  4. [gelöst] IOBroker JudoiSoft
19 Beiträge 4 Kommentatoren 722 Aufrufe 4 Beobachtet
    @marcel-drzal Bitte keine Screenshots von Konsolentext.
    @thomas-braun ok, wie ist es besser?
      @marcel-drzal Den Text in CodeTags </> einbetten.
      Wie im ersten Post halt auch.
        @thomas-braun ok
        • GlasfaserG Offline
          GlasfaserG Offline
          @marcel-drzal
          Nicht den Screenshot !!
          zu CodeTags ...
          ? 2 Antworten Letzte Antwort
          • GlasfaserG Glasfaser
            @marcel-drzal
            zu CodeTags ...
            @glasfaser
            smartmeter.1	2021-04-11 14:55:41.898	info	(701) Received 13 values, 4 updated
            smartmeter.0	2021-04-11 14:55:40.815	info	(686) Received 10 values, 6 updated
            host.raspberrypi2	2021-04-11 14:55:29.874	info	Restart adapter system.adapter.judoisoft.0 because enabled
            host.raspberrypi2	2021-04-11 14:55:29.874	error	instance system.adapter.judoisoft.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
            host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
            host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
            host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
            host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
            host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
            host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
            host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: SyntaxError: Unexpected token ')'
            host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: ^
            host.raspberrypi2	2021-04-11 14:55:29.870	error	Caught by controller[0]: return();
            host.raspberrypi2	2021-04-11 14:55:29.869	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.judoisoft/main.js:1044
            host.raspberrypi2	2021-04-11 14:55:29.473	info	instance system.adapter.judoisoft.0 started with pid 4524
            host.raspberrypi2	2021-04-11 14:55:08.115	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            dwd.0	2021-04-11 14:55:07.567	info	(4506) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            dwd.0	2021-04-11 14:55:03.148	info	(4506) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.1, js-controller: 3.2.16
            host.raspberrypi2	2021-04-11 14:55:00.052	info	instance system.adapter.dwd.0 started with pid 4506
            host.raspberrypi2	2021-04-11 14:54:59.401	info	Restart adapter system.adapter.judoisoft.0 because enabled
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              @marcel-drzal
              Hast du die Daten Nutzer und Passwort per Drag&Drop eingetragen .
              Lösche es nochmal und trage es neu ein .
              Wenn nicht dann :
              Deinstalliere die Instanz und den Adapter .
              Dann den Adapter neu installieren und eine Instanz erstellen .
                @marcel-drzal
                Wenn nicht dann :
                ielleicht es mit dem Benutzer Password zusammen?
                habe aber diese Daten aus der Judo App und da geht es
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @arteck kannst du mal hier schauen !
                    @glasfaser sorry falsches Fenster
                      @marcel-drzal
                      zu CodeTags ...
                      @glasfaser vielleicht es mit dem Benutzer Password zusammen?
                        @glasfaser leider geht es immer noch nicht. Password sollte stimmen
                        kannst mir mal den Link für den Adapter senden. vielleicht ist da was falsch
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @marcel-drzal sagte in IOBroker JudoiSoft:
                          Und was willst du mit dem Link machen : https://github.com/arteck/ioBroker.judoisoft
                          Ich kann dir da nicht weiterhelfen , habe deshalb arteck in diesem Thread eingeladen .
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            hatte noch ein bug entdeckt... jetzt
                            • arteckA arteck
                              @arteck wo?
                                @arteck wo?
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @marcel-drzal
                                Hast du den Adapter über GitHub neu runtergeladen , bzw. wird er als Update in deinen Adaptern angezeigt .
                                Changelog
                                1.0.7 (2021-04-14)
                                    (arteck) corr psw save method
