  4. Zigbee-Adapter 1.0.2 Danalock
    6.5k
zigbee adapterdanalock
191 Beiträge 13 Kommentatoren 36.1k Aufrufe 15 Beobachtet
  • J Jan1
    @asgothian
    Das stand wohl auf true und wurde nur nicht angezeigt. Ein Wechsel hin und her bringt keine Log Einträge.
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #176
    @jan1 Bist du sicher ? Wenn du es zwei mal mit wahr belegst sollte eine Meldung kommen. Dazu muss es nicht zwischendurch falsch werden.
    A.
    • AsgothianA Asgothian
      A.
      Jan1
      #177
      @asgothian
      Habe jetzt mal auf debug gestellt und zweimal true gesetzt, dann kaommt das im Log:
      2021-06-20 11:35:01.122 - debug: zigbee.0 (45269) handleMessage. {"type":"attributeReport","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5473}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9926}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701118,"_linkquality":99},"endpoint":"[Circular]","data":{"measuredValue":2691},"linkquality":99,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":151,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2021-06-20 11:35:01.126 - debug: zigbee.0 (45269) Received Zigbee message from '0x00158d0001d7347c', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2691}' from endpoint 1 with groupID 0
      2021-06-20 11:35:01.130 - debug: zigbee.0 (45269) Type attributeReport device {"type":"device","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5473}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9926}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701118,"_linkquality":99},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"name":"0x00158d0001d7347c"} incoming event: {"type":"attributeReport","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5473}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9926}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701118,"_linkquality":99},"endpoint":"[Circular]","data":{"measuredValue":2691},"linkquality":99,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":151,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2021-06-20 11:35:01.139 - debug: zigbee.0 (45269) handleMessage. {"type":"attributeReport","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5426}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9926}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701138,"_linkquality":105},"endpoint":"[Circular]","data":{"measuredValue":5426},"linkquality":105,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":152,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2021-06-20 11:35:01.144 - debug: zigbee.0 (45269) handleMessage. {"type":"attributeReport","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5426}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9923}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701143,"_linkquality":105},"endpoint":"[Circular]","data":{"measuredValue":992,"scale":-1,"scaledValue":9923},"linkquality":105,"groupID":0,"cluster":"msPressureMeasurement","meta":{"zclTransactionSequenceNumber":153,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2021-06-20 11:35:01.145 - debug: zigbee.0 (45269) Received Zigbee message from '0x00158d0001d7347c', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":5426}' from endpoint 1 with groupID 0
      2021-06-20 11:35:01.146 - debug: zigbee.0 (45269) Type attributeReport device {"type":"device","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5426}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9923}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701143,"_linkquality":105},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"name":"0x00158d0001d7347c"} incoming event: {"type":"attributeReport","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5426}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9923}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701143,"_linkquality":105},"endpoint":"[Circular]","data":{"measuredValue":5426},"linkquality":105,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":152,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2021-06-20 11:35:01.148 - debug: zigbee.0 (45269) Received Zigbee message from '0x00158d0001d7347c', type 'attributeReport', cluster 'msPressureMeasurement', data '{"measuredValue":992,"scale":-1,"scaledValue":9923}' from endpoint 1 with groupID 0
