  4. Xiomi Mihome Vacuum
Xiomi Mihome Vacuum
13 Beiträge 6 Kommentatoren 1.5k Aufrufe 7 Beobachtet
  • da_WoodyD da_Woody
    @worxweis man könnte, wenn du dein log in code-tags setzt damit das lesbar wird.
    dauert manchmal schon so 10 min bis sich der adapter grün meldet...
    W Offline
    W Offline
    worxweis
    @da_woody ```
    mihome-vacuum.0 2021-03-06 18:17:50.635 debug (18973) Xiaomi Cloud: Login successful
    mihome-vacuum.0 2021-03-06 18:17:46.830 info (18973) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0 2021-03-06 18:17:46.419 debug (18973) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    mihome-vacuum.0 2021-03-06 18:17:46.339 debug (18973) server started on 0.0.0.0:53421
    mihome-vacuum.0 2021-03-06 18:17:46.309 info (18973) Cloud control disabled
    mihome-vacuum.0 2021-03-06 18:17:46.307 info (18973) Expert mode disabled, states deleted
    mihome-vacuum.0 2021-03-06 18:17:46.296 debug (18973) Xiaomi Cloud: Logging in
    mihome-vacuum.0 2021-03-06 18:17:46.294 debug (18973) load Map creator... true
    mihome-vacuum.0 2021-03-06 18:17:46.171 info (18973) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0 2021-03-06 18:17:45.654 debug (18973) statesDB connected
    mihome-vacuum.0 2021-03-06 18:17:45.653 debug (18973) States connected to redis: 0.0.0.0:6379
    mihome-vacuum.0 2021-03-06 18:17:45.642 debug (18973) States create User PubSub Client
    mihome-vacuum.0 2021-03-06 18:17:45.641 debug (18973) States create System PubSub Client
    mihome-vacuum.0 2021-03-06 18:17:45.631 debug (18973) Redis States: Use Redis connection: 0.0.0.0:6379
    mihome-vacuum.0 2021-03-06 18:17:45.629 debug (18973) objectDB connected
    mihome-vacuum.0 2021-03-06 18:17:45.619 debug (18973) Objects connected to redis: 0.0.0.0:9001
    mihome-vacuum.0 2021-03-06 18:17:45.594 debug (18973) Objects client initialize lua scripts
    mihome-vacuum.0 2021-03-06 18:17:45.593 debug (18973) Objects create User PubSub Client
    mihome-vacuum.0 2021-03-06 18:17:45.591 debug (18973) Objects create System PubSub Client
    mihome-vacuum.0 2021-03-06 18:17:45.589 debug (18973) Objects client ready ... initialize now
    mihome-vacuum.0 2021-03-06 18:17:45.525 debug (18973) Redis Objects: Use Redis connection: 0.0.0.0:9001
    So, hab das mit den Code-Tags nicht gewusst. Jedenfalls wird der bei mir nie grün. Da kann ich Tage und Wochen warten, wird nicht grün.
    Kannst du aus dem Log etwas herauslesen was daran schuld sein kann?
    • W worxweis
      @da_woody ```
      @worxweis
      iobroker status
      mal zeigen.
      W 1 Antwort Letzte Antwort
        @worxweis
        iobroker status
        mal zeigen.
        W Offline
        W Offline
        worxweis
        Objects type: file
        States  type: redis
        • W worxweis
          Objects type: file
          States  type: redis
          @worxweis
          Hier meldet sich erfolgreich ein V1 an:
          2021-03-10 20:10:13.503  - info: host.raspberrypi "system.adapter.mihome-vacuum.0" enabled
          2021-03-10 20:10:13.561  - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 1076
          2021-03-10 20:10:15.363  - info: mihome-vacuum.0 (1076) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.16.0, js-controller: 3.2.16
          2021-03-10 20:10:15.404  - info: mihome-vacuum.0 (1076) Expert mode disabled, states deleted
          2021-03-10 20:10:15.406  - info: mihome-vacuum.0 (1076) Create state clean_home for controlling by cloud adapter
          2021-03-10 20:10:15.448  - info: mihome-vacuum.0 (1076) New generation or new fw(3.5.8,004028) detected, create new states goto and zoneclean
          2021-03-10 20:10:15.467  - info: mihome-vacuum.0 (1076) connecting, this can take up to 10 minutes ...
