  4. PH-Messung
    6.3k
PH-Messung
432 Beiträge 48 Kommentatoren 145.5k Aufrufe 50 Beobachtet
  • apollon77A apollon77
    Cool, updated Ihr bitte nochmal - vor allem @skinni und @coyote und postet die Ausgabe nochmal ... ich will sehen was bei euch diese "unbekannten Pakete" sind :-) habe das Logging angepasst. Danke
    (und @coyote bei dir wars irgendwie abgeschnitten) ...
    Aber denke auf der Basis haben wir was
    skinni
    #136
    @apollon77
    pi@iobroker:~/node_modules/node-ph803w/example $ DEBUG=ph803w* node discovery
    Discover PH803W devices ... CTRL-C to quit
      ph803w:discovery Listen for local PH803W devices on port 12414 +0ms
      ph803w:discovery Send broadcast message 0000000303000003 +2ms
      ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +53ms
      ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +2ms
    PH803W Device discovered on 192.168.88.128
      ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +91ms
      ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +0ms
      ph803w:discovery Ignore data package because invalid message type 145: 000000031400009106e8db848c4b17040202c60a5400000000 +27s
    ERROR: Ignore data package because invalid message type 145
      ph803w:discovery Ignore data package because invalid message type 145: 000000031400009106e8db848c4b17040202c60a5300000000 +6s
    • apollon77A Offline
      #137
      Ok, ich denke die weitere Pakete die da kommen sind soweit egal :-)
      Damit geht Discovery auch. Dann kann ich vllt doch ohne mein Gerät mal am Adapter basteln
        #138
        Ich hab an Discovery nochmal bissl rumgeschraubt. Könnt Ihr bitte nochmal checken ob es noch tut? Am besten (falls jemand früher gemacht hat): Nach 11:10 :-)
        S ? 2 Antworten Letzte Antwort
          skinni
          #139
          @apollon77
          Discovering PH803W devices ... CTRL-C to quit
            ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +82ms
            ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +1ms
            ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +3ms
          ^C
            #140
            @apollon77 hier die neue Version
              ph803w:discovery Send broadcast message 0000000303000003 +1ms
              ph803w:discovery Parsing discovered device: 192.168.0.118:12414 - 000000036800000400166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300000020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e302e3800 +305ms
              ph803w:discovery Discovered device: {"ip":"192.168.0.118","id":"kbE88JgrhZy0yNJonP9abK","data1":"40f5202c8493","data2":"","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.0.8"} +2ms
            PH803W Device discovered on 192.168.0.118
              ph803w:discovery Ignore data package because invalid message type 26: 000000034500001a00166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300203264336439353464396262373431623461313962613131353331303439333262 +29s
              #141
              Hat jemand ne Idee was ich für ein Adapter-Bild/Icon nehmen könnte? Jemand "grafisch begabt"? ;-)
              I 1 Antwort Letzte Antwort
                skinni
                schrieb am zuletzt editiert von skinni
                #142
                Einfach sowas? Transparenten Hintergrund kann ich bei Bedarf auch noch machen, falls das in die richtige Richtung geht
                Egal wie du dich entscheidest, hier mit transparentem Hintergrund
                  I Offline
                  I Offline
                  I-Punkt
                  #143
                  @apollon77
                  Gedanklich bin ich bei solchen Messungen immer gleich bei Pipette oder Reagenzglas.
                  09bcfa1b-5a3c-49fc-a8f2-0f63740dc286-image.png 1fe197ed-15d8-4e41-8123-e19bf3d124e8-image.png
                  • C Chaosbrother
                    Hallo
                    Hat vieleicht jemand eine Idee , wie ich die Daten in den Iobroker bekomme und nicht in die Chinacloud?
                    Scheint ein Eps8266 verbaut zu sein.
                    Es handelt sich um dieses Teil. PH-803W (https://de.aliexpress.com/item/1005001297583199.html?spm=a2g0o.productlist.0.0.74816ce9CkewAY&algo_pvid=da15f797-fea6-4eee-9715-c6b71092575c&algo_expid=da15f797-fea6-4eee-9715-c6b71092575c-1&btsid=0b0a050b16140056883318857edd8f&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_)
                    Das ist die App und Cloud dazu. (http://docs.gizwits.com/en-us/overview/overview.html)
                    Leider reichen meine Kentnisse dafür nicht aus , gibt auch was auf github dazu.
