  4. PH-Messung
    6.3k
PH-Messung
432 Beiträge 48 Kommentatoren 145.5k Aufrufe 50 Beobachtet
  • S skinni
    @apollon77 said in PH-Messung:
    DEBUG=ph803w* iobroker debug ph803w.0
    2021-06-09 17:04:43.930  - debug: ph803w.0 (16118) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-06-09 17:04:43.979  - debug: ph803w.0 (16118) Objects client ready ... initialize now
    2021-06-09 17:04:43.981  - debug: ph803w.0 (16118) Objects create System PubSub Client
    2021-06-09 17:04:43.983  - debug: ph803w.0 (16118) Objects create User PubSub Client
    2021-06-09 17:04:43.984  - debug: ph803w.0 (16118) Objects client initialize lua scripts
    2021-06-09 17:04:44.012  - debug: ph803w.0 (16118) Objects connected to redis: 127.0.0.1:9001
    2021-06-09 17:04:44.023  - debug: ph803w.0 (16118) objectDB connected
    2021-06-09 17:04:44.026  - debug: ph803w.0 (16118) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-06-09 17:04:44.058  - debug: ph803w.0 (16118) States create System PubSub Client
    2021-06-09 17:04:44.059  - debug: ph803w.0 (16118) States create User PubSub Client
    2021-06-09 17:04:44.069  - debug: ph803w.0 (16118) States connected to redis: 127.0.0.1:9000
    2021-06-09 17:04:44.070  - debug: ph803w.0 (16118) statesDB connected
    2021-06-09 17:04:44.358  - debug: ph803w.0 (16118) Plugin sentry Initialize Plugin (enabled=true)
    2021-06-09 17:04:44.617  - error: ph803w.0 (16118) adapter disabled
    2021-06-09 17:04:44.624  - info: ph803w.0 (16118) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ph803w, node: v12.22.1, js-controller: 3.2.16
    2021-06-09 17:04:44.715  - debug: ph803w.0 (16118) Init 1 known devices without discovery ...
    2021-06-09 17:04:44.774  - info: ph803w.0 (16118) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
    2021-06-09 17:04:44.845  - debug: ph803w.0 (16118) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
    2021-06-09 17:04:44.945  - debug: ph803w.0 (16118) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
    2021-06-09 17:05:50.930  - info: ph803w.0 (16118) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
    Wenn ich aus- und einschalte steht da nur
    2021-06-09 17:10:42.827  - info: ph803w.0 (27348) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
    Hier nochmal ein reboot des Geräts
    2021-06-09 17:19:33.898  - error: ph803w.0 (27348) PH803W device 2tqRa88FgaUS5AxgARVYug Error: Error: connect EHOSTUNREACH 192.168.88.128:12416
    2021-06-09 17:19:33.900  - info: ph803w.0 (27348) Disconnected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128
    2021-06-09 17:19:43.913  - info: ph803w.0 (27348) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
    und noch ein Edit..
    in iobroker siehts weiterhin so aus:
    #209
    @skinni Ok, mach mal den manuellen Aufruf per SSH aufruf leicht anders und vorher nochmal Update von GitHub
    DEBUG=ph803w* node /opt/iobroker/node_modules/iobroker.ph803w/main.js --debug
    • J johnbobjamesson
      @skinni said in PH-Messung:
      Ich überlege mir gerade ob und wie ich mit blockly ein script baue um auszuwerten ob die die Tendenz eher sinkend, oder steigend ist.
      z.B. Durchschnitt der letzten 25 Werte und dann Vergleichen mit dem aktuellen Wert.
      Machts Sinn sowas mit in den Adapter einzubauen, oder eher nicht?
      Ich habe zuerst gedacht, "Wozu soll man das brauchen, PH geht tendiert immer nach oben, Redox immer nach unten...", aber bei näherem Überlegen wäre das natürlich eine Möglichkeit, die Chlorpumpe erst einzuschalten und ggfs. länger laufen zu lassen, wenn der Trend eindeutig nach unten geht...
      #210
      @johnbobjamesson sagte in PH-Messung:
      kann ich nicht bestätigen.
      ich habe den Pool jetzt etwa 20 Jahre.
      ich habe nur bei der ersteinrichtung eine Gabe von pH-minus benötigt.
