  4. Regelmäßiger Absturz
27 Beiträge 3 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • S SvenSmarthome
    Da das System bis jetzt noch nicht läuft halb so schlimm. Außer Ersteinrichtung habe ich noch nichts gemacht.
    Vielleicht hilft das weiter, wie man das downloaden kann habe ich noch nicht raus.
    host.raspberrypi 2021-05-31 18:08:45.813 info Restart adapter system.adapter.hm-rpc.1 because enabled
    host.raspberrypi 2021-05-31 18:08:45.806 info instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    hm-rpc.1 2021-05-31 18:08:45.100 info (2751) Terminated (NO_ERROR): Without reason
    hm-rpc.1 2021-05-31 18:08:45.097 info (2751) terminating
    hm-rpc.1 2021-05-31 18:08:44.571 error (2751) Init not possible, going to stop: response timeout
    hm-rpc.1 2021-05-31 18:08:44.563 info (2751) binrpc -> 192.168.2.113:2001/ init ["xmlrpc_bin://192.168.2.40:12001",""]
    hm-rpc.1 2021-05-31 18:08:14.558 error (2751) Init not possible, going to stop: response timeout
    hm-rpc.1 2021-05-31 18:08:09.542 info (2751) binrpc client is trying to connect to 192.168.2.113:2001/ with ["xmlrpc_bin://192.168.2.40:12001","raspberrypi:hm-rpc.1"]
    hm-rpc.1 2021-05-31 18:08:09.541 info (2751) binrpc server is trying to listen on 192.168.2.40:12001
    hm-rpc.1 2021-05-31 18:08:09.296 info (2751) starting. Version 1.14.37 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16
    host.raspberrypi 2021-05-31 18:08:06.856 info instance system.adapter.hm-rpc.1 started with pid 2751
    fritzdect.0 2021-05-31 18:08:00.530 error (1784) no response part in returned message
    fritzdect.0 2021-05-31 18:08:00.528 error (1784) fritzbox returned this {"msg":"get error in http request","function":"get_login_state","error":{"errno":"ENOTFOUND","code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"192.x.x.x"}}
    javascript.0 2021-05-31 18:08:00.002 warn (1994) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    host.raspberrypi 2021-05-31 18:07:36.817 info Restart adapter system.adapter.hm-rpc.1 because enabled
    host.raspberrypi 2021-05-31 18:07:36.810 info instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
    hm-rpc.1 2021-05-31 18:07:36.099 info (2702) Terminated (NO_ERROR): Without reason
    hm-rpc.1 2021-05-31 18:07:36.094 info (2702) terminating
    hm-rpc.1 2021-05-31 18:07:35.582 error (2702) Init not possible, going to stop: response timeout
    hm-rpc.1 2021-05-31 18:07:35.578 info (2702) binrpc -> 192.168.2.113:2001/ init ["xmlrpc_bin://192.168.2.40:12001",""]
    hm-rpc.1 2021-05-31 18:07:05.574 error (2702) Init not possible, going to stop: response timeout
    hm-rpc.1 2021-05-31 18:07:00.556 info (2702) binrpc client is trying to connect to 192.168.2.113:2001/ with ["xmlrpc_bin://192.168.2.40:12001","raspberrypi:hm-rpc.1"]
    hm-rpc.1 2021-05-31 18:07:00.554 info (2702) binrpc server is trying to listen on 192.168.2.40:12001
    hm-rpc.1 2021-05-31 18:07:00.313 info (2702) starting. Version 1.14.37 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.22.1, js-controller: 3.2.16
    javascript.0 2021-05-31 18:07:00.002 warn (1994) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    Vielleicht bringt das hier was.
    Vielen Dank.
    Sven
    haselchenH Offline
    haselchenH Offline
    haselchen
    @svensmarthome
    Welche Anleitung hast du denn benutzt?
    Quelle?
    • haselchenH haselchen
      @svensmarthome
      Quelle?
      SvenSmarthome
      @haselchen
      https://www.youtube.com/watch?v=-z4PF5TNzq8&t=17s
      • S SvenSmarthome
        @haselchen
        haselchenH Offline
        haselchenH Offline
        haselchen
        @svensmarthome
        Erstmal KEIN Youtube, sondern alles von hier.
        Und dann ist das Video 2 Jahre alt.
        Geh oben auf Docu und mach es nochmal vernünftig.
        • S SvenSmarthome
          Vielen Dank.
          Sven
          @svensmarthome sagte in Regelmäßiger Absturz:
          Bitte Code in CodeTags setzen, dann mag man das auch lesen.
          Und auf Anfragen auch entsprechend antworten. Die Ausgabe zu
          ps aux | grep -i Xorg
          hab ich noch nicht gesehen.
