ich hoffe in diesem Threat etwas Hilfe zu finden, leider habe ich ebenfalls das Problem, dass sich der Roborock (S7) nicht vernünftiv verbindet,
Verbunden mit host: Wahr
Lebenszeichen: Wahr
Verbunden mit Mihome-vacuum: falsch
Mein System:
Node.js     v12.22.1
NPM         6.14.12
Adapter mihome-vacuum v. 2.1.1
Roborock S7
Log
mihome-vacuum.0	2021-05-13 21:49:53.528	debug	(24782) Receive <<< Helo <<< 213100200000000018cf333400010134ffffffffffffffffffffffffffffffff
mihome-vacuum.0	2021-05-13 21:49:48.533	debug	(24782) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
mihome-vacuum.0	2021-05-13 21:49:48.532	debug	(24782) no answer for id:88 received, giving up
mihome-vacuum.0	2021-05-13 21:49:43.699	debug	(24782) The answer from the robot is not correct! (SyntaxError: Unexpected end of JSON input) "{\"id\":88,\"result\":[{\"msg_ver\":2,\"msg_seq\":553,\"state\":8,\"battery\":100,\"clean_time\":3430,\"c
mihome-vacuum.0	2021-05-13 21:49:43.698	debug	(24782) Receive <<< {"id":88,"result":[{"msg_ver":2,"msg_seq":553,"state":8,"battery":100,"clean_time":3430,"clean_area":57700000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fr
mihome-vacuum.0	2021-05-13 21:49:43.532	debug	(24782) sendMsg[3] >>> {"id":88,"method":"get_status"}
mihome-vacuum.0	2021-05-13 21:49:38.692	debug	(24782) The answer from the robot is not correct! (SyntaxError: Unexpected end of JSON input) "{\"id\":88,\"result\":[{\"msg_ver\":2,\"msg_seq\":552,\"state\":8,\"battery\":100,\"clean_time\":3430,\"c
mihome-vacuum.0	2021-05-13 21:49:38.690	debug	(24782) Receive <<< {"id":88,"result":[{"msg_ver":2,"msg_seq":552,"state":8,"battery":100,"clean_time":3430,"clean_area":57700000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fr
mihome-vacuum.0	2021-05-13 21:49:38.530	debug	(24782) sendMsg[2] >>> {"id":88,"method":"get_status"}
mihome-vacuum.0	2021-05-13 21:49:33.781	debug	(24782) The answer from the robot is not correct! (SyntaxError: Unexpected end of JSON input) "{\"id\":88,\"result\":[{\"msg_ver\":2,\"msg_seq\":551,\"state\":8,\"battery\":100,\"clean_time\":3430,\"c
mihome-vacuum.0	2021-05-13 21:49:33.781	debug	(24782) Receive <<< {"id":88,"result":[{"msg_ver":2,"msg_seq":551,"state":8,"battery":100,"clean_time":3430,"clean_area":57700000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fr
mihome-vacuum.0	2021-05-13 21:49:33.529	debug	(24782) sendMsg[1] >>> {"id":88,"method":"get_status"}
mihome-vacuum.0	2021-05-13 21:49:33.524	debug	(24782) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
mihome-vacuum.0	2021-05-13 21:49:33.524	info	(24782) connecting, this can take up to 10 minutes ...
mihome-vacuum.0	2021-05-13 21:49:33.524	warn	(24782) Time difference between Mihome Vacuum and ioBroker: -1620869549 sec
mihome-vacuum.0	2021-05-13 21:49:33.523	debug	(24782) Receive <<< Helo <<< 213100200000000018cf333400010120ffffffffffffffffffffffffffffffff
Danke für eure Hilfe