      2021-06-20 11:35:01.150 - debug: zigbee.0 (45269) Type attributeReport device {"type":"device","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5426}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9923}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701143,"_linkquality":105},"mapped":{"zigbeeModel":["lumi.weather"],"model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"name":"0x00158d0001d7347c"} incoming event: {"type":"attributeReport","device":{"ID":12,"_type":"EndDevice","_ieeeAddr":"0x00158d0001d7347c","_networkAddress":59336,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":770,"inputClusters":[0,3,65535,1026,1027,1029],"outputClusters":[0,4,65535],"deviceNetworkAddress":59336,"deviceIeeeAddress":"0x00158d0001d7347c","clusters":{"genBasic":{"attributes":{"65281":{"1":3025,"4":5032,"5":14,"6":[0,1],"10":0,"100":2694,"101":5496,"102":99290},"modelId":"lumi.weather","manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":30,"dateCode":"20191205","swBuildId":"3000-0001"}},"msTemperatureMeasurement":{"attributes":{"measuredValue":2691}},"msRelativeHumidity":{"attributes":{"measuredValue":5426}},"msPressureMeasurement":{"attributes":{"measuredValue":992,"scale":-1,"scaledValue":9923}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.weather","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":30,"_dateCode":"20191205","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1624181701143,"_linkquality":105},"endpoint":"[Circular]","data":{"measuredValue":992,"scale":-1,"scaledValue":9923},"linkquality":105,"groupID":0,"cluster":"msPressureMeasurement","meta":{"zclTransactionSequenceNumber":153,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2021-06-20 11:35:01.165 - debug: zigbee.0 (45269) Publish {"temperature":26.91} to "00158d0001d7347c"
      2021-06-20 11:35:01.174 - debug: zigbee.0 (45269) Publish {"humidity":54.26} to "00158d0001d7347c"
      2021-06-20 11:35:01.184 - debug: zigbee.0 (45269) Publish {"pressure":992} to "00158d0001d7347c"
      2021-06-20 11:35:12.635 - debug: zigbee.0 (45269) Non-pingable device 0x00158d00030a3270 lumi.sensor_motion.aq2 was last seen '446.939' seconds ago.
      2021-06-20 11:35:12.637 - debug: zigbee.0 (45269) Non-pingable device 0x00158d0002ea07ac lumi.sensor_motion.aq2 was last seen '835.273' seconds ago.
      2021-06-20 11:35:12.638 - debug: zigbee.0 (45269) Non-pingable device 0x00158d0002fd3f30 lumi.sensor_motion.aq2 was last seen '1012.698' seconds ago.
      2021-06-20 11:35:12.639 - debug: zigbee.0 (45269) Non-pingable device 0x00158d00032c1109 lumi.sensor_motion.aq2 was last seen '1630.65' seconds ago.
      2021-06-20 11:35:12.640 - debug: zigbee.0 (45269) Non-pingable device 0x00158d0003667aba lumi.sensor_motion.aq2 was last seen '1373.813' seconds ago.
      2021-06-20 11:35:12.641 - debug: zigbee.0 (45269) Non-pingable device 0x00158d000249a9a8 lumi.sensor_ht was last seen '1103.992' seconds ago.
      2021-06-20 11:35:12.642 - debug: zigbee.0 (45269) Non-pingable device 0x00158d00025562c5 lumi.sensor_ht was last seen '747.354' seconds ago.
      2021-06-20 11:35:12.643 - debug: zigbee.0 (45269) Non-pingable device 0x00158d00023ce458 lumi.sensor_ht was last seen '1481.125' seconds ago.
      2021-06-20 11:35:12.644 - debug: zigbee.0 (45269) Non-pingable device 0x00158d000208dc76 lumi.sensor_ht was last seen '83.342' seconds ago.
      2021-06-20 11:35:12.645 - debug: zigbee.0 (45269) Non-pingable device 0x00158d000588e92c lumi.weather was last seen '425.682' seconds ago.
      2021-06-20 11:35:12.646 - debug: zigbee.0 (45269) Non-pingable device 0x00158d0001d7347c lumi.weather was last seen '11.503' seconds ago.
      2021-06-20 11:35:12.647 - debug: zigbee.0 (45269) Non-pingable device 0xec1bbdfffe972471 TRADFRI on/off switch was last seen '44067.688' seconds ago.
      2021-06-20 11:35:12.648 - debug: zigbee.0 (45269) Non-pingable device 0xccccccfffee04e28 TRADFRI on/off switch was last seen '171333.795' seconds ago.
      2021-06-20 11:35:12.648 - debug: zigbee.0 (45269) Publish available for 0xccccccfffee04e28 = false
      2021-06-20 11:35:12.651 - debug: zigbee.0 (45269) Publish LQ for 0xccccccfffee04e28 = 0
      2021-06-20 11:35:12.655 - debug: zigbee.0 (45269) Non-pingable device 0xec1bbdfffe9734c2 TRADFRI on/off switch was last seen '25035.024' seconds ago.
