  4. Probleme mit Serialport bei zwave2
    6.8k
118 Beiträge 5 Kommentatoren 15.0k Aufrufe 2 Beobachtet
  • E Esmax666
    @alcalzone
    EDIT: es geht jetzt : (mit ACM09
    hi hab jetzt ein usb hub, und jetzt zeigt er ACM0
    und ich bekomme das:
    pi@raspberrypi:~ $ ls -ls /dev/ | grep serial
    0 drwxr-xr-x 4 root root          80 Mai 21 13:46 serial
    0 lrwxrwxrwx 1 root root           5 Mai 20 20:56 serial0 -> ttyS0
    0 lrwxrwxrwx 1 root root           7 Mai 20 20:56 serial1 -> ttyAMA0
    pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2
    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js -        -force --logs
    2021-05-21 13:52:23.280  - info: zwave2.0 (393) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
    13:52:23.362 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
    13:52:23.369 DRIVER   version 7.4.0
    13:52:23.371 CONFIG   version 7.4.0
    13:52:23.372 DRIVER
    13:52:23.372 DRIVER   starting driver...
    13:52:23.409 DRIVER   opening serial port /dev/serial1
    13:52:23.429 DRIVER   serial port errored: Error Resource temporarily unavailable Cannot lock port
    13:52:23.430 DRIVER   destroying driver instance...
    2021-05-21 13:52:23.433  - error: zwave2.0 (393) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
    /dev/serial1
    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs
    2021-05-21 13:53:56.938  - info: zwave2.0 (530) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
    13:53:57.027 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
    13:53:57.032 DRIVER   version 7.4.0
    13:53:57.034 CONFIG   version 7.4.0
    13:53:57.035 DRIVER
    13:53:57.036 DRIVER   starting driver...
    13:53:57.069 DRIVER   opening serial port /dev/serial1
    13:53:57.089 DRIVER   serial port errored: Error Resource temporarily unavailable Cannot lock port
    13:53:57.092 DRIVER   destroying driver instance...
    2021-05-21 13:53:57.096  - error: zwave2.0 (530) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
    /dev/ttyACM0
    2021-05-21 13:56:15.231  - info: zwave2.0 (615) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
    13:56:15.326 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
    13:56:15.330 DRIVER   version 7.4.0
    13:56:15.332 CONFIG   version 7.4.0
    13:56:15.333 DRIVER
    13:56:15.334 DRIVER   starting driver...
    13:56:15.365 DRIVER   opening serial port /dev/ttyACM0
    13:56:15.386 DRIVER   serial port errored: Error Resource temporarily unavailable Cannot lock port
    13:56:15.387 DRIVER   destroying driver instance...
    2021-05-21 13:56:15.390  - error: zwave2.0 (615) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
    2021-05-21 13:56:15.948  - debug: zwave2.0 (615) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
    2021-05-21 13:56:15.952  - debug: zwave2.0 (615) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
    2021-05-21 13:56:15.953  - debug: zwave2.0 (615) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
    2021-05-21 13:56:16.953  - debug: zwave2.0 (615) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
    2021-05-21 13:56:16.957  - debug: zwave2.0 (615) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
    2021-05-21 13:56:16.961  - debug: zwave2.0 (615) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
    2021-05-21 13:57:06.347  - info: zwave2.0 (643) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
    13:57:06.432 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
    13:57:06.437 DRIVER   version 7.4.0
    13:57:06.439 CONFIG   version 7.4.0
    13:57:06.439 DRIVER
    13:57:06.440 DRIVER   starting driver...
    13:57:06.472 DRIVER   opening serial port /dev/ttyAMA0
    13:57:06.496 DRIVER   serial port errored: Error Resource temporarily unavailable Cannot lock port
    13:57:06.497 DRIVER   destroying driver instance...
    2021-05-21 13:57:06.501  - error: zwave2.0 (643) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #98
    @esmax666 sagte in Probleme mit Serialport bei zwave2:
    Da scheint immer noch was anderes drauf zuzugreifen.
    E 1 Antwort Letzte Antwort
    • AlCalzoneA AlCalzone
      @esmax666 Bevor du viel Geld für nen Hub ausgibst, kauf dir lieber gleich nen Z-Wave 700 Stick:
      https://www.mouser.de/ProductDetail/Silicon-Labs/SLUSB001A?qs=u16ybLDytRbJsMfgk3EnSA==
      Kostet fast nix und ist Zukunftssicher.
      Lenny.CBL Offline
      Lenny.CBL Offline
      Lenny.CB
      #99
      @alcalzone 20€ Versandkosten... krass, ist ja mehr als der Stick kostet. 🤮
        Esmax666
        #100
        @alcalzone was kannst ich sonst noch machen ? willst du noch etwas sehen ?
        • E Esmax666
          Esmax666
          schrieb am zuletzt editiert von Esmax666
          #101
          @esmax666
          ich habe sonst ganz normal hier rasbian hier runtergelanden
          https://www.raspberrypi.org/software/operating-systems/
          und dann einfach
          curl -sLf https://iobroker.net/install.sh | bash -
          soll man lieber / gibt es sonst fertig image mit rasbian ?
          oder wo konnte noch das problem kommen ?
          • E Esmax666
            @esmax666
            und dann einfach
            #102
            @esmax666
            Nein, alles richtig gemacht.
            Du schreibst doch aber oben, dass jetzt alles funktioniert?
              @esmax666
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #103
              @thomas-braun sagte in Probleme mit Serialport bei zwave2:
              Du schreibst doch anber oben, dass jetzt alles funktioniert?
              Tuts aber nicht - der Adapter verweigert immer noch den "richtigen" Start wegen "cannot lock port".
                #104
                @alcalzone @Esmax666
                Dann halt nochmal mit
                sudo lsof /dev/tty[wasauchimmergeradeaktivseinsollte]
                schauen.
                • AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #105
                  @Esmax666 schau auch mal ob in /boot/config.txt eine Zeile enable_uart=1 zu finden ist.
                  Auf meinem Pi4 ist das der Fall und dort geht der Adapter.
                  E 2 Antworten Letzte Antwort
                    schauen.
                    Esmax666
                    #106
                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ sudo lsof /dev/ttyACM0
                    COMMAND PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
                    node    673 iobroker   26uW  CHR  166,0      0t0  427 /dev/ttyACM0
                      Esmax666
                      #107
                      @alcalzone said in Probleme mit Serialport bei zwave2:
                      config.txt
                      ganz am ende
                      pi@raspberrypi:/boot $ cat config.txt
                      # For more options and information see
                      # http://rpf.io/configtxt
                      # Some settings may impact device functionality. See link above for details
                      # uncomment if you get no picture on HDMI for a default "safe" mode
                      #hdmi_safe=1
                      # uncomment this if your display has a black border of unused pixels visible
                      # and your display can output without overscan
                      #disable_overscan=1
                      # uncomment the following to adjust overscan. Use positive numbers if console
                      # goes off screen, and negative if there is too much border
                      #overscan_left=16
                      #overscan_right=16
                      #overscan_top=16
                      #overscan_bottom=16
                      # uncomment to force a console size. By default it will be display's size minus
                      # overscan.
                      #framebuffer_width=1280
                      #framebuffer_height=720
                      # uncomment if hdmi display is not detected and composite is being output
                      #hdmi_force_hotplug=1
                      # uncomment to force a specific HDMI mode (this will force VGA)
                      #hdmi_group=1
                      #hdmi_mode=1
                      # uncomment to force a HDMI mode rather than DVI. This can make audio work in
                      # DMT (computer monitor) modes
                      #hdmi_drive=2
                      # uncomment to increase signal to HDMI, if you have interference, blanking, or
                      # no display
                      #config_hdmi_boost=4
                      # uncomment for composite PAL
                      #sdtv_mode=2
                      #uncomment to overclock the arm. 700 MHz is the default.
