  4. Probleme beim Installieren von MQTT-Client
91 Beiträge 5 Kommentatoren 11.3k Aufrufe 2 Beobachtet
    @berges01 sagte in Probleme beim Installieren von MQTT-Client:
    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
    Wo hast du den denn sonst hingedrückt?
    Wie installiert?
    iobroker stop
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    mal probieren.
    Berges01B Offline
    Berges01B Offline
    Berges01
    @thomas-braun said in Probleme beim Installieren von MQTT-Client:
    Wie installiert?
    iobroker stop
    cd /opt/iobroker
    mal probieren.
    berges01@BergesHome:~$ cd /opt/iobroker
    berges01@BergesHome:/opt/iobroker$ iobroker stop
    berges01@BergesHome:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
    > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.12
    > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    In file included from ../../nan/nan.h:56,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      736 |       (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
      770 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      404 | NODE_MODULE(unix_dgram, Initialize)
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    > node rebuild.js
    ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
    > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
      CXX(target) Release/obj.target/diskusage/src/main.o
                     from ../src/main.cpp:3:
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       42 | NODE_MODULE(diskusage, Init)
      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      SOLINK_MODULE(target) Release/obj.target/diskusage.node
      COPY Release/diskusage.node
    make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
    > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short). Generating new Certificate!
    object system.certificates updated
    object _design/system updated
    > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
    > node scripts/postinstall
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.js-controller@3.2.16
    added 145 packages from 124 contributors, removed 15 packages and updated 1 package in 33.776s
    45 packages are looking for funding
      run `npm fund` for details
    Da genau so etwas befürchte bin ich sehr vorsichtig was ich mache.
    Ich habe bei den Adaptern nur den MQTT-Client ausgewählt und auf das + gedrückt da wahr es geschehen.
    Sonst nichts !!
    Ich habe ein Backup mit IOBroker BackUp erstellt wenn das einfacher ist ?!?!
    F.B.
    • Berges01B Berges01
      Wie installiert?
      iobroker stop
      cd /opt/iobroker
      mal probieren.
      > node-gyp rebuild
      > node rebuild.js
      > node-gyp rebuild
      Sonst nichts !!
      @berges01
      Uns startet das Ding jetzt wieder?
      iobroker start
      iobroker status
      Berges01B 1 Antwort Letzte Antwort
        @berges01
        iobroker start
        iobroker status
        Berges01B Offline
        Berges01B Offline
        Berges01
        @berges01
        iobroker start
        iobroker status
        berges01@BergesHome:/opt/iobroker$ iobroker start
        berges01@BergesHome:/opt/iobroker$ iobroker status
        Objects type: file
        States  type: file
        Scheind so !
        Ist das mit dem MQTT-Client so Buggy ?
        Ich suche eine Möglichkeit meine ESP32 Käfer mit dem ioBroker zu verbinden.
        Bei Fibari HC3 habe ich auf dem HC3 einen Web-Client laufen programmiert und laufen gelassen der dann auf dem Webserver des ESp32 die Daten abgehohlt hat und in die Systemvariabeln des HC3 integriert hatte.
        Höhrt sich she Tricki an ist aber eigendlich eine Simple Geschichte.
        Da ich den ioBroker nicht gut genug kenne, dachte ich mache es mit dem MQTT dann wird das eine Runde Sache. Weit gefehlt das wahr ein Dilemma.
        Leider.
        F.B.
        HomoranH mickymM Thomas BraunT 3 Antworten Letzte Antwort
          @berges01
          iobroker start
          iobroker status
          Objects type: file
          States  type: file
          Scheind so !
          Leider.
          das lag aber nicht am Adapter.
          der läuft bei mir einwandfrei.
          Da hat irgendetwas anderes dein System zerschossen. Die Installation irgendeines Adapters hat dann wahrscheinlich nur den Rest gegeben.
            @berges01
            iobroker start
            iobroker status
            Objects type: file
            States  type: file
            Scheind so !
            Leider.
            mickymM Offline
            mickymM Offline
            mickym
            @berges01 Den MQTT Adapter, den ich Dir empfohlen habe - also der sowohl als Client wie als Broker arbeitet, der läuft bei mir seit knapp 2 Jahren. Das gibt keine Probleme. Wenn Du den also über die Admin Oberfläche installierst sollte das auch durchlaufen.
            Wie gesagt der nur Client Adapter ist mE ziemlich alt.
            HomoranH Berges01B 2 Antworten Letzte Antwort
              @berges01
              iobroker start
              iobroker status
              Objects type: file
              States  type: file
              Scheind so !
              Leider.
              @berges01
              Zu MQTT kann ich nix sagen, nutze ich nicht.
              Aber eigentlich sollte dir ein simples Hinzufügen eines Adapters nicht gleich den ioBroker zerballern. Ist auch für mich ein neues Phänomen und scheint nicht häufig vorzukommen.
              Aber hatten wir nicht auf deiner Maschine das ubuntu/dfsg-eigene nodeJS rausgekratzt?
              • mickymM mickym
                @mickym sagte in Probleme beim Installieren von MQTT-Client:
                Das mag inzwischen so sein - bin da nicht auf dem laufenden.
                Früher hieß es nämlich genau andersrum ;-)
                Berges01B mickymM 2 Antworten Letzte Antwort
                • mickymM mickym
                  Berges01B Offline
                  Berges01B Offline
                  Berges01
                  @mickym said in Probleme beim Installieren von MQTT-Client:
                  Oh ha ich werde es noch mal versuchen !
                  Wenn ich nur nicht so Hilflos auf der Linuxseite währe !
