  4. Node-Red
  5. Mehrere Datenpunkte mit einer variablen vergleichen
    6.5k
25 Beiträge 2 Kommentatoren 2.5k Aufrufe 2 Beobachtet
  • R Renegade 0
    @mickym
    habs jetzt mit etwas tüfteln wie folgt gelöst. Nicht schön, aber funktioniert. ;)
            "id": "1ae851a8.7c63de",
            "type": "tab",
            "label": "RFID-Check",
            "disabled": false,
            "info": ""
            "id": "51113dd8.972204",
            "type": "ioBroker list",
            "z": "1ae851a8.7c63de",
            "name": "authorised",
            "topic": "0_userdata.0.door-server.door-RFID.*",
            "objType": "state",
            "regex": "",
            "asArray": "false",
            "onlyIDs": "false",
            "withValues": "true",
            "x": 550,
            "y": 200,
            "wires": [
                    "f064dd3d.75fe8"
            "id": "a2577882.2efd08",
            "type": "ioBroker in",
            "name": "client/RFID",
            "topic": "mqtt.0.client.RFID",
            "payloadType": "object",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "fireOnStart": "false",
            "x": 90,
            "y": 200,
            "wires": [
                    "9d981111.4543b"
            "id": "9d981111.4543b",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "move",
                    "p": "payload",
                    "pt": "msg",
                    "to": "search",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 300,
            "y": 200,
            "wires": [
                    "51113dd8.972204"
            "id": "7d60e459.bed5bc",
            "type": "debug",
            "name": "Finish",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": true,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "payload",
            "statusType": "auto",
            "x": 1190,
            "y": 140,
            "wires": []
            "id": "f064dd3d.75fe8",
            "type": "switch",
            "name": "Treffer?",
            "property": "payload",
            "propertyType": "msg",
            "rules": [
                    "t": "jsonata_exp",
                    "v": "search.val = payload.val",
                    "vt": "jsonata"
            "checkall": "false",
            "repair": false,
            "outputs": 1,
            "x": 740,
            "y": 200,
            "wires": [
                    "8d0e7800.870138",
                    "ccff8fad.33733"
            "id": "8d0e7800.870138",
            "type": "change",
            "name": "setze payload auf true",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 980,
            "y": 140,
            "wires": [
                    "7d60e459.bed5bc"
            "id": "7e533710.fd4f68",
            "type": "debug",
            "name": "result",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 1190,
            "y": 240,
            "wires": []
            "id": "ccff8fad.33733",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.common.name",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 970,
            "y": 240,
            "wires": [
                    "7e533710.fd4f68"
    mickymM Offline
    mickymM Offline
    mickym
    Was ist unschön - warum Du die RFID als objekt holst und nicht wie ich als Value - verstehe ich allerdings nicht.
    R 1 Antwort Letzte Antwort
    • mickymM mickym
      Renegade 0
      @mickym
      Da die als value im String kommt und ich die val aus der Liste als number bekomme. Also habe ich gleich die RFID als Objekt geholt, da ist es dann als number "konvertiert". ;)
      • R Renegade 0
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        @renegade-0 Ok - ansonsten habe ich Dir ja unten gezeigt, wie Du in der switch Node konvertierst - damit das alles matched. Wahrscheinlich sind sogar Strings besser - nicht dass es RFID mit führenden Nullen gibt. ;)
        Aber was ist daran unschön. ;) ???
        • mickymM mickym
          Renegade 0
          @mickym
          schöner wäre natürlich ein echtes konvertieren, aber so fit bin ich noch nicht. Bin ja ein Frischling auf dem Gebiet node-Red. :)
          Kämpfe zb. gerade damit eine saubere Lösung zu finden, wenn eine Variable den Status von true auf false oder anders rum ändert, der switch dann sagt bei ture mache das und bei false das, aber leider kommen die werte aus der Var als bool und die switch kann kein bool.
          • R Renegade 0
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @renegade-0 Der Switch kann bool .)
            • mickymM mickym
              Renegade 0
              @mickym
              ahh, warum kann ich da ned einfach auswählen, wie bei den anderen?^^
              Letzte Frage für heute, weil ich grad Dich als Genie dran hab. :) Wie löst du es, wenn du quasi eine AND funktion brauchst. also wenn Var 1 +2 true, dann mach true?
