  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 504.4k Aufrufe 82 Beobachtet
  • T tazdevil20
    @meistertr
    Hier das Log:
    2021-05-01 13:12:46.651 - debug: mihome-vacuum.0 (170106) ERROR at setGetStatus: TypeError: Cannot read property 'sendMessage' of undefined
    2021-05-01 13:12:53.126 - debug: mihome-vacuum.0 (170106) get params for stock Vacuum
    2021-05-01 13:12:53.126 - debug: mihome-vacuum.0 (170106) Message= {"id":66,"method":"get_status"}
    2021-05-01 13:12:54.182 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4367,"state":5,"battery":60,"clean_time":1,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":66}
    2021-05-01 13:12:54.182 - debug: mihome-vacuum.0 (170106) setGetStatus {"msg_ver":3,"msg_seq":4367,"state":5,"battery":60,"clean_time":1,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
    2021-05-01 13:12:54.184 - debug: mihome-vacuum.0 (170106) Message= {"id":67,"method":"get_sound_volume"}
    2021-05-01 13:12:54.191 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[43],"id":67}
    2021-05-01 13:12:54.192 - debug: mihome-vacuum.0 (170106) Message= {"id":68,"method":"get_consumable"}
    2021-05-01 13:12:54.197 - warn: mihome-vacuum.0 (170106) State value to set for "mihome-vacuum.0.info.water_box" has wrong type "boolean" but has to be "string"
    2021-05-01 13:12:54.209 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"main_brush_work_time":14749,"side_brush_work_time":14749,"filter_work_time":14749,"filter_element_work_time":0,"sensor_dirty_time":14749}],"id":68}
    2021-05-01 13:12:54.211 - debug: mihome-vacuum.0 (170106) Message= {"id":69,"method":"get_clean_summary"}
    2021-05-01 13:12:54.230 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[1561506,24796622500,1457,[1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921,1618807328,1618777063,1618766127,1618764814,1618763678,1618762805]],"id":69}
    2021-05-01 13:12:54.231 - debug: mihome-vacuum.0 (170106) Message= {"id":70,"method":"get_carpet_mode"}
    2021-05-01 13:12:54.275 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":70}
    2021-05-01 13:12:56.308 - debug: mihome-vacuum.0 (170106) Get Mappointer while cleaning
    2021-05-01 13:13:04.275 - debug: mihome-vacuum.0 (170106) get params for stock Vacuum
    2021-05-01 13:13:04.276 - debug: mihome-vacuum.0 (170106) Message= {"id":71,"method":"get_status"}
    2021-05-01 13:13:04.284 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4370,"state":5,"battery":60,"clean_time":17,"clean_area":190000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":71}
    2021-05-01 13:13:04.285 - debug: mihome-vacuum.0 (170106) setGetStatus {"msg_ver":3,"msg_seq":4370,"state":5,"battery":60,"clean_time":17,"clean_area":190000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
    2021-05-01 13:13:04.286 - debug: mihome-vacuum.0 (170106) Message= {"id":72,"method":"get_sound_volume"}
    2021-05-01 13:13:04.293 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[43],"id":72}
    2021-05-01 13:13:04.293 - debug: mihome-vacuum.0 (170106) Message= {"id":73,"method":"get_consumable"}
    2021-05-01 13:13:04.299 - warn: mihome-vacuum.0 (170106) State value to set for "mihome-vacuum.0.info.water_box" has wrong type "boolean" but has to be "string"
    2021-05-01 13:13:04.304 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"main_brush_work_time":14749,"side_brush_work_time":14749,"filter_work_time":14749,"filter_element_work_time":0,"sensor_dirty_time":14749}],"id":73}
    2021-05-01 13:13:04.305 - debug: mihome-vacuum.0 (170106) Message= {"id":74,"method":"get_clean_summary"}
    2021-05-01 13:13:04.320 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[1561506,24796622500,1457,[1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921,1618807328,1618777063,1618766127,1618764814,1618763678,1618762805]],"id":74}
    2021-05-01 13:13:04.321 - debug: mihome-vacuum.0 (170106) Message= {"id":75,"method":"get_carpet_mode"}
    2021-05-01 13:13:04.328 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":75}
    2021-05-01 13:13:14.330 - debug: mihome-vacuum.0 (170106) get params for stock Vacuum
    2021-05-01 13:13:14.331 - debug: mihome-vacuum.0 (170106) Message= {"id":76,"method":"get_status"}
    2021-05-01 13:13:15.339 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4373,"state":5,"battery":60,"clean_time":30,"clean_area":527500,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":76}
    2021-05-01 13:13:15.340 - debug: mihome-vacuum.0 (170106) setGetStatus {"msg_ver":3,"msg_seq":4373,"state":5,"battery":60,"clean_time":30,"clean_area":527500,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
    2021-05-01 13:13:15.341 - debug: mihome-vacuum.0 (170106) Message= {"id":77,"method":"get_sound_volume"}
    2021-05-01 13:13:15.349 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[43],"id":77}
    2021-05-01 13:13:15.349 - debug: mihome-vacuum.0 (170106) Message= {"id":78,"method":"get_consumable"}
    2021-05-01 13:13:15.355 - warn: mihome-vacuum.0 (170106) State value to set for "mihome-vacuum.0.info.water_box" has wrong type "boolean" but has to be "string"
    2021-05-01 13:13:15.356 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"main_brush_work_time":14749,"side_brush_work_time":14749,"filter_work_time":14749,"filter_element_work_time":0,"sensor_dirty_time":14749}],"id":78}
    2021-05-01 13:13:15.356 - debug: mihome-vacuum.0 (170106) Message= {"id":79,"method":"get_clean_summary"}
    2021-05-01 13:13:15.364 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[1561506,24796622500,1457,[1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921,1618807328,1618777063,1618766127,1618764814,1618763678,1618762805]],"id":79}
    2021-05-01 13:13:15.365 - debug: mihome-vacuum.0 (170106) Message= {"id":80,"method":"get_carpet_mode"}
    2021-05-01 13:13:15.372 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":80}
    2021-05-01 13:13:25.375 - debug: mihome-vacuum.0 (170106) get params for stock Vacuum
    2021-05-01 13:13:25.375 - debug: mihome-vacuum.0 (170106) Message= {"id":81,"method":"get_status"}
    2021-05-01 13:13:25.383 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4376,"state":5,"battery":60,"clean_time":38,"clean_area":785000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":81}
    2021-05-01 13:13:25.384 - debug: mihome-vacuum.0 (170106) setGetStatus {"msg_ver":3,"msg_seq":4376,"state":5,"battery":60,"clean_time":38,"clean_area":785000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
