  4. PH-Messung
    6.3k
PH-Messung
432 Beiträge 48 Kommentatoren 145.5k Aufrufe 50 Beobachtet
  • S skinni
    @apollon77 Jetzt hab ichs aber
    2021-06-09 16:38:59.552 - info: ph803w.0 (12663) Loglevel changed from "info" to "debug"
    2021-06-09 16:39:42.158 - info: host.iobroker stopInstance system.adapter.ph803w.0 (force=false, process=true)
    2021-06-09 16:39:42.233 - info: ph803w.0 (12663) Got terminate signal TERMINATE_YOURSELF
    2021-06-09 16:39:42.236 - info: ph803w.0 (12663) terminating
    2021-06-09 16:39:42.238 - debug: ph803w.0 (12663) Plugin sentry destroyed
    2021-06-09 16:39:42.239 - info: ph803w.0 (12663) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-06-09 16:39:42.240 - info: ph803w.0 (12663) Disconnected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128
    2021-06-09 16:39:42.269 - info: host.iobroker stopInstance system.adapter.ph803w.0 send kill signal
    2021-06-09 16:39:42.830 - info: host.iobroker instance system.adapter.ph803w.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-06-09 16:39:45.460 - info: host.iobroker instance system.adapter.ph803w.0 started with pid 13186
    2021-06-09 16:39:47.815 - info: ph803w.0 (13186) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.ph803w, node: v12.22.1, js-controller: 3.2.16
    2021-06-09 16:39:47.968 - info: ph803w.0 (13186) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
    2021-06-09 16:40:22.014 - info: ph803w.0 (13186) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
    2021-06-09 16:41:08.140 - info: host.iobroker stopInstance system.adapter.ph803w.0 (force=false, process=true)
    2021-06-09 16:41:08.150 - info: ph803w.0 (13186) Got terminate signal TERMINATE_YOURSELF
    2021-06-09 16:41:08.154 - info: ph803w.0 (13186) terminating
    2021-06-09 16:41:08.155 - info: ph803w.0 (13186) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-06-09 16:41:08.156 - info: ph803w.0 (13186) Disconnected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128
    2021-06-09 16:41:08.185 - info: host.iobroker stopInstance system.adapter.ph803w.0 send kill signal
    2021-06-09 16:41:08.744 - info: host.iobroker instance system.adapter.ph803w.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-06-09 16:41:11.279 - info: host.iobroker instance system.adapter.ph803w.0 started with pid 16461
    2021-06-09 16:41:12.599 - debug: ph803w.0 (16461) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-06-09 16:41:12.660 - debug: ph803w.0 (16461) Objects client ready ... initialize now
    2021-06-09 16:41:12.664 - debug: ph803w.0 (16461) Objects create System PubSub Client
    2021-06-09 16:41:12.666 - debug: ph803w.0 (16461) Objects create User PubSub Client
    2021-06-09 16:41:12.667 - debug: ph803w.0 (16461) Objects client initialize lua scripts
    2021-06-09 16:41:12.703 - debug: ph803w.0 (16461) Objects connected to redis: 127.0.0.1:9001
    2021-06-09 16:41:12.715 - debug: ph803w.0 (16461) objectDB connected
    2021-06-09 16:41:12.723 - debug: ph803w.0 (16461) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-06-09 16:41:12.741 - debug: ph803w.0 (16461) States create System PubSub Client
    2021-06-09 16:41:12.742 - debug: ph803w.0 (16461) States create User PubSub Client
    2021-06-09 16:41:12.754 - debug: ph803w.0 (16461) States connected to redis: 127.0.0.1:9000
    2021-06-09 16:41:12.755 - debug: ph803w.0 (16461) statesDB connected
    2021-06-09 16:41:13.053 - debug: ph803w.0 (16461) Plugin sentry Initialize Plugin (enabled=true)
    2021-06-09 16:41:13.531 - info: ph803w.0 (16461) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.ph803w, node: v12.22.1, js-controller: 3.2.16
    2021-06-09 16:41:13.642 - debug: ph803w.0 (16461) Init 1 known devices without discovery ...