                      #arm_freq=800
                      # Uncomment some or all of these to enable the optional hardware interfaces
                      #dtparam=i2c_arm=on
                      #dtparam=i2s=on
                      #dtparam=spi=on
                      # Uncomment this to enable infrared communication.
                      #dtoverlay=gpio-ir,gpio_pin=17
                      #dtoverlay=gpio-ir-tx,gpio_pin=18
                      # Additional overlays and parameters are documented /boot/overlays/README
                      # Enable audio (loads snd_bcm2835)
                      dtparam=audio=on
                      [pi4]
                      # Enable DRM VC4 V3D driver on top of the dispmanx display stack
                      dtoverlay=vc4-fkms-v3d
                      max_framebuffers=2
                      [all]
                      #dtoverlay=vc4-fkms-v3d
                      enable_uart=1
                        Esmax666
                        #108
                        @alcalzone ist config.txt ok ?
                        sonst bei starten habe ich grün und gekomme jetzt das
                        zwave2.0	2021-05-22 10:49:27.281	info	(10672) Node 2 is alive
                        zwave2.0	2021-05-22 10:49:27.257	debug	(10672) object zwave2.0.Node_026.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{
                        zwave2.0	2021-05-22 10:49:27.247	info	(10672) Node 2: ready to use
                        zwave2.0	2021-05-22 10:49:27.075	info	(10672) Node 25: ready to use
                        zwave2.0	2021-05-22 10:49:27.048	info	(10672) Node 24: ready to use
                        zwave2.0	2021-05-22 10:49:26.970	info	(10672) Node 23: ready to use
                        zwave2.0	2021-05-22 10:49:26.782	debug	(10672) object zwave2.0.Node_022.Multilevel_Switch.down changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Down)"},"native":{
                        zwave2.0	2021-05-22 10:49:26.639	debug	(10672) object zwave2.0.Node_022.Multilevel_Switch.up changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Up)"},"native":{"nod
                        zwave2.0	2021-05-22 10:49:26.520	info	(10672) Node 20: ready to use
                        zwave2.0	2021-05-22 10:49:26.454	info	(10672) Node 9: ready to use
                        zwave2.0	2021-05-22 10:49:26.412	info	(10672) Node 8: ready to use
                        zwave2.0	2021-05-22 10:49:26.382	info	(10672) Node 7: ready to use
                        zwave2.0	2021-05-22 10:49:25.971	info	(10672) Node 1: ready to use
                        zwave2.0	2021-05-22 10:49:25.717	info	(10672) The driver is ready. Found 21 nodes.
                        zwave2.0	2021-05-22 10:49:21.694	info	(10672) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                        zwave2.0	2021-05-22 10:49:21.461	debug	(10672) statesDB connected
                        zwave2.0	2021-05-22 10:49:21.460	debug	(10672) States connected to redis: 127.0.0.1:9000
                        zwave2.0	2021-05-22 10:49:21.452	debug	(10672) States create User PubSub Client
                        zwave2.0	2021-05-22 10:49:21.451	debug	(10672) States create System PubSub Client
                        zwave2.0	2021-05-22 10:49:21.440	debug	(10672) Redis States: Use Redis connection: 127.0.0.1:9000
                        zwave2.0	2021-05-22 10:49:21.437	debug	(10672) objectDB connected
                        zwave2.0	2021-05-22 10:49:21.285	debug	(10672) Objects connected to redis: 127.0.0.1:9001
                        zwave2.0	2021-05-22 10:49:21.271	debug	(10672) Objects client initialize lua scripts
                        zwave2.0	2021-05-22 10:49:21.270	debug	(10672) Objects create User PubSub Client
                        zwave2.0	2021-05-22 10:49:21.268	debug	(10672) Objects create System PubSub Client
                        zwave2.0	2021-05-22 10:49:21.265	debug	(10672) Objects client ready ... initialize now
                        zwave2.0	2021-05-22 10:49:21.228	debug	(10672) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        host.raspberrypi	2021-05-22 10:49:19.250	info	instance system.adapter.zwave2.0 started with pid 10672
                        host.raspberrypi	2021-05-22 10:49:19.081	info	"system.adapter.zwave2.0" enabled
                        host.raspberrypi	2021-05-22 10:48:42.831	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        zwave2.0	2021-05-22 10:48:42.176	info	(673) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        zwave2.0	2021-05-22 10:48:42.175	info	(673) terminating
                        zwave2.0	2021-05-22 10:48:42.174	info	(673) Cleaned everything up!
                        zwave2.0	2021-05-22 10:48:42.006	info	(673) Resetting node status...
                        zwave2.0	2021-05-22 10:48:41.974	info	(673) Shutting down driver...
                        zwave2.0	2021-05-22 10:48:41.972	info	(673) Got terminate signal TERMINATE_YOURSELF
                        host.raspberrypi	2021-05-22 10:48:41.973	info	stopInstance system.adapter.zwave2.0 send kill signal
                        host.raspberrypi	2021-05-22 10:48:41.963	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                        host.raspberrypi	2021-05-22 10:48:41.958	info	"system.adapter.zwave2.0" disabled
                        und in console bekomme ich das
                        2021-05-22 10:53:01.219  - error: zwave2.0 (26343) adapter disabled
                        2021-05-22 10:53:01.229  - info: zwave2.0 (26343) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                        10:53:01.309 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                        10:53:01.314 DRIVER   version 7.4.0
                        10:53:01.316 CONFIG   version 7.4.0
                        10:53:01.317 DRIVER
                        10:53:01.318 DRIVER   starting driver...
                        10:53:01.346 DRIVER   opening serial port /dev/ttyACM0
                        10:53:01.366 DRIVER   serial port opened
                        10:53:01.368 SERIAL » [NAK]        (0x15)
                        10:53:02.875 DRIVER   loading configuration...
                        10:53:04.042 DRIVER   beginning interview...
                        10:53:04.044 DRIVER   added request handler for AddNodeToNetwork (0x4a)...
                                              1 registered
                        10:53:04.045 DRIVER   added request handler for RemoveNodeFromNetwork (0x4b)...
                                              1 registered
                        10:53:04.045 DRIVER   added request handler for ReplaceFailedNode (0x63)...
                                              1 registered
                        10:53:04.047 CNTRLR   beginning interview...
                        10:53:04.048 CNTRLR   querying version info...
                        10:53:04.229 SERIAL » 0x01030015e9                                                         (5 bytes)
                        10:53:04.232 DRIVER » [REQ] [GetControllerVersion]
                        10:53:04.238 SERIAL « [ACK]        (0x06)
                        10:53:04.242 SERIAL « 0x011001155a2d5761766520332e3935000199                              (18 bytes)
                        10:53:04.244 SERIAL » [ACK]        (0x06)
                        10:53:04.246 DRIVER « [RES] [GetControllerVersion]
                                                payload: 0x5a2d5761766520332e39350001
                        10:53:04.257 CNTRLR   received version info:
                                                controller type: Static Controller
                                                library version: Z-Wave 3.95
                        10:53:04.258 CNTRLR   querying controller IDs...
