  4. Mini-HowTo: Cannot find view "system" for search "host"
302 Beiträge 39 Kommentatoren 124.4k Aufrufe 45 Beobachtet
  • Marc_el_KM Marc_el_K
    @thomas-braun kannst Du damit etwas anfangen:
    Hier die Logs auszugsweise genau zum Zeitpunkt des Shutdowns (8:10 Uhr)
    auth.log
    Apr  3 08:10:29 raspberrypi sshd[25168]: Accepted password for pi from 192.168.178.23 port 37261 ssh2
    Apr  3 08:10:29 raspberrypi sshd[25168]: pam_unix(sshd:session): session opened for user pi by (uid=0)
    Apr  3 08:10:29 raspberrypi systemd-logind[369]: New session 21 of user pi.
    Apr  3 08:10:29 raspberrypi systemd: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
    Apr  3 08:10:37 raspberrypi sudo:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/iobroker stop
    Apr  3 08:10:37 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
    Apr  3 08:10:37 raspberrypi sudo:     root : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/systemctl stop iobroker
    Apr  3 08:10:42 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
    Apr  3 08:10:59 raspberrypi sudo:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/iobroker shutdown now
    Apr  3 08:10:59 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
    Apr  3 08:10:59 raspberrypi sudo:     root : TTY=pts/0 ; PWD=/home/pi ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js shutdown now
    Apr  3 08:10:59 raspberrypi sudo: pam_unix(sudo:session): session opened for user iobroker by pi(uid=0)
    Apr  3 08:11:01 raspberrypi sudo: pam_unix(sudo:session): session closed for user iobroker
    Apr  3 08:11:01 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
    Apr  3 08:11:22 raspberrypi sudo:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/shutdown now
    Apr  3 08:11:22 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
    Apr  3 08:11:22 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
    Apr  3 08:11:22 raspberrypi sshd[25168]: pam_unix(sshd:session): session closed for user pi
    Apr  3 08:11:22 raspberrypi sshd[851]: Received signal 15; terminating.
    Apr  3 08:11:29 raspberrypi systemd-logind[340]: New seat seat0.
    Apr  3 08:11:41 raspberrypi sshd[731]: Server listening on 0.0.0.0 port 22.
    Apr  3 08:11:41 raspberrypi sshd[731]: Server listening on :: port 22.
    Apr  3 08:42:07 raspberrypi systemd-logind[386]: New seat seat0.
    Apr  3 08:42:18 raspberrypi sshd[681]: Server listening on 0.0.0.0 port 22.
    Apr  3 08:42:18 raspberrypi sshd[681]: Server listening on :: port 22.
    Apr  3 08:47:08 raspberrypi sshd[905]: Accepted password for pi from 192.168.178.23 port 41377 ssh2
    daemon.log
    Apr  3 08:09:21 raspberrypi bash[845]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
    Apr  3 08:10:21 raspberrypi bash[845]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Permission denied
    Apr  3 08:10:29 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
    Apr  3 08:10:29 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
    Apr  3 08:10:29 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
    Apr  3 08:10:29 raspberrypi systemd[1]: Starting User Manager for UID 1000...
    Apr  3 08:10:30 raspberrypi systemd[25223]: Listening on GnuPG network certificate management daemon.
    Apr  3 08:10:30 raspberrypi systemd[25223]: Reached target Paths.
    Apr  3 08:10:30 raspberrypi systemd[25223]: Reached target Timers.
    Apr  3 08:10:30 raspberrypi systemd[25223]: Listening on GnuPG cryptographic agent and passphrase cache.
    Apr  3 08:10:30 raspberrypi systemd[25223]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
    Apr  3 08:10:30 raspberrypi systemd[25223]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
    Apr  3 08:10:30 raspberrypi systemd[25223]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
    Apr  3 08:10:30 raspberrypi systemd[25223]: Reached target Sockets.
    Apr  3 08:10:30 raspberrypi systemd[25223]: Reached target Basic System.
    Apr  3 08:10:30 raspberrypi systemd[25223]: Reached target Default.
    Apr  3 08:10:30 raspberrypi systemd[25223]: Startup finished in 169ms.
    Apr  3 08:10:30 raspberrypi systemd[1]: Started User Manager for UID 1000.
    Apr  3 08:10:30 raspberrypi systemd[1]: Started Session 21 of user pi.
    Apr  3 08:10:37 raspberrypi systemd[1]: Stopping ioBroker Server...
    Apr  3 08:10:39 raspberrypi bash[845]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    Apr  3 08:10:40 raspberrypi bash[845]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
    Apr  3 08:10:40 raspberrypi bash[845]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Apr  3 08:10:40 raspberrypi bash[845]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
    Apr  3 08:10:42 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
    Apr  3 08:10:42 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Apr  3 08:10:42 raspberrypi systemd[1]: Stopped ioBroker Server.
    Apr  3 08:11:22 raspberrypi systemd[1]: Removed slice system-bthelper.slice.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped target Sound Card.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping Save/Restore Sound Card State...
    Apr  3 08:11:22 raspberrypi systemd[1]: systemd-rfkill.socket: Succeeded.
    Apr  3 08:11:22 raspberrypi systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
    Apr  3 08:11:22 raspberrypi systemd[1]: Condition check resulted in Turns off Raspberry Pi display backlight on shutdown/reboot being skipped.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping Session 21 of user pi.
    Apr  3 08:11:22 raspberrypi systemd[1]: Unmounting RPC Pipe File System...
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped target Timers.
    Apr  3 08:11:22 raspberrypi systemd[1]: man-db.timer: Succeeded.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped Daily man-db regeneration.
    Apr  3 08:11:22 raspberrypi systemd[1]: apt-daily-upgrade.timer: Succeeded.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped Daily apt upgrade and clean activities.
    Apr  3 08:11:22 raspberrypi systemd[1]: apt-daily.timer: Succeeded.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped Daily apt download activities.
    Apr  3 08:11:22 raspberrypi systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped Daily Cleanup of Temporary Directories.
    Apr  3 08:11:22 raspberrypi meyectl[395]:     INFO: interrupt signal received, shutting down...
    Apr  3 08:11:22 raspberrypi meyectl[395]:     INFO: server stopped
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped target Graphical Interface.
    Apr  3 08:11:22 raspberrypi avahi-daemon[363]: Got SIGTERM, quitting.
    Apr  3 08:11:22 raspberrypi meyectl[395]:     INFO: tasks stopped
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped target Multi-User System.
    Apr  3 08:11:22 raspberrypi avahi-daemon[363]: Leaving mDNS multicast group on interface eth0.IPv6 with address 2003:e4:7720:ec00:2644:7cf7:d745:dfa1.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping dphys-swapfile - set up, mount/unmount, and delete a swap file...
    Apr  3 08:11:22 raspberrypi avahi-daemon[363]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.178.76.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping OpenBSD Secure Shell server...
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped target Login Prompts.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping motionEye Server...
    Apr  3 08:11:22 raspberrypi systemd[1]: rpi-eeprom-update.service: Succeeded.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopped Check for Raspberry Pi EEPROM updates.
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping triggerhappy global hotkey daemon...
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping Regular background program processing daemon...
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping Configure Bluetooth Modems connected by UART...
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping rng-tools.service...
    Apr  3 08:11:22 raspberrypi systemd[1]: Stopping LSB: Start Motion detection...
    Apr  3 08:11:29 raspberrypi fake-hwclock[119]: Sat  3 Apr 07:11:25 UTC 2021
    Apr  3 08:11:29 raspberrypi systemd-fsck[134]: e2fsck 1.44.5 (15-Dec-2018)
    Apr  3 08:11:29 raspberrypi systemd[1]: Started udev Coldplug all Devices.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Set the console keyboard layout.
    Apr  3 08:11:29 raspberrypi systemd-fsck[134]: rootfs: clean, 137317/7699296 files, 1364572/31150592 blocks
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Helper to synchronize boot up for ifupdown.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started File System Check on Root Device.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Create System Users...
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Load/Save Random Seed...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Create System Users.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Load/Save Random Seed.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Create Static Device Nodes in /dev...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
    Apr  3 08:11:29 raspberrypi systemd[1]: Started udev Kernel Device Manager.
    Apr  3 08:11:29 raspberrypi systemd-udevd[163]: Using default interface naming scheme 'v240'.
    Apr  3 08:11:29 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/f8e84112-01.
    Apr  3 08:11:29 raspberrypi systemd[1]: Found device /dev/serial1.
    Apr  3 08:11:29 raspberrypi systemd-udevd[166]: Using default interface naming scheme 'v240'.
    Apr  3 08:11:29 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/f8e84112-01...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
    Apr  3 08:11:29 raspberrypi systemd-fsck[279]: fsck.fat 4.1 (2017-01-24)
    Apr  3 08:11:29 raspberrypi systemd-fsck[279]: /dev/mmcblk0p1: 264 files, 97566/516190 clusters
    Apr  3 08:11:29 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/f8e84112-01.
    Apr  3 08:11:29 raspberrypi systemd[1]: Mounting /boot...
    Apr  3 08:11:29 raspberrypi systemd[1]: Mounted /boot.
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target Local File Systems.
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Raise network interfaces...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Set console font and keymap...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Set console font and keymap.
    Apr  3 08:11:29 raspberrypi systemd[1]: nfs-config.service: Succeeded.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Preprocess NFS configuration.
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target NFS client services.
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target Remote File Systems.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Network Time Synchronization...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Raise network interfaces.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Network Time Synchronization.
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target System Time Synchronized.
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target System Initialization.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Daily apt download activities.
    Apr  3 08:11:29 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Daily rotation of log files.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Daily man-db regeneration.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target Timers.
    Apr  3 08:11:29 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
    Apr  3 08:11:29 raspberrypi systemd[1]: Listening on triggerhappy.socket.
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target Sockets.
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target Basic System.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting rng-tools.service...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Login Service...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
    Apr  3 08:11:29 raspberrypi alsactl[341]: alsactl 1.1.8 daemon started
    Apr  3 08:11:29 raspberrypi systemd[1]: Started motionEye Server.
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
    Apr  3 08:11:29 raspberrypi rng-tools[339]: Starting Hardware RNG entropy gatherer daemon: rngd.
    Apr  3 08:11:29 raspberrypi rngd[345]: rngd 2-unofficial-mt.14 starting up...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Regular background program processing daemon.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
    Apr  3 08:11:29 raspberrypi rngd[345]: entropy feed to the kernel ready
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting System Logging Service...
    Apr  3 08:11:29 raspberrypi avahi-daemon[349]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
    Apr  3 08:11:29 raspberrypi avahi-daemon[349]: Successfully dropped root privileges.
    Apr  3 08:11:29 raspberrypi avahi-daemon[349]: avahi-daemon 0.7 starting up.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting LSB: Start Motion detection...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started D-Bus System Message Bus.
    Apr  3 08:11:29 raspberrypi thd[373]: Found socket passed from systemd
    Apr  3 08:11:29 raspberrypi dhcpcd[358]: dev: loaded udev
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting WPA supplicant...
    Apr  3 08:11:29 raspberrypi systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
    Apr  3 08:11:29 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
    Apr  3 08:11:29 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started rng-tools.service.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started System Logging Service.
    Apr  3 08:11:29 raspberrypi dphys-swapfile[343]: want /var/swap=100MByte, checking existing: keeping it
    Apr  3 08:11:29 raspberrypi systemd[1]: Reached target Sound Card.
    Apr  3 08:11:29 raspberrypi motion[379]: Not starting motion daemon, disabled via /etc/default/motion ... (warning).
    Apr  3 08:11:29 raspberrypi dbus-daemon[385]: [system] Successfully activated service 'org.freedesktop.systemd1'
    Apr  3 08:11:29 raspberrypi avahi-daemon[349]: Successfully called chroot().
    Apr  3 08:11:29 raspberrypi avahi-daemon[349]: Successfully dropped remaining capabilities.
    Apr  3 08:11:29 raspberrypi avahi-daemon[349]: No service file found in /etc/avahi/services.
    Apr  3 08:11:29 raspberrypi avahi-daemon[349]: Network interface enumeration completed.
    Apr  3 08:11:29 raspberrypi avahi-daemon[349]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 723682461.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started LSB: Start Motion detection.
    Apr  3 08:11:29 raspberrypi wpa_supplicant[392]: Successfully initialized wpa_supplicant
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started WPA supplicant.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Login Service.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
    Apr  3 08:11:29 raspberrypi raspi-config[395]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
    Apr  3 08:11:29 raspberrypi raspi-config[395]:  No. Switching to ondemand scaling governor.
    Apr  3 08:11:29 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
    Apr  3 08:11:29 raspberrypi dhcpcd[358]: wlan0: starting wpa_supplicant
    Apr  3 08:11:29 raspberrypi dhcpcd-run-hooks[452]: wlan0: starting wpa_supplicant
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]: BOOTLOADER: up-to-date
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]:    CURRENT: Thu  3 Sep 12:11:43 UTC 2020 (1599135103)
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]:     LATEST: Thu  3 Sep 12:11:43 UTC 2020 (1599135103)
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]:             Use raspi-config to change the release.
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]:   VL805_FW: Using bootloader EEPROM
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]:      VL805: up-to-date
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]:    CURRENT: 000138a1
    Apr  3 08:11:29 raspberrypi rpi-eeprom-update[356]:     LATEST: 000138a1
    Apr  3 08:11:29 raspberrypi systemd[1]: Started Check for Raspberry Pi EEPROM updates.
    Apr  3 08:11:29 raspberrypi dhcpcd[358]: wlan0: connected to Access Point `'
    Apr  3 08:11:29 raspberrypi dhcpcd[358]: eth0: waiting for carrier
    Apr  3 08:11:29 raspberrypi dhcpcd[358]: dhcpcd_prestartinterface: wlan0: Operation not possible due to RF-kill
    Apr  3 08:11:29 raspberrypi dhcpcd[358]: wlan0: waiting for carrier
    Apr  3 08:11:30 raspberrypi meyectl[344]:     INFO: hello! this is motionEye server 0.42.1
    Apr  3 08:11:32 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
    Apr  3 08:11:34 raspberrypi meyectl[344]:     INFO: cleanup started
    Apr  3 08:11:34 raspberrypi meyectl[344]:     INFO: wsswitch started
    Apr  3 08:11:34 raspberrypi meyectl[344]:     INFO: tasks started
    Apr  3 08:11:34 raspberrypi meyectl[344]:     INFO: mjpg client garbage collector started
    Apr  3 08:11:34 raspberrypi meyectl[344]:     INFO: server started
    Apr  3 08:11:34 raspberrypi dhcpcd[358]: eth0: carrier acquired
    Apr  3 08:11:34 raspberrypi dhcpcd[358]: DUID 00:01:00:01:27:8f:0a:6e:dc:a6:32:d9:04:68
    Apr  3 08:11:34 raspberrypi dhcpcd[358]: eth0: IAID 32:d9:04:68
    Apr  3 08:11:34 raspberrypi dhcpcd[358]: eth0: adding address fe80::afc:39a2:8efa:c552
    Apr  3 08:11:34 raspberrypi avahi-daemon[349]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::afc:39a2:8efa:c552.
    Apr  3 08:11:34 raspberrypi avahi-daemon[349]: New relevant interface eth0.IPv6 for mDNS.
    Apr  3 08:11:34 raspberrypi avahi-daemon[349]: Registering new address record for fe80::afc:39a2:8efa:c552 on eth0.*.
    Apr  3 08:11:35 raspberrypi dhcpcd[358]: eth0: soliciting an IPv6 router
    Apr  3 08:11:35 raspberrypi dhcpcd[358]: eth0: rebinding lease of 192.168.178.76
    Apr  3 08:11:35 raspberrypi dhcpcd[358]: eth0: probing address 192.168.178.76/24
    Apr  3 08:11:36 raspberrypi btuart[361]: bcm43xx_init
    Apr  3 08:11:36 raspberrypi btuart[361]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
    Apr  3 08:11:36 raspberrypi btuart[361]: Set Controller UART speed to 3000000 bit/s
    Apr  3 08:11:36 raspberrypi btuart[361]: Device setup complete
    Apr  3 08:11:36 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
    Apr  3 08:11:36 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
    Apr  3 08:11:36 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
    Apr  3 08:11:36 raspberrypi systemd[1]: Created slice system-bthelper.slice.
    Apr  3 08:11:36 raspberrypi systemd[1]: Starting Bluetooth service...
    Apr  3 08:11:36 raspberrypi bluetoothd[505]: Bluetooth daemon 5.50
    Apr  3 08:11:36 raspberrypi systemd[1]: Started Bluetooth service.
    Apr  3 08:11:36 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
    Apr  3 08:11:36 raspberrypi bluetoothd[505]: Starting SDP server
    Apr  3 08:11:36 raspberrypi systemd[1]: Reached target Bluetooth.
    Apr  3 08:11:36 raspberrypi dbus-daemon[385]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=505 comm="/usr/lib/bluetooth/bluetoothd ")
    Apr  3 08:11:36 raspberrypi bluetoothd[505]: Bluetooth management interface 1.18 initialized
    Apr  3 08:11:36 raspberrypi bluetoothd[505]: Sap driver initialization failed.
    Apr  3 08:11:36 raspberrypi bluetoothd[505]: sap-server: Operation not permitted (1)
    Apr  3 08:11:36 raspberrypi bthelper[506]: Raspberry Pi BDADDR already set
    Apr  3 08:11:36 raspberrypi systemd[1]: Starting Hostname Service...
    Apr  3 08:11:36 raspberrypi dbus-daemon[385]: [system] Successfully activated service 'org.freedesktop.hostname1'
    Apr  3 08:11:36 raspberrypi systemd[1]: Started Hostname Service.
    Apr  3 08:11:36 raspberrypi bluetoothd[505]: Failed to set privacy: Rejected (0x0b)
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Name: raspberrypi
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Alias: raspberrypi
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 00001801-0000-1000-8000-00805f9b34fb
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 00001200-0000-1000-8000-00805f9b34fb
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 00001800-0000-1000-8000-00805f9b34fb
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Alias: BlueZ 5.50
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Pairable: yes
    Apr  3 08:11:36 raspberrypi bthelper[506]: Changing power off succeeded
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Powered: no
    Apr  3 08:11:36 raspberrypi bthelper[506]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Discovering: no
    Apr  3 08:11:36 raspberrypi bthelper[506]: Changing power on succeeded
    Apr  3 08:11:36 raspberrypi systemd[1]: bthelper@hci0.service: Succeeded.
    Apr  3 08:11:36 raspberrypi dhcpcd[358]: eth0: Router Advertisement from fe80::2e91:abff:fee8:3482
    Apr  3 08:11:36 raspberrypi dhcpcd[358]: eth0: adding address 2003:e4:7720:ec00:2644:7cf7:d745:dfa1/64
    Apr  3 08:11:36 raspberrypi avahi-daemon[349]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::afc:39a2:8efa:c552.
    Apr  3 08:11:36 raspberrypi avahi-daemon[349]: Joining mDNS multicast group on interface eth0.IPv6 with address 2003:e4:7720:ec00:2644:7cf7:d745:dfa1.
    Apr  3 08:11:36 raspberrypi avahi-daemon[349]: Registering new address record for 2003:e4:7720:ec00:2644:7cf7:d745:dfa1 on eth0.*.
    Apr  3 08:11:36 raspberrypi dhcpcd[358]: eth0: adding route to 2003:e4:7720:ec00::/64
    Apr  3 08:11:36 raspberrypi avahi-daemon[349]: Withdrawing address record for fe80::afc:39a2:8efa:c552 on eth0.
    Apr  3 08:11:36 raspberrypi dhcpcd[358]: eth0: requesting DHCPv6 information
    Apr  3 08:11:36 raspberrypi dhcpcd[358]: eth0: fe80::2e91:abff:fee8:3482 is reachable again
    Apr  3 08:11:36 raspberrypi dhcpcd[358]: eth0: adding default route via fe80::2e91:abff:fee8:3482
    Apr  3 08:11:37 raspberrypi dhcpcd[358]: Too few arguments.
    Apr  3 08:11:41 raspberrypi dhcpcd[358]: eth0: leased 192.168.178.76 for 864000 seconds
    Apr  3 08:11:41 raspberrypi avahi-daemon[349]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.178.76.
    Apr  3 08:11:41 raspberrypi avahi-daemon[349]: New relevant interface eth0.IPv4 for mDNS.
    Apr  3 08:11:41 raspberrypi avahi-daemon[349]: Registering new address record for 192.168.178.76 on eth0.IPv4.
    Apr  3 08:11:41 raspberrypi dhcpcd[358]: eth0: adding route to 192.168.178.0/24
    Apr  3 08:11:41 raspberrypi dhcpcd[358]: eth0: adding default route via 192.168.178.1
    Apr  3 08:11:41 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
    Apr  3 08:11:41 raspberrypi dhcpcd[358]: Too few arguments.
    Apr  3 08:11:41 raspberrypi dhcpcd[358]: forked to background, child pid 721
    Apr  3 08:11:41 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
    Apr  3 08:11:41 raspberrypi systemd[1]: Reached target Network.
    Apr  3 08:11:41 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
    Apr  3 08:11:41 raspberrypi systemd[1]: Starting Permit User Sessions...
    Apr  3 08:11:41 raspberrypi systemd[1]: Started ioBroker Server.
    Apr  3 08:11:41 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
    Apr  3 08:11:41 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
    Apr  3 08:11:41 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
    Apr  3 08:11:41 raspberrypi systemd[1]: Started Permit User Sessions.
    Apr  3 08:11:41 raspberrypi systemd[1]: Started Getty on tty1.
    Apr  3 08:11:41 raspberrypi systemd[1]: Reached target Login Prompts.
    Apr  3 08:11:41 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
    Apr  3 08:11:41 raspberrypi systemd[1]: Reached target Multi-User System.
    Apr  3 08:11:41 raspberrypi systemd[1]: Reached target Graphical Interface.
    Apr  3 08:11:41 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
    Apr  3 08:11:41 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
    Apr  3 08:11:41 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
    Apr  3 08:11:41 raspberrypi systemd[1]: Startup finished in 2.135s (kernel) + 17.708s (userspace) = 19.843s.
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.fritzdect.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.dwd.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.trashschedule.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.iot.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.tuya.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.tankerkoenig.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.meross.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.daswetter.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.upnp.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.ble.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis-colorpicker.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis-inventwo.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis-fancyswitch.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis-bars.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis-canvas-gauges.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.vis-material-advanced.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.rpi2.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.paw.0" for host "raspberrypi"
    Apr  3 08:11:45 raspberrypi bash[724]: host.raspberrypi check instance "system.adapter.simple-api.0" for host "raspberrypi"
    Apr  3 08:11:47 raspberrypi dhcpcd[721]: eth0: fe80::2e91:abff:fee8:3482 is reachable again
    Apr  3 08:11:58 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
    Apr  3 08:42:07 raspberrypi meyectl[344]:    ERROR: mjpg client timed out receiving data for camera 1 on port 1111
        Apr  3 08:42:07 raspberrypi fake-hwclock[115]: Sat  3 Apr 07:11:25 UTC 2021
    Apr  3 08:42:07 raspberrypi systemd-fsck[132]: e2fsck 1.44.5 (15-Dec-2018)
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Set the console keyboard layout.
    Apr  3 08:42:07 raspberrypi systemd-fsck[132]: rootfs: clean, 137322/7699296 files, 1361899/31150592 blocks
    Apr  3 08:42:07 raspberrypi systemd[1]: Started File System Check on Root Device.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started udev Coldplug all Devices.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Helper to synchronize boot up for ifupdown.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Create System Users...
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Load/Save Random Seed...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Create System Users.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Load/Save Random Seed.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Create Static Device Nodes in /dev...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
    Apr  3 08:42:07 raspberrypi systemd[1]: Started udev Kernel Device Manager.
    Apr  3 08:42:07 raspberrypi systemd-udevd[173]: Using default interface naming scheme 'v240'.
    Apr  3 08:42:07 raspberrypi systemd[1]: Found device /dev/serial1.
    Apr  3 08:42:07 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/f8e84112-01.
    Apr  3 08:42:07 raspberrypi systemd-udevd[170]: Using default interface naming scheme 'v240'.