          2021-03-10 20:10:15.505  - info: mihome-vacuum.0 (1076) Connected
          2021-03-10 20:10:15.937  - info: mihome-vacuum.0 (1076) set nächster Timer: Nicht verfügbar
          2021-03-10 20:10:16.516  - info: mihome-vacuum.0 (1076) create state for carpet_mode
          Schaut ein wenig anders aus. (Gut, der debug mode ist auch aus...)
            @worxweis
            W Offline
            W Offline
            worxweis
            Das hilft mir jetzt aber auch nicht weiter, oder?
              soern
              Mahlzeit,
              ich schließe mich einfach mal hier mit zu, damit das Forum nicht 1000 gleiche Threads hat.
              Ich habe leider das gleiche Problem wie @worxweis.
              Mein System:
              Node.js v.12.21.0
              NPM v.6.14.11
              Single Host - JS-Controller 3.2.16
              Adapter mihome-vacuum v. 2.1.1
              Apple Xiaomi App Version 6.2.200
              Firmware vom Roborock S5 max: 3.5.8_1340
              Meine Logs:
              mihome-vacuum.0	2021-03-11 16:26:24.262	info	(3349) set nächster Timer: Nicht verfügbar
              mihome-vacuum.0	2021-03-11 16:26:23.754	info	(3349) Cloud control disabled
              mihome-vacuum.0	2021-03-11 16:26:23.754	info	(3349) Expert mode disabled, states deleted
              mihome-vacuum.0	2021-03-11 16:26:23.726	info	(3349) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
              mihome-vacuum.0	2021-03-11 16:26:19.383	info	(1406) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              mihome-vacuum.0	2021-03-11 16:26:19.382	info	(1406) terminating
              mihome-vacuum.0	2021-03-11 16:26:19.381	info	(1406) Got terminate signal TERMINATE_YOURSELF
              Broker Status:
              root@ioBroker:~# iobroker status
              Objects type: file
              States  type: file
              NodeJS Version habe ich schon auf 10 sowie auf 14 geändert gehabt, den JS-Controller habe ich auch schon geupdatet.
              Ich bin schon seit einigen Tagen dabei.
              • S soern
                Mahlzeit,
                Mein System:
                Node.js v.12.21.0
                NPM v.6.14.11
                Meine Logs:
                Broker Status:
                Objects type: file
                States  type: file
                @soern sagte in Xiomi Mihome Vacuum:
                Wobei? Dein System zu zerlegen?
                Den root login würde ich schonmal tunlichst vermeiden.
                Wenn das System es nicht aus technischen Gründen erfordert loggt man sich nicht als root ein.
                  soern
                  Das System ist mir derzeit nicht wichtig. Es ist ja noch am Anfang und wird mit ziemlicher Sicherheit nach der Lösung in den Ruhestand geschickt und auf ein neuen System neu installiert.
                  Dabei den Adapter auf unterschiedliche Version zu updaten, mein Netzwerk zuhause Repeater frei zu machen, den Robby neu anlernen.
                  In manchen Beiträgen steht, man sollte einfach ein wenig warten, dies hab ich auch schon hinter mir.
