  4. Asterisk bringt "Error while dialing (2). Error: {}"
    6.4k
116 Beiträge 10 Kommentatoren 20.1k Aufrufe 11 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    #92
    So, habe in der sip.conf mal
    [general]				; Do not change
    port = 5060				; Do not change
    bindaddr = 0.0.0.0			; Do not change
    context = default			; Do not change
    subscribecontext = default		; Do not change
    register => iobroker:abcde16@192.168.243.1/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
    [123456789]               		; Change to username of Fritzbox WLAN/LAN telephone
    type = friend			    	; Do not change
    username = 123456789      		; Change to username of Fritzbox WLAN/LAN telephone
    host = 192.168.243.1          		; Change hostname / IP address of Fritzbox
    secret = abcde16         ; Change password of Fritzbox WLAN/LAN telephone
    fromdomain =  192.168.243.1  		; Change hostname / IP address of Fritzbox
    fromuser = 123456789   	  	; Change username of Fritzbox WLAN/LAN telephone
    eingegeben.
    Wenn ich die Instanz neu starte sind man in putty, dass versucht wird eine Verbindung aufzubauen.
    Connected to Asterisk 16.2.1~dfsg-1+deb10u2 currently running on VM-iobroker (pid = 14402)
    [Jun  9 22:05:01] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #9)
      == Manager 'manager' logged off from 192.168.243.12
      == Manager 'manager' logged on from 192.168.243.12
    [Jun  9 22:05:21] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #10)
    [Jun  9 22:05:41] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #11)
    [Jun  9 22:06:01] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #12)
    [Jun  9 22:06:21] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #13)
    [Jun  9 22:06:41] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #14)
    [Jun  9 22:07:01] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #15)
    [Jun  9 22:07:21] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #16)
    [Jun  9 22:07:41] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #17)
    [Jun  9 22:08:01] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #18)
    Und dies klappt wohl nicht.
    Aber warum ?
    Danke.
      boeskij
      schrieb am zuletzt editiert von boeskij
      #93
      @bahnuhr weil der Username noch an weiteren Stellen in der sip.conf steht und natürlich auch in der Fritzbox angepasst werden muss
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #94
        So, mal kurze Rückinfo von mir.
        Ich habe nun alle möglichen Konstellationen probiert.
        Asterisk kann sich wohl nicht an der FB7490 anmelden.
        Für mich ist nun Schluss.
        Ich bekomme dies nicht hin.
        Trotzdem Danke für die Mühe.
        Vielleicht könnte sich ja doch mal der Entwickler dazu bewegen, dass dies vernünftig läuft.
        mfg
        Dieter
        Danke.
        • bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          #95
          Jaaaaaaaaaaaaa.
          Es klappt.
          Habe mehrere threads gelesen und viel gegoogelt.
          Irgendwo hat einer geschrieben, dass man die Fritzbox mal neu starten soll.
          Und dies war die Lösung.
          Lag letztendlich an der FB.
          Aber egal, jetzt läuft es.
          Nochmals danke für die Inputs.
          Danke.
          V 1 Antwort Letzte Antwort
          • bahnuhrB bahnuhr
            Jaaaaaaaaaaaaa.
            Es klappt.
            V Offline
            V Offline
            varg
            schrieb am zuletzt editiert von varg
            #96
            @bahnuhr
            also rein der fritz box neustart hat bei mir nichts gebracht (image backup wurde eingespielt so dass die ursprüngliche Installation und config wieder da war)
            • V varg
              @bahnuhr
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              #97
              @varg sagte in Asterisk bringt "Error while dialing (2). Error: {}":
              @bahnuhr
              Erzeugts du die Datei jetzt auch mit pico2wave ?
              Ich hatte wohl mehrere Probleme:
              • Datei wurde nicht erzeugt : Lösung war pico2wave
                Hier muss der Entwickler dran !
              • Login hatte nicht gepasst: Lösung war manuell Datei sip.conf geändert
              • Fritzbox wollte nicht: Lösung war neustart der FB
              mfg
              Dieter
              Danke.
              stekS 1 Antwort Letzte Antwort
              • bahnuhrB bahnuhr
                @bahnuhr
                mfg
                Dieter
                stekS Offline
                stekS Offline
                stek
                #98
                @bahnuhr
                wie hast du diese problem gelöst.
                bei mir habe ich alles neu istalliert aber ich bekomme immer das Fehler:
                Meine allarmirung hat diese funktion verwendet und jetz funktioniert nicht mehr...