                        10:53:04.266 SERIAL » 0x01030020dc                                                         (5 bytes)
                        10:53:04.267 DRIVER » [REQ] [GetControllerId]
                        10:53:04.270 SERIAL « [ACK]        (0x06)
                        10:53:04.272 SERIAL « 0x01080120dc3452b301de                                              (10 bytes)
                        10:53:04.274 SERIAL » [ACK]        (0x06)
                        10:53:04.275 DRIVER « [RES] [GetControllerId]
                                                payload: 0xdc3452b301
                        10:53:04.282 CNTRLR   received controller IDs:
                                                home ID:     0xdc3452b3
                                                own node ID: 1
                        10:53:04.283 CNTRLR   querying controller capabilities...
                        10:53:04.290 SERIAL » 0x01030005f9                                                         (5 bytes)
                        10:53:04.291 DRIVER » [REQ] [GetControllerCapabilities]
                        10:53:04.294 SERIAL « [ACK]        (0x06)
                        10:53:04.296 SERIAL « 0x010401051ce3                                                       (6 bytes)
                        10:53:04.297 SERIAL » [ACK]        (0x06)
                        10:53:04.299 DRIVER « [RES] [GetControllerCapabilities]
                                                payload: 0x1c
                        10:53:04.314 CNTRLR   received controller capabilities:
                                                controller role:     primary
                                                is in other network: false
                                                is SIS present:      true
                                                was real primary:    true
                                                is a SUC:            true
                        10:53:04.315 CNTRLR   querying API capabilities...
                        10:53:04.322 SERIAL » 0x01030007fb                                                         (5 bytes)
                        10:53:04.323 DRIVER » [REQ] [GetSerialApiCapabilities]
                        10:53:04.327 SERIAL « [ACK]        (0x06)
                        10:53:04.329 SERIAL « 0x012b0107010000860001005afe81ff884f1f0000fb9f7da067000080008086000 (45 bytes)
                                              000e87300000e0000600000fb
                        10:53:04.332 SERIAL » [ACK]        (0x06)
                        10:53:04.334 DRIVER « [RES] [GetSerialApiCapabilities]
                                                payload: 0x010000860001005afe81ff884f1f0000fb9f7da067000080008086000000e8730
                                              0000e0000600000
                        10:53:04.341 CNTRLR   received API capabilities:
                                                serial API version:  1.0
                                                manufacturer ID:     0x86
                                                product type:        0x01
                                                product ID:          0x5a
                                                supported functions:
                                                · GetSerialApiInitData (0x02)
                                                · FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION (0x03)
                                                · ApplicationCommand (0x04)
                                                · GetControllerCapabilities (0x05)
                                                · SetSerialApiTimeouts (0x06)
                                                · GetSerialApiCapabilities (0x07)
                                                · FUNC_ID_SERIAL_API_SOFT_RESET (0x08)
                                                · UNKNOWN_FUNC_UNKNOWN_0x09 (0x09)
                                                · UNKNOWN_FUNC_RF_RECEIVE_MODE (0x10)
                                                · UNKNOWN_FUNC_SET_SLEEP_MODE (0x11)
                                                · FUNC_ID_ZW_SEND_NODE_INFORMATION (0x12)
                                                · SendData (0x13)
                                                · SendDataMulticast (0x14)
                                                · GetControllerVersion (0x15)
                                                · SendDataAbort (0x16)
                                                · FUNC_ID_ZW_R_F_POWER_LEVEL_SET (0x17)
                                                · UNKNOWN_FUNC_SEND_DATA_META (0x18)
                                                · FUNC_ID_ZW_GET_RANDOM (0x1c)
                                                · GetControllerId (0x20)
                                                · UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
                                                · UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
                                                · UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
                                                · UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
                                                · UNKNOWN_FUNC_FlashAutoProgSet (0x27)
                                                · UNKNOWN_FUNC_NVMGetId (0x29)
                                                · UNKNOWN_FUNC_NVMExtReadLongBuffer (0x2a)
                                                · UNKNOWN_FUNC_NVMExtWriteLongBuffer (0x2b)
                                                · UNKNOWN_FUNC_NVMExtReadLongByte (0x2c)
                                                · UNKNOWN_FUNC_NVMExtWriteLongByte (0x2d)
                                                · GetNodeProtocolInfo (0x41)
                                                · HardReset (0x42)
                                                · FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
                                                · FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
                                                · AssignReturnRoute (0x46)
                                                · DeleteReturnRoute (0x47)
                                                · RequestNodeNeighborUpdate (0x48)
                                                · ApplicationUpdateRequest (0x49)
                                                · AddNodeToNetwork (0x4a)
                                                · RemoveNodeFromNetwork (0x4b)
                                                · FUNC_ID_ZW_CREATE_NEW_PRIMARY (0x4c)
                                                · FUNC_ID_ZW_CONTROLLER_CHANGE (0x4d)
                                                · FUNC_ID_ZW_SET_LEARN_MODE (0x50)
                                                · AssignSUCReturnRoute (0x51)
                                                · FUNC_ID_ZW_REQUEST_NETWORK_UPDATE (0x53)
                                                · SetSUCNodeId (0x54)
                                                · DeleteSUCReturnRoute (0x55)
                                                · GetSUCNodeId (0x56)
                                                · UNKNOWN_FUNC_SEND_SUC_ID (0x57)
                                                · FUNC_ID_ZW_EXPLORE_REQUEST_INCLUSION (0x5e)
                                                · RequestNodeInfo (0x60)
                                                · RemoveFailedNode (0x61)
                                                · IsFailedNode (0x62)
                                                · ReplaceFailedNode (0x63)
                                                · UNKNOWN_FUNC_UNKNOWN_0x66 (0x66)
                                                · UNKNOWN_FUNC_UNKNOWN_0x67 (0x67)
                                                · GetRoutingInfo (0x80)
                                                · UNKNOWN_FUNC_LOCK_ROUTE_RESPONSE (0x90)
                                                · UNKNOWN_FUNC_GET_PRIORITY_ROUTE (0x92)
                                                · UNKNOWN_FUNC_SET_PRIORITY_ROUTE (0x93)
                                                · UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
                                                · UNKNOWN_FUNC_UNKNOWN_0xB4 (0xb4)
                                                · UNKNOWN_FUNC_WATCH_DOG_ENABLE (0xb6)
                                                · UNKNOWN_FUNC_WATCH_DOG_DISABLE (0xb7)
                                                · UNKNOWN_FUNC_WATCH_DOG_KICK (0xb8)
                                                · UNKNOWN_FUNC_UNKNOWN_0xB9 (0xb9)
                                                · UNKNOWN_FUNC_RF_POWERLEVEL_GET (0xba)
                                                · UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
                                                · UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
                                                · UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
                                                · UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
                                                · UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
                                                · UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
                                                · undefined (0xee)
                                                · UNKNOWN_FUNC_UNKNOWN_0xEF (0xef)
                        10:53:04.345 CNTRLR   finding SUC...
                        10:53:04.352 SERIAL » 0x01030056aa                                                         (5 bytes)
                        10:53:04.354 DRIVER » [REQ] [GetSUCNodeId]
                        10:53:04.357 SERIAL « [ACK]        (0x06)
                        10:53:04.359 SERIAL « 0x0104015601ad                                                       (6 bytes)
                        10:53:04.361 SERIAL » [ACK]        (0x06)
                        10:53:04.362 DRIVER « [RES] [GetSUCNodeId]
                                                payload: 0x01
                        10:53:04.375 CNTRLR   This is the SUC
                        10:53:04.740 CNTRLR   querying node information...