                    Firmware auslesen und Server ändern? Denke aber das wäre zu einfach. Irgendwie muß man die Daten doch umlenken können , wie bei den Steckdosen oder ähnliches.
                    Gruß Chaosbrother
                    opossumO Offline
                    opossumO Offline
                    opossum
                    #144
                    @chaosbrother ,
                    werden die beiden Messsonden mitgeliefert oder muss ich die extra bei Ali bestellen oder reicht Dein Link zum Bestellen aus?
                    https://www.schlepper-petersdorf.de
                    coyoteC 1 Antwort Letzte Antwort
                    • HomoranH Offline
                      HomoranH Offline
                      #145
                      da es hier um das pH803w geht, finde ich ein Kleinbild davon eigentlich am sinnvollsten.
                      Ansonsten wirft die Suche einiges aus:
                      wenn wir davon irgenwas in Lizenz haben, wäre das auch noch denkbar.
                      • opossumO opossum
                        @chaosbrother ,
                        coyoteC Offline
                        coyoteC Offline
                        coyote
                        schrieb am zuletzt editiert von coyote
                        #146
                        @opossum ich antworte mal auf deine Frage.
                        Die beiden Sonden, die auf dem Bild des Links sind, sind mit dabei. Wenn du aber ne Messzelle verbaust, passen diese nicht in die Verschraubungen rein.
                        Da müsstest du dir entweder extra ein Gewindeadapter basteln oder andere neue zylinderförmige Messsonden mit 12mm Durchmesser kaufen ( so hab ich es gemacht, kosten ja nicht die Welt bei Ali)
                        Zum Icon, bin da bei @Homoran @skinni . Entweder einfach ein Kleinbild des ph803w oder ein Icon aus seinem Screenshot
                        W 1 Antwort Letzte Antwort
                        • coyoteC coyote
                          W Offline
                          W Offline
                          weimaraner
                          #147
                          @all ich lese hier seit Tagen mit. Es ist echt der Wahnsinn, was ihr hier alle in wenigen Tagen auf die Beine gestellt habt. Das las sich, wie ein Krimi. Technisch habe ich keinen Plan, was @apollon77 hier gezaubert hat, aber es war trotzdem spannend mitzuverfolgen, wie ihr dem Ziel immer näher gekommen seid. 😁 Hut ab!
                          Ich würde übrigens dieses icon gut finden
                          • W weimaraner
                            #148
                            @weimaraner Ich wäre bei dem zwei drunter nur in nem Dunklen Blau anstelle dem schwarz? Kann mir das einer als PNG geben?
                            • I I-Punkt
                              @apollon77
                              #149
                              @i-punkt Die sind generell gut, aber mit für diesen Fall - geht ja quasi um ein spezifisches Gerät, den PH803W zu allgemein. Denke das Icon sollte schon Farblich und "aussehen" was damit zu tun haben.
                              Für die Readme kann man auch durch aus noch ein größeres ausgeschnittenes und freigestellte echtes PH803W machen - das ist dann nur nix als Icon
                                #150
                                Hey, na, noch jemand wach?? Jemand er einen PH803W und ioBroker hat? Jemand dessen PH803W an ist? jemand der nen Adapter testen will? ;-))
                                Bitte Adapter von https://github.com/Apollon77/ioBroker.ph803w/ installieren ... EInstellungen braucht es aktuell keine. Discovery per UDP - PH803W muss also im gleichen netzwerk sein wie der ioBroker Rechner
                                coyoteC 3 Antworten Letzte Antwort
                                  coyoteC Offline
                                  coyoteC Offline
                                  coyote
                                  #151
                                  @apollon77 teste gleich, gib mir noch paar Minuten ;-)
                                    coyoteC Offline
                                    coyoteC Offline
                                    coyote
                                    #152
                                    @apollon77 tja, was soll ich sagen Ingo :-)
                                    Wer kann, der kann...👏 👏 Vielen dank
                                      coyoteC Offline
                                      coyoteC Offline
                                      coyote
                                      #153
                                      @apollon77 wie deinstalliere ich denn jetzt am Besten das Testscript von dir?
                                      • coyoteC coyote
                                        #154
                                        @coyote einfach das Verzeichnis was du dafür angelegt hast löschen.
                                        • I Offline
                                          I Offline
                                          ioUser 0
                                          #155
                                          irgendwie haut die Installation im ioBroker bei mir nicht hin.
                                          Eine kurze Newbie-Erklärung für die Installation und was man alles benötigt wäre toll.