                  Mal sehen !
                  Sonst müßte noch mal einer helfen (LEIDER).
                  F.B.
                    @berges01
                    Berges01B Offline
                    Berges01B Offline
                    Berges01
                    @berges01
                    Wie gesagt da gehe ich nicht dran ich bediene nur den ioBroker denn Linux bekomme ich nicht wieder anś laufen.
                    F.B.
                      Berges01B Offline
                      Berges01B Offline
                      Berges01
                      @homoran said in Probleme beim Installieren von MQTT-Client:
                      So der MQTT-Broker/Client V2.3.5 ist durchgelaufen und meldet sich mit der Konfigurationsebene.
                      DANKE erst mal und das mit dem Alten MQTT-Client sollte mal einer (Fachmann) überprüfen nicht das das eine Serie ist und das mit den Neuen Teilen nicht läuft.
                      Ich rühre den nicht wieder an.
                      DANKE Euch !!!!!!
                      Gruss Frank
                      F.B.
                      HomoranH mickymM 2 Antworten Letzte Antwort
                        DANKE Euch !!!!!!
                        Gruss Frank
                        der läuft einwandfrei - das hat nichts mit neuen Teilen zu tun!
                        Das MQTT-Protokoll hat sich nicht geändert.
                        Bei dir war vorher schon der Wurm drin!
                        Wenn @Thomas-Braun schreibt, dass du vorher das Ubuntu node drin hattest, *kann dein Problem noch Nachwehen davon haben.
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @homoran sagte in Probleme beim Installieren von MQTT-Client:
                          Ich weiß - das hört man hier oft nicht gerne - aber zum Einen nutze ich halt den anderen Adapter und weiß dass er funktioniert - mit dem anderen hatte ich auch Probleme. Und auch wenn man einen funktionierenden Adapter nicht ändern braucht, so gibt einem das Änderungsprotokoll meines Erachtens durchaus einen Aufschluss, wie gepflegt ein Adapter ist. ;)
                          • mickymM mickym
                            Da habe ich überhaupt kein Problem mit.
                            Mit dem MQTT-Adapter hatte ich vor Jahren deutlich größere Probleme
                            Und bei dem Client ist es wesentlich einfacher Daten gezielt zu publishen.
                            EDIT:
                            Hab mir gerade mal das changelog näher angesehen.
                            Das kann man auch anders interpretieren 😂
                            Der MQTT-Adapter hatte mehr Probleme, die behoben werden mussten. Das hat einfach länger gedauert...
                              DANKE Euch !!!!!!
                              Gruss Frank
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @berges01 Wenn Du mosquitto als Broker hast und den Client als Front-End benutzt kann ich Dir nur empfehlen, alle Haken wegzulassen:
                              Bei der Bekanntgabe der eigenen States muss dann eben mqtt.0.* stehen. Ist aber im Standard auch so eingestellt. Ich würde da nichts verkonfigurieren, dann hast Du Dein gesamten mosquitto broker im iobroker verfügbar.
                              • mickymM mickym
                                Berges01B Offline
                                Berges01B Offline
                                Berges01
                                Ich hatte nur Ubuntu 21.04 Desprüngliche sktop installier.
                                Dann das hier vorgeschlagenen Aufruf Szenario für Ubuntu.
                                Das wahr das Ursprüngliche System.
                                Ich kann nicht sagen was OK oder falsch ist.
                                Da verlasse ich mich auf Euch.
                                Da muss ich mich noch einarbeiten, aber erst mal muss der ioBroker richtig laufen und alles abbilden was ich hier an Sensoren und Aktoren habe.
                                135 habe ich integriert und der Rest kommt über MQTT und 4 Stück muss ich über z-wave noch einbinden, die sind aber prpblematisch eingebaut.
                                F.B.
                                  Wenn du noch nicht sehr weit bist, würde ich an deiner Stelle alles neu aufsetzen, bevor die möglichen Leichen im Keller noch später zu Problemen führen.
                                  Nimm einfach ein Debian ohne Desktop und installiere mit dem Einzeiler.
                                  Dann ist alles sauber.
                                  Im Moment arbeitest du mit einem mehrfach gepatchten System.
                                  Das kann eine Zeitbombe sein.
                                    EDIT:
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    EDIT:
                                    Jo da hast Du Recht. ;) - Das ist halt immer Ansichtssache.
                                    Ich hab mir nur mal den Screenshot von dem anderen Adapter ansgeschaut und auch mit der etwas gezielteren Veröffentlichung magst Du Recht haben, wobei man da oben ja durchaus eine Liste mit mehreren Pfaden zur Veröffentlichung eintragen kann. Ist Geschmackssache. Ich hab mir zur gezielten Veröffentlichung dann einfach eine weitere Instanz des Adapters angelegt.
                                    • mickymM mickym
                                      EDIT:
                                      aber das publishen in der Object-Liste für jeden State mit Topic Pfad usw. ist einfach unschlagbar
                                      Habe damals die Vitaldaten diverser SBCs verglichen und konnte so auf allen SBCs mit identischen Einstellungen fahren, weil jeder entsprechned seine Werte in die selbe Struktur gepublished hatte
                                        @berges01
                                        Lüppt?
                                        Dann bin ich hier raus, von MQTT hab ich nämlich keine Ahnung...
                                          @berges01
                                          Lüppt?
                                          @thomas-braun sagte in Probleme beim Installieren von MQTT-Client:
                                          Bleib!
                                          ich brauche deine Hilfe um @Berges01 dazu zubringen sein System neu und sauber aufzusetzen
