  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.3k
1.2k Beiträge 100 Kommentatoren 499.2k Aufrufe 82 Beobachtet
    Kueppert
    schrieb am zuletzt editiert von Kueppert
    gerade den Saugi gestartet und versucht nach 30 Sek wieder nach Hause zu schicken:
    mihome-vacuum.0	2021-04-14 19:12:58.963	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 19:12:30.497	warn	(28226) Error at stop Cleaning: MESSAGE TIMEOUT
    mihome-vacuum.0	2021-04-14 19:12:24.858	info	(28226) Map selected create states...
    mihome-vacuum.0	2021-04-14 19:12:24.669	warn	(28226) Login failed
    mihome-vacuum.0	2021-04-14 19:12:23.854	info	(28226) settest next timer: not available
    mihome-vacuum.0	2021-04-14 19:12:23.262	info	(28226) select standard vacuum protocol....
    mihome-vacuum.0	2021-04-14 19:12:23.260	warn	(28226) No Answer for DeviceModel use model from Config
    mihome-vacuum.0	2021-04-14 19:12:23.259	warn	(28226) No Answer for DeviceModel use old one
    mihome-vacuum.0	2021-04-14 19:12:23.259	warn	(28226) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER CONNECTION CAN TAKE UP TO 10 MINUTES PLESASE WAIT AND DON`T TRUN THE ADAPTER OFF
    mihome-vacuum.0	2021-04-14 19:12:13.156	info	(28226) check group user admin group admin: false
    mihome-vacuum.0	2021-04-14 19:12:12.214	info	(28226) check user admin pw iobroker: true
    mihome-vacuum.0	2021-04-14 19:12:11.689	info	(28226) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
    mihome-vacuum.0	2021-04-14 19:11:39.172	warn	(27284) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mihome-vacuum.0	2021-04-14 19:11:39.170	info	(27284) terminating
    mihome-vacuum.0	2021-04-14 19:11:39.125	error	(27284) Cannot read property 'channels' of null
    mihome-vacuum.0	2021-04-14 19:11:39.124	error	at processImmediate (internal/timers.js:461:21)
    mihome-vacuum.0	2021-04-14 19:11:39.124	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5559:38)
    mihome-vacuum.0	2021-04-14 19:11:39.124	error	at MihomeVacuum.emit (events.js:314:20)
    mihome-vacuum.0	2021-04-14 19:11:39.124	error	at MihomeVacuum.onStateChange (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:316:10)
    mihome-vacuum.0	2021-04-14 19:11:39.124	error	at VacuumManager.stateChange (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/vacuum.js:749:16)
    mihome-vacuum.0	2021-04-14 19:11:39.124	error	at VacuumManager.startCleaning (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/vacuum.js:1201:37)
    mihome-vacuum.0	2021-04-14 19:11:39.124	error	(27284) TypeError: Cannot read property 'channels' of null
    mihome-vacuum.0	2021-04-14 19:11:39.120	error	(27284) unhandled promise rejection: Cannot read property 'channels' of null
    mihome-vacuum.0	2021-04-14 19:11:39.119	error	(27284) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    gewartet...30 Sekunden, dann erst Pause, dann Home ging. Kann auch Zufall sein...