                        10:53:04.748 SERIAL » 0x01030002fe                                                         (5 bytes)
                        10:53:04.749 DRIVER » [REQ] [GetSerialApiInitData]
                        10:53:04.760 SERIAL « [ACK]        (0x06)
                        10:53:04.852 SERIAL « 0x0125010205081ddf01e8f30700000000000000000000000000000000000000000 (39 bytes)
                                              000000005000e
                        10:53:04.853 SERIAL » [ACK]        (0x06)
                        10:53:04.854 DRIVER « [RES] [GetSerialApiInitData]
                                                payload: 0x05081ddf01e8f3070000000000000000000000000000000000000000000000000
                                              500
                        10:53:04.860 CNTRLR   received node information:
                                                controller is a SUC:        true
                                                controller is a slave:      false
                                                controller supports timers: false
                                                nodes in the network:       1, 2, 3, 4, 5, 7, 8, 9, 20, 22, 23, 24, 25, 26,
                                              29, 30, 31, 32, 33, 34, 35
                        10:53:04.928 DRIVER   Cache file for homeId 0xdc3452b3 found, attempting to restore the network from
                                               cache...
                        10:53:05.024 CNTRLR   [Node 001] Embedded device config loaded
                        10:53:05.042 CNTRLR   [Node 002] Embedded device config loaded
                        10:53:05.051 CNTRLR   [Node 003] Embedded device config loaded
                        10:53:05.060 CNTRLR   [Node 004] Embedded device config loaded
                        10:53:05.069 CNTRLR   [Node 005] Embedded device config loaded
                        10:53:05.076 CNTRLR   [Node 007] Embedded device config loaded
                        10:53:05.085 CNTRLR   [Node 008] Embedded device config loaded
                        10:53:05.093 CNTRLR   [Node 009] Embedded device config loaded
                        10:53:05.110 CNTRLR   [Node 020] Embedded device config loaded
                        10:53:05.118 CNTRLR   [Node 022] Embedded device config loaded
                        10:53:05.128 CNTRLR   [Node 023] Embedded device config loaded
                        10:53:05.136 CNTRLR   [Node 024] Embedded device config loaded
                        10:53:05.148 CNTRLR   [Node 025] Embedded device config loaded
                        10:53:05.156 CNTRLR   [Node 026] Embedded device config loaded
                        10:53:05.166 CNTRLR   [Node 029] Embedded device config loaded
                        10:53:05.176 CNTRLR   [Node 030] Embedded device config loaded
                        10:53:05.187 CNTRLR   [Node 031] Embedded device config loaded
                        10:53:05.196 CNTRLR   [Node 032] Embedded device config loaded
                        10:53:05.208 CNTRLR   [Node 033] Embedded device config loaded
                        10:53:05.217 CNTRLR   [Node 034] Embedded device config loaded
                        10:53:05.225 CNTRLR   [Node 035] Embedded device config loaded
                        10:53:05.226 DRIVER   Restoring the network from cache was successful!
                        10:53:05.232 CNTRLR   [Node 001] [Manufacturer Specific] manufacturerId: metadata updated
                        10:53:05.233 CNTRLR   [Node 001] [Manufacturer Specific] productType: metadata updated
                        10:53:05.234 CNTRLR   [Node 001] [Manufacturer Specific] productId: metadata updated
                        10:53:05.236 CNTRLR   [Node 001] [~] [Manufacturer Specific] manufacturerId: 134 => 134
                        10:53:05.238 CNTRLR   [Node 001] [~] [Manufacturer Specific] productType: 1 => 1
                        10:53:05.239 CNTRLR   [Node 001] [~] [Manufacturer Specific] productId: 90 => 90
                        10:53:05.240 CNTRLR   setting serial API timeouts: ack = 1000 ms, byte = 150 ms
                        10:53:05.246 SERIAL » 0x01050006640f97                                                     (7 bytes)
                        10:53:05.247 DRIVER » [REQ] [SetSerialApiTimeouts]
                                                payload: 0x640f
                        10:53:05.252 SERIAL « [ACK]        (0x06)
                        10:53:05.254 SERIAL « 0x01050106640f96                                                     (7 bytes)
                        10:53:05.255 SERIAL » [ACK]        (0x06)
                        10:53:05.256 DRIVER « [RES] [SetSerialApiTimeouts]
                                                payload: 0x640f
                        10:53:05.262 CNTRLR   serial API timeouts overwritten. The old values were: ack = 1000 ms, byte = 15
                                              0 ms
                        10:53:05.262 CNTRLR   Interview completed
                        10:53:05.265 DRIVER   driver ready
                        2021-05-22 10:53:05.266  - info: zwave2.0 (26343) The driver is ready. Found 21 nodes.
                        10:53:05.271 CNTRLR   [Node 001] The node is alive.
                        10:53:05.272 CNTRLR   [Node 001] The node is ready to be used
                        10:53:05.273 CNTRLR » [Node 002] pinging the node...
                        10:53:05.444 SERIAL » 0x010800130201002501c3                                              (10 bytes)
                        10:53:05.445 DRIVER » [Node 002] [REQ] [SendData]
                                              │ transmit options: 0x25
                                              │ callback id:      1
                                              └─[NoOperationCC]
                        10:53:05.447 CNTRLR » [Node 003] pinging the node...
                        10:53:05.449 CNTRLR » [Node 004] pinging the node...
                        10:53:05.461 CNTRLR » [Node 005] pinging the node...
                        10:53:05.472 CNTRLR   [Node 007] The node is asleep.
                        10:53:05.475 CNTRLR   [Node 007] The node is ready to be used
                        10:53:05.477 CNTRLR   [Node 008] The node is asleep.
                        10:53:05.479 CNTRLR   [Node 008] The node is ready to be used
                        10:53:05.480 CNTRLR » [Node 008] Assigning SUC return route...
                        10:53:05.484 CNTRLR   [Node 009] The node is asleep.
                        10:53:05.486 CNTRLR   [Node 009] The node is ready to be used
                        10:53:05.487 CNTRLR » [Node 009] Assigning SUC return route...
                        10:53:05.491 CNTRLR   [Node 020] The node is asleep.
                        10:53:05.492 CNTRLR   [Node 020] The node is ready to be used
                        10:53:05.493 CNTRLR » [Node 020] Assigning SUC return route...
                        10:53:05.496 CNTRLR » [Node 022] pinging the node...
                        10:53:05.500 CNTRLR   [Node 023] The node is asleep.
                        10:53:05.502 CNTRLR   [Node 023] The node is ready to be used
                        10:53:05.503 CNTRLR » [Node 023] Assigning SUC return route...
                        10:53:05.507 CNTRLR   [Node 024] The node is asleep.
                        10:53:05.509 CNTRLR   [Node 024] The node is ready to be used
                        10:53:05.510 CNTRLR   [Node 025] The node is asleep.
                        10:53:05.512 CNTRLR   [Node 025] The node is ready to be used
                        10:53:05.513 CNTRLR » [Node 025] Assigning SUC return route...
                        10:53:05.517 CNTRLR » [Node 026] pinging the node...
                        10:53:05.520 CNTRLR » [Node 029] pinging the node...
                        10:53:05.524 CNTRLR » [Node 030] pinging the node...
                        10:53:05.527 CNTRLR » [Node 031] pinging the node...
                        10:53:05.530 CNTRLR » [Node 032] pinging the node...
                        10:53:05.534 CNTRLR » [Node 033] pinging the node...
                        10:53:05.537 CNTRLR » [Node 034] pinging the node...
                        10:53:05.540 CNTRLR » [Node 035] pinging the node...
