  4. Backup / Restore von Raspberry Pi auf Synology [gelöst]
46 Beiträge 6 Kommentatoren 6.3k Aufrufe 5 Beobachtet
  • Z ZoXx
    2021-07-07 10:44:52.428  - info: host.IoBroker-copy iobroker.js-controller version 3.2.16 js-controller starting
    2021-07-07 10:44:52.440  - info: host.IoBroker-copy Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-07-07 10:44:52.441  - info: host.IoBroker-copy hostname: IoBroker-copy, node: v12.22.1
    2021-07-07 10:44:52.443  - info: host.IoBroker-copy ip addresses: 172.17.0.6
    2021-07-07 10:44:53.034  - info: host.IoBroker-copy connected to Objects and States
    2021-07-07 10:44:53.080  - info: host.IoBroker-copy added notifications configuration of host
    2021-07-07 10:44:53.736  - info: host.IoBroker-copy 4 instances found
    2021-07-07 10:44:53.766  - info: host.IoBroker-copy starting 4 instances
    2021-07-07 10:44:53.839  - info: host.IoBroker-copy instance system.adapter.admin.0 started with pid 109
    2021-07-07 10:44:56.903  - info: admin.0 (109) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
    2021-07-07 10:44:56.973  - info: admin.0 (109) requesting all states
    2021-07-07 10:44:56.974  - info: admin.0 (109) requesting all objects
    2021-07-07 10:44:57.466  - info: admin.0 (109) received all objects
    2021-07-07 10:44:57.638  - info: admin.0 (109) http server listening on port 8081
    2021-07-07 10:44:57.824  - info: host.IoBroker-copy instance system.adapter.discovery.0 started with pid 124
    2021-07-07 10:44:57.639  - info: admin.0 (109) Use link "http://localhost:8081" to configure.
    2021-07-07 10:45:00.634  - info: discovery.0 (124) starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
    2021-07-07 10:45:01.808  - info: host.IoBroker-copy instance system.adapter.info.0 started with pid 151
    2021-07-07 10:45:05.807  - info: host.IoBroker-copy instance system.adapter.backitup.0 started with pid 170
    2021-07-07 10:45:07.211  - info: info.0 (151) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
    2021-07-07 10:45:13.991  - info: backitup.0 (170) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
    2021-07-07 10:45:14.132  - info: backitup.0 (170) [iobroker] backup was activated at 02:40 every 1 day(s)
    Beim start steht, dass iobroker gestoppt und neu gestartedt wird.
    Als nächstes wird mit der Wiederherstellung begonnen.
    @zoxx sagte in Backup / Restore von Raspberry Pi auf Synology:
    ich sehe nur dass backitup gestartet wird und der schedule für das Backup auf 2:40 jeden Tag eingestellt ist.
    was sagt iobroker list instances?
    Z 2 Antworten Letzte Antwort
      Z
      Z
      ZoXx
      @homoran said in Backup / Restore von Raspberry Pi auf Synology:
      genau. Das sehe ich in den Logs auch immer wieder.
      Wie führe ich den Befehl wo aus?
      • Z ZoXx
        in der Konsole (puTTY), da wo du auch ioBroker installiert hast
        Z 1 Antwort Letzte Antwort
          Z
          Z
          ZoXx
          ist über das GUI Docker von Synology installiert.
          • Z ZoXx
            aber auf dem Pi hattest du doch mit puTTY gearbeitet, dann muss das hier doch auch gehen.
            kenne mich mit Docker nicht aus
              Z
              Z
              ZoXx
              schrieb am zuletzt editiert von ZoXx
              Genau, da läuft das System aber direkt so installiert.
              Ich bin dort auch Neuling, muss mich in den Docker einloggen und dann schauen, Der meckert aber noch bei Synology immer, wenn ich da rein möchte.
                Z
                Z
                ZoXx
                + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
                + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
                + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
                + instance is alive
                wendy2702W HomoranH 2 Antworten Letzte Antwort
                • Z ZoXx
                  + instance is alive
                  wendy2702W
                  wendy2702W
                  @zoxx Und wie genau hast du das restore gemacht?
