  5. [gelöst]Trockenlaufschutz, Problem mit Blockly
    2.9k
    5.0k
107 Beiträge 6 Kommentatoren 11.4k Aufrufe 2 Beobachtet
  • N nole
    @jan1 Ich hatte da noch nicht aktive Bausteine auf der Seite.
    <variables>
    <variable type="timeout" id="timeout3">timeout3</variable>
    </variables>
    <block type="on_ext" id=")3Y6O)OSZ6,a.eId9_([" x="-412" y="213">
    <value name="OID0">
    <shadow type="field_oid" id="FB}qA2j)SArnar=BQ8z"> <field name="oid">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.ENERGY_Power</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="nT8{B{T^As}6|P1eFdAp"> <value name="IF0"> <block type="logic_compare" id="h=ll3)j0~lH*]vID@v{h"> <field name="OP">GTE</field> <value name="A"> <block type="get_value" id="prv]M@]WP)O8kWxQv,M">
    <field name="OID">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.ENERGY_Power</field>
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="QWMd~%R.#BvSN.-Jr7|S">
    <field name="NUM">100</field>
    </block>
    </value>
    </block>
    </value>
    <statement name="DO0">
    <block type="controls_if" id=";N~?jZO,:^+(B6c4+e.p">
    <value name="IF0">
    <block type="logic_compare" id="nLGp=iM$L~IydiZi8!Z?">
    <field name="OP">LTE</field>
    <value name="A">
    <block type="get_value" id="#X;Nd8faxS1r?ibN,9Ur">
    </block>
    </value>
    <value name="B">
    <block type="math_number" id="3L+HxZZZ[6;bcStTgXv"> <field name="NUM">50</field> </block> </value> </block> </value> <statement name="DO0"> <block type="timeouts_cleartimeout" id="s_tu+G)JzfXKRo!,-i?j"> <field name="NAME">timeout3</field> </block> </statement> <next> <block type="timeouts_settimeout" id="|y|12S1gi{?f|+:!d87">
    <field name="DELAY">30</field>
    <field name="UNIT">min</field>
    <block type="control" id="]:Q/hgD*3Ye$XrhiCKVK">
    <field name="OID">sonoff.0.Sonoff-POWR2-Hauswasserpumpe.POWER</field>
    <value name="VALUE">
    <block type="logic_boolean" id="]qeVb0?p3y!^dSP8T!{!">
    </block>
    </value>
    <next>
    <block type="email" id="$9UHB7f:5pH}KOb-MKc+">
    <field name="IS_HTML">FALSE</field>
    <field name="LOG">warn</field>
    <value name="TO">
    <shadow type="text" id="k[:)o{+Cw9TDavPP#q~0">
    <field name="TEXT">nobtukpetploy@web.de</field>
    </shadow>
    </value>
    <value name="TEXT">
    <shadow type="text" id="Jg,,Cl.tlM@syT9Y]D#}">
    <field name="TEXT">Die Hauswasserpumpe ist OFF, bitte Wasser auffüllen und wieder einschalten. Danke.</field>
    </shadow>
    </value>
    <value name="SUBJECT">
    <shadow type="text" id="qh:kGtW{TIeASi#IVI)A">
    <field name="TEXT">Warnung Hauswasserpumpe</field>
    </shadow>
    </value>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </statement>
    <next>
    <block type="debug" id="jv2kcn+O#/wer{(+o+DW">
    <value name="TEXT">
    <shadow type="text">
    </shadow>
    <block type="text_join" id="FXin0|uc^i=Wm;0R-Jtj">
    <value name="ADD0">
    <block type="text" id="Z##h?{^2;N/L6AAv4~..">
    <field name="TEXT">Watt:</field>
    </block>
    </value>
    <value name="ADD1">
    <block type="on_source" id="t@LBx#Y!8Fv5({,pHM[,">
    </block>
    </value>
    </block>
    </value>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </xml>
    Jan1
    @nole
    Hast schon mal die Symbole über dem Editor gesehen wenn Du was postest? Da gibts nix zu erklären, weil das selbsterklärend ist und lösche den letzten Post, bevor ich keine Lust mehr habe mir den Finger wund zu scrollen ;)
    Edit:
    ich kenne übrigens kein Forum bei dem das nicht so gehandhabt wird und das hat nix mit Linux oder sonstigen zu tun :)
    N 2 Antworten Letzte Antwort
    • J Jan1
      @nole
      Edit:
      N Offline
      N Offline
      nole
      schrieb am zuletzt editiert von nole
      @jan1
       <variables>
       </variables>
         <value name="OID0">
           <shadow type="field_oid" id="FB}qA2j)SArn`ar=BQ8z">
           </shadow>
         </value>
             <value name="IF0">
                 <value name="A">
                   <block type="get_value" id="prv]M@]WP)O8k`WxQv,M">
                   </block>
                 </value>
                 <value name="B">
                   </block>
                 </value>
               </block>
             </value>
                 <value name="IF0">
                     <value name="A">
                       </block>
                     </value>
                     <value name="B">
                       <block type="math_number" id="3L+Hx`ZZZ[6;bcStTgXv">
                       </block>
                     </value>
                   </block>
                 </value>
                   </block>
                 </statement>
                 <next>
                   <block type="timeouts_settimeout" id="|y|12`S1gi{?f|+:!d87">
                           </block>
                         </value>
                         <next>
                             <value name="TO">
                               </shadow>
                             </value>
                             <value name="TEXT">
                               </shadow>
                             </value>
                               </shadow>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </statement>
             <next>
                 <value name="TEXT">
                   </shadow>
                     <value name="ADD0">