    Unter MAP hab ich aber nen IMG erhalten :)
    NACHTRAG:
    das hatte ich vorher auf jeden Fall nicht O.o
    mihome-vacuum.0	2021-04-14 21:01:35.255	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 21:01:15.214	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 21:00:55.161	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 21:00:35.118	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 21:00:15.077	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:59:55.026	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:59:34.976	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:59:14.934	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:58:54.877	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:58:34.832	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:58:14.792	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:57:54.746	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:57:34.694	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:57:14.647	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:56:54.605	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:56:34.565	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:56:14.515	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:55:54.461	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:55:34.422	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:55:14.372	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:54:54.330	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:54:34.282	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:54:14.234	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:53:54.186	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:53:34.132	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:53:14.088	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:52:54.036	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:52:33.990	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:52:13.947	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:51:53.888	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:51:33.847	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:51:13.803	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:50:53.760	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:50:33.712	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:50:13.668	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:49:53.616	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:49:33.573	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:49:13.523	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:48:53.482	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:48:33.439	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:48:13.392	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:47:53.343	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:47:33.296	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:47:13.241	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:46:53.188	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:46:33.142	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:46:13.087	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:45:20.722	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:45:00.670	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:44:40.551	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:44:20.431	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:44:00.377	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:43:40.326	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:43:20.195	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:43:00.136	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:42:40.074	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:42:19.941	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:41:59.898	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:41:39.843	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:41:19.708	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:40:59.651	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:40:39.603	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:40:19.522	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:39:59.480	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:39:39.433	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:39:19.297	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:38:59.251	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:38:39.213	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:38:19.070	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:37:59.023	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:37:38.984	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:37:18.712	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:36:58.673	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:36:38.634	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:36:18.595	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:35:58.556	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:35:38.508	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:35:18.362	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:34:58.316	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:34:38.259	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:34:18.130	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:33:58.065	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:33:38.025	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:33:17.874	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:32:57.834	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:32:37.790	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:32:17.616	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:31:57.576	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:31:37.528	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:31:17.378	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:30:57.336	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:30:37.294	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:30:17.158	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:29:57.102	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:29:37.060	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:29:16.925	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:28:56.872	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:28:36.827	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:28:16.708	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:27:56.661	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:27:36.611	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:27:16.472	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:26:56.416	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:26:36.363	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:26:16.225	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:25:56.187	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:25:36.145	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:25:16.013	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:24:55.950	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:24:35.905	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:24:15.753	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:23:55.702	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:23:35.655	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:23:15.539	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:22:55.495	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:22:35.448	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:22:15.393	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:21:55.347	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:21:35.303	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:21:15.260	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:20:55.219	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:20:35.176	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:20:15.133	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:19:55.074	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:19:35.033	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:19:14.973	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:18:54.930	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:18:34.870	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:18:14.810	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:17:54.764	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:17:34.695	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:17:14.613	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:16:54.566	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:16:34.528	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:16:14.489	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:15:54.442	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:15:34.400	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:15:14.356	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:14:54.316	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:14:34.271	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:14:14.217	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:13:54.167	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:13:34.115	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:13:14.073	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:12:54.019	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:12:33.979	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:12:13.932	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:11:53.887	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:11:33.845	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:11:13.805	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:10:53.750	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:10:33.702	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:10:13.644	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:09:53.602	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:09:33.559	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:09:13.515	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:08:53.468	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:08:33.428	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:08:13.377	warn	(28226) answer map_slot is currently not supported!
    mihome-vacuum.0	2021-04-14 20:07:53.327	warn	(28226) answer map_slot is currently not supported!
    • K Kueppert
      @meistertr hab den Vacuum V1 mit Valetudo.
      Installation ohne AUffälligkeiten LOG auch ohne Auffälligkeiten. Das eine Answer Map Slot hatte ich vorher auch schon :)
      mihome-vacuum.0	2021-04-14 19:04:47.679	warn	(18778) answer map_slot is currently not supported!
      mihome-vacuum.0	2021-04-14 19:04:27.601	warn	(18778) answer map_slot is currently not supported!
      mihome-vacuum.0	2021-04-14 19:04:07.723	info	(18778) settest next timer: not available
      mihome-vacuum.0	2021-04-14 19:04:07.498	info	(18778) create state for carpet_mode
      mihome-vacuum.0	2021-04-14 19:04:07.482	warn	(18778) answer map_slot is currently not supported!
      mihome-vacuum.0	2021-04-14 19:04:07.354	info	(18778) Map selected create states...
      mihome-vacuum.0	2021-04-14 19:04:07.124	warn	(18778) State "mihome-vacuum.0.deviceInfo.mac" has no existing object, this might lead to an error in future versions
      mihome-vacuum.0	2021-04-14 19:04:07.122	warn	(18778) State "mihome-vacuum.0.deviceInfo.fw_ver" has no existing object, this might lead to an error in future versions
      mihome-vacuum.0	2021-04-14 19:04:07.121	warn	(18778) State "mihome-vacuum.0.deviceInfo.model" has no existing object, this might lead to an error in future versions
      Ok, wenn ich versuche die MAP zu laden, bekomme ich auch o. g. warn-Meldung im LOG. Hab nur Valetudo bei Map aktiviert...