    2021-06-09 16:41:13.790 - info: ph803w.0 (16461) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
    2021-06-09 16:41:13.863 - debug: ph803w.0 (16461) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
    2021-06-09 16:41:13.864 - debug: ph803w.0 (16461) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
    2021-06-09 16:42:11.106 - info: ph803w.0 (16461) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
    #200
    @skinni Hehe hat sich überschnitten und dein Log hat mich auf eine Idee gebracht. Bitte nochmal aktuellstes GitHub versuchen
    • apollon77A apollon77
      skinni
      #201
      @apollon77
      2021-06-09 16:46:32.607 - info: host.iobroker iobroker url https://github.com/Apollon77/ioBroker.ph803w --host iobroker --debug
      2021-06-09 16:46:34.842 - info: host.iobroker iobroker install Apollon77/ioBroker.ph803w#4d1f3d628c5ab7266d63559b701b41aabda29129
      2021-06-09 16:46:35.502 - info: host.iobroker iobroker NPM version: 6.14.12
      2021-06-09 16:46:35.506 - info: host.iobroker iobroker npm install Apollon77/ioBroker.ph803w#4d1f3d628c5ab7266d63559b701b41aabda29129 --loglevel error --prefix "/opt/iobroker" (System call)
      2021-06-09 16:47:00.077 - info: host.iobroker iobroker + iobroker.ph803w@0.1.4
      2021-06-09 16:47:00.078 - info: host.iobroker iobroker updated 1 package in 23.214s
      2021-06-09 16:47:02.206 - info: host.iobroker iobroker
      2021-06-09 16:47:02.208 - info: host.iobroker iobroker 55 packages are looking for funding run `npm fund` for details
      2021-06-09 16:47:02.280 - info: host.iobroker iobroker upload [5] ph803w.admin /opt/iobroker/node_modules/iobroker.ph803w/admin/words.js words.js application/javascript
      2021-06-09 16:47:02.373 - info: host.iobroker iobroker upload [4] ph803w.admin /opt/iobroker/node_modules/iobroker.ph803w/admin/style.css style.css text/css
      2021-06-09 16:47:02.449 - info: host.iobroker iobroker upload [3] ph803w.admin /opt/iobroker/node_modules/iobroker.ph803w/admin/ph803w_icon.png ph803w_icon.png image/png
      2021-06-09 16:47:02.525 - info: host.iobroker iobroker upload [2] ph803w.admin /opt/iobroker/node_modules/iobroker.ph803w/admin/ph803w.png ph803w.png image/png
      2021-06-09 16:47:02.585 - info: host.iobroker iobroker upload [1] ph803w.admin /opt/iobroker/node_modules/iobroker.ph803w/admin/index_m.html index_m.html text/html
      2021-06-09 16:47:02.643 - info: host.iobroker iobroker upload [0] ph803w.admin /opt/iobroker/node_modules/iobroker.ph803w/admin/admin.d.ts admin.d.ts video/mp2t
      2021-06-09 16:47:02.766 - info: host.iobroker iobroker Update "system.adapter.ph803w.0"
      2021-06-09 16:47:02.796 - info: host.iobroker stopInstance system.adapter.ph803w.0 (force=false, process=true)
      2021-06-09 16:47:02.803 - info: ph803w.0 (16461) Got terminate signal TERMINATE_YOURSELF
      2021-06-09 16:47:02.807 - info: ph803w.0 (16461) terminating
      2021-06-09 16:47:02.809 - debug: ph803w.0 (16461) Plugin sentry destroyed
      2021-06-09 16:47:02.810 - info: ph803w.0 (16461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-06-09 16:47:02.810 - info: ph803w.0 (16461) Disconnected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128
      2021-06-09 16:47:02.819 - info: host.iobroker stopInstance system.adapter.ph803w.0 send kill signal
      2021-06-09 16:47:03.391 - info: host.iobroker instance system.adapter.ph803w.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-06-09 16:47:03.874 - info: host.iobroker iobroker exit 0
      2021-06-09 16:47:05.910 - info: host.iobroker instance system.adapter.ph803w.0 started with pid 402
      2021-06-09 16:47:07.046 - debug: ph803w.0 (402) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-06-09 16:47:07.096 - debug: ph803w.0 (402) Objects client ready ... initialize now