    2021-05-01 13:13:25.385 - debug: mihome-vacuum.0 (170106) Message= {"id":82,"method":"get_sound_volume"}
    2021-05-01 13:13:25.391 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[43],"id":82}
    2021-05-01 13:13:25.392 - debug: mihome-vacuum.0 (170106) Message= {"id":83,"method":"get_consumable"}
    2021-05-01 13:13:25.393 - warn: mihome-vacuum.0 (170106) State value to set for "mihome-vacuum.0.info.water_box" has wrong type "boolean" but has to be "string"
    2021-05-01 13:13:25.404 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"main_brush_work_time":14749,"side_brush_work_time":14749,"filter_work_time":14749,"filter_element_work_time":0,"sensor_dirty_time":14749}],"id":83}
    2021-05-01 13:13:25.405 - debug: mihome-vacuum.0 (170106) Message= {"id":84,"method":"get_clean_summary"}
    2021-05-01 13:13:25.422 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[1561506,24796622500,1457,[1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921,1618807328,1618777063,1618766127,1618764814,1618763678,1618762805]],"id":84}
    2021-05-01 13:13:25.423 - debug: mihome-vacuum.0 (170106) Message= {"id":85,"method":"get_carpet_mode"}
    2021-05-01 13:13:25.434 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":85}
    2021-05-01 13:13:27.838 - debug: mihome-vacuum.0 (170106) Receive <<< Helo <<< 213100200000000005c27ac2608d37d7ffffffffffffffffffffffffffffffff
    2021-05-01 13:13:35.437 - debug: mihome-vacuum.0 (170106) get params for stock Vacuum
    2021-05-01 13:13:35.437 - debug: mihome-vacuum.0 (170106) Message= {"id":86,"method":"get_status"}
    2021-05-01 13:13:36.520 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4380,"state":5,"battery":60,"clean_time":51,"clean_area":1372500,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":86}
    2021-05-01 13:13:36.520 - debug: mihome-vacuum.0 (170106) setGetStatus {"msg_ver":3,"msg_seq":4380,"state":5,"battery":60,"clean_time":51,"clean_area":1372500,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
    2021-05-01 13:13:36.521 - debug: mihome-vacuum.0 (170106) Message= {"id":87,"method":"get_sound_volume"}
    2021-05-01 13:13:36.525 - warn: mihome-vacuum.0 (170106) State value to set for "mihome-vacuum.0.info.water_box" has wrong type "boolean" but has to be "string"
    2021-05-01 13:13:36.527 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[43],"id":87}
    2021-05-01 13:13:36.528 - debug: mihome-vacuum.0 (170106) Message= {"id":88,"method":"get_consumable"}
    2021-05-01 13:13:36.535 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"main_brush_work_time":14749,"side_brush_work_time":14749,"filter_work_time":14749,"filter_element_work_time":0,"sensor_dirty_time":14749}],"id":88}
    2021-05-01 13:13:36.535 - debug: mihome-vacuum.0 (170106) Message= {"id":89,"method":"get_clean_summary"}
    2021-05-01 13:13:36.547 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[1561506,24796622500,1457,[1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921,1618807328,1618777063,1618766127,1618764814,1618763678,1618762805]],"id":89}
    2021-05-01 13:13:36.547 - debug: mihome-vacuum.0 (170106) Message= {"id":90,"method":"get_carpet_mode"}
    2021-05-01 13:13:36.554 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":90}
    2021-05-01 13:13:46.556 - debug: mihome-vacuum.0 (170106) get params for stock Vacuum
    2021-05-01 13:13:46.557 - debug: mihome-vacuum.0 (170106) Message= {"id":91,"method":"get_status"}
    2021-05-01 13:13:46.567 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4383,"state":5,"battery":60,"clean_time":60,"clean_area":1640000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":91}
    2021-05-01 13:13:46.568 - debug: mihome-vacuum.0 (170106) setGetStatus {"msg_ver":3,"msg_seq":4383,"state":5,"battery":60,"clean_time":60,"clean_area":1640000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
    2021-05-01 13:13:46.568 - debug: mihome-vacuum.0 (170106) Message= {"id":92,"method":"get_sound_volume"}
    2021-05-01 13:13:46.578 - warn: mihome-vacuum.0 (170106) State value to set for "mihome-vacuum.0.info.water_box" has wrong type "boolean" but has to be "string"
    2021-05-01 13:13:46.582 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[43],"id":92}
    2021-05-01 13:13:46.582 - debug: mihome-vacuum.0 (170106) Message= {"id":93,"method":"get_consumable"}
    2021-05-01 13:13:46.590 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"main_brush_work_time":14749,"side_brush_work_time":14749,"filter_work_time":14749,"filter_element_work_time":0,"sensor_dirty_time":14749}],"id":93}
    2021-05-01 13:13:46.591 - debug: mihome-vacuum.0 (170106) Message= {"id":94,"method":"get_clean_summary"}
    2021-05-01 13:13:46.602 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[1561506,24796622500,1457,[1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921,1618807328,1618777063,1618766127,1618764814,1618763678,1618762805]],"id":94}
    2021-05-01 13:13:46.603 - debug: mihome-vacuum.0 (170106) Message= {"id":95,"method":"get_carpet_mode"}
    2021-05-01 13:13:46.614 - debug: mihome-vacuum.0 (170106) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":95}
    Interessant ist, dass jetzt beim beginn des Saugvorgangs (über iobroker) ein paar Umrisse angezeigt wurden. Zuvor habe ich schonmal saugen lassen und da hat er scheinbar nach ca. 10 Sekunden die Karte einmalig aktualisiert.
    So sieht jetzt die Karte bis zum schluss aus:
    data:image/png;base64,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
    Vielen Dank für die tolle Arbeit.
    MeistertrM Offline
    MeistertrM Offline
    Meistertr
    #122
    @tazdevil20 sagte in Test Adapter Mihome-vacuum v3.1.3 Next Generarition:
    water_box
    ist das schon mit der 3.1.3? wenn nciht bitte nochmal updaten falls ja, bitte komplett löschen und neu installieren
    • MeistertrM Meistertr
      water_box
      saeft_2003
      #123
      @meistertr
      Könntest du bitte noch kurz meine Frage beantworten. Danke ☺️
      https://forum.iobroker.net/topic/44077/test-adapter-mihome-vacuum-v3-1-3-next-generarition/119
      • S saeft_2003
        @meistertr
        Ok. Ich wollte mal kurz Danke sagen, dass mit dem Kartenwechsel funktioniert einwandfrei und zügig, genau das habe ich gebraucht. Großes Lob 😊👍
        Eins vermisse ich noch. Das der state von einem Raum auf die Info „clean Room“ geht auch wenn die Raumreinigung aus der App heraus gestartet wurde. Ist das möglich?