      Seit dem nur noch pH plus.
      Diese Jahr lag der pH bei Inbetriebnahme (vor 10 Tagen) bei etwa 7,7, was mich sehr verwunderte.
      Also abgewartet. Heute war es 7,2. Die Temperatur steigt noch (im Moment knapp 23°), da wird der pH noch weiter fallen.
      • apollon77A apollon77
        skinni
        #211
        pi@iobroker:~ $ DEBUG=ph803w* node /opt/iobroker/node_modules/iobroker.ph803w/main.js --debug
        2021-06-09 17:36:06.532  - debug: ph803w.0 (3336) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2021-06-09 17:36:06.586  - debug: ph803w.0 (3336) Objects client ready ... initialize now
        2021-06-09 17:36:06.597  - debug: ph803w.0 (3336) Objects create System PubSub Client
        2021-06-09 17:36:06.600  - debug: ph803w.0 (3336) Objects create User PubSub Client
        2021-06-09 17:36:06.602  - debug: ph803w.0 (3336) Objects client initialize lua scripts
        2021-06-09 17:36:06.622  - debug: ph803w.0 (3336) Objects connected to redis: 127.0.0.1:9001
        2021-06-09 17:36:06.633  - debug: ph803w.0 (3336) objectDB connected
        2021-06-09 17:36:06.636  - debug: ph803w.0 (3336) Redis States: Use Redis connection: 127.0.0.1:9000
        2021-06-09 17:36:06.650  - debug: ph803w.0 (3336) States create System PubSub Client
        2021-06-09 17:36:06.652  - debug: ph803w.0 (3336) States create User PubSub Client
        2021-06-09 17:36:06.671  - debug: ph803w.0 (3336) States connected to redis: 127.0.0.1:9000
        2021-06-09 17:36:06.673  - debug: ph803w.0 (3336) statesDB connected
        2021-06-09 17:36:06.975  - debug: ph803w.0 (3336) Plugin sentry Initialize Plugin (enabled=true)
        2021-06-09 17:36:07.206  - error: ph803w.0 (3336) adapter disabled
        2021-06-09 17:36:07.212  - info: ph803w.0 (3336) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ph803w, node: v12.22.1, js-controller: 3.2.16
        2021-06-09 17:36:07.309  - debug: ph803w.0 (3336) Init 1 known devices without discovery ...
        2021-06-09 17:36:07.312  - debug: ph803w.0 (3336) Start PH803W Device initialization for 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128
          ph803w:device Connected to TCP 192.168.88.128:12416 +0ms
        2021-06-09 17:36:07.382  - info: ph803w.0 (3336) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
          ph803w:device Write and register for response type 7: 0000000303000006 +3ms
          ph803w:discovery Listen for local PH803W devices on port 12414 +0ms
          ph803w:discovery Send broadcast message 0000000303000003 +0ms
          ph803w:device Passcode received: IVEXBRFPMQ +11ms
          ph803w:device Resolve for message type 7: {"type":"Buffer","data":[73,86,69,88,66,82,70,80,77,81]} +0ms
          ph803w:device Write and register for response type 9: 000000030f000008000a49564558425246504d51 +1ms
          ph803w:device login success +8ms
          ph803w:device Resolve for message type 9: true +0ms
          ph803w:device Write and register for response type 145: 000000030400009002 +1ms
          ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +50ms
        2021-06-09 17:36:07.455  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"11","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Resolve for message type 145: {"binFlags1":"11","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +2ms
        2021-06-09 17:36:07.456  - debug: ph803w.0 (3336) Initialization for PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 done (1/1)
          ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +101ms
          ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +0ms
        2021-06-09 17:36:07.492  - debug: ph803w.0 (3336) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
          ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +2ms
        2021-06-09 17:36:07.494  - debug: ph803w.0 (3336) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
          ph803w:device Send ping +4s
          ph803w:device received pong +13ms
          ph803w:device received pong +6ms
          ph803w:device received pong +5ms
          ph803w:device received pong +9ms
          ph803w:device received pong +7ms
          ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":621,"phOutlet":false,"redoxOutlet":true} +3s
        2021-06-09 17:36:38.938  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":621,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":621,"phOutlet":false,"redoxOutlet":true} +2ms
          ph803w:device Send ping +521ms
          ph803w:device received pong +4ms
          ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +1s
        2021-06-09 17:36:44.939  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +2ms
          ph803w:device Send ping +3s
          ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":624,"phOutlet":false,"redoxOutlet":true} +3s
        2021-06-09 17:36:50.945  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":624,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":624,"phOutlet":false,"redoxOutlet":true} +1ms
          ph803w:device Send ping +531ms
        2021-06-09 17:36:56.948  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +1ms
          ph803w:device Ping response overdue, reconnect +8s
          ph803w:device Destroy socket +0ms
          ph803w:device Socket close +1ms
          ph803w:device Connected to TCP 192.168.88.128:12416 +25s
        2021-06-09 17:37:36.864  - info: ph803w.0 (3336) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
          ph803w:device login success +7ms
          ph803w:device Write and register for response type 145: 000000030400009002 +0ms
          ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.15,"redox":601,"phOutlet":false,"redoxOutlet":true} +52ms
        2021-06-09 17:37:36.924  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"11","binFlags2":"10","ph":7.15,"redox":601,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Resolve for message type 145: {"binFlags1":"11","binFlags2":"10","ph":7.15,"redox":601,"phOutlet":false,"redoxOutlet":true} +1ms
        2021-06-09 17:37:36.926  - debug: ph803w.0 (3336) Initialization for PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 done (2/1)
          ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.15,"redox":602,"phOutlet":false,"redoxOutlet":true} +4s
        2021-06-09 17:37:40.430  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.15,"redox":602,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.15,"redox":602,"phOutlet":false,"redoxOutlet":true} +1ms
          ph803w:device Send ping +442ms
          ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":608,"phOutlet":false,"redoxOutlet":true} +2s
        2021-06-09 17:37:46.437  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":608,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":608,"phOutlet":false,"redoxOutlet":true} +1ms
          ph803w:device Send ping +2s
          ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":612,"phOutlet":false,"redoxOutlet":true} +4s
        2021-06-09 17:37:52.438  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":612,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":612,"phOutlet":false,"redoxOutlet":true} +2ms
          ph803w:device Send ping +448ms
          ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.13,"redox":614,"phOutlet":false,"redoxOutlet":true} +2s
        2021-06-09 17:37:58.500  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.13,"redox":614,"phOutlet":false,"redoxOutlet":true}
          ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.13,"redox":614,"phOutlet":false,"redoxOutlet":true} +1ms
        • S skinni
          #212
          @skinni sagte in PH-Messung:
          Ok, generell tut alles ... hab den Grund gefunden warum der connected Status falsch ist,. Aber generell tut alles.
          Also nochmal GitHub bitte ... besser jetzt?
            skinni
            #213
            @apollon77 jetzt klappts!
            • S skinni
              #214
              @skinni Dann kommt die 0.1.5 offiziell
              • apollon77A Offline
                #215
                Wnn möglich bitte alle mal auf die 0.1.5 gehen damit ich weiss das es bei allen noch tut :-)
                  skinni
                  #216
                  Bei mir ist alles gut 😊 👍
                  • I Offline
                    I Offline
                    ioUser 0
                    #217
                    Auch hier alles in Ordnung 👍
                    • I ioUser 0
                      johnbobjamesson
                      #218
                      Yeah!
                      @apollon77 : Vielen Dank für Deine Arbeit! Ich freue mich richtig, könnte mir das stundenlang ansehen, wie der ph Wert stetig steigt :)
                      • J johnbobjamesson
                        Yeah!
                        #219
                        @johnbobjamesson Ja Ja Ja macht mich nur alle neidisch ... Die zwei Sonden vom Ali sind heute angekommen ... das PH803W (was eigentlich garantierte 10 Tage Lieferung hatte) nicht :-) Aber naja vllt ja morgen. Gemke hat auch heute endlich die Messzelle versendet, die soll morgen kommen. Also noch hab ich ne Chance aufs Wochenende :-)
                          skinni
                          #220
                          Meine Sendung bei Gemke ging auch heute raus, war wohl Versandtag :)
                            #221
                            jetzt habt ihr mich auch bald soweit.
                            noch löse ich bunte Tabletten auf.
