  4. Probleme mit Serialport bei zwave2
    6.7k
118 Beiträge 5 Kommentatoren 15.0k Aufrufe 2 Beobachtet
  • E Esmax666
    @thomas-braun said in Test Adapter Z-Wave 2 v1.10.x:
    Windows User, oder? Der Treiber ist im Linux-Kernel schon drin.
    warum windows User ?
    steht sogar in log
    host.raspberrypi	2021-05-16 08:00:00.072	info	instance system.adapter.ical.0 started with pid 29746
    zwave2.0	2021-05-16 07:55:56.747	error	(12308) The Z-Wave driver could not be started: Error: Is a directory, cannot open /dev/
    zwave2.0	2021-05-16 07:55:56.584	info	(12308) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
    host.raspberrypi	2021-05-16 07:55:54.148	info	instance system.adapter.zwave2.0 started with pid 12308
    host.raspberrypi	2021-05-16 07:55:51.659	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zwave2.0	2021-05-16 07:55:51.028	info	(6004) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zwave2.0	2021-05-16 07:55:51.026	info	(6004) terminating
    Esmax666
    Linux raspberrypi 5.10.17-v7l+ #1414 SMP Fri Apr 30 13:20:47 BST 2021 armv7l
    permitted by applicable law.
    Last login: Sun May 16 00:06:39 2021
    pi@raspberrypi:~ $ npm i iobroker.zwave2
    > @serialport/bindings@9.0.7 install /home/pi/node_modules/@serialport/bindings
    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    prebuild-install WARN install No prebuilt binaries found (target=12.22.1 runtime=node arch=arm libc= platform=linux)
    make: Verzeichnis „/home/pi/node_modules/@serialport/bindings/build“ wird betreten
      CXX(target) Release/obj.target/bindings/src/serialport.o
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     _queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:56,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
      CXX(target) Release/obj.target/bindings/src/serialport_unix.o
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
      CXX(target) Release/obj.target/bindings/src/poller.o
      CXX(target) Release/obj.target/bindings/src/serialport_linux.o
      SOLINK_MODULE(target) Release/obj.target/bindings.node
      COPY Release/bindings.node
    make: Verzeichnis „/home/pi/node_modules/@serialport/bindings/build“ wird verlassennpm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
    npm notice created a lockfile as package-lock.json. You should commit this file.
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    + iobroker.zwave2@1.10.0
    added 168 packages from 189 contributors and audited 168 packages in 41.299s
    29 packages are looking for funding
      run `npm fund` for details
    found 0 vulnerabilities
    pi@raspberrypi:~ $ npm i zwave-js
    + zwave-js@7.4.0
    updated 1 package and audited 309 packages in 6.047s
    pi@raspberrypi:~ $
    • AlCalzoneA AlCalzone
      @esmax666 Probier mal /dev/serial0, da bin ich beim Raspberry Pi 4 auch schon drüber gestolpert.
      Ansonsten: ist das wirklich ein Z-Stick Gen5 oder doch ein Z-Stick Gen5 + ? Ich hab grob im Hinterkopf dass ersterer Probleme mit neueren USB-Schnittstellen macht.
      Esmax666
      @alcalzone
      Das ist die Raspi3 die die funktionniert (npm version vielleicht passt nicht)
      (hier ist ACM0) auf raspi4 geht auch nicht fehlt etwas ?
      • E Esmax666
        steht sogar in log
        @esmax666 sagte in Test Adapter Z-Wave 2 v1.10.x:
        steht sogar in log
        Da steht, dass /dev kein device node ist sondern ein Verzeichnis. Vermutlich hast du /dev in den Einstellungen des Adapters drin.
        Ist falsch. Jetzt hast du das im /home-Verzeichnis von pi installiert.
        Nimm den Adapter aus der Adapterliste im Admin.
        Aus deinem dmesg:
        [Sa Mai 15 21:06:15 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
        Das ist der für das Gerät geladene Treiber. Und da sieht man auch, dass das Device auf ttyAMA0 liegt.
        E 1 Antwort Letzte Antwort
          steht sogar in log
          Aus deinem dmesg:
          Esmax666
          Hatte ich schon gemacht.
          sogar sogar instance weg gemacht und neu gemacht
          leider geht es nicht mehr
          • E Esmax666
            Stimmt dann wohl.
            Leider kann man aus deiner 'Fehlerbeschreibung' nichts herauslesen.
              Stimmt dann wohl.