        MeistertrM Offline
        MeistertrM Offline
        Meistertr
        #124
        @saeft_2003 ja das ist möglich
          saeft_2003
          #125
          @meistertr sagte in Test Adapter Mihome-vacuum v3.1.3 Next Generarition:
          Das wäre echt super. Müsste das jetzt schon gehen, oder baust du das in die nächste Version ein?
          C 1 Antwort Letzte Antwort
          • S saeft_2003
            Coffeelover
            #126
            Thema Mehrzonenreinigung:
            Nach dem Fehler, dass jeder Raum nur noch roomxyz hieß, habe ich es endlich geschafft, die ursprünglichen Räume wieder mit VIS zu verknüpfen. Heute den ersten Raum angeklickt - Robbie direkt los zur Raumreinigung. Dann zweiten Raum angeklickt, der Raum bekam den State Waiting, aber der S7 ist nach Raum 1 direkt wieder zum Laden gefahren. Was mache ich falsch?
            Thema Wischtuch:
            Hat irgendwer von euch eine Lösung zB via Script, die den Roboter nach getaner Wischarbeit und mit montiertem Wischtuch zum Waschbecken statt zum Laden fährt?
            • C Coffeelover
              Thema Wischtuch:
              saeft_2003
              #127
              @coffeelover sagte in Test Adapter Mihome-vacuum v3.1.3 Next Generarition:
              Hast du mal kurz gewartet? bei mir ist er manchmal auch schon fast an der LS und bekommt dann erst das Signal für den nächsten Raum. Steht bei dir multiroom auf true? Steht der Raum dann im queue?
              Thema Wischtuch:
              Ich hätte auch gern die Info im iobroker ob das wischtuch angebracht ist oder nicht, ob das möglich ist kann uns nur @MeisterTR beantworten?
              C MeistertrM 2 Antworten Letzte Antwort
              • S saeft_2003
                Thema Wischtuch:
                Coffeelover
                #128
                @saeft_2003
                Ich habe gewartet, bis er zurück war. Nach ner Stunde habe ich ne Komplett-Reinigung gestartet; bis dahin war nichts passiert. Multimap war true und im Queue stand irgendwas mit "Segment [xxxxx, yyyyy]". Wenn ich methodisch richtig unterwegs bin, teste ich einfach noch einmal.
                Es gibt im iobroker ja schon das Signal des Wassertanks.
                Das würde mir reichen, da ich immer Tank und Tuch montiere oder demontiere. Versuche mich die Tage einfach an nem Script.
                MeistertrM 1 Antwort Letzte Antwort
                • C Coffeelover
                  @saeft_2003
                  MeistertrM Offline
                  MeistertrM Offline
                  Meistertr
                  #129
                  @coffeelover werde ich mir nochmal genauer anschauen
                  • S saeft_2003
                    Thema Wischtuch:
                    MeistertrM Offline
                    MeistertrM Offline
                    Meistertr
                    #130
                    @saeft_2003 gerne selber Testen und berichten: Adapter auf debug und die nachricht fur get_status komtrollieren mit und ohne Wischtuch ob es dafür ein flag gibt und berichten.
                    • MeistertrM Offline
                      MeistertrM Offline
                      Meistertr
                      #131
                      in der 3.1.4 sind die Verbindungsprobleme behoben.
                        saeft_2003
                        #132
                        @meistertr sagte in Test Adapter Mihome-vacuum v3.1.4 Next Generarition:
                        Ok mache ich bei Gelegenheit.
                        Weiter oben hattest du gesagt das es möglich ist das der state von einem Raum auf clean Room geht auch wenn die Raumreinigung aus der app heraus gestartet wurde. Müsste das jetzt schon gehen, oder ist das für nächste Versionen geplant?
                        • S saeft_2003
                          MeistertrM Offline
                          MeistertrM Offline
                          Meistertr
                          schrieb am zuletzt editiert von Meistertr
                          #133
                          @saeft_2003 hab das gerade nochmal kontrolliert. Eine Zuordnung der Räume bei Appstart geht nicht, wel dieapp/sauger keine unterschied macht zwischen den Räumen, Es geht nur "es werden 3 Räume gesaugt", was ich machen kann ist ein state mit ActualCleanRooms, wo ein arra mit den aktuell zu Saugenden Räumen aufgelistet wird.
                          Edit. was auch gehen würde, dass man vergleicht in welchen raum sich der Roboter gerade befindet und daran den aktuellen Raum bestimmt (mach ich aber nicht weil ich echt noch ne Menge Arbeit vorm mir habe) also wenn sich dafür jemand berufen fühlt, gerne Hand anlegen
                            saeft_2003
                            schrieb am zuletzt editiert von saeft_2003
                            #134
                            @meistertr
                            OK danke.
                            Themawechsel bezüglich der Info ob die Wischplatte dran ist. Ich habe heute im debug saugen und wischen lassen.
                            Beim wischen steht bei setgetstate mop_forbidden_enable: 1
                            Beim saugen ohne Wischplatte steht mop_forbidden_enable: 0
                            Ich habe nicht viel Ahnung aber für mich sieht es so aus als kann man daran erkennen ob die Wischplatte dran ist oder nicht. Ist es ein großes Ding hierfür ein DP mit einzubauen beim nächsten Update?
                              @tazdevil20 natürlich nicht. Bitte mal einen debug log posten damit ich sehen kann was da los ist. Vom Saugen am besten
                              tazdevil20
                              schrieb am zuletzt editiert von tazdevil20
                              #135
                              @meistertr
                              Es war noch die 3.1.1. Habe den Adapter deinstalliert und direkt von git neu installiert.