                        10:53:05.548 SERIAL « [ACK]        (0x06)
                        10:53:05.552 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:05.554 SERIAL » [ACK]        (0x06)
                        10:53:05.556 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:05.574  - info: zwave2.0 (26343) Node 1: ready to use
                        2021-05-22 10:53:05.863  - info: zwave2.0 (26343) Node 7: ready to use
                        2021-05-22 10:53:05.890  - info: zwave2.0 (26343) Node 8: ready to use
                        2021-05-22 10:53:05.913  - info: zwave2.0 (26343) Node 9: ready to use
                        2021-05-22 10:53:05.960  - info: zwave2.0 (26343) Node 20: ready to use
                        2021-05-22 10:53:06.287  - debug: zwave2.0 (26343) object zwave2.0.Node_022.Multilevel_Switch.up changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Up)"},"native":{"nodeId":22,"valueId":{"commandClass":38,"endpoint":0,"property":"Up"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673586180,"_id":"zwave2.0.Node_022.Multilevel_Switch.up","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:06.353  - debug: zwave2.0 (26343) object zwave2.0.Node_022.Multilevel_Switch.down changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Down)"},"native":{"nodeId":22,"valueId":{"commandClass":38,"endpoint":0,"property":"Down"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673586319,"_id":"zwave2.0.Node_022.Multilevel_Switch.down","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:06.650  - info: zwave2.0 (26343) Node 23: ready to use
                        2021-05-22 10:53:06.675  - info: zwave2.0 (26343) Node 24: ready to use
                        2021-05-22 10:53:06.712  - info: zwave2.0 (26343) Node 25: ready to use
                        2021-05-22 10:53:06.793  - debug: zwave2.0 (26343) object zwave2.0.Node_026.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":26,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673586786,"_id":"zwave2.0.Node_026.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        10:53:06.804 SERIAL « 0x010700130100007d97                                                 (9 bytes)
                        10:53:06.805 SERIAL » [ACK]        (0x06)
                        10:53:06.808 DRIVER « [REQ] [SendData]
                                                callback id:     1
                                                transmit status: OK
                        10:53:06.818 SERIAL » 0x010800130301002502c1                                              (10 bytes)
                        10:53:06.819 DRIVER » [Node 003] [REQ] [SendData]
                                              │ callback id:      2
                                              └─[NoOperationCC]
                        10:53:06.820 CNTRLR   [Node 002] The node is alive.
                        10:53:06.821 CNTRLR   [Node 002] The node is ready to be used
                        2021-05-22 10:53:06.822  - info: zwave2.0 (26343) Node 2: ready to use
                        10:53:06.823 CNTRLR « [Node 002] ping successful
                        2021-05-22 10:53:06.827  - debug: zwave2.0 (26343) object zwave2.0.Node_026.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":26,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673586799,"_id":"zwave2.0.Node_026.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        10:53:06.828 SERIAL « [ACK]        (0x06)
                        10:53:06.831 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:06.832 SERIAL » [ACK]        (0x06)
                        10:53:06.834 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:06.852  - info: zwave2.0 (26343) Node 2 is alive
                        2021-05-22 10:53:06.917  - debug: zwave2.0 (26343) object zwave2.0.Node_026.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":26,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673586900,"_id":"zwave2.0.Node_026.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.303  - debug: zwave2.0 (26343) object zwave2.0.Node_029.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":29,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587297,"_id":"zwave2.0.Node_029.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.315  - debug: zwave2.0 (26343) object zwave2.0.Node_029.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":29,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587307,"_id":"zwave2.0.Node_029.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.337  - debug: zwave2.0 (26343) object zwave2.0.Node_029.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":29,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587330,"_id":"zwave2.0.Node_029.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.414  - debug: zwave2.0 (26343) object zwave2.0.Node_030.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":30,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587409,"_id":"zwave2.0.Node_030.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.428  - debug: zwave2.0 (26343) object zwave2.0.Node_030.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":30,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587421,"_id":"zwave2.0.Node_030.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.446  - debug: zwave2.0 (26343) object zwave2.0.Node_030.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":30,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587439,"_id":"zwave2.0.Node_030.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.514  - debug: zwave2.0 (26343) object zwave2.0.Node_031.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":31,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587509,"_id":"zwave2.0.Node_031.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.521  - debug: zwave2.0 (26343) object zwave2.0.Node_031.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":31,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587517,"_id":"zwave2.0.Node_031.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.535  - debug: zwave2.0 (26343) object zwave2.0.Node_031.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":31,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587531,"_id":"zwave2.0.Node_031.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.588  - debug: zwave2.0 (26343) object zwave2.0.Node_032.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":32,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587584,"_id":"zwave2.0.Node_032.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.595  - debug: zwave2.0 (26343) object zwave2.0.Node_032.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":32,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587591,"_id":"zwave2.0.Node_032.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.611  - debug: zwave2.0 (26343) object zwave2.0.Node_032.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":32,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587605,"_id":"zwave2.0.Node_032.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.671  - debug: zwave2.0 (26343) object zwave2.0.Node_033.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":33,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587667,"_id":"zwave2.0.Node_033.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.678  - debug: zwave2.0 (26343) object zwave2.0.Node_033.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":33,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587674,"_id":"zwave2.0.Node_033.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.693  - debug: zwave2.0 (26343) object zwave2.0.Node_033.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":33,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587689,"_id":"zwave2.0.Node_033.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.748  - debug: zwave2.0 (26343) object zwave2.0.Node_034.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":34,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587743,"_id":"zwave2.0.Node_034.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.755  - debug: zwave2.0 (26343) object zwave2.0.Node_034.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":34,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587751,"_id":"zwave2.0.Node_034.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.774  - debug: zwave2.0 (26343) object zwave2.0.Node_034.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":34,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587770,"_id":"zwave2.0.Node_034.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.829  - debug: zwave2.0 (26343) object zwave2.0.Node_035.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":35,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587826,"_id":"zwave2.0.Node_035.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.836  - debug: zwave2.0 (26343) object zwave2.0.Node_035.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":35,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587832,"_id":"zwave2.0.Node_035.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:07.850  - debug: zwave2.0 (26343) object zwave2.0.Node_035.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":35,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673587846,"_id":"zwave2.0.Node_035.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        10:53:08.080 SERIAL « 0x010700130200007d94                                                 (9 bytes)
                        10:53:08.081 SERIAL » [ACK]        (0x06)
                        10:53:08.082 DRIVER « [REQ] [SendData]
                                                callback id:     2
                                                transmit status: OK
                        10:53:08.090 SERIAL » 0x010800130401002503c7                                              (10 bytes)
                        10:53:08.091 DRIVER » [Node 004] [REQ] [SendData]
                                              │ callback id:      3
                                              └─[NoOperationCC]
                        10:53:08.092 CNTRLR   [Node 003] The node is alive.
                        10:53:08.093 CNTRLR   [Node 003] The node is ready to be used
                        2021-05-22 10:53:08.094  - info: zwave2.0 (26343) Node 3: ready to use
                        10:53:08.095 CNTRLR « [Node 003] ping successful
                        10:53:08.099 SERIAL « [ACK]        (0x06)
                        10:53:08.104 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:08.105 SERIAL » [ACK]        (0x06)
                        10:53:08.107 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:08.115  - info: zwave2.0 (26343) Node 3 is alive
                        10:53:09.707 SERIAL « 0x01070013030000a149                                                 (9 bytes)
                        10:53:09.708 SERIAL » [ACK]        (0x06)
                        10:53:09.709 DRIVER « [REQ] [SendData]
                                                callback id:     3
                                                transmit status: OK
                        10:53:09.726 SERIAL » 0x010800130501002504c1                                              (10 bytes)
                        10:53:09.727 DRIVER » [Node 005] [REQ] [SendData]
                                              │ callback id:      4
                                              └─[NoOperationCC]
                        10:53:09.730 CNTRLR   [Node 004] The node is alive.