    Apr  3 08:42:07 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/f8e84112-01...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
    Apr  3 08:42:07 raspberrypi systemd-fsck[280]: fsck.fat 4.1 (2017-01-24)
    Apr  3 08:42:07 raspberrypi systemd-fsck[280]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
    Apr  3 08:42:07 raspberrypi systemd-fsck[280]:  Automatically removing dirty bit.
    Apr  3 08:42:07 raspberrypi systemd-fsck[280]: Performing changes.
    Apr  3 08:42:07 raspberrypi systemd-fsck[280]: /dev/mmcblk0p1: 264 files, 97566/516190 clusters
    Apr  3 08:42:07 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/f8e84112-01.
    Apr  3 08:42:07 raspberrypi systemd[1]: Mounting /boot...
    Apr  3 08:42:07 raspberrypi systemd[1]: Mounted /boot.
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target Local File Systems.
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Raise network interfaces...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Set console font and keymap...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Set console font and keymap.
    Apr  3 08:42:07 raspberrypi systemd[1]: nfs-config.service: Succeeded.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Preprocess NFS configuration.
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target NFS client services.
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target Remote File Systems.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Network Time Synchronization...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Raise network interfaces.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Network Time Synchronization.
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target System Initialization.
    Apr  3 08:42:07 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
    Apr  3 08:42:07 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    Apr  3 08:42:07 raspberrypi systemd[1]: Listening on triggerhappy.socket.
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target Sockets.
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target Basic System.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting rng-tools.service...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Regular background program processing daemon.
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started D-Bus System Message Bus.
    Apr  3 08:42:07 raspberrypi rng-tools[342]: Starting Hardware RNG entropy gatherer daemon: rngd.
    Apr  3 08:42:07 raspberrypi rngd[357]: rngd 2-unofficial-mt.14 starting up...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting WPA supplicant...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting LSB: Start Motion detection...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
    Apr  3 08:42:07 raspberrypi rngd[357]: entropy feed to the kernel ready
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting System Logging Service...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started motionEye Server.
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
    Apr  3 08:42:07 raspberrypi thd[374]: Found socket passed from systemd
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Login Service...
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
    Apr  3 08:42:07 raspberrypi systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
    Apr  3 08:42:07 raspberrypi alsactl[387]: alsactl 1.1.8 daemon started
    Apr  3 08:42:07 raspberrypi systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target System Time Synchronized.
    Apr  3 08:42:07 raspberrypi dhcpcd[369]: dev: loaded udev
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Daily apt download activities.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Daily man-db regeneration.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Daily rotation of log files.
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target Timers.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started rng-tools.service.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started System Logging Service.
    Apr  3 08:42:07 raspberrypi avahi-daemon[379]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
    Apr  3 08:42:07 raspberrypi avahi-daemon[379]: Successfully dropped root privileges.
    Apr  3 08:42:07 raspberrypi avahi-daemon[379]: avahi-daemon 0.7 starting up.
    Apr  3 08:42:07 raspberrypi dphys-swapfile[340]: want /var/swap=100MByte, checking existing: keeping it
    Apr  3 08:42:07 raspberrypi systemd[1]: Reached target Sound Card.
    Apr  3 08:42:07 raspberrypi motion[368]: Not starting motion daemon, disabled via /etc/default/motion ... (warning).
    Apr  3 08:42:07 raspberrypi wpa_supplicant[364]: Successfully initialized wpa_supplicant
    Apr  3 08:42:07 raspberrypi raspi-config[341]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
    Apr  3 08:42:07 raspberrypi avahi-daemon[379]: Successfully called chroot().
    Apr  3 08:42:07 raspberrypi avahi-daemon[379]: Successfully dropped remaining capabilities.
    Apr  3 08:42:07 raspberrypi raspi-config[341]:  No. Switching to ondemand scaling governor.
    Apr  3 08:42:07 raspberrypi avahi-daemon[379]: No service file found in /etc/avahi/services.
    Apr  3 08:42:07 raspberrypi avahi-daemon[379]: Network interface enumeration completed.
    Apr  3 08:42:07 raspberrypi avahi-daemon[379]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 4246940340.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started LSB: Start Motion detection.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
    Apr  3 08:42:07 raspberrypi dbus-daemon[352]: [system] Successfully activated service 'org.freedesktop.systemd1'
    Apr  3 08:42:07 raspberrypi systemd[1]: Started WPA supplicant.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Login Service.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
    Apr  3 08:42:07 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
    Apr  3 08:42:07 raspberrypi dhcpcd[369]: wlan0: starting wpa_supplicant
    Apr  3 08:42:07 raspberrypi dhcpcd-run-hooks[448]: wlan0: starting wpa_supplicant
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]: BOOTLOADER: up-to-date
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]:    CURRENT: Thu  3 Sep 12:11:43 UTC 2020 (1599135103)
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]:     LATEST: Thu  3 Sep 12:11:43 UTC 2020 (1599135103)
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]:             Use raspi-config to change the release.
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]:   VL805_FW: Using bootloader EEPROM
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]:      VL805: up-to-date
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]:    CURRENT: 000138a1
    Apr  3 08:42:08 raspberrypi rpi-eeprom-update[389]:     LATEST: 000138a1
    Apr  3 08:42:08 raspberrypi systemd[1]: Started Check for Raspberry Pi EEPROM updates.
    Apr  3 08:42:08 raspberrypi dhcpcd[369]: wlan0: connected to Access Point `'
    Apr  3 08:42:08 raspberrypi dhcpcd[369]: eth0: waiting for carrier
    Apr  3 08:42:08 raspberrypi dhcpcd[369]: dhcpcd_prestartinterface: wlan0: Operation not possible due to RF-kill
    Apr  3 08:42:08 raspberrypi dhcpcd[369]: wlan0: waiting for carrier
    Apr  3 08:42:08 raspberrypi meyectl[385]:     INFO: hello! this is motionEye server 0.42.1
    Apr  3 08:42:11 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
    Apr  3 08:42:12 raspberrypi meyectl[385]:     INFO: cleanup started
    Apr  3 08:42:12 raspberrypi meyectl[385]:     INFO: wsswitch started
    Apr  3 08:42:12 raspberrypi meyectl[385]:     INFO: tasks started
    Apr  3 08:42:12 raspberrypi meyectl[385]:     INFO: mjpg client garbage collector started
    Apr  3 08:42:12 raspberrypi meyectl[385]:     INFO: server started
    Apr  3 08:42:13 raspberrypi dhcpcd[369]: eth0: carrier acquired
    Apr  3 08:42:13 raspberrypi dhcpcd[369]: DUID 00:01:00:01:27:8f:0a:6e:dc:a6:32:d9:04:68
    Apr  3 08:42:13 raspberrypi dhcpcd[369]: eth0: IAID 32:d9:04:68
    Apr  3 08:42:13 raspberrypi dhcpcd[369]: eth0: adding address fe80::afc:39a2:8efa:c552
    Apr  3 08:42:13 raspberrypi avahi-daemon[379]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::afc:39a2:8efa:c552.
    Apr  3 08:42:13 raspberrypi avahi-daemon[379]: New relevant interface eth0.IPv6 for mDNS.
    Apr  3 08:42:13 raspberrypi avahi-daemon[379]: Registering new address record for fe80::afc:39a2:8efa:c552 on eth0.*.
    Apr  3 08:42:13 raspberrypi dhcpcd[369]: eth0: rebinding lease of 192.168.178.76
    Apr  3 08:42:13 raspberrypi dhcpcd[369]: eth0: probing address 192.168.178.76/24
    Apr  3 08:42:13 raspberrypi dhcpcd[369]: eth0: soliciting an IPv6 router
    Apr  3 08:42:14 raspberrypi btuart[350]: bcm43xx_init
    Apr  3 08:42:14 raspberrypi btuart[350]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
    Apr  3 08:42:14 raspberrypi btuart[350]: Set Controller UART speed to 3000000 bit/s
    Apr  3 08:42:14 raspberrypi btuart[350]: Device setup complete
    Apr  3 08:42:14 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
    Apr  3 08:42:14 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
    Apr  3 08:42:14 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
    Apr  3 08:42:14 raspberrypi systemd[1]: Starting Bluetooth service...
    Apr  3 08:42:14 raspberrypi systemd[1]: Created slice system-bthelper.slice.
    Apr  3 08:42:14 raspberrypi bluetoothd[557]: Bluetooth daemon 5.50
    Apr  3 08:42:14 raspberrypi systemd[1]: Started Bluetooth service.
    Apr  3 08:42:14 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
    Apr  3 08:42:14 raspberrypi bluetoothd[557]: Starting SDP server
    Apr  3 08:42:14 raspberrypi systemd[1]: Reached target Bluetooth.
    Apr  3 08:42:14 raspberrypi dbus-daemon[352]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=557 comm="/usr/lib/bluetooth/bluetoothd ")
    Apr  3 08:42:14 raspberrypi bluetoothd[557]: Bluetooth management interface 1.18 initialized
    Apr  3 08:42:14 raspberrypi bluetoothd[557]: Sap driver initialization failed.
    Apr  3 08:42:14 raspberrypi bluetoothd[557]: sap-server: Operation not permitted (1)
    Apr  3 08:42:14 raspberrypi bthelper[558]: Raspberry Pi BDADDR already set
    Apr  3 08:42:14 raspberrypi systemd[1]: Starting Hostname Service...
    Apr  3 08:42:14 raspberrypi dbus-daemon[352]: [system] Successfully activated service 'org.freedesktop.hostname1'
    Apr  3 08:42:14 raspberrypi systemd[1]: Started Hostname Service.
    Apr  3 08:42:14 raspberrypi bluetoothd[557]: Failed to set privacy: Rejected (0x0b)
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Name: raspberrypi
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Alias: raspberrypi
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 00001801-0000-1000-8000-00805f9b34fb
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 00001200-0000-1000-8000-00805f9b34fb
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A UUIDs: 00001800-0000-1000-8000-00805f9b34fb
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Alias: BlueZ 5.50
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Pairable: yes
    Apr  3 08:42:14 raspberrypi bthelper[558]: Changing power off succeeded
    Apr  3 08:42:14 raspberrypi bthelper[558]: Changing power on succeeded
    Apr  3 08:42:14 raspberrypi bthelper[558]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:D9:04:6A Powered: yes
    Apr  3 08:42:14 raspberrypi systemd[1]: bthelper@hci0.service: Succeeded.
    Apr  3 08:42:15 raspberrypi dhcpcd[369]: eth0: Router Advertisement from fe80::2e91:abff:fee8:3482
    Apr  3 08:42:15 raspberrypi dhcpcd[369]: eth0: adding address 2003:e4:7720:ec00:2644:7cf7:d745:dfa1/64
    Apr  3 08:42:15 raspberrypi dhcpcd[369]: eth0: adding route to 2003:e4:7720:ec00::/64
    Apr  3 08:42:15 raspberrypi dhcpcd[369]: eth0: requesting DHCPv6 information
    Apr  3 08:42:15 raspberrypi avahi-daemon[379]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::afc:39a2:8efa:c552.
    Apr  3 08:42:15 raspberrypi avahi-daemon[379]: Joining mDNS multicast group on interface eth0.IPv6 with address 2003:e4:7720:ec00:2644:7cf7:d745:dfa1.
    Apr  3 08:42:15 raspberrypi avahi-daemon[379]: Registering new address record for 2003:e4:7720:ec00:2644:7cf7:d745:dfa1 on eth0.*.
    Apr  3 08:42:15 raspberrypi avahi-daemon[379]: Withdrawing address record for fe80::afc:39a2:8efa:c552 on eth0.
    Apr  3 08:42:15 raspberrypi dhcpcd[369]: eth0: fe80::2e91:abff:fee8:3482 is reachable again
    Apr  3 08:42:15 raspberrypi dhcpcd[369]: eth0: adding default route via fe80::2e91:abff:fee8:3482
    Apr  3 08:42:15 raspberrypi dhcpcd[369]: Too few arguments.
    Apr  3 08:42:18 raspberrypi dhcpcd[369]: eth0: leased 192.168.178.76 for 864000 seconds
    Apr  3 08:42:18 raspberrypi avahi-daemon[379]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.178.76.
    Apr  3 08:42:18 raspberrypi avahi-daemon[379]: New relevant interface eth0.IPv4 for mDNS.
    Apr  3 08:42:18 raspberrypi avahi-daemon[379]: Registering new address record for 192.168.178.76 on eth0.IPv4.
    Apr  3 08:42:18 raspberrypi dhcpcd[369]: eth0: adding route to 192.168.178.0/24
    Apr  3 08:42:18 raspberrypi dhcpcd[369]: eth0: adding default route via 192.168.178.1
    Apr  3 08:42:18 raspberrypi dhcpcd[369]: Too few arguments.
    Apr  3 08:42:18 raspberrypi dhcpcd[369]: forked to background, child pid 673
    Apr  3 08:42:18 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
    Apr  3 08:42:18 raspberrypi systemd[1]: Reached target Network.
    Apr  3 08:42:18 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
    Apr  3 08:42:18 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
    Apr  3 08:42:18 raspberrypi systemd[1]: Starting Permit User Sessions...
    Apr  3 08:42:18 raspberrypi systemd[1]: Started ioBroker Server.
    Apr  3 08:42:18 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
    Apr  3 08:42:18 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
    Apr  3 08:42:18 raspberrypi systemd[1]: Started Permit User Sessions.
    Apr  3 08:42:18 raspberrypi systemd[1]: Started Getty on tty1.
    Apr  3 08:42:18 raspberrypi systemd[1]: Reached target Login Prompts.
    Apr  3 08:42:18 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
    Apr  3 08:42:18 raspberrypi systemd[1]: Reached target Multi-User System.
    Apr  3 08:42:18 raspberrypi systemd[1]: Reached target Graphical Interface.
    Apr  3 08:42:18 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
    Apr  3 08:42:18 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
    Apr  3 08:42:18 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
    Apr  3 08:42:18 raspberrypi systemd[1]: Startup finished in 2.219s (kernel) + 16.324s (userspace) = 18.544s.
    Apr  3 08:42:19 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
    Apr  3 08:42:21 raspberrypi bash[678]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Apr  3 08:42:21 raspberrypi bash[678]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
    Apr  3 08:42:21 raspberrypi bash[678]: object system.meta.uuid created: 26711388-ed9e-e086-6f07-6f13554a9a3f
    Apr  3 08:42:21 raspberrypi bash[678]: object system.user.admin created
    Apr  3 08:42:36 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
    Apr  3 08:43:24 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 1 on port 1111
    Apr  3 08:43:29 raspberrypi dhcpcd[673]: eth0: fe80::2e91:abff:fee8:3482 is reachable again
    Apr  3 08:43:31 raspberrypi systemd[1]: systemd-hostnamed.service: Succeeded.
    Apr  3 08:43:34 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:43:44 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:43:54 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:44:04 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:44:14 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:44:24 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:44:34 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:44:44 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:44:54 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:45:04 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:45:14 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:45:24 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:45:34 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:45:44 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:45:54 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:46:04 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:46:14 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:46:24 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:46:34 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:46:44 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:46:54 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:47:04 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:47:08 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
    Apr  3 08:47:08 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
    Apr  3 08:47:08 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
    Apr  3 08:47:08 raspberrypi systemd[1]: Starting User Manager for UID 1000...
    Apr  3 08:47:08 raspberrypi systemd[908]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
    Apr  3 08:47:08 raspberrypi systemd[908]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
    Apr  3 08:47:08 raspberrypi systemd[908]: Reached target Paths.
    Apr  3 08:47:08 raspberrypi systemd[908]: Listening on GnuPG cryptographic agent and passphrase cache.
    Apr  3 08:47:08 raspberrypi systemd[908]: Listening on GnuPG network certificate management daemon.
    Apr  3 08:47:08 raspberrypi systemd[908]: Reached target Timers.
    Apr  3 08:47:08 raspberrypi systemd[908]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
    Apr  3 08:47:08 raspberrypi systemd[908]: Reached target Sockets.
    Apr  3 08:47:08 raspberrypi systemd[908]: Reached target Basic System.
    Apr  3 08:47:08 raspberrypi systemd[908]: Reached target Default.
    Apr  3 08:47:08 raspberrypi systemd[908]: Startup finished in 153ms.
    Apr  3 08:47:08 raspberrypi systemd[1]: Started User Manager for UID 1000.
    Apr  3 08:47:08 raspberrypi systemd[1]: Started Session 1 of user pi.
    Apr  3 08:47:14 raspberrypi meyectl[385]:    ERROR: mjpg client timed out receiving data for camera 2 on port 1112
    Apr  3 08:47:16 raspberrypi systemd[1]: Stopping ioBroker Server...
    Apr  3 08:47:17 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
    Apr  3 08:47:17 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Apr  3 08:47:17 raspberrypi systemd[1]: Stopped ioBroker Server.
    Apr  3 08:47:23 raspberrypi systemd[1]: Stopped target Bluetooth.
    Apr  3 08:47:23 raspberrypi bluetoothd[557]: Terminating
    Apr  3 08:47:23 raspberrypi systemd[1]: Stopping Bluetooth service...
    Apr  3 08:47:23 raspberrypi systemd[1]: Stopping Session 1 of user pi.
    Apr  3 08:47:23 raspberrypi systemd[1]: Stopped target Timers.
    Apr  3 08:47:23 raspberrypi systemd[1]: apt-daily-upgrade.timer: Succeeded.
    Apr  3 08:47:23 raspberrypi systemd[1]: Stopped Daily apt upgrade and clean activities.
    Apr  3 08:47:23 raspberrypi systemd[1]: apt-daily.timer: Succeeded.
    Apr  3 08:47:23 raspberrypi systemd[1]: Stopped Daily apt download activities.
    Apr  3 08:47:23 raspberrypi systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
    Apr  3 08:47:23 raspberrypi systemd[1]: Stopped Daily Cleanup of Temporary Directories.
    Apr  3 08:47:23 raspberrypi bluetoothd[557]: Stopping SDP server
    Apr  3 08:47:23 raspberrypi systemd[1]: man-db.timer: Succeeded.
    Apr  3 08:47:23 raspberrypi bluetoothd[557]: Exit
    #75
    @marc_el_k Das ist aber nicht syslog oder kernellog.
    Und auch nicht iobroker.log
    • U Offline
      U Offline
      UwesSmartHome
      #76
      Hallo Zusammen,
      hatte soeben auch dieses Problem, die Anleitung hat geholfen. Es ist in den letzten 4 Tagen 2 mal passiert. Habe absolut nicht an der Hardware gemacht, nur den MOSDBUS Adapter und BAckupit installiert. Irgendwie muss da was inkompatibel sein.
      Grüsse
      • U UwesSmartHome
        Hallo Zusammen,
        Grüsse
        #77
        @uwessmarthome Dann hier das gleiche: ioBroker Log bitte von der Platte und auch /var/log/syslog
          User, die plötzlich nicht mehr in den ioBroker kommen und auf der Kommandozeile auf ein freundliches
          iobroker status
          so frech begrüßt werden:
          iobroker status
           Cannot read system.config: null (OK when migrating or restoring)
           Cannot find view "system" for search "host"
          können mal folgendes versuchen:
          Mit
          ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
          bekommt man so etwas in der Art zu sehen:
          total 19240
          -rw-rwxr--+ 1 iobroker iobroker 895277 Mar 16 16:23 2021-03-16_16-23_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 113674 Mar 16 16:23 2021-03-16_16-23_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 113571 Mar 16 16:47 2021-03-16_16-47_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 895066 Mar 16 16:48 2021-03-16_16-48_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 112795 Mar 16 16:51 2021-03-16_16-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker      0 Mar 16 16:53 2021-03-16_16-53_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker   3505 Mar 16 16:56 2021-03-16_16-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker      0 Mar 16 16:56 2021-03-16_16-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker   3505 Mar 16 16:57 2021-03-16_16-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 112864 Mar 16 16:57 2021-03-16_16-57_states.json.gz
          Man schaut wann zuerst 'auffällige' Dateien mit Dateigröße 0 oder auffälligem Schwund zwischen zwei Dateien auftauchen, wie hier:
          -rw-rw-r--+ 1 iobroker iobroker 1681373 Mar 16 18:00 2021-03-16_18-00_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker    3504 Mar 16 18:11 2021-03-16_18-11_objects.json.gz
          und guckt sich die letzten intakten Dateien davor aus. Im Beispiel diese:
          Die gleiche Übung muss ggf. auch für die states-Datenbank durchgeführt werden.
          Mit
          ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
          sieht man die, dann weiter wie oben mit den objects schon geschehen.
          Mit folgender Befehlsfolge kann man u. U. den ioBroker wieder beleben:
          (Bei Verwendung von jsonl ändern sich die Dateinamen entsprechend! Dann also json durch jsonl ersetzen!)
          iobroker stop
          cd /opt/iobroker/iobroker-data/
          mv objects.json objects.json.old
          mv states.json states.json.old
          cd backup-objects/
          gunzip -ck INTAKTE_DATEI_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
          gunzip -ck INTAKTE_DATEI_states.json.gz > /opt/iobroker/iobroker-data/states.json
          iobroker start
          INTAKTE_DATEI dabei mit dem zuvor ausgeguckten Dateinamen ersetzen.
          Mit freundlicher Empfehlung von @wendy2702
          W Offline
          W Offline
          WolfgangFB
          #78
          Hallo
          Ich freu mich auch immer wieder über diese gut funktionierende Lösung. Bei mir war es heute so, dass währen ich ein javascript editiert habe plötzlich die Oberfläche eingefroren ist und ich dann das System nicht mehr starten konnte.
          Im Verdacht habe ich ein skript, dass in einen Datenpunkt einen String schreibt, der immer länger wird. Ich kenne mich in javascript nicht so gut aus und weiß nicht, ob es da eine Obergrenze gibt, aber vielleicht ist das ja ein Ansatz zum Suchen.
          Gruß Wolfgang
          • W WolfgangFB
            Hallo
            Gruß Wolfgang
            #79
            @wolfgangfb ich denkendes Limit ist akademisch bzw vom normalen RAM durchaus begrenzt.
            Auch was „eingefroren“ heißt ist so ne Sache.
            Zeig doch mal ioBroker und syslog von dem zeitpunkt
            • W Offline
              W Offline
              WolfgangFB
              #80
              @apollon77 Hi
              Eingefrohren heißt: Ich bin ja im Browser wenn ich etwas mache. Plötzlich (ohne selbst irgend eine Aktion angestoße zu haben) kommt der graue Hintergrund mit dem drehenden Rad. Aus dem Raspi selbst sehe ich dann, dass iobroker status nicht mehr erreichbar ist.Nachdem start "iobroker start" kommt die bekannte Meldung "cannot find..."
              Wenn Du mir jetzt noch verrätst, was Du genau mit "zeig doch mal IoBroker" meinst und wie ich an den syslog von einem bestimmten Zeitpunkt komme mache ich das gerne.
              Gruß Wolfgang
              • W WolfgangFB
                @apollon77 Hi
                Gruß Wolfgang
                #81
                @wolfgangfb
                Für den heutigen Tag:
                cat /opt/iobroker/log/iobroker.current.log
                cat /var/log/syslog
                Ansonsten wäre noch die Ausstattung mit RAM interessant und ob da eine graphische Oberfläche vorgesehen ist:
                free -h
                who -r
                  @wolfgangfb
                  cat /var/log/syslog
                  free -h
                  who -r
                  #82
                  @thomas-braun sagte in Mini-HowTo: Cannot find view "system" for search "host":
                  Denke ehr gestern weil war wohl gestern :-)
                  • apollon77A apollon77
                    #83
                    @apollon77 @WolfgangFB
                    Dann halt so:
                    zcat /opt/iobroker/log/iobroker.2021-04-18.log.gz
                    cat /var/log/syslog.1
                    W 1 Antwort Letzte Antwort
                      Dann halt so:
                      W Offline
                      W Offline
                      WolfgangFB
                      #84
                      OK
                      Die iobroker log von kurz davor
                      2021-04-18 19:41:59.330  - info: web.0 (2740) ==>Connected system.user.admin from ::ffff:192.168.1.24
                      2021-04-18 19:41:59.335  - info: web.0 (2740) ==>Connected system.user.admin from ::ffff:192.168.1.24
                      2021-04-18 19:44:30.706  - info: host.raspberrypi4 iobroker.js-controller version 3.2.16 js-controller starting
                      2021-04-18 19:44:30.712  - info: host.raspberrypi4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                      2021-04-18 19:44:30.713  - info: host.raspberrypi4 hostname: raspberrypi4, node: v12.21.0
                      2021-04-18 19:44:30.713  - info: host.raspberrypi4 ip addresses: 192.168.1.203 2a02:810b:c63f:d98c::d7c2 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca fe80::da0:a631:6da1:f23c
                      2021-04-18 19:44:30.796  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
                      2021-04-18 19:44:32.727  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected token : in JSON at position 9906348. Continue with empty dataset!