                              Leider ist das Problem noch da (hatte den Wert "Request Intervall" von 2000 auf 1000 heruntergesetzt):
                              2021-05-02 14:21:15.405 - info: mihome-vacuum.0 (254330) State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
                              2021-05-02 14:21:23.741 - info: host.iobroker stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                              2021-05-02 14:21:23.746 - info: host.iobroker stopInstance system.adapter.mihome-vacuum.0 send kill signal
                              2021-05-02 14:21:23.746 - info: mihome-vacuum.0 (254330) Got terminate signal TERMINATE_YOURSELF
                              2021-05-02 14:21:23.747 - info: mihome-vacuum.0 (254330) terminating
                              2021-05-02 14:21:23.748 - info: mihome-vacuum.0 (254330) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2021-05-02 14:21:24.335 - info: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2021-05-02 14:21:26.857 - info: host.iobroker instance system.adapter.mihome-vacuum.0 started with pid 254450
                              2021-05-02 14:21:27.711 - debug: mihome-vacuum.0 (254450) Redis Objects: Use Redis connection: 0.0.0.0:9001
                              2021-05-02 14:21:27.771 - debug: mihome-vacuum.0 (254450) Objects client ready ... initialize now
                              2021-05-02 14:21:27.772 - debug: mihome-vacuum.0 (254450) Objects create System PubSub Client
                              2021-05-02 14:21:27.773 - debug: mihome-vacuum.0 (254450) Objects create User PubSub Client
                              2021-05-02 14:21:27.773 - debug: mihome-vacuum.0 (254450) Objects client initialize lua scripts
                              2021-05-02 14:21:27.865 - debug: mihome-vacuum.0 (254450) Objects connected to redis: 0.0.0.0:9001
                              2021-05-02 14:21:27.870 - debug: mihome-vacuum.0 (254450) objectDB connected
                              2021-05-02 14:21:27.872 - debug: mihome-vacuum.0 (254450) Redis States: Use Redis connection: 0.0.0.0:6379
                              2021-05-02 14:21:27.877 - debug: mihome-vacuum.0 (254450) States create System PubSub Client
                              2021-05-02 14:21:27.878 - debug: mihome-vacuum.0 (254450) States create User PubSub Client
                              2021-05-02 14:21:27.883 - debug: mihome-vacuum.0 (254450) States connected to redis: 0.0.0.0:6379
                              2021-05-02 14:21:27.884 - debug: mihome-vacuum.0 (254450) statesDB connected
                              2021-05-02 14:21:28.156 - info: mihome-vacuum.0 (254450) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.3.5
                              2021-05-02 14:21:28.347 - info: mihome-vacuum.0 (254450) check user admin pw iobroker: true,system.user.admin
                              2021-05-02 14:21:28.351 - info: mihome-vacuum.0 (254450) check group user admin group admin: false
                              2021-05-02 14:21:28.355 - debug: mihome-vacuum.0 (254450) Create State for deviceInfomac
                              2021-05-02 14:21:28.356 - debug: mihome-vacuum.0 (254450) Create State for deviceInfomodel
                              2021-05-02 14:21:28.399 - debug: mihome-vacuum.0 (254450) Create State for deviceInfofw_ver
                              2021-05-02 14:21:28.400 - debug: mihome-vacuum.0 (254450) Create State for deviceInfowifi_signal
                              2021-05-02 14:21:28.401 - debug: mihome-vacuum.0 (254450) MIIO: Config: ip:192.168.178.40 token: 707148336f746b544a386f4366534c70
                              2021-05-02 14:21:28.405 - debug: mihome-vacuum.0 (254450) server started on 0.0.0.0:53421
                              2021-05-02 14:21:28.411 - debug: mihome-vacuum.0 (254450) Receive <<< Helo <<< 213100200000000005c27ac2608e9948ffffffffffffffffffffffffffffffff
                              2021-05-02 14:21:28.411 - debug: mihome-vacuum.0 (254450) MAIN: Connected to device, try to get model..
                              2021-05-02 14:21:28.416 - debug: mihome-vacuum.0 (254450) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5","ack":true,"ts":1619957752998,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1619957752998}
                              2021-05-02 14:21:28.417 - debug: mihome-vacuum.0 (254450) Message= {"id":1,"method":"miIO.info"}
                              2021-05-02 14:21:28.426 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_002034","ap":{"ssid":"TazDevilsCave","bssid":"E0:28:6D:31:24:24","rssi":-51},"netif":{"localIp":"192.168.178.40","mask":"255.255.255.0","gw":"192.168.178.1\n127.0.0.1"},"model":"roborock.vacuum.s5","mac":"7C:49:EB:9D:AC:E3","token":"707148336f746b544a386f4366534c70","life":37678}}
                              2021-05-02 14:21:28.427 - debug: mihome-vacuum.0 (254450) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_002034","ap":{"ssid":"TazDevilsCave","bssid":"E0:28:6D:31:24:24","rssi":-51},"netif":{"localIp":"192.168.178.40","mask":"255.255.255.0","gw":"192.168.178.1\n127.0.0.1"},"model":"roborock.vacuum.s5","mac":"7C:49:EB:9D:AC:E3","token":"707148336f746b544a386f4366534c70","life":37678}}
                              2021-05-02 14:21:28.427 - debug: mihome-vacuum.0 (254450) Get Device data..0
                              2021-05-02 14:21:28.428 - debug: mihome-vacuum.0 (254450) Get Device data from robot..
                              2021-05-02 14:21:28.428 - debug: mihome-vacuum.0 (254450) DeviceModel selected to: roborock.vacuum.s5
                              2021-05-02 14:21:28.429 - info: mihome-vacuum.0 (254450) select standard vacuum protocol....