      2021-06-09 16:47:07.099 - debug: ph803w.0 (402) Objects create System PubSub Client
      2021-06-09 16:47:07.101 - debug: ph803w.0 (402) Objects create User PubSub Client
      2021-06-09 16:47:07.102 - debug: ph803w.0 (402) Objects client initialize lua scripts
      2021-06-09 16:47:07.130 - debug: ph803w.0 (402) Objects connected to redis: 127.0.0.1:9001
      2021-06-09 16:47:07.139 - debug: ph803w.0 (402) objectDB connected
      2021-06-09 16:47:07.142 - debug: ph803w.0 (402) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-06-09 16:47:07.151 - debug: ph803w.0 (402) States create System PubSub Client
      2021-06-09 16:47:07.152 - debug: ph803w.0 (402) States create User PubSub Client
      2021-06-09 16:47:07.162 - debug: ph803w.0 (402) States connected to redis: 127.0.0.1:9000
      2021-06-09 16:47:07.164 - debug: ph803w.0 (402) statesDB connected
      2021-06-09 16:47:07.460 - debug: ph803w.0 (402) Plugin sentry Initialize Plugin (enabled=true)
      2021-06-09 16:47:08.012 - info: ph803w.0 (402) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ph803w, node: v12.22.1, js-controller: 3.2.16
      2021-06-09 16:47:10.141 - debug: ph803w.0 (402) Init 1 known devices without discovery ...
      2021-06-09 16:47:10.810 - info: ph803w.0 (402) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
      2021-06-09 16:47:10.932 - debug: ph803w.0 (402) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
      2021-06-09 16:47:11.037 - debug: ph803w.0 (402) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
      2021-06-09 16:47:19.293 - info: host.iobroker stopInstance system.adapter.ph803w.0 (force=false, process=true)
      2021-06-09 16:47:19.301 - info: host.iobroker stopInstance system.adapter.ph803w.0 send kill signal
      2021-06-09 16:47:19.299 - info: ph803w.0 (402) Got terminate signal TERMINATE_YOURSELF
      2021-06-09 16:47:19.303 - info: ph803w.0 (402) terminating
      2021-06-09 16:47:19.304 - debug: ph803w.0 (402) Plugin sentry destroyed
      2021-06-09 16:47:19.305 - info: ph803w.0 (402) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-06-09 16:47:19.306 - info: ph803w.0 (402) Disconnected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128
      2021-06-09 16:47:19.891 - info: host.iobroker instance system.adapter.ph803w.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-06-09 16:47:22.407 - info: host.iobroker instance system.adapter.ph803w.0 started with pid 1128
      2021-06-09 16:47:23.509 - debug: ph803w.0 (1128) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-06-09 16:47:23.548 - debug: ph803w.0 (1128) Objects client ready ... initialize now
      2021-06-09 16:47:23.551 - debug: ph803w.0 (1128) Objects create System PubSub Client
      2021-06-09 16:47:23.553 - debug: ph803w.0 (1128) Objects create User PubSub Client
      2021-06-09 16:47:23.554 - debug: ph803w.0 (1128) Objects client initialize lua scripts
      2021-06-09 16:47:23.577 - debug: ph803w.0 (1128) Objects connected to redis: 127.0.0.1:9001
      2021-06-09 16:47:23.587 - debug: ph803w.0 (1128) objectDB connected
      2021-06-09 16:47:23.589 - debug: ph803w.0 (1128) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-06-09 16:47:23.598 - debug: ph803w.0 (1128) States create System PubSub Client
      2021-06-09 16:47:23.600 - debug: ph803w.0 (1128) States create User PubSub Client
      2021-06-09 16:47:23.609 - debug: ph803w.0 (1128) States connected to redis: 127.0.0.1:9000
      2021-06-09 16:47:23.610 - debug: ph803w.0 (1128) statesDB connected
      2021-06-09 16:47:23.891 - debug: ph803w.0 (1128) Plugin sentry Initialize Plugin (enabled=true)
      2021-06-09 16:47:24.126 - info: ph803w.0 (1128) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ph803w, node: v12.22.1, js-controller: 3.2.16
      2021-06-09 16:47:24.222 - debug: ph803w.0 (1128) Init 1 known devices without discovery ...