      2021-06-20 11:35:12.656 - debug: zigbee.0 (45269) Non-pingable device 0xec1bbdfffeb45b50 TRADFRI on/off switch was last seen '331520.53' seconds ago.
      2021-06-20 11:35:12.658 - debug: zigbee.0 (45269) Publish available for 0xec1bbdfffeb45b50 = false
      2021-06-20 11:35:12.661 - debug: zigbee.0 (45269) Publish LQ for 0xec1bbdfffeb45b50 = 0
      2021-06-20 11:35:12.666 - debug: zigbee.0 (45269) Non-pingable device 0x000b57fffe59d1f6 V3-BTZB was last seen '337.406' seconds ago.
      2021-06-20 11:35:13.239 - debug: zigbee.0 (45269) User stateChange zigbee.0.000b57fffe59d1f6.device_query {"val":true,"ack":false,"ts":1624181713234,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1624178530511}
      2021-06-20 11:35:13.249 - debug: zigbee.0 (45269) Change state 'device_query' at device 0x000b57fffe59d1f6 type 'V3-BTZB/V3-BTZBE'
      2021-06-20 11:35:13.256 - debug: zigbee.0 (45269) entity: {"type":"device","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":9620,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":9620,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":172}},"closuresDoorLock":{"attributes":{"lockState":0}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"_configuredReportings":[{"cluster":257,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":62000,"repChange":0}],"meta":{},"pendingRequests":[]}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":923668394},"_lastSeen":1624181375260},"mapped":{"zigbeeModel":["V3-BTZB","V3-BTZBE"],"model":"V3-BTZB/V3-BTZBE","vendor":"Danalock","description":"BT/ZB smartlock","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"},{"type":"enum","name":"lock_state","property":"lock_state","access":1,"values":["not_fully_locked","locked","unlocked"],"description":"Actual state of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59d1f6"}
      2021-06-20 11:35:13.257 - debug: zigbee.0 (45269) Mapped Model: {"zigbeeModel":["V3-BTZB","V3-BTZBE"],"model":"V3-BTZB/V3-BTZBE","vendor":"Danalock","description":"BT/ZB smartlock","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"},{"type":"enum","name":"lock_state","property":"lock_state","access":1,"values":["not_fully_locked","locked","unlocked"],"description":"Actual state of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]}
      2021-06-20 11:35:13.260 - debug: zigbee.0 (45269) Device query for '0x000b57fffe59d1f6' started
      2021-06-20 11:35:16.857 - debug: zigbee.0 (45269) User stateChange zigbee.0.000b57fffe59d1f6.device_query {"val":true,"ack":false,"ts":1624181716851,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1624178530511}
      2021-06-20 11:35:16.865 - debug: zigbee.0 (45269) Change state 'device_query' at device 0x000b57fffe59d1f6 type 'V3-BTZB/V3-BTZBE'
      2021-06-20 11:35:16.869 - debug: zigbee.0 (45269) entity: {"type":"device","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":9620,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":9620,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":172}},"closuresDoorLock":{"attributes":{"lockState":0}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"_configuredReportings":[{"cluster":257,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":62000,"repChange":0}],"meta":{},"pendingRequests":[]}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":923668394},"_lastSeen":1624181375260},"mapped":{"zigbeeModel":["V3-BTZB","V3-BTZBE"],"model":"V3-BTZB/V3-BTZBE","vendor":"Danalock","description":"BT/ZB smartlock","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"},{"type":"enum","name":"lock_state","property":"lock_state","access":1,"values":["not_fully_locked","locked","unlocked"],"description":"Actual state of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x000b57fffe59d1f6"}
      2021-06-20 11:35:16.870 - debug: zigbee.0 (45269) Mapped Model: {"zigbeeModel":["V3-BTZB","V3-BTZBE"],"model":"V3-BTZB/V3-BTZBE","vendor":"Danalock","description":"BT/ZB smartlock","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"},{"type":"enum","name":"lock_state","property":"lock_state","access":1,"values":["not_fully_locked","locked","unlocked"],"description":"Actual state of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]}