                      2021-04-18 19:44:32.850  - error: host.raspberrypi4 Cannot read system.config: null (OK when migrating or restoring)
                      2021-04-18 19:44:32.860  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                      2021-04-18 19:44:32.861  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/states.json.bak: /opt/iobroker/iobroker-data/states.json.bak: Unexpected end of JSON input. Continue with empty dataset!
                      2021-04-18 19:44:32.951  - info: host.raspberrypi4 connected to Objects and States
                      2021-04-18 19:44:35.875  - info: host.raspberrypi4 added notifications configuration of host
                      2021-04-18 19:44:35.908  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
                      2021-04-18 19:44:35.929  - error: host.raspberrypi4 Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                      2021-04-18 19:44:36.058  - info: host.raspberrypi4 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2021-04-18 19:44:36.065  - error: host.raspberrypi4 Cannot find view "system" for search "host"
                      in der syslog sehe ich, das kurz zuvor das System neu gebootet hat. Wobei die Zeiten nicht zum iobroker Log passen. (Während der Bootphase haben laut iobroker log Ereignisse stattgefunden.
                      Ich bin mir jetzt auch nicht mehr ganz sicher, ob (oder wann) ich dann den Raspi neu gestartet habe.
                      Beim nächsten mal weiß ich aber jetzt, welche Logzeitpunkte wichtig sind und werde die dann genau festhalten (oder möchte jemand die gesamten Logs per PM zur Analyse haben?)
                      MOD EDIT: LOG IN CODE TAGS </> GESETZT
                      Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                      • W WolfgangFB
                        OK
                        #85
                        @wolfgangfb Und das syslog? Das wäre für @apollon77 mit Sicherheit noch interessanter als das iobroker.log
                        • W WolfgangFB
                          OK
                          #86
                          @wolfgangfb sagte in Mini-HowTo: Cannot find view "system" for search "host":
                          Also generell sieht man hier schön das es ein Harter "power off style" reboot gewesen ist. Wie aich immer das normale json UND das bak kaputt sein können und das von states UND objects verstehe ich zwar nur bedingt aber naja. Ich würde hier ggf sogar auf Filesystem Schaden tippen
                          • W Offline
                            W Offline
                            WolfgangFB
                            #87
                            @apollon77 So, gerade wieder, diesmal nichts neu gestartet sondern gleich die Logs gesichert.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=DC:A6:32:BA:3C:74 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19d7e1e8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Set the console keyboard layout.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started udev Coldplug all Devices.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Memory: 3654936K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133864K reserved, 262144K cma-reserved, 3264512K highmem)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] ftrace: allocating 33942 entries in 67 pages
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
                            Apr 20 14:24:11 raspberrypi4 systemd-fsck[134]: rootfs: clean, 198103/1859088 files, 1454653/7566848 blocks
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started File System Check on Root Device.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000026] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Remount Root and Kernel File Systems...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000088] bcm2835: system timer (irq = 25)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000761] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000780] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.000795] Switching to timer-based delay loop, resolution 18ns
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Helper to synchronize boot up for ifupdown.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.001050] Console: colour dummy device 80x30
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.001117] printk: console [tty1] enabled
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.001171] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.001204] pid_max: default: 32768 minimum: 301
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.001375] LSM: Security Framework initializing
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.001565] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.001591] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.003164] Disabling memory control group subsystem
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Remount Root and Kernel File Systems.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.003285] CPU: Testing write buffer coherency: ok
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.003755] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create System Users...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.004973] Setting up static identity map for 0x200000 - 0x20003c
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.005172] rcu: Hierarchical SRCU implementation.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.006106] smp: Bringing up secondary CPUs ...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.007344] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.008746] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.010062] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Load/Save Random Seed...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.010240] smp: Brought up 1 node, 4 CPUs
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.010261] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.010276] CPU: All CPU(s) started in HYP mode.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Flush Journal to Persistent Storage...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.010290] CPU: Virtualization extensions available.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.011228] devtmpfs: initialized
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.025476] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.025712] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.025744] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.032843] pinctrl core: initialized pinctrl subsystem
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.033944] NET: Registered protocol family 16
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.038118] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Load/Save Random Seed.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.038898] audit: initializing netlink subsys (disabled)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.039160] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.039747] thermal_sys: Registered thermal governor 'step_wise'
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.040550] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.040568] hw-breakpoint: maximum watchpoint size is 8 bytes.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.041004] Serial: AMBA PL011 UART driver
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Flush Journal to Persistent Storage.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.073158] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create System Users.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.090895] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.100907] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.145645] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.149841] vgaarb: loaded
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.150279] SCSI subsystem initialized
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.150509] usbcore: registered new interface driver usbfs
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.150570] usbcore: registered new interface driver hub
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create Static Device Nodes in /dev...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.150646] usbcore: registered new device driver usb
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.151344] usb_phy_generic phy: supply vcc not found, using dummy regulator
                            Apr 20 14:24:11 raspberrypi4 kernel: [    0.153338] clocksource: Switched to clocksource arch_sys_counter
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.152426] VFS: Disk quotas dquot_6.6.0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.152528] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.152706] FS-Cache: Loaded
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create Static Device Nodes in /dev.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.152906] CacheFiles: Loaded
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.153980] simple-framebuffer 3e6c7000.framebuffer: framebuffer at 0x3e6c7000, 0x500000 bytes, mapped to 0x(ptrval)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting udev Kernel Device Manager...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.154001] simple-framebuffer 3e6c7000.framebuffer: format=a8r8g8b8, mode=1280x1024x32, linelength=5120
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.154476] Console: switching to colour frame buffer device 160x64
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local File Systems (Pre).
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started udev Kernel Device Manager.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Show Plymouth Boot Screen...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Received SIGRTMIN+20 from PID 172 (plymouthd).
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Show Plymouth Boot Screen.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local Encrypted Volumes.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
                            Apr 20 14:24:11 raspberrypi4 systemd-udevd[168]: Using default interface naming scheme 'v240'.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Found device /dev/serial1.
                            Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 5: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
                            Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 4: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
                            Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 4 was not an MTP device
                            Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 3: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
                            Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 3 was not an MTP device
                            Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 5 was not an MTP device
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Found device /dev/disk/by-partuuid/19d7e1e8-01.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting File System Check on /dev/disk/by-partuuid/19d7e1e8-01...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.171948] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.171993] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.172148] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.172220] TCP: Hash tables configured (established 8192 bind 8192)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in FUSE Control File System being skipped.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.172386] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.172423] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.172688] NET: Registered protocol family 1
                            Apr 20 14:24:11 raspberrypi4 systemd-udevd[163]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.173461] RPC: Registered named UNIX socket transport module.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.173477] RPC: Registered udp transport module.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.173492] RPC: Registered tcp transport module.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.173507] RPC: Registered tcp NFSv4.1 backchannel transport module.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.173531] PCI: CLS 0 bytes, default 64
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Load/Save RF Kill Switch Status...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.176598] Initialise system trusted keyrings
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.176847] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                            Apr 20 14:24:11 raspberrypi4 systemd-udevd[189]: Using default interface naming scheme 'v240'.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.185544] zbud: loaded
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.187463] FS-Cache: Netfs 'nfs' registered for caching
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.188227] NFS: Registering the id_resolver key type
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.188260] Key type id_resolver registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.188275] Key type id_legacy registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.188414] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Load/Save RF Kill Switch Status.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.189464] Key type asymmetric registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.189481] Asymmetric key parser 'x509' registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.189673] bounce: pool size: 64 pages
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.189720] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.189946] io scheduler mq-deadline registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.189963] io scheduler kyber registered
                            Apr 20 14:24:11 raspberrypi4 systemd-udevd[160]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.194565] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.194596] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.194676] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.194764] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.255446] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.255832] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.255852] pci_bus 0000:00: root bus resource [bus 00-ff]
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.255873] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.255962] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                            Apr 20 14:24:11 raspberrypi4 systemd-udevd[152]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.256206] pci 0000:00:00.0: PME# supported from D0 D3hot
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.259734] PCI: bus0: Fast back to back transfers disabled
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.260075] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                            Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: fsck.fat 4.1 (2017-01-24)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.260204] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.260638] pci 0000:01:00.0: PME# supported from D0 D3cold
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.264174] PCI: bus1: Fast back to back transfers disabled
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.264238] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.264262] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.264344] pci 0000:00:00.0: PCI bridge to [bus 01]
                            Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.264370] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.264800] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.265035] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
                            Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]:  Automatically removing dirty bit.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.273628] iproc-rng200 fe104000.rng: hwrng registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.273943] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.274817] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.287194] brd: module loaded
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.299668] loop: module loaded
                            Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: Performing changes.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.301375] Loading iSCSI transport class v2.0-870.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.303870] libphy: Fixed MDIO Bus: probed
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.305567] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.323383] libphy: bcmgenet MII bus: probed
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.403508] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.404703] usbcore: registered new interface driver r8152
                            Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: /dev/mmcblk0p1: 264 files, 97566/516190 clusters
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.404771] usbcore: registered new interface driver lan78xx
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.404832] usbcore: registered new interface driver smsc95xx
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.406470] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started File System Check on /dev/disk/by-partuuid/19d7e1e8-01.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.406637] xhci_hcd 0000:01:00.0: xHCI Host Controller
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.406673] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.410047] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.411381] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.411401] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Mounting /boot...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.411418] usb usb1: Product: xHCI Host Controller
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.411435] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.411451] usb usb1: SerialNumber: 0000:01:00.0
                            Apr 20 14:24:11 raspberrypi4 systemd-udevd[196]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.412211] hub 1-0:1.0: USB hub found
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.412328] hub 1-0:1.0: 1 port detected
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.412999] xhci_hcd 0000:01:00.0: xHCI Host Controller
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.413038] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.413064] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Mounted /boot.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.413633] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.413652] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.413669] usb usb2: Product: xHCI Host Controller
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local File Systems.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.413685] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.413701] usb usb2: SerialNumber: 0000:01:00.0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.414412] hub 2-0:1.0: USB hub found
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.414496] hub 2-0:1.0: 4 ports detected
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.416217] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.416531] dwc_otg: FIQ enabled
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.416546] dwc_otg: NAK holdoff enabled
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.416560] dwc_otg: FIQ split-transaction FSM enabled
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Preprocess NFS configuration...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.416578] Module dwc_common_port init
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.417030] usbcore: registered new interface driver uas
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.417136] usbcore: registered new interface driver usb-storage
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.417332] mousedev: PS/2 mouse device common for all mice
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.419051] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.422586] sdhci: Secure Digital Host Controller Interface driver
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.422602] sdhci: Copyright(c) Pierre Ossman
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.423310] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.424006] sdhci-pltfm: SDHCI platform and OF driver helper
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Set console font and keymap...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.428187] ledtrig-cpu: registered to indicate activity on CPUs
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.428545] hid: raw HID events driver (C) Jiri Kosina
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.428739] usbcore: registered new interface driver usbhid
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.428755] usbhid: USB HID core driver
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.434717] Initializing XFRM netlink socket
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.434760] NET: Registered protocol family 17
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.434888] Key type dns_resolver registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.435341] Registering SWP/SWPB emulation handler
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Raise network interfaces...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.435522] registered taskstats version 1
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.435550] Loading compiled-in X.509 certificates
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.436381] Key type ._fscrypt registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.436398] Key type .fscrypt registered
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create Volatile Files and Directories...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.436413] Key type fscrypt-provisioning registered
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.448070] uart-pl011 fe201000.serial: there is not valid maps for state default
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.448377] uart-pl011 fe201000.serial: cts_event_workaround enabled
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.448469] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: nfs-config.service: Succeeded.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.455276] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.456349] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.456366] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.486695] of_cfs_init
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Preprocess NFS configuration.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.486967] of_cfs_init: OK
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.507463] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.509156] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.510840] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.513978] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.515664] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target NFS client services.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Remote File Systems (Pre).
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Remote File Systems.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Set console font and keymap.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create Volatile Files and Directories.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Network Time Synchronization...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Update UTMP about System Boot/Shutdown.
                            Apr 20 14:24:11 raspberrypi4 systemd-timesyncd[338]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2021-04-20 14:24:08 CEST
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Network Time Synchronization.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target System Time Synchronized.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: plymouth-read-write.service: Succeeded.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target System Initialization.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started CUPS Scheduler.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Paths.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.524316] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.525279] Waiting for root device PARTUUID=19d7e1e8-02...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.556591] random: fast init done
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.560965] mmc0: new high speed SDHC card at address b368
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily rotation of log files.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.561943] mmcblk0: mmc0:b368 NCard 29.1 GiB
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.564164]  mmcblk0: p1 p2
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.586167] mmc1: new high speed SDIO card at address 0001
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily Cleanup of Temporary Directories.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.595504] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.595521] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.773383] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.955972] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.955994] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily apt download activities.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.956011] usb 1-1: Product: USB2.0 Hub
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.958069] hub 1-1:1.0: USB hub found
                            Apr 20 14:24:11 raspberrypi4 kernel: [    1.958360] hub 1-1:1.0: 4 ports detected
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on D-Bus System Message Bus Socket.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.283380] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.423754] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.00
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.423773] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.423792] usb 1-1.1: Product: USB Receiver
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily apt upgrade and clean activities.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.423809] usb 1-1.1: Manufacturer: Logitech
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.436786] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C534.0001/input/input0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.504263] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily man-db regeneration.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.516405] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input1
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.516951] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input2
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.583693] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input3
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.584302] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.683377] usb 1-1.2: new low-speed USB device number 4 using xhci_hcd
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.821311] usb 1-1.2: New USB device found, idVendor=0458, idProduct=0007, bcdDevice= 0.00
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.821332] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Timers.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.821349] usb 1-1.2: Product: Optical Mouse
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.821366] usb 1-1.2: Manufacturer:  KYE
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on CUPS Scheduler.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.830698] input:  KYE   Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0458:0007.0003/input/input6
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.831210] hid-generic 0003:0458:0007.0003: input,hidraw2: USB HID v1.10 Mouse [ KYE   Optical Mouse] on usb-0000:01:00.0-1.2/input0
                            Apr 20 14:24:11 raspberrypi4 kernel: [    2.923377] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
                            Apr 20 14:24:11 raspberrypi4 kernel: [    3.062846] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
                            Apr 20 14:24:11 raspberrypi4 kernel: [    3.062866] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on triggerhappy.socket.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    3.062883] usb 1-1.3: Product: TI CC2531 USB CDC
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    3.062899] usb 1-1.3: Manufacturer: Texas Instruments
                            Apr 20 14:24:11 raspberrypi4 kernel: [    3.062916] usb 1-1.3: SerialNumber: __0X00124B001CD40626
                            Apr 20 14:24:11 raspberrypi4 kernel: [    3.531627] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                            Apr 20 14:24:11 raspberrypi4 kernel: [    3.590223] EXT4-fs (mmcblk0p2): 9 orphan inodes deleted
                            Apr 20 14:24:11 raspberrypi4 kernel: [    3.590242] EXT4-fs (mmcblk0p2): recovery complete
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Sockets.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.879135] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.879224] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.894488] devtmpfs: mounted
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Basic System.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.903459] Freeing unused kernel memory: 2048K
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.903785] Run /sbin/init as init process
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.903799]   with arguments:
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.903814]     /sbin/init
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Regular background program processing daemon.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.903828]     splash
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.903842]   with environment:
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.903857]     HOME=/
                            Apr 20 14:24:11 raspberrypi4 kernel: [    4.903871]     TERM=linux
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
                            Apr 20 14:24:11 raspberrypi4 kernel: [    7.032863] NET: Registered protocol family 10
                            Apr 20 14:24:11 raspberrypi4 kernel: [    7.034356] Segment Routing with IPv6
                            Apr 20 14:24:11 raspberrypi4 kernel: [    8.463450] random: systemd: uninitialized urandom read (16 bytes read)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    8.481708] random: systemd: uninitialized urandom read (16 bytes read)
                            Apr 20 14:24:11 raspberrypi4 kernel: [    8.482962] random: systemd: uninitialized urandom read (16 bytes read)
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting rng-tools.service...
                            Apr 20 14:24:11 raspberrypi4 kernel: [    8.721652] i2c /dev entries driver
                            Apr 20 14:24:11 raspberrypi4 kernel: [    9.554904] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.641713] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.642290] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.642885] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.643750] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.822744] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Configure Bluetooth Modems connected by UART...
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.824501] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.826737] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.826771] [vc_sm_connected_init]: start
                            Apr 20 14:24:11 raspberrypi4 cron[376]: (CRON) INFO (pidfile fd = 3)
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.848273] [vc_sm_connected_init]: installed successfully
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.849805] bcm2835_audio bcm2835_audio: card created with 4 channels
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.853096] bcm2835_audio bcm2835_audio: card created with 4 channels
                            Apr 20 14:24:11 raspberrypi4 cron[376]: (CRON) INFO (Running @reboot jobs)
                            Apr 20 14:24:11 raspberrypi4 kernel: [   10.982850] mc: Linux media interface: v0.10
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.105427] videodev: Linux video capture interface: v2.00
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.427266] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.427273] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.462722] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Manage Sound Card State (restore and store).
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.550425] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.557730] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.584209] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.584751] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.585224] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                            Apr 20 14:24:11 raspberrypi4 alsactl[383]: alsactl 1.1.8 daemon started
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting dhcpcd on all interfaces...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Check for v3d driver...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started D-Bus System Message Bus.
                            Apr 20 14:24:11 raspberrypi4 rng-tools[378]: Starting Hardware RNG entropy gatherer daemon: rngd.
                            Apr 20 14:24:11 raspberrypi4 rngd[398]: rngd 2-unofficial-mt.14 starting up...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting WPA supplicant...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Save/Restore Sound Card State...
                            Apr 20 14:24:11 raspberrypi4 rngd[398]: entropy feed to the kernel ready
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Login Service...
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.585569] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.585601] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.585627] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Disk Manager...
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.585650] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.585672] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting triggerhappy global hotkey daemon...
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.585873] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.632460] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.632488] checking generic (3e6c7000 500000) vs hw (0 ffffffffffffffff)
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.632506] fb0: switching to vc4drmfb from simple
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.633128] Console: switching to colour dummy device 80x30
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting System Logging Service...
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.634949] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.636914] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.636972] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.637019] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.637061] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.637112] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.637157] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.637199] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.637239] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Raise network interfaces.
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started rng-tools.service.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.637280] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Save/Restore Sound Card State.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.665628] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.721157] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.721203] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.734419] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                            Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Sound Card.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.734457] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.741420] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.741459] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.745750] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.856935] Console: switching to colour frame buffer device 160x64
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.880028] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.940829] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.946802] usbcore: registered new interface driver cdc_acm
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.946823] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                            Apr 20 14:24:11 raspberrypi4 kernel: [   11.960247] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                            Apr 20 14:24:11 raspberrypi4 dhcpcd[386]: dev: loaded udev
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.076017] brcmfmac: F1 signature read @0x18000000=0x15264345
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.086842] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.087515] usbcore: registered new interface driver brcmfmac
                            Apr 20 14:24:11 raspberrypi4 thd[412]: Found socket passed from systemd
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.231259] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.286383] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.477063] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.529613] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.716938] logitech-djreceiver 0003:046D:C534.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
                            Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.800235] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
                            Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: Successfully dropped root privileges.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.803626] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input7
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.807717] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input8
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.814168] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input9
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.814657] hid-generic 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:01:00.0-1.1/input1:1
                            Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: avahi-daemon 0.7 starting up.
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.816229] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
                            Apr 20 14:24:11 raspberrypi4 dhcpcd[386]: forked to background, child pid 440
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.818419] input: Logitech Wireless Mouse PID:4038 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4038.0005/input/input14
                            Apr 20 14:24:11 raspberrypi4 kernel: [   12.819041] hid-generic 0003:046D:4038.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4038] on usb-0000:01:00.0-1.1/input1:2
                            Apr 20 14:24:11 raspberrypi4 kernel: [   13.713076] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input18
                            Apr 20 14:24:11 raspberrypi4 rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
                            Apr 20 14:24:11 raspberrypi4 kernel: [   13.714890] logitech-hidpp-device 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:01:00.0-1.1/input1:1
                            Apr 20 14:24:11 raspberrypi4 kernel: [   13.856632] input: Logitech Wireless Mouse PID:4038 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4038.0005/input/input19
                            Apr 20 14:24:11 raspberrypi4 kernel: [   13.857187] logitech-hidpp-device 0003:046D:4038.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4038] on usb-0000:01:00.0-1.1/input1:2
                            Apr 20 14:24:11 raspberrypi4 kernel: [   16.716140] random: crng init done
                            Apr 20 14:24:11 raspberrypi4 rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="413" x-info="https://www.rsyslog.com"] start
                            Apr 20 14:24:11 raspberrypi4 kernel: [   16.716164] random: 7 urandom warning(s) missed due to ratelimiting
                            Apr 20 14:24:11 raspberrypi4 kernel: [   16.737069] uart-pl011 fe201000.serial: no DMA platform data
                            Apr 20 14:24:11 raspberrypi4 kernel: [   18.518351] 8021q: 802.1Q VLAN Support v1.8
                            Apr 20 14:24:11 raspberrypi4 udisksd[411]: udisks daemon version 2.8.1 starting
                            Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 8.2.0 CTV); collect: 128K
                            Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 14768/63488
                            Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 7.99864
                            Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: fills: 0, generated: 0
                            Apr 20 14:24:11 raspberrypi4 dphys-swapfile[410]: want /var/swap=100MByte, checking existing: keeping it
                            Apr 20 14:24:11 raspberrypi4 dhcpcd-run-hooks[488]: wlan0: starting wpa_supplicant
                            Apr 20 14:24:12 raspberrypi4 kernel: [   19.850495] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started triggerhappy global hotkey daemon.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started System Logging Service.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: systemd-rfkill.service: Succeeded.
                            Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Successfully called chroot().
                            Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Successfully dropped remaining capabilities.
                            Apr 20 14:24:12 raspberrypi4 wpa_supplicant[403]: Successfully initialized wpa_supplicant
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started dhcpcd on all interfaces.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Check for v3d driver.
                            Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: No service file found in /etc/avahi/services.
                            Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Network interface enumeration completed.
                            Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Server startup complete. Host name is raspberrypi4.local. Local service cookie is 2766927354.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Login Service.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Avahi mDNS/DNS-SD Stack.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started WPA supplicant.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Make remote CUPS printers available locally.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Reached target Network.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Permit User Sessions...
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started ioBroker Server.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Reached target Network is Online.
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Samba NMB Daemon...
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Daily apt download activities...
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting /etc/rc.local Compatibility...
                            Apr 20 14:24:12 raspberrypi4 systemd[1]: Started VNC Server in Service Mode daemon.
                            Apr 20 14:24:12 raspberrypi4 kernel: [   20.513499] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                            Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting OpenBSD Secure Shell server...
                            Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting MariaDB 10.3.27 database server...
                            Apr 20 14:24:13 raspberrypi4 systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
                            Apr 20 14:24:13 raspberrypi4 systemd[1]: Started Permit User Sessions.
                            Apr 20 14:24:13 raspberrypi4 systemd[1]: Started /etc/rc.local Compatibility.
                            Apr 20 14:24:13 raspberrypi4 udisksd[411]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
                            Apr 20 14:24:13 raspberrypi4 udisksd[411]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
                            Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting Light Display Manager...
                            Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting Hold until boot process finishes up...
                            Apr 20 14:24:13 raspberrypi4 dnsmasq[502]: dnsmasq: Syntaxprüfung OK.