                              2021-05-02 14:21:28.445 - debug: mihome-vacuum.0 (254450) Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                              2021-05-02 14:21:28.451 - debug: mihome-vacuum.0 (254450) Create State for deviceInfoundefined
                              2021-05-02 14:21:28.452 - debug: mihome-vacuum.0 (254450) Create State for deviceInfoundefined
                              2021-05-02 14:21:28.453 - debug: mihome-vacuum.0 (254450) Create State for deviceInfoundefined
                              2021-05-02 14:21:28.454 - debug: mihome-vacuum.0 (254450) Create State for deviceInfoundefined
                              2021-05-02 14:21:28.455 - debug: mihome-vacuum.0 (254450) Create State for deviceInfoundefined
                              2021-05-02 14:21:28.468 - debug: mihome-vacuum.0 (254450) Create State for deviceInfoundefined
                              2021-05-02 14:21:28.469 - debug: mihome-vacuum.0 (254450) Create State for deviceInfoundefined
                              2021-05-02 14:21:28.640 - debug: mihome-vacuum.0 (254450) Create State for deviceInfo{"id":"mihome-vacuum.0.control.clean_home"}
                              2021-05-02 14:21:28.643 - debug: mihome-vacuum.0 (254450) Create State for stockInfoundefined
                              2021-05-02 14:21:28.644 - debug: mihome-vacuum.0 (254450) Create State for stockInfoundefined
                              2021-05-02 14:21:28.645 - debug: mihome-vacuum.0 (254450) Create State for stockInfoundefined
                              2021-05-02 14:21:28.647 - debug: mihome-vacuum.0 (254450) Create State for stockInfoundefined
                              2021-05-02 14:21:28.652 - debug: mihome-vacuum.0 (254450) Create State for stockConsumableundefined
                              2021-05-02 14:21:28.653 - debug: mihome-vacuum.0 (254450) Create State for stockConsumableundefined
                              2021-05-02 14:21:28.655 - debug: mihome-vacuum.0 (254450) Create State for stockConsumableundefined
                              2021-05-02 14:21:28.656 - debug: mihome-vacuum.0 (254450) Create State for stockConsumableundefined
                              2021-05-02 14:21:28.658 - debug: mihome-vacuum.0 (254450) Create State for stockConsumableundefined
                              2021-05-02 14:21:28.661 - debug: mihome-vacuum.0 (254450) Create State for stockHistoryundefined
                              2021-05-02 14:21:28.662 - debug: mihome-vacuum.0 (254450) Create State for stockHistoryundefined
                              2021-05-02 14:21:28.664 - debug: mihome-vacuum.0 (254450) Create State for stockHistoryundefined
                              2021-05-02 14:21:28.667 - debug: mihome-vacuum.0 (254450) Create State for Queue: queue
                              2021-05-02 14:21:28.668 - debug: mihome-vacuum.0 (254450) Create State for Queue: clearQueue
                              2021-05-02 14:21:28.671 - debug: mihome-vacuum.0 (254450) Create State for enableResumeZoneundefined
                              2021-05-02 14:21:28.711 - debug: mihome-vacuum.0 (254450) Create State for enableResumeZoneundefined
                              2021-05-02 14:21:28.712 - info: mihome-vacuum.0 (254450) Map not selected delete states...
                              2021-05-02 14:21:28.712 - debug: mihome-vacuum.0 (254450) Create State done!
                              2021-05-02 14:21:28.713 - debug: mihome-vacuum.0 (254450) get params for stock Vacuum
                              2021-05-02 14:21:28.713 - debug: mihome-vacuum.0 (254450) Message= {"id":2,"method":"get_status"}
                              2021-05-02 14:21:28.721 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4637,"state":3,"battery":64,"clean_time":751,"clean_area":12132500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":2}
                              2021-05-02 14:21:28.722 - debug: mihome-vacuum.0 (254450) setGetStatus {"msg_ver":3,"msg_seq":4637,"state":3,"battery":64,"clean_time":751,"clean_area":12132500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
                              2021-05-02 14:21:28.722 - info: mihome-vacuum.0 (254450) change states from State control.fan_power
                              2021-05-02 14:21:29.676 - info: mihome-vacuum.0 (254450) create states for water box
                              2021-05-02 14:21:29.827 - warn: mihome-vacuum.0 (254450) State "mihome-vacuum.0.cleanmap.actualMap" has no existing object, this might lead to an error in future versions
                              2021-05-02 14:21:29.977 - info: mihome-vacuum.0 (254450) settest next timer: not available
                              2021-05-02 14:21:29.979 - warn: mihome-vacuum.0 (254450) State "mihome-vacuum.0.cleanmap.mapStatus" has no existing object, this might lead to an error in future versions
                              2021-05-02 14:21:29.995 - debug: mihome-vacuum.0 (254450) Message= {"id":3,"method":"get_map_v1"}
                              2021-05-02 14:21:30.004 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":["map_slot_2"],"id":3}
                              2021-05-02 14:21:30.004 - debug: mihome-vacuum.0 (254450) Message= {"id":4,"method":"get_room_mapping"}
                              2021-05-02 14:21:30.014 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[],"id":4}
                              2021-05-02 14:21:30.015 - debug: mihome-vacuum.0 (254450) Message= {"id":5,"method":"get_network_info"}
                              2021-05-02 14:21:30.040 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":{"ssid":"TazDevilsCave","ip":"192.168.178.40","mac":"7c:49:eb:9d:ac:e3","bssid":"e0:28:6d:31:24:24","rssi":-70},"id":5}
                              2021-05-02 14:21:30.043 - info: mihome-vacuum.0 (254450) State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
                              2021-05-02 14:21:30.086 - debug: mihome-vacuum.0 (254450) Message= {"id":6,"method":"get_sound_volume"}
                              2021-05-02 14:21:30.095 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[43],"id":6}
                              2021-05-02 14:21:30.096 - debug: mihome-vacuum.0 (254450) Message= {"id":7,"method":"get_consumable"}
                              2021-05-02 14:21:30.103 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"main_brush_work_time":20896,"side_brush_work_time":20896,"filter_work_time":20896,"filter_element_work_time":0,"sensor_dirty_time":20896}],"id":7}
                              2021-05-02 14:21:30.104 - debug: mihome-vacuum.0 (254450) Message= {"id":8,"method":"get_clean_summary"}
                              2021-05-02 14:21:30.115 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[1567653,24874245000,1463,[1619956959,1619954510,1619882398,1619880796,1619868270,1619867565,1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921]],"id":8}
                              2021-05-02 14:21:30.117 - debug: mihome-vacuum.0 (254450) Message= {"id":9,"method":"get_clean_record","params":[1619956959]}