                Ich brauche eine lösung voice meldungen von Iobroker zu senden
                Stefano
                • stekS stek
                  @bahnuhr
                  Stefano
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #99
                  @stek sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                  steht genau 1 Beitrag vor deinem.
                  Danke.
                  • Z Offline
                    Z Offline
                    zaggul
                    #100
                    Wow, ihr seid genial!
                    Ich war zwischenzeitlich aus privaten Gründen hier nicht mehr aktiv und hatte es nicht verfolgt. Mit der Lösung via pico2wave läuft es nun astrein!
                    Merke: Je weniger externe Abhängigkeiten, desto besser ;-)
                    Vielen vielen Dank!
                    • bahnuhrB bahnuhr
                      V Offline
                      V Offline
                      varg
                      #101
                      @bahnuhr
                      hantiere hier gerade mit einem testsystem rum. zeilen hab ich ausgeklammert. connected to manager passt auch ohne error.
                      Nur dann will er bei der nummer string. Steh ich auf dem Schlauch ?
                      Plattform: linux
                      RAM: 1.8 GB
                      Node.js: v14.17.1
                      NPM: 6.14.13
                      Admin ist die neueste beta
                      host ist 3.3.12
                      sterisk.0	2021-06-19 05:36:43.988	info	(948) State value to set for "asterisk.0.dialout.telnr" has to be type "string" but received type "number"
                      • B boeskij
                        @bahnuhr
                        Hoffe das hier hilft:
                        let msg = "Dieser Text wird vorgelesen."
                        exec('pico2wave -w /tmp/ttsdatei.wav -l de-DE "' + msg + '"', function (error, stdout, stderr) {
                                                /* wav erstellt */
                                                exec('sox /tmp/ttsdatei.wav -r 8000 -c 1 /tmp/ttsdatei.gsm', function (error, stdout, stderr) {
                                                    /* gsm erstellt */
                                                    exec('rm /tmp/ttsdatei.wav', function (error, stdout, stderr) {
                                                        /* wav gelöscht, sonst wurde beim folgenden Anruf ggf. die falsche Datei aufgerufen... */
                                                            sendTo('asterisk.0', "dial", { telnr: callNumber, callerid: callerId, audiofile: '/tmp/ttsdatei.gsm'},  (res) => {
        console.log('Result: ' + JSON.stringify(res));
        exec('cp /tmp/ttsdatei.gsm /tmp/asterisk_dtmf.gsm', function (error, stdout, stderr) {
        /* Die asterisk_dtmf.gsm wird für Dial-In Anrufe verwendet... Hier wird dann einfach der letzte Anruf nochmal wiedergegeben */
        /* Das folgende Löschen führte bei mir zu Problemen, also bleibt die Datei liegen.. wird ja eh überschrieben */
        /* exec('rm /tmp/ttsdatei.gsm', function (error, stdout, stderr) { console.log('Telefonalamierung: gsm gelöscht'); }); */
                        stekS Offline
                        stekS Offline
                        stek
                        #102
                        @boeskij
                        Das Einfügen dieses Codes (und die Installation von pico2wave) wird mit jeder anderen Modifikation funktionieren.
                        Danke für die Tipps, jetzt funktioniert der Hausalarm wieder...für alle, die es ausprobieren wollen ;-)
                        on({id: 'asterisk.0.dialout.call'}, function (obj) {
                            let msg = getState('asterisk.0.dialout.text').val;
                            let tnr = getState('asterisk.0.dialout.telnr').val;
                            let cid = getState('asterisk.0.dialout.callerid').val;
                            exec('pico2wave -w /tmp/ttsdatei.wav -l it-IT "' + msg + '"', function (error, stdout, stderr) {
                                                    /* wav erstellt */
                                                        /* gsm erstellt */
        sendTo('asterisk.0', "dial", { telnr: tnr , callerid: cid, audiofile: '/tmp/ttsdatei.gsm'},  (res) => {
                        • stekS stek
                          @boeskij
                                                      /* wav erstellt */
                                                          /* gsm erstellt */
                          V Offline
                          V Offline
                          varg
                          #103
                          @stek
                          cool danke klappt
                          • C Offline
                            CrazyFloyd
                            schrieb am zuletzt editiert von CrazyFloyd
                            #104
                            Ich bekomme es leider nicht hin.