                            Apr 20 14:24:14 raspberrypi4 raspi-config[414]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
                            Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: wlan0: connected to Access Point `'
                            Apr 20 14:24:14 raspberrypi4 systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                            Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: eth0: waiting for carrier
                            Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: wlan0: waiting for carrier
                            Apr 20 14:24:14 raspberrypi4 kernel: [   21.989989] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                            Apr 20 14:24:14 raspberrypi4 kernel: [   21.990254] bcmgenet fd580000.ethernet eth0: Link is Down
                            Apr 20 14:24:14 raspberrypi4 udisksd[411]: Failed to load the 'mdraid' libblockdev plugin
                            Apr 20 14:24:14 raspberrypi4 udisksd[411]: Failed to load the 'crypto' libblockdev plugin
                            Apr 20 14:24:14 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.5' (uid=0 pid=411 comm="/usr/lib/udisks2/udisksd ")
                            Apr 20 14:24:14 raspberrypi4 systemd[1]: Starting Authorization Manager...
                            Apr 20 14:24:14 raspberrypi4 systemd[1]: Started Mosquitto MQTT v3.1/v3.1.1 Broker.
                            Apr 20 14:24:14 raspberrypi4 systemd[1]: Started OpenBSD Secure Shell server.
                            Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: gestartet, Version 2.80, Cachegröße 150
                            Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: DNS-Dienst auf lokale Subnetze eingeschränkt
                            Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: Übersetzungsoptionen: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
                            Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: /etc/hosts gelesen - 5 Adressen
                            Apr 20 14:24:15 raspberrypi4 dnsmasq[556]: keine Server in /run/dnsmasq/resolv.conf gefunden, werde es später neu versuchen
                            Apr 20 14:24:15 raspberrypi4 dnsmasq[557]: Too few arguments.
                            Apr 20 14:24:15 raspberrypi4 systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
                            Apr 20 14:24:15 raspberrypi4 systemd[1]: Reached target Host and Network Name Lookups.
                            Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]: BOOTLOADER: up-to-date
                            Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                            Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:     LATEST: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                            Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
                            Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:             Use raspi-config to change the release.
                            Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:   VL805_FW: Dedicated VL805 EEPROM
                            Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:      VL805: up-to-date
                            Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    CURRENT: 000138a1
                            Apr 20 14:24:16 raspberrypi4 rpi-eeprom-update[385]:     LATEST: 000138a1
                            Apr 20 14:24:16 raspberrypi4 systemd[1]: Started Check for Raspberry Pi EEPROM updates.
                            Apr 20 14:24:18 raspberrypi4 dhcpcd[440]: eth0: carrier acquired
                            Apr 20 14:24:18 raspberrypi4 kernel: [   26.153638] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                            Apr 20 14:24:18 raspberrypi4 kernel: [   26.153698] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                            Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: DUID 00:01:00:01:27:8f:0c:24:dc:a6:32:ba:3c:74
                            Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: IAID 32:ba:3c:74
                            Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: adding address fe80::da0:a631:6da1:f23c
                            Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::da0:a631:6da1:f23c.
                            Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: New relevant interface eth0.IPv6 for mDNS.
                            Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: probing address 192.168.1.203/24
                            Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: Registering new address record for fe80::da0:a631:6da1:f23c on eth0.*.
                            Apr 20 14:24:19 raspberrypi4 lightdm[524]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.629392] Bluetooth: Core ver 2.22
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.629502] NET: Registered protocol family 31
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.629516] Bluetooth: HCI device and connection manager initialized
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.630104] Bluetooth: HCI socket layer initialized
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.630124] Bluetooth: L2CAP socket layer initialized
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.630171] Bluetooth: SCO socket layer initialized
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.869925] Bluetooth: HCI UART driver ver 2.3
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.869946] Bluetooth: HCI UART protocol H4 registered
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.870061] Bluetooth: HCI UART protocol Three-wire (H5) registered
                            Apr 20 14:24:20 raspberrypi4 kernel: [   27.870348] Bluetooth: HCI UART protocol Broadcom registered
                            Apr 20 14:24:20 raspberrypi4 btuart[380]: bcm43xx_init
                            Apr 20 14:24:20 raspberrypi4 btuart[380]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
                            Apr 20 14:24:20 raspberrypi4 btuart[380]: Set Controller UART speed to 3000000 bit/s
                            Apr 20 14:24:20 raspberrypi4 btuart[380]: Device setup complete
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Starting Load/Save RF Kill Switch Status...
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Configure Bluetooth Modems connected by UART.
                            Apr 20 14:24:20 raspberrypi4 polkitd[552]: started daemon version 0.105 using authority implementation `local' version `0.105'
                            Apr 20 14:24:20 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Load/Save RF Kill Switch Status.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: plymouth-start.service: Succeeded.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: plymouth-quit-wait.service: Succeeded.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Hold until boot process finishes up.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Received SIGRTMIN+21 from PID 172 (n/a).
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Authorization Manager.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Light Display Manager.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Getty on tty1.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Reached target Login Prompts.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Created slice system-bthelper.slice.
                            Apr 20 14:24:20 raspberrypi4 systemd[1]: Starting Bluetooth service...
                            Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: soliciting an IPv6 router
                            Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: Router Advertisement from fe80::f2af:85ff:fe8c:99dc
                            Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: adding address 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca/64
                            Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::da0:a631:6da1:f23c.
                            Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv6 with address 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca.
                            Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Registering new address record for 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca on eth0.*.
                            Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: adding route to 2a02:810b:c63f:d98c::/64
                            Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Withdrawing address record for fe80::da0:a631:6da1:f23c on eth0.
                            Apr 20 14:24:20 raspberrypi4 kernel: [   28.477216] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                            Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: confirming prior DHCPv6 lease
                            Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: fe80::f2af:85ff:fe8c:99dc is reachable again
                            Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: adding default route via fe80::f2af:85ff:fe8c:99dc
                            Apr 20 14:24:21 raspberrypi4 systemd[1]: Started Disk Manager.
                            Apr 20 14:24:21 raspberrypi4 udisksd[411]: Acquired the name org.freedesktop.UDisks2 on the system message bus
                            Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: REPLY6 received from fe80::f2af:85ff:fe8c:99dc
                            Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: adding address 2a02:810b:c63f:d98c::d7c2/128
                            Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: renew in 21600, rebind in 34560, expire in 43200 seconds
                            Apr 20 14:24:21 raspberrypi4 avahi-daemon[390]: Registering new address record for 2a02:810b:c63f:d98c::d7c2 on eth0.*.
                            Apr 20 14:24:22 raspberrypi4 bluetoothd[691]: Bluetooth daemon 5.50
                            Apr 20 14:24:22 raspberrypi4 systemd[1]: Started Bluetooth service.
                            Apr 20 14:24:22 raspberrypi4 systemd[1]: Started Raspberry Pi bluetooth helper.
                            Apr 20 14:24:22 raspberrypi4 systemd[1]: Reached target Bluetooth.
                            Apr 20 14:24:22 raspberrypi4 bluetoothd[691]: Starting SDP server
                            Apr 20 14:24:22 raspberrypi4 mysqld[642]: 2021-04-20 14:24:22 0 [Note] /usr/sbin/mysqld (mysqld 10.3.27-MariaDB-0+deb10u1) starting as process 642 ...
                            Apr 20 14:24:22 raspberrypi4 mysqld[642]: 2021-04-20 14:24:22 0 [Warning] Could not increase number of max_open_files to more than 16384 (request: 32186)
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: Raspberry Pi BDADDR already set
                            Apr 20 14:24:23 raspberrypi4 kernel: [   30.787342] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                            Apr 20 14:24:23 raspberrypi4 kernel: [   30.787364] Bluetooth: BNEP filters: protocol multicast
                            Apr 20 14:24:23 raspberrypi4 kernel: [   30.787394] Bluetooth: BNEP socket layer initialized
                            Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Bluetooth management interface 1.18 initialized
                            Apr 20 14:24:23 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.13' (uid=0 pid=691 comm="/usr/lib/bluetooth/bluetoothd ")
                            Apr 20 14:24:23 raspberrypi4 vncserver-x11[536,root]: ServerManager: Server started
                            Apr 20 14:24:23 raspberrypi4 systemd[1]: Starting Hostname Service...
                            Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Sap driver initialization failed.
                            Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: sap-server: Operation not permitted (1)
                            Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Failed to set privacy: Rejected (0x0b)
                            Apr 20 14:24:23 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.hostname1'
                            Apr 20 14:24:23 raspberrypi4 systemd[1]: Started Hostname Service.
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001801-0000-1000-8000-00805f9b34fb
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001800-0000-1000-8000-00805f9b34fb
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 Alias: BlueZ 5.50
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 Pairable: yes
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: Changing power off succeeded
                            Apr 20 14:24:23 raspberrypi4 bthelper[699]: Changing power on succeeded
                            Apr 20 14:24:23 raspberrypi4 systemd[1]: bthelper@hci0.service: Succeeded.
                            Apr 20 14:24:23 raspberrypi4 vncserver-x11[536,root]: ConsoleDisplay: Cannot find a running X server on vt1
                            Apr 20 14:24:24 raspberrypi4 vncserver-x11[536,root]: ConsoleDisplay: Found running X server (pid=681, binary=/usr/lib/xorg/Xorg)
                            Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: using static address 192.168.1.203/24
                            Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: adding route to 192.168.1.0/24
                            Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.203.
                            Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: New relevant interface eth0.IPv4 for mDNS.
                            Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: adding default route via 192.168.1.200
                            Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: Registering new address record for 192.168.1.203 on eth0.IPv4.
                            Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: lese /run/dnsmasq/resolv.conf
                            Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver 192.168.1.200#53
                            Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver 8.8.8.8#53
                            Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver fd51:42f8:caae:d92e::1#53
                            Apr 20 14:24:25 raspberrypi4 systemd[1]: systemd-rfkill.service: Succeeded.
                            Apr 20 14:24:27 raspberrypi4 dhcpcd[440]: eth0: fe80::f2af:85ff:fe8c:99dc is reachable again
                            Apr 20 14:24:29 raspberrypi4 systemd[1]: Started Samba NMB Daemon.
                            Apr 20 14:24:29 raspberrypi4 systemd[1]: Starting Samba SMB Daemon...
                            Apr 20 14:24:29 raspberrypi4 vncserver-x11[536,root]: AgentInitCheck: no response from agent
                            Apr 20 14:24:30 raspberrypi4 systemd[1]: Created slice User Slice of UID 1000.
                            Apr 20 14:24:30 raspberrypi4 systemd[1]: Starting User Runtime Directory /run/user/1000...
                            Apr 20 14:24:30 raspberrypi4 systemd[1]: Started User Runtime Directory /run/user/1000.
                            Apr 20 14:24:30 raspberrypi4 systemd[1]: Starting User Manager for UID 1000...
                            Apr 20 14:24:30 raspberrypi4 systemd[1]: apt-daily.service: Succeeded.
                            Apr 20 14:24:30 raspberrypi4 systemd[1]: Started Daily apt download activities.
                            Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: lese /run/dnsmasq/resolv.conf
                            Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 192.168.1.200#53
                            Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 8.8.8.8#53
                            Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver fd51:42f8:caae:d92e::1#53
                            Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 2a02:810b:c63f:d98c:f2af:85ff:fe8c:99dc#53
                            Apr 20 14:24:32 raspberrypi4 systemd[1]: Started MariaDB 10.3.27 database server.
                            Apr 20 14:24:32 raspberrypi4 /etc/mysql/debian-start[901]: Upgrading MySQL tables if necessary.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on Sound System.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Paths.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Timers.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG network certificate management daemon.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Starting D-Bus User Message Bus Socket.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on D-Bus User Message Bus Socket.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Sockets.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Basic System.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Default.
                            Apr 20 14:24:32 raspberrypi4 systemd[811]: Startup finished in 2.212s.
                            Apr 20 14:24:32 raspberrypi4 systemd[1]: Started User Manager for UID 1000.
                            Apr 20 14:24:32 raspberrypi4 systemd[1]: Started Session 1 of user pi.
                            Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: /usr/bin/mysql_upgrade: the '--basedir' option is always ignored
                            Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: Looking for 'mysql' as: /usr/bin/mysql
                            Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: Looking for 'mysqlcheck' as: /usr/bin/mysqlcheck
                            Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: This installation of MySQL is already upgraded to 10.3.27-MariaDB, use --force if you still need to run mysql_upgrade
                            Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[984]: Checking for insecure root accounts.
                            Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[990]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
                            Apr 20 14:24:35 raspberrypi4 systemd[1]: Started Samba SMB Daemon.
                            Apr 20 14:24:35 raspberrypi4 systemd[1]: Reached target Multi-User System.
                            Apr 20 14:24:35 raspberrypi4 systemd[1]: Reached target Graphical Interface.
                            Apr 20 14:24:35 raspberrypi4 systemd[1]: Starting Update UTMP about System Runlevel Changes...
                            Apr 20 14:24:35 raspberrypi4 systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
                            Apr 20 14:24:35 raspberrypi4 systemd[1]: Started Update UTMP about System Runlevel Changes.
                            Apr 20 14:24:35 raspberrypi4 systemd[1]: Startup finished in 6.594s (kernel) + 36.438s (userspace) = 43.033s.
                            Apr 20 14:24:36 raspberrypi4 vncserver-x11[536,root]: Connections: connected: 192.168.1.24::54365 (TCP)
                            Apr 20 14:24:36 raspberrypi4 vncserver-x11[536,root]: Connections: authenticated: 192.168.1.24::54365 (TCP), as (anonymous) (d permissions)
                            Apr 20 14:24:37 raspberrypi4 kernel: [   44.583156] broken atomic modeset userspace detected, disabling atomic
                            Apr 20 14:24:37 raspberrypi4 systemd[1]: systemd-fsckd.service: Succeeded.
                            Apr 20 14:34:15 raspberrypi4 systemd-timesyncd[338]: Synchronized to time server for the first time [2a02:a00:1009:6202::123]:123 (2.debian.pool.ntp.org).
                            Apr 20 14:34:15 raspberrypi4 lightdm[1064]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                            Apr 20 14:34:15 raspberrypi4 systemd[1]: Started Session 3 of user pi.
                            Apr 20 14:34:15 raspberrypi4 bash[504]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                            Apr 20 14:34:15 raspberrypi4 bash[504]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                            Apr 20 14:34:16 raspberrypi4 bash[504]: object system.meta.uuid created: f2bf0859-fa5f-19ae-5629-68c17843bcf5
                            Apr 20 14:34:16 raspberrypi4 bash[504]: object system.user.admin created
                            Apr 20 14:34:16 raspberrypi4 systemd[811]: Started D-Bus User Message Bus.
                            Apr 20 14:34:29 raspberrypi4 systemd[1]: systemd-hostnamed.service: Succeeded.
                            Apr 20 14:34:30 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=1000 pid=1083 comm="/usr/bin/lxsession -s LXDE-pi -e LXDE ")
                            Apr 20 14:34:30 raspberrypi4 systemd[811]: Starting Virtual filesystem service...
                            Apr 20 14:34:30 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.Daemon'
                            Apr 20 14:34:30 raspberrypi4 systemd[811]: Started Virtual filesystem service.
                            Apr 20 14:34:30 raspberrypi4 kernel: [   62.126481] fuse: init (API version 7.32)
                            Apr 20 14:34:31 raspberrypi4 systemd[1]: Mounting FUSE Control File System...
                            Apr 20 14:34:31 raspberrypi4 systemd[1]: Mounted FUSE Control File System.
                            Apr 20 14:34:31 raspberrypi4 systemd[811]: Starting Sound Service...
                            Apr 20 14:34:32 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.29' (uid=1000 pid=1238 comm="/usr/bin/pulseaudio --daemonize=no ")
                            Apr 20 14:34:32 raspberrypi4 systemd[1]: Starting RealtimeKit Scheduling Policy Service...
                            Apr 20 14:34:32 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
                            Apr 20 14:34:32 raspberrypi4 systemd[1]: Started RealtimeKit Scheduling Policy Service.
                            Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully called chroot.
                            Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully dropped privileges.
                            Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully limited resources.
                            Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Running.
                            Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Canary thread running.
                            Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Watchdog thread running.
                            Apr 20 14:34:33 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                            Apr 20 14:34:33 raspberrypi4 systemd[811]: Starting Virtual filesystem service - disk device monitor...
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - disk device monitor.
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - Media Transfer Protocol monitor.
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                            Apr 20 14:34:34 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1238 of process 1238 (n/a) owned by '1000' high priority at nice level -11.
                            Apr 20 14:34:34 raspberrypi4 rtkit-daemon[1253]: Supervising 1 threads of 1 processes of 1 users.
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - digital camera monitor...
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - digital camera monitor.
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - GNOME Online Accounts monitor.
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - Apple File Conduit monitor...
                            Apr 20 14:34:34 raspberrypi4 gvfs-afc-volume-monitor[1295]: Volume monitor alive
                            Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
                            Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - Apple File Conduit monitor.
                            Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 1 threads of 1 processes of 1 users.
                            Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1302 of process 1238 (n/a) owned by '1000' RT at priority 5.
                            Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 2 threads of 1 processes of 1 users.
                            Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1303 of process 1238 (n/a) owned by '1000' RT at priority 5.
                            Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 3 threads of 1 processes of 1 users.
                            Apr 20 14:34:35 raspberrypi4 systemd[811]: Started Sound Service.
                            Apr 20 14:34:35 raspberrypi4 bluetoothd[691]: Endpoint registered: sender=:1.34 path=/MediaEndpoint/A2DPSource
                            Apr 20 14:34:35 raspberrypi4 bluetoothd[691]: Endpoint registered: sender=:1.34 path=/MediaEndpoint/A2DPSink
                            Apr 20 14:34:35 raspberrypi4 pulseaudio[1238]: E: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
                            Apr 20 14:34:35 raspberrypi4 kernel: [   66.990077] Bluetooth: RFCOMM TTY layer initialized
                            Apr 20 14:34:35 raspberrypi4 kernel: [   66.990099] Bluetooth: RFCOMM socket layer initialized
                            Apr 20 14:34:35 raspberrypi4 kernel: [   66.990120] Bluetooth: RFCOMM ver 1.11
                            und hier das Ende vom IOBroker log:
                            2021-04-20 14:28:55.984  - error: javascript.0 (14256) function(DeviceName(s, x)){ // mit Punkt am Ende
                            2021-04-20 14:28:55.985  - error: javascript.0 (14256) ^^^^^^^^
                            2021-04-20 14:28:55.985  - error: javascript.0 (14256) SyntaxError: Function statements require a function name
                            2021-04-20 14:28:55.985  - error: javascript.0 (14256)     at new Script (vm.js:88:7)
                            2021-04-20 14:28:55.985  - error: javascript.0 (14256)     at Object.createScript (vm.js:261:10)
                            2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
                            2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
                            2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
                            2021-04-20 14:28:55.987  - error: javascript.0 (14256)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17)
                            2021-04-20 14:28:55.987  - error: javascript.0 (14256)     at processImmediate (internal/timers.js:463:21)
                            2021-04-20 14:29:01.400  - error: javascript.0 (14256) script.js.Test: test
                            2021-04-20 14:29:29.817  - info: javascript.0 (14256) Stop script script.js.Sensoren.ShellyErfassen
                            2021-04-20 14:29:29.839  - info: javascript.0 (14256) Start javascript script.js.Sensoren.ShellyErfassen
                            2021-04-20 14:30:00.052  - info: host.raspberrypi4 instance system.adapter.daswetter.0 started with pid 4110
                            2021-04-20 14:30:01.917  - info: daswetter.0 (4110) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.21.0, js-controller: 3.2.16
                            2021-04-20 14:30:14.329  - info: daswetter.0 (4110) Terminated (NO_ERROR): Without reason
                            2021-04-20 14:30:14.854  - info: daswetter.0 (4110) cleaned everything up...
                            2021-04-20 14:30:14.869  - info: host.raspberrypi4 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-04-20 14:24:38.869  - info: host.raspberrypi4 iobroker.js-controller version 3.2.16 js-controller starting
                            2021-04-20 14:24:38.874  - info: host.raspberrypi4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                            2021-04-20 14:24:38.875  - info: host.raspberrypi4 hostname: raspberrypi4, node: v12.21.0
                            2021-04-20 14:24:38.876  - info: host.raspberrypi4 ip addresses: 192.168.1.203 2a02:810b:c63f:d98c::d7c2 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca fe80::da0:a631:6da1:f23c
                            2021-04-20 14:24:38.941  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
                            2021-04-20 14:24:38.943  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected end of JSON input. Continue with empty dataset!
                            2021-04-20 14:24:39.020  - error: host.raspberrypi4 Cannot read system.config: null (OK when migrating or restoring)
                            2021-04-20 14:24:39.029  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                            2021-04-20 14:34:15.578  - info: host.raspberrypi4 connected to Objects and States
                            2021-04-20 14:34:15.727  - warn: host.raspberrypi4 logger system.adapter.admin.0.logging was deleted
                            2021-04-20 14:34:15.728  - warn: host.raspberrypi4 logger system.adapter.javascript.0.logging was deleted
                            2021-04-20 14:34:15.773  - info: host.raspberrypi4 added notifications configuration of host
                            2021-04-20 14:34:15.780  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
                            2021-04-20 14:34:15.781  - error: host.raspberrypi4 Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                            2021-04-20 14:34:15.796  - info: host.raspberrypi4 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            2021-04-20 14:34:15.803  - error: host.raspberrypi4 Cannot find view "system" for search "host"
                            2021-04-20 14:34:15.812  - error: host.raspberrypi4 Cannot find view "system" for search "state"
                            2021-04-20 14:34:15.813  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
                            2021-04-20 14:34:15.815  - error: host.raspberrypi4 Could not collect system.host.raspberrypi4 states to check for obsolete states: Error: Cannot find view "system"
                            2021-04-20 14:34:15.816  - error: host.raspberrypi4 _design/system missing - call node iobroker.js setup
                            2021-04-20 14:34:16.643  - info: host.raspberrypi4 Created UUID: f2bf0859-fa5f-19ae-5629-68c17843bcf5
                            und
                            pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ free -h
                            Mem:          3,7Gi       244Mi       3,1Gi        48Mi       404Mi       3,3Gi
                            Swap:          99Mi          0B        99Mi
                            pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ who -r
                                     Runlevel 5   2021-04-20 14:24
                            Gruß Wolfgang
                            apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                            • W WolfgangFB
                              @apollon77 So, gerade wieder, diesmal nichts neu gestartet sondern gleich die Logs gesichert.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=DC:A6:32:BA:3C:74 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19d7e1e8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Set the console keyboard layout.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started udev Coldplug all Devices.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Memory: 3654936K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133864K reserved, 262144K cma-reserved, 3264512K highmem)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] ftrace: allocating 33942 entries in 67 pages
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
                              Apr 20 14:24:11 raspberrypi4 systemd-fsck[134]: rootfs: clean, 198103/1859088 files, 1454653/7566848 blocks
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started File System Check on Root Device.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000026] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Remount Root and Kernel File Systems...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000088] bcm2835: system timer (irq = 25)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000761] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000780] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.000795] Switching to timer-based delay loop, resolution 18ns
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Helper to synchronize boot up for ifupdown.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.001050] Console: colour dummy device 80x30
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.001117] printk: console [tty1] enabled
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.001171] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.001204] pid_max: default: 32768 minimum: 301
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.001375] LSM: Security Framework initializing
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.001565] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.001591] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.003164] Disabling memory control group subsystem
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Remount Root and Kernel File Systems.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.003285] CPU: Testing write buffer coherency: ok
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.003755] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create System Users...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.004973] Setting up static identity map for 0x200000 - 0x20003c
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.005172] rcu: Hierarchical SRCU implementation.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.006106] smp: Bringing up secondary CPUs ...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.007344] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.008746] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.010062] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Load/Save Random Seed...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.010240] smp: Brought up 1 node, 4 CPUs
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.010261] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.010276] CPU: All CPU(s) started in HYP mode.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Flush Journal to Persistent Storage...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.010290] CPU: Virtualization extensions available.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.011228] devtmpfs: initialized
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.025476] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.025712] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.025744] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.032843] pinctrl core: initialized pinctrl subsystem
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.033944] NET: Registered protocol family 16
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.038118] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Load/Save Random Seed.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.038898] audit: initializing netlink subsys (disabled)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.039160] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.039747] thermal_sys: Registered thermal governor 'step_wise'
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.040550] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.040568] hw-breakpoint: maximum watchpoint size is 8 bytes.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.041004] Serial: AMBA PL011 UART driver
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Flush Journal to Persistent Storage.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.073158] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create System Users.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.090895] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.100907] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.145645] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.149841] vgaarb: loaded
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.150279] SCSI subsystem initialized
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.150509] usbcore: registered new interface driver usbfs
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.150570] usbcore: registered new interface driver hub
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create Static Device Nodes in /dev...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.150646] usbcore: registered new device driver usb
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.151344] usb_phy_generic phy: supply vcc not found, using dummy regulator
                              Apr 20 14:24:11 raspberrypi4 kernel: [    0.153338] clocksource: Switched to clocksource arch_sys_counter
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.152426] VFS: Disk quotas dquot_6.6.0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.152528] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.152706] FS-Cache: Loaded
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create Static Device Nodes in /dev.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.152906] CacheFiles: Loaded
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.153980] simple-framebuffer 3e6c7000.framebuffer: framebuffer at 0x3e6c7000, 0x500000 bytes, mapped to 0x(ptrval)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting udev Kernel Device Manager...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.154001] simple-framebuffer 3e6c7000.framebuffer: format=a8r8g8b8, mode=1280x1024x32, linelength=5120
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.154476] Console: switching to colour frame buffer device 160x64
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local File Systems (Pre).