      BlackHawk3000
      schrieb am zuletzt editiert von BlackHawk3000
      @meistertr Erstmal super Arbeit die du leistest.
      Eine Frage, seit heute bin ich im Besitz eines ROIDMI EVE Plus, der eine Untermarke von Xiaomi ist.
      Man kann diesen Sauger auch ganz normal über die MiHomeApp steuern.
      Daher meine Frage, kannst du diesen auch einbinden?
      Wenn ja was benötigst du, um dir unter die Arme zu greifen. (Achtung Anfänger) ?
      Habe bereits deinen 3.0.4 Adapter installiert. Folgendes spuckt er im Debug aus:
      mihome-vacuum.0	2021-04-14 19:54:03.212	debug	(15781) Receive Timeout<<<
      mihome-vacuum.0	2021-04-14 19:54:03.111	debug	(15781) Receive Timeout<<<
      mihome-vacuum.0	2021-04-14 19:54:03.006	debug	(15781) Receive Timeout<<<
      mihome-vacuum.0	2021-04-14 19:54:02.904	debug	(15781) Receive Timeout<<<
      mihome-vacuum.0	2021-04-14 19:54:02.713	debug	(15781) Receive Timeout<<<
      mihome-vacuum.0	2021-04-14 19:54:01.317	warn	(15781) Model roidmi.vacuum.v60 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
      mihome-vacuum.0	2021-04-14 19:54:01.317	debug	(15781) DeviceModel selected to: roidmi.vacuum.v60
      mihome-vacuum.0	2021-04-14 19:54:01.316	warn	(15781) No Answer for DeviceModel use model from Config
      mihome-vacuum.0	2021-04-14 19:54:01.316	warn	(15781) No Answer for DeviceModel use old one
      mihome-vacuum.0	2021-04-14 19:54:01.316	warn	(15781) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER CONNECTION CAN TAKE UP TO 10 MINUTES PLESASE WAIT AND DON`T TRUN THE ADAPTER OFF
      mihome-vacuum.0	2021-04-14 19:54:01.315	debug	(15781) Get Device data..4
      mihome-vacuum.0	2021-04-14 19:54:01.212	debug	(15781) Message= {"id":5,"method":"miIO.info"}
      mihome-vacuum.0	2021-04-14 19:54:01.211	debug	(15781) Get Device data..3
      mihome-vacuum.0	2021-04-14 19:54:01.109	debug	(15781) Message= {"id":4,"method":"miIO.info"}
      mihome-vacuum.0	2021-04-14 19:54:01.108	debug	(15781) Get Device data..2
      mihome-vacuum.0	2021-04-14 19:54:01.005	debug	(15781) Message= {"id":3,"method":"miIO.info"}
      mihome-vacuum.0	2021-04-14 19:54:01.005	debug	(15781) Get Device data..1
      mihome-vacuum.0	2021-04-14 19:54:00.901	debug	(15781) Message= {"id":2,"method":"miIO.info"}
      mihome-vacuum.0	2021-04-14 19:54:00.901	debug	(15781) Get Device data..0
      mihome-vacuum.0	2021-04-14 19:54:00.710	debug	(15781) Message= {"id":1,"method":"miIO.info"}
      mihome-vacuum.0	2021-04-14 19:54:00.709	debug	(15781) GETMODELFROMAPI: objModel: {"val":"roidmi.vacuum.v60","ack":true,"ts":1618422820472,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1618422820472}
      mihome-vacuum.0	2021-04-14 19:54:00.708	debug	(15781) Time difference between Mihome Vacuum and ioBroker: -1618420957 sec
      mihome-vacuum.0	2021-04-14 19:54:00.706	debug	(15781) MAIN: Connected to device, try to get model..