                  Weil davon steht ja nichts im log.
                  • Z
                    Z
                    ZoXx
                    @wendy2702 said in Backup / Restore von Raspberry Pi auf Synology:
                    ich habe den restore über backitup angestoßen
                    • Z ZoXx
                      + instance is alive
                      @zoxx Geht doch ;-)
                      dann hat backitup auch wirklich noch nichts gemacht.
                      Bitte ioBroker neu starten, backitup unter Instanzen im Expertenmodus auf Logstufe debug stellen, dann nochmal den restore anstoßen und das debug log posten
                        @zoxx Geht doch ;-)
                        Z
                        Z
                        ZoXx
                        @zoxx Geht doch ;-)
                        backitup.0	2021-07-07 12:23:37.169	debug	(629) sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0
                        backitup.0	2021-07-07 12:23:37.125	debug	(629) set chmod for "/opt/iobroker/backups" successfully
                        backitup.0	2021-07-07 12:23:32.452	debug	(629) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                        backitup.0	2021-07-07 12:23:30.446	debug	(629) Backup list be read ...
                        backitup.0	2021-07-07 12:23:26.827	debug	(629) telegram-instance: telegram.0
                        backitup.0	2021-07-07 12:23:25.157	debug	(629) No backup file was found
                        backitup.0	2021-07-07 12:23:25.079	info	(629) [iobroker] backup was activated at 02:40 every 1 day(s)
                        backitup.0	2021-07-07 12:23:24.934	info	(629) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
                        backitup.0	2021-07-07 12:23:24.563	debug	(629) Plugin sentry Initialize Plugin (enabled=true)
                        backitup.0	2021-07-07 12:23:24.106	debug	(629) statesDB connected
                        backitup.0	2021-07-07 12:23:24.105	debug	(629) States connected to redis: 127.0.0.1:9000
                        backitup.0	2021-07-07 12:23:24.046	debug	(629) States create User PubSub Client
                        backitup.0	2021-07-07 12:23:24.043	debug	(629) States create System PubSub Client
                        backitup.0	2021-07-07 12:23:24.030	debug	(629) Redis States: Use Redis connection: 127.0.0.1:9000
                        backitup.0	2021-07-07 12:23:24.026	debug	(629) objectDB connected
                        backitup.0	2021-07-07 12:23:24.011	debug	(629) Objects connected to redis: 127.0.0.1:9001
                        backitup.0	2021-07-07 12:23:23.989	debug	(629) Objects client initialize lua scripts
                        backitup.0	2021-07-07 12:23:23.987	debug	(629) Objects create User PubSub Client
                        backitup.0	2021-07-07 12:23:23.985	debug	(629) Objects create System PubSub Client
                        backitup.0	2021-07-07 12:23:23.981	debug	(629) Objects client ready ... initialize now
                        backitup.0	2021-07-07 12:23:23.920	debug	(629) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        backitup.0	2021-07-07 12:23:17.437	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.436	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.434	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.429	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.428	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.427	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.426	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.425	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.424	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.414	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.411	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.410	warn	(614) get state error: Connection is closed.
                        backitup.0	2021-07-07 12:23:17.394	warn	(614) redis get backitup.0.history.iobrokerLastTime, error - Connection is closed.
                        backitup.0	2021-07-07 12:23:17.393	warn	(614) redis get backitup.0.history.html, error - Connection is closed.
                        backitup.0	2021-07-07 12:23:17.392	warn	(614) redis get backitup.0.history.json, error - Connection is closed.
                        backitup.0	2021-07-07 12:23:17.391	warn	(614) redis get backitup.0.history.iobrokerSuccess, error - Connection is closed.
                        backitup.0	2021-07-07 12:23:17.390	warn	(614) redis get backitup.0.history.ccuSuccess, error - Connection is closed.
                        backitup.0	2021-07-07 12:23:17.389	warn	(614) redis get backitup.0.oneClick.ccu, error - Connection is closed.
                        backitup.0	2021-07-07 12:23:17.388	warn	(614) redis get backitup.0.oneClick.iobroker, error - Connection is closed.