              Esmax666
              @thomas-braun was kann ich sonst noch als info geben ?
              sonst habe ich noch 2 warn und 1 error
              info.0	2021-05-16 13:07:15.628	warn	(2791) State "info.0.uuid" has no existing object, this might lead to an error in future versions
              host.raspberrypi	2021-05-16 13:00:08.345	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              host.raspberrypi	2021-05-16 13:00:00.042	info	instance system.adapter.ical.0 started with pid 5361
              zwave2.0	2021-05-16 12:59:53.829	info	(5346) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
              host.raspberrypi	2021-05-16 12:59:51.487	info	instance system.adapter.zwave2.0 started with pid 5346
              host.raspberrypi	2021-05-16 12:59:21.429	info	Restart adapter system.adapter.zwave2.0 because enabled
              host.raspberrypi	2021-05-16 12:59:21.428	info	instance system.adapter.zwave2.0 terminated with code NaN ()
              host.raspberrypi	2021-05-16 12:59:21.427	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
              host.raspberrypi	2021-05-16 12:59:21.422	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
              zwave2.0	2021-05-16 12:45:57.264	info	(5176) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
              host.raspberrypi	2021-05-16 12:45:55.024	info	instance system.adapter.zwave2.0 started with pid 5176
              host.raspberrypi	2021-05-16 12:45:24.958	info	Restart adapter system.adapter.zwave2.0 because enabled
              host.raspberrypi	2021-05-16 12:45:24.957	info	instance system.adapter.zwave2.0 terminated with code NaN ()
              host.raspberrypi	2021-05-16 12:45:24.956	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
              host.raspberrypi	2021-05-16 12:45:24.950	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
              info.0	2021-05-16 12:37:15.604	warn	(2791) State "info.0.uuid" has no existing object, this might lead to an error in future versions
              zwave2.0	2021-05-16 12:32:01.208	info	(5010) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
              host.raspberrypi	2021-05-16 12:31:58.911	info	instance system.adapter.zwave2.0 started with pid 5010
              host.raspberrypi	2021-05-16 12:31:28.859	info	Restart adapter system.adapter.zwave2.0 because enabled
              host.raspberrypi	2021-05-16 12:31:28.859	info	instance system.adapter.zwave2.0 terminated with code NaN ()
              host.raspberrypi	2021-05-16 12:31:28.858	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
              host.raspberrypi	2021-05-16 12:31:28.857	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
              • E Esmax666
                @esmax666
                Speicher dicht?
                free -ht
                anschauen.
                  @esmax666
                  Speicher dicht?
                  free -ht
                  anschauen.
                  Esmax666
                  • E Esmax666
                    @esmax666
                    Bitte keine Bilderchen posten, KonsolenTEXT in CodeTags eingebettet hier rein.
                    • AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @Esmax666 die Datei brauchst du inzwischen nicht mehr manuell bearbeiten. Auf Pi 4 sind das die Schritte, die ausreichen: Konsole auf,
                      sudo raspi-config
                      • 3 Interface Options
                      • P6 Serial Port
                      • "Would you like a login shell to be accessible over serial?" => NO
                      • "Would you like the serial port hardware to be enabled?" => YES
                      Danach sollte der Adapter funktionieren, wenn du /dev/serial0 einträgst - ist leider nicht in der Liste zu finden.
                      Thomas BraunT E 3 Antworten Letzte Antwort
                        sudo raspi-config
                        • P6 Serial Port
                        @alcalzone
                        An den Hardware-Part hatte ich noch gar nicht gedacht, bzw. vorausgesetzt das der natürlich auch aktiviert wurde.
                        Wobei dann /dev/serial0 'nur' ein symlink auf das device node /dev/ttyAMA0 sein dürfte.
                          sudo raspi-config
                          • P6 Serial Port
                          Esmax666
                          @alcalzone
                          ok ist jetzt aktviert
                          und auch neu gestartet
                          aber immer Driver could not be started
                          zwave2.0	2021-05-16 15:32:12.067	error	(17665) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/serial0
                          zwave2.0	2021-05-16 15:32:11.921	info	(17665) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          host.raspberrypi	2021-05-16 15:32:09.511	info	instance system.adapter.zwave2.0 started with pid 17665
                          host.raspberrypi	2021-05-16 15:32:07.043	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          zwave2.0	2021-05-16 15:32:06.372	info	(5742) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zwave2.0	2021-05-16 15:32:06.371	info	(5742) terminating
                          zwave2.0	2021-05-16 15:32:06.369	info	(5742) Shutting down driver...
                          zwave2.0	2021-05-16 15:32:06.367	info	(5742) Got terminate signal TERMINATE_YOURSELF
                          host.raspberrypi	2021-05-16 15:32:06.367	info	stopInstance system.adapter.zwave2.0 send kill signal
                          host.raspberrypi	2021-05-16 15:32:06.359	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                          host.raspberrypi	2021-05-16 15:30:27.733	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                          ical.0	2021-05-16 15:30:27.198	info	(8661) Terminated (NO_ERROR): Without reason
                          • E Esmax666
                            @alcalzone
                            @esmax666
                            Und wenn du das device direkt anrufst? Unter /dev/ttyAMA0
                            Gibt es das Gerät?
