  4. Test Adapter Solarlog v2.x.x latest
solarlog
76 Beiträge 12 Kommentatoren 12.7k Aufrufe 10 Beobachtet
  • S schmuh
    @forelleblau
    Hi Marcel,
    es kommen noch ein paar kosmetische Logs, guckst du:
    solarlog.0	2021-05-16 09:25:05.046	info	(25442) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
    solarlog.0	2021-05-16 09:25:05.046	info	(25442) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
    solarlog.0	2021-05-16 08:25:06.267	info	(25442) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
    solarlog.0	2021-05-16 08:25:06.267	info	(25442) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
    solarlog.0	2021-05-16 07:25:03.636	info	(25442) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
    solarlog.0	2021-05-16 07:25:03.635	info	(25442) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
    solarlog.0	2021-05-16 06:25:03.860	info	(25442) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
    solarlog.0	2021-05-16 06:25:03.860	info	(25442) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
    Nicht schlimm, aber wenn du mal wieder eine Änderung machst, geht es vielleicht in einem.
    Schönes WE
    Werner
    forelleblau
    schrieb am zuletzt editiert von forelleblau
    @schmuh Hallo Werner
    Ist in der der github-version schon behoben. Hab es nur noch nicht als Version publiziert, weil ich noch etwas warten wollte, ob noch mehr Fehler kommen.
    Ev. muss du aber die bestehenden Objekte vor der Installation löschen, damit sie als 'number' neu angelegt werden.
    Danke vielmal für deine Aufmerksamkeit und herzliche Grüsse
    Marcel
    F 1 Antwort Letzte Antwort
    • Agria4800A Agria4800
      @forelleblau : Auch von meiner Seite aus als "stiller Nutzer" ein DANKE an dich 👍
      Ach, na gut, wenn ich schon dabei bin, dann auch gleich mit ne Frage!
      Ist es für dich ein großer Aufwand, alle DP außer Aktuell von Watt in kW zu ändern?
      Ich mache das aktuell mit JS, dabei generiere ich mir noch den Eigenverbrauch pro Monat(indem ich die Tageswerte addiere) und verrechne somit diese mit Verbrauch und Erzeugung, sodass ich den Bezug und der Ertrag erhalte. Das wäre natürlich auch ein Traum, wenn das der Adapter leiten könnte...
      Okay, jetzt sind es schon 2 Fragen... 😊
      forelleblau
      @agria4800 Hallo Agria4800
      Danke für die Anregung. Mit ändern bin ich da lieber zurückhaltend. Da haben wohl etliche noch Visualisierungen oder eigene Berechnungen hintendran, die dann alle geändert werden müssten.
      Zudem arbeite ich lieber mit Watt, da diese Werte so als Integers im Solarlog geholt werden können. So kann jeder mit den Originalwerten arbeiten.
      Wenn du einzelne Werte gerne zusätzlich als kW im Adapter dargestellt hättest, kann ich das als Zusatz bei Gelegenheit machen, dann sag mir bitte welche.
      Falls jedoch viele/alle lieber kW statt Watt hätten, kann ich das schon ändern, bisher hat aber für mich nichts dafür gesprochen.
      herzliche Grüsse
      forelleblau
      • F forelleblau
        Marcel
        forelleblau
        @forelleblau Hallo Werner. Ist jetzt mit v2.1.3 im latest-repo publizeirt.
        Grüsse Marcel
        • F forelleblau
          Grüsse Marcel
          schmuh
          @forelleblau
          Hallo Marcel,
          Super! Wie du geschrieben hast, musste ich die DP einmal löschen.
          Beste Grüße
          Werner
          • F forelleblau
            herzliche Grüsse
            forelleblau
            schmuh
            @forelleblau sagte in Test Adapter Solarlog v2.0.x latest:
            herzliche Grüsse
            forelleblau
            Ich sehe das genau so wie @forelleblau die Daten so zu verarbeiten, wie sie aus dem SolarLog kommen. Man ist flexibler. Das umrechnen per Script/Blockly ist ja ganz einfach.
            Beste Grüße
            Werner
            Agria4800A 1 Antwort Letzte Antwort
            • S schmuh
              herzliche Grüsse
              forelleblau
              Beste Grüße
              Werner
              Agria4800A Offline
              Agria4800A Offline
              Agria4800
              @schmuh sagte in Test Adapter Solarlog v2.0.x latest:
              herzliche Grüsse
              forelleblau
              Beste Grüße
              Werner
              @forelleblau @schmuh: Da bin ich ja komplett bei Euch, allerdings macht es ja wenig Unterschied, ob man diese im Adapter umrechnet oder per Script und Zahlen im 6-10 stelligen Watt Bereich anzugeben auch nicht... 😊
              Wie gesagt, aktuell berechne ich alles per Script und es funktioniert auch wunderbar.
              Daher habe ich das auch nur als Interesse angesprochen... mir ging es dabei eher um Leute, die diesen Adapter nutzen und nicht so gut mit JS/Blockly sind...
              @forelleblau: Aber wenn du zufällig mal wieder am Adapter überarbeiten bist, über einen Eigenverbrauch als Monatswert würde ich mich freuen... (aktuell wird dieses ja nur so angegeben (wobei Year bei mir nicht gefüllt wird!) 04ec7aeb-d6f9-4f80-916e-fba6b73714f5-image.png
              Grüße und weiter so 👍
                herzliche Grüsse
                forelleblau
                Beste Grüße
                Werner
                forelleblau
                @agria4800 Hallo agria4800
                Welche Version vom Adapter nutzt du mit welchem Solarlog? Und hast du das Importieren der Wechselrichter- und der Historischen Daten aktiviert? Dann sollte eine ganze Reihe mehr Infos zum Eigenverbrauch verfügbar sein:
                Grüsse Forelleblau
                • F forelleblau
                  Grüsse Forelleblau
                  Agria4800A Offline
                  Agria4800A Offline
                  Agria4800
                  @forelleblau : ich habe den solarlog 500 PM+ und die aktuelle Github Version:2.1.3.
                  Importieren der Wechselrichter- und der Historischen Daten aktiviert, --> Ja, natürlich :-)
                  Diese Selfcons-Daten erhalte ich auch, wobei nur wenige gefüllt werden...
                    forelleblau
                    @agria4800
                    Die Monats- und Jahresobjekte werden gesetzt, wenn die Historischen Daten abgerufen werden. Hast du bei den 'Historic' - Werten für das laufende und das letzte Jahr und für den laufenden und den letzten Monat Werte drin?
                    Wenn ja, kannst du mir einmal ein Debug-Log von einem Adapter - Start und von einem Abruf der Historischen Daten (Logeintrag:Langzeitwerte abrufen) schicken / posten.
                    Dann kann ich sehen, was passiert oder eben nicht.