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started udev Kernel Device Manager.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Show Plymouth Boot Screen...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Received SIGRTMIN+20 from PID 172 (plymouthd).
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Show Plymouth Boot Screen.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local Encrypted Volumes.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
                              Apr 20 14:24:11 raspberrypi4 systemd-udevd[168]: Using default interface naming scheme 'v240'.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Found device /dev/serial1.
                              Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 5: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
                              Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 4: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
                              Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 4 was not an MTP device
                              Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 3: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
                              Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 3 was not an MTP device
                              Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 5 was not an MTP device
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Found device /dev/disk/by-partuuid/19d7e1e8-01.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting File System Check on /dev/disk/by-partuuid/19d7e1e8-01...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.171948] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.171993] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.172148] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.172220] TCP: Hash tables configured (established 8192 bind 8192)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in FUSE Control File System being skipped.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.172386] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.172423] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.172688] NET: Registered protocol family 1
                              Apr 20 14:24:11 raspberrypi4 systemd-udevd[163]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.173461] RPC: Registered named UNIX socket transport module.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.173477] RPC: Registered udp transport module.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.173492] RPC: Registered tcp transport module.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.173507] RPC: Registered tcp NFSv4.1 backchannel transport module.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.173531] PCI: CLS 0 bytes, default 64
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Load/Save RF Kill Switch Status...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.176598] Initialise system trusted keyrings
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.176847] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                              Apr 20 14:24:11 raspberrypi4 systemd-udevd[189]: Using default interface naming scheme 'v240'.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.185544] zbud: loaded
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.187463] FS-Cache: Netfs 'nfs' registered for caching
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.188227] NFS: Registering the id_resolver key type
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.188260] Key type id_resolver registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.188275] Key type id_legacy registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.188414] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Load/Save RF Kill Switch Status.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.189464] Key type asymmetric registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.189481] Asymmetric key parser 'x509' registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.189673] bounce: pool size: 64 pages
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.189720] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.189946] io scheduler mq-deadline registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.189963] io scheduler kyber registered
                              Apr 20 14:24:11 raspberrypi4 systemd-udevd[160]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.194565] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.194596] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.194676] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.194764] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.255446] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.255832] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.255852] pci_bus 0000:00: root bus resource [bus 00-ff]
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.255873] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.255962] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                              Apr 20 14:24:11 raspberrypi4 systemd-udevd[152]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.256206] pci 0000:00:00.0: PME# supported from D0 D3hot
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.259734] PCI: bus0: Fast back to back transfers disabled
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.260075] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                              Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: fsck.fat 4.1 (2017-01-24)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.260204] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.260638] pci 0000:01:00.0: PME# supported from D0 D3cold
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.264174] PCI: bus1: Fast back to back transfers disabled
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.264238] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.264262] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.264344] pci 0000:00:00.0: PCI bridge to [bus 01]
                              Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.264370] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.264800] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.265035] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
                              Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]:  Automatically removing dirty bit.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.273628] iproc-rng200 fe104000.rng: hwrng registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.273943] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.274817] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.287194] brd: module loaded
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.299668] loop: module loaded
                              Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: Performing changes.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.301375] Loading iSCSI transport class v2.0-870.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.303870] libphy: Fixed MDIO Bus: probed
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.305567] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.323383] libphy: bcmgenet MII bus: probed
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.403508] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.404703] usbcore: registered new interface driver r8152
                              Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: /dev/mmcblk0p1: 264 files, 97566/516190 clusters
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.404771] usbcore: registered new interface driver lan78xx
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.404832] usbcore: registered new interface driver smsc95xx
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.406470] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started File System Check on /dev/disk/by-partuuid/19d7e1e8-01.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.406637] xhci_hcd 0000:01:00.0: xHCI Host Controller
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.406673] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.410047] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.411381] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.411401] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Mounting /boot...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.411418] usb usb1: Product: xHCI Host Controller
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.411435] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.411451] usb usb1: SerialNumber: 0000:01:00.0
                              Apr 20 14:24:11 raspberrypi4 systemd-udevd[196]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.412211] hub 1-0:1.0: USB hub found
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.412328] hub 1-0:1.0: 1 port detected
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.412999] xhci_hcd 0000:01:00.0: xHCI Host Controller
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.413038] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.413064] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Mounted /boot.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.413633] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.413652] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.413669] usb usb2: Product: xHCI Host Controller
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local File Systems.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.413685] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.413701] usb usb2: SerialNumber: 0000:01:00.0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.414412] hub 2-0:1.0: USB hub found
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.414496] hub 2-0:1.0: 4 ports detected
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.416217] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.416531] dwc_otg: FIQ enabled
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.416546] dwc_otg: NAK holdoff enabled
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.416560] dwc_otg: FIQ split-transaction FSM enabled
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Preprocess NFS configuration...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.416578] Module dwc_common_port init
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.417030] usbcore: registered new interface driver uas
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.417136] usbcore: registered new interface driver usb-storage
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.417332] mousedev: PS/2 mouse device common for all mice
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.419051] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.422586] sdhci: Secure Digital Host Controller Interface driver
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.422602] sdhci: Copyright(c) Pierre Ossman
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.423310] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.424006] sdhci-pltfm: SDHCI platform and OF driver helper
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Set console font and keymap...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.428187] ledtrig-cpu: registered to indicate activity on CPUs
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.428545] hid: raw HID events driver (C) Jiri Kosina
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.428739] usbcore: registered new interface driver usbhid
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.428755] usbhid: USB HID core driver
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.434717] Initializing XFRM netlink socket
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.434760] NET: Registered protocol family 17
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.434888] Key type dns_resolver registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.435341] Registering SWP/SWPB emulation handler
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Raise network interfaces...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.435522] registered taskstats version 1
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.435550] Loading compiled-in X.509 certificates
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.436381] Key type ._fscrypt registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.436398] Key type .fscrypt registered
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create Volatile Files and Directories...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.436413] Key type fscrypt-provisioning registered
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.448070] uart-pl011 fe201000.serial: there is not valid maps for state default
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.448377] uart-pl011 fe201000.serial: cts_event_workaround enabled
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.448469] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: nfs-config.service: Succeeded.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.455276] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.456349] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.456366] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.486695] of_cfs_init
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Preprocess NFS configuration.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.486967] of_cfs_init: OK
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.507463] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.509156] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.510840] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.513978] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.515664] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target NFS client services.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Remote File Systems (Pre).
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Remote File Systems.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Set console font and keymap.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create Volatile Files and Directories.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Network Time Synchronization...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Update UTMP about System Boot/Shutdown.
                              Apr 20 14:24:11 raspberrypi4 systemd-timesyncd[338]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2021-04-20 14:24:08 CEST
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Network Time Synchronization.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target System Time Synchronized.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: plymouth-read-write.service: Succeeded.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target System Initialization.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started CUPS Scheduler.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Paths.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.524316] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.525279] Waiting for root device PARTUUID=19d7e1e8-02...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.556591] random: fast init done
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.560965] mmc0: new high speed SDHC card at address b368
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily rotation of log files.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.561943] mmcblk0: mmc0:b368 NCard 29.1 GiB
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.564164]  mmcblk0: p1 p2
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.586167] mmc1: new high speed SDIO card at address 0001
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily Cleanup of Temporary Directories.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.595504] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.595521] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.773383] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.955972] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.955994] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily apt download activities.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.956011] usb 1-1: Product: USB2.0 Hub
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.958069] hub 1-1:1.0: USB hub found
                              Apr 20 14:24:11 raspberrypi4 kernel: [    1.958360] hub 1-1:1.0: 4 ports detected
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on D-Bus System Message Bus Socket.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.283380] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.423754] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.00
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.423773] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.423792] usb 1-1.1: Product: USB Receiver
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily apt upgrade and clean activities.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.423809] usb 1-1.1: Manufacturer: Logitech
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.436786] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C534.0001/input/input0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.504263] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily man-db regeneration.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.516405] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input1
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.516951] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input2
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.583693] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input3
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.584302] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.683377] usb 1-1.2: new low-speed USB device number 4 using xhci_hcd
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.821311] usb 1-1.2: New USB device found, idVendor=0458, idProduct=0007, bcdDevice= 0.00
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.821332] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Timers.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.821349] usb 1-1.2: Product: Optical Mouse
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.821366] usb 1-1.2: Manufacturer:  KYE
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on CUPS Scheduler.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.830698] input:  KYE   Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0458:0007.0003/input/input6
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.831210] hid-generic 0003:0458:0007.0003: input,hidraw2: USB HID v1.10 Mouse [ KYE   Optical Mouse] on usb-0000:01:00.0-1.2/input0
                              Apr 20 14:24:11 raspberrypi4 kernel: [    2.923377] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
                              Apr 20 14:24:11 raspberrypi4 kernel: [    3.062846] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
                              Apr 20 14:24:11 raspberrypi4 kernel: [    3.062866] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on triggerhappy.socket.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    3.062883] usb 1-1.3: Product: TI CC2531 USB CDC
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    3.062899] usb 1-1.3: Manufacturer: Texas Instruments
                              Apr 20 14:24:11 raspberrypi4 kernel: [    3.062916] usb 1-1.3: SerialNumber: __0X00124B001CD40626
                              Apr 20 14:24:11 raspberrypi4 kernel: [    3.531627] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                              Apr 20 14:24:11 raspberrypi4 kernel: [    3.590223] EXT4-fs (mmcblk0p2): 9 orphan inodes deleted
                              Apr 20 14:24:11 raspberrypi4 kernel: [    3.590242] EXT4-fs (mmcblk0p2): recovery complete
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Sockets.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.879135] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.879224] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.894488] devtmpfs: mounted
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Basic System.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.903459] Freeing unused kernel memory: 2048K
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.903785] Run /sbin/init as init process
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.903799]   with arguments:
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.903814]     /sbin/init
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Regular background program processing daemon.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.903828]     splash
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.903842]   with environment:
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.903857]     HOME=/
                              Apr 20 14:24:11 raspberrypi4 kernel: [    4.903871]     TERM=linux
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
                              Apr 20 14:24:11 raspberrypi4 kernel: [    7.032863] NET: Registered protocol family 10
                              Apr 20 14:24:11 raspberrypi4 kernel: [    7.034356] Segment Routing with IPv6
                              Apr 20 14:24:11 raspberrypi4 kernel: [    8.463450] random: systemd: uninitialized urandom read (16 bytes read)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    8.481708] random: systemd: uninitialized urandom read (16 bytes read)
                              Apr 20 14:24:11 raspberrypi4 kernel: [    8.482962] random: systemd: uninitialized urandom read (16 bytes read)
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting rng-tools.service...
                              Apr 20 14:24:11 raspberrypi4 kernel: [    8.721652] i2c /dev entries driver
                              Apr 20 14:24:11 raspberrypi4 kernel: [    9.554904] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.641713] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.642290] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.642885] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.643750] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.822744] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Configure Bluetooth Modems connected by UART...
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.824501] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.826737] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.826771] [vc_sm_connected_init]: start
                              Apr 20 14:24:11 raspberrypi4 cron[376]: (CRON) INFO (pidfile fd = 3)
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.848273] [vc_sm_connected_init]: installed successfully
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.849805] bcm2835_audio bcm2835_audio: card created with 4 channels
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.853096] bcm2835_audio bcm2835_audio: card created with 4 channels
                              Apr 20 14:24:11 raspberrypi4 cron[376]: (CRON) INFO (Running @reboot jobs)
                              Apr 20 14:24:11 raspberrypi4 kernel: [   10.982850] mc: Linux media interface: v0.10
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.105427] videodev: Linux video capture interface: v2.00
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.427266] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.427273] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.462722] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Manage Sound Card State (restore and store).
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.550425] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.557730] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.584209] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.584751] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.585224] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                              Apr 20 14:24:11 raspberrypi4 alsactl[383]: alsactl 1.1.8 daemon started
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting dhcpcd on all interfaces...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Check for v3d driver...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started D-Bus System Message Bus.
                              Apr 20 14:24:11 raspberrypi4 rng-tools[378]: Starting Hardware RNG entropy gatherer daemon: rngd.
                              Apr 20 14:24:11 raspberrypi4 rngd[398]: rngd 2-unofficial-mt.14 starting up...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting WPA supplicant...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Save/Restore Sound Card State...
                              Apr 20 14:24:11 raspberrypi4 rngd[398]: entropy feed to the kernel ready
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Login Service...
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.585569] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.585601] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.585627] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Disk Manager...
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.585650] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.585672] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting triggerhappy global hotkey daemon...
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.585873] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.632460] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.632488] checking generic (3e6c7000 500000) vs hw (0 ffffffffffffffff)
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.632506] fb0: switching to vc4drmfb from simple
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.633128] Console: switching to colour dummy device 80x30
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting System Logging Service...
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.634949] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.636914] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.636972] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.637019] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.637061] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.637112] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.637157] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.637199] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.637239] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Raise network interfaces.
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started rng-tools.service.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.637280] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Save/Restore Sound Card State.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.665628] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.721157] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.721203] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.734419] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                              Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Sound Card.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.734457] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.741420] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.741459] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.745750] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.856935] Console: switching to colour frame buffer device 160x64
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.880028] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.940829] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.946802] usbcore: registered new interface driver cdc_acm
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.946823] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                              Apr 20 14:24:11 raspberrypi4 kernel: [   11.960247] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                              Apr 20 14:24:11 raspberrypi4 dhcpcd[386]: dev: loaded udev
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.076017] brcmfmac: F1 signature read @0x18000000=0x15264345
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.086842] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.087515] usbcore: registered new interface driver brcmfmac
                              Apr 20 14:24:11 raspberrypi4 thd[412]: Found socket passed from systemd
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.231259] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.286383] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.477063] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.529613] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.716938] logitech-djreceiver 0003:046D:C534.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
                              Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.800235] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
                              Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: Successfully dropped root privileges.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.803626] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input7
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.807717] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input8
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.814168] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input9
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.814657] hid-generic 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:01:00.0-1.1/input1:1
                              Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: avahi-daemon 0.7 starting up.
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.816229] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
                              Apr 20 14:24:11 raspberrypi4 dhcpcd[386]: forked to background, child pid 440
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.818419] input: Logitech Wireless Mouse PID:4038 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4038.0005/input/input14
                              Apr 20 14:24:11 raspberrypi4 kernel: [   12.819041] hid-generic 0003:046D:4038.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4038] on usb-0000:01:00.0-1.1/input1:2
                              Apr 20 14:24:11 raspberrypi4 kernel: [   13.713076] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input18
                              Apr 20 14:24:11 raspberrypi4 rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
                              Apr 20 14:24:11 raspberrypi4 kernel: [   13.714890] logitech-hidpp-device 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:01:00.0-1.1/input1:1
                              Apr 20 14:24:11 raspberrypi4 kernel: [   13.856632] input: Logitech Wireless Mouse PID:4038 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4038.0005/input/input19
                              Apr 20 14:24:11 raspberrypi4 kernel: [   13.857187] logitech-hidpp-device 0003:046D:4038.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4038] on usb-0000:01:00.0-1.1/input1:2
                              Apr 20 14:24:11 raspberrypi4 kernel: [   16.716140] random: crng init done
                              Apr 20 14:24:11 raspberrypi4 rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="413" x-info="https://www.rsyslog.com"] start
                              Apr 20 14:24:11 raspberrypi4 kernel: [   16.716164] random: 7 urandom warning(s) missed due to ratelimiting
                              Apr 20 14:24:11 raspberrypi4 kernel: [   16.737069] uart-pl011 fe201000.serial: no DMA platform data
                              Apr 20 14:24:11 raspberrypi4 kernel: [   18.518351] 8021q: 802.1Q VLAN Support v1.8
                              Apr 20 14:24:11 raspberrypi4 udisksd[411]: udisks daemon version 2.8.1 starting
                              Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 8.2.0 CTV); collect: 128K
                              Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 14768/63488
                              Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 7.99864
                              Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: fills: 0, generated: 0
                              Apr 20 14:24:11 raspberrypi4 dphys-swapfile[410]: want /var/swap=100MByte, checking existing: keeping it
                              Apr 20 14:24:11 raspberrypi4 dhcpcd-run-hooks[488]: wlan0: starting wpa_supplicant
                              Apr 20 14:24:12 raspberrypi4 kernel: [   19.850495] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started triggerhappy global hotkey daemon.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started System Logging Service.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: systemd-rfkill.service: Succeeded.
                              Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Successfully called chroot().
                              Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Successfully dropped remaining capabilities.
                              Apr 20 14:24:12 raspberrypi4 wpa_supplicant[403]: Successfully initialized wpa_supplicant
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started dhcpcd on all interfaces.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Check for v3d driver.
                              Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: No service file found in /etc/avahi/services.
                              Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Network interface enumeration completed.
                              Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Server startup complete. Host name is raspberrypi4.local. Local service cookie is 2766927354.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Login Service.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Avahi mDNS/DNS-SD Stack.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started WPA supplicant.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Make remote CUPS printers available locally.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Reached target Network.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Permit User Sessions...
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started ioBroker Server.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Reached target Network is Online.
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Samba NMB Daemon...
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Daily apt download activities...
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting /etc/rc.local Compatibility...
                              Apr 20 14:24:12 raspberrypi4 systemd[1]: Started VNC Server in Service Mode daemon.
                              Apr 20 14:24:12 raspberrypi4 kernel: [   20.513499] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                              Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting OpenBSD Secure Shell server...
                              Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting MariaDB 10.3.27 database server...
                              Apr 20 14:24:13 raspberrypi4 systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
                              Apr 20 14:24:13 raspberrypi4 systemd[1]: Started Permit User Sessions.
                              Apr 20 14:24:13 raspberrypi4 systemd[1]: Started /etc/rc.local Compatibility.
                              Apr 20 14:24:13 raspberrypi4 udisksd[411]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
                              Apr 20 14:24:13 raspberrypi4 udisksd[411]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
                              Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting Light Display Manager...
                              Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting Hold until boot process finishes up...
                              Apr 20 14:24:13 raspberrypi4 dnsmasq[502]: dnsmasq: Syntaxprüfung OK.
                              Apr 20 14:24:14 raspberrypi4 raspi-config[414]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
                              Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: wlan0: connected to Access Point `'
                              Apr 20 14:24:14 raspberrypi4 systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                              Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: eth0: waiting for carrier
                              Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: wlan0: waiting for carrier
                              Apr 20 14:24:14 raspberrypi4 kernel: [   21.989989] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                              Apr 20 14:24:14 raspberrypi4 kernel: [   21.990254] bcmgenet fd580000.ethernet eth0: Link is Down
                              Apr 20 14:24:14 raspberrypi4 udisksd[411]: Failed to load the 'mdraid' libblockdev plugin
                              Apr 20 14:24:14 raspberrypi4 udisksd[411]: Failed to load the 'crypto' libblockdev plugin
                              Apr 20 14:24:14 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.5' (uid=0 pid=411 comm="/usr/lib/udisks2/udisksd ")
                              Apr 20 14:24:14 raspberrypi4 systemd[1]: Starting Authorization Manager...
                              Apr 20 14:24:14 raspberrypi4 systemd[1]: Started Mosquitto MQTT v3.1/v3.1.1 Broker.
                              Apr 20 14:24:14 raspberrypi4 systemd[1]: Started OpenBSD Secure Shell server.
                              Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: gestartet, Version 2.80, Cachegröße 150
                              Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: DNS-Dienst auf lokale Subnetze eingeschränkt
                              Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: Übersetzungsoptionen: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
                              Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: /etc/hosts gelesen - 5 Adressen
                              Apr 20 14:24:15 raspberrypi4 dnsmasq[556]: keine Server in /run/dnsmasq/resolv.conf gefunden, werde es später neu versuchen
                              Apr 20 14:24:15 raspberrypi4 dnsmasq[557]: Too few arguments.
                              Apr 20 14:24:15 raspberrypi4 systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
                              Apr 20 14:24:15 raspberrypi4 systemd[1]: Reached target Host and Network Name Lookups.
                              Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]: BOOTLOADER: up-to-date
                              Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                              Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:     LATEST: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                              Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
                              Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:             Use raspi-config to change the release.
                              Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:   VL805_FW: Dedicated VL805 EEPROM
                              Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:      VL805: up-to-date
                              Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    CURRENT: 000138a1
                              Apr 20 14:24:16 raspberrypi4 rpi-eeprom-update[385]:     LATEST: 000138a1
                              Apr 20 14:24:16 raspberrypi4 systemd[1]: Started Check for Raspberry Pi EEPROM updates.
                              Apr 20 14:24:18 raspberrypi4 dhcpcd[440]: eth0: carrier acquired
                              Apr 20 14:24:18 raspberrypi4 kernel: [   26.153638] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                              Apr 20 14:24:18 raspberrypi4 kernel: [   26.153698] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                              Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: DUID 00:01:00:01:27:8f:0c:24:dc:a6:32:ba:3c:74
                              Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: IAID 32:ba:3c:74
                              Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: adding address fe80::da0:a631:6da1:f23c
                              Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::da0:a631:6da1:f23c.
                              Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: New relevant interface eth0.IPv6 for mDNS.
                              Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: probing address 192.168.1.203/24
                              Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: Registering new address record for fe80::da0:a631:6da1:f23c on eth0.*.
                              Apr 20 14:24:19 raspberrypi4 lightdm[524]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.629392] Bluetooth: Core ver 2.22
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.629502] NET: Registered protocol family 31
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.629516] Bluetooth: HCI device and connection manager initialized
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.630104] Bluetooth: HCI socket layer initialized
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.630124] Bluetooth: L2CAP socket layer initialized
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.630171] Bluetooth: SCO socket layer initialized
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.869925] Bluetooth: HCI UART driver ver 2.3
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.869946] Bluetooth: HCI UART protocol H4 registered
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.870061] Bluetooth: HCI UART protocol Three-wire (H5) registered
                              Apr 20 14:24:20 raspberrypi4 kernel: [   27.870348] Bluetooth: HCI UART protocol Broadcom registered
                              Apr 20 14:24:20 raspberrypi4 btuart[380]: bcm43xx_init
                              Apr 20 14:24:20 raspberrypi4 btuart[380]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
                              Apr 20 14:24:20 raspberrypi4 btuart[380]: Set Controller UART speed to 3000000 bit/s
                              Apr 20 14:24:20 raspberrypi4 btuart[380]: Device setup complete
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Starting Load/Save RF Kill Switch Status...
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Configure Bluetooth Modems connected by UART.
                              Apr 20 14:24:20 raspberrypi4 polkitd[552]: started daemon version 0.105 using authority implementation `local' version `0.105'
                              Apr 20 14:24:20 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Load/Save RF Kill Switch Status.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: plymouth-start.service: Succeeded.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: plymouth-quit-wait.service: Succeeded.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Hold until boot process finishes up.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Received SIGRTMIN+21 from PID 172 (n/a).
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Authorization Manager.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Light Display Manager.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Getty on tty1.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Reached target Login Prompts.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Created slice system-bthelper.slice.
                              Apr 20 14:24:20 raspberrypi4 systemd[1]: Starting Bluetooth service...
                              Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: soliciting an IPv6 router
                              Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: Router Advertisement from fe80::f2af:85ff:fe8c:99dc
                              Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: adding address 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca/64
                              Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::da0:a631:6da1:f23c.
                              Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv6 with address 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca.
                              Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Registering new address record for 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca on eth0.*.
                              Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: adding route to 2a02:810b:c63f:d98c::/64
                              Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Withdrawing address record for fe80::da0:a631:6da1:f23c on eth0.