                        10:53:09.737 CNTRLR   [Node 004] The node is ready to be used
                        2021-05-22 10:53:09.738  - info: zwave2.0 (26343) Node 4: ready to use
                        10:53:09.740 CNTRLR « [Node 004] ping successful
                        10:53:09.744 SERIAL « [ACK]        (0x06)
                        10:53:09.751 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:09.752 SERIAL » [ACK]        (0x06)
                        10:53:09.755 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:09.769  - info: zwave2.0 (26343) Node 4 is alive
                        10:53:11.274 SERIAL « 0x010700130400009a75                                                 (9 bytes)
                        10:53:11.275 SERIAL » [ACK]        (0x06)
                        10:53:11.278 DRIVER « [REQ] [SendData]
                                                callback id:     4
                                                transmit status: OK
                        10:53:11.297 SERIAL » 0x010800131601002505d3                                              (10 bytes)
                        10:53:11.299 DRIVER » [Node 022] [REQ] [SendData]
                                              │ callback id:      5
                                              └─[NoOperationCC]
                        10:53:11.301 CNTRLR   [Node 005] The node is alive.
                        10:53:11.303 CNTRLR   [Node 005] The node is ready to be used
                        2021-05-22 10:53:11.304  - info: zwave2.0 (26343) Node 5: ready to use
                        10:53:11.305 CNTRLR « [Node 005] ping successful
                        10:53:11.310 SERIAL « [ACK]        (0x06)
                        10:53:11.314 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:11.315 SERIAL » [ACK]        (0x06)
                        10:53:11.318 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:11.561  - info: zwave2.0 (26343) Node 5 is alive
                        10:53:12.920 SERIAL « 0x01070013050000a14f                                                 (9 bytes)
                        10:53:12.921 SERIAL » [ACK]        (0x06)
                        10:53:12.923 DRIVER « [REQ] [SendData]
                                                callback id:     5
                                                transmit status: OK
                        10:53:12.937 SERIAL » 0x010800131a01002506dc                                              (10 bytes)
                        10:53:12.939 DRIVER » [Node 026] [REQ] [SendData]
                                              │ callback id:      6
                                              └─[NoOperationCC]
                        10:53:12.941 CNTRLR   [Node 022] The node is alive.
                        10:53:12.942 CNTRLR   [Node 022] The node is ready to be used
                        2021-05-22 10:53:12.943  - info: zwave2.0 (26343) Node 22: ready to use
                        10:53:12.945 CNTRLR « [Node 022] ping successful
                        10:53:12.948 SERIAL « [ACK]        (0x06)
                        10:53:12.953 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:12.954 SERIAL » [ACK]        (0x06)
                        10:53:12.955 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:12.965  - info: zwave2.0 (26343) Node 22 is alive
                        10:53:12.975 SERIAL « 0x0107001306000002ef                                                 (9 bytes)
                        10:53:12.977 SERIAL » [ACK]        (0x06)
                        10:53:12.979 DRIVER « [REQ] [SendData]
                                                callback id:     6
                                                transmit status: OK
                        10:53:12.991 SERIAL » 0x010800131d01002507da                                              (10 bytes)
                        10:53:12.992 DRIVER » [Node 029] [REQ] [SendData]
                                              │ callback id:      7
                                              └─[NoOperationCC]
                        10:53:12.994 CNTRLR   [Node 026] The node is alive.
                        10:53:12.996 CNTRLR   [Node 026] The node is ready to be used
                        2021-05-22 10:53:12.996  - info: zwave2.0 (26343) Node 26: ready to use
                        10:53:12.998 CNTRLR « [Node 026] ping successful
                        10:53:13.015 SERIAL « [ACK]        (0x06)
                        10:53:13.020 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:13.021 SERIAL » [ACK]        (0x06)
                        10:53:13.024 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:13.037  - info: zwave2.0 (26343) Node 26 is alive
                        2021-05-22 10:53:13.050  - debug: zwave2.0 (26343) object zwave2.0.Node_022.Multilevel_Switch.up changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Up)"},"native":{"nodeId":22,"valueId":{"commandClass":38,"endpoint":0,"property":"Up"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593041,"_id":"zwave2.0.Node_022.Multilevel_Switch.up","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        10:53:13.063 SERIAL « 0x0107001307000006ea                                                 (9 bytes)
                        10:53:13.064 SERIAL » [ACK]        (0x06)
                        10:53:13.065 DRIVER « [REQ] [SendData]
                                                callback id:     7
                                                transmit status: OK
                        10:53:13.073 SERIAL » 0x010800131e01002508d6                                              (10 bytes)
                        10:53:13.074 DRIVER » [Node 030] [REQ] [SendData]
                                              │ callback id:      8
                                              └─[NoOperationCC]
                        10:53:13.075 CNTRLR   [Node 029] The node is alive.
                        10:53:13.076 CNTRLR   [Node 029] The node is ready to be used
                        2021-05-22 10:53:13.077  - info: zwave2.0 (26343) Node 29: ready to use
                        10:53:13.078 CNTRLR « [Node 029] ping successful
                        10:53:13.083 SERIAL « [ACK]        (0x06)
                        10:53:13.088 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:13.090 SERIAL » [ACK]        (0x06)
                        10:53:13.092 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:13.100  - debug: zwave2.0 (26343) object zwave2.0.Node_022.Multilevel_Switch.down changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Down)"},"native":{"nodeId":22,"valueId":{"commandClass":38,"endpoint":0,"property":"Down"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593082,"_id":"zwave2.0.Node_022.Multilevel_Switch.down","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.106  - info: zwave2.0 (26343) Node 29 is alive
                        2021-05-22 10:53:13.125  - debug: zwave2.0 (26343) object zwave2.0.Node_026.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":26,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593111,"_id":"zwave2.0.Node_026.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.137  - debug: zwave2.0 (26343) object zwave2.0.Node_026.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":26,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593130,"_id":"zwave2.0.Node_026.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.148  - debug: zwave2.0 (26343) object zwave2.0.Node_029.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":29,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593142,"_id":"zwave2.0.Node_029.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.158  - debug: zwave2.0 (26343) object zwave2.0.Node_029.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":29,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593152,"_id":"zwave2.0.Node_029.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        10:53:13.168 SERIAL « 0x0107001308000009ea                                                 (9 bytes)
                        10:53:13.169 SERIAL » [ACK]        (0x06)
                        2021-05-22 10:53:13.170  - debug: zwave2.0 (26343) object zwave2.0.Node_026.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":26,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593163,"_id":"zwave2.0.Node_026.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        10:53:13.172 DRIVER « [REQ] [SendData]
                                                callback id:     8
                                                transmit status: OK
                        10:53:13.181 SERIAL » 0x010800131f01002509d6                                              (10 bytes)
                        10:53:13.183 DRIVER » [Node 031] [REQ] [SendData]
                                              │ callback id:      9
                                              └─[NoOperationCC]
                        10:53:13.184 CNTRLR   [Node 030] The node is alive.
                        10:53:13.185 CNTRLR   [Node 030] The node is ready to be used
                        2021-05-22 10:53:13.186  - info: zwave2.0 (26343) Node 30: ready to use
                        10:53:13.187 CNTRLR « [Node 030] ping successful
                        10:53:13.191 SERIAL « [ACK]        (0x06)
                        10:53:13.198 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:13.199 SERIAL » [ACK]        (0x06)
                        10:53:13.201 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:13.209  - info: zwave2.0 (26343) Node 30 is alive
                        10:53:13.212 SERIAL « 0x0107001309000002e0                                                 (9 bytes)
                        10:53:13.213 SERIAL » [ACK]        (0x06)
                        10:53:13.214 DRIVER « [REQ] [SendData]
                                                callback id:     9
                                                transmit status: OK
                        10:53:13.229 SERIAL » 0x01080013200100250aea                                              (10 bytes)
                        10:53:13.230 DRIVER » [Node 032] [REQ] [SendData]
                                              │ callback id:      10
                                              └─[NoOperationCC]
                        10:53:13.231 CNTRLR   [Node 031] The node is alive.