                    Grüsse
                    forelleblau
                    • F forelleblau
                      @agria4800
                      Grüsse
                      forelleblau
                      Agria4800A Offline
                      Agria4800A Offline
                      Agria4800
                      schrieb am zuletzt editiert von Agria4800
                      @agria4800
                      Grüsse
                      forelleblau
                      Servus: Anbei mal ein Debug vom Log
                      solarlog.0	2021-05-21 21:02:17.421	debug	(3091933) stateChange solarlog.0.SelfCons.selfconsratioyesterday {"val":17.2,"ack":true,"ts":1621623737401,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621548219297}
                      solarlog.0	2021-05-21 21:02:17.421	debug	(3091933) stateChange solarlog.0.SelfCons.selfconsyesterday {"val":4383,"ack":true,"ts":1621623737401,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621548219296}
                      solarlog.0	2021-05-21 21:02:17.421	debug	(3091933) stateChange solarlog.0.SelfCons.selfconsratiotoday {"val":45.9,"ack":true,"ts":1621623737401,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623500516}
                      solarlog.0	2021-05-21 21:02:17.415	debug	(3091933) stateChange solarlog.0.SelfCons.selfconstoday {"val":9633,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623690677}
                      solarlog.0	2021-05-21 21:02:17.414	debug	(3091933) stateChange solarlog.0.INV.WR 3.daysum {"val":10563,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623690677}
                      solarlog.0	2021-05-21 21:02:17.414	debug	(3091933) stateChange solarlog.0.INV.WR 2.daysum {"val":10441,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623690677}
                      solarlog.0	2021-05-21 21:02:17.413	debug	(3091933) stateChange solarlog.0.INV.S0-IN A.daysum {"val":15962,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623690677}
                      solarlog.0	2021-05-21 21:02:17.412	debug	(3091933) stateChange solarlog.0.status.consyieldtotal {"val":24100332,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737400}
                      solarlog.0	2021-05-21 21:02:17.412	debug	(3091933) stateChange solarlog.0.status.consyieldyear {"val":1435258,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737400}
                      solarlog.0	2021-05-21 21:02:17.411	debug	(3091933) stateChange solarlog.0.status.consyieldmonth {"val":189586,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737400}
                      solarlog.0	2021-05-21 21:02:17.410	debug	(3091933) stateChange solarlog.0.status.consyieldyesterday {"val":8254,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621548219296}
                      solarlog.0	2021-05-21 21:02:17.410	debug	(3091933) stateChange solarlog.0.status.consyieldday {"val":15972,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737400}
                      solarlog.0	2021-05-21 21:02:17.409	debug	(3091933) stateChange solarlog.0.status.yieldtotal {"val":56679632,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623690671}
                      solarlog.0	2021-05-21 21:02:17.409	debug	(3091933) stateChange solarlog.0.status.yieldyear {"val":2570757,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623690671}
                      solarlog.0	2021-05-21 21:02:17.408	debug	(3091933) stateChange solarlog.0.status.yieldmonth {"val":483603,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623690671}
                      solarlog.0	2021-05-21 21:02:17.408	debug	(3091933) stateChange solarlog.0.status.yieldyesterday {"val":25488,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621548219296}
                      solarlog.0	2021-05-21 21:02:17.408	debug	(3091933) stateChange solarlog.0.status.yieldday {"val":21005,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623690670}
                      solarlog.0	2021-05-21 21:02:17.408	debug	(3091933) stateChange solarlog.0.status.conspac {"val":262,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737400}
                      solarlog.0	2021-05-21 21:02:17.407	debug	(3091933) stateChange solarlog.0.status.udc {"val":413,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737400}
                      solarlog.0	2021-05-21 21:02:17.406	debug	(3091933) stateChange solarlog.0.status.uac {"val":0,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547592571}
                      solarlog.0	2021-05-21 21:02:17.404	debug	(3091933) stateChange solarlog.0.status.pdc {"val":13,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737400}
                      solarlog.0	2021-05-21 21:02:17.403	debug	(3091933) stateChange solarlog.0.status.pac {"val":13,"ack":true,"ts":1621623737400,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737400}
                      solarlog.0	2021-05-21 21:02:17.402	debug	(3091933) stateChange solarlog.0.info.totalPower {"val":6400,"ack":true,"ts":1621623737399,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621094478289}
                      solarlog.0	2021-05-21 21:02:17.401	debug	(3091933) stateChange solarlog.0.info.lastSync {"val":"21.05.21 21:02:15","ack":true,"ts":1621623737399,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623737399}
                      solarlog.0	2021-05-21 21:02:17.391	debug	(3091933) END Request: "token=;preval=none;{\"447\":null,\"777\":{\"0\":null},\"778\":{\"0\":null},\"801\":{\"170\":null}}"
                      solarlog.0	2021-05-21 21:02:17.391	debug	(3091933) Keine Batterie vorhanden
                      solarlog.0	2021-05-21 21:02:17.391	debug	(3091933) Gesternsumme Eigenverbrauch: 4383
                      solarlog.0	2021-05-21 21:02:17.391	debug	(3091933) Gesternwerte SelfCons: 20.05.21,4383,0,0,0
                      solarlog.0	2021-05-21 21:02:17.391	debug	(3091933) Index Tageswerte gestern: 19
                      solarlog.0	2021-05-21 21:02:17.391	debug	(3091933) Monat gestern: 5
                      solarlog.0	2021-05-21 21:02:17.390	debug	(3091933) Gestern: 20.05.21
                      solarlog.0	2021-05-21 21:02:17.390	debug	(3091933) Tagessumme Eigenverbrauch: 9633
                      solarlog.0	2021-05-21 21:02:17.390	debug	(3091933) Tageswerte SelfCons: 21.05.21,9633,0,0,0
                      solarlog.0	2021-05-21 21:02:17.390	debug	(3091933) Index Tageswerte: 20
                      solarlog.0	2021-05-21 21:02:17.390	debug	(3091933) Monat heute: 5
                      solarlog.0	2021-05-21 21:02:17.390	debug	(3091933) Heute: 21.05.21
                      solarlog.0	2021-05-21 21:02:17.390	debug	(3091933) DataSelfCons: 01.05.21,3086,0,0,0,02.05.21,5083,0,0,0,03.05.21,7755,0,0,0,04.05.21,3917,0,0,0,05.05.21,4820,0,0,0,06.05.21,4101,0,0,0,07.05.21,4330,0,0,0,08.05.21,12324,0,0,0,09.05.21,5988,0
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) INV.WR 3: 10563
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) INV.WR 2: 10441
