  4. Node-Red
  5. Mehrere Datenpunkte mit einer variablen vergleichen
    6.5k
25 Beiträge 2 Kommentatoren 2.5k Aufrufe 2 Beobachtet
  • mickymM mickym
    @renegade-0 Na dann kannst doch meinen Flow nehmen. Statt Hugo kommt halt der Zahlenstring rein.
    Ob Du dann true aus gibst oder über das Objekt kommst auch direkt an den Namen zur Begrüßung
    Renegade 0
    @mickym
    Kapier deinen Flow noch ned ganz. Hab grad umgebastelt, aber will ned so ganz.
            "id": "1ae851a8.7c63de",
            "type": "tab",
            "label": "RFID-Check",
            "disabled": false,
            "info": ""
            "id": "51113dd8.972204",
            "type": "ioBroker list",
            "z": "1ae851a8.7c63de",
            "name": "authorised",
            "topic": "0_userdata.0.door-server.door-RFID.*",
            "objType": "state",
            "regex": "",
            "asArray": "false",
            "onlyIDs": "true",
            "withValues": "true",
            "x": 550,
            "y": 200,
            "wires": [
                    "f064dd3d.75fe8",
                    "689dcd8a.51a634"
            "id": "a2577882.2efd08",
            "type": "ioBroker in",
            "name": "client/RFID",
            "topic": "mqtt.0.client.RFID",
            "payloadType": "value",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "x": 90,
            "y": 200,
            "wires": [
                    "9d981111.4543b"
            "id": "9d981111.4543b",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "move",
                    "p": "payload",
                    "pt": "msg",
                    "to": "search",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 300,
            "y": 200,
            "wires": [
                    "51113dd8.972204"
            "id": "7d60e459.bed5bc",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": true,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "payload",
            "statusType": "auto",
            "x": 1150,
            "y": 200,
            "wires": []
            "id": "f064dd3d.75fe8",
            "type": "switch",
            "name": "Treffer?",
            "property": "payload",
            "propertyType": "msg",
            "rules": [
                    "t": "jsonata_exp",
                    "v": "search = payload.val",
                    "vt": "jsonata"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 740,
            "y": 200,
            "wires": [
                    "8d0e7800.870138",
                    "7e533710.fd4f68"
            "id": "8d0e7800.870138",
            "type": "change",
            "name": "setze payload auf true",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 940,
            "y": 200,
            "wires": [
                    "7d60e459.bed5bc"
            "id": "689dcd8a.51a634",
            "type": "debug",
            "name": "Test 1:",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 740,
            "y": 340,
            "wires": []
            "id": "7e533710.fd4f68",
            "type": "debug",
            "name": "search",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "search",
            "statusVal": "",
            "x": 1030,
            "y": 340,
            "wires": []
    • R Renegade 0
      @mickym
              "type": "tab",
              "disabled": false,
              "info": ""
              "objType": "state",
              "regex": "",
              "asArray": "false",
              "onlyIDs": "true",
              "x": 550,
              "y": 200,
              "wires": [
                      "f064dd3d.75fe8",
                      "689dcd8a.51a634"
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 90,
              "y": 200,
              "wires": [
                      "9d981111.4543b"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "move",
                      "p": "payload",
                      "pt": "msg",
                      "to": "search",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 300,
              "y": 200,
              "wires": [
                      "51113dd8.972204"
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": true,
              "x": 1150,
              "y": 200,
              "wires": []
              "type": "switch",
              "name": "Treffer?",
              "rules": [
                      "t": "jsonata_exp",
                      "vt": "jsonata"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 740,
              "y": 200,
              "wires": [
                      "8d0e7800.870138",
                      "7e533710.fd4f68"
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 940,