                        backitup.0	2021-07-07 12:23:17.388	warn	(614) redis get backitup.0.history.ccuLastTime, error - Connection is closed.
                        backitup.0	2021-07-07 12:23:17.383	debug	(614) No backup file was found
                        backitup.0	2021-07-07 12:23:17.309	info	(614) [iobroker] backup was activated at 02:40 every 1 day(s)
                        backitup.0	2021-07-07 12:23:17.168	info	(614) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
                        backitup.0	2021-07-07 12:23:16.788	info	(614) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        backitup.0	2021-07-07 12:23:16.787	debug	(614) Plugin sentry destroyed
                        backitup.0	2021-07-07 12:23:16.772	debug	(614) statesDB connected
                        backitup.0	2021-07-07 12:23:16.770	debug	(614) States connected to redis: 127.0.0.1:9000
                        backitup.0	2021-07-07 12:23:16.744	debug	(614) States create User PubSub Client
                        backitup.0	2021-07-07 12:23:16.742	debug	(614) States create System PubSub Client
                        backitup.0	2021-07-07 12:23:16.727	debug	(614) Redis States: Use Redis connection: 127.0.0.1:9000
                        backitup.0	2021-07-07 12:23:16.723	debug	(614) objectDB connected
                        backitup.0	2021-07-07 12:23:16.704	debug	(614) Objects connected to redis: 127.0.0.1:9001
                        backitup.0	2021-07-07 12:23:16.672	debug	(614) Objects client initialize lua scripts
                        backitup.0	2021-07-07 12:23:16.670	debug	(614) Objects create User PubSub Client
                        backitup.0	2021-07-07 12:23:16.668	debug	(614) Objects create System PubSub Client
                        backitup.0	2021-07-07 12:23:16.664	debug	(614) Objects client ready ... initialize now
                        backitup.0	2021-07-07 12:23:16.602	debug	(614) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        backitup.0	2021-07-07 12:23:08.483	info	(171) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        backitup.0	2021-07-07 12:23:08.480	info	(171) terminating
                        backitup.0	2021-07-07 12:23:08.478	info	(171) cleaned everything up...
                        backitup.0	2021-07-07 12:23:08.475	info	(171) Got terminate signal TERMINATE_YOURSELF
                        • Z ZoXx
                          @zoxx Geht doch ;-)
                          was sagt
                          iobroker status
                          EDIT:
                          nee, scheint zu passen
                          aber:
                          also nochmal zum Anfang!
                          @wendy2702 sagte in Backup / Restore von Raspberry Pi auf Synology:
                            was sagt
                            iobroker status
                            EDIT:
                            aber:
                            Z
                            Z
                            ZoXx
                            iobroker status
                            Objects type: file
                            States  type: file
                            • Z ZoXx
                              iobroker status
                              Objects type: file
                              States  type: file
                              @zoxx Danke - hab`s gerade editiert
                              • Z ZoXx
                                iobroker status
                                Objects type: file
                                States  type: file
                                @zoxx lief Redis auf dem RasPi?
                                • wendy2702W
                                  wendy2702W
                                  @Homoran : sieht so aus.
                                  Vorher Redis jetzt File. Denke dem fehlt jetzt Redis.
                                  • wendy2702W wendy2702
                                    sieht so aus.
                                    genau!
                                    @ZoXx
                                    was sagt denn der RasPi bei iobroker status?
                                      sieht so aus.
                                      genau!
                                      @ZoXx
                                      Z
                                      Z
                                      ZoXx
                                      Okay alles klar, Sekunde ich checke es eben.
                                        sieht so aus.
                                        genau!
                                        @ZoXx
                                        Z
                                        Z
                                        ZoXx
                                        @ZoXx
                                        Objects type: file
                                        States  type: file
                                        • Z ZoXx
                                          @ZoXx
                                          Objects type: file
                                          States  type: file
                                          @zoxx Danke!
                                          Dann muss jetzt ein Docker-kundiger ran warum die Verbindung geschlossen wird
                                          84.1k