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) INV.S0-IN A: 15962
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) Tagessummen: 15962,10441,10563
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) Index Tageswerte: 20
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) Heute: 21.05.21
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) Anzahl Elemente: 3
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) Inv. to treat: S0-IN A,WR 2,WR 3
                      solarlog.0	2021-05-21 21:02:17.388	debug	(3091933) DataSUZ: 01.05.21,6210,9388,9452,02.05.21,9058,13182,13477,03.05.21,11116,12798,13018,04.05.21,7686,6723,6809,05.05.21,9502,14923,15081,06.05.21,9692,4804,4819,07.05.21,7100,16942,17319,08.0
                      solarlog.0	2021-05-21 21:02:17.387	debug	(3091933) Data801_170: [object Object]
                      solarlog.0	2021-05-21 21:02:17.387	debug	(3091933) Anzahl Elemente: 0
                      solarlog.0	2021-05-21 21:02:17.387	debug	(3091933) Schaltgruppen: ,,,,,,,,,
                      solarlog.0	2021-05-21 21:02:17.387	debug	(3091933) Auswertedaten: {"447":{"0":{"100":"","101":{"0":{"100":255,"101":255},"1":{"100":255,"101":255},"2":{"100":255,"101":255},"3":{"100":255,"101":255},"4":{"100":255,"101":255},"5":{"100":255,"
                      solarlog.0	2021-05-21 21:02:17.386	debug	(3091933) Datensatz: {"447":null,"777":{"0":null},"778":{"0":null},"801":{"170":null}}
                      solarlog.0	2021-05-21 21:02:17.386	debug	(3091933) Verarbeite Daten
                      solarlog.0	2021-05-21 21:02:17.386	debug	(3091933) body: {"447":{"0":{"100":"","101":{"0":{"100":255,"101":255},"1":{"100":255,"101":255},"2":{"100":255,"101":255},"3":{"100":255,"101":255},"4":{"100":255,"101":255},"5":{"100":255,"101":255}
                      solarlog.0	2021-05-21 21:02:17.381	debug	(3091933) HEADERS: {"date":"Fri, 21 May 2021 21:02:20 GMT","server":"IPC@CHIP","content-type":"text/plain","transfer-encoding":"chunked"}
                      solarlog.0	2021-05-21 21:02:17.381	debug	(3091933) http Status: 200
                      solarlog.0	2021-05-21 21:02:16.168	debug	(3091933) stateChange solarlog.0.INV.WR 3.devicebrand {"val":"Steca","ack":true,"ts":1621623736161,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547801824}
                      solarlog.0	2021-05-21 21:02:16.167	debug	(3091933) stateChange solarlog.0.INV.WR 3.devicetype {"val":"Standard","ack":true,"ts":1621623736161,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547801824}
                      solarlog.0	2021-05-21 21:02:16.166	debug	(3091933) stateChange solarlog.0.INV.WR 3.deviceclass {"val":"Wechselrichter","ack":true,"ts":1621623736160,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547801824}
                      solarlog.0	2021-05-21 21:02:16.165	debug	(3091933) stateChange solarlog.0.INV.WR 2.devicebrand {"val":"Steca","ack":true,"ts":1621623736160,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547592495}
                      solarlog.0	2021-05-21 21:02:16.164	debug	(3091933) stateChange solarlog.0.INV.WR 2.devicetype {"val":"Standard","ack":true,"ts":1621623736160,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547592495}
                      solarlog.0	2021-05-21 21:02:16.164	debug	(3091933) stateChange solarlog.0.INV.WR 2.deviceclass {"val":"Wechselrichter","ack":true,"ts":1621623736160,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547592495}
                      solarlog.0	2021-05-21 21:02:16.163	debug	(3091933) stateChange solarlog.0.INV.S0-IN A.devicebrand {"val":"S0In","ack":true,"ts":1621623736160,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547801823}
                      solarlog.0	2021-05-21 21:02:16.162	debug	(3091933) stateChange solarlog.0.INV.S0-IN A.devicetype {"val":"","ack":true,"ts":1621623736160,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547801823}
                      solarlog.0	2021-05-21 21:02:16.162	debug	(3091933) stateChange solarlog.0.INV.S0-IN A.deviceclass {"val":"Zähler","ack":true,"ts":1621623736160,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547801823}
                      solarlog.0	2021-05-21 21:02:16.158	debug	(3091933) Adapter WR 3 vorhanden
                      solarlog.0	2021-05-21 21:02:16.158	debug	(3091933) Adapter WR 2 vorhanden
                      solarlog.0	2021-05-21 21:02:16.158	debug	(3091933) Adapter S0-IN A vorhanden
                      solarlog.0	2021-05-21 21:02:16.155	debug	(3091933) Data to request body: token=;preval=none;{"447":null,"777":{"0":null},"778":{"0":null},"801":{"170":null}}
                      solarlog.0	2021-05-21 21:02:16.155	debug	(3091933) OPTIONS: {"host":"192.168.178.34","port":"80","path":"/getjp","method":"POST","headers":{"Accept":"*/*","Accept-Encoding":"gzip, deflate","Connection":"keep-alive","Content-Type":"applicatio
                      solarlog.0	2021-05-21 21:02:16.155	debug	(3091933) DATA: token=;preval=none;{"447":null,"777":{"0":null},"778":{"0":null},"801":{"170":null}}DATALENGTH: 84
                      solarlog.0	2021-05-21 21:02:16.154	debug	(3091933) Names: S0-IN A,WR 2,WR 3
                      solarlog.0	2021-05-21 21:02:16.154	info	(3091933) Alle WR/Zaehler gefunden
                      solarlog.0	2021-05-21 21:02:16.154	debug	(3091933) Anzahl positiv: 3
                      solarlog.0	2021-05-21 21:02:16.154	debug	(3091933) numbinv: 3
                      solarlog.0	2021-05-21 21:02:16.154	debug	(3091933) Inverters to test: S0-IN A,WR 2,WR 3
                      solarlog.0	2021-05-21 21:02:14.156	debug	(3091933) Adapter WR 3 vorhanden
                      solarlog.0	2021-05-21 21:02:14.156	debug	(3091933) Adapter WR 2 vorhanden
                      solarlog.0	2021-05-21 21:02:14.156	debug	(3091933) Adapter S0-IN A vorhanden
                      solarlog.0	2021-05-21 21:02:14.154	warn	(3091933) Nicht alle WR/Zaehler gefunden
                      solarlog.0	2021-05-21 21:02:14.154	debug	(3091933) Anzahl positiv: 0
                      solarlog.0	2021-05-21 21:02:14.154	debug	(3091933) numbinv: 3
                      solarlog.0	2021-05-21 21:02:14.154	debug	(3091933) Inverters to test: S0-IN A,WR 2,WR 3
                      solarlog.0	2021-05-21 21:02:13.700	debug	(3091933) stateChange solarlog.0.forecast.setpointToday {"val":23.466666666666665,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1617861513826}
                      solarlog.0	2021-05-21 21:02:13.700	debug	(3091933) stateChange solarlog.0.forecast.setpointCurrMonth {"val":704,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1617861513826}