              "y": 200,
              "wires": [
                      "7d60e459.bed5bc"
              "type": "debug",
              "name": "Test 1:",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 740,
              "y": 340,
              "wires": []
              "type": "debug",
              "name": "search",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 1030,
              "y": 340,
              "wires": []
      mickymM Offline
      mickymM Offline
      mickym
      @renegade-0 sagte in Mehrere Datenpunkte mit einer variablen vergleichen:
        [        {        "id": "1ae851a8.7c63de",        "type": "tab",        "label": "RFID-Check",        "disabled": false,        "info": ""        },        {        "id": "51113dd8.972204",        "type": "ioBroker list",        "z": "1ae851a8.7c63de",        "name": "authorised",        "topic": "0_userdata.0.door-server.door-RFID.*",        "objType": "state",        "regex": "",        "asArray": "false",        "onlyIDs": "true",        "withValues": "true",        "x": 550,        "y": 200,        "wires": [        [        "f064dd3d.75fe8",        "689dcd8a.51a634"        ]        ]        },        {        "id": "a2577882.2efd08",        "type": "ioBroker in",        "z": "1ae851a8.7c63de",        "name": "client/RFID",        "topic": "mqtt.0.client.RFID",        "payloadType": "value",        "onlyack": "",        "func": "all",        "gap": "",        "fireOnStart": "false",        "x": 90,        "y": 200,        "wires": [        [        "9d981111.4543b"        ]        ]        },        {        "id": "9d981111.4543b",        "type": "change",        "z": "1ae851a8.7c63de",        "name": "",        "rules": [        {        "t": "move",        "p": "payload",        "pt": "msg",        "to": "search",        "tot": "msg"        }        ],        "action": "",        "property": "",        "from": "",        "to": "",        "reg": false,        "x": 300,        "y": 200,        "wires": [        [        "51113dd8.972204"        ]        ]        },        {        "id": "7d60e459.bed5bc",        "type": "debug",        "z": "1ae851a8.7c63de",        "name": "",        "active": true,        "tosidebar": true,        "console": false,        "tostatus": true,        "complete": "payload",        "targetType": "msg",        "statusVal": "payload",        "statusType": "auto",        "x": 1150,        "y": 200,        "wires": []        },        {        "id": "f064dd3d.75fe8",        "type": "switch",        "z": "1ae851a8.7c63de",        "name": "Treffer?",        "property": "payload",        "propertyType": "msg",        "rules": [        {        "t": "jsonata_exp",        "v": "search = payload.val",        "vt": "jsonata"        }        ],        "checkall": "true",        "repair": false,        "outputs": 1,        "x": 740,        "y": 200,        "wires": [        [        "8d0e7800.870138",        "7e533710.fd4f68"        ]        ]        },        {        "id": "8d0e7800.870138",        "type": "change",        "z": "1ae851a8.7c63de",        "name": "setze payload auf true",        "rules": [        {        "t": "set",        "p": "payload",        "pt": "msg",        "to": "true",        "tot": "bool"        }        ],        "action": "",        "property": "",        "from": "",        "to": "",        "reg": false,        "x": 940,        "y": 200,        "wires": [        [        "7d60e459.bed5bc"        ]        ]        },        {        "id": "689dcd8a.51a634",        "type": "debug",        "z": "1ae851a8.7c63de",        "name": "Test 1:",        "active": true,        "tosidebar": true,        "console": false,        "tostatus": false,        "complete": "payload",        "targetType": "msg",        "statusVal": "",        "statusType": "auto",        "x": 740,        "y": 340,        "wires": []        },        {        "id": "7e533710.fd4f68",        "type": "debug",        "z": "1ae851a8.7c63de",        "name": "search",        "active": true,        "tosidebar": true,        "console": false,        "tostatus": false,        "complete": "search",        "targetType": "msg",        "statusVal": "",        "statusType": "auto",        "x": 1030,        "y": 340,        "wires": []        }        ]
      1. Fehler:
      Dann setze mal den letzten Node - weg - der Dir true setzt - Du kannst dann den Namen direkt aus dem Objekt lesen.
      Exportiere mal die Datenpunkte unter der RFID - damit ichs selbst im Flow machen kann.
      R 1 Antwort Letzte Antwort
      • mickymM mickym
        1. Fehler:
        Renegade 0
        @mickym
        Das mit dem ERgebnis klappt noch ned.