                              Apr 20 14:24:20 raspberrypi4 kernel: [   28.477216] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                              Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: confirming prior DHCPv6 lease
                              Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: fe80::f2af:85ff:fe8c:99dc is reachable again
                              Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: adding default route via fe80::f2af:85ff:fe8c:99dc
                              Apr 20 14:24:21 raspberrypi4 systemd[1]: Started Disk Manager.
                              Apr 20 14:24:21 raspberrypi4 udisksd[411]: Acquired the name org.freedesktop.UDisks2 on the system message bus
                              Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: REPLY6 received from fe80::f2af:85ff:fe8c:99dc
                              Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: adding address 2a02:810b:c63f:d98c::d7c2/128
                              Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: renew in 21600, rebind in 34560, expire in 43200 seconds
                              Apr 20 14:24:21 raspberrypi4 avahi-daemon[390]: Registering new address record for 2a02:810b:c63f:d98c::d7c2 on eth0.*.
                              Apr 20 14:24:22 raspberrypi4 bluetoothd[691]: Bluetooth daemon 5.50
                              Apr 20 14:24:22 raspberrypi4 systemd[1]: Started Bluetooth service.
                              Apr 20 14:24:22 raspberrypi4 systemd[1]: Started Raspberry Pi bluetooth helper.
                              Apr 20 14:24:22 raspberrypi4 systemd[1]: Reached target Bluetooth.
                              Apr 20 14:24:22 raspberrypi4 bluetoothd[691]: Starting SDP server
                              Apr 20 14:24:22 raspberrypi4 mysqld[642]: 2021-04-20 14:24:22 0 [Note] /usr/sbin/mysqld (mysqld 10.3.27-MariaDB-0+deb10u1) starting as process 642 ...
                              Apr 20 14:24:22 raspberrypi4 mysqld[642]: 2021-04-20 14:24:22 0 [Warning] Could not increase number of max_open_files to more than 16384 (request: 32186)
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: Raspberry Pi BDADDR already set
                              Apr 20 14:24:23 raspberrypi4 kernel: [   30.787342] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                              Apr 20 14:24:23 raspberrypi4 kernel: [   30.787364] Bluetooth: BNEP filters: protocol multicast
                              Apr 20 14:24:23 raspberrypi4 kernel: [   30.787394] Bluetooth: BNEP socket layer initialized
                              Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Bluetooth management interface 1.18 initialized
                              Apr 20 14:24:23 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.13' (uid=0 pid=691 comm="/usr/lib/bluetooth/bluetoothd ")
                              Apr 20 14:24:23 raspberrypi4 vncserver-x11[536,root]: ServerManager: Server started
                              Apr 20 14:24:23 raspberrypi4 systemd[1]: Starting Hostname Service...
                              Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Sap driver initialization failed.
                              Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: sap-server: Operation not permitted (1)
                              Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Failed to set privacy: Rejected (0x0b)
                              Apr 20 14:24:23 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.hostname1'
                              Apr 20 14:24:23 raspberrypi4 systemd[1]: Started Hostname Service.
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001801-0000-1000-8000-00805f9b34fb
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001800-0000-1000-8000-00805f9b34fb
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 Alias: BlueZ 5.50
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 Pairable: yes
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: Changing power off succeeded
                              Apr 20 14:24:23 raspberrypi4 bthelper[699]: Changing power on succeeded
                              Apr 20 14:24:23 raspberrypi4 systemd[1]: bthelper@hci0.service: Succeeded.
                              Apr 20 14:24:23 raspberrypi4 vncserver-x11[536,root]: ConsoleDisplay: Cannot find a running X server on vt1
                              Apr 20 14:24:24 raspberrypi4 vncserver-x11[536,root]: ConsoleDisplay: Found running X server (pid=681, binary=/usr/lib/xorg/Xorg)
                              Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: using static address 192.168.1.203/24
                              Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: adding route to 192.168.1.0/24
                              Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.203.
                              Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: New relevant interface eth0.IPv4 for mDNS.
                              Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: adding default route via 192.168.1.200
                              Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: Registering new address record for 192.168.1.203 on eth0.IPv4.
                              Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: lese /run/dnsmasq/resolv.conf
                              Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver 192.168.1.200#53
                              Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver 8.8.8.8#53
                              Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver fd51:42f8:caae:d92e::1#53
                              Apr 20 14:24:25 raspberrypi4 systemd[1]: systemd-rfkill.service: Succeeded.
                              Apr 20 14:24:27 raspberrypi4 dhcpcd[440]: eth0: fe80::f2af:85ff:fe8c:99dc is reachable again
                              Apr 20 14:24:29 raspberrypi4 systemd[1]: Started Samba NMB Daemon.
                              Apr 20 14:24:29 raspberrypi4 systemd[1]: Starting Samba SMB Daemon...
                              Apr 20 14:24:29 raspberrypi4 vncserver-x11[536,root]: AgentInitCheck: no response from agent
                              Apr 20 14:24:30 raspberrypi4 systemd[1]: Created slice User Slice of UID 1000.
                              Apr 20 14:24:30 raspberrypi4 systemd[1]: Starting User Runtime Directory /run/user/1000...
                              Apr 20 14:24:30 raspberrypi4 systemd[1]: Started User Runtime Directory /run/user/1000.
                              Apr 20 14:24:30 raspberrypi4 systemd[1]: Starting User Manager for UID 1000...
                              Apr 20 14:24:30 raspberrypi4 systemd[1]: apt-daily.service: Succeeded.
                              Apr 20 14:24:30 raspberrypi4 systemd[1]: Started Daily apt download activities.
                              Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: lese /run/dnsmasq/resolv.conf
                              Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 192.168.1.200#53
                              Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 8.8.8.8#53
                              Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver fd51:42f8:caae:d92e::1#53
                              Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 2a02:810b:c63f:d98c:f2af:85ff:fe8c:99dc#53
                              Apr 20 14:24:32 raspberrypi4 systemd[1]: Started MariaDB 10.3.27 database server.
                              Apr 20 14:24:32 raspberrypi4 /etc/mysql/debian-start[901]: Upgrading MySQL tables if necessary.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on Sound System.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Paths.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Timers.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG network certificate management daemon.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Starting D-Bus User Message Bus Socket.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on D-Bus User Message Bus Socket.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Sockets.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Basic System.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Default.
                              Apr 20 14:24:32 raspberrypi4 systemd[811]: Startup finished in 2.212s.
                              Apr 20 14:24:32 raspberrypi4 systemd[1]: Started User Manager for UID 1000.
                              Apr 20 14:24:32 raspberrypi4 systemd[1]: Started Session 1 of user pi.
                              Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: /usr/bin/mysql_upgrade: the '--basedir' option is always ignored
                              Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: Looking for 'mysql' as: /usr/bin/mysql
                              Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: Looking for 'mysqlcheck' as: /usr/bin/mysqlcheck
                              Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: This installation of MySQL is already upgraded to 10.3.27-MariaDB, use --force if you still need to run mysql_upgrade
                              Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[984]: Checking for insecure root accounts.
                              Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[990]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
                              Apr 20 14:24:35 raspberrypi4 systemd[1]: Started Samba SMB Daemon.
                              Apr 20 14:24:35 raspberrypi4 systemd[1]: Reached target Multi-User System.
                              Apr 20 14:24:35 raspberrypi4 systemd[1]: Reached target Graphical Interface.
                              Apr 20 14:24:35 raspberrypi4 systemd[1]: Starting Update UTMP about System Runlevel Changes...
                              Apr 20 14:24:35 raspberrypi4 systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
                              Apr 20 14:24:35 raspberrypi4 systemd[1]: Started Update UTMP about System Runlevel Changes.
                              Apr 20 14:24:35 raspberrypi4 systemd[1]: Startup finished in 6.594s (kernel) + 36.438s (userspace) = 43.033s.
                              Apr 20 14:24:36 raspberrypi4 vncserver-x11[536,root]: Connections: connected: 192.168.1.24::54365 (TCP)
                              Apr 20 14:24:36 raspberrypi4 vncserver-x11[536,root]: Connections: authenticated: 192.168.1.24::54365 (TCP), as (anonymous) (d permissions)
                              Apr 20 14:24:37 raspberrypi4 kernel: [   44.583156] broken atomic modeset userspace detected, disabling atomic
                              Apr 20 14:24:37 raspberrypi4 systemd[1]: systemd-fsckd.service: Succeeded.
                              Apr 20 14:34:15 raspberrypi4 systemd-timesyncd[338]: Synchronized to time server for the first time [2a02:a00:1009:6202::123]:123 (2.debian.pool.ntp.org).
                              Apr 20 14:34:15 raspberrypi4 lightdm[1064]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                              Apr 20 14:34:15 raspberrypi4 systemd[1]: Started Session 3 of user pi.
                              Apr 20 14:34:15 raspberrypi4 bash[504]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                              Apr 20 14:34:15 raspberrypi4 bash[504]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                              Apr 20 14:34:16 raspberrypi4 bash[504]: object system.meta.uuid created: f2bf0859-fa5f-19ae-5629-68c17843bcf5
                              Apr 20 14:34:16 raspberrypi4 bash[504]: object system.user.admin created
                              Apr 20 14:34:16 raspberrypi4 systemd[811]: Started D-Bus User Message Bus.
                              Apr 20 14:34:29 raspberrypi4 systemd[1]: systemd-hostnamed.service: Succeeded.
                              Apr 20 14:34:30 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=1000 pid=1083 comm="/usr/bin/lxsession -s LXDE-pi -e LXDE ")
                              Apr 20 14:34:30 raspberrypi4 systemd[811]: Starting Virtual filesystem service...
                              Apr 20 14:34:30 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.Daemon'
                              Apr 20 14:34:30 raspberrypi4 systemd[811]: Started Virtual filesystem service.
                              Apr 20 14:34:30 raspberrypi4 kernel: [   62.126481] fuse: init (API version 7.32)
                              Apr 20 14:34:31 raspberrypi4 systemd[1]: Mounting FUSE Control File System...
                              Apr 20 14:34:31 raspberrypi4 systemd[1]: Mounted FUSE Control File System.
                              Apr 20 14:34:31 raspberrypi4 systemd[811]: Starting Sound Service...
                              Apr 20 14:34:32 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.29' (uid=1000 pid=1238 comm="/usr/bin/pulseaudio --daemonize=no ")
                              Apr 20 14:34:32 raspberrypi4 systemd[1]: Starting RealtimeKit Scheduling Policy Service...
                              Apr 20 14:34:32 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
                              Apr 20 14:34:32 raspberrypi4 systemd[1]: Started RealtimeKit Scheduling Policy Service.
                              Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully called chroot.
                              Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully dropped privileges.
                              Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully limited resources.
                              Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Running.
                              Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Canary thread running.
                              Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Watchdog thread running.
                              Apr 20 14:34:33 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                              Apr 20 14:34:33 raspberrypi4 systemd[811]: Starting Virtual filesystem service - disk device monitor...
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - disk device monitor.
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - Media Transfer Protocol monitor.
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                              Apr 20 14:34:34 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1238 of process 1238 (n/a) owned by '1000' high priority at nice level -11.
                              Apr 20 14:34:34 raspberrypi4 rtkit-daemon[1253]: Supervising 1 threads of 1 processes of 1 users.
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - digital camera monitor...
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - digital camera monitor.
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - GNOME Online Accounts monitor.
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - Apple File Conduit monitor...
                              Apr 20 14:34:34 raspberrypi4 gvfs-afc-volume-monitor[1295]: Volume monitor alive
                              Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
                              Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - Apple File Conduit monitor.
                              Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 1 threads of 1 processes of 1 users.
                              Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1302 of process 1238 (n/a) owned by '1000' RT at priority 5.
                              Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 2 threads of 1 processes of 1 users.
                              Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1303 of process 1238 (n/a) owned by '1000' RT at priority 5.
                              Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 3 threads of 1 processes of 1 users.
                              Apr 20 14:34:35 raspberrypi4 systemd[811]: Started Sound Service.
                              Apr 20 14:34:35 raspberrypi4 bluetoothd[691]: Endpoint registered: sender=:1.34 path=/MediaEndpoint/A2DPSource
                              Apr 20 14:34:35 raspberrypi4 bluetoothd[691]: Endpoint registered: sender=:1.34 path=/MediaEndpoint/A2DPSink
                              Apr 20 14:34:35 raspberrypi4 pulseaudio[1238]: E: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
                              Apr 20 14:34:35 raspberrypi4 kernel: [   66.990077] Bluetooth: RFCOMM TTY layer initialized
                              Apr 20 14:34:35 raspberrypi4 kernel: [   66.990099] Bluetooth: RFCOMM socket layer initialized
                              Apr 20 14:34:35 raspberrypi4 kernel: [   66.990120] Bluetooth: RFCOMM ver 1.11
                              und hier das Ende vom IOBroker log:
                              2021-04-20 14:28:55.984  - error: javascript.0 (14256) function(DeviceName(s, x)){ // mit Punkt am Ende
                              2021-04-20 14:28:55.985  - error: javascript.0 (14256) ^^^^^^^^
                              2021-04-20 14:28:55.985  - error: javascript.0 (14256) SyntaxError: Function statements require a function name
                              2021-04-20 14:28:55.985  - error: javascript.0 (14256)     at new Script (vm.js:88:7)
                              2021-04-20 14:28:55.985  - error: javascript.0 (14256)     at Object.createScript (vm.js:261:10)
                              2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
                              2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
                              2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
                              2021-04-20 14:28:55.987  - error: javascript.0 (14256)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17)
                              2021-04-20 14:28:55.987  - error: javascript.0 (14256)     at processImmediate (internal/timers.js:463:21)
                              2021-04-20 14:29:01.400  - error: javascript.0 (14256) script.js.Test: test
                              2021-04-20 14:29:29.817  - info: javascript.0 (14256) Stop script script.js.Sensoren.ShellyErfassen
                              2021-04-20 14:29:29.839  - info: javascript.0 (14256) Start javascript script.js.Sensoren.ShellyErfassen
                              2021-04-20 14:30:00.052  - info: host.raspberrypi4 instance system.adapter.daswetter.0 started with pid 4110
                              2021-04-20 14:30:01.917  - info: daswetter.0 (4110) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.21.0, js-controller: 3.2.16
                              2021-04-20 14:30:14.329  - info: daswetter.0 (4110) Terminated (NO_ERROR): Without reason
                              2021-04-20 14:30:14.854  - info: daswetter.0 (4110) cleaned everything up...
                              2021-04-20 14:30:14.869  - info: host.raspberrypi4 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-04-20 14:24:38.869  - info: host.raspberrypi4 iobroker.js-controller version 3.2.16 js-controller starting
                              2021-04-20 14:24:38.874  - info: host.raspberrypi4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                              2021-04-20 14:24:38.875  - info: host.raspberrypi4 hostname: raspberrypi4, node: v12.21.0
                              2021-04-20 14:24:38.876  - info: host.raspberrypi4 ip addresses: 192.168.1.203 2a02:810b:c63f:d98c::d7c2 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca fe80::da0:a631:6da1:f23c
                              2021-04-20 14:24:38.941  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
                              2021-04-20 14:24:38.943  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected end of JSON input. Continue with empty dataset!
                              2021-04-20 14:24:39.020  - error: host.raspberrypi4 Cannot read system.config: null (OK when migrating or restoring)
                              2021-04-20 14:24:39.029  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                              2021-04-20 14:34:15.578  - info: host.raspberrypi4 connected to Objects and States
                              2021-04-20 14:34:15.727  - warn: host.raspberrypi4 logger system.adapter.admin.0.logging was deleted
                              2021-04-20 14:34:15.728  - warn: host.raspberrypi4 logger system.adapter.javascript.0.logging was deleted
                              2021-04-20 14:34:15.773  - info: host.raspberrypi4 added notifications configuration of host
                              2021-04-20 14:34:15.780  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
                              2021-04-20 14:34:15.781  - error: host.raspberrypi4 Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                              2021-04-20 14:34:15.796  - info: host.raspberrypi4 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                              2021-04-20 14:34:15.803  - error: host.raspberrypi4 Cannot find view "system" for search "host"
                              2021-04-20 14:34:15.812  - error: host.raspberrypi4 Cannot find view "system" for search "state"
                              2021-04-20 14:34:15.813  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
                              2021-04-20 14:34:15.815  - error: host.raspberrypi4 Could not collect system.host.raspberrypi4 states to check for obsolete states: Error: Cannot find view "system"
                              2021-04-20 14:34:15.816  - error: host.raspberrypi4 _design/system missing - call node iobroker.js setup
                              2021-04-20 14:34:16.643  - info: host.raspberrypi4 Created UUID: f2bf0859-fa5f-19ae-5629-68c17843bcf5
                              und
                              pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ free -h
                              Mem:          3,7Gi       244Mi       3,1Gi        48Mi       404Mi       3,3Gi
                              Swap:          99Mi          0B        99Mi
                              pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ who -r
                                       Runlevel 5   2021-04-20 14:24
                              Gruß Wolfgang
                              #88
                              @wolfgangfb sagte in Mini-HowTo: Cannot find view "system" for search "host":
                              Was kommt denn im Syslog DAVOR? Du hst mit dem Syslog genau mit dem Reboot gestartet ... Alao ja...das dicng hat rebootet "aus dem Nichts". Warum könnte man höchstens im sysLog vorher sehen
                              • W WolfgangFB
                                @apollon77 So, gerade wieder, diesmal nichts neu gestartet sondern gleich die Logs gesichert.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=DC:A6:32:BA:3C:74 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=19d7e1e8-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Set the console keyboard layout.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Please use sysfs to set IO scheduler for individual devices.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started udev Coldplug all Devices.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Memory: 3654936K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133864K reserved, 262144K cma-reserved, 3264512K highmem)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] ftrace: allocating 33942 entries in 67 pages
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] ftrace: allocated 67 pages with 3 groups
                                Apr 20 14:24:11 raspberrypi4 systemd-fsck[134]: rootfs: clean, 198103/1859088 files, 1454653/7566848 blocks
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] rcu: Hierarchical RCU implementation.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] 	Rude variant of Tasks RCU enabled.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] 	Tracing variant of Tasks RCU enabled.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started File System Check on Root Device.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000026] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Remount Root and Kernel File Systems...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000088] bcm2835: system timer (irq = 25)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000742] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000761] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000780] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.000795] Switching to timer-based delay loop, resolution 18ns
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Helper to synchronize boot up for ifupdown.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.001050] Console: colour dummy device 80x30
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.001117] printk: console [tty1] enabled
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.001171] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.001204] pid_max: default: 32768 minimum: 301
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.001375] LSM: Security Framework initializing
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.001565] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.001591] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.003164] Disabling memory control group subsystem
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Remount Root and Kernel File Systems.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.003285] CPU: Testing write buffer coherency: ok
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.003755] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create System Users...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.004973] Setting up static identity map for 0x200000 - 0x20003c
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.005172] rcu: Hierarchical SRCU implementation.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.006106] smp: Bringing up secondary CPUs ...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.007344] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.008746] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.010062] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Load/Save Random Seed...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.010240] smp: Brought up 1 node, 4 CPUs
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.010261] SMP: Total of 4 processors activated (432.00 BogoMIPS).
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.010276] CPU: All CPU(s) started in HYP mode.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Flush Journal to Persistent Storage...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.010290] CPU: Virtualization extensions available.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.011228] devtmpfs: initialized
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.025476] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.025712] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.025744] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.032843] pinctrl core: initialized pinctrl subsystem
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.033944] NET: Registered protocol family 16
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.038118] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Load/Save Random Seed.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.038898] audit: initializing netlink subsys (disabled)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.039160] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.039747] thermal_sys: Registered thermal governor 'step_wise'
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.040550] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.040568] hw-breakpoint: maximum watchpoint size is 8 bytes.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.041004] Serial: AMBA PL011 UART driver
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Flush Journal to Persistent Storage.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.073158] bcm2835-mbox fe00b880.mailbox: mailbox enabled
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create System Users.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.090895] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.100907] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.145645] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.149841] vgaarb: loaded
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.150279] SCSI subsystem initialized
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.150509] usbcore: registered new interface driver usbfs
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.150570] usbcore: registered new interface driver hub
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create Static Device Nodes in /dev...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.150646] usbcore: registered new device driver usb
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.151344] usb_phy_generic phy: supply vcc not found, using dummy regulator
                                Apr 20 14:24:11 raspberrypi4 kernel: [    0.153338] clocksource: Switched to clocksource arch_sys_counter
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.152426] VFS: Disk quotas dquot_6.6.0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.152528] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.152706] FS-Cache: Loaded
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create Static Device Nodes in /dev.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.152906] CacheFiles: Loaded
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.153980] simple-framebuffer 3e6c7000.framebuffer: framebuffer at 0x3e6c7000, 0x500000 bytes, mapped to 0x(ptrval)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting udev Kernel Device Manager...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.154001] simple-framebuffer 3e6c7000.framebuffer: format=a8r8g8b8, mode=1280x1024x32, linelength=5120
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.154476] Console: switching to colour frame buffer device 160x64
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local File Systems (Pre).
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started udev Kernel Device Manager.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Show Plymouth Boot Screen...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Received SIGRTMIN+20 from PID 172 (plymouthd).
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Show Plymouth Boot Screen.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local Encrypted Volumes.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
                                Apr 20 14:24:11 raspberrypi4 systemd-udevd[168]: Using default interface naming scheme 'v240'.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Found device /dev/serial1.
                                Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 5: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
                                Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 4: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2"
                                Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 4 was not an MTP device
                                Apr 20 14:24:11 raspberrypi4 mtp-probe: checking bus 1, device 3: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
                                Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 3 was not an MTP device
                                Apr 20 14:24:11 raspberrypi4 mtp-probe: bus: 1, device: 5 was not an MTP device
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Found device /dev/disk/by-partuuid/19d7e1e8-01.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Huge Pages File System being skipped.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting File System Check on /dev/disk/by-partuuid/19d7e1e8-01...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.171948] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.171993] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.172148] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.172220] TCP: Hash tables configured (established 8192 bind 8192)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in FUSE Control File System being skipped.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.172386] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.172423] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.172688] NET: Registered protocol family 1
                                Apr 20 14:24:11 raspberrypi4 systemd-udevd[163]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.173461] RPC: Registered named UNIX socket transport module.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.173477] RPC: Registered udp transport module.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.173492] RPC: Registered tcp transport module.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.173507] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.173531] PCI: CLS 0 bytes, default 64
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Load/Save RF Kill Switch Status...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.176598] Initialise system trusted keyrings
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.176847] workingset: timestamp_bits=14 max_order=20 bucket_order=6
                                Apr 20 14:24:11 raspberrypi4 systemd-udevd[189]: Using default interface naming scheme 'v240'.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.185544] zbud: loaded
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.187463] FS-Cache: Netfs 'nfs' registered for caching
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.188227] NFS: Registering the id_resolver key type
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.188260] Key type id_resolver registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.188275] Key type id_legacy registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.188414] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Load/Save RF Kill Switch Status.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.189464] Key type asymmetric registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.189481] Asymmetric key parser 'x509' registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.189673] bounce: pool size: 64 pages
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.189720] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.189946] io scheduler mq-deadline registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.189963] io scheduler kyber registered
                                Apr 20 14:24:11 raspberrypi4 systemd-udevd[160]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.194565] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.194596] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.194676] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.194764] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.255446] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.255832] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.255852] pci_bus 0000:00: root bus resource [bus 00-ff]
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.255873] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.255962] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                                Apr 20 14:24:11 raspberrypi4 systemd-udevd[152]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.256206] pci 0000:00:00.0: PME# supported from D0 D3hot
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.259734] PCI: bus0: Fast back to back transfers disabled
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.260075] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                                Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: fsck.fat 4.1 (2017-01-24)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.260204] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.260638] pci 0000:01:00.0: PME# supported from D0 D3cold
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.264174] PCI: bus1: Fast back to back transfers disabled
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.264238] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.264262] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.264344] pci 0000:00:00.0: PCI bridge to [bus 01]
                                Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.264370] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.264800] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.265035] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
                                Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]:  Automatically removing dirty bit.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.273628] iproc-rng200 fe104000.rng: hwrng registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.273943] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.274817] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.287194] brd: module loaded
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.299668] loop: module loaded
                                Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: Performing changes.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.301375] Loading iSCSI transport class v2.0-870.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.303870] libphy: Fixed MDIO Bus: probed
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.305567] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.323383] libphy: bcmgenet MII bus: probed
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.403508] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.404703] usbcore: registered new interface driver r8152
                                Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: /dev/mmcblk0p1: 264 files, 97566/516190 clusters
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.404771] usbcore: registered new interface driver lan78xx
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.404832] usbcore: registered new interface driver smsc95xx
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.406470] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started File System Check on /dev/disk/by-partuuid/19d7e1e8-01.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.406637] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.406673] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.410047] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.411381] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.411401] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Mounting /boot...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.411418] usb usb1: Product: xHCI Host Controller
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.411435] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.411451] usb usb1: SerialNumber: 0000:01:00.0
                                Apr 20 14:24:11 raspberrypi4 systemd-udevd[196]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.412211] hub 1-0:1.0: USB hub found
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.412328] hub 1-0:1.0: 1 port detected
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.412999] xhci_hcd 0000:01:00.0: xHCI Host Controller
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.413038] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.413064] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Mounted /boot.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.413633] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.413652] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.413669] usb usb2: Product: xHCI Host Controller
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Local File Systems.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.413685] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.413701] usb usb2: SerialNumber: 0000:01:00.0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.414412] hub 2-0:1.0: USB hub found
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.414496] hub 2-0:1.0: 4 ports detected
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.416217] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.416531] dwc_otg: FIQ enabled
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.416546] dwc_otg: NAK holdoff enabled
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.416560] dwc_otg: FIQ split-transaction FSM enabled
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Preprocess NFS configuration...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.416578] Module dwc_common_port init
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.417030] usbcore: registered new interface driver uas
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.417136] usbcore: registered new interface driver usb-storage
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.417332] mousedev: PS/2 mouse device common for all mice
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.419051] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.422586] sdhci: Secure Digital Host Controller Interface driver
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.422602] sdhci: Copyright(c) Pierre Ossman
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.423310] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.424006] sdhci-pltfm: SDHCI platform and OF driver helper
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Set console font and keymap...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.428187] ledtrig-cpu: registered to indicate activity on CPUs
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.428545] hid: raw HID events driver (C) Jiri Kosina
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.428739] usbcore: registered new interface driver usbhid
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.428755] usbhid: USB HID core driver
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.434717] Initializing XFRM netlink socket
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.434760] NET: Registered protocol family 17
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.434888] Key type dns_resolver registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.435341] Registering SWP/SWPB emulation handler
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Raise network interfaces...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.435522] registered taskstats version 1
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.435550] Loading compiled-in X.509 certificates
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.436381] Key type ._fscrypt registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.436398] Key type .fscrypt registered
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Create Volatile Files and Directories...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.436413] Key type fscrypt-provisioning registered
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.448070] uart-pl011 fe201000.serial: there is not valid maps for state default
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.448377] uart-pl011 fe201000.serial: cts_event_workaround enabled
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.448469] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: nfs-config.service: Succeeded.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.455276] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.456349] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.456366] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.486695] of_cfs_init
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Preprocess NFS configuration.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.486967] of_cfs_init: OK
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.507463] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.509156] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.510840] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.513978] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.515664] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target NFS client services.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Remote File Systems (Pre).