                      solarlog.0	2021-05-21 21:02:13.700	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.12 {"val":192,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.699	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.11 {"val":256,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.699	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.10 {"val":384,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.699	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.09 {"val":640,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.699	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.08 {"val":768,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.699	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.07 {"val":832,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.697	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.06 {"val":832,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.697	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.05 {"val":704,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.697	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.04 {"val":704,"ack":true,"ts":1621623733657,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.696	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.03 {"val":576,"ack":true,"ts":1621623733656,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.696	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.02 {"val":384,"ack":true,"ts":1621623733656,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.696	debug	(3091933) stateChange solarlog.0.forecast.setpointMonth.01 {"val":128,"ack":true,"ts":1621623733656,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.696	debug	(3091933) stateChange solarlog.0.forecast.setpointYear {"val":6400,"ack":true,"ts":1621623733656,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.693	debug	(3091933) stateChange solarlog.0.info.SD {"val":"[39|PH|acon |000C086D] - 9/2020","ack":true,"ts":1621623733568,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608474861586}
                      solarlog.0	2021-05-21 21:02:13.693	debug	(3091933) stateChange solarlog.0.info.FWrelD {"val":"15.10.2019","ack":true,"ts":1621623733568,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.693	debug	(3091933) stateChange solarlog.0.info.FW {"val":"3.6.0 Build 99","ack":true,"ts":1621623733568,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.693	debug	(3091933) stateChange solarlog.0.info.InstDate {"val":"01.02.13 00:00:00","ack":true,"ts":1621623733568,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419616}
                      solarlog.0	2021-05-21 21:02:13.693	debug	(3091933) stateChange solarlog.0.info.Model {"val":"500","ack":true,"ts":1621623733568,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621063576386}
                      solarlog.0	2021-05-21 21:02:13.693	debug	(3091933) stateChange solarlog.0.info.SN {"val":"1079739848","ack":true,"ts":1621623733567,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607547341630}
                      solarlog.0	2021-05-21 21:02:13.692	debug	(3091933) stateChange solarlog.0.info.MAC {"val":"003056A4B303","ack":true,"ts":1621623733567,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419615}
                      solarlog.0	2021-05-21 21:02:13.682	debug	(3091933) stateChange solarlog.0.info.CLIB {"val":"V3.00","ack":true,"ts":1621623733567,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419615}
                      solarlog.0	2021-05-21 21:02:13.681	debug	(3091933) stateChange solarlog.0.info.RTOS {"val":"SC123/SC143 V2.05 FULL","ack":true,"ts":1621623733567,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419615}
                      solarlog.0	2021-05-21 21:02:13.673	debug	(3091933) stateChange solarlog.0.info.numinv {"val":3,"ack":true,"ts":1621623733567,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1608478419615}
                      solarlog.0	2021-05-21 21:02:13.574	debug	(3091933) END Request: "token=;preval=none;{\"141\":{\"0\":{\"119\":null,\"162\":null},\"1\":{\"119\":null,\"162\":null},\"2\":{\"119\":null,\"162\":null}}}"
                      solarlog.0	2021-05-21 21:02:13.573	debug	(3091933) Schaltgruppen: ,,,,,,,,,
                      solarlog.0	2021-05-21 21:02:13.573	debug	(3091933) Anzahl Schaltgruppen: 0
                      solarlog.0	2021-05-21 21:02:13.573	debug	(3091933) Names zum anlegen: S0-IN A,WR 2,WR 3
                      solarlog.0	2021-05-21 21:02:13.573	debug	(3091933) NumInv Obj: 4
                      solarlog.0	2021-05-21 21:02:13.573	debug	(3091933) Lege nun Objekte an - soweit nicht vorhanden 2
                      solarlog.0	2021-05-21 21:02:13.572	debug	(3091933) Deviceclasses: Zähler,Wechselrichter,Wechselrichter
                      solarlog.0	2021-05-21 21:02:13.572	debug	(3091933) Devicebrands: S0In,Steca,Steca
                      solarlog.0	2021-05-21 21:02:13.572	debug	(3091933) Devicetypes: ,Standard,Standard
                      solarlog.0	2021-05-21 21:02:13.572	debug	(3091933) Batterie als Gerät: false
                      solarlog.0	2021-05-21 21:02:13.571	debug	(3091933) INV.WR 3.devicebrand: Steca
                      solarlog.0	2021-05-21 21:02:13.571	debug	(3091933) INV.WR 3.devicetype: Standard
                      solarlog.0	2021-05-21 21:02:13.571	debug	(3091933) Batterie als Gerät: false
                      solarlog.0	2021-05-21 21:02:13.571	debug	(3091933) INV.WR 2.devicebrand: Steca
                      solarlog.0	2021-05-21 21:02:13.571	debug	(3091933) INV.WR 2.devicetype: Standard
                      solarlog.0	2021-05-21 21:02:13.571	debug	(3091933) INV.S0-IN A.devicebrand: S0In
                      solarlog.0	2021-05-21 21:02:13.571	debug	(3091933) INV.S0-IN A.devicetype:
                      solarlog.0	2021-05-21 21:02:13.571	debug	(3091933) Deviceinfos: 9,32,32
                      solarlog.0	2021-05-21 21:02:13.570	debug	(3091933) Inverters: S0-IN A,WR 2,WR 3
                      solarlog.0	2021-05-21 21:02:13.570	debug	(3091933) Deviceinfos: 9,32
                      solarlog.0	2021-05-21 21:02:13.570	debug	(3091933) Auswertedaten: {"141":{"0":{"119":"S0-IN A","162":9},"1":{"119":"WR 2","162":32},"2":{"119":"WR 3","162":32}}}
                      solarlog.0	2021-05-21 21:02:13.570	debug	(3091933) Datensatz: {"141":{"0":{"119":null,"162":null},"1":{"119":null,"162":null},"2":{"119":null,"162":null}}}
                      solarlog.0	2021-05-21 21:02:13.570	debug	(3091933) Verarbeite Daten
                      solarlog.0	2021-05-21 21:02:13.570	debug	(3091933) body: {"141":{"0":{"119":"S0-IN A","162":9},"1":{"119":"WR 2","162":32},"2":{"119":"WR 3","162":32}}}
                      solarlog.0	2021-05-21 21:02:13.569	debug	(3091933) HEADERS: {"date":"Fri, 21 May 2021 21:02:16 GMT","server":"IPC@CHIP","content-type":"text/plain","transfer-encoding":"chunked"}
                      solarlog.0	2021-05-21 21:02:13.569	debug	(3091933) http Status: 200
                      solarlog.0	2021-05-21 21:02:13.528	debug	(3091933) END Request: "token=;preval=none;{\"152\":null,\"161\":null,\"162\":null,\"447\":null,\"610\":null,\"611\":null,\"617\":null,\"706\":null,\"739\":null,\"740\":null,\"744\":null,\"800\":{\"10
                      solarlog.0	2021-05-21 21:02:13.528	debug	(3091933) Batteriestatus: false
                      solarlog.0	2021-05-21 21:02:13.528	debug	(3091933) Keine Batterie vorhanden.