                "type": "tab",
                "disabled": false,
                "info": ""
                "objType": "state",
                "regex": "",
                "asArray": "false",
                "onlyIDs": "false",
                "x": 550,
                "y": 200,
                "wires": [
                        "f064dd3d.75fe8",
                        "7e533710.fd4f68"
                "onlyack": "",
                "func": "all",
                "gap": "",
                "x": 90,
                "y": 200,
                "wires": [
                        "9d981111.4543b"
                "type": "change",
                "name": "",
                "rules": [
                        "t": "move",
                        "p": "payload",
                        "pt": "msg",
                        "to": "search",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 300,
                "y": 200,
                "wires": [
                        "51113dd8.972204"
                "type": "debug",
                "name": "",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": true,
                "x": 1150,
                "y": 200,
                "wires": []
                "type": "switch",
                "name": "Treffer?",
                "rules": [
                        "t": "jsonata_exp",
                        "vt": "jsonata"
                "checkall": "true",
                "repair": false,
                "outputs": 1,
                "x": 740,
                "y": 200,
                "wires": [
                        "7d60e459.bed5bc"
                "type": "change",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "true",
                        "tot": "bool"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 700,
                "y": 500,
                "wires": [
                "type": "debug",
                "name": "search",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "complete": "payload.val",
                "targetType": "jsonata",
                "statusVal": "",
                "x": 1030,
                "y": 340,
                "wires": []
        Datenpunkte
          "0_userdata.0.door-server.door-RFID": {
            "_id": "0_userdata.0.door-server.door-RFID",
            "type": "channel",
            "common": {
              "name": "door-RFID",
              "role": "",
              "desc": "Zutrittsberechtigungen",
              "icon": ""
            "native": {},
            "user": "system.user.admin",
            "ts": 1623537286142,
            "acl": {
              "object": 1636,
              "owner": "system.user.admin",
          "0_userdata.0.door-server.door-RFID.Hans_Dampf": {
            "_id": "0_userdata.0.door-server.door-RFID.Hans_Dampf",
            "type": "state",
            "common": {
              "name": "Hans Dampf",
              "role": "",
              "type": "number",
              "desc": "Manuell erzeugt",
              "read": true,
              "write": true,
              "def": false
            "native": {},
            "ts": 1623537330521,
            "acl": {
              "object": 1636,
              "state": 1636
          "0_userdata.0.door-server.door-RFID.Sabine_Schussel": {
            "_id": "0_userdata.0.door-server.door-RFID.Sabine_Schussel",
            "type": "state",
            "common": {
              "name": "Sabine Schussel",
              "role": "",
              "type": "string",
              "read": true,
              "write": true,
              "def": false
            "native": {},
            "ts": 1623537366599,
            "acl": {
              "object": 1636,
              "state": 1636
        • R Renegade 0
          @mickym
                  "type": "tab",
                  "disabled": false,
                  "info": ""
                  "objType": "state",
                  "regex": "",
                  "asArray": "false",
                  "onlyIDs": "false",
                  "x": 550,
                  "y": 200,
                  "wires": [
                          "f064dd3d.75fe8",
                          "7e533710.fd4f68"
                  "onlyack": "",
                  "func": "all",
                  "gap": "",
                  "x": 90,
                  "y": 200,
                  "wires": [
                          "9d981111.4543b"
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "move",
                          "p": "payload",
                          "pt": "msg",
                          "to": "search",
                          "tot": "msg"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 300,
                  "y": 200,
                  "wires": [
                          "51113dd8.972204"
                  "type": "debug",
                  "name": "",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": true,
                  "x": 1150,
                  "y": 200,
                  "wires": []
                  "type": "switch",
                  "name": "Treffer?",
                  "rules": [
                          "t": "jsonata_exp",
                          "vt": "jsonata"
                  "checkall": "true",
                  "repair": false,
                  "outputs": 1,
                  "x": 740,
                  "y": 200,
                  "wires": [
                          "7d60e459.bed5bc"
                  "type": "change",
                  "rules": [
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "true",
                          "tot": "bool"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 700,
                  "y": 500,
                  "wires": [
                  "type": "debug",
                  "name": "search",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 1030,
                  "y": 340,
                  "wires": []
          Datenpunkte
              "type": "channel",
              "common": {
                "role": "",
                "icon": ""
              "native": {},
              "acl": {
                "object": 1636,
              "type": "state",
              "common": {
                "role": "",
                "type": "number",
                "read": true,
                "write": true,
                "def": false
              "native": {},
              "acl": {
                "object": 1636,
                "state": 1636
              "type": "state",
              "common": {
                "role": "",
                "type": "string",
                "read": true,
                "write": true,
                "def": false
              "native": {},
              "acl": {
                "object": 1636,
                "state": 1636
          mickymM Offline
          mickymM Offline
          mickym
          So das Problem ist wieder mal die Typ Konvertierung. Was hast Du in Deiner NodeRed Adapter Konfig. Hast Du diese ecklige OPtion raus gemacht, dass alles in Strings gewandelt wird?
          • mickymM mickym
            Renegade 0
            @mickym
            jetzt ja. :)
            • R Renegade 0
              @mickym
              jetzt ja. :)
              mickymM Offline
              mickymM Offline
              mickym
              @mickym
              jetzt ja. :)
              Sollte man als erstes machen!!!!