      mihome-vacuum.0	2021-04-14 19:54:00.705	debug	(15781) Receive <<< Helo <<< 2131002000000000185728150000075bffffffffffffffffffffffffffffffff
      mihome-vacuum.0	2021-04-14 19:54:00.647	debug	(15781) server started on 0.0.0.0:53421
      Danke im Voraus
      Gruß Blacky
      M A 2 Antworten Letzte Antwort
      • MeistertrM Meistertr
        Aktuelle Test Version 3.1.6
        Veröffentlichungsdatum 18.4.2021
        Github Link https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
        Lange hats gedauert aber langsam komm ich zum Ende (wobei das dann wahrscheinlich der Anfang ist :) ).
        Was hat sich geändert? Alles und nix kann kann man sagen.
        Der Adapter wurde komplett neu aufgesetzt und dem Aktuellen stand angepasst.
        vorher:
        • Nachrichten an den Roboter wurden willkürlich geschickt und gehofft das eine Antwort kommt.
        • Die Erkennung des Roboters (Modell und Marke und Firmware) wurden durch Ankommende Nachrichten oder das Ausbleiben erkannt
        • comact mode nicht möglich da zig Timeouts liefen
        • Keine neuen/anderen Sauger integrierbar da alles in einer Datei lag
        jetzt:
        • beim start wird zwingend das Modell ermittelt wonach dann die richtige Datei für den jeweiligen Sauger geladen wird
        • danach werden Strukturiert die Sonderfunktionen ermittelt und freigegeben
        • Nachrichten werden nicht mehr willkürlich gesendet sonders strukturiert und jede Nachricht bekommt eine Antwort
        • comact mode möglich da alle timer zentral gelagert sind
        ich habe mich bemüht die Objekte zum Vorgänger gleich zu lassen. also Optisch ist nicht viel neu aber wie gesagt unterm Kleid alles was man im debug log sehen sollte.
        ich habe noch nicht viele Sauger in der Datenbank also kann es zu warn log einträgen kommen, dann bitte modell und bezeichnung posten dann nehm ich sie mit rein.
        Bitte alles Testen da ich viel ohne Testen umgeschrieben habe (bei über 2000 Zeilen) konnte ich nicht alles direkt testen.
        Stand Aktuell:
        Jetzt sollte alles gehen was bei der 2er auch geht. und mehr
        Was sollte gehen:
        • alles wie beim alten außer die map (folgt in kürze)
        • viomi Modelle die sonst über meinen Fork liefen sind nun mit drin
        • support für den S7 (letztes update hat die History kaputt gemacht)
        • Map wir unterstützt
        Fixes:
        • Map bei zwei Saugern funtionieren
        • Map wird zuverlässig(er) geladen
        • 3.0.2 Manueller Map Reload Button funktionert
        • 3.0.4/ 3.0.7 Timer geht wieder
        • 3.0.5 Disable map_slot warning, add start button, fix error while sending messages without selected device, fix water_box value
        • 3.0.6 fix queue States, fix cleaning Buttons.
        • 3.0.8 fix map for Valetudo
        • 3.1.0 aktuelle Goto und Zones werden gespeichert
        • 3.1.1 fix queue
        • 3.1.3 Map bugfix, add Multimap Support
        • 3.1.3 fix missing Wifi Signal
        • 3.1.4 Fix Connrection after reboot/ now wifi
          3.1.6:
        • fixed Disk I/O
        • added get States when map is changed
        • minimize Messages
        • changed logentrys from warn to debug
        • added Donate button
        folgt in Kürze:
        - Koordinaten von goto und Zonen werden angezeigt (in den jeweiligen states)
        • dreame support über miot
        • compactmode
          - map
        • map für history
        • material tabel
        • led Status S7
        • neues Logo
        • Doku aufbereiten
        Installieren bitte über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum (einfach von git)
        Bitte Vorher den alten Adapter vollständig löschen.