            SvenSmarthome
            schrieb am zuletzt editiert von SvenSmarthome
            Ich hatte das nicht verstanden das ich das machen soll.
            Hier ein Screenshot
            Ich hoffe das geht so. Ich verstehe nicht was die Ausgabe sagt.
            Zum neu Aufsetzen brauche ich etwas Zeit, mache ich dann aber.
            Vielen Dank
            Sven
            • S SvenSmarthome
              Hier ein Screenshot
              Vielen Dank
              Sven
              @svensmarthome
              Dann setzt das Ding ohne Desktop-Umgebung auf, nur Kommandozeile.
              Ein Pi3 mit 1GB hat keine Kapazität für so einen Blödsinn zu verschenken, freezes sind die Folge.
              Und bitte keine Screenshots von Text. Konsolenoutput in CodeTags eingebettet als Text posten.
                @svensmarthome
                SvenSmarthome
                @thomas-braun said in Regelmäßiger Absturz:
                Auch auf die Gefahr hin das ich doof rüber komme, was genau meinst Du damit und wie mache ich das?
                • S SvenSmarthome
                  @svensmarthome
                  anklicken, Text zwischen die Steuerzeichen kopieren, fertig.
                    @svensmarthome
                    SvenSmarthome
                    pi@raspberrypi:~ $ ps aux | grep -i Xorg
                    pi        1008  0.0  0.0   7348   500 pts/0    S+   17:48   0:00 grep --color=au                      to -i Xorg
                    Hab gerade nochmals neu aufgesetzt, ist so besser?
                    • S SvenSmarthome
                      @svensmarthome
                      Jo.
                      who -r
                      sagt? Sollte eigentlich was mit Runlevel 3 kommen dann.
                        @svensmarthome
                        Jo.
                        who -r
                        SvenSmarthome
                        pi@raspberrypi:~ $ who -r
                                 run-level 5  2021-06-02 17:46
                        • S SvenSmarthome
                          @svensmarthome
                          Mach es nach dem 'kleinen Werkzeugkasten':
                          Punkt
                          RunLevel 5 / graphische Oberfläche
                            @svensmarthome
                            Punkt
                            SvenSmarthome
                            Ich habe jetzt das Raspberry OS Light installiert...
                            • S SvenSmarthome
                              @svensmarthome
                              Okay, das hat die 'dämliche' Angewohnheit sich mit RL5 zu melden.
                              Ich würds ändern.
                                @svensmarthome
                                Ich würds ändern.
                                SvenSmarthome
                                         run-level 3  2021-06-02 18:37
                                Ich dachte ich nehme das Lite das hat am wenigsten und braucht am wenigsten Ressourcen.
                                Jetzt habe ich Run-level 3
                                • S SvenSmarthome
                                  Das ist ja auch richtig. Und sicherer ist es auch noch.
                                  Und leichter zu bedienen auch.
                                    SvenSmarthome
                                    Ich habe ioBroker jetzt mal machen lassen, was er selbst so gefunden hat.
                                    Er hat alle Adapter installiert bis auf 2 da steht foglendes:
                                    1. Bei den Instanzen der eine (hm-rpc.1) der immer nur von gelb auf rot wechselt aber nicht grün wird. Das hatte ich bis jetzt immer so.
                                      Die neue Installation war nicht die erste Installation und nicht die 2. irgendwas mache ich bestimmt falsch bei der einen Instanz.
                                    Ich hoffe hier ist es OK mit den Screenshots.
                                    Und schonmal vielen Dank für die Unterstützung beim installieren.
                                    • S SvenSmarthome
                                      @svensmarthome
                                      Systemzeit richtig?
                                      date && date -u
                                        @svensmarthome
                                        Systemzeit richtig?
                                        date && date -u
                                        SvenSmarthome
                                        date && date -u
                                        pi@raspberrypi:~ $ date && date -u
                                        Wed  2 Jun 19:03:27 BST 2021
                                        Wed  2 Jun 18:03:27 UTC 2021
                                        Irgendwie scheinbar nicht oder interpretiere ich es falsch?
                                        Ich habe mir die Adapterliste angeschaut, z.b. für Philips Hue gibts 2 Adapter, Die Infos habe ich auch gelesen, scheinbar können beide alles. Wie findet man hier eine Entscheidung?
                                        Vielen Dank.
                                        • S SvenSmarthome
                                          date && date -u
                                          Vielen Dank.
                                          @svensmarthome
                                          Da ist die englische Zeit eingestellt.
                                          sudo timedatectl set-timezone Europe/Berlin
                                          bringt es auf deutsche Zeit.
                                          Tastatur ist vermutlich auch noch auf englisch.