      2021-06-09 16:47:24.520 - info: ph803w.0 (1128) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
      2021-06-09 16:47:24.572 - debug: ph803w.0 (1128) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
      2021-06-09 16:47:24.659 - debug: ph803w.0 (1128) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
      2021-06-09 16:48:00.002 - error: javascript.0 (12871) Cannot get astro date for "nightEnd"
      2021-06-09 16:48:00.004 - error: javascript.0 (12871) Cannot get astro date for "night"
      2021-06-09 16:48:21.823 - info: ph803w.0 (1128) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
        schletti
        #202
        Muss ich für ein Update den Adapter vorher wieder löschen?
        • S schletti
          #203
          @schletti Nein, einfach "drüber" Installieren. Falls es eine Installation von GitHub ist dann ggf manuell nach dem Update neu starten
            schletti
            #204
            Blöde Frage, aber was muss ich wo machen um einfach drüber zu installieren?
            • S skinni
              @apollon77
              #205
              @skinni Ok, dann ganz anders :-) Das log hilft nicht.
              • Im Admin Adapterinstanz beenden
              • Log dich mit SSH ein
              • DEBUG=ph803w* iobroker debug ph803w.0
              • Dann das log von der Konsole bitte posten, da sollte mehr stehen
                schletti
                #206
                Habs schon selber gefunden wie es geht, einfach wie neuen Adapter installieren.
                  skinni
                  schrieb am zuletzt editiert von skinni
                  #207
                  @apollon77 said in PH-Messung:
                  2021-06-09 17:04:43.930  - debug: ph803w.0 (16118) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2021-06-09 17:04:43.979  - debug: ph803w.0 (16118) Objects client ready ... initialize now
                  2021-06-09 17:04:43.981  - debug: ph803w.0 (16118) Objects create System PubSub Client
                  2021-06-09 17:04:43.983  - debug: ph803w.0 (16118) Objects create User PubSub Client
                  2021-06-09 17:04:43.984  - debug: ph803w.0 (16118) Objects client initialize lua scripts
                  2021-06-09 17:04:44.012  - debug: ph803w.0 (16118) Objects connected to redis: 127.0.0.1:9001
                  2021-06-09 17:04:44.023  - debug: ph803w.0 (16118) objectDB connected
                  2021-06-09 17:04:44.026  - debug: ph803w.0 (16118) Redis States: Use Redis connection: 127.0.0.1:9000
                  2021-06-09 17:04:44.058  - debug: ph803w.0 (16118) States create System PubSub Client
                  2021-06-09 17:04:44.059  - debug: ph803w.0 (16118) States create User PubSub Client
                  2021-06-09 17:04:44.069  - debug: ph803w.0 (16118) States connected to redis: 127.0.0.1:9000
                  2021-06-09 17:04:44.070  - debug: ph803w.0 (16118) statesDB connected
                  2021-06-09 17:04:44.358  - debug: ph803w.0 (16118) Plugin sentry Initialize Plugin (enabled=true)
                  2021-06-09 17:04:44.617  - error: ph803w.0 (16118) adapter disabled
                  2021-06-09 17:04:44.624  - info: ph803w.0 (16118) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ph803w, node: v12.22.1, js-controller: 3.2.16
                  2021-06-09 17:04:44.715  - debug: ph803w.0 (16118) Init 1 known devices without discovery ...