                        10:53:13.233 CNTRLR   [Node 031] The node is ready to be used
                        2021-05-22 10:53:13.234  - info: zwave2.0 (26343) Node 31: ready to use
                        10:53:13.235 CNTRLR « [Node 031] ping successful
                        10:53:13.239 SERIAL « [ACK]        (0x06)
                        10:53:13.250 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:13.251 SERIAL » [ACK]        (0x06)
                        2021-05-22 10:53:13.253  - debug: zwave2.0 (26343) object zwave2.0.Node_029.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":29,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593238,"_id":"zwave2.0.Node_029.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        10:53:13.255 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:13.260  - info: zwave2.0 (26343) Node 31 is alive
                        10:53:13.261 SERIAL « 0x010700130a000002e3                                                 (9 bytes)
                        10:53:13.262 SERIAL » [ACK]        (0x06)
                        10:53:13.263 DRIVER « [REQ] [SendData]
                                                callback id:     10
                                                transmit status: OK
                        10:53:13.270 SERIAL » 0x01080013210100250bea                                              (10 bytes)
                        10:53:13.271 DRIVER » [Node 033] [REQ] [SendData]
                                              │ callback id:      11
                                              └─[NoOperationCC]
                        10:53:13.272 CNTRLR   [Node 032] The node is alive.
                        10:53:13.273 CNTRLR   [Node 032] The node is ready to be used
                        2021-05-22 10:53:13.273  - info: zwave2.0 (26343) Node 32: ready to use
                        10:53:13.274 CNTRLR « [Node 032] ping successful
                        10:53:13.278 SERIAL « [ACK]        (0x06)
                        10:53:13.285 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:13.286 SERIAL » [ACK]        (0x06)
                        10:53:13.288 DRIVER « [RES] [SendData]
                                                was sent: true
                        10:53:13.307 SERIAL « 0x010700130b000002e2                                                 (9 bytes)
                        10:53:13.307 SERIAL » [ACK]        (0x06)
                        2021-05-22 10:53:13.309  - info: zwave2.0 (26343) Node 32 is alive
                        10:53:13.311 DRIVER « [REQ] [SendData]
                                                callback id:     11
                                                transmit status: OK
                        10:53:13.318 SERIAL » 0x01080013220100250cee                                              (10 bytes)
                        10:53:13.319 DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      12
                                              └─[NoOperationCC]
                        10:53:13.320 CNTRLR   [Node 033] The node is alive.
                        10:53:13.321 CNTRLR   [Node 033] The node is ready to be used
                        2021-05-22 10:53:13.321  - info: zwave2.0 (26343) Node 33: ready to use
                        10:53:13.322 CNTRLR « [Node 033] ping successful
                        10:53:13.329 SERIAL « [ACK]        (0x06)
                        10:53:13.332 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:13.334 SERIAL » [ACK]        (0x06)
                        10:53:13.338 DRIVER « [RES] [SendData]
                                                was sent: true
                        10:53:13.357 SERIAL « 0x010700130c000002e5                                                 (9 bytes)
                        10:53:13.358 SERIAL » [ACK]        (0x06)
                        10:53:13.359 DRIVER « [REQ] [SendData]
                                                callback id:     12
                                                transmit status: OK
                        10:53:13.368 SERIAL » 0x01080013230100250dee                                              (10 bytes)
                        10:53:13.369 DRIVER » [Node 035] [REQ] [SendData]
                                              │ callback id:      13
                                              └─[NoOperationCC]
                        10:53:13.370 CNTRLR   [Node 034] The node is alive.
                        10:53:13.371 CNTRLR   [Node 034] The node is ready to be used
                        2021-05-22 10:53:13.371  - info: zwave2.0 (26343) Node 34: ready to use
                        10:53:13.372 CNTRLR « [Node 034] ping successful
                        10:53:13.384 SERIAL « [ACK]        (0x06)
                        10:53:13.389 SERIAL « 0x0104011301e8                                                       (6 bytes)
                        10:53:13.390 SERIAL » [ACK]        (0x06)
                        2021-05-22 10:53:13.393  - info: zwave2.0 (26343) Node 33 is alive
                        10:53:13.395 DRIVER « [RES] [SendData]
                                                was sent: true
                        2021-05-22 10:53:13.419  - info: zwave2.0 (26343) Node 34 is alive
                        10:53:13.433 SERIAL « 0x010700130d000005e3                                                 (9 bytes)
                        10:53:13.434 SERIAL » [ACK]        (0x06)
                        10:53:13.435 DRIVER « [REQ] [SendData]
                                                callback id:     13
                                                transmit status: OK
                        10:53:13.447 CNTRLR   [Node 035] The node is alive.
                        10:53:13.448 CNTRLR   [Node 035] The node is ready to be used
                        10:53:13.449 CNTRLR   All nodes are ready to be used
                        2021-05-22 10:53:13.450  - info: zwave2.0 (26343) All nodes are ready to use
                        2021-05-22 10:53:13.451  - info: zwave2.0 (26343) Node 35: ready to use
                        10:53:13.514 CNTRLR « [Node 035] ping successful
                        2021-05-22 10:53:13.562  - info: zwave2.0 (26343) Node 35 is alive
                        2021-05-22 10:53:13.571  - debug: zwave2.0 (26343) object zwave2.0.Node_030.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":30,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593544,"_id":"zwave2.0.Node_030.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.590  - debug: zwave2.0 (26343) object zwave2.0.Node_031.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":31,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593576,"_id":"zwave2.0.Node_031.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.614  - debug: zwave2.0 (26343) object zwave2.0.Node_032.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":32,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593585,"_id":"zwave2.0.Node_032.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.617  - debug: zwave2.0 (26343) object zwave2.0.Node_030.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":30,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593591,"_id":"zwave2.0.Node_030.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.646  - debug: zwave2.0 (26343) object zwave2.0.Node_033.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":33,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593618,"_id":"zwave2.0.Node_033.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.647  - debug: zwave2.0 (26343) object zwave2.0.Node_031.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":31,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593623,"_id":"zwave2.0.Node_031.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.650  - debug: zwave2.0 (26343) object zwave2.0.Node_034.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":34,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593623,"_id":"zwave2.0.Node_034.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        10:53:13.685 DRIVER   Usage statistics sent - next transmission scheduled in 23 hours.