                              2021-05-02 14:21:30.127 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619956959,1619957710,751,12132500,0,1,1,1]],"id":9}
                              2021-05-02 14:21:30.128 - debug: mihome-vacuum.0 (254450) Message= {"id":10,"method":"get_clean_record","params":[1619954510]}
                              2021-05-02 14:21:30.134 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619954510,1619956251,1741,16475000,0,1,1,1]],"id":10}
                              2021-05-02 14:21:30.135 - debug: mihome-vacuum.0 (254450) Message= {"id":11,"method":"get_clean_record","params":[1619882398]}
                              2021-05-02 14:21:30.140 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619882398,1619883889,1491,26180000,0,1,2,1]],"id":11}
                              2021-05-02 14:21:30.141 - debug: mihome-vacuum.0 (254450) Message= {"id":12,"method":"get_clean_record","params":[1619880796]}
                              2021-05-02 14:21:30.148 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619880796,1619881635,839,8080000,0,1,2,1]],"id":12}
                              2021-05-02 14:21:30.149 - debug: mihome-vacuum.0 (254450) Message= {"id":13,"method":"get_clean_record","params":[1619868270]}
                              2021-05-02 14:21:30.154 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619868270,1619868973,703,8010000,0,1,1,1]],"id":13}
                              2021-05-02 14:21:30.154 - debug: mihome-vacuum.0 (254450) Message= {"id":14,"method":"get_clean_record","params":[1619867565]}
                              2021-05-02 14:21:30.167 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619867565,1619868187,622,6745000,0,1,2,1]],"id":14}
                              2021-05-02 14:21:30.168 - debug: mihome-vacuum.0 (254450) Message= {"id":15,"method":"get_clean_record","params":[1619863687]}
                              2021-05-02 14:21:30.176 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619863687,1619866641,2761,43242500,0,1,1,1]],"id":15}
                              2021-05-02 14:21:30.177 - debug: mihome-vacuum.0 (254450) Message= {"id":16,"method":"get_clean_record","params":[1619799323]}
                              2021-05-02 14:21:30.185 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619799323,1619800154,831,13825000,0,1,1,1]],"id":16}
                              2021-05-02 14:21:30.186 - debug: mihome-vacuum.0 (254450) Message= {"id":17,"method":"get_clean_record","params":[1619794271]}
                              2021-05-02 14:21:30.193 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619794271,1619794425,154,1240000,0,1,2,1]],"id":17}
                              2021-05-02 14:21:30.193 - debug: mihome-vacuum.0 (254450) Message= {"id":18,"method":"get_clean_record","params":[1619792296]}
                              2021-05-02 14:21:30.201 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619792296,1619793110,814,8047500,0,1,2,1]],"id":18}
                              2021-05-02 14:21:30.201 - debug: mihome-vacuum.0 (254450) Message= {"id":19,"method":"get_clean_record","params":[1619787328]}
                              2021-05-02 14:21:30.211 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619787328,1619789894,2566,41182500,0,1,1,1]],"id":19}
                              2021-05-02 14:21:30.211 - debug: mihome-vacuum.0 (254450) Message= {"id":20,"method":"get_clean_record","params":[1619713333]}
                              2021-05-02 14:21:30.218 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619713333,1619713497,164,1277500,0,1,1,1]],"id":20}
                              2021-05-02 14:21:30.218 - debug: mihome-vacuum.0 (254450) Message= {"id":21,"method":"get_clean_record","params":[1619702461]}
                              2021-05-02 14:21:30.225 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619702461,1619703685,1224,10507500,0,1,1,1]],"id":21}
                              2021-05-02 14:21:30.226 - debug: mihome-vacuum.0 (254450) Message= {"id":22,"method":"get_clean_record","params":[1619699767]}
                              2021-05-02 14:21:30.231 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619699767,1619700772,1005,18107500,0,1,2,1]],"id":22}
                              2021-05-02 14:21:30.231 - debug: mihome-vacuum.0 (254450) Message= {"id":23,"method":"get_clean_record","params":[1619346926]}
                              2021-05-02 14:21:30.240 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619346926,1619348082,1022,16347500,0,1,1,1]],"id":23}
                              2021-05-02 14:21:30.241 - debug: mihome-vacuum.0 (254450) Message= {"id":24,"method":"get_clean_record","params":[1619342131]}
                              2021-05-02 14:21:30.247 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619342131,1619344605,2474,43072500,0,1,1,1]],"id":24}
                              2021-05-02 14:21:30.248 - debug: mihome-vacuum.0 (254450) Message= {"id":25,"method":"get_clean_record","params":[1619263352]}
                              2021-05-02 14:21:30.254 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619263352,1619264204,852,7905000,0,1,1,1]],"id":25}
                              2021-05-02 14:21:30.255 - debug: mihome-vacuum.0 (254450) Message= {"id":26,"method":"get_clean_record","params":[1619259412]}
                              2021-05-02 14:21:30.261 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1619259412,1619260294,882,7822500,0,1,1,1]],"id":26}
                              2021-05-02 14:21:30.262 - debug: mihome-vacuum.0 (254450) Message= {"id":27,"method":"get_clean_record","params":[1618813425]}
                              2021-05-02 14:21:30.274 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1618813425,1618815463,2038,37245000,0,1,1,1]],"id":27}
                              2021-05-02 14:21:30.275 - debug: mihome-vacuum.0 (254450) Message= {"id":28,"method":"get_clean_record","params":[1618808921]}
                              2021-05-02 14:21:30.281 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[[1618808921,1618809175,254,2250000,0,1,2,1]],"id":28}