                            Zwei fragen habe ich:
                            läuft das ganze jetzt ohne es in der cloud anmelden zu müssen?
                            die andere betrifft die Messtechnik.
                            ich hatte das 803w immer in Verbindung mit Aquarien gefunden.
                            Selbst da hatte ich gewaltige Probleme wenn meine pH-Elektrode von Wasser angeströmt wurde.
                            ich kann es mir überhaupt nicht vorstellen, dass im Durchfluss vernünftige Werte kommen.
                            Wie wendet ihr das System an?
                            apollon77A coyoteC 2 Antworten Letzte Antwort
                              #222
                              @homoran Also ich kann jetzt bisher nur aus der Theorie sprechen: angeströhmt wird Sie aber nicht mit dem vollen Volumenstrom der Pumpe sondern in einem Bypass - daher auch die Gemke Messzelle als Bypass.
                              Cloud sollte nicht nötig sein ... aber denke das können die die es schon haben besser sagen :-)
                              Ingo
                                coyoteC Offline
                                coyoteC Offline
                                coyote
                                #223
                                @homoran Cloud Anmeldung ist nicht nötig
                                  #224
                                  Danke für die Antworten.
                                  hab mir gerade die Zelle angesehen, das könnte funktionieren.
                                  An den Preisen für die Elektroden (Einstabmessketten) hat sich seit meiner Aquarienzeit nichts gebessert.
                                  Gute Glaselektroden, die länger halten, kosten immer noch ein Vermögen.
                                  Da kann ich 2x1000 Tabletten für kaufen
                                  S J 2 Antworten Letzte Antwort
                                    skinni
                                    schrieb am zuletzt editiert von skinni
                                    #225
                                    @homoran kurz zusammengefasst: Es gibt den ph803, der kann redox nur bis 500 regeln, ist für uns also ohne Modifikation unbrauchbar. Dann gibts den ph803w, den wir hier haben. Zur Installation brauchst du ein Android Handy und musst eine modifizierte Gizwits App installieren, Link dazu mit Password findet man in der mitgelieferten Anleitung.
                                    Die App benötigt ansonsten keine Registrierung oder Kontoerstellung und dient uns nur dazu, das Gerät ins WLAN zu bringen, die Werte kann man jetzt über den Adapter in iobroker anzeigen lassen, die App benötigt man nicht mehr.
                                    Konfiguriert wird das Gerät komplett übers Bedienfeld am Gerät.
                                    Dass der Volumenstrom Probleme macht, hat bisher noch niemand im poolforum berichtet, aber er verkürzt auf jeden Fall die Lebensdauer der Elektroden, daher sollte man die immer in einen Bypass hängen. Manche haben sie auch im Skimmer hängen.
                                    Probleme gibts bisher nur in Kombination mit Salzelektrolyse, das liegt aber nicht am 803 sondern an den Elektroden. Ich hab mir eine für 69€ gekauft und die scheint bisher zu funktionieren. Mit Sicherheit weiß ich das erst in 2-3 Tagen, wenn mein Chlorwert wieder normal ist :)
                                    Es geht ja in erster Linie darum, mit dem Gerät zwei Schlauchpumpen (oder einen Chlorinator) für Chlor und PH Dosierung anzusteuern, sodass du die Chemie nicht mehr manuell einstellen musst.
                                    apollon77A LatziL N 4 Antworten Letzte Antwort
                                    • S skinni
                                      #226
                                      Ich hatte noch überlegt auch die WLAN.-Anmeldung über die ph803w nodejs lib zu machen, aber ich fürchte bis ich Leuten von allen möglichen systemen erklärt habe wie Sie ihren raspi mit dem "anfangs WLAN AP des Geräts" verbinden bin ich Uropa :-) (Ok, und ich hatte davon bisher noch keinen Wireshark mitschnitt)
                                      • S skinni
                                        #227
                                        Da bin ich gespannt was meine Ali Elektrode https://de.aliexpress.com/item/32707433870.html anstellt mit dem Chlorinator - wenn deine Elektode geht musst mir mal den Link geben (hier darf man die posten :-) )
                                          JohnnyBahama
                                          #228
                                          @homoran Zeit ist halt Geld. Du sparst dir das manuelle messen und nachjustieren 1000x 2Minuten.