                        2021-05-22 10:53:13.704  - debug: zwave2.0 (26343) object zwave2.0.Node_032.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":32,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593660,"_id":"zwave2.0.Node_032.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.713  - debug: zwave2.0 (26343) object zwave2.0.Node_033.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":33,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593663,"_id":"zwave2.0.Node_033.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.736  - debug: zwave2.0 (26343) object zwave2.0.Node_035.Multilevel_Switch.open changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Open)"},"native":{"nodeId":35,"valueId":{"commandClass":38,"endpoint":0,"property":"Open"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593707,"_id":"zwave2.0.Node_035.Multilevel_Switch.open","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.780  - debug: zwave2.0 (26343) object zwave2.0.Node_034.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":34,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593707,"_id":"zwave2.0.Node_034.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.807  - debug: zwave2.0 (26343) object zwave2.0.Node_030.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":30,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593792,"_id":"zwave2.0.Node_030.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.838  - debug: zwave2.0 (26343) object zwave2.0.Node_035.Multilevel_Switch.close changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Perform a level change (Close)"},"native":{"nodeId":35,"valueId":{"commandClass":38,"endpoint":0,"property":"Close"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593802,"_id":"zwave2.0.Node_035.Multilevel_Switch.close","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.854  - debug: zwave2.0 (26343) object zwave2.0.Node_031.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":31,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593832,"_id":"zwave2.0.Node_031.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.887  - debug: zwave2.0 (26343) object zwave2.0.Node_032.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":32,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593878,"_id":"zwave2.0.Node_032.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.893  - debug: zwave2.0 (26343) object zwave2.0.Node_033.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":33,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593880,"_id":"zwave2.0.Node_033.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.894  - debug: zwave2.0 (26343) object zwave2.0.Node_034.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":34,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593884,"_id":"zwave2.0.Node_034.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        2021-05-22 10:53:13.949  - debug: zwave2.0 (26343) object zwave2.0.Node_035.Central_Scene.slowRefresh changed: {"type":"state","common":{"type":"boolean","read":true,"write":true,"role":"switch","name":"Send held down notifications at a slow rate","desc":"When this is true, KeyHeldDown notifications are sent every 55s. When this is false, the notifications are sent every 200ms."},"native":{"nodeId":35,"valueId":{"commandClass":91,"endpoint":0,"property":"slowRefresh"}},"from":"system.adapter.zwave2.0","user":"system.user.admin","ts":1621673593926,"_id":"zwave2.0.Node_035.Central_Scene.slowRefresh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                        E 1 Antwort Letzte Antwort
                        • E Esmax666
                          pi@raspberrypi:~ $ ls -ls /dev/ | grep serial
                          0 drwxr-xr-x 4 root root          80 Mai 21 13:46 serial
                          0 lrwxrwxrwx 1 root root           5 Mai 20 20:56 serial0 -> ttyS0
                          0 lrwxrwxrwx 1 root root           7 Mai 20 20:56 serial1 -> ttyAMA0
                          pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2
                          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs
                          10:53:01.317 DRIVER
                                                1 registered
                                                1 registered
                                                1 registered
                                                  home ID:     0xdc3452b3
                                                  own node ID: 1
                                                  payload: 0x1c
                                                  is a SUC:            true
                                                0000e0000600000
                                                  product type:        0x01
                                                  product ID:          0x5a
                                                  · SendData (0x13)
                                                  · HardReset (0x42)
                                                  · undefined (0xee)
                                                  payload: 0x01
                                                000000005000e
                                                500
                                                 cache...
                                                  payload: 0x640f
                                                  payload: 0x640f
                                                0 ms
                                                │ callback id:      1
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     1
                                                  transmit status: OK
                                                │ callback id:      2
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     2
                                                  transmit status: OK
                                                │ callback id:      3
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     3
                                                  transmit status: OK
                                                │ callback id:      4
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     4
                                                  transmit status: OK
                                                │ callback id:      5
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     5
                                                  transmit status: OK
                                                │ callback id:      6
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     6
                                                  transmit status: OK
                                                │ callback id:      7
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     7
                                                  transmit status: OK
                                                │ callback id:      8
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     8
                                                  transmit status: OK
                                                │ callback id:      9
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     9
                                                  transmit status: OK
                                                │ callback id:      10
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     10
                                                  transmit status: OK
                                                │ callback id:      11
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     11
                                                  transmit status: OK
                                                │ callback id:      12
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     12
                                                  transmit status: OK
                                                │ callback id:      13
                                                └─[NoOperationCC]
                                                  was sent: true
                                                  callback id:     13
                                                  transmit status: OK
                          Esmax666
                          #109
                          @AlCalzone
                          Man kann die Objekte sehen, die aus meiner alten Installation wieder aufgetaucht sind
                          aber die Kommunikation scheint nicht gut zu sein, die Werte werden nicht aktualisiert. Befehle werden nicht ausgeführt.
                          • E Esmax666
                            @AlCalzone
                            Esmax666
                            #110
                            @AlCalzone
                            Ich habe iobrocker und rasbian zurückgesetzt und Backitup gestartet.
                            Z-Wave ist angeschlossen und hat die Objekte gefunden, aber es zeigt nicht alle aktuellen Werte an.
                            Es zeigt mir die aktuellen Werte für einige Objekte, aber nicht für andere.
                            also hier fehlt : currentvalue (ist einfach leer)
                            und hier zeigt er alles
                            kann man Backitup nehmen mit zwave als backup ?
                            • E Esmax666
                              @AlCalzone
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              #111
                              Na das sieht doch schon besser aus.
                              @esmax666 sagte in Probleme mit Serialport bei zwave2:
                              Dafür mach mir bitte mal eine Logdatei
                              https://github.com/AlCalzone/ioBroker.zwave2/blob/master/docs/de/bei-problemen.md#notwendige-informationen-für-ein-issue
                              und lade sie hier hoch.
                              Falls du das meinst, zwave2 ist voll ins iobroker-Backup integriert (welches auch von backitup genutzt wird)
                              • AlCalzoneA AlCalzone
                                Esmax666
                                schrieb am zuletzt editiert von Esmax666
                                #112
                                @alcalzone
                                Ok also die probleme sind bei "TechniSat Shutter-Switch" z.B hier "node 035" -> "Currentvalue" ist leer (aber auch die andere Technisat)
                                zwavejs_2021-05-23.log
                                dc3452b3.values.jsonl dc3452b3.json dc3452b3.metadata.jsonl
                                ich habe auch schon leer cache gemacht und healh network
                                ohne erfolg
                                Ich habe in der Dokumentation nicht gefunden, ob es möglich ist, das Gerät zu zwingen, alle Informationen nochmal zu senden
                                https://www.technisat.com/en_XX/Roller-shutter-flush-mount,-BJ/352-22704-22938/
                                • E Esmax666
                                  @alcalzone
                                  ohne erfolg
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #113
                                  @esmax666 Mindestens Node 35 ist verschlüsselt eingebunden, antwortet aber nicht auf die verschlüsselten Anfragen. Mein Tip ist auf einem falschen Netzwerkschlüssel in den Adapter-Einstellungen.
                                  E 2 Antworten Letzte Antwort
                                    Esmax666
                                    #114
                                    @alcalzone
                                    Ich habe den Schlüssel gewechselt. Ich denke, jetzt ist alles in Ordnung.
                                    Es ist nur seltsam, aber der Webserver reagiert nicht sehr schnell.
                                    Nach ein Click muss ich muss 2-3 Sekunden warten, bis meine Datei in "Objekte" geöffnet wird. Die Reaktivität ist sehr langsam :/
                                      Esmax666
                                      #115
                                      Hi @alcalzone
                                      Das Problem ist wieder da :/
                                      Habe Adapter und iobroker neu gestartet aber bringt nichts
                                      zwavejs_2021-05-24.log
                                      dc3452b3.json
                                      Was kannst ich sonst noch machen ?
                                      • E Esmax666
                                        Hi @alcalzone
                                        dc3452b3.json
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #116
                                        @esmax666
                                        No such file or directory
                                        Heißt, dass der USB-Stick nicht mehr den Pfad hat oder gar nicht mehr gefunden wird. Hast du den Host schon mal komplett neu gestartet?
                                          @esmax666
                                          Esmax666
                                          #117
                                          @alcalzone raspi ist auch neue gestratet leider ohne erfolg :/