        Dies ist die Alpha also BITTE nur installieren wenn ihr wisst was ihr macht und einen qualifizierten Bugreport liefern könnt
        Bitte in dieses Thema NUR Fehler oder Requests die den Adapter betreffen. KEINE Installationsfehler oder sonstige Fragen. macht dafür bitte wenn die Suche nichts ergeben hat ein neues Thema auf damit es hier nicht so überläuft wie in den alten Threads..
        da_WoodyD Offline
        da_WoodyD Offline
        @meistertr Roborock S6 Pure 👍
        • B BlackHawk3000
          Danke im Voraus
          Gruß Blacky
          mech
          schrieb am zuletzt editiert von mech
          Habe den Adapter auch mal installiert und beteilige mich gern an dem Test.
          Roborock S6 maxv
          @IOBroker:~# npm -v
          6.14.4
          @IOBroker:~# nodejs -v
          v14.16.0
          Installation / Log (Ohne Auffälligkeiten):
          mihome-vacuum.0	2021-04-14 20:47:55.027	info	(8004) create new room: 644001017629
          mihome-vacuum.0	2021-04-14 20:47:55.027	info	(8004) create new room: 644001017632
          mihome-vacuum.0	2021-04-14 20:47:55.026	info	(8004) create new room: 644001016932
          mihome-vacuum.0	2021-04-14 20:47:55.021	info	(8004) create new room: 644001016935
          mihome-vacuum.0	2021-04-14 20:47:55.020	info	(8004) create new room: 644001016934
          mihome-vacuum.0	2021-04-14 20:47:55.020	info	(8004) create new room: 644001016916
          mihome-vacuum.0	2021-04-14 20:47:55.019	info	(8004) create new room: 644001016933
          mihome-vacuum.0	2021-04-14 20:47:54.951	info	(8004) create state for carpet_mode
          mihome-vacuum.0	2021-04-14 20:47:53.572	info	(8004) create states for water box mode
          mihome-vacuum.0	2021-04-14 20:47:53.566	info	(8004) settest next timer: not available
          mihome-vacuum.0	2021-04-14 20:47:53.548	info	(8004) create states for water box
          mihome-vacuum.0	2021-04-14 20:47:53.525	info	(8004) change states from State control.fan_power
          mihome-vacuum.0	2021-04-14 20:47:53.410	info	(8004) Map not selected delete states...
          mihome-vacuum.0	2021-04-14 20:47:53.027	info	(8004) select standard vacuum protocol....
          mihome-vacuum.0	2021-04-14 20:47:50.885	info	(8004) check group user admin group admin: false
          mihome-vacuum.0	2021-04-14 20:47:50.529	info	(8004) check user admin pw iobroker: false
          mihome-vacuum.0	2021-04-14 20:47:50.053	info	(8004) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.16.0, js-controller: 3.2.16
          host.IOBroker	2021-04-14 20:47:48.376	info	instance system.adapter.mihome-vacuum.0 started with pid 8004
          host.IOBroker	2021-04-14 20:47:45.773	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          host.IOBroker	2021-04-14 20:47:45.255	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
          mihome-vacuum.0	2021-04-14 20:47:45.211	info	(7989) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          mihome-vacuum.0	2021-04-14 20:47:45.211	info	(7989) terminating
          mihome-vacuum.0	2021-04-14 20:47:45.209	info	(7989) Got terminate signal TERMINATE_YOURSELF
          host.IOBroker	2021-04-14 20:47:45.205	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
          Dann die MAP aktiviert (Adapter bleibt "Gelb", aber das dauert ja):
          mihome-vacuum.0	2021-04-14 20:53:11.786	info	(8037) Map selected create states...
          mihome-vacuum.0	2021-04-14 20:53:10.357	info	(8037) settest next timer: not available
          mihome-vacuum.0	2021-04-14 20:53:09.817	info	(8037) select standard vacuum protocol....
          mihome-vacuum.0	2021-04-14 20:53:09.815	warn	(8037) No Answer for DeviceModel use model from Config
          mihome-vacuum.0	2021-04-14 20:53:09.815	warn	(8037) No Answer for DeviceModel use old one
          mihome-vacuum.0	2021-04-14 20:53:09.814	warn	(8037) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER CONNECTION CAN TAKE UP TO 10 MINUTES PLESASE WAIT AND DON`T TRUN THE ADAPTER OFF
          Update dann noch wenn ich sehe ob der Adapter "Grün" wird und die Map verfügbar ist.
