  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
    @mcu
    Was für ein Dateisystem hast du auf dem NAS-Laufwerk?
    MCU
    #1236
    • M MCU
      #1237
      @mcu Okay.
      Ich hab da ext4 drauf.
        @mcu Okay.
        MCU
        #1238
        @thomas-braun Hab jetzt debug eingestellt:
        Beim 2. Mount kommt ein Fehler:
        2021-05-13 22:39:52.043 - info: backitup.0 (3165) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
        2021-05-13 22:39:52.132 - info: backitup.0 (3165) [iobroker] backup was activated at 02:00 every 1 day(s)
        2021-05-13 22:39:52.302 - debug: backitup.0 (3165) mount successfully completed
        2021-05-13 22:39:54.315 - debug: backitup.0 (3165) detect backup file 1 from cifs: iobroker_2021_05_13-22_20_17_backupiobroker.tar.gz
        2021-05-13 22:39:54.318 - debug: backitup.0 (3165) detect last backup file: iobroker_2021_05_13-22_20_17_backupiobroker.tar.gz
        2021-05-13 22:40:02.167 - debug: backitup.0 (3165) mount activ... umount in 2 Seconds!!
        2021-05-13 22:40:02.942 - debug: backitup.0 (3165) Backup list be read ...
        2021-05-13 22:40:03.014 - debug: backitup.0 (3165) device is busy... wait 2 Minutes!!
        2021-05-13 22:40:03.026 - debug: backitup.0 (3165) first mount attempt with smb option failed. try next mount attempt without smb option ...
        2021-05-13 22:40:03.095 - error: backitup.0 (3165) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/FRITZ.NAS/FDB/Backup2 /opt/iobroker/backups
        mount error(16): Device or resource busy
        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
        2021-05-13 22:40:04.266 - debug: backitup.0 (3165) umount successfully completed
        2021-05-13 22:40:05.106 - debug: backitup.0 (3165) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
        2021-05-13 22:40:09.619 - debug: backitup.0 (3165) set chmod for "/opt/iobroker/backups" successfully
        2021-05-13 22:40:09.625 - debug: backitup.0 (3165) sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0
        2021-05-13 22:41:14.145 - debug: backitup.0 (3165) telegram-instance:
        • M MCU
          #1239
          @mcu sagte in Test Adapter Backitup v2.1.x:
          Dann greift da schon was anderes drauf zu.
            MCU
            #1240
            @thomas-braun Wenn ich mir die Eigenschaften zum Ordner anschaue:
            Schreibschutz entfernen funktioniert nicht, ist sofort wieder da ? FritzBox?
            • M MCU
              #1241
              @mcu
              Was ist das für ein Tool?
                @mcu
                MCU
                #1242
                @thomas-braun Rechte Maustaste auf dem Ordner / Eigenschaften.
                chmod?
                2021-05-13 22:58:03.227 - debug: backitup.0 (3287) Backup list be read ...
                2021-05-13 22:58:03.321 - debug: backitup.0 (3287) mount successfully completed
                2021-05-13 22:58:05.334 - debug: backitup.0 (3287) sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                2021-05-13 22:58:10.041 - debug: backitup.0 (3287) cannot set chmod for "/opt/iobroker/backups": Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'
                2021-05-13 22:58:10.206 - debug: backitup.0 (3287) [jarvis] Start Jarvis Restore ...
                2021-05-13 22:58:10.207 - debug: backitup.0 (3287) [jarvis] filename for restore: /opt/iobroker/backups/jarvis.0_2021_05_13-22_22_50_backupiobroker.tar.gz
                2021-05-13 22:58:10.210 - debug: backitup.0 (3287) [jarvis] jarvis tmp directory created: /opt/iobroker/backups/jarvis_0
                2021-05-13 22:58:10.245 - error: backitup.0 (3287) [jarvis] jarvis restore not completed
                2021-05-13 22:58:10.246 - error: backitup.0 (3287) [jarvis] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/jarvis_0/'
                2021-05-13 22:58:10.247 - debug: backitup.0 (3287) sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0
                Kann es sein, dass dem root Berechtigungen fehlen? Wie kann ich das kontrollieren?
