  4. [gelöst] IOBroker JudoiSoft
19 Beiträge 4 Kommentatoren 722 Aufrufe 4 Beobachtet
    @glasfaser
    smartmeter.1	2021-04-11 14:55:41.898	info	(701) Received 13 values, 4 updated
    smartmeter.0	2021-04-11 14:55:40.815	info	(686) Received 10 values, 6 updated
    host.raspberrypi2	2021-04-11 14:55:29.874	info	Restart adapter system.adapter.judoisoft.0 because enabled
    host.raspberrypi2	2021-04-11 14:55:29.874	error	instance system.adapter.judoisoft.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
    host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
    host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: SyntaxError: Unexpected token ')'
    host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: ^
    host.raspberrypi2	2021-04-11 14:55:29.870	error	Caught by controller[0]: return();
    host.raspberrypi2	2021-04-11 14:55:29.869	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.judoisoft/main.js:1044
    host.raspberrypi2	2021-04-11 14:55:29.473	info	instance system.adapter.judoisoft.0 started with pid 4524
    host.raspberrypi2	2021-04-11 14:55:08.115	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    dwd.0	2021-04-11 14:55:07.567	info	(4506) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    dwd.0	2021-04-11 14:55:03.148	info	(4506) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.1, js-controller: 3.2.16
    host.raspberrypi2	2021-04-11 14:55:00.052	info	instance system.adapter.dwd.0 started with pid 4506
    host.raspberrypi2	2021-04-11 14:54:59.401	info	Restart adapter system.adapter.judoisoft.0 because enabled
    GlasfaserG Offline
    GlasfaserG Offline
    @marcel-drzal
    Hast du die Daten Nutzer und Passwort per Drag&Drop eingetragen .
    Lösche es nochmal und trage es neu ein .
    Wenn nicht dann :
    Deinstalliere die Instanz und den Adapter .
    Dann den Adapter neu installieren und eine Instanz erstellen .
    • GlasfaserG Glasfaser
      @marcel-drzal
      Wenn nicht dann :
      ielleicht es mit dem Benutzer Password zusammen?
      habe aber diese Daten aus der Judo App und da geht es
        GlasfaserG Offline
        GlasfaserG Offline
        @arteck kannst du mal hier schauen !
        ? 2 Antworten Letzte Antwort
          @glasfaser sorry falsches Fenster
            @marcel-drzal
            Nicht den Screenshot !!
            zu CodeTags ...
            @glasfaser vielleicht es mit dem Benutzer Password zusammen?
              @glasfaser leider geht es immer noch nicht. Password sollte stimmen
              kannst mir mal den Link für den Adapter senden. vielleicht ist da was falsch
                GlasfaserG Offline
                GlasfaserG Offline
                @marcel-drzal sagte in IOBroker JudoiSoft:
                Und was willst du mit dem Link machen : https://github.com/arteck/ioBroker.judoisoft
                Ich kann dir da nicht weiterhelfen , habe deshalb arteck in diesem Thread eingeladen .
                • arteckA Offline
                  arteckA Offline
                  arteck
                  hatte noch ein bug entdeckt... jetzt
                  • arteckA arteck
                    @arteck wo?
                      @arteck wo?
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @marcel-drzal
                      Hast du den Adapter über GitHub neu runtergeladen , bzw. wird er als Update in deinen Adaptern angezeigt .
                      Changelog
                      1.0.7 (2021-04-14)
                          (arteck) corr psw save method