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Remote File Systems.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Set console font and keymap.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Create Volatile Files and Directories.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Network Time Synchronization...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Update UTMP about System Boot/Shutdown.
                                Apr 20 14:24:11 raspberrypi4 systemd-timesyncd[338]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2021-04-20 14:24:08 CEST
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Network Time Synchronization.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target System Time Synchronized.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: plymouth-read-write.service: Succeeded.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target System Initialization.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started CUPS Scheduler.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Paths.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.524316] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.525279] Waiting for root device PARTUUID=19d7e1e8-02...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.556591] random: fast init done
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.560965] mmc0: new high speed SDHC card at address b368
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily rotation of log files.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.561943] mmcblk0: mmc0:b368 NCard 29.1 GiB
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.564164]  mmcblk0: p1 p2
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.586167] mmc1: new high speed SDIO card at address 0001
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily Cleanup of Temporary Directories.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.595504] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.595521] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.773383] usb 1-1: new high-speed USB device number 2 using xhci_hcd
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.955972] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.955994] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily apt download activities.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.956011] usb 1-1: Product: USB2.0 Hub
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.958069] hub 1-1:1.0: USB hub found
                                Apr 20 14:24:11 raspberrypi4 kernel: [    1.958360] hub 1-1:1.0: 4 ports detected
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on D-Bus System Message Bus Socket.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.283380] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.423754] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.00
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.423773] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.423792] usb 1-1.1: Product: USB Receiver
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily apt upgrade and clean activities.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.423809] usb 1-1.1: Manufacturer: Logitech
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.436786] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C534.0001/input/input0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.504263] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Daily man-db regeneration.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.516405] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input1
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.516951] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input2
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.583693] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input3
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.584302] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.683377] usb 1-1.2: new low-speed USB device number 4 using xhci_hcd
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.821311] usb 1-1.2: New USB device found, idVendor=0458, idProduct=0007, bcdDevice= 0.00
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.821332] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Timers.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.821349] usb 1-1.2: Product: Optical Mouse
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.821366] usb 1-1.2: Manufacturer:  KYE
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on CUPS Scheduler.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.830698] input:  KYE   Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0458:0007.0003/input/input6
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.831210] hid-generic 0003:0458:0007.0003: input,hidraw2: USB HID v1.10 Mouse [ KYE   Optical Mouse] on usb-0000:01:00.0-1.2/input0
                                Apr 20 14:24:11 raspberrypi4 kernel: [    2.923377] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
                                Apr 20 14:24:11 raspberrypi4 kernel: [    3.062846] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
                                Apr 20 14:24:11 raspberrypi4 kernel: [    3.062866] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on triggerhappy.socket.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    3.062883] usb 1-1.3: Product: TI CC2531 USB CDC
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    3.062899] usb 1-1.3: Manufacturer: Texas Instruments
                                Apr 20 14:24:11 raspberrypi4 kernel: [    3.062916] usb 1-1.3: SerialNumber: __0X00124B001CD40626
                                Apr 20 14:24:11 raspberrypi4 kernel: [    3.531627] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                                Apr 20 14:24:11 raspberrypi4 kernel: [    3.590223] EXT4-fs (mmcblk0p2): 9 orphan inodes deleted
                                Apr 20 14:24:11 raspberrypi4 kernel: [    3.590242] EXT4-fs (mmcblk0p2): recovery complete
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Sockets.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.879135] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.879224] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.894488] devtmpfs: mounted
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Basic System.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.903459] Freeing unused kernel memory: 2048K
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.903785] Run /sbin/init as init process
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.903799]   with arguments:
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.903814]     /sbin/init
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Regular background program processing daemon.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.903828]     splash
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.903842]   with environment:
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.903857]     HOME=/
                                Apr 20 14:24:11 raspberrypi4 kernel: [    4.903871]     TERM=linux
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
                                Apr 20 14:24:11 raspberrypi4 kernel: [    7.032863] NET: Registered protocol family 10
                                Apr 20 14:24:11 raspberrypi4 kernel: [    7.034356] Segment Routing with IPv6
                                Apr 20 14:24:11 raspberrypi4 kernel: [    8.463450] random: systemd: uninitialized urandom read (16 bytes read)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    8.481708] random: systemd: uninitialized urandom read (16 bytes read)
                                Apr 20 14:24:11 raspberrypi4 kernel: [    8.482962] random: systemd: uninitialized urandom read (16 bytes read)
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting rng-tools.service...
                                Apr 20 14:24:11 raspberrypi4 kernel: [    8.721652] i2c /dev entries driver
                                Apr 20 14:24:11 raspberrypi4 kernel: [    9.554904] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.641713] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.642290] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.642885] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.643750] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.822744] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Configure Bluetooth Modems connected by UART...
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.824501] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.826737] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.826771] [vc_sm_connected_init]: start
                                Apr 20 14:24:11 raspberrypi4 cron[376]: (CRON) INFO (pidfile fd = 3)
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.848273] [vc_sm_connected_init]: installed successfully
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.849805] bcm2835_audio bcm2835_audio: card created with 4 channels
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.853096] bcm2835_audio bcm2835_audio: card created with 4 channels
                                Apr 20 14:24:11 raspberrypi4 cron[376]: (CRON) INFO (Running @reboot jobs)
                                Apr 20 14:24:11 raspberrypi4 kernel: [   10.982850] mc: Linux media interface: v0.10
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.105427] videodev: Linux video capture interface: v2.00
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.427266] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.427273] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.462722] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Manage Sound Card State (restore and store).
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.550425] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.557730] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.584209] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.584751] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.585224] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                Apr 20 14:24:11 raspberrypi4 alsactl[383]: alsactl 1.1.8 daemon started
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting dhcpcd on all interfaces...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Check for v3d driver...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started D-Bus System Message Bus.
                                Apr 20 14:24:11 raspberrypi4 rng-tools[378]: Starting Hardware RNG entropy gatherer daemon: rngd.
                                Apr 20 14:24:11 raspberrypi4 rngd[398]: rngd 2-unofficial-mt.14 starting up...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting WPA supplicant...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Save/Restore Sound Card State...
                                Apr 20 14:24:11 raspberrypi4 rngd[398]: entropy feed to the kernel ready
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Login Service...
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.585569] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.585601] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.585627] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting Disk Manager...
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.585650] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.585672] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting triggerhappy global hotkey daemon...
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.585873] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.632460] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.632488] checking generic (3e6c7000 500000) vs hw (0 ffffffffffffffff)
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.632506] fb0: switching to vc4drmfb from simple
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.633128] Console: switching to colour dummy device 80x30
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting System Logging Service...
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.634949] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.636914] vc4-drm gpu: [drm] HDMI-A-1: EDID is invalid:
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.636972] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.637019] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.637061] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.637112] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.637157] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.637199] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.637239] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Raise network interfaces.
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started rng-tools.service.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.637280] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Started Save/Restore Sound Card State.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.665628] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.721157] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.721203] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.734419] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                Apr 20 14:24:11 raspberrypi4 systemd[1]: Reached target Sound Card.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.734457] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.741420] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.741459] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.745750] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.856935] Console: switching to colour frame buffer device 160x64
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.880028] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.940829] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.946802] usbcore: registered new interface driver cdc_acm
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.946823] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
                                Apr 20 14:24:11 raspberrypi4 kernel: [   11.960247] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                Apr 20 14:24:11 raspberrypi4 dhcpcd[386]: dev: loaded udev
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.076017] brcmfmac: F1 signature read @0x18000000=0x15264345
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.086842] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.087515] usbcore: registered new interface driver brcmfmac
                                Apr 20 14:24:11 raspberrypi4 thd[412]: Found socket passed from systemd
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.231259] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.286383] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.477063] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.529613] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.716938] logitech-djreceiver 0003:046D:C534.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
                                Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.800235] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 1
                                Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: Successfully dropped root privileges.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.803626] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input7
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.807717] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input8
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.814168] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input9
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.814657] hid-generic 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:01:00.0-1.1/input1:1
                                Apr 20 14:24:11 raspberrypi4 avahi-daemon[390]: avahi-daemon 0.7 starting up.
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.816229] logitech-djreceiver 0003:046D:C534.0002: device of type eQUAD nano Lite (0x0a) connected on slot 2
                                Apr 20 14:24:11 raspberrypi4 dhcpcd[386]: forked to background, child pid 440
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.818419] input: Logitech Wireless Mouse PID:4038 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4038.0005/input/input14
                                Apr 20 14:24:11 raspberrypi4 kernel: [   12.819041] hid-generic 0003:046D:4038.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4038] on usb-0000:01:00.0-1.1/input1:2
                                Apr 20 14:24:11 raspberrypi4 kernel: [   13.713076] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4023.0004/input/input18
                                Apr 20 14:24:11 raspberrypi4 rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
                                Apr 20 14:24:11 raspberrypi4 kernel: [   13.714890] logitech-hidpp-device 0003:046D:4023.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-0000:01:00.0-1.1/input1:1
                                Apr 20 14:24:11 raspberrypi4 kernel: [   13.856632] input: Logitech Wireless Mouse PID:4038 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/0003:046D:4038.0005/input/input19
                                Apr 20 14:24:11 raspberrypi4 kernel: [   13.857187] logitech-hidpp-device 0003:046D:4038.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4038] on usb-0000:01:00.0-1.1/input1:2
                                Apr 20 14:24:11 raspberrypi4 kernel: [   16.716140] random: crng init done
                                Apr 20 14:24:11 raspberrypi4 rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="413" x-info="https://www.rsyslog.com"] start
                                Apr 20 14:24:11 raspberrypi4 kernel: [   16.716164] random: 7 urandom warning(s) missed due to ratelimiting
                                Apr 20 14:24:11 raspberrypi4 kernel: [   16.737069] uart-pl011 fe201000.serial: no DMA platform data
                                Apr 20 14:24:11 raspberrypi4 kernel: [   18.518351] 8021q: 802.1Q VLAN Support v1.8
                                Apr 20 14:24:11 raspberrypi4 udisksd[411]: udisks daemon version 2.8.1 starting
                                Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 8.2.0 CTV); collect: 128K
                                Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 14768/63488
                                Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 7.99864
                                Apr 20 14:24:11 raspberrypi4 haveged[341]: haveged: fills: 0, generated: 0
                                Apr 20 14:24:11 raspberrypi4 dphys-swapfile[410]: want /var/swap=100MByte, checking existing: keeping it
                                Apr 20 14:24:11 raspberrypi4 dhcpcd-run-hooks[488]: wlan0: starting wpa_supplicant
                                Apr 20 14:24:12 raspberrypi4 kernel: [   19.850495] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started triggerhappy global hotkey daemon.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started System Logging Service.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: systemd-rfkill.service: Succeeded.
                                Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Successfully called chroot().
                                Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Successfully dropped remaining capabilities.
                                Apr 20 14:24:12 raspberrypi4 wpa_supplicant[403]: Successfully initialized wpa_supplicant
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started dhcpcd on all interfaces.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Check for v3d driver.
                                Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: No service file found in /etc/avahi/services.
                                Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Network interface enumeration completed.
                                Apr 20 14:24:12 raspberrypi4 avahi-daemon[390]: Server startup complete. Host name is raspberrypi4.local. Local service cookie is 2766927354.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Login Service.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Avahi mDNS/DNS-SD Stack.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started WPA supplicant.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started Make remote CUPS printers available locally.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Reached target Network.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Permit User Sessions...
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started ioBroker Server.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Reached target Network is Online.
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Samba NMB Daemon...
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting Daily apt download activities...
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Starting /etc/rc.local Compatibility...
                                Apr 20 14:24:12 raspberrypi4 systemd[1]: Started VNC Server in Service Mode daemon.
                                Apr 20 14:24:12 raspberrypi4 kernel: [   20.513499] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
                                Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting OpenBSD Secure Shell server...
                                Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting MariaDB 10.3.27 database server...
                                Apr 20 14:24:13 raspberrypi4 systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
                                Apr 20 14:24:13 raspberrypi4 systemd[1]: Started Permit User Sessions.
                                Apr 20 14:24:13 raspberrypi4 systemd[1]: Started /etc/rc.local Compatibility.
                                Apr 20 14:24:13 raspberrypi4 udisksd[411]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
                                Apr 20 14:24:13 raspberrypi4 udisksd[411]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
                                Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting Light Display Manager...
                                Apr 20 14:24:13 raspberrypi4 systemd[1]: Starting Hold until boot process finishes up...
                                Apr 20 14:24:13 raspberrypi4 dnsmasq[502]: dnsmasq: Syntaxprüfung OK.
                                Apr 20 14:24:14 raspberrypi4 raspi-config[414]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
                                Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: wlan0: connected to Access Point `'
                                Apr 20 14:24:14 raspberrypi4 systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                                Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: eth0: waiting for carrier
                                Apr 20 14:24:14 raspberrypi4 dhcpcd[440]: wlan0: waiting for carrier
                                Apr 20 14:24:14 raspberrypi4 kernel: [   21.989989] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                                Apr 20 14:24:14 raspberrypi4 kernel: [   21.990254] bcmgenet fd580000.ethernet eth0: Link is Down
                                Apr 20 14:24:14 raspberrypi4 udisksd[411]: Failed to load the 'mdraid' libblockdev plugin
                                Apr 20 14:24:14 raspberrypi4 udisksd[411]: Failed to load the 'crypto' libblockdev plugin
                                Apr 20 14:24:14 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.5' (uid=0 pid=411 comm="/usr/lib/udisks2/udisksd ")
                                Apr 20 14:24:14 raspberrypi4 systemd[1]: Starting Authorization Manager...
                                Apr 20 14:24:14 raspberrypi4 systemd[1]: Started Mosquitto MQTT v3.1/v3.1.1 Broker.
                                Apr 20 14:24:14 raspberrypi4 systemd[1]: Started OpenBSD Secure Shell server.
                                Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: gestartet, Version 2.80, Cachegröße 150
                                Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: DNS-Dienst auf lokale Subnetze eingeschränkt
                                Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: Übersetzungsoptionen: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
                                Apr 20 14:24:14 raspberrypi4 dnsmasq[556]: /etc/hosts gelesen - 5 Adressen
                                Apr 20 14:24:15 raspberrypi4 dnsmasq[556]: keine Server in /run/dnsmasq/resolv.conf gefunden, werde es später neu versuchen
                                Apr 20 14:24:15 raspberrypi4 dnsmasq[557]: Too few arguments.
                                Apr 20 14:24:15 raspberrypi4 systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
                                Apr 20 14:24:15 raspberrypi4 systemd[1]: Reached target Host and Network Name Lookups.
                                Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]: BOOTLOADER: up-to-date
                                Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                                Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:     LATEST: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
                                Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
                                Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:             Use raspi-config to change the release.
                                Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:   VL805_FW: Dedicated VL805 EEPROM
                                Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:      VL805: up-to-date
                                Apr 20 14:24:15 raspberrypi4 rpi-eeprom-update[385]:    CURRENT: 000138a1
                                Apr 20 14:24:16 raspberrypi4 rpi-eeprom-update[385]:     LATEST: 000138a1
                                Apr 20 14:24:16 raspberrypi4 systemd[1]: Started Check for Raspberry Pi EEPROM updates.
                                Apr 20 14:24:18 raspberrypi4 dhcpcd[440]: eth0: carrier acquired
                                Apr 20 14:24:18 raspberrypi4 kernel: [   26.153638] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                Apr 20 14:24:18 raspberrypi4 kernel: [   26.153698] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: DUID 00:01:00:01:27:8f:0c:24:dc:a6:32:ba:3c:74
                                Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: IAID 32:ba:3c:74
                                Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: adding address fe80::da0:a631:6da1:f23c
                                Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::da0:a631:6da1:f23c.
                                Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: New relevant interface eth0.IPv6 for mDNS.
                                Apr 20 14:24:19 raspberrypi4 dhcpcd[440]: eth0: probing address 192.168.1.203/24
                                Apr 20 14:24:19 raspberrypi4 avahi-daemon[390]: Registering new address record for fe80::da0:a631:6da1:f23c on eth0.*.
                                Apr 20 14:24:19 raspberrypi4 lightdm[524]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.629392] Bluetooth: Core ver 2.22
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.629502] NET: Registered protocol family 31
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.629516] Bluetooth: HCI device and connection manager initialized
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.630104] Bluetooth: HCI socket layer initialized
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.630124] Bluetooth: L2CAP socket layer initialized
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.630171] Bluetooth: SCO socket layer initialized
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.869925] Bluetooth: HCI UART driver ver 2.3
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.869946] Bluetooth: HCI UART protocol H4 registered
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.870061] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                Apr 20 14:24:20 raspberrypi4 kernel: [   27.870348] Bluetooth: HCI UART protocol Broadcom registered
                                Apr 20 14:24:20 raspberrypi4 btuart[380]: bcm43xx_init
                                Apr 20 14:24:20 raspberrypi4 btuart[380]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
                                Apr 20 14:24:20 raspberrypi4 btuart[380]: Set Controller UART speed to 3000000 bit/s
                                Apr 20 14:24:20 raspberrypi4 btuart[380]: Device setup complete
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Starting Load/Save RF Kill Switch Status...
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Configure Bluetooth Modems connected by UART.
                                Apr 20 14:24:20 raspberrypi4 polkitd[552]: started daemon version 0.105 using authority implementation `local' version `0.105'
                                Apr 20 14:24:20 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Load/Save RF Kill Switch Status.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: plymouth-start.service: Succeeded.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: plymouth-quit-wait.service: Succeeded.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Hold until boot process finishes up.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Received SIGRTMIN+21 from PID 172 (n/a).
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Authorization Manager.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Light Display Manager.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Started Getty on tty1.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Reached target Login Prompts.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Created slice system-bthelper.slice.
                                Apr 20 14:24:20 raspberrypi4 systemd[1]: Starting Bluetooth service...
                                Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: soliciting an IPv6 router
                                Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: Router Advertisement from fe80::f2af:85ff:fe8c:99dc
                                Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: adding address 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca/64
                                Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::da0:a631:6da1:f23c.
                                Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv6 with address 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca.
                                Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Registering new address record for 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca on eth0.*.
                                Apr 20 14:24:20 raspberrypi4 dhcpcd[440]: eth0: adding route to 2a02:810b:c63f:d98c::/64
                                Apr 20 14:24:20 raspberrypi4 avahi-daemon[390]: Withdrawing address record for fe80::da0:a631:6da1:f23c on eth0.
                                Apr 20 14:24:20 raspberrypi4 kernel: [   28.477216] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
                                Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: confirming prior DHCPv6 lease
                                Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: fe80::f2af:85ff:fe8c:99dc is reachable again
                                Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: adding default route via fe80::f2af:85ff:fe8c:99dc
                                Apr 20 14:24:21 raspberrypi4 systemd[1]: Started Disk Manager.
                                Apr 20 14:24:21 raspberrypi4 udisksd[411]: Acquired the name org.freedesktop.UDisks2 on the system message bus
                                Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: REPLY6 received from fe80::f2af:85ff:fe8c:99dc
                                Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: adding address 2a02:810b:c63f:d98c::d7c2/128
                                Apr 20 14:24:21 raspberrypi4 dhcpcd[440]: eth0: renew in 21600, rebind in 34560, expire in 43200 seconds
                                Apr 20 14:24:21 raspberrypi4 avahi-daemon[390]: Registering new address record for 2a02:810b:c63f:d98c::d7c2 on eth0.*.
                                Apr 20 14:24:22 raspberrypi4 bluetoothd[691]: Bluetooth daemon 5.50
                                Apr 20 14:24:22 raspberrypi4 systemd[1]: Started Bluetooth service.
                                Apr 20 14:24:22 raspberrypi4 systemd[1]: Started Raspberry Pi bluetooth helper.
                                Apr 20 14:24:22 raspberrypi4 systemd[1]: Reached target Bluetooth.
                                Apr 20 14:24:22 raspberrypi4 bluetoothd[691]: Starting SDP server
                                Apr 20 14:24:22 raspberrypi4 mysqld[642]: 2021-04-20 14:24:22 0 [Note] /usr/sbin/mysqld (mysqld 10.3.27-MariaDB-0+deb10u1) starting as process 642 ...
                                Apr 20 14:24:22 raspberrypi4 mysqld[642]: 2021-04-20 14:24:22 0 [Warning] Could not increase number of max_open_files to more than 16384 (request: 32186)
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: Raspberry Pi BDADDR already set
                                Apr 20 14:24:23 raspberrypi4 kernel: [   30.787342] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                Apr 20 14:24:23 raspberrypi4 kernel: [   30.787364] Bluetooth: BNEP filters: protocol multicast
                                Apr 20 14:24:23 raspberrypi4 kernel: [   30.787394] Bluetooth: BNEP socket layer initialized
                                Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Bluetooth management interface 1.18 initialized
                                Apr 20 14:24:23 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.13' (uid=0 pid=691 comm="/usr/lib/bluetooth/bluetoothd ")
                                Apr 20 14:24:23 raspberrypi4 vncserver-x11[536,root]: ServerManager: Server started
                                Apr 20 14:24:23 raspberrypi4 systemd[1]: Starting Hostname Service...
                                Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Sap driver initialization failed.
                                Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: sap-server: Operation not permitted (1)
                                Apr 20 14:24:23 raspberrypi4 bluetoothd[691]: Failed to set privacy: Rejected (0x0b)
                                Apr 20 14:24:23 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.hostname1'
                                Apr 20 14:24:23 raspberrypi4 systemd[1]: Started Hostname Service.