                  2021-06-09 17:04:44.774  - info: ph803w.0 (16118) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
                  2021-06-09 17:04:44.845  - debug: ph803w.0 (16118) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
                  2021-06-09 17:04:44.945  - debug: ph803w.0 (16118) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
                  2021-06-09 17:05:50.930  - info: ph803w.0 (16118) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
                  Wenn ich aus- und einschalte steht da nur
                  2021-06-09 17:10:42.827  - info: ph803w.0 (27348) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
                  Hier nochmal ein reboot des Geräts
                  2021-06-09 17:19:33.898  - error: ph803w.0 (27348) PH803W device 2tqRa88FgaUS5AxgARVYug Error: Error: connect EHOSTUNREACH 192.168.88.128:12416
                  2021-06-09 17:19:33.900  - info: ph803w.0 (27348) Disconnected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128
                  2021-06-09 17:19:43.913  - info: ph803w.0 (27348) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
                  und noch ein Edit..
                  in iobroker siehts weiterhin so aus:
                  • S skinni
                    Ich überlege mir gerade ob und wie ich mit blockly ein script baue um auszuwerten ob die die Tendenz eher sinkend, oder steigend ist.
                    z.B. Durchschnitt der letzten 25 Werte und dann Vergleichen mit dem aktuellen Wert.
                    Machts Sinn sowas mit in den Adapter einzubauen, oder eher nicht?
                    johnbobjamesson
                    #208
                    @skinni said in PH-Messung:
                    Ich habe zuerst gedacht, "Wozu soll man das brauchen, PH geht tendiert immer nach oben, Redox immer nach unten...", aber bei näherem Überlegen wäre das natürlich eine Möglichkeit, die Chlorpumpe erst einzuschalten und ggfs. länger laufen zu lassen, wenn der Trend eindeutig nach unten geht...
                    • S skinni
                      und noch ein Edit..
                      #209
                      @skinni Ok, mach mal den manuellen Aufruf per SSH aufruf leicht anders und vorher nochmal Update von GitHub
                      DEBUG=ph803w* node /opt/iobroker/node_modules/iobroker.ph803w/main.js --debug
                      • J johnbobjamesson
                        #210
                        @johnbobjamesson sagte in PH-Messung:
                        kann ich nicht bestätigen.
                        ich habe den Pool jetzt etwa 20 Jahre.
                        ich habe nur bei der ersteinrichtung eine Gabe von pH-minus benötigt.
                        Seit dem nur noch pH plus.
                        Diese Jahr lag der pH bei Inbetriebnahme (vor 10 Tagen) bei etwa 7,7, was mich sehr verwunderte.
                        Also abgewartet. Heute war es 7,2. Die Temperatur steigt noch (im Moment knapp 23°), da wird der pH noch weiter fallen.