                  • S soern
                    @soern
                    Als root abmelden,
                    iobroker fix
                    als user
                      @soern
                      Als root abmelden,
                      iobroker fix
                      als user
                      my_zeus
                      ich hoffe in diesem Threat etwas Hilfe zu finden, leider habe ich ebenfalls das Problem, dass sich der Roborock (S7) nicht vernünftiv verbindet,
                      Verbunden mit host: Wahr
                      Lebenszeichen: Wahr
                      Verbunden mit Mihome-vacuum: falsch
                      Mein System:
                      Node.js v12.22.1
                      NPM 6.14.12
                      Roborock S7
                      Log
                      mihome-vacuum.0	2021-05-13 21:49:53.528	debug	(24782) Receive <<< Helo <<< 213100200000000018cf333400010134ffffffffffffffffffffffffffffffff
                      mihome-vacuum.0	2021-05-13 21:49:48.533	debug	(24782) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2021-05-13 21:49:48.532	debug	(24782) no answer for id:88 received, giving up
                      mihome-vacuum.0	2021-05-13 21:49:43.699	debug	(24782) The answer from the robot is not correct! (SyntaxError: Unexpected end of JSON input) "{\"id\":88,\"result\":[{\"msg_ver\":2,\"msg_seq\":553,\"state\":8,\"battery\":100,\"clean_time\":3430,\"c
                      mihome-vacuum.0	2021-05-13 21:49:43.698	debug	(24782) Receive <<< {"id":88,"result":[{"msg_ver":2,"msg_seq":553,"state":8,"battery":100,"clean_time":3430,"clean_area":57700000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fr
                      mihome-vacuum.0	2021-05-13 21:49:43.532	debug	(24782) sendMsg[3] >>> {"id":88,"method":"get_status"}
                      mihome-vacuum.0	2021-05-13 21:49:38.692	debug	(24782) The answer from the robot is not correct! (SyntaxError: Unexpected end of JSON input) "{\"id\":88,\"result\":[{\"msg_ver\":2,\"msg_seq\":552,\"state\":8,\"battery\":100,\"clean_time\":3430,\"c
                      mihome-vacuum.0	2021-05-13 21:49:38.690	debug	(24782) Receive <<< {"id":88,"result":[{"msg_ver":2,"msg_seq":552,"state":8,"battery":100,"clean_time":3430,"clean_area":57700000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fr
                      mihome-vacuum.0	2021-05-13 21:49:38.530	debug	(24782) sendMsg[2] >>> {"id":88,"method":"get_status"}
                      mihome-vacuum.0	2021-05-13 21:49:33.781	debug	(24782) The answer from the robot is not correct! (SyntaxError: Unexpected end of JSON input) "{\"id\":88,\"result\":[{\"msg_ver\":2,\"msg_seq\":551,\"state\":8,\"battery\":100,\"clean_time\":3430,\"c
                      mihome-vacuum.0	2021-05-13 21:49:33.781	debug	(24782) Receive <<< {"id":88,"result":[{"msg_ver":2,"msg_seq":551,"state":8,"battery":100,"clean_time":3430,"clean_area":57700000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fr
                      mihome-vacuum.0	2021-05-13 21:49:33.529	debug	(24782) sendMsg[1] >>> {"id":88,"method":"get_status"}
                      mihome-vacuum.0	2021-05-13 21:49:33.524	debug	(24782) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2021-05-13 21:49:33.524	info	(24782) connecting, this can take up to 10 minutes ...
                      mihome-vacuum.0	2021-05-13 21:49:33.524	warn	(24782) Time difference between Mihome Vacuum and ioBroker: -1620869549 sec
                      mihome-vacuum.0	2021-05-13 21:49:33.523	debug	(24782) Receive <<< Helo <<< 213100200000000018cf333400010120ffffffffffffffffffffffffffffffff
                      Danke für eure Hilfe
                      • M my_zeus
                        Lebenszeichen: Wahr
                        Mein System:
                        Node.js v12.22.1
                        NPM 6.14.12
                        Roborock S7
                        Log
                        Maxim-777
                        @my_zeus
                        ich glaube du musst die neue Version von mihome installieren (mihome-vacuum v. 3.x.x)
                        Ist zwar noch Beta, aber teilweise funktioniert gut.
                        BG Maxim