                      solarlog.0	2021-05-21 21:02:13.528	debug	(3091933) Battdata:
                      solarlog.0	2021-05-21 21:02:13.513	debug	(3091933) Schaltgruppen neu: ,,,,,,,,,
                      solarlog.0	2021-05-21 21:02:13.513	debug	(3091933) namessg = ,,,,,,,,,
                      solarlog.0	2021-05-21 21:02:13.513	debug	(3091933) Anzahl Schaltgruppen: 0
                      solarlog.0	2021-05-21 21:02:13.509	debug	(3091933) Schaltgruppendaten: [object Object]
                      solarlog.0	2021-05-21 21:02:13.508	debug	(3091933) Data to request body: token=;preval=none;{"141":{"0":{"119":null,"162":null},"1":{"119":null,"162":null},"2":{"119":null,"162":null}}}
                      solarlog.0	2021-05-21 21:02:13.508	debug	(3091933) OPTIONS: {"host":"192.168.178.34","port":"80","path":"/getjp","method":"POST","headers":{"Accept":"*/*","Accept-Encoding":"gzip, deflate","Connection":"keep-alive","Content-Type":"applicatio
                      solarlog.0	2021-05-21 21:02:13.508	debug	(3091933) DATA: token=;preval=none;{"141":{"0":{"119":null,"162":null},"1":{"119":null,"162":null},"2":{"119":null,"162":null}}}DATALENGTH: 112
                      solarlog.0	2021-05-21 21:02:13.508	debug	(3091933) Numer of inverters/meters :3
                      solarlog.0	2021-05-21 21:02:13.507	debug	(3091933) List of Inverters: [object Object]
                      solarlog.0	2021-05-21 21:02:13.507	debug	(3091933) Brandlist: [object Object]
                      solarlog.0	2021-05-21 21:02:13.507	debug	(3091933) Devicelist: 0,,,0,0,0,0,,0,2,Data1,SMA,1200,1,7,1,,0,3,,,9600,1,1,2,kaco485.dll,0,4,,Sunways,9600,1,1,3,,0,5,,,19200,9,1,4,solarmax.dll,0,6,SolarNet,Fronius,57600,2,1,5,,0,7,,Danfoss,19200,1
                      solarlog.0	2021-05-21 21:02:13.505	debug	(3091933) Auswertedaten: {"152":{"0":2,"1":6,"2":9,"3":11,"4":11,"5":13,"6":13,"7":12,"8":10,"9":6,"10":4,"11":3},"161":6400,"162":1000,"447":{"0":{"100":"","101":{"0":{"100":255,"101":255},"1":{"100"
                      solarlog.0	2021-05-21 21:02:13.505	debug	(3091933) Datensatz: {"152":null,"161":null,"162":null,"447":null,"610":null,"611":null,"617":null,"706":null,"739":null,"740":null,"744":null,"800":{"100":null,"160":null},"801":{"101":null,"102":nul
                      solarlog.0	2021-05-21 21:02:13.505	debug	(3091933) Verarbeite Daten
                      solarlog.0	2021-05-21 21:02:13.502	debug	(3091933) body: {"152":{"0":2,"1":6,"2":9,"3":11,"4":11,"5":13,"6":13,"7":12,"8":10,"9":6,"10":4,"11":3},"161":6400,"162":1000,"447":{"0":{"100":"","101":{"0":{"100":255,"101":255},"1":{"100":255,"101
                      solarlog.0	2021-05-21 21:02:13.482	debug	(3091933) HEADERS: {"date":"Fri, 21 May 2021 21:02:16 GMT","server":"IPC@CHIP","content-type":"text/plain","transfer-encoding":"chunked"}
                      solarlog.0	2021-05-21 21:02:13.481	debug	(3091933) http Status: 200
                      solarlog.0	2021-05-21 21:02:12.656	debug	(3091933) Data to request body: token=;preval=none;{"152":null,"161":null,"162":null,"447":null,"610":null,"611":null,"617":null,"706":null,"739":null,"740":null,"744":null,"800":{"100":null,"160":nul
                      solarlog.0	2021-05-21 21:02:12.654	debug	(3091933) OPTIONS: {"host":"192.168.178.34","port":"80","path":"/getjp","method":"POST","headers":{"Accept":"*/*","Accept-Encoding":"gzip, deflate","Connection":"keep-alive","Content-Type":"applicatio
                      solarlog.0	2021-05-21 21:02:12.653	debug	(3091933) DATA: token=;preval=none;{"152":null,"161":null,"162":null,"447":null,"610":null,"611":null,"617":null,"706":null,"739":null,"740":null,"744":null,"800":{"100":null,"160":null},"801":{"101":
                      solarlog.0	2021-05-21 21:02:12.176	debug	(3091933) stateChange solarlog.0.info.connection {"val":true,"ack":true,"ts":1621623732174,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621623732174}
                      solarlog.0	2021-05-21 21:02:12.152	debug	(3091933) WR Importieren
                      solarlog.0	2021-05-21 21:02:12.152	debug	(3091933) uzimp: true
                      solarlog.0	2021-05-21 21:02:12.152	debug	(3091933) [START] Started Adapter with: 192.168.178.34
                      solarlog.0	2021-05-21 21:02:12.152	debug	(3091933) [INFO] Configured polling interval averages&other: 300000
                      solarlog.0	2021-05-21 21:02:12.152	debug	(3091933) [INFO] Configured polling interval consuption/production: 30000
                      solarlog.0	2021-05-21 21:02:12.152	info	(3091933) Forecast - Datenabruf: false
                      solarlog.0	2021-05-21 21:02:12.152	info	(3091933) Rufe historische Daten um 5:00 ab
                      solarlog.0	2021-05-21 21:02:12.152	info	(3091933) Unterzähler - Import: true
                      solarlog.0	2021-05-21 21:02:12.152	debug	(3091933) LOVE - Ich liebe euch!
                      solarlog.0	2021-05-21 21:02:12.150	info	(3091933) [START] Starting solarlog adapter
                      solarlog.0	2021-05-21 21:02:12.141	info	(3091933) starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.solarlog, node: v12.22.1, js-controller: 3.2.16
                      host.nuc1	2021-05-21 21:02:11.418	info	instance system.adapter.solarlog.0 started with pid 3091933
                      host.nuc1	2021-05-21 21:02:08.948	info	instance system.adapter.solarlog.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      host.nuc1	2021-05-21 21:02:08.394	info	stopInstance system.adapter.solarlog.0 send kill signal
                      solarlog.0	2021-05-21 21:02:08.394	info	(3091215) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      solarlog.0	2021-05-21 21:02:08.393	info	(3091215) terminating
                      solarlog.0	2021-05-21 21:02:08.393	info	(3091215) [END] Stopping solarlog adapter...
                      solarlog.0	2021-05-21 21:02:08.391	info	(3091215) Got terminate signal TERMINATE_YOURSELF
                      host.nuc1	2021-05-21 21:02:08.385	info	stopInstance system.adapter.solarlog.0 (force=false, process=true)
                      hier in der Datei einen längeren Log:
                      Solarlog Adapter Logfile.rtf
                      und hier meine Einstellung:
                        @agria4800
                        Grüsse
                        forelleblau
                        forelleblau
                        @agria4800 Hallo agria4800. Der Teil vom Log sieht gut aus, da werden die Werte geschrieben, die du siehst. Das was scheinbar nicht klappt passtiert beim Abrufen der Langzeitwerte / Historie, die du auf 05.00 morgens eingestellt hast.
                        Kannst du mir den Teil auch noch zur Verfügung stellen.
