, waiting for a device to be plugged in.
                            (shell) exec (capture output) "/bin/pidof"
                            (shell) arg "wmbusmetersd"
                            (shell) output: >>>5672
                            (shell) return code 0
                            (shell) 5728 exited
                            (shell) arg "wmbusmeters"
                            (shell) output: >>><<<
                            (shell) return code 1
                            (shell) 5729 exited
                            (serial) TIMER thread interrupted
                            [2021-07-11_13:27:53] (memory) rss 2924544 peak 2.78 MiB
                            [2021-07-11_13:28:37] Expected im871a on /dev/ttyUSB0 but found unknown instead, ignoring it!
                            (verbose) ignoring device auto
                            nicht gut aus. (ich verstehe das so, dass der Dongle garnicht erkannt wird)
                            • W WolfgangFB
                              @wolfgangfb
                              (im871a) get config
                              (shell) 5728 exited
                              (shell) 5729 exited
                              matze-dev
                              @wolfgangfb Hallo Wolfgang, in der Tat, da sieht nicht so gut aus. Was sagt das Logfile, in das die Werte geschrieben werden? "cat /var/log/wmbusmeters/wmbusmeters.log" - sind die Werte darin OK?
                              • M matze-dev
                                W Offline
                                W Offline
                                WolfgangFB
                                @matze-dev
                                (Ab dem Zeitpunkt, wo der wmbusmaster neu gestartet worden ist)
                                (im871a) get config
                                (shell) 5728 exited
                                (shell) 5729 exited
                                • W WolfgangFB
                                  @matze-dev
                                  (im871a) get config
                                  (shell) 5728 exited
                                  (shell) 5729 exited
                                  W Offline
                                  W Offline
                                  WolfgangFB
                                  @wolfgangfb
                                  Ich dachte ich probiere das ganze nochmal parallel auf einer jungfräulichen SD Karte.
                                  Also mit Imager ein neues Image gezogen, auf die SD Karte geschrieben.
                                  Läuft soweit.
                                  pi@raspberrypi:~ $ lsb_release -a
                                  Release:        10
                                  Codename:       buster
                                  pi@raspberrypi:~ $
                                  pi@raspberrypi:~ $ sudo apt-get install mosquitto
                                  ist auch ohne Fehlermeldung durchgelaufen.
                                  Jetzt zur Frage, wie ich den wmbusmeters richtig installiere und konfiguriere (ich möchte mir das für mich idiotensicher aufschreiben weil ich das bestimmt noch öfter brauche und beim letzten mal etliche Versuche gebraucht habe.
                                  Ich habe es mal mit der Anleitung von
                                  https://snapcraft.io/install/wmbusmeters/raspbian
                                  probiert
                                  sudo apt update
                                  sudo apt install snapd
                                  pi@raspberrypi:~ $ sudo snap install core
                                  2021-07-11T20:43:45+02:00 INFO Waiting for restart...
                                  core 16-2.51.1 from Canonical✓ installed
                                  Channel latest/stable for core is closed; temporarily forwarding to stable.
                                  pi@raspberrypi:~ $ sudo snap install wmbusmeters
                                  wmbusmeters 1.3.0 from Fredrik Öhrström (oehrstroem) installed
                                  pi@raspberrypi:~ $
                                  Dummerweise gibt es aber jetzt kein Verzeichnis /etc/wmbusmeters
                                  Also: An dieser Stelle der erste Stolperstein. Wie installiere ich den wmbusmeters richtig?
                                  Soll der als daemon oder als service laufen?
                                  • W WolfgangFB
                                    @wolfgangfb
                                    Läuft soweit.
                                    Release:        10
                                    Codename:       buster
                                    pi@raspberrypi:~ $
                                    probiert
                                    sudo apt update
                                    pi@raspberrypi:~ $
                                    @wolfgangfb Warum hantierst du da mit snap rum, wenn du mosquitto doch schon via apt installiert hast? Jetzt hast du das doppelt installiert, fürchte ich.
                                      W Offline
                                      W Offline
                                      WolfgangFB
                                      schrieb am zuletzt editiert von WolfgangFB
                                      Ich habe nach einer idiotensicheren Möglichkeit den busmeter zu installieren gesucht und google lieferte mir
                                      https://snapcraft.io/install/wmbusmeters/raspbian#install
                                      Die Anleitung habe ich so verstanden, dass man damit ein Werkzeug zum installieren von busmeters installiert (snap) und dann mit dem Befehl
                                      zum gewünschten Erfolg kommt.
                                      Für mich klang/klingt das so, als ob snap etwas ähnliches wie apt-get ist War wohl nichts, aber: wie geht es richtig?
                                      Ist snap etwas das automatisch mosquitto installiert oder warum habe ich das jetzt doppelt?
                                      Die Github Seite, auf die matze-dev verweist
                                      gibt auch den "snap" als Installationsmöglichkeit an.
                                      • W WolfgangFB
                                        @wolfgangfb
                                        Was denkst du passiert wenn man install angibt und das ganze ohne Fehlermeldung durchläuft?
                                        snap ist eine andere Methode Pakete zu installieren.
                                        Wird gerne für Entwicklerversionen verwendet, das ganze läuft dann in einer Art Sandbox ab. Auf dem Raspberry würde ich aber immer die vorgesehene Methode via apt bevorzugen. Viele Paketmanager verderben das System. Insbesondere wenn da auf Verdacht irgendwie irgendwas ins System gedübelt wird.
                                          @wolfgangfb
                                          W Offline
                                          W Offline
                                          WolfgangFB
                                          @thomas-braun said in Adapter WM-Bus / Kampstrup Multical 21:
                                          @wolfgangfb
                                          Ich denke, dass man damit mosquitto installiert
                                          ich habe auch auf Verdacht
                                          sudo apt-get install wmbusmeters
                                          probiert,das hat aber nicht funktioniert, ich weiß aber immer noch nicht, was
                                          mit einer doppelten Installation von mosquitto zu tun hat (es geht einmal um mosquitto, das ich installieren konnte und einmal um wmbusmeter das ich bisher nicht installieren konnte)
                                          Thomas BraunT M 2 Antworten Letzte Antwort
