  4. [gelöst] IOBroker JudoiSoft
19 Beiträge 4 Kommentatoren 722 Aufrufe 4 Beobachtet
  • ? Offline
    hatte ein Netzwertproblem mit der Heitzung
    Ich habe eine Enthärtungsanlage und wollte die Daten im IOBroker anzeigen lassen Adapter Judoisoft.
    bekomme keine Verbindung. über die App funktioniert es. Hoffe ihr könnt mir helfen.
    host.raspberrypi2	2021-04-11 13:29:32.911	info	Restart adapter system.adapter.judoisoft.0 because enabled
    host.raspberrypi2	2021-04-11 13:29:32.910	error	instance system.adapter.judoisoft.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi2	2021-04-11 13:29:32.910	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi2	2021-04-11 13:29:32.909	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.raspberrypi2	2021-04-11 13:29:32.909	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi2	2021-04-11 13:29:32.909	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi2	2021-04-11 13:29:32.908	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi2	2021-04-11 13:29:32.908	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
    host.raspberrypi2	2021-04-11 13:29:32.908	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
    host.raspberrypi2	2021-04-11 13:29:32.907	error	Caught by controller[0]: SyntaxError: Unexpected token ')'
    host.raspberrypi2	2021-04-11 13:29:32.907	error	Caught by controller[0]: ^
    host.raspberrypi2	2021-04-11 13:29:32.906	error	Caught by controller[0]: return();
    host.raspberrypi2	2021-04-11 13:29:32.904	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.judoisoft/main.js:1044
    host.raspberrypi2	2021-04-11 13:29:32.441	info	instance system.adapter.judoisoft.0 started with pid 2281
    host.raspberrypi2	2021-04-11 13:29:02.405	info	Restart adapter system.adapter.judoisoft.0 because enabled
    host.raspberrypi2	2021-04-11 13:29:02.405	error	instance system.adapter.judoisoft.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi2	2021-04-11 13:29:02.405	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi2	2021-04-11 13:29:02.405	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.raspberrypi2	2021-04-11 13:29:02.404	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi2	2021-04-11 13:29:02.404	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      @marcel-drzal node/npm sauber installiert?
      Was liefert
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        Was liefert
        @thomas-braun ```
        6c045744-149c-47ff-a23f-2f618667c21d-grafik.png code_text
          @thomas-braun ```
          @marcel-drzal Bitte keine Screenshots von Konsolentext.
            @thomas-braun ok, wie ist es besser?
              @marcel-drzal Den Text in CodeTags </> einbetten.
              Wie im ersten Post halt auch.
                @thomas-braun ok
                • GlasfaserG Offline
                  GlasfaserG Offline
                  @marcel-drzal
                  Nicht den Screenshot !!
                  zu CodeTags ...
                  ? 2 Antworten Letzte Antwort
                  • GlasfaserG Glasfaser
                    @marcel-drzal
                    zu CodeTags ...
                    @glasfaser
                    smartmeter.1	2021-04-11 14:55:41.898	info	(701) Received 13 values, 4 updated
                    smartmeter.0	2021-04-11 14:55:40.815	info	(686) Received 10 values, 6 updated
                    host.raspberrypi2	2021-04-11 14:55:29.874	info	Restart adapter system.adapter.judoisoft.0 because enabled
                    host.raspberrypi2	2021-04-11 14:55:29.874	error	instance system.adapter.judoisoft.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                    host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
                    host.raspberrypi2	2021-04-11 14:55:29.873	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                    host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
                    host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                    host.raspberrypi2	2021-04-11 14:55:29.872	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
                    host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
                    host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: SyntaxError: Unexpected token ')'
                    host.raspberrypi2	2021-04-11 14:55:29.871	error	Caught by controller[0]: ^
                    host.raspberrypi2	2021-04-11 14:55:29.870	error	Caught by controller[0]: return();
                    host.raspberrypi2	2021-04-11 14:55:29.869	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.judoisoft/main.js:1044
                    host.raspberrypi2	2021-04-11 14:55:29.473	info	instance system.adapter.judoisoft.0 started with pid 4524
                    host.raspberrypi2	2021-04-11 14:55:08.115	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    dwd.0	2021-04-11 14:55:07.567	info	(4506) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    dwd.0	2021-04-11 14:55:03.148	info	(4506) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.1, js-controller: 3.2.16
                    host.raspberrypi2	2021-04-11 14:55:00.052	info	instance system.adapter.dwd.0 started with pid 4506
                    host.raspberrypi2	2021-04-11 14:54:59.401	info	Restart adapter system.adapter.judoisoft.0 because enabled
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @marcel-drzal
                      Hast du die Daten Nutzer und Passwort per Drag&Drop eingetragen .
                      Lösche es nochmal und trage es neu ein .
                      Wenn nicht dann :
                      Deinstalliere die Instanz und den Adapter .
                      Dann den Adapter neu installieren und eine Instanz erstellen .
                        @marcel-drzal
                        Wenn nicht dann :
                        ielleicht es mit dem Benutzer Password zusammen?
                        habe aber diese Daten aus der Judo App und da geht es
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @arteck kannst du mal hier schauen !
                            @glasfaser sorry falsches Fenster
                              @marcel-drzal
                              zu CodeTags ...
                              @glasfaser vielleicht es mit dem Benutzer Password zusammen?
                                @glasfaser leider geht es immer noch nicht. Password sollte stimmen
                                kannst mir mal den Link für den Adapter senden. vielleicht ist da was falsch
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @marcel-drzal sagte in IOBroker JudoiSoft:
                                  Und was willst du mit dem Link machen : https://github.com/arteck/ioBroker.judoisoft
                                  Ich kann dir da nicht weiterhelfen , habe deshalb arteck in diesem Thread eingeladen .
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    hatte noch ein bug entdeckt... jetzt
                                    • arteckA arteck
                                      @arteck wo?
                                        @arteck wo?
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @marcel-drzal
                                        Hast du den Adapter über GitHub neu runtergeladen , bzw. wird er als Update in deinen Adaptern angezeigt .
                                        Changelog
                                        1.0.7 (2021-04-14)
                                            (arteck) corr psw save method