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001801-0000-1000-8000-00805f9b34fb
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 UUIDs: 00001800-0000-1000-8000-00805f9b34fb
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 Alias: BlueZ 5.50
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: [#033[0;93mCHG#033[0m] Controller DC:A6:32:BA:3C:76 Pairable: yes
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: Changing power off succeeded
                                Apr 20 14:24:23 raspberrypi4 bthelper[699]: Changing power on succeeded
                                Apr 20 14:24:23 raspberrypi4 systemd[1]: bthelper@hci0.service: Succeeded.
                                Apr 20 14:24:23 raspberrypi4 vncserver-x11[536,root]: ConsoleDisplay: Cannot find a running X server on vt1
                                Apr 20 14:24:24 raspberrypi4 vncserver-x11[536,root]: ConsoleDisplay: Found running X server (pid=681, binary=/usr/lib/xorg/Xorg)
                                Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: using static address 192.168.1.203/24
                                Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: adding route to 192.168.1.0/24
                                Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.203.
                                Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: New relevant interface eth0.IPv4 for mDNS.
                                Apr 20 14:24:24 raspberrypi4 dhcpcd[440]: eth0: adding default route via 192.168.1.200
                                Apr 20 14:24:24 raspberrypi4 avahi-daemon[390]: Registering new address record for 192.168.1.203 on eth0.IPv4.
                                Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: lese /run/dnsmasq/resolv.conf
                                Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver 192.168.1.200#53
                                Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver 8.8.8.8#53
                                Apr 20 14:24:24 raspberrypi4 dnsmasq[556]: Benutze Namensserver fd51:42f8:caae:d92e::1#53
                                Apr 20 14:24:25 raspberrypi4 systemd[1]: systemd-rfkill.service: Succeeded.
                                Apr 20 14:24:27 raspberrypi4 dhcpcd[440]: eth0: fe80::f2af:85ff:fe8c:99dc is reachable again
                                Apr 20 14:24:29 raspberrypi4 systemd[1]: Started Samba NMB Daemon.
                                Apr 20 14:24:29 raspberrypi4 systemd[1]: Starting Samba SMB Daemon...
                                Apr 20 14:24:29 raspberrypi4 vncserver-x11[536,root]: AgentInitCheck: no response from agent
                                Apr 20 14:24:30 raspberrypi4 systemd[1]: Created slice User Slice of UID 1000.
                                Apr 20 14:24:30 raspberrypi4 systemd[1]: Starting User Runtime Directory /run/user/1000...
                                Apr 20 14:24:30 raspberrypi4 systemd[1]: Started User Runtime Directory /run/user/1000.
                                Apr 20 14:24:30 raspberrypi4 systemd[1]: Starting User Manager for UID 1000...
                                Apr 20 14:24:30 raspberrypi4 systemd[1]: apt-daily.service: Succeeded.
                                Apr 20 14:24:30 raspberrypi4 systemd[1]: Started Daily apt download activities.
                                Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: lese /run/dnsmasq/resolv.conf
                                Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 192.168.1.200#53
                                Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 8.8.8.8#53
                                Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver fd51:42f8:caae:d92e::1#53
                                Apr 20 14:24:31 raspberrypi4 dnsmasq[556]: Benutze Namensserver 2a02:810b:c63f:d98c:f2af:85ff:fe8c:99dc#53
                                Apr 20 14:24:32 raspberrypi4 systemd[1]: Started MariaDB 10.3.27 database server.
                                Apr 20 14:24:32 raspberrypi4 /etc/mysql/debian-start[901]: Upgrading MySQL tables if necessary.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on Sound System.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Paths.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG cryptographic agent and passphrase cache.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Timers.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on GnuPG network certificate management daemon.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Starting D-Bus User Message Bus Socket.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Listening on D-Bus User Message Bus Socket.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Sockets.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Basic System.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Reached target Default.
                                Apr 20 14:24:32 raspberrypi4 systemd[811]: Startup finished in 2.212s.
                                Apr 20 14:24:32 raspberrypi4 systemd[1]: Started User Manager for UID 1000.
                                Apr 20 14:24:32 raspberrypi4 systemd[1]: Started Session 1 of user pi.
                                Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: /usr/bin/mysql_upgrade: the '--basedir' option is always ignored
                                Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: Looking for 'mysql' as: /usr/bin/mysql
                                Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: Looking for 'mysqlcheck' as: /usr/bin/mysqlcheck
                                Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[904]: This installation of MySQL is already upgraded to 10.3.27-MariaDB, use --force if you still need to run mysql_upgrade
                                Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[984]: Checking for insecure root accounts.
                                Apr 20 14:24:34 raspberrypi4 /etc/mysql/debian-start[990]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
                                Apr 20 14:24:35 raspberrypi4 systemd[1]: Started Samba SMB Daemon.
                                Apr 20 14:24:35 raspberrypi4 systemd[1]: Reached target Multi-User System.
                                Apr 20 14:24:35 raspberrypi4 systemd[1]: Reached target Graphical Interface.
                                Apr 20 14:24:35 raspberrypi4 systemd[1]: Starting Update UTMP about System Runlevel Changes...
                                Apr 20 14:24:35 raspberrypi4 systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
                                Apr 20 14:24:35 raspberrypi4 systemd[1]: Started Update UTMP about System Runlevel Changes.
                                Apr 20 14:24:35 raspberrypi4 systemd[1]: Startup finished in 6.594s (kernel) + 36.438s (userspace) = 43.033s.
                                Apr 20 14:24:36 raspberrypi4 vncserver-x11[536,root]: Connections: connected: 192.168.1.24::54365 (TCP)
                                Apr 20 14:24:36 raspberrypi4 vncserver-x11[536,root]: Connections: authenticated: 192.168.1.24::54365 (TCP), as (anonymous) (d permissions)
                                Apr 20 14:24:37 raspberrypi4 kernel: [   44.583156] broken atomic modeset userspace detected, disabling atomic
                                Apr 20 14:24:37 raspberrypi4 systemd[1]: systemd-fsckd.service: Succeeded.
                                Apr 20 14:34:15 raspberrypi4 systemd-timesyncd[338]: Synchronized to time server for the first time [2a02:a00:1009:6202::123]:123 (2.debian.pool.ntp.org).
                                Apr 20 14:34:15 raspberrypi4 lightdm[1064]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
                                Apr 20 14:34:15 raspberrypi4 systemd[1]: Started Session 3 of user pi.
                                Apr 20 14:34:15 raspberrypi4 bash[504]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                                Apr 20 14:34:15 raspberrypi4 bash[504]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                                Apr 20 14:34:16 raspberrypi4 bash[504]: object system.meta.uuid created: f2bf0859-fa5f-19ae-5629-68c17843bcf5
                                Apr 20 14:34:16 raspberrypi4 bash[504]: object system.user.admin created
                                Apr 20 14:34:16 raspberrypi4 systemd[811]: Started D-Bus User Message Bus.
                                Apr 20 14:34:29 raspberrypi4 systemd[1]: systemd-hostnamed.service: Succeeded.
                                Apr 20 14:34:30 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=1000 pid=1083 comm="/usr/bin/lxsession -s LXDE-pi -e LXDE ")
                                Apr 20 14:34:30 raspberrypi4 systemd[811]: Starting Virtual filesystem service...
                                Apr 20 14:34:30 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.Daemon'
                                Apr 20 14:34:30 raspberrypi4 systemd[811]: Started Virtual filesystem service.
                                Apr 20 14:34:30 raspberrypi4 kernel: [   62.126481] fuse: init (API version 7.32)
                                Apr 20 14:34:31 raspberrypi4 systemd[1]: Mounting FUSE Control File System...
                                Apr 20 14:34:31 raspberrypi4 systemd[1]: Mounted FUSE Control File System.
                                Apr 20 14:34:31 raspberrypi4 systemd[811]: Starting Sound Service...
                                Apr 20 14:34:32 raspberrypi4 dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.29' (uid=1000 pid=1238 comm="/usr/bin/pulseaudio --daemonize=no ")
                                Apr 20 14:34:32 raspberrypi4 systemd[1]: Starting RealtimeKit Scheduling Policy Service...
                                Apr 20 14:34:32 raspberrypi4 dbus-daemon[397]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
                                Apr 20 14:34:32 raspberrypi4 systemd[1]: Started RealtimeKit Scheduling Policy Service.
                                Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully called chroot.
                                Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully dropped privileges.
                                Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Successfully limited resources.
                                Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Running.
                                Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Canary thread running.
                                Apr 20 14:34:32 raspberrypi4 rtkit-daemon[1253]: Watchdog thread running.
                                Apr 20 14:34:33 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                                Apr 20 14:34:33 raspberrypi4 systemd[811]: Starting Virtual filesystem service - disk device monitor...
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - disk device monitor.
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - Media Transfer Protocol monitor.
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                                Apr 20 14:34:34 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1238 of process 1238 (n/a) owned by '1000' high priority at nice level -11.
                                Apr 20 14:34:34 raspberrypi4 rtkit-daemon[1253]: Supervising 1 threads of 1 processes of 1 users.
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - digital camera monitor...
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - digital camera monitor.
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - GNOME Online Accounts monitor.
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.7' (uid=1000 pid=1215 comm="pcmanfm --desktop --profile LXDE-pi ")
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Starting Virtual filesystem service - Apple File Conduit monitor...
                                Apr 20 14:34:34 raspberrypi4 gvfs-afc-volume-monitor[1295]: Volume monitor alive
                                Apr 20 14:34:34 raspberrypi4 dbus-daemon[1091]: [session uid=1000 pid=1091] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
                                Apr 20 14:34:34 raspberrypi4 systemd[811]: Started Virtual filesystem service - Apple File Conduit monitor.
                                Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 1 threads of 1 processes of 1 users.
                                Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1302 of process 1238 (n/a) owned by '1000' RT at priority 5.
                                Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 2 threads of 1 processes of 1 users.
                                Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Successfully made thread 1303 of process 1238 (n/a) owned by '1000' RT at priority 5.
                                Apr 20 14:34:35 raspberrypi4 rtkit-daemon[1253]: Supervising 3 threads of 1 processes of 1 users.
                                Apr 20 14:34:35 raspberrypi4 systemd[811]: Started Sound Service.
                                Apr 20 14:34:35 raspberrypi4 bluetoothd[691]: Endpoint registered: sender=:1.34 path=/MediaEndpoint/A2DPSource
                                Apr 20 14:34:35 raspberrypi4 bluetoothd[691]: Endpoint registered: sender=:1.34 path=/MediaEndpoint/A2DPSink
                                Apr 20 14:34:35 raspberrypi4 pulseaudio[1238]: E: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
                                Apr 20 14:34:35 raspberrypi4 kernel: [   66.990077] Bluetooth: RFCOMM TTY layer initialized
                                Apr 20 14:34:35 raspberrypi4 kernel: [   66.990099] Bluetooth: RFCOMM socket layer initialized
                                Apr 20 14:34:35 raspberrypi4 kernel: [   66.990120] Bluetooth: RFCOMM ver 1.11
                                und hier das Ende vom IOBroker log:
                                2021-04-20 14:28:55.984  - error: javascript.0 (14256) function(DeviceName(s, x)){ // mit Punkt am Ende
                                2021-04-20 14:28:55.985  - error: javascript.0 (14256) ^^^^^^^^
                                2021-04-20 14:28:55.985  - error: javascript.0 (14256) SyntaxError: Function statements require a function name
                                2021-04-20 14:28:55.985  - error: javascript.0 (14256)     at new Script (vm.js:88:7)
                                2021-04-20 14:28:55.985  - error: javascript.0 (14256)     at Object.createScript (vm.js:261:10)
                                2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
                                2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
                                2021-04-20 14:28:55.986  - error: javascript.0 (14256)     at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
                                2021-04-20 14:28:55.987  - error: javascript.0 (14256)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17)
                                2021-04-20 14:28:55.987  - error: javascript.0 (14256)     at processImmediate (internal/timers.js:463:21)
                                2021-04-20 14:29:01.400  - error: javascript.0 (14256) script.js.Test: test
                                2021-04-20 14:29:29.817  - info: javascript.0 (14256) Stop script script.js.Sensoren.ShellyErfassen
                                2021-04-20 14:29:29.839  - info: javascript.0 (14256) Start javascript script.js.Sensoren.ShellyErfassen
                                2021-04-20 14:30:00.052  - info: host.raspberrypi4 instance system.adapter.daswetter.0 started with pid 4110
                                2021-04-20 14:30:01.917  - info: daswetter.0 (4110) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.21.0, js-controller: 3.2.16
                                2021-04-20 14:30:14.329  - info: daswetter.0 (4110) Terminated (NO_ERROR): Without reason
                                2021-04-20 14:30:14.854  - info: daswetter.0 (4110) cleaned everything up...
                                2021-04-20 14:30:14.869  - info: host.raspberrypi4 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2021-04-20 14:24:38.869  - info: host.raspberrypi4 iobroker.js-controller version 3.2.16 js-controller starting
                                2021-04-20 14:24:38.874  - info: host.raspberrypi4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                2021-04-20 14:24:38.875  - info: host.raspberrypi4 hostname: raspberrypi4, node: v12.21.0
                                2021-04-20 14:24:38.876  - info: host.raspberrypi4 ip addresses: 192.168.1.203 2a02:810b:c63f:d98c::d7c2 2a02:810b:c63f:d98c:57e2:cb2a:6c85:3cca fe80::da0:a631:6da1:f23c
                                2021-04-20 14:24:38.941  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
                                2021-04-20 14:24:38.943  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected end of JSON input. Continue with empty dataset!
                                2021-04-20 14:24:39.020  - error: host.raspberrypi4 Cannot read system.config: null (OK when migrating or restoring)
                                2021-04-20 14:24:39.029  - error: host.raspberrypi4-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                                2021-04-20 14:34:15.578  - info: host.raspberrypi4 connected to Objects and States
                                2021-04-20 14:34:15.727  - warn: host.raspberrypi4 logger system.adapter.admin.0.logging was deleted
                                2021-04-20 14:34:15.728  - warn: host.raspberrypi4 logger system.adapter.javascript.0.logging was deleted
                                2021-04-20 14:34:15.773  - info: host.raspberrypi4 added notifications configuration of host
                                2021-04-20 14:34:15.780  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
                                2021-04-20 14:34:15.781  - error: host.raspberrypi4 Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                                2021-04-20 14:34:15.796  - info: host.raspberrypi4 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2021-04-20 14:34:15.803  - error: host.raspberrypi4 Cannot find view "system" for search "host"
                                2021-04-20 14:34:15.812  - error: host.raspberrypi4 Cannot find view "system" for search "state"
                                2021-04-20 14:34:15.813  - error: host.raspberrypi4 Cannot find view "system" for search "instance"
                                2021-04-20 14:34:15.815  - error: host.raspberrypi4 Could not collect system.host.raspberrypi4 states to check for obsolete states: Error: Cannot find view "system"
                                2021-04-20 14:34:15.816  - error: host.raspberrypi4 _design/system missing - call node iobroker.js setup
                                2021-04-20 14:34:16.643  - info: host.raspberrypi4 Created UUID: f2bf0859-fa5f-19ae-5629-68c17843bcf5
                                und
                                pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ free -h
                                Mem:          3,7Gi       244Mi       3,1Gi        48Mi       404Mi       3,3Gi
                                Swap:          99Mi          0B        99Mi
                                pi@raspberrypi4:/opt/iobroker/iobroker-data/backup-objects $ who -r
                                         Runlevel 5   2021-04-20 14:24
                                Gruß Wolfgang
                                #89
                                @wolfgangfb sagte in Mini-HowTo: Cannot find view "system" for search "host":
                                Apr 20 14:24:11 raspberrypi4 systemd-fsck[296]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
                                Kein "Stromausfall" oder sonstiges rüdes Umgehen mit dem System? Da scheint mir auf dem Datenträger was krumm zu sein dann.
                                Und den mitlaufenden Desktop würde ich auch ausschalten. Im Serverbetrieb ist Kommandozeile angesagt.
                                W 1 Antwort Letzte Antwort
                                  W Offline
                                  W Offline
                                  WolfgangFB
                                  #90
                                  Hier der Teil des Syslog davor:
                                  Apr 20 12:43:51 raspberrypi4 rngd[404]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                                  Apr 20 12:44:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:45:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:46:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:47:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:48:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:49:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:50:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:51:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:52:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:53:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:54:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:54:54 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
                                  Apr 20 12:54:54 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
                                  Apr 20 12:55:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:56:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:57:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:58:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 12:59:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:00:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:01:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:02:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:03:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:04:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:05:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:06:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:07:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:08:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:09:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:10:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:11:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:12:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:13:06 raspberrypi4 vncserver-x11[544,root]: Connections: disconnected: 192.168.1.24::64761 (TCP) ([IdleTimeout] Das Zeitlimit dieser Verbindung wurde durch Inaktivität überschritten.)
                                  Apr 20 13:13:10 raspberrypi4 vncserver-x11[544,root]: Connections: connected: 192.168.1.24::51718 (TCP)
                                  Apr 20 13:13:10 raspberrypi4 vncserver-x11[544,root]: Connections: authenticated: 192.168.1.24::51718 (TCP), as (anonymous) (d permissions)
                                  Apr 20 13:13:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:14:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:15:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:16:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:17:01 raspberrypi4 CRON[8441]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                                  Apr 20 13:17:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:18:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:19:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:20:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:21:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:22:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:23:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:24:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:25:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:26:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:27:14 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
                                  Apr 20 13:27:14 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                                  Apr 20 13:27:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:28:05 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
                                  Apr 20 13:28:05 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                                  Apr 20 13:28:15 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
                                  Apr 20 13:28:16 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
                                  Apr 20 13:28:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:29:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:29:36 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
                                  Apr 20 13:29:37 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
                                  Apr 20 13:29:58 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
                                  Apr 20 13:29:58 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
                                  Apr 20 13:30:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:31:05 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
                                  Apr 20 13:31:05 raspberrypi4 bash[9439]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
                                  Apr 20 13:31:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:32:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:33:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:34:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:35:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:36:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:37:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:38:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:39:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:40:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:41:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:42:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:43:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: bits received from HRNG source: 1320064
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: bits sent to kernel pool: 1262560
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: entropy added to kernel pool: 1262560
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2 successes: 66
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2 failures: 0
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Poker: 0
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Runs: 0
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Long run: 0
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: HRNG source speed: (min=285.570; avg=490.356; max=513.940)Kibits/s
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: FIPS tests speed: (min=4.830; avg=16.596; max=31.474)Mibits/s
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: Lowest ready-buffers level: 2
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: Entropy starvations: 0
                                  Apr 20 13:43:51 raspberrypi4 rngd[404]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                                  Apr 20 13:44:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:45:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:46:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:47:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:48:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:49:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:50:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:51:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:52:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:53:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:54:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:55:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:56:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:57:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:58:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 13:58:43 raspberrypi4 bash[9439]: Cannot parse "/Wolfgang/vis-views.json
                                  Apr 20 13:58:44 raspberrypi4 bash[9439]: Send diag info: {"uuid":"f5052040-c067-1fab-30de-7d247dd1c820","language":"de","country":"Germany","hosts":[{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.21.0","arch":"arm","adapters":{"admin":{"version":"4.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.7.1","platform":"Javascript/Node.js"},"backitup":{"version":"1.7.0","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"cloud":{"version":"4.0.4","platform":"Javascript/Node.js"},"devices":{"version":"0.3.15","platform":"Javascript/Node.js"},"discovery":{"version":"2.5.0","platform":"Javascript/Node.js"},"enigma2":{"version":"1.3.2","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"harmony":{"version":"1.2.2","platform":"Javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"info":{"version":"1.7.14","platform":"Javascript/Node.js"},"javascript":{"version":"4.8.4","platform":"Javascript/Node.js"},"meross":{"version":"1.5.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.0.3","platform":"Javascript/Node.js"},"ping":{"version":"1.4.12","platform":"Javascript/Node.js"},"pushover":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"scenes":{"version":"2.3.6","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.6","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.0","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.0.5","platform":"javascript/Node.js"},"vis":{"version":"1.3.4","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"2.7.4","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"web":{"version":"3.2.3","platform":"Javascript/Node.js"},"zigbee":{"version":"1.4.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"vis-material-advanced":{"version":"1.3.0","platform":"Javascript/Node.js"},"sql":{"version":"1.15.5","platform":"Javascript/Node.js"},"flot":{"version":"1.10.6","platform":"javascript/Node.js"},"heatingcontrol":{"version":"2.2.0","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.4","platform":"Javascript/Node.js"},"tvprogram":{"version":"1.0.0","platform":"Javascript/Node.js"},"tvspielfilm":{"version":"1.0.4","platform":"javascript/Node.js"},"shuttercontrol":{"version":"1.1.5","platform":"Javascript/Node.js"},"material":{"version":"0.13.9","platform":"javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4013187072,"ostype":"Linux","city":"fischbach","vis":423}
                                  Apr 20 13:59:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:00:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:01:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:02:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:03:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:04:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:05:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:06:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:07:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:08:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:09:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:10:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:11:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:12:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:13:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:14:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:15:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:16:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:17:01 raspberrypi4 CRON[31531]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                                  Apr 20 14:17:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:18:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:19:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:20:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:21:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:22:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:23:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:24:19 raspberrypi4 vncserver-x11[544,root]: Connections: disconnected: 192.168.1.24::51718 (TCP) ([IdleTimeout] Das Zeitlimit dieser Verbindung wurde durch Inaktivität überschritten.)
                                  Apr 20 14:24:23 raspberrypi4 vncserver-x11[544,root]: Connections: connected: 192.168.1.24::53991 (TCP)
                                  Apr 20 14:24:23 raspberrypi4 vncserver-x11[544,root]: Connections: authenticated: 192.168.1.24::53991 (TCP), as (anonymous) (d permissions)
                                  Apr 20 14:24:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:25:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:26:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:27:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:28:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:29:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:30:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:31:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:32:34 raspberrypi4 bash[9439]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
                                  Apr 20 14:24:11 raspberrypi4 systemd-modules-load[106]: Inserted module 'i2c_dev'
                                  Apr 20 14:24:11 raspberrypi4 kernel: [    0.000000] Booting Linux on physical CPU 0x0
                                  apollon77A Thomas BraunT wendy2702W 3 Antworten Letzte Antwort
                                  • W WolfgangFB
                                    #91
                                    Ok, faktisch nicht s zu sehen was den Reboot verursacht hat ... Dann tippe ich ggf auf Spannungsversorgung? bzw die üblichen verdächtigen :-)
                                    • W WolfgangFB
                                      #92
                                      @wolfgangfb
                                      vncserver-x11
                                      ist ein Prozess der da nicht laufen sollte. Schalte den verdammten Desktop-Quatsch aus!
                                      dmesg -T
                                      bringt?
                                      • W WolfgangFB
                                        wendy2702W Online
                                        wendy2702W Online
                                        #93
                                        @wolfgangfb Was ist überhaupt alles auf dem Pi installiert ?
                                        • W Offline
                                          W Offline
                                          WolfgangFB
                                          #94
                                          Mit dmesg -T kommt eine ewig lange Liste, die aber nicht den Reboot Zeitpunkt beinhalten.
                                          Was aber ein paarmal auftritt ist folgender Part:
                                          Di Apr 20 17:19:50 2021] [  12060]  1001 12060     1177      156    24576        0             0 ping
                                          [Di Apr 20 17:19:50 2021] [  12062]     0 12062       98        1    24576        0             0 resolvconf
                                          [Di Apr 20 17:19:50 2021] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=9736,uid=1001
                                          [Di Apr 20 17:19:50 2021] Out of memory: Killed process 9736 (node) total-vm:1223992kB, anon-rss:1090996kB, file-rss:7692kB, shmem-rss:0kB, UID:1001 pgtables:3496kB oom_score_adj:0
                                          [Di Apr 20 17:19:50 2021] oom_reaper: reaped process 9736 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                                          Das habe ich durch ein fehlerhaftes Javaskript verursacht bei dem ich nicht beachtet habe, dass Variablen in Funktionen nicht lokal sind und damit jedes mal die Javaskript Instanz gekillt habe. Ob das zum Reboot Zeitpunkt auch der Fall war weiß ich nicht.
                                          Der Raspi ist mein Bastelrechner, deshalb auch der vnc-Server mit dem ich einfach alles mögliche ausprobiere.