      2021-06-20 11:35:16.871 - warn: zigbee.0 (45269) Device query for '0x000b57fffe59d1f6' blocked
      2021-06-20 11:35:17.125 - debug: zigbee.0 (45269) handleMessage. {"type":"readResponse","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":9620,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":9620,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":172}},"closuresDoorLock":{"attributes":{"lockState":0}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"_configuredReportings":[{"cluster":257,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":62000,"repChange":0}],"meta":{},"pendingRequests":[]}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":923668394},"_lastSeen":1624181717120,"_linkquality":54},"endpoint":"[Circular]","data":{"lockState":0},"linkquality":54,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2021-06-20 11:35:17.127 - debug: zigbee.0 (45269) Received Zigbee message from '0x000b57fffe59d1f6', type 'readResponse', cluster 'closuresDoorLock', data '{"lockState":0}' from endpoint 1 with groupID 0
      2021-06-20 11:35:17.129 - debug: zigbee.0 (45269) Type readResponse device {"type":"device","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":9620,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":9620,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":172}},"closuresDoorLock":{"attributes":{"lockState":0}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"_configuredReportings":[{"cluster":257,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":62000,"repChange":0}],"meta":{},"pendingRequests":[]}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":923668394},"_lastSeen":1624181717120,"_linkquality":54},"mapped":{"zigbeeModel":["V3-BTZB","V3-BTZBE"],"model":"V3-BTZB/V3-BTZBE","vendor":"Danalock","description":"BT/ZB smartlock","fromZigbee":[{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":"commandOperationEventNotification"},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]}],"exposes":[{"type":"lock","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"LOCK","value_off":"UNLOCK","description":"State of the lock"},{"type":"enum","name":"lock_state","property":"lock_state","access":1,"values":["not_fully_locked","locked","unlocked"],"description":"Actual state of the lock"}]},{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"name":"0x000b57fffe59d1f6"} incoming event: {"type":"readResponse","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59d1f6","_networkAddress":9620,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":9620,"deviceIeeeAddress":"0x000b57fffe59d1f6","clusters":{"genBasic":{"attributes":{"modelId":"V3-BTZB","manufacturerName":"Danalock","powerSource":3,"zclVersion":2,"appVersion":1,"stackVersion":1,"hwVersion":4,"dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":172}},"closuresDoorLock":{"attributes":{"lockState":0}}},"_binds":[{"cluster":257,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b001ca5fdcf","endpointID":1}],"_configuredReportings":[{"cluster":257,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":62000,"repChange":0}],"meta":{},"pendingRequests":[]}],"_manufacturerName":"Danalock","_powerSource":"Battery","_modelID":"V3-BTZB","_applicationVersion":1,"_stackVersion":1,"_zclVersion":2,"_hardwareVersion":4,"_dateCode":"20200815\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":923668394},"_lastSeen":1624181717120,"_linkquality":54},"endpoint":"[Circular]","data":{"lockState":0},"linkquality":54,"groupID":0,"cluster":"closuresDoorLock","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
      2021-06-20 11:35:17.132 - debug: zigbee.0 (45269) Device query for '0x000b57fffe59d1f6' done
      2021-06-20 11:35:17.148 - debug: zigbee.0 (45269) Publish {"state":"UNLOCK","lock_state":"not_fully_locked"} to "000b57fffe59d1f6"
      Ohne Debug kommt nix im Log.
      • J Jan1
        @asgothian
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #178
        @jan1 sagte in Zigbee-Adapter 1.0.2 Danalock:
        Seltsam. Diese Meldung hätte auch ohne Debug auftauchen müssen.
        Ist auch egal - das Schloss hat offensichtlich keine Option den Status auszulesen - zumindest nicht über den Herdsman.
        Was übrig bleibt ist zu versuchen das reporting wieder zu aktivieren.
        A.
          A.