                          skinni
                          #211
                          pi@iobroker:~ $ DEBUG=ph803w* node /opt/iobroker/node_modules/iobroker.ph803w/main.js --debug
                          2021-06-09 17:36:06.532  - debug: ph803w.0 (3336) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2021-06-09 17:36:06.586  - debug: ph803w.0 (3336) Objects client ready ... initialize now
                          2021-06-09 17:36:06.597  - debug: ph803w.0 (3336) Objects create System PubSub Client
                          2021-06-09 17:36:06.600  - debug: ph803w.0 (3336) Objects create User PubSub Client
                          2021-06-09 17:36:06.602  - debug: ph803w.0 (3336) Objects client initialize lua scripts
                          2021-06-09 17:36:06.622  - debug: ph803w.0 (3336) Objects connected to redis: 127.0.0.1:9001
                          2021-06-09 17:36:06.633  - debug: ph803w.0 (3336) objectDB connected
                          2021-06-09 17:36:06.636  - debug: ph803w.0 (3336) Redis States: Use Redis connection: 127.0.0.1:9000
                          2021-06-09 17:36:06.650  - debug: ph803w.0 (3336) States create System PubSub Client
                          2021-06-09 17:36:06.652  - debug: ph803w.0 (3336) States create User PubSub Client
                          2021-06-09 17:36:06.671  - debug: ph803w.0 (3336) States connected to redis: 127.0.0.1:9000
                          2021-06-09 17:36:06.673  - debug: ph803w.0 (3336) statesDB connected
                          2021-06-09 17:36:06.975  - debug: ph803w.0 (3336) Plugin sentry Initialize Plugin (enabled=true)
                          2021-06-09 17:36:07.206  - error: ph803w.0 (3336) adapter disabled
                          2021-06-09 17:36:07.212  - info: ph803w.0 (3336) starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ph803w, node: v12.22.1, js-controller: 3.2.16
                          2021-06-09 17:36:07.309  - debug: ph803w.0 (3336) Init 1 known devices without discovery ...
                          2021-06-09 17:36:07.312  - debug: ph803w.0 (3336) Start PH803W Device initialization for 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128
                            ph803w:device Connected to TCP 192.168.88.128:12416 +0ms
                          2021-06-09 17:36:07.382  - info: ph803w.0 (3336) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
                            ph803w:device Write and register for response type 7: 0000000303000006 +3ms
                            ph803w:discovery Listen for local PH803W devices on port 12414 +0ms
                            ph803w:discovery Send broadcast message 0000000303000003 +0ms
                            ph803w:device Passcode received: IVEXBRFPMQ +11ms
                            ph803w:device Resolve for message type 7: {"type":"Buffer","data":[73,86,69,88,66,82,70,80,77,81]} +0ms
                            ph803w:device Write and register for response type 9: 000000030f000008000a49564558425246504d51 +1ms
                            ph803w:device login success +8ms
                            ph803w:device Resolve for message type 9: true +0ms
                            ph803w:device Write and register for response type 145: 000000030400009002 +1ms
                            ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +50ms
                          2021-06-09 17:36:07.455  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"11","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Resolve for message type 145: {"binFlags1":"11","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +2ms
                          2021-06-09 17:36:07.456  - debug: ph803w.0 (3336) Initialization for PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 done (1/1)
                            ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +101ms
                            ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +0ms
                          2021-06-09 17:36:07.492  - debug: ph803w.0 (3336) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
                            ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +2ms
                          2021-06-09 17:36:07.494  - debug: ph803w.0 (3336) Discovered PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 already known, ignore
                            ph803w:device Send ping +4s
                            ph803w:device received pong +13ms
                            ph803w:device received pong +6ms
                            ph803w:device received pong +5ms
                            ph803w:device received pong +9ms
                            ph803w:device received pong +7ms
                            ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":621,"phOutlet":false,"redoxOutlet":true} +3s
                          2021-06-09 17:36:38.938  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":621,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":621,"phOutlet":false,"redoxOutlet":true} +2ms
                            ph803w:device Send ping +521ms
                            ph803w:device received pong +4ms
                            ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +1s
                          2021-06-09 17:36:44.939  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +2ms
                            ph803w:device Send ping +3s
                            ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":624,"phOutlet":false,"redoxOutlet":true} +3s
                          2021-06-09 17:36:50.945  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":624,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":624,"phOutlet":false,"redoxOutlet":true} +1ms
                            ph803w:device Send ping +531ms
                          2021-06-09 17:36:56.948  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.12,"redox":623,"phOutlet":false,"redoxOutlet":true} +1ms
                            ph803w:device Ping response overdue, reconnect +8s
                            ph803w:device Destroy socket +0ms
                            ph803w:device Socket close +1ms
                            ph803w:device Connected to TCP 192.168.88.128:12416 +25s
                          2021-06-09 17:37:36.864  - info: ph803w.0 (3336) Connected PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 ... logging in ...
