  4. Meteoalarm 1.2.0 - Unwetterwarnungen
23 Beiträge 5 Kommentatoren 3.2k Aufrufe 7 Beobachtet
  • sigi234S sigi234
    @jackblackson
    Hallo, kann man das abstellen, bzw auf Warn umstellen?
    meteoalarm.1
    2021-06-21 08:39:09.471	error	Error ETIMEOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.0
    2021-06-21 08:36:09.583	error	Error ETIMEOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.5
    2021-06-21 08:34:09.510	error	Error ETIMEOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.4
    2021-06-21 08:32:09.509	error	Error ESOCKETTIMEDOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.3
    2021-06-21 08:30:09.678	error	Error ETIMEOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.2
    2021-06-21 08:28:09.438	error	Error ETIMEOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.5
    2021-06-21 08:17:12.572	error	Error ESOCKETTIMEDOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.4
    2021-06-21 08:16:09.366	error	Error ETIMEOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.3
    2021-06-21 08:15:09.483	error	Error ETIMEOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.1
    2021-06-21 08:13:10.439	error	Error ESOCKETTIMEDOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    meteoalarm.0
    2021-06-21 08:12:09.412	error	Error ETIMEOUT: No website response after 8 seconds. Adapter will try again at next scheduled run.
    jackblacksonJ Offline
    jackblackson
    schrieb am zuletzt editiert von jackblackson
    @sigi234 Leider wurde (aus meiner Sicht ziemlich kurzfristig) die Website deaktiviert, da sie auf eine neue umgestellt haben (meteoalarm.org). Ich bin gerade dran, den Adapter zu aktualisieren. Eigentlich wurde mir am Freitag gesagt, das es erst im Lauf dieser Woche, oder bis Ende Juni passiert - in em Fall haben sie es jetzt vorgezogen. Hoffe so bald wie möglich ein Update bereistellen zu können. Es wurde jedoch einiges umgestellt.
    PS: Aber das auf Warn umzustellen ist generel natürlich eine gute Idee, werd ich machen.
    Salzer MichaelS 1 Antwort Letzte Antwort
    • jackblacksonJ jackblackson
      Salzer MichaelS Offline
      Salzer Michael
      @jackblackson
      Hallo
      Vielen Dank für den Adapter
      Wie ist der Update Stand wegen neuer Meteoseite
      2.0.0 ist jetzt aktuell zu verwenden
      Datenpunkte haben sich geändert zb heute ,tomorrow gibts nicht mehr ?
      • Salzer MichaelS Salzer Michael
        @jackblackson
        Hallo
        sigi234S Online
        sigi234S Online
        @salzer-michael
        https://forum.iobroker.net/topic/46184/test-adapter-meteoalarm-v2-0-x?_=1625650500334
        • Salzer MichaelS Offline
          Salzer Michael
          Hello
          Danke ,hab versucht das umzusetzen und dein meteo als vorlage zu nehmen.
          dp
          Beginn : {meteoalarm.1.alarms.Alarm 1.effective}
          kommt so
          Beginn : 2021-07-07T00:00:00+02:00
          Eine Idee wie das auf "Startzeit formatieren kann als 07.07.2021 02:00
          Lieben dank
            Hello
            dp
            kommt so
            Lieben dank
            sigi234S Online
            sigi234S Online
            @salzer-michael sagte in Meteoalarm 1.2.0 - Unwetterwarnungen:
            Hello
            dp
            kommt so
            Lieben dank
            Widget:
            [{"tpl":"tplValueTimestamp","data":{"oid":"meteoalarm.1.alarms.Alarm 1.effective","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"format_date":"DD.MM.YYYY hh:mm","html_append":"","show_interval":false},"style":{"left":"1001px","top":"151px","width":"249px","height":"22px"},"widgetSet":"basic"}]
              Salzer Michael
              schrieb am zuletzt editiert von Salzer Michael
              @sigi234
              hmm
              Das widget zeigt dann aber den "zeitstempel wo der datenpunkt aktualisiert wurde und nicht das start datum
              wenn im binding
              Beginn : {meteoalarm.1.alarms.Alarm 1.effective;date(DD.MM.YY hh:mm)}
              kommt in vis editor zwar "undefined" aber im browser start zeit nur halt ohne die 2 stunden "offset" oder wie auch immer das zu bezeichnen wäre.