                            Kann jemand vielleicht über mein Fehlerbild drüber schauen und mir noch einen Tipp geben.
                            asterisk.0
                            2021-06-26 09:29:49.389 error Error while dialing (1). Error: {"response":"Error","actionid":"d4032cc3-b84e-5573-5779-f676c768a050","message":"Originate failed"}, Result: {"parameter":{"telnr":"**611","callerid":"**621","audiofile":"/tmp/ttsdatei","extension":"15041965"},"options":{"action":"originate","channel":"SIP/15041965/**611","context":"ael-ansage","exten":"**611","priority":1,"timeout":60000,"variable":{"repeat":5,"file":"/tmp/ttsdatei","del":""},"callerid":"**621"},"guid":"d4032cc3-b84e-5573-5779-f676c768a050","result":{"response":"Error","actionid":"d4032cc3-b84e-5573-5779-f676c768a050","message":"Originate failed"}}
                            **621 und **611 sind die internen Telefonfonnummer der Telephoniegeräte der Fritzbox. Diese habe ich im Script in Hochkommas gesetzt. ohne Hochkommas geht das Script in einen Error, mit den Sternchen vor der Nummer.
                            • C CrazyFloyd
                              asterisk.0
                              boeskij
                              #105
                              @crazyfloyd
                              funktionieren denn andere Rufnummern oder gar keine?
                              werden eingehende Anrufe vom asterisk/iobroker beantwortet?
                              zeig doch mal das Script...
                              C 1 Antwort Letzte Antwort
                              • B boeskij
                                @crazyfloyd
                                CrazyFloyd
                                #106
                                @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                @crazyfloyd
                                Hier mein script:
                                                        /* wav erstellt */
                                                            /* gsm erstellt */
        sendTo('asterisk.0', "dial", { telnr: '**611' , callerid: '**621', audiofile: '/tmp/ttsdatei.gsm'},  (res) => {
                                • C CrazyFloyd
                                  @crazyfloyd
                                  Hier mein script:
                                                          /* wav erstellt */
                                                              /* gsm erstellt */
                                  boeskij
                                  #107
                                  @crazyfloyd
                                  das sieht jetzt erstmal nicht so verkehrt aus...
                                  verbindet sich die asterisk-instanz mit dem asterisk?
                                  verbindet sich asterisk mit der fritzbox?
                                  • V varg
                                    @stek
                                    cool danke klappt
                                    V Offline
                                    V Offline
                                    varg
                                    #108
                                    @varg habe gerade eine chat anfrage erhalten und poste nochmals hier die vorgehensweise die (dank der jungs hier) bei mir funktioniert hat.
                                    wget -q https://ftp-master.debian.org/keys/release-10.asc -O- | sudo apt-key add -
                                    echo "deb http://deb.debian.org/debian buster non-free" | sudo tee -a /etc/apt/sources.list
                                    sudo apt update
                                    sudo apt install libttspico-utils
                                    sudo apt-get install libttspico-utils lame
                                    in asterisk transcoder auf sox gestellt.
                                    asterisk config nach github
        /* wav erstellt */
        /* gsm erstellt */
                                    bei instanzstart kommt zwar nach wie vor error while converting file aber das wird ja dann vom script und tts übernommen.