              Wenn es Zahlen sind gehts nämlich jetzt, sonst musst halt konvertieren:
              Hier der Flow - auch mit Namen, wenn Du nicht nur true haben willst. ;)
                     "objType": "state",
                     "regex": "",
                     "asArray": "false",
                     "onlyIDs": "false",
                     "x": 550,
                     "y": 200,
                     "wires": [
                             "f064dd3d.75fe8",
                             "689dcd8a.51a634"
                     "onlyack": "",
                     "func": "all",
                     "gap": "",
                     "x": 80,
                     "y": 140,
                     "wires": [
                             "9d981111.4543b"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "move",
                             "p": "payload",
                             "pt": "msg",
                             "to": "search",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 320,
                     "y": 200,
                     "wires": [
                             "51113dd8.972204"
                     "type": "debug",
                     "name": "Matched",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": true,
                     "x": 1160,
                     "y": 120,
                     "wires": []
                     "type": "switch",
                     "name": "Treffer?",
                     "rules": [
                             "t": "jsonata_exp",
                             "vt": "jsonata"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 1,
                     "x": 740,
                     "y": 200,
                     "wires": [
                             "8d0e7800.870138",
                             "7e533710.fd4f68",
                             "43a48ca8.55e674"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "true",
                             "tot": "bool"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 960,
                     "y": 120,
                     "wires": [
                             "7d60e459.bed5bc"
                     "type": "debug",
                     "name": "Test 1:",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "true",
                     "targetType": "full",
                     "statusVal": "",
                     "x": 740,
                     "y": 340,
                     "wires": []
                     "type": "debug",
                     "name": "search",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1030,
                     "y": 340,
                     "wires": []
                     "id": "eb860852.0e1938",
                     "type": "inject",
                     "name": "",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "12345",
                     "payloadType": "num",
                     "x": 90,
                     "y": 240,
                     "wires": [
                             "9d981111.4543b"
                     "id": "43a48ca8.55e674",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "payload.common.name",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 970,
                     "y": 200,
                     "wires": [
                             "5ab61be9.22b424"
                     "id": "5ab61be9.22b424",
                     "type": "debug",
                     "name": "Wer bist Du?",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1190,
                     "y": 200,
                     "wires": []
              Ansonsten wenn Du die Zahlen als Strings miteinander vergleichen willst, musst halt in der switch Node konvertieren, also von
              in
              • mickymM mickym
                @mickym
                jetzt ja. :)
                       "objType": "state",
                       "regex": "",
                       "asArray": "false",
                       "onlyIDs": "false",
                       "x": 550,
                       "y": 200,
                       "wires": [
                               "f064dd3d.75fe8",
                               "689dcd8a.51a634"
                       "onlyack": "",
                       "func": "all",
                       "gap": "",
                       "x": 80,
                       "y": 140,
                       "wires": [
                               "9d981111.4543b"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "move",
                               "p": "payload",
                               "pt": "msg",
                               "to": "search",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 320,
                       "y": 200,
                       "wires": [
                               "51113dd8.972204"
                       "type": "debug",
                       "name": "Matched",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": true,
                       "x": 1160,
                       "y": 120,
                       "wires": []
                       "type": "switch",
                       "name": "Treffer?",
                       "rules": [
                               "t": "jsonata_exp",
                               "vt": "jsonata"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 1,
                       "x": 740,
                       "y": 200,
                       "wires": [
                               "8d0e7800.870138",
                               "7e533710.fd4f68",
                               "43a48ca8.55e674"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "true",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 960,
                       "y": 120,
                       "wires": [
                               "7d60e459.bed5bc"
                       "type": "debug",
                       "name": "Test 1:",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "true",
                       "statusVal": "",
                       "x": 740,
                       "y": 340,
                       "wires": []
                       "type": "debug",
                       "name": "search",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1030,
                       "y": 340,
                       "wires": []
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "12345",
                       "x": 90,
                       "y": 240,
                       "wires": [
                               "9d981111.4543b"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 970,
                       "y": 200,
                       "wires": [
                               "5ab61be9.22b424"
                       "type": "debug",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1190,
                       "y": 200,
                       "wires": []
                in
                Renegade 0
                @mickym
                habs jetzt mit etwas tüfteln wie folgt gelöst. Nicht schön, aber funktioniert. ;)
                        "type": "tab",
                        "disabled": false,
                        "info": ""