          Alle anderen Datenpunkte sehen gut aus, ich glaube das Wifi Signal zieht er aktuell nicht mehr.
          Vielen Dank für den Adapter ;)
          Update: Adapter "GRÜN" Karte wurde geladen. Wenn die sich nun auch aktualisiert ist alles roger!
          Update1:
          Der Datenpunkt für den Wassertank war vorher true / false und scheint nun vermutlich 0/1 zu sein.
          MeistertrM 1 Antwort Letzte Antwort
            BlackHawk3000
            Habe einen alten Beitrag von dir gefunden Meister, deshalb habe ich mal etwas gesucht.
            Folgende Urls habe ich schon einmal gefunden:
            # http://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:roidmi-v60:1
            gibt auch noch mit :2
            # http://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:roidmi-v60:2
            Des Weiteren habe ich dann mal die alten Befehle genutzt, die vermutlich hier nicht passen werden.
            Bitte hier um Berichtigung und evtl. um ein/zwei Beispiele, dann setze ich die Befehle anders um:
            "battery": {"siid": 3, "piid": 1},                      [{"code":0,"did":"408365077","piid":1,"siid":3,"value":100}]
            "charge_state": {"siid": 3, "piid": 2},                 [{"code":0,"did":"408365077","piid":2,"siid":3,"value":1}]
            "error": {"siid": 2, "piid": 2},                        [{"code":0,"did":"408365077","piid":2,"siid":2,"value":0}]
            "state": {"siid": 2, "piid": 1},                        [{"code":0,"did":"408365077","piid":1,"siid":2,"value":9}]
            "fan_speed": {"siid": 2, "piid": 6},                    [{"code":-4003,"did":"408365077","piid":6,"siid":2}]
            "operating_mode": {"siid": 2, "piid": 4},               [{"code":0,"did":"408365077","piid":4,"siid":2,"value":2}]
            "mop_state": {"siid": 16, "piid": 1},                   [{"did":"408365077","piid":1,"siid":16}]
            "water_level": {"siid": 2, "piid": 5},                  [{"code":-4003,"did":"408365077","piid":5,"siid":2}]
            "brush_life_level": {"siid": 14, "piid": 1},            [{"code":0,"did":"408365077","piid":1,"siid":14,"value":0}]
            #  "brush_life_time": {"siid": 14, "piid": 2},          [{"code":-4003,"did":"408365077","piid":2,"siid":14}]
            "brush_life_level2": {"siid": 15, "piid": 1},           [{"code":0,"did":"408365077","piid":1,"siid":15,"value":1722}]
            #  "brush_life_time2": {"siid": 15, "piid": 2},         [{"code":0,"did":"408365077","piid":2,"siid":15,"value":95}]
            "filter_life_level": {"siid": 11, "piid": 1},           [{"code":0,"did":"408365077","piid":1,"siid":11,"value":17922}]
            #  "filter_life_time": {"siid": 11, "piid": 2},         [{"code":0,"did":"408365077","piid":2,"siid":11,"value":99}]
            "clean_area": {"siid": 9, "piid": 1},                   [{"code":0,"did":"408365077","piid":1,"siid":9,"value":40}]
            "clean_time": {"siid": 18, "piid": 5},                  [{"did":"408365077","piid":5,"siid":18}]
            "total_clean_count": {"siid": 9, "piid": 5},            [{"code":-4003,"did":"408365077","piid":5,"siid":9}]
            #   "total_clean_area": {"siid": 9, "piid": 3},         [{"code":-4003,"did":"408365077","piid":3,"siid":9}]
            #  "dnd_enabled": {"siid": 12, "piid": 2},              [{"code":0,"did":"408365077","piid":2,"siid":12,"value":99}]
            #  "audio_volume": {"siid": 4, "piid": 2},              [{"did":"408365077","piid":2,"siid":4}]
            #  "direction_key": {"siid": 8, "piid": 1}              [{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]
            Folgende Fehlermeldung kommt wenn ich die Befehle ausgeführt habe:
            host.iobroker	2021-04-14 21:11:04.084	info	instance system.adapter.mihome-vacuum.0 started with pid 1074