              idde warum oder wie die zwei stunden dazu rechnen könnt oder in deinem widget das start datum bekomm ?
              hmm
              denk
              denk
              denk
              Ich glaube das hat sich erledigt
              wenn richtig versteh
              datum im dp beduetet Starzteit des alarms z.B.: 07.07.2021 00:00 +2. Dabei bedeuten +2 zu UTZ Timezone.
              Heißt ich kann das mit Datum Format im Binding verwenden.
                @sigi234
                hmm
                wenn im binding
                hmm
                denk
                denk
                denk
                Salzer Michael
                @sigi234
                Grummel
                Schön das das jetz ginge.
                Aber Heute und Morgen geht so nicht mehr
                beim aktualisieren im Meteoalarm schreibt er jetzt datenpunkte alarm1,alarm2,alarm3,alarm4 sortiert nach wann der alarm aktualisiert wurde und keine sortierung für nächsten tag gefunden hab.
                Passt du deine VIS an oder bin gezwungen das selber auszustudieren ?
                sigi234S da_WoodyD 3 Antworten Letzte Antwort
                  @sigi234
                  Grummel
                  sigi234S Online
                  sigi234S Online
                  @salzer-michael
                  @jackblackson sagte in Test Adapter Meteoalarm v2.0.x:
                  So - die v2.0.0 ist mal im Latest, da die alte Website nun scheinbar wirklich deaktiviert wird. Ich werde natürlich weiter an den noch bekannten Themen wie Sortierung usw. arbeiten. Mal schauen was hier noch an Problemen auftauchen, bevor es ins Finetuning geht. Ist doch mehr Aufwand wie gedacht, so ein einfacher "Wetteradapter" ;)
                    @sigi234
                    Grummel
                    sigi234S Online
                    sigi234S Online
                    Hier mal die aktuelle Vis, aber noch nicht fertig.
                    VIEW_Meteoalarm_Inventwo_sigi234.txt
                      @sigi234
                      Grummel
                      da_WoodyD Offline
                      da_WoodyD Offline
                      @salzer-michael wenn du in dem anderen, verlinkten thread lesen würdest, dann würdest du dir leichter tun. da sind schon jede menge erklärungen.
                        Salzer Michael
                        @da_woody
                        sorry hab wohl beim suche nach Meteoalarm übersehen das 2.0.0 schon gibt.
                        Aber Danke für den Hinweis
                          Aktuelle Test Version 1.2.0 (inzwischen wird Version 2.0 getestet - Link**)
                          Veröffentlichungsdatum 23.05.2021
                          Github Link https://github.com/jack-blackson/ioBroker.meteoalarm
                          In der neuen Version habe ich versucht, das HTML Widget etwas zu verbessern. Dieses ist nun in den Einstellungen des Adapters konfigurierbar:
                          • Man kann zwischen schwarzen und weißen Symbolen wechseln
                          • Die jeweiligen Farben für die unterschiedlichen Warnstufen können selbst definiert werden
                          • Die Symbole im HTML Widget können deaktiviert werden - wenn man z.B. die Symbole als eigenes Widget größer anzeigen will
                          Es wurden generell neue Symbole eingeführt - in höherer Auflösung, und als png mit transparentem Hintergrund.
                          Ich würde mich über ein Feedback freuen, ob euch diese Features helfen, bzw. ob noch etwas fehlt.
                          Die Version ist auch bereits im Latest verfügbar.
                          sigi234S Online
                          sigi234S Online
                          @jackblackson
                          Ich würde im 1 Beitrag auf die
                          neue Version hinweisen.