                Thomas BraunT M simatecS 3 Antworten Letzte Antwort
                • M MCU
                  chmod?
                  #1243
                  @mcu Unter Windows oder was? Auf dem Server läuft nichts klickbares.
                  • M MCU
                    chmod?
                    MCU
                    #1244
                    @mcu Ja Windows.
                    • M MCU
                      @mcu Ja Windows.
                      #1245
                      @mcu Windows/NTFS kennt sowas wie unix-Rechte nicht. Und auch kein utime.
                      Ich habe deswegen meine backup-Platte an der Fritzbox mit einem ext4 formatiert. Funktioniert.
                        MCU
                        #1246
                        @thomas-braun Dann versuch ich das mal umzustellen.
                        • M MCU
                          #1247
                          @mcu Allerdings muss man ggf. das extra mit besonderen Optionen versehen, damit das auf dem abgespeckten FritzNAS läuft.
                          Hatte ich mal vor kurzem hier im Forum verewigt, was man da genau machen muss.
                            MCU
                            #1248
                            @thomas-braun ext2 oder ext3 reicht auch?
                            Hab es gefunden:
                            https://forum.iobroker.net/topic/44674/ext4-dateisystem-am-fritznas-betreiben?_=1620924566328
                            NAS/Kopieren dürfen dann nur ext4-Platten sein?
                            • M MCU
                              Hab es gefunden:
                              #1249
                              @mcu
                              Nimm ext4.
                              Eigentlich sollte das bei smb-shares keine Rolle spielen, bzw. über die Mount-Optionen weggefedert werden. Kann aber sein, das ein Backup hier noch mit anderen Methoden hantiert.
                              • simatecS simatec
                                @der_user
                                In mysql ist das Backup nur mit dem Punkt im Dateinamen.
                                Das ist so korrekt.
                                der_user
                                #1250
                                @simatec said in Test Adapter Backitup v2.1.x:
                                Das ist so korrekt.
                                Ok. Dann scheint die MYSQL Sicherungsdatei ja in Ordnung zu sein.
                                Jetzt ist dann nur die Frage ob es was besonderes zu beachten gibt, um einen Restore der MYSQL Sicherung zu machen.
                                Bei mir passiert nämlich nichts - sprich das Fenster bleibt mit folgenden Zeilen stehen + offen:
                                • M MCU
                                  chmod?
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #1251
                                  Die Meldung kannst du ignorieren, da die nur lokal greifen würde. Ich fixe die Meldung in der Version 2.1.7
                                  • Besuche meine Github Seite
                                  • HowTo Restore ioBroker
                                  • D der_user
                                    Das ist so korrekt.
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #1252
                                    @der_user Da liegt ein Bug vor. Ist in Version 2.1.7 gefixt.
                                    Lade die Version gerade auf Github hoch. Sollte also gleich auf Github zur Verfügung stehen und auch demnächst als Update im Latest sein.
                                    • simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #1253
                                      Ab sofort steht die Version 2.1.7 auf Github und in kürze auch im latest zur Verfügung.
                                      Changelog
                                      2.1.7 (14.05.2021)
                                      • (simatec) Bugfix mysql Restore
                                      • (simatec) Bugfix pgsql Restore
                                      • (simatec) small Bugfix
                                      • (simatec) dependencies updated
                                      • (simatec) node 16 support added
                                      D 2 Antworten Letzte Antwort
                                      • simatecS simatec
                                        Changelog
                                        2.1.7 (14.05.2021)
                                        der_user
                                        #1254
                                        2.1.7 (14.05.2021)
                                        Danke. ein erster Test schaut sehr gut aus.
                                        Hätte ich mich doch nur früher gemeldet und nicht eine Woche an mir selbst gezweifelt ;-)
                                        • simatecS simatec
                                          Changelog
                                          2.1.7 (14.05.2021)
                                          der_user
                                          #1255
                                          Noch eine Verständnisfrage: werden beim Einspielen des MYSQL-Restores die Daten zur ggf. existierenden DB hinzugefügt oder wird vorher ein Drop der bestehenden Daten gemacht und sind nach dem Einspielen nur die Daten aus der Sicherung vorhanden?