            host.iobroker	2021-04-14 21:10:34.061	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
            host.iobroker	2021-04-14 21:10:34.061	error	instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            mihome-vacuum.0	2021-04-14 21:10:33.381	warn	(32537) Terminated (UNCAUGHT_EXCEPTION): Without reason
            mihome-vacuum.0	2021-04-14 21:10:33.380	info	(32537) terminating
            mihome-vacuum.0	2021-04-14 21:10:33.368	error	(32537) Cannot read property 'stateChange' of null
            mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) TypeError: Cannot read property 'stateChange' of null at MihomeVacuum.onStateChange (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:316:10) at process._tickCallback (interna
            mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) unhandled promise rejection: Cannot read property 'stateChange' of null
            mihome-vacuum.0	2021-04-14 21:10:33.367	error	(32537) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            mihome-vacuum.0	2021-04-14 21:10:33.366	debug	(32537) Get self send data:{"id":6,"result":[{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]}
            mihome-vacuum.0	2021-04-14 21:10:33.366	debug	(32537) MIIO RECIVE: {"id":6,"result":[{"code":0,"did":"408365077","piid":1,"siid":8,"value":0}]}
            mihome-vacuum.0	2021-04-14 21:10:33.099	debug	(32537) Message= {"id":6,"method":"get_properties","params":[{"did":"408365077","siid":8,"piid":1}]}
            mihome-vacuum.0	2021-04-14 21:10:33.099	info	(32537) send message: Method: get_properties Params: [{"did":"408365077","siid":8,"piid":1}]
            Blacky
            • B BlackHawk3000
              Blacky
              MeistertrM Offline
              MeistertrM Offline
              Meistertr
              @blackhawk3000 kannst du das bitte in ein git issue verpacken damit ich es auf dem schirm habe
              • M mech
                Roborock S6 maxv
                @IOBroker:~# npm -v
                6.14.4
                v14.16.0
                Update1:
                MeistertrM Offline
                MeistertrM Offline
                Meistertr
                @mech sollte ture false sein, werde ich anpassen
                  vorher:
                  jetzt:
                  Stand Aktuell:
                  Was sollte gehen:
                  Fixes:
                  • 3.1.1 fix queue
                    3.1.6:
                  • fixed Disk I/O
                  • minimize Messages
                  folgt in Kürze:
                  • compactmode
                    - map
                  • map für history
                  • material tabel
                  • led Status S7
                  • neues Logo
                  • Doku aufbereiten
                  Coffeelover
                  @meistertr Habe gerade den Adapter installiert iVm einem roborock.vacuum.a15 (Roborock S7).
                  Map und History werden sauber angezeigt.
                  Beim Versuch unter Rooms auf den Button "roomClean" zu klicken, passiert leider nichts. Im Log sieht es folgendermaßen aus. Ein Anwenderfehler ist nicht ganz auszuschließen - ich habe mit den Rooms bisher nicht gearbeitet.
                  mihome-vacuum.3	2021-04-14 23:55:15.760	warn	(29422) Get Mappinter done redomap...
                  mihome-vacuum.3	2021-04-14 23:55:15.484	warn	(29422) Get Mappinter while cleaning
                  mihome-vacuum.3	2021-04-14 23:55:07.136	warn	(29422) Get Mappinter done redomap...
                  mihome-vacuum.3	2021-04-14 23:55:06.916	warn	(29422) Get Mappinter while cleaning
                  mihome-vacuum.3	2021-04-14 23:54:59.922	warn	(29422) Get Mappinter done redomap...
                  mihome-vacuum.3	2021-04-14 23:54:59.776	warn	(29422) Get Mappinter while cleaning
                  mihome-vacuum.3	2021-04-14 23:54:52.912	warn	(29422) Get Mappinter done redomap...