          Jan1
          #179
          @asgothian
          Wie geschrieben, es funktioniert wie es soll, die paar nice to have Infos die fehlen stören nicht wirklich. Wenn Du das trotzdem wieder zum Laufen bekommst, wäre natürlich das Sahnehäubchen ;)
          • J Jan1
            @asgothian
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #180
            @jan1 Ich werde da auf Deine Hilfe angewiesen sein - ausgehend davon das @smarthomegirl zwar den Fehler gemeldet hat (auch auf Github) sich aber ansonsten nicht an der Lösung beteiligt hat.
            Ich selber habe kein Schloss und kann deswegen nur bedingt ohne Hilfe daran arbeiten.
            A.
              A.
              Jan1
              #181
              @asgothian
              ich bin dabei, was brauchst alles?
              • J Jan1
                @asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #182
                Noch nix. Ich muss mir die Code-Basis erst einmal anschauen. Dann müsstest Du einen Test-Branch von mir installieren bei dem wir versuchen das Schloss zum "reporting" zu überreden. Das kann (auch wegen der Temperaturen) und wegen Besuch kommendes Wochenende ein paar Tage dauern.
                A.
                J Jan PuchtaJ 2 Antworten Letzte Antwort
                  A.
                  Jan1
                  #183
                  @asgothian
                  lass Dir Zeit und kein Stress ;)
                    A.
                    Jan PuchtaJ Offline
                    Jan PuchtaJ Offline
                    Jan Puchta
                    #184
                    @asgothian hallo, hoffe ich störe nicht.
                    habe seit geraumer Zeit das Problem das der Status sich nicht verändert lock_state (Actual state of the lock).
                    Ich kann leider nicht sagen seit wann dieses Problem besteht. (nehme an seit dem neuem Dashboard da ich alles in meinen scripten anpassen musste)
                    Ein neues Pairing brachte kurz Erfolge (am 27.06.2021 letzter automatischer Eintrag), aber jetzt ist das Problem wieder da.
                    Wenn jetzt das Schloss auf oder zu geschlossen wird, ändert sich aber der das lock_state nicht mehr.
                    Über Entwickler lässt sich der Status manuell auslesen.
                    Da mein SmartHome auf diesen lock_state reagiert (da auch manuelles betätigen mit Schlüssel funktionierte), frage ich hiermit was ich machen kann das dies wieder funktioniert.
                    • Jan PuchtaJ Jan Puchta
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #185
                      @jan-puchta sagte in Zigbee-Adapter 1.0.2 Danalock:
                      Welche Adapter version setzt du aktuell ein ?
                      Jan PuchtaJ M 2 Antworten Letzte Antwort
                        Jan PuchtaJ Offline
                        Jan PuchtaJ Offline
                        Jan Puchta
                        #186
                        @asgothian sorry für die späte antwort, es war die 1.5.6 version. habe wieder auf 1.4.4 zurück gewechselt
                          mera
                          #187
                          @asgothian
                          Hi, gibt es hier schon was neues, zum Thema: Statusanzeige Danalock?
                          • M mera
                            @asgothian
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #188
                            @mera
                            Nein, das ist den updateproblemen zum Opfer gefallen.
                            A.
                              @mera
                              A.
                              mera
                              #189
                              @asgothian
                              Also bleibt mir nur die Möglichkeit, in regelmäßigen Abstand oder über ein Türkontakt, ein Trigger auf device_query zu setzen?
                              Somit hätte ich wenigstens den richtigen Status in iobroker wenn jemand das Danalock manuell öffnet/schließt.
                              Ja, schade eigentlich.
                              Vielleicht wird das ja irgendwann wieder funktionieren.
                              Denn zurück auf eine alte Version, möchte ich nicht.
                              Trotzdem,
                              danke und Gruß
                              • M mera
                                @asgothian
                                Trotzdem,
                                danke und Gruß
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #190
                                @mera das problem ist bei mir auf der Liste, aber mit begrenzter Priorität - ich hab kein Schloss um das vollständig durch zu gehen und mal eben 250 Euro ausgeben ist nicht drin.
                                A.
                                  A.
                                  mera
                                  #191
                                  @asgothian
                                  ja das kann ich verstehen.
                                  Ist schon schön zu hören das es vielleicht irgendwann wieder funktionieren könnte.
                                  Einen schönen Abend, wünsche ich noch. :)