                        • F forelleblau
                          Agria4800A Offline
                          Agria4800A Offline
                          Agria4800
                          Ja klar, hätte ich auch selbst drauf kommen können... sorry
                          Log Langzeitwerte
                             Zeit
                          debug
                          Meldung
                          solarlog.0	2021-05-22 18:24:01.471	debug	(3947767) stateChange solarlog.0.SelfCons.selfconsratiolastyear {"val":null,"ack":true,"ts":1621700641368,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621700641368}
                          solarlog.0	2021-05-22 18:24:01.470	debug	(3947767) stateChange solarlog.0.SelfCons.selfconsratioyear {"val":null,"ack":true,"ts":1621700641368,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621700641368}
                          solarlog.0	2021-05-22 18:24:01.466	debug	(3947767) stateChange solarlog.0.SelfCons.selfconslastyear {"val":null,"ack":true,"ts":1621700641368,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.466	debug	(3947767) stateChange solarlog.0.SelfCons.selfconsyear {"val":null,"ack":true,"ts":1621700641368,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.466	debug	(3947767) stateChange solarlog.0.Historic.200.selfconsyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.466	debug	(3947767) stateChange solarlog.0.Historic.200.consyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.466	debug	(3947767) stateChange solarlog.0.Historic.200.yieldyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.465	debug	(3947767) stateChange solarlog.0.Historic.200.consyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.465	debug	(3947767) stateChange solarlog.0.Historic.200.yieldyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.465	debug	(3947767) stateChange solarlog.0.Historic.200.selfconsyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.464	debug	(3947767) stateChange solarlog.0.Historic.200.consyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.464	debug	(3947767) stateChange solarlog.0.Historic.200.yieldyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020672}
                          solarlog.0	2021-05-22 18:24:01.464	debug	(3947767) stateChange solarlog.0.Historic.20 .selfconsyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.463	debug	(3947767) stateChange solarlog.0.Historic.20 .consyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.463	debug	(3947767) stateChange solarlog.0.Historic.20 .yieldyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.461	debug	(3947767) stateChange solarlog.0.Historic.20E.selfconsyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.461	debug	(3947767) stateChange solarlog.0.Historic.20E.consyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.461	debug	(3947767) stateChange solarlog.0.Historic.20E.yieldyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.461	debug	(3947767) stateChange solarlog.0.Historic.20L.selfconsyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.459	debug	(3947767) stateChange solarlog.0.Historic.20L.consyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.459	debug	(3947767) stateChange solarlog.0.Historic.20L.yieldyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.459	debug	(3947767) stateChange solarlog.0.Historic.20B.selfconsyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.454	debug	(3947767) stateChange solarlog.0.Historic.20B.consyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.453	debug	(3947767) stateChange solarlog.0.Historic.20B.yieldyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.453	debug	(3947767) stateChange solarlog.0.Historic.20I.selfconsyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.453	debug	(3947767) stateChange solarlog.0.Historic.20I.consyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.453	debug	(3947767) stateChange solarlog.0.Historic.20I.yieldyear {"val":null,"ack":true,"ts":1621700641367,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.453	debug	(3947767) stateChange solarlog.0.Historic.20S.selfconsyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.453	debug	(3947767) stateChange solarlog.0.Historic.20S.consyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.453	debug	(3947767) stateChange solarlog.0.Historic.20S.yieldyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.446	debug	(3947767) stateChange solarlog.0.Historic.20O.selfconsyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.446	debug	(3947767) stateChange solarlog.0.Historic.20O.consyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.446	debug	(3947767) stateChange solarlog.0.Historic.20O.yieldyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.445	debug	(3947767) stateChange solarlog.0.Historic.20P.selfconsyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.445	debug	(3947767) stateChange solarlog.0.Historic.20P.consyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.444	debug	(3947767) stateChange solarlog.0.Historic.20P.yieldyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.444	debug	(3947767) stateChange solarlog.0.Historic.20M.selfconsyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.444	debug	(3947767) stateChange solarlog.0.Historic.20M.consyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.442	debug	(3947767) stateChange solarlog.0.Historic.20M.yieldyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.442	debug	(3947767) stateChange solarlog.0.Historic.20I.selfconsyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.439	debug	(3947767) stateChange solarlog.0.Historic.20I.consyear {"val":null,"ack":true,"ts":1621700641366,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.439	debug	(3947767) stateChange solarlog.0.Historic.20I.yieldyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.438	debug	(3947767) stateChange solarlog.0.Historic.20 .selfconsyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.437	debug	(3947767) stateChange solarlog.0.Historic.20 .consyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.437	debug	(3947767) stateChange solarlog.0.Historic.20 .yieldyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.435	debug	(3947767) stateChange solarlog.0.Historic.20Y.selfconsyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.435	debug	(3947767) stateChange solarlog.0.Historic.20Y.consyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.434	debug	(3947767) stateChange solarlog.0.Historic.20Y.yieldyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.434	debug	(3947767) stateChange solarlog.0.Historic.20R.selfconsyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.433	debug	(3947767) stateChange solarlog.0.Historic.20R.consyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.433	debug	(3947767) stateChange solarlog.0.Historic.20R.yieldyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.433	debug	(3947767) stateChange solarlog.0.Historic.20E.selfconsyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.433	debug	(3947767) stateChange solarlog.0.Historic.20E.consyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.432	debug	(3947767) stateChange solarlog.0.Historic.20E.yieldyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020651}
                          solarlog.0	2021-05-22 18:24:01.432	debug	(3947767) stateChange solarlog.0.Historic.20U.selfconsyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.431	debug	(3947767) stateChange solarlog.0.Historic.20U.consyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.430	debug	(3947767) stateChange solarlog.0.Historic.20U.yieldyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.430	debug	(3947767) stateChange solarlog.0.Historic.20Q.selfconsyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.429	debug	(3947767) stateChange solarlog.0.Historic.20Q.consyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.428	debug	(3947767) stateChange solarlog.0.Historic.20Q.yieldyear {"val":null,"ack":true,"ts":1621700641365,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.427	debug	(3947767) stateChange solarlog.0.SelfCons.selfconsratiolastmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621700641364}
                          solarlog.0	2021-05-22 18:24:01.426	debug	(3947767) stateChange solarlog.0.SelfCons.selfconsratiomonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621700641364}
                          solarlog.0	2021-05-22 18:24:01.425	debug	(3947767) stateChange solarlog.0.SelfCons.selfconslastmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.425	debug	(3947767) stateChange solarlog.0.SelfCons.selfconsmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.423	debug	(3947767) stateChange solarlog.0.Historic.200.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.423	debug	(3947767) stateChange solarlog.0.Historic.200.monthly..consmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.423	debug	(3947767) stateChange solarlog.0.Historic.200.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.422	debug	(3947767) stateChange solarlog.0.Historic.200.monthly..consmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020650}