                       </block>
                     </value>
                     <value name="ADD1">
                       </block>
                     </value>
                   </block>
                 </value>
               </block>
             </next>
           </block>
         </statement>
       </block>
      </xml>
      [/s]
      • N nole
        @jan1
         <variables>
         </variables>
           <value name="OID0">
             </shadow>
           </value>
               <value name="IF0">
                   <value name="A">
                     </block>
                   </value>
                   <value name="B">
                     </block>
                   </value>
                 </block>
               </value>
                   <value name="IF0">
                       <value name="A">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                     </block>
                   </statement>
                   <next>
                             </block>
                           </value>
                           <next>
                               <value name="TO">
                                 </shadow>
                               </value>
                               <value name="TEXT">
                                 </shadow>
                               </value>
                                 </shadow>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
               <next>
                   <value name="TEXT">
                     </shadow>
                       <value name="ADD0">
                         </block>
                       </value>
                       <value name="ADD1">
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </statement>
         </block>
        </xml>
        [/s]
        Jan1
        @nole
        Dann noch in Code Tags im Spoiler da ich das erhalte:
        Wobei, was hast denn jetzt gepostet, das Blockly als Export (wie ich das haben möchte), oder einfach in Java Script umgeschaltet? Könnte natürlich auch an der versauten Codierung liegen, weil nicht i Code Tags gepackt.
        N 1 Antwort Letzte Antwort
        • J Jan1
          @nole
          Edit:
          N Offline
          N Offline
          nole
          @jan1 Tut mir leid, das ist mein erstes Forum und ich lerne den Umgang damit noch. Aber du hast Recht, wer richtig hinsieht ist im Vorteil.
          Habe ich das jetzt so richtig gemacht.```
            <variables>
            </variables>
              <value name="OID0">
                </shadow>
              </value>
                  <value name="IF0">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                      <value name="IF0">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                        </block>
                      </statement>
                      <next>
                                </block>
                              </value>
                              <next>
                                  <value name="TO">
                                    </shadow>
                                  </value>
                                  <value name="TEXT">
                                    </shadow>
                                  </value>
                                    </shadow>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <next>
                      <value name="TEXT">
                        </shadow>
                          <value name="ADD0">
                            </block>
                          </value>
                          <value name="ADD1">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          • J Jan1
            @nole
            N Offline
            N Offline
            nole
            @jan1 Blockly als Export
            • N nole
                <variables>
                </variables>
                  <value name="OID0">
                    </shadow>
                  </value>
                      <value name="IF0">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                          <value name="IF0">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                            </block>
                          </statement>
                          <next>
                                    </block>
                                  </value>
                                  <next>
                                      <value name="TO">
                                        </shadow>
                                      </value>
                                      <value name="TEXT">
                                        </shadow>
                                      </value>
                                        </shadow>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <next>
                          <value name="TEXT">
                            </shadow>
                              <value name="ADD0">
                                </block>
                              </value>
                              <value name="ADD1">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              Jan1
              @nole
              wenn Du jetzt noch mal was offen gepostest, dann bin ich hier raus!
              Ich kann das nicht importieren, weil wohl was fehlt oder das Ding ohne Code Tags schlicht versaut wird.