                              2021-05-02 14:21:30.282 - debug: mihome-vacuum.0 (254450) finish logs all [{"Datum":"2.5","Start":"14:02","Saugzeit":"13 min","Fläche":"12.13 m²","Error":0,"Ende":true},{"Datum":"2.5","Start":"13:21","Saugzeit":"29 min","Fläche":"16.48 m²","Error":0,"Ende":true},{"Datum":"1.5","Start":"17:19","Saugzeit":"25 min","Fläche":"26.18 m²","Error":0,"Ende":true},{"Datum":"1.5","Start":"16:53","Saugzeit":"14 min","Fläche":"8.08 m²","Error":0,"Ende":true},{"Datum":"1.5","Start":"13:24","Saugzeit":"12 min","Fläche":"8.01 m²","Error":0,"Ende":true},{"Datum":"1.5","Start":"13:12","Saugzeit":"10 min","Fläche":"6.75 m²","Error":0,"Ende":true},{"Datum":"1.5","Start":"12:08","Saugzeit":"46 min","Fläche":"43.24 m²","Error":0,"Ende":true},{"Datum":"30.4","Start":"18:15","Saugzeit":"14 min","Fläche":"13.83 m²","Error":0,"Ende":true},{"Datum":"30.4","Start":"16:51","Saugzeit":"3 min","Fläche":"1.24 m²","Error":0,"Ende":true},{"Datum":"30.4","Start":"16:18","Saugzeit":"14 min","Fläche":"8.05 m²","Error":0,"Ende":true},{"Datum":"30.4","Start":"14:55","Saugzeit":"43 min","Fläche":"41.18 m²","Error":0,"Ende":true},{"Datum":"29.4","Start":"18:22","Saugzeit":"3 min","Fläche":"1.28 m²","Error":0,"Ende":true},{"Datum":"29.4","Start":"15:21","Saugzeit":"20 min","Fläche":"10.51 m²","Error":0,"Ende":true},{"Datum":"29.4","Start":"14:36","Saugzeit":"17 min","Fläche":"18.11 m²","Error":0,"Ende":true},{"Datum":"25.4","Start":"12:35","Saugzeit":"17 min","Fläche":"16.35 m²","Error":0,"Ende":true},{"Datum":"25.4","Start":"11:15","Saugzeit":"41 min","Fläche":"43.07 m²","Error":0,"Ende":true},{"Datum":"24.4","Start":"13:22","Saugzeit":"14 min","Fläche":"7.91 m²","Error":0,"Ende":true},{"Datum":"24.4","Start":"12:16","Saugzeit":"15 min","Fläche":"7.82 m²","Error":0,"Ende":true},{"Datum":"19.4","Start":"08:23","Saugzeit":"34 min","Fläche":"37.25 m²","Error":0,"Ende":true},{"Datum":"19.4","Start":"07:08","Saugzeit":"4 min","Fläche":"2.25 m²","Error":0,"Ende":true}]
                              2021-05-02 14:21:30.283 - debug: mihome-vacuum.0 (254450) Message= {"id":29,"method":"get_multi_maps_list"}
                              2021-05-02 14:21:30.291 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":"unknown_method","id":29}
                              2021-05-02 14:21:30.292 - debug: mihome-vacuum.0 (254450) Message= {"id":30,"method":"get_map_v1"}
                              2021-05-02 14:21:30.300 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":["map_slot_3"],"id":30}
                              2021-05-02 14:21:30.301 - debug: mihome-vacuum.0 (254450) Message= {"id":31,"method":"get_carpet_mode"}
                              2021-05-02 14:21:30.328 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":31}
                              2021-05-02 14:21:30.329 - info: mihome-vacuum.0 (254450) create state for carpet_mode
                              2021-05-02 14:21:30.329 - debug: mihome-vacuum.0 (254450) Message= {"id":32,"method":"get_carpet_mode"}
                              2021-05-02 14:21:30.335 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":32}
                              2021-05-02 14:21:38.416 - debug: mihome-vacuum.0 (254450) Receive <<< Helo <<< 213100200000000005c27ac2608e9952ffffffffffffffffffffffffffffffff
                              2021-05-02 14:21:40.908 - debug: mihome-vacuum.0 (254450) command: start parent: control
                              2021-05-02 14:21:40.909 - debug: mihome-vacuum.0 (254450) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                              2021-05-02 14:21:40.910 - debug: mihome-vacuum.0 (254450) start Cleaning: 5 MObj: {}
                              2021-05-02 14:21:40.910 - info: mihome-vacuum.0 (254450) trigger cleaning all
                              2021-05-02 14:21:40.910 - debug: mihome-vacuum.0 (254450) Message= {"id":33,"method":"app_start"}
                              2021-05-02 14:21:40.913 - debug: mihome-vacuum.0 (254450) We are in onMessage:{"command":"startVacuuming","message":null,"from":"system.adapter.mihome-vacuum.0","_id":29109620}
                              2021-05-02 14:21:40.913 - debug: mihome-vacuum.0 (254450) Message= {"id":34,"method":"app_start"}
                              2021-05-02 14:21:40.917 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":["ok"],"id":33}
                              2021-05-02 14:21:40.924 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":["ok"],"id":34}
                              2021-05-02 14:21:42.927 - debug: mihome-vacuum.0 (254450) ERROR at setGetStatus: TypeError: Cannot read property 'sendMessage' of undefined
                              2021-05-02 14:21:48.422 - debug: mihome-vacuum.0 (254450) Receive <<< Helo <<< 213100200000000005c27ac2608e995cffffffffffffffffffffffffffffffff
                              2021-05-02 14:21:50.337 - debug: mihome-vacuum.0 (254450) get params for stock Vacuum
                              2021-05-02 14:21:50.337 - debug: mihome-vacuum.0 (254450) Message= {"id":35,"method":"get_status"}
                              2021-05-02 14:21:50.345 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4642,"state":5,"battery":64,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":35}
                              2021-05-02 14:21:50.345 - debug: mihome-vacuum.0 (254450) setGetStatus {"msg_ver":3,"msg_seq":4642,"state":5,"battery":64,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
                              2021-05-02 14:21:50.347 - debug: mihome-vacuum.0 (254450) Message= {"id":36,"method":"get_network_info"}
                              2021-05-02 14:21:50.355 - info: mihome-vacuum.0 (254450) State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
                              2021-05-02 14:21:50.375 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":{"ssid":"TazDevilsCave","ip":"192.168.178.40","mac":"7c:49:eb:9d:ac:e3","bssid":"e0:28:6d:31:24:24","rssi":-69},"id":36}
                              2021-05-02 14:21:50.388 - debug: mihome-vacuum.0 (254450) Message= {"id":37,"method":"get_sound_volume"}
                              2021-05-02 14:21:50.402 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[43],"id":37}
                              2021-05-02 14:21:50.403 - debug: mihome-vacuum.0 (254450) Message= {"id":38,"method":"get_consumable"}
                              2021-05-02 14:21:50.412 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"main_brush_work_time":20896,"side_brush_work_time":20896,"filter_work_time":20896,"filter_element_work_time":0,"sensor_dirty_time":20896}],"id":38}
                              2021-05-02 14:21:50.413 - debug: mihome-vacuum.0 (254450) Message= {"id":39,"method":"get_clean_summary"}
                              2021-05-02 14:21:50.426 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[1567653,24874245000,1463,[1619956959,1619954510,1619882398,1619880796,1619868270,1619867565,1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921]],"id":39}
                              2021-05-02 14:21:50.427 - debug: mihome-vacuum.0 (254450) Message= {"id":40,"method":"get_multi_maps_list"}
                              2021-05-02 14:21:50.434 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":"unknown_method","id":40}
                              2021-05-02 14:21:50.435 - debug: mihome-vacuum.0 (254450) Message= {"id":41,"method":"get_map_v1"}
                              2021-05-02 14:21:50.443 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":["map_slot_13"],"id":41}
                              2021-05-02 14:21:50.443 - debug: mihome-vacuum.0 (254450) Message= {"id":42,"method":"get_carpet_mode"}
                              2021-05-02 14:21:50.453 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":42}
                              2021-05-02 14:21:58.428 - debug: mihome-vacuum.0 (254450) Receive <<< Helo <<< 213100200000000005c27ac2608e9966ffffffffffffffffffffffffffffffff
                              2021-05-02 14:22:08.435 - debug: mihome-vacuum.0 (254450) Receive <<< Helo <<< 213100200000000005c27ac2608e9970ffffffffffffffffffffffffffffffff