                        "objType": "state",
                        "regex": "",
                        "asArray": "false",
                        "onlyIDs": "false",
                        "x": 550,
                        "y": 200,
                        "wires": [
                                "f064dd3d.75fe8"
                        "payloadType": "object",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 90,
                        "y": 200,
                        "wires": [
                                "9d981111.4543b"
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "move",
                                "p": "payload",
                                "pt": "msg",
                                "to": "search",
                                "tot": "msg"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 300,
                        "y": 200,
                        "wires": [
                                "51113dd8.972204"
                        "type": "debug",
                        "name": "Finish",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": true,
                        "x": 1190,
                        "y": 140,
                        "wires": []
                        "type": "switch",
                        "name": "Treffer?",
                        "rules": [
                                "t": "jsonata_exp",
                                "v": "search.val = payload.val",
                                "vt": "jsonata"
                        "checkall": "false",
                        "repair": false,
                        "outputs": 1,
                        "x": 740,
                        "y": 200,
                        "wires": [
                                "8d0e7800.870138",
                                "ccff8fad.33733"
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 980,
                        "y": 140,
                        "wires": [
                                "7d60e459.bed5bc"
                        "type": "debug",
                        "name": "result",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1190,
                        "y": 240,
                        "wires": []
                        "id": "ccff8fad.33733",
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "msg"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 970,
                        "y": 240,
                        "wires": [
                                "7e533710.fd4f68"
                • R Renegade 0
                  @mickym
                          "type": "tab",
                          "disabled": false,
                          "info": ""
                          "objType": "state",
                          "regex": "",
                          "asArray": "false",
                          "onlyIDs": "false",
                          "x": 550,
                          "y": 200,
                          "wires": [
                                  "f064dd3d.75fe8"
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 90,
                          "y": 200,
                          "wires": [
                                  "9d981111.4543b"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "move",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "search",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 300,
                          "y": 200,
                          "wires": [
                                  "51113dd8.972204"
                          "type": "debug",
                          "name": "Finish",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": true,
                          "x": 1190,
                          "y": 140,
                          "wires": []
                          "type": "switch",
                          "name": "Treffer?",
                          "rules": [
                                  "t": "jsonata_exp",
                                  "vt": "jsonata"
                          "repair": false,
                          "outputs": 1,
                          "x": 740,
                          "y": 200,
                          "wires": [
                                  "8d0e7800.870138",
                                  "ccff8fad.33733"
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "true",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 980,
                          "y": 140,
                          "wires": [
                                  "7d60e459.bed5bc"
                          "type": "debug",
                          "name": "result",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1190,
                          "y": 240,
                          "wires": []
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 970,
                          "y": 240,
                          "wires": [
                                  "7e533710.fd4f68"
                  mickymM Offline
                  mickymM Offline
                  mickym
                  Was ist unschön - warum Du die RFID als objekt holst und nicht wie ich als Value - verstehe ich allerdings nicht.
                  • mickymM mickym
                    Renegade 0
                    @mickym
                    Da die als value im String kommt und ich die val aus der Liste als number bekomme. Also habe ich gleich die RFID als Objekt geholt, da ist es dann als number "konvertiert". ;)
                    • R Renegade 0
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @renegade-0 Ok - ansonsten habe ich Dir ja unten gezeigt, wie Du in der switch Node konvertierst - damit das alles matched. Wahrscheinlich sind sogar Strings besser - nicht dass es RFID mit führenden Nullen gibt. ;)
                      Aber was ist daran unschön. ;) ???
                      • mickymM mickym
                        Renegade 0
                        @mickym
                        schöner wäre natürlich ein echtes konvertieren, aber so fit bin ich noch nicht. Bin ja ein Frischling auf dem Gebiet node-Red. :)
                        Kämpfe zb. gerade damit eine saubere Lösung zu finden, wenn eine Variable den Status von true auf false oder anders rum ändert, der switch dann sagt bei ture mache das und bei false das, aber leider kommen die werte aus der Var als bool und die switch kann kein bool.
                        • R Renegade 0
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @renegade-0 Der Switch kann bool .)
                          • mickymM mickym
                            Renegade 0
                            @mickym
                            ahh, warum kann ich da ned einfach auswählen, wie bei den anderen?^^
                            Letzte Frage für heute, weil ich grad Dich als Genie dran hab. :) Wie löst du es, wenn du quasi eine AND funktion brauchst. also wenn Var 1 +2 true, dann mach true?
                            • R Renegade 0
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @renegade-0
                              Mit JSONATA hast Du über $string() in String gewandelt. Das habe ich Dir unten gezeigt.