                          solarlog.0	2021-05-22 18:24:01.421	debug	(3947767) stateChange solarlog.0.Historic.200.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.421	debug	(3947767) stateChange solarlog.0.Historic.20 .monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.421	debug	(3947767) stateChange solarlog.0.Historic.20 .monthly..consmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.421	debug	(3947767) stateChange solarlog.0.Historic.20 .monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.421	debug	(3947767) stateChange solarlog.0.Historic.20E.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.418	debug	(3947767) stateChange solarlog.0.Historic.20E.monthly..consmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.417	debug	(3947767) stateChange solarlog.0.Historic.20E.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.417	debug	(3947767) stateChange solarlog.0.Historic.20L.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.417	debug	(3947767) stateChange solarlog.0.Historic.20L.monthly..consmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.417	debug	(3947767) stateChange solarlog.0.Historic.20L.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.417	debug	(3947767) stateChange solarlog.0.Historic.20B.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.417	debug	(3947767) stateChange solarlog.0.Historic.20B.monthly..consmonth {"val":null,"ack":true,"ts":1621700641364,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.417	debug	(3947767) stateChange solarlog.0.Historic.20B.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641363,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.416	debug	(3947767) stateChange solarlog.0.Historic.20I.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641363,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.416	debug	(3947767) stateChange solarlog.0.Historic.20I.monthly..consmonth {"val":null,"ack":true,"ts":1621700641363,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.416	debug	(3947767) stateChange solarlog.0.Historic.20I.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.416	debug	(3947767) stateChange solarlog.0.Historic.20S.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.416	debug	(3947767) stateChange solarlog.0.Historic.20S.monthly..consmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.416	debug	(3947767) stateChange solarlog.0.Historic.20S.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.415	debug	(3947767) stateChange solarlog.0.Historic.20S.monthly..consmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.411	debug	(3947767) stateChange solarlog.0.Historic.20S.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.411	debug	(3947767) stateChange solarlog.0.Historic.20O.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.411	debug	(3947767) stateChange solarlog.0.Historic.20O.monthly..consmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.411	debug	(3947767) stateChange solarlog.0.Historic.20O.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.411	debug	(3947767) stateChange solarlog.0.Historic.20P.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.410	debug	(3947767) stateChange solarlog.0.Historic.20P.monthly..consmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.410	debug	(3947767) stateChange solarlog.0.Historic.20P.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020648}
                          solarlog.0	2021-05-22 18:24:01.410	debug	(3947767) stateChange solarlog.0.Historic.20M.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641347,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020648}
                          solarlog.0	2021-05-22 18:24:01.410	debug	(3947767) stateChange solarlog.0.Historic.20M.monthly..consmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020648}
                          solarlog.0	2021-05-22 18:24:01.410	debug	(3947767) stateChange solarlog.0.Historic.20M.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020648}
                          solarlog.0	2021-05-22 18:24:01.410	debug	(3947767) stateChange solarlog.0.Historic.20I.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.410	debug	(3947767) stateChange solarlog.0.Historic.20I.monthly..consmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.410	debug	(3947767) stateChange solarlog.0.Historic.20I.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.409	debug	(3947767) stateChange solarlog.0.Historic.20 .monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.409	debug	(3947767) stateChange solarlog.0.Historic.20 .monthly..consmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.409	debug	(3947767) stateChange solarlog.0.Historic.20 .monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.409	debug	(3947767) stateChange solarlog.0.Historic.20Y.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.392	debug	(3947767) stateChange solarlog.0.Historic.20Y.monthly..consmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.391	debug	(3947767) stateChange solarlog.0.Historic.20Y.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.391	debug	(3947767) stateChange solarlog.0.Historic.20R.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.391	debug	(3947767) stateChange solarlog.0.Historic.20R.monthly..consmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.390	debug	(3947767) stateChange solarlog.0.Historic.20R.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.390	debug	(3947767) stateChange solarlog.0.Historic.20E.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.390	debug	(3947767) stateChange solarlog.0.Historic.20E.monthly..consmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.389	debug	(3947767) stateChange solarlog.0.Historic.20E.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020649}
                          solarlog.0	2021-05-22 18:24:01.389	debug	(3947767) stateChange solarlog.0.Historic.20U.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641346,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.386	debug	(3947767) stateChange solarlog.0.Historic.20U.monthly..consmonth {"val":null,"ack":true,"ts":1621700641345,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.386	debug	(3947767) stateChange solarlog.0.Historic.20U.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.385	debug	(3947767) stateChange solarlog.0.Historic.20Q.monthly..selfconsmonth {"val":null,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.384	debug	(3947767) stateChange solarlog.0.Historic.20Q.monthly..consmonth {"val":null,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.383	debug	(3947767) stateChange solarlog.0.Historic.20Q.monthly..yieldmonth {"val":null,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.382	debug	(3947767) stateChange solarlog.0.Historic.2021.yieldyearINV.WR 3 {"val":1308372,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621700641340}
                          solarlog.0	2021-05-22 18:24:01.382	debug	(3947767) stateChange solarlog.0.Historic.2021.yieldyearINV.WR 2 {"val":1289281,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621700641340}
                          solarlog.0	2021-05-22 18:24:01.381	debug	(3947767) stateChange solarlog.0.Historic.2021.yieldyearINV.S0-IN A {"val":1447178,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1621700641340}
                          solarlog.0	2021-05-22 18:24:01.380	debug	(3947767) stateChange solarlog.0.Historic.2020.yieldyearINV.WR 3 {"val":3396617,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1609498800669}
                          solarlog.0	2021-05-22 18:24:01.380	debug	(3947767) stateChange solarlog.0.Historic.2020.yieldyearINV.WR 2 {"val":3351406,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1609498800669}
                          solarlog.0	2021-05-22 18:24:01.379	debug	(3947767) stateChange solarlog.0.Historic.2020.yieldyearINV.S0-IN A {"val":3270575,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1609498800667}
                          solarlog.0	2021-05-22 18:24:01.379	debug	(3947767) stateChange solarlog.0.Historic.2019.yieldyearINV.WR 3 {"val":3468348,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.378	debug	(3947767) stateChange solarlog.0.Historic.2019.yieldyearINV.WR 2 {"val":3435139,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.378	debug	(3947767) stateChange solarlog.0.Historic.2019.yieldyearINV.S0-IN A {"val":3554154,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.377	debug	(3947767) stateChange solarlog.0.Historic.2018.yieldyearINV.WR 3 {"val":3559394,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.377	debug	(3947767) stateChange solarlog.0.Historic.2018.yieldyearINV.WR 2 {"val":3508219,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.376	debug	(3947767) stateChange solarlog.0.Historic.2018.yieldyearINV.S0-IN A {"val":3325680,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.376	debug	(3947767) stateChange solarlog.0.Historic.2017.yieldyearINV.WR 3 {"val":3468701,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.375	debug	(3947767) stateChange solarlog.0.Historic.2017.yieldyearINV.WR 2 {"val":3444231,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.375	debug	(3947767) stateChange solarlog.0.Historic.2017.yieldyearINV.S0-IN A {"val":3120604,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.374	debug	(3947767) stateChange solarlog.0.Historic.2016.yieldyearINV.WR 3 {"val":3151067,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.374	debug	(3947767) stateChange solarlog.0.Historic.2016.yieldyearINV.WR 2 {"val":3146904,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020645}