                              2021-05-02 14:22:10.455 - debug: mihome-vacuum.0 (254450) get params for stock Vacuum
                              2021-05-02 14:22:10.455 - debug: mihome-vacuum.0 (254450) Message= {"id":43,"method":"get_status"}
                              2021-05-02 14:22:10.463 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":4647,"state":5,"battery":64,"clean_time":28,"clean_area":625000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":43}
                              2021-05-02 14:22:10.463 - debug: mihome-vacuum.0 (254450) setGetStatus {"msg_ver":3,"msg_seq":4647,"state":5,"battery":64,"clean_time":28,"clean_area":625000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":0,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":1,"lock_status":0,"error_text":"No error"}
                              2021-05-02 14:22:10.464 - debug: mihome-vacuum.0 (254450) Message= {"id":44,"method":"get_network_info"}
                              2021-05-02 14:22:10.472 - info: mihome-vacuum.0 (254450) State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
                              2021-05-02 14:22:10.488 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":{"ssid":"TazDevilsCave","ip":"192.168.178.40","mac":"7c:49:eb:9d:ac:e3","bssid":"e0:28:6d:31:24:24","rssi":-71},"id":44}
                              2021-05-02 14:22:10.493 - debug: mihome-vacuum.0 (254450) Message= {"id":45,"method":"get_sound_volume"}
                              2021-05-02 14:22:10.502 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[43],"id":45}
                              2021-05-02 14:22:10.503 - debug: mihome-vacuum.0 (254450) Message= {"id":46,"method":"get_consumable"}
                              2021-05-02 14:22:10.513 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"main_brush_work_time":20896,"side_brush_work_time":20896,"filter_work_time":20896,"filter_element_work_time":0,"sensor_dirty_time":20896}],"id":46}
                              2021-05-02 14:22:10.514 - debug: mihome-vacuum.0 (254450) Message= {"id":47,"method":"get_clean_summary"}
                              2021-05-02 14:22:10.524 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[1567653,24874245000,1463,[1619956959,1619954510,1619882398,1619880796,1619868270,1619867565,1619863687,1619799323,1619794271,1619792296,1619787328,1619713333,1619702461,1619699767,1619346926,1619342131,1619263352,1619259412,1618813425,1618808921]],"id":47}
                              2021-05-02 14:22:10.525 - debug: mihome-vacuum.0 (254450) Message= {"id":48,"method":"get_multi_maps_list"}
                              2021-05-02 14:22:10.533 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":"unknown_method","id":48}
                              2021-05-02 14:22:10.533 - debug: mihome-vacuum.0 (254450) Message= {"id":49,"method":"get_map_v1"}
                              2021-05-02 14:22:10.541 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":["map_slot_16"],"id":49}
                              2021-05-02 14:22:10.542 - debug: mihome-vacuum.0 (254450) Message= {"id":50,"method":"get_carpet_mode"}
                              2021-05-02 14:22:10.552 - debug: mihome-vacuum.0 (254450) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":50}
                              2021-05-02 14:22:18.670 - debug: mihome-vacuum.0 (254450) Receive <<< Helo <<< 213100200000000005c27ac2608e997affffffffffffffffffffffffffffffff
                              Auch das Problem mit der Warnung der water_box ist noch da.
                              • T tazdevil20
                                @meistertr
                                MeistertrM Offline
                                MeistertrM Offline
                                Meistertr
                                #136
                                @tazdevil20 du hast die karte nicht aktiviert in der Config
                                S F T 3 Antworten Letzte Antwort
                                  saeft_2003
                                  #137
                                  @meistertr
                                  Kann ich den Status von mop_forbidden_enable irgendwie manuell in einen DP bekommen?
                                  https://forum.iobroker.net/topic/44077/test-adapter-mihome-vacuum-v3-1-4-next-generarition/134
                                    Frank579
                                    #138
                                    Hallo @meistertr ich habe bei mir 2 S5Max laufen, bei beiden bekomme ich immer wieder einen Fehler zur Karte im Log, In der Vis wird auch keine Angezeigt.
                                    2021-05-02 15:08:33.634 - warn: mihome-vacuum.1 (17651) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Sun, 02 May 2021 13:08:33 GMT","content-type":"application/octet-stream","content-length":"123","connection":"close","x-xiaomi-request-id":"741bde26-4419-bb33-0000-01792d31df9d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"awsde0.fds.api.xiaomi.com","port":443,"hostname":"awsde0.fds.api.xiaomi.com","hash":null,"search":"?Expires=1619960902000&GalaxyAccessKeyId=5271733786445&Signature=rnAMg82zBOll3QRFnMHQiBXuqDU=","query":"Expires=1619960902000&GalaxyAccessKeyId=5271733786445&Signature=rnAMg82zBOll3QRFnMHQiBXuqDU=","pathname":"/robomap/rubyslite/320349404/11","path":"/robomap/rubyslite/320349404/11?Expires=1619960902000&GalaxyAccessKeyId=5271733786445&Signature=rnAMg82zBOll3QRFnMHQiBXuqDU=","href":"https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320349404/11?Expires=1619960902000&GalaxyAccessKeyId=5271733786445&Signature=rnAMg82zBOll3QRFnMHQiBXuqDU="},"method":"GET","headers":{}}}
                                    Habe Version 3.1.4 installiert
                                    • F Frank579
                                      MeistertrM Offline
                                      MeistertrM Offline
                                      Meistertr
                                      #139
                                      @frank579 und mit der 2er Version ging es? Hast du en etwas längeren logauszug?
                                      F 1 Antwort Letzte Antwort
                                        Frank579
                                        #140
                                        @meistertr jein hatte in der 2er eine Karte die aber nicht regelmäßig Aktualisiert wurde ... Meine aber auch anfangs mit der 3er eine Karte gehabt zu haben, bin da aber nicht sicher ob ich da den DP der VIS schon geändert hatte, oder ob es noch ne Alte war.... 🙄
                                        Was Benötigst du denn noch als Log. da ist alle was der Adapter raus gibt bei dem Fehler ....
                                        • F Frank579
                                          MeistertrM Offline
                                          MeistertrM Offline
                                          Meistertr
                                          #141
                                          @frank579 ein debuglog vom Saugvorgang am besten incl. start des adapter