                                    mit folgendem blockly trigger ich dann die datenpunkte
                                      <block type="on" id="kKge@_%+BDw6n!K(/^X(" x="63" y="1163">
                                        <field name="OID">0_userdata.0.notfall.asterisk_04</field>
                                        <field name="CONDITION">true</field>
                                        <statement name="STATEMENT">
                                          <block type="control" id="Zma!K=;5A|U@oRsH4[0s">
                                            <field name="OID">asterisk.0.dialout.text</field>
                                            <value name="VALUE">
                                              <block type="text" id="{d.,gn^x-!O3Mf%OFwu;">
                                                <field name="TEXT">Rauchmelder zu Hause ausgelöst</field>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="control" id="j}/Ii|hS}Tm=mI8[ah[Y">
                                                <field name="OID">asterisk.0.dialout.telnr</field>
                                                  <block type="text" id="jGY8`[Q9`0u#J+]CWWmc">
                                                    <field name="TEXT">00000000000</field>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="control" id="7vVeDp2(HKA^yDV..=`M">
                                                    <field name="OID">asterisk.0.dialout.callerid</field>
                                                      <block type="text" id=".PKJzB615hu)o|v.ns7)">
                                                        <field name="TEXT">0</field>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="control" id="#gb%Wc4:m]{xk1W|KxyX">
                                                        <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                                                        <field name="OID">asterisk.0.dialout.call</field>
                                                        <field name="DELAY_MS">2000</field>
                                                        <field name="UNIT">ms</field>
                                                          <block type="logic_boolean" id="E8SqluH0+3,i.U;2GT+2">
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="control" id="jpO:t6;=~p9o[/]KMr?A">
                                                            <field name="DELAY_MS">60</field>
                                                              <block type="logic_boolean" id="`s`R94Iz^9G|2Sh/.jsq">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                      </block>
                                    </xml>
                                    • B boeskij
                                      @crazyfloyd
                                      CrazyFloyd
                                      #109
                                      @crazyfloyd
                                      ja und nein. ich habe festgestellt das ich von der asterix istanz folgende fehlermeldung bekomme:
                                      sudo asterisk -rvvvvvvv
                                      Asterisk 16.2.1~dfsg-1+deb10u2, Copyright (C) 1999 - 2018, Digium, Inc. and others.
                                      Created by Mark Spencer markster@digium.com
                                      Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
                                      This is free software, with components licensed under the GNU General Public
                                      License version 2 and other licenses; you are welcome to redistribute it under
                                      certain conditions. Type 'core show license' for details.
                                      Connected to Asterisk 16.2.1~dfsg-1+deb10u2 currently running on rasp-iobroker (pid = 29625)
                                      rasp-iobroker*CLI> sip show registry
                                      Host dnsmgr Username Refresh State Reg.Time
                                      192.168.2.1:5060 N 123456789 120 Request Sent
                                      1 SIP registrations.
                                      [Jun 27 17:28:13] ERROR[29927]: chan_sip.c:4321 __sip_reliable_xmit: Serious Network Trouble; __sip_xmit returns error for pkt data
                                      [Jun 27 17:28:13] NOTICE[29927]: chan_sip.c:15981 sip_reg_timeout: -- Registration for '123456789@192.168.2.1' timed out, trying again (Attempt #2)
                                      ich bin mir aber sicher das das telefoniegerät an der fritzbox und der user in der sip.conf richtig sind. werde langsam wahnsinnig.
                                      kann das evtl an der neuen fritz soft liegen version 7.27 auf einer 7530.?
                                      • C CrazyFloyd
                                        @crazyfloyd
                                        CrazyFloyd
                                        #110
                                        @crazyfloyd sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                        @crazyfloyd
                                        Ich hab es jetzt hin bekommen. Kann aber nicht genau sagen woran es letzt-endlich gelegen hat. Danke für alles..... Von Herzen..
                                        • B boeskij
                                          ich vermute Google hat etwas an der verwendeten Text-To-Speech API verändert, sodass nur noch eine bestimmte Anzahl Wandlungen in einem Zeitraum möglich sind (wenn überhaupt noch)...
                                          Ich habe es jetzt so gelöst, dass im Skript "umzu" mit lokalem PicoTTS wav-Dateien erzeugt und mit sox zur gsm konvertiert werden.
                                          Problem ist, dass beim Starten des Adapters der Dial-In-Text an Google geschickt wird und natürlich nicht gewandelt wird...
                                          Als Konsequenz daraus startet dann der Adapter nicht korrekt (kein DTMF mehr möglich)
                                          Um dies quick and dirty zu beheben habe ich in der asterisk.js die Zeilen 757 und 788 auskommentiert...
                                          Der Teil dazwischen wurde sonst nicht ausgeführt...
                                          757:	/* convertDialInFile(parameter, () => { */
                                          788:	/* }); */
                                          Wäre natürlich toll, wenn jemand den Adapter so umbauen könnte, dass eine andere TTS-Engine genutzt wird...
                                          Z Offline
                                          Z Offline
                                          zaggul
                                          schrieb am zuletzt editiert von zaggul
                                          #111
                                          doppelt, sorry.
