  4. Socket Error Pi nicht erreichbar
173 Beiträge 9 Kommentatoren 25.9k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @jwedenig
    EDIT:
    Zeige mal
    iobroker status
    iobroker list instances
    jwedenig
    Der Vollständigkeit halber hier mit neuer SD Karte:
    @glasfaser sagte in Socket Error Pi nicht erreichbar:
    @jwedenig
    EDIT:
    Zeige mal
    iobroker status
    pi@raspberrypi:~ $ iobroker status
    Objects type: file
    States  type: file
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi                              -  enabled
    + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
    + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
    + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE876FE-if00
    + instance is alive
    • J jwedenig
      Ja, vom Strom genommen, ok, schlecht gemerkt!
      Aber wenn der Pi über Terminal auch nicht mehr erreichbar ist, wie kann ich Ihn dann sanft herunterfahren?
      @jwedenig
      Zur allergrößten Not mit dem Unix-Affengriff.
      Erfahrungsgemäß fängt sich die Kiste aber nach einiger Zeit (zumindest soweit, dass wieder ein Zugang per ssh möglich ist). Ich hab meinen Pi eigentlich noch nie hart vom Netz trennen müssen.
      (Vermutlich auch deswegen noch nie Trouble mit der SD-Karte gehabt).
        @jwedenig sagte in Socket Error Pi nicht erreichbar:
        Nur leider wird das gleiche in 2 Tagen wieder passieren, und ich weiss nicht warum!:-(
        Was bedeutet bei dir denn 'Pi neustarten'? Hart vom Strom genommen? Dann passiert nämlich genau das was du jetzt bei dir beobachtest.
        Das Ding will 'wie rohe Eier' behandelt werden, immer sanft herunterfahren.
        da_WoodyD Offline
        da_WoodyD Offline
        @thomas-braun sagte in Socket Error Pi nicht erreichbar:
        nuja, vllt is das beim ioBroker so, mit octoprint bei meinen 3d-druckern praktizier ich das seit 1.5 jahren ohne probleme.
        andererseits musste ich auch schon dem mini-itx einige male den saft brutal entziehen... allerdings mit SSD...
        aber sicher, ist sicher... :)
        @jwedenig du meinst sicher sun disk. die sollten eigentlich keine probs machen...
        J Thomas BraunT 2 Antworten Letzte Antwort
          @jwedenig
          jwedenig
          Unix-Affengriff
          Du meinst Ctrl-Alt-Entf?
          Wenn ja, wie mache ich das beim Pi?
          bezügl. SD Karte: Kann ich die dann weghauen oder geht neu formatieren auch und neu draufspielen?
          • da_WoodyD da_Woody
            jwedenig
            Ja, SanDisk heissen die
              @da_woody sagte in Socket Error Pi nicht erreichbar:
              Dann hast du entweder seit 1,5 Jahren mehr Glück als Verstand oder da sind nicht so viele Dateien gleichzeitig offen (beim ioBroker sind z. B. die Verbindungen zur Datenbank immer offen und werden nur alle paar Minuten gespeichert. Da kommen dann auch oft diese zerkrümelten Dateien her).
              @jwedenig
              Ctrl-Alt-Entf funktioniert nicht (immer) auf Linux-(Servern).
              Das ist etwas komplexer bei Linux/Unix.
              Ich spreche vom REISUB. Schau z. B. hier rein:
              https://de.wikipedia.org/wiki/Klammergriff
              da_WoodyD J 2 Antworten Letzte Antwort
                @jwedenig
                da_WoodyD Offline
                da_WoodyD Offline
                fool.gif suchs dir aus!
                ne, octoprint ist da sicher nicht so anspruchsvoll. strom weg gibts im normalfall ja nur wenn nicht gedruckt wird. was soll da noch offen sein. der werkelt ja beim drucken nur die gcode datei ab und zeigt die GUI an klar gehn da auch daten rum, temp, fortschritt und so, aber sonst...
                  @da_woody Ich würd's aber nicht drauf ankommen lassen. Sauberer shutdown ist immer zu machen.
                    da_WoodyD Offline
                    da_WoodyD Offline
                    @thomas-braun deswegen ärgere ich mich nicht mit blockly...
                    aber ich könnte ja @Negalein quälen, der hat ja rumgefummelt nachdem ich ihm den drucker aufgebaut habe...
                    Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
                      @jwedenig
                      jwedenig
                      schrieb am zuletzt editiert von jwedenig
                      Sorry, bin nochmal lästig!
                      Also, wenn ich mal wieder über Terminal und SSH nicht auf meinen Pi komme und ihn sauber runterfahren möchte, dann verwende ich diese Zeichenfolge, stimmt?
                      Weisst Du mit welcher Tastenkombination am Mac im Terminal ich dies aktiviere?
                      Ich habe nämlich keine SysReq Taste am Lappi
                      -1
                      • J jwedenig
                        @jwedenig AltGr auch nicht? Keine Ahnung von Fallobst und deren Tastaturen.
                          Warum blockly?
                          sudo shutdown
                          und du bist da.
                            Warum blockly?
                            sudo shutdown
                            und du bist da.
                            da_WoodyD Offline
                            da_WoodyD Offline
                            @thomas-braun schon klar, aber ich hab die 3d-drucker an SP112er stecken und dreh mit dem drucker auch den raspi ab... :)
                              @da_woody Da würde ich dann aber noch einen sauberen shutdown reinflicken.
                                da_WoodyD Offline
                                da_WoodyD Offline
                                @thomas-braun ich sprech ja nur den switch an, wo soll ich da ein shutdown reinflicken? kratz.gif
                                  @da_woody
                                  In dem du zuerst den Raspi runterfährst und dann mit 1-2 Minuten verzögerung erst den Strom killst.
                                    @da_woody
                                    da_WoodyD Offline
                                    da_WoodyD Offline
                                    @thomas-braun also script, oder blockly... wie gesagt, ich kill in iQontrol nur sonoff.0.Ender.POWER, oder halt einen anderen drucker.
                                      @da_woody
                                      wie gesagt: Harakiri.
                                        @da_woody
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        @thomas-braun jep, no risk, no fun! ;)
                                        sollts wirklich mal knallen, octoprint is in paar min aufgesezt. SDin PC rein, insten, gut ists.
                                        aber deine warnungen sind absolut berechtigt... :)
                                        W 1 Antwort Letzte Antwort
                                          W Online
                                          W Online
                                          Wildbill
                                          schrieb am zuletzt editiert von Wildbill
                                          @da_woody Gerade der Raspi neigt aber dazu, bei plötzlichem Stromausschalten die SD-Karte zu schreddern, so daß sich diese auch nicht mehr verwenden lässt, weil sie dann defekt ist.
                                          Deinen PC fährst Du doch sicher auch sauber runter und schaltest ihn nicht einfach aus? Wobei das, bei zerstörtem Windows wenigstens ein Anreiz wäre, gleich ein vernünftiges Betriebssystem aufzuspielen...
                                          Ein Raspi ist nix anderes wie Dein Computer, nur anders Betriebssystem.
                                          Gruß, Jürgen