              N dslraserD 2 Antworten Letzte Antwort
              • J Jan1
                @nole
                N Offline
                N Offline
                nole
                @jan1 Tut mir leid, was habe ich denn bis jetzt richtig? Was benötigst du noch und wie mache ich das?
                Ich bin dir wirklich sehr dankbar für deine Hilfe.
                • N nole
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @nole https://forum.iobroker.net/post/394912
                  • liv-in-skyL liv-in-sky
                    Jan1
                    @liv-in-sky
                    geil, ne Anleitung dazu.
                    Kann man die irgendwie oben anpinnen?
                    liv-in-skyL N 2 Antworten Letzte Antwort
                    • J Jan1
                      @liv-in-sky
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @jan1 habe sie in den lesezeichen
                      • J Jan1
                        @nole
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        @jan1 sagte in Trockenlaufschutz, Problem mit Blockly:
                        @nole
                        Das ist von Ihm @nole (Import ging bei mir)
                          <variables>
                          </variables>
                            <value name="OID0">
                              </shadow>
                            </value>
                                <value name="IF0">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                    <value name="IF0">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                      </block>
                                    </statement>
                                    <next>
                                              </block>
                                            </value>
                                            <next>
                                                <value name="TO">
                                                  </shadow>
                                                </value>
                                                <value name="TEXT">
                                                  </shadow>
                                                </value>
                                                  </shadow>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                                <next>
                                    <value name="TEXT">
                                      </shadow>
                                        <value name="ADD0">
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </xml>
                        • J Jan1
                          @liv-in-sky
                          N Offline
                          N Offline
                          nole
                          @jan1 Ich muß das Skript wenn ich das richtig verstehe in den Code Tag (</>) packen? habe ich doch eben gemacht, oder kann man da noch was falsch machen?
                          • dslraserD dslraser
                            @nole
                              <variables>
                              </variables>
                                <value name="OID0">
                                  </shadow>
                                </value>
                                    <value name="IF0">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                        <value name="IF0">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          </block>
                                        </statement>
                                        <next>
                                                  </block>
                                                </value>
                                                <next>
                                                    <value name="TO">
                                                      </shadow>
                                                    </value>
                                                    <value name="TEXT">
                                                      </shadow>
                                                    </value>
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                    <next>
                                        <value name="TEXT">
                                          </shadow>
                                            <value name="ADD0">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </xml>
                            Jan1
                            @dslraser
                            Hm, hast Du den Admin 5 und den aktuellen JS-Controller laufen?
                            Bei mir geht kein Import!
                            • J Jan1
                              @dslraser
                              N Offline
                              N Offline
                              nole
                              @jan1 aktuell Admin 4.2.1, JS-Controller aktuell
                              • N nole
                                Jan1
                                @nole
                                Ja so ist es und dann sieht es so aus wie bei dslraser ;)
                                Ich kann das aber trotzdem nicht im portieren, was aber auch an ein paar Betas in meinem System liegen könnte.
                                Die Frage zu den Versionen war eigentlich an dslraser, weil bei Ihm Dein Export funktioniert, aber gut zu wissen, dass Du auch noch die "alten" Versionen drauf hast.
                                BBTownB 1 Antwort Letzte Antwort
                                • J Jan1
                                  @dslraser
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  @dslraser
                                  nein, beides nicht.
                                  • J Jan1
                                    @nole
                                    BBTownB Offline
                                    BBTownB Offline
                                    BBTown
                                    schrieb am zuletzt editiert von BBTown
                                    @jan1 ich kann es auch nicht importieren weil bei mir das Blockly-Modul "eMail" fehlt.
                                    Hast Du ggf. das gleiche Problem? (Ich nutze E-Mail derzeit nicht in Blockly)
                                      @dslraser
                                      nein, beides nicht.
                                      Jan1
                                      @dslraser
                                      OK, dann muss ich mal schauen, obs zu dem Bug schon was gibt ;)
                                      Kannst Du bitte das Blockly umbauen? Ich muss weg und da fehlt eh nur der stoptimeout
                                      dslraserD N 2 Antworten Letzte Antwort
                                      • J Jan1
                                        @dslraser
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        Ich muss weg
                                        ich auch...
                                        • BBTownB BBTown
                                          Jan1
                                          @bbtown
                                          E-Mail in Blockly??? Ich werd alt, was soll das denn schon wieder? Wie bekomm ich das Modul rein?