                            ph803w:device login success +7ms
                            ph803w:device Write and register for response type 145: 000000030400009002 +0ms
                            ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.15,"redox":601,"phOutlet":false,"redoxOutlet":true} +52ms
                          2021-06-09 17:37:36.924  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"11","binFlags2":"10","ph":7.15,"redox":601,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Resolve for message type 145: {"binFlags1":"11","binFlags2":"10","ph":7.15,"redox":601,"phOutlet":false,"redoxOutlet":true} +1ms
                          2021-06-09 17:37:36.926  - debug: ph803w.0 (3336) Initialization for PH803W device 2tqRa88FgaUS5AxgARVYug on IP 192.168.88.128 done (2/1)
                            ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.15,"redox":602,"phOutlet":false,"redoxOutlet":true} +4s
                          2021-06-09 17:37:40.430  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.15,"redox":602,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.15,"redox":602,"phOutlet":false,"redoxOutlet":true} +1ms
                            ph803w:device Send ping +442ms
                            ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":608,"phOutlet":false,"redoxOutlet":true} +2s
                          2021-06-09 17:37:46.437  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":608,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":608,"phOutlet":false,"redoxOutlet":true} +1ms
                            ph803w:device Send ping +2s
                            ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":612,"phOutlet":false,"redoxOutlet":true} +4s
                          2021-06-09 17:37:52.438  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":612,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":612,"phOutlet":false,"redoxOutlet":true} +2ms
                            ph803w:device Send ping +448ms
                            ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.13,"redox":614,"phOutlet":false,"redoxOutlet":true} +2s
                          2021-06-09 17:37:58.500  - debug: ph803w.0 (3336) Data received for PH803W device 2tqRa88FgaUS5AxgARVYug: {"binFlags1":"100","binFlags2":"10","ph":7.13,"redox":614,"phOutlet":false,"redoxOutlet":true}
                            ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.13,"redox":614,"phOutlet":false,"redoxOutlet":true} +1ms
                          • S skinni
                            #212
                            @skinni sagte in PH-Messung:
                            Ok, generell tut alles ... hab den Grund gefunden warum der connected Status falsch ist,. Aber generell tut alles.
                            Also nochmal GitHub bitte ... besser jetzt?
                              skinni
                              #213
                              @apollon77 jetzt klappts!
                              • S skinni
                                #214
                                @skinni Dann kommt die 0.1.5 offiziell
                                • apollon77A Offline
                                  #215
                                  Wnn möglich bitte alle mal auf die 0.1.5 gehen damit ich weiss das es bei allen noch tut :-)
                                    skinni
                                    #216
                                    Bei mir ist alles gut 😊 👍
                                    • I Offline
                                      I Offline
                                      ioUser 0
                                      #217
                                      Auch hier alles in Ordnung 👍
                                      • I ioUser 0
                                        johnbobjamesson
                                        #218
                                        Yeah!
                                        @apollon77 : Vielen Dank für Deine Arbeit! Ich freue mich richtig, könnte mir das stundenlang ansehen, wie der ph Wert stetig steigt :)
                                        • J johnbobjamesson
                                          Yeah!
                                          #219
                                          @johnbobjamesson Ja Ja Ja macht mich nur alle neidisch ... Die zwei Sonden vom Ali sind heute angekommen ... das PH803W (was eigentlich garantierte 10 Tage Lieferung hatte) nicht :-) Aber naja vllt ja morgen. Gemke hat auch heute endlich die Messzelle versendet, die soll morgen kommen. Also noch hab ich ne Chance aufs Wochenende :-)