                            ls -la /dev/ttyAMA0
                            sudo -u iobroker groups
                              @esmax666
                              Gibt es das Gerät?
                              ls -la /dev/ttyAMA0
                              Esmax666
                              schrieb am zuletzt editiert von Esmax666
                              @thomas-braun said in Probleme mit Serialport bei zwave2:
                              /dev/ttyAMA0
                              dann bekomme ich wie davor
                              zwave2.0	2021-05-16 15:39:28.776	info	(15581) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                              host.raspberrypi	2021-05-16 15:39:26.309	info	instance system.adapter.zwave2.0 started with pid 15581
                              host.raspberrypi	2021-05-16 15:39:23.743	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              zwave2.0	2021-05-16 15:39:23.146	info	(17665) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              zwave2.0	2021-05-16 15:39:23.145	info	(17665) terminating
                              zwave2.0	2021-05-16 15:39:23.143	info	(17665) Shutting down driver...
                              host.raspberrypi	2021-05-16 15:39:23.141	info	stopInstance system.adapter.zwave2.0 send kill signal
                              zwave2.0	2021-05-16 15:39:23.141	info	(17665) Got terminate signal TERMINATE_YOURSELF
                              host.raspberrypi	2021-05-16 15:39:23.126	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                              und als "debug level" bekomme ich das :
                              zwave2.0	2021-05-16 15:41:19.769	info	(24494) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                              zwave2.0	2021-05-16 15:41:19.518	debug	(24494) statesDB connected
                              zwave2.0	2021-05-16 15:41:19.517	debug	(24494) States connected to redis: 127.0.0.1:9000
                              zwave2.0	2021-05-16 15:41:19.510	debug	(24494) States create User PubSub Client
                              zwave2.0	2021-05-16 15:41:19.508	debug	(24494) States create System PubSub Client
                              zwave2.0	2021-05-16 15:41:19.501	debug	(24494) Redis States: Use Redis connection: 127.0.0.1:9000
                              zwave2.0	2021-05-16 15:41:19.498	debug	(24494) objectDB connected
                              zwave2.0	2021-05-16 15:41:19.469	debug	(24494) Objects connected to redis: 127.0.0.1:9001
                              zwave2.0	2021-05-16 15:41:19.455	debug	(24494) Objects client initialize lua scripts
                              zwave2.0	2021-05-16 15:41:19.453	debug	(24494) Objects create User PubSub Client
                              zwave2.0	2021-05-16 15:41:19.451	debug	(24494) Objects create System PubSub Client
                              zwave2.0	2021-05-16 15:41:19.448	debug	(24494) Objects client ready ... initialize now
                              zwave2.0	2021-05-16 15:41:19.402	debug	(24494) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              host.raspberrypi	2021-05-16 15:41:17.450	info	instance system.adapter.zwave2.0 started with pid 24494
                              host.raspberrypi	2021-05-16 15:41:17.338	info	"system.adapter.zwave2.0" enabled
                              host.raspberrypi	2021-05-16 15:41:15.669	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              host.raspberrypi	2021-05-16 15:41:15.087	info	stopInstance system.adapter.zwave2.0 send kill signal
                              zwave2.0	2021-05-16 15:41:15.048	info	(22847) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              zwave2.0	2021-05-16 15:41:15.046	info	(22847) terminating
                              zwave2.0	2021-05-16 15:41:15.044	info	(22847) Shutting down driver...