                  mihome-vacuum.3	2021-04-14 23:54:52.575	warn	(29422) Get Mappinter while cleaning
                  mihome-vacuum.3	2021-04-14 23:54:48.489	warn	(29422) Get Mappinter done redomap...
                  mihome-vacuum.3	2021-04-14 23:54:48.095	warn	(29422) Get Mappinter while cleaning
                  mihome-vacuum.3	2021-04-14 23:54:30.872	warn	(29422) Get Mappinter done redomap...
                  mihome-vacuum.3	2021-04-14 23:54:28.865	warn	(29422) Get Mappinter while cleaning
                  mihome-vacuum.3	2021-04-14 23:54:22.408	warn	(29422) Get Mappinter done redomap...
                  mihome-vacuum.3	2021-04-14 23:54:22.196	warn	(29422) Get Mappinter while cleaning
                  mihome-vacuum.3	2021-04-14 23:53:45.615	warn	(29422) State "mihome-vacuum.3.info.queue" has no existing object, this might lead to an error in future versions
                  • C Coffeelover
                    MeistertrM Offline
                    MeistertrM Offline
                    Meistertr
                    @coffeelover sagte in Test Adapter Mihome-vacuum v3.0.5 Next Generarition:
                    queue
                    sollte in der 3.0.6 gehen
                      queue
                      mech
                      @meistertr said in Test Adapter Mihome-vacuum v3.0.6 Next Generarition:
                      queue
                      306 läuft und der Fehler mit dem Mappinter ist auch weg. Danke dafür :)
                        Kueppert
                        Ich hab die V3.0.7 und 3.0.6 ausprobiert. Bei beiden erhalte ich KEINE Fehlermeldung answer map_slot is currently not supported mehr
                        Dafür erhalte ich aber auch keine MAP mehr :( In Valetudo ist sie jedoch vorhanden:
                        EInstellung Adapter Map-Settings:
                        Version 3.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum,
                        node: v12.21.0,
                        rockrobo.vacuum.v1
                        • K Kueppert
                          node: v12.21.0,
                          rockrobo.vacuum.v1
                          MeistertrM Offline
                          MeistertrM Offline
                          Meistertr
                          @kueppert zeig mal einen ausgibiegen debug log
                            Kueppert
                            @meistertr anbei das komplette LOG (Token hab ich ge-X-t):
                            iobroker.2021-04-15.log
                            MeistertrM 2 Antworten Letzte Antwort
                            • K Kueppert
                              MeistertrM Offline
                              MeistertrM Offline
                              Meistertr
                              @kueppert du bruacst den token nicht xxen der ist nur lokal gültig
                              • K Kueppert
                                MeistertrM Offline
                                MeistertrM Offline
                                Meistertr
                                @kueppert sollte in der 3.0.8 wieder gehen
                                  Kueppert
                                  @meistertr YEEES Meister, Fehlermeldung weg und unter Cleanmap wieder die Map da. Perfekt. Vielen Dank 👍 👍 👍
                                  NACHTRAG: Auch die CPU-Auslastung, mit der ich bei der alten Adapter-Version unheimlich Probleme hatte (bis hin zum Absturz vom NUC) sind nun weg. Hatte den Adapter daher lang nicht verwendet.
                                  • K Kueppert
                                    MeistertrM Offline
                                    MeistertrM Offline
                                    Meistertr
                                    @kueppert der Performance Gewinn war zu erwarten da der Code extrem optimiert wurde.
                                    • MeistertrM Offline
                                      MeistertrM Offline
                                      Meistertr
                                      Dann wird Zeit von Alpha in beta zu gehen
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        @meistertr RoborockS6 macht keine probleme.
                                        allerdings hat er schon vor längerer zeit den goto verloren. hab da mal was eingetragen, passt allerding natürlich mit. in der App kann ich ja das target anklicken, aber ich finde die positon nirgends als xval, yval. wie kann man das rausfinden?
                                        • da_WoodyD da_Woody
                                          @da_woody die Positionen hab ich bei meinen S5 mit der FloleApp herausgefunden.. vielleicht geht die auch mit dem S6..?
                                          C da_WoodyD 2 Antworten Letzte Antwort