                          solarlog.0	2021-05-22 18:24:01.373	debug	(3947767) stateChange solarlog.0.Historic.2016.yieldyearINV.S0-IN A {"val":2801383,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.373	debug	(3947767) stateChange solarlog.0.Historic.2015.yieldyearINV.WR 3 {"val":3480237,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.373	debug	(3947767) stateChange solarlog.0.Historic.2015.yieldyearINV.WR 2 {"val":3479966,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.372	debug	(3947767) stateChange solarlog.0.Historic.2015.yieldyearINV.S0-IN A {"val":2593876,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.372	debug	(3947767) stateChange solarlog.0.Historic.2014.yieldyearINV.WR 3 {"val":3344127,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.371	debug	(3947767) stateChange solarlog.0.Historic.2014.yieldyearINV.WR 2 {"val":3327192,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.369	debug	(3947767) stateChange solarlog.0.Historic.2014.yieldyearINV.S0-IN A {"val":2042780,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.369	debug	(3947767) stateChange solarlog.0.Historic.2013.yieldyearINV.WR 3 {"val":3295632,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.369	debug	(3947767) stateChange solarlog.0.Historic.2013.yieldyearINV.WR 2 {"val":3251695,"ack":true,"ts":1621700641340,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.369	debug	(3947767) stateChange solarlog.0.Historic.2013.yieldyearINV.S0-IN A {"val":1956022,"ack":true,"ts":1621700641339,"q":0,"from":"system.adapter.solarlog.0","user":"system.user.admin","lc":1607848020644}
                          solarlog.0	2021-05-22 18:24:01.255	debug	(3947767) END Request: "token=;preval=none;{\"854\":null,\"877\":null,\"878\":null}"
                          solarlog.0	2021-05-22 18:24:01.254	debug	(3947767) DataYear: QUERY IMPOSSIBLE 000
                          solarlog.0	2021-05-22 18:24:01.253	debug	(3947767) DataMonth: QUERY IMPOSSIBLE 000
                          solarlog.0	2021-05-22 18:24:01.252	debug	(3947767) Anzahl Elemente: 3
                          solarlog.0	2021-05-22 18:24:01.252	debug	(3947767) Inv. to treat: S0-IN A,WR 2,WR 3
                          solarlog.0	2021-05-22 18:24:01.252	debug	(3947767) DataYear: 01.01.13,1956022,3251695,3295632,01.01.14,2042780,3327192,3344127,01.01.15,2593876,3479966,3480237,01.01.16,2801383,3146904,3151067,01.01.17,3120604,3444231,3468701,01.01.18,332568
                          solarlog.0	2021-05-22 18:24:01.252	debug	(3947767) Auswertedaten: {"854":[["01.01.13",[1956022,3251695,3295632]],["01.01.14",[2042780,3327192,3344127]],["01.01.15",[2593876,3479966,3480237]],["01.01.16",[2801383,3146904,3151067]],["01.01.17"
                          solarlog.0	2021-05-22 18:24:01.252	debug	(3947767) Datensatz: {"854":null,"877":null,"878":null}
                          solarlog.0	2021-05-22 18:24:01.252	debug	(3947767) Verarbeite Daten
                          solarlog.0	2021-05-22 18:24:01.252	debug	(3947767) body: {"854":[["01.01.13",[1956022,3251695,3295632]],["01.01.14",[2042780,3327192,3344127]],["01.01.15",[2593876,3479966,3480237]],["01.01.16",[2801383,3146904,3151067]],["01.01.17",[3120604
                          solarlog.0	2021-05-22 18:24:01.247	debug	(3947767) HEADERS: {"date":"Sat, 22 May 2021 18:24:03 GMT","server":"IPC@CHIP","content-type":"text/plain","transfer-encoding":"chunked"}
                          solarlog.0	2021-05-22 18:24:01.246	debug	(3947767) http Status: 200
                          solarlog.0	2021-05-22 18:24:00.015	debug	(3947767) Data to request body: token=;preval=none;{"854":null,"877":null,"878":null}
                          solarlog.0	2021-05-22 18:24:00.014	debug	(3947767) OPTIONS: {"host":"192.168.178.34","port":"80","path":"/getjp","method":"POST","headers":{"Accept":"*/*","Accept-Encoding":"gzip, deflate","Connection":"keep-alive","Content-Type":"applicatio
                          solarlog.0	2021-05-22 18:24:00.014	debug	(3947767) DATA: token=;preval=none;{"854":null,"877":null,"878":null}DATALENGTH: 53
                          solarlog.0	2021-05-22 18:24:00.014	info	(3947767) Langzeitwerte abrufen
                          F 1 Antwort Letzte Antwort
                          • Agria4800A Agria4800
                            @forelleblau sagte in Test Adapter Solarlog v2.0.x latest:
                            Log Langzeitwerte
                               Zeit
                            debug
                            Meldung
                            forelleblau
                            @agria4800 Danke, ja genau das. Kannst du mir das wieder als Datei zur Verfügung stellen. Im geposteten sind die Zeilen abgeschnitten (z.B. body: {....) und ich seh nicht die ganzen Daten die hin und her gehen. Sehe nur was nicht funktioniert.
                            Agria4800A 1 Antwort Letzte Antwort
                            • F forelleblau
                              Agria4800A Offline
                              Agria4800A Offline
                              Agria4800
                              ja klar, hier wieder als Datei:
                              Log Solarlog Langzeitwerte.rtf
                                forelleblau
                                @agria4800 Danke für das Log. Darin sehe ich, dass dein solarlog für die Abfrage der Monats- und Jahreswerte ein 'Query Impossible' zurückmeldet.
                                Jetzt gibt es verschieden Möglichkeiten:
                                a) wir schieben es auf den solarlog 500 mit der etwas anderen Software und lassen alle wie es ist.
                                b) wir machen a) und ich stelle sicher, dass nur die Objekte angelegt werden, die auch befüllt werden können.
                                c) Wir graben etwas tiefer nach einer anderen Lösung. Dazu müsste ich dir aber js-scripts für den js-Adapter schicken können, die du dann dort laufen lässt und mir jeweils die Antwort zeigst. Oder du schaust bei dir gewisse Queries mit dem Browser - 'Entwicklungstool' an.
                                Was wäre nach deinem Geschmack?
                                an alle anderen: Tritt das Problem nur bei solarlog 500 Geräten auf?
                                Grüsse forelleblau
                                • F forelleblau
                                  Grüsse forelleblau
                                  Agria4800A Offline
                                  Agria4800A Offline
                                  Agria4800
                                  @forelleblau :Servus, ich stehe zur Verfügung! Ich schicke dir mal ne PN
                                  • F forelleblau
                                    Aktuelle Test Version 2.1.4
                                    Veröffentlichungsdatum 26.8.2021
                                    Github Link https://github.com/iobroker-community-adapters/ioBroker.solarlog
                                    v2.1.4
                                    Neu werden auch bei Solarlog 500 - Geräten die History & Selfcons - Werte korrekt ausgefüllt.
                                    Agria4800A Offline
                                    Agria4800A Offline
                                    Agria4800
                                    v2.1.4
                                    Vielen Dank nochmal für deine Unterstützung 👍 👏
                                    • L Offline
                                      LoDDl
                                      Hallo @forelleblau ,
                                      ich habe einen Solar Log 50 und mir wird, wie bei dir auf Github beschrieben, überall dieses "Access Denied" angezeigt. Gibt es dafür in irgendeiner Art einen Workaround?
                                      Vielen Dank und liebe Grüße!
                                      Andreas
                                      • F Offline
                                        forelleblau
                                        Hallo Andreas
                                        Einen eigentlichen Workaround gibt es nicht. Was du tun kannst, ist in den 'Erweiterten Einstellungen' das 'Importieren von Wechselrichter- und Gerätedaten' aktivieren. Damit solltest du die Daten der einzelnen Wechselrichter oder Metern erhalten. Hast du das schon gemacht?
                                        Ich kann mal prüfen, welche der betroffenen 'Access denied' Daten ich allenfalls über andere Abfragen zur Verfügung stellen könnte.
                                        Ich hab mir mal ein Issue dazu angelegt.
                                        Grüsse
                                        Marcel
                                        L T 2 Antworten Letzte Antwort
                                        • F forelleblau
                                          Hallo Andreas
                                          Grüsse
                                          Marcel
                                          LoDDl
                                          @forelleblau wie einfach es sein kann... Das eine Häkchen hat alles gerettet :D Danke dir vielmals, da sind zwar immer noch einige "Access Denied" Datenpunkte aber die wichtigsten Sachen funktionieren :) Das reicht vollkommen.
                                          Liebe Grüße!