                              AND machst auch über JSONATA oder sammelst alles in einem Objekt, das mache ich bei vielen Verknüpfungen - da kann ich ggf. auch einen anderen Thread verweisen, wo ich das alles erklärt habe.
                              Die Nachrichten warten nicht aufeinander. Entweder vergleichst Du innerhalb eines Nachrichtenobjektes oder sammelst in Flow-Variablen.
                              Hier der Flow zu spielen:
                                     "id": "4d5d7a10.756a74",
                                     "type": "inject",
                                     "z": "1121287c.817698",
                                     "name": "",
                                     "props": [
                                             "p": "var1",
                                             "v": "25",
                                             "vt": "num"
                                             "p": "var2",
                                             "v": "hallo",
                                             "vt": "str"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "payloadType": "str",
                                     "x": 670,
                                     "y": 560,
                                     "wires": [
                                             "74314629.96c8b8"
                                     "id": "74314629.96c8b8",
                                     "type": "switch",
                                     "name": "",
                                     "rules": [
                                             "t": "jsonata_exp",
                                             "v": "var1 = 25 and var2 = 'hallo'",
                                             "vt": "jsonata"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 1,
                                     "x": 850,
                                     "y": 560,
                                     "wires": [
                                             "d6e9cd73.e8162"
                                     "id": "d6e9cd73.e8162",
                                     "type": "debug",
                                     "name": "var1 = 25 und var2 = hallo",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "complete": "true",
                                     "statusVal": "",
                                     "x": 1090,
                                     "y": 560,
                                     "wires": []
                                     "id": "a83d9abb.c1d118",
                                     "type": "inject",
                                     "name": "",
                                     "props": [
                                             "p": "var1",
                                             "v": "22",
                                             "vt": "num"
                                             "p": "var2",
                                             "v": "hallo",
                                             "vt": "str"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 670,
                                     "y": 500,
                                     "wires": [
                                             "74314629.96c8b8"
                              Für die Überwachung mehrere Zustände verweise ich auch einen anderen Beitrag von mir: https://forum.iobroker.net/topic/44765/gelöst-überwachung-eingeschaltete-verbraucher/3?_=1623542233576
                              Manche installieren sich auch eine UND Node. Ich denke man kommt ohne aus. Aber wer will kann ja zusätzliche NOdes installieren: https://flows.nodered.org/node/node-red-contrib-boolean-logic
                              • mickymM mickym
                                @renegade-0
                                       "type": "inject",
                                       "name": "",
                                       "props": [
                                               "p": "var1",
                                               "v": "25",
                                               "vt": "num"
                                               "p": "var2",
                                               "v": "hallo",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "x": 670,
                                       "y": 560,
                                       "wires": [
                                               "74314629.96c8b8"
                                       "type": "switch",
                                       "name": "",
                                       "rules": [
                                               "t": "jsonata_exp",
                                               "vt": "jsonata"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 1,
                                       "x": 850,
                                       "y": 560,
                                       "wires": [
                                               "d6e9cd73.e8162"
                                       "type": "debug",
                                       "active": true,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "complete": "true",
                                       "statusVal": "",
                                       "x": 1090,
                                       "y": 560,
                                       "wires": []
                                       "type": "inject",
                                       "name": "",
                                       "props": [
                                               "p": "var1",
                                               "v": "22",
                                               "vt": "num"
                                               "p": "var2",
                                               "v": "hallo",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "x": 670,
                                       "y": 500,
                                       "wires": [
                                               "74314629.96c8b8"
                                Renegade 0
                                @mickym
                                perfekt danke dir. Damit werde ich mich morgen mal soielen. Also falls du mal an die österreichische Grenze kommst. Steht ein Bier, Kaffe, Tee oder was immer du willst gern für Dich bereit. :)
                                Und nochmals vielen Lieben Dank für die Rettung und deine Zeit.
                                • R Renegade 0
                                  @mickym
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @renegade-0 Soweit weg wohne ich nicht davon weg. ;)
                                  • mickymM mickym
                                    Renegade 0
                                    @mickym
                                    Na dann, die Prüfung ist bald rum.^^
                                    • R Renegade 0
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @mickym
                                      Bei var1=true und var2= true (also beide Variablen enthalten einen Bool) - kannst in das JSONATA Feld natürlich einfach schreiben:
                                      var1 and var2
                                      Der Switch leitet dann an diesen Ausgang wenn der gesamte Ausdruck im JSONATA Feld true ergibt.