                              zwave2.0	2021-05-16 15:41:15.042	info	(22847) Got terminate signal TERMINATE_YOURSELF
                              host.raspberrypi	2021-05-16 15:41:15.029	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                              host.raspberrypi	2021-05-16 15:41:15.027	info	"system.adapter.zwave2.0" disabled
                              zwave2.0	2021-05-16 15:40:59.111	info	(22847) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                              zwave2.0	2021-05-16 15:40:58.808	debug	(22847) statesDB connected
                              zwave2.0	2021-05-16 15:40:58.807	debug	(22847) States connected to redis: 127.0.0.1:9000
                              zwave2.0	2021-05-16 15:40:58.795	debug	(22847) States create User PubSub Client
                              zwave2.0	2021-05-16 15:40:58.794	debug	(22847) States create System PubSub Client
                              zwave2.0	2021-05-16 15:40:58.783	debug	(22847) Redis States: Use Redis connection: 127.0.0.1:9000
                              zwave2.0	2021-05-16 15:40:58.781	debug	(22847) objectDB connected
                              zwave2.0	2021-05-16 15:40:58.751	debug	(22847) Objects connected to redis: 127.0.0.1:9001
                              zwave2.0	2021-05-16 15:40:58.737	debug	(22847) Objects client initialize lua scripts
                              zwave2.0	2021-05-16 15:40:58.736	debug	(22847) Objects create User PubSub Client
                              zwave2.0	2021-05-16 15:40:58.735	debug	(22847) Objects create System PubSub Client
                              zwave2.0	2021-05-16 15:40:58.732	debug	(22847) Objects client ready ... initialize now
                              zwave2.0	2021-05-16 15:40:58.696	debug	(22847) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              host.raspberrypi	2021-05-16 15:40:56.599	info	instance system.adapter.zwave2.0 started with pid 22847
                              host.raspberrypi	2021-05-16 15:40:56.462	info	"system.adapter.zwave2.0" enabled
                              host.raspberrypi	2021-05-16 15:40:50.698	info	instance system.adapter.zwave2.0 terminated with code null ()
                              host.raspberrypi	2021-05-16 15:40:50.697	warn	instance system.adapter.zwave2.0 terminated due to SIGTERM
                              host.raspberrypi	2021-05-16 15:40:50.626	info	stopInstance system.adapter.zwave2.0 killing pid 22283
                              host.raspberrypi	2021-05-16 15:40:49.624	info	stopInstance system.adapter.zwave2.0 send kill signal
                              host.raspberrypi	2021-05-16 15:40:49.613	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                              host.raspberrypi	2021-05-16 15:40:49.613	info	"system.adapter.zwave2.0" disabled
                              host.raspberrypi	2021-05-16 15:40:49.345	info	instance system.adapter.zwave2.0 started with pid 22283
                              host.raspberrypi	2021-05-16 15:40:46.840	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              zwave2.0	2021-05-16 15:40:46.228	info	(15581) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              zwave2.0	2021-05-16 15:40:46.226	info	(15581) terminating
                              zwave2.0	2021-05-16 15:40:46.225	info	(15581) Shutting down driver...
                              zwave2.0	2021-05-16 15:40:46.223	info	(15581) Got terminate signal TERMINATE_YOURSELF
                              host.raspberrypi	2021-05-16 15:40:46.223	info	stopInstance system.adapter.zwave2.0 send kill signal
                              host.raspberrypi	2021-05-16 15:40:46.210	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                              • E Esmax666
                                /dev/ttyAMA0
                                @esmax666
                                ls -la /dev/ttyAMA0
                                  @esmax666
                                  ls -la /dev/ttyAMA0
                                  Esmax666
                                  auch nicht
                                  zwave2.0	2021-05-16 15:44:27.972	info	(7201) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                  host.raspberrypi	2021-05-16 15:44:25.611	info	instance system.adapter.zwave2.0 started with pid 7201
                                  host.raspberrypi	2021-05-16 15:44:25.529	info	"system.adapter.zwave2.0" enabled
                                  host.raspberrypi	2021-05-16 15:44:24.965	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  zwave2.0	2021-05-16 15:44:24.304	info	(30224) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  zwave2.0	2021-05-16 15:44:24.302	info	(30224) terminating
                                  zwave2.0	2021-05-16 15:44:24.301	info	(30224) Shutting down driver...
                                  host.raspberrypi	2021-05-16 15:44:24.299	info	stopInstance system.adapter.zwave2.0 send kill signal
                                  zwave2.0	2021-05-16 15:44:24.298	info	(30224) Got terminate signal TERMINATE_YOURSELF
                                  host.raspberrypi	2021-05-16 15:44:24.285	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                                  host.raspberrypi	2021-05-16 15:44:24.278	info	"system.adapter.zwave2.0" disabled
                                  zwave2.0	2021-05-16 15:44:11.075	debug	(30224) system.adapter.admin.0: logging true
                                  zwave2.0	2021-05-16 15:44:06.538	debug	(30224) system.adapter.admin.0: logging false
                                  • E Esmax666
                                    auch nicht
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    @esmax666 Starte den Adapter mal auf der Konsole, da sieht man ggf. mehr:
                                    cd /opt/iobroker/node_modules/iobroker.zwave2
                                    node build/main.js --force --logs
                                    E 2 Antworten Letzte Antwort
                                      Esmax666
                                      @alcalzone said in Probleme mit Serialport bei zwave2:
                                      pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2
                                      pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs        2021-05-16 16:43:17.078  - info: zwave2.0 (17697) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                      Logging to file:
                                              /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log
                                      2021-05-16 16:43:17.235  - error: zwave2.0 (17697) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
                                      ^C2021-05-16 16:43:47.907  - info: zwave2.0 (17697) Shutting down driver...
                                      2021-05-16 16:43:47.916  - info: zwave2.0 (17697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      • E Esmax666
                                        Logging to file:
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        @esmax666 sagte in Probleme mit Serialport bei zwave2:
                                        Cannot lock port
                                        Da greift schon irgendwas anderes auf den Port zu.
                                          Cannot lock port
                                          @Esmax666
                                          sudo lsof /dev/ttyAMA0