              • R Renegade 0
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @renegade-0
                Mit JSONATA hast Du über $string() in String gewandelt. Das habe ich Dir unten gezeigt.
                AND machst auch über JSONATA oder sammelst alles in einem Objekt, das mache ich bei vielen Verknüpfungen - da kann ich ggf. auch einen anderen Thread verweisen, wo ich das alles erklärt habe.
                Die Nachrichten warten nicht aufeinander. Entweder vergleichst Du innerhalb eines Nachrichtenobjektes oder sammelst in Flow-Variablen.
                Hier der Flow zu spielen:
                       "id": "4d5d7a10.756a74",
                       "type": "inject",
                       "z": "1121287c.817698",
                       "name": "",
                       "props": [
                               "p": "var1",
                               "v": "25",
                               "vt": "num"
                               "p": "var2",
                               "v": "hallo",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payloadType": "str",
                       "x": 670,
                       "y": 560,
                       "wires": [
                               "74314629.96c8b8"
                       "id": "74314629.96c8b8",
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "jsonata_exp",
                               "v": "var1 = 25 and var2 = 'hallo'",
                               "vt": "jsonata"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 1,
                       "x": 850,
                       "y": 560,
                       "wires": [
                               "d6e9cd73.e8162"
                       "id": "d6e9cd73.e8162",
                       "type": "debug",
                       "name": "var1 = 25 und var2 = hallo",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "true",
                       "targetType": "full",
                       "statusVal": "",
                       "x": 1090,
                       "y": 560,
                       "wires": []
                       "id": "a83d9abb.c1d118",
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "var1",
                               "v": "22",
                               "vt": "num"
                               "p": "var2",
                               "v": "hallo",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "x": 670,
                       "y": 500,
                       "wires": [
                               "74314629.96c8b8"
                Für die Überwachung mehrere Zustände verweise ich auch einen anderen Beitrag von mir: https://forum.iobroker.net/topic/44765/gelöst-überwachung-eingeschaltete-verbraucher/3?_=1623542233576
                Manche installieren sich auch eine UND Node. Ich denke man kommt ohne aus. Aber wer will kann ja zusätzliche NOdes installieren: https://flows.nodered.org/node/node-red-contrib-boolean-logic
                • mickymM mickym
                  @renegade-0
                         "type": "inject",
                         "name": "",
                         "props": [
                                 "p": "var1",
                                 "v": "25",
                                 "vt": "num"
                                 "p": "var2",
                                 "v": "hallo",
                                 "vt": "str"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "x": 670,
                         "y": 560,
                         "wires": [
                                 "74314629.96c8b8"
                         "type": "switch",
                         "name": "",
                         "rules": [
                                 "t": "jsonata_exp",
                                 "vt": "jsonata"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 850,
                         "y": 560,
                         "wires": [
                                 "d6e9cd73.e8162"
                         "type": "debug",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "true",
                         "statusVal": "",
                         "x": 1090,
                         "y": 560,
                         "wires": []
                         "type": "inject",
                         "name": "",
                         "props": [
                                 "p": "var1",
                                 "v": "22",
                                 "vt": "num"
                                 "p": "var2",
                                 "v": "hallo",
                                 "vt": "str"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "x": 670,
                         "y": 500,
                         "wires": [
                                 "74314629.96c8b8"
                  Renegade 0
                  @mickym
                  perfekt danke dir. Damit werde ich mich morgen mal soielen. Also falls du mal an die österreichische Grenze kommst. Steht ein Bier, Kaffe, Tee oder was immer du willst gern für Dich bereit. :)
                  Und nochmals vielen Lieben Dank für die Rettung und deine Zeit.
                  • R Renegade 0
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @renegade-0 Soweit weg wohne ich nicht davon weg. ;)
                    • mickymM mickym
                      Renegade 0
                      @mickym
                      Na dann, die Prüfung ist bald rum.^^
                      • R Renegade 0
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @renegade-0 sagte in Mehrere Datenpunkte mit einer variablen vergleichen:
                        @mickym
                        Bei var1=true und var2= true (also beide Variablen enthalten einen Bool) - kannst in das JSONATA Feld natürlich einfach schreiben:
                        var1 and var2
                        Der Switch leitet dann an diesen Ausgang wenn der gesamte Ausdruck im JSONATA Feld true ergibt.
