  4. RangeError nach js update
    5.7k
    1.5k
13 Beiträge 5 Kommentatoren 2.5k Aufrufe
  • PatrickP Offline
    PatrickP Offline
    Patrick
    RangeError: 2016-12-23 10:11:53.683 error at C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:127:7
    RangeError: 2016-12-23 10:11:53.683 error at C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:270:10
    RangeError: 2016-12-23 10:11:53.683 error at Sender.flush (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:268:3)
    RangeError: 2016-12-23 10:11:53.683 error at C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:120:10
    RangeError: 2016-12-23 10:11:53.683 error at Sender.applyExtensions (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:287:5)
    RangeError: 2016-12-23 10:11:53.683 error at C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:126:12
    RangeError: 2016-12-23 10:11:53.683 error at Sender.frameAndSend (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:166:14)
    RangeError: 2016-12-23 10:11:53.683 error at new Buffer (buffer.js:61:12)
    RangeError: 2016-12-23 10:11:53.683 error at fromString (buffer.js:167:16)
    RangeError: 2016-12-23 10:11:53.683 error at byteLength (buffer.js:319:25)
    RangeError: 2016-12-23 10:11:53.683 error Maximum call stack size exceeded
    uncaught 2016-12-23 10:11:53.679 error exception: Maximum call stack size exceeded
    Morgen
    ich habe seit dem JS update immer mal wider das Problem
    weiß jemand wo das herkommt?
    und was man dagegen unternehmen kann ?
    • PatrickP Offline
      PatrickP Offline
      Patrick
      ricknetpc 2016-12-23 10:18:47.298 error RangeError: Maximum call stack size exceeded at isFinite (native) at Buffer.write (buffer.js:605:14) at fromString (buffer.js:173:26) at new Buffer (buffer.js:61:12) at Sender.fram
      ricknetpc 2016-12-23 10:18:47.296 error uncaught exception: Maximum call stack size exceeded
      • BluefoxB Offline
        BluefoxB Offline
        @Patrick:
        Morgen
        und was man dagegen unternehmen kann ? `
        node.js version?
        • PatrickP Offline
          PatrickP Offline
          Patrick
          @Bluefox:
          @Patrick:
          Morgen
          node.js version? `
          node:4.6.1
          • PatrickP Offline
            PatrickP Offline
            Patrick
            keiner eine Idee ?
            iobroker	2017-01-09 20:46:57.250	info	_restart
            RangeError:	2017-01-09 20:46:57.247	error	at C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:120:10
            RangeError:	2017-01-09 20:46:57.247	error	at Sender.applyExtensions (C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:287:5)
            RangeError:	2017-01-09 20:46:57.247	error	at C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:127:7
            RangeError:	2017-01-09 20:46:57.247	error	at C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:270:10
            RangeError:	2017-01-09 20:46:57.247	error	at Sender.flush (C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:268:3)
            RangeError:	2017-01-09 20:46:57.247	error	at C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:126:12
            RangeError:	2017-01-09 20:46:57.247	error	at Sender.frameAndSend (C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:235:38)
            RangeError:	2017-01-09 20:46:57.247	error	at onEnd (C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\lib\transports\websocket.js:118:52)
            RangeError:	2017-01-09 20:46:57.247	error	Maximum call stack size exceeded
            uncaught	2017-01-09 20:46:57.240	error	exception: Maximum call stack size exceeded
            host.DESKTOP-2UOKJ1H	2017-01-09 20:46:51.426	info	instance system.adapter.vis.0 terminated while should be started once
            vis.0	2017-01-09 20:46:50.876	info	Uploaded.
            vis.0	2017-01-09 20:46:44.467	info	600 files uploaded...
            vis.0	2017-01-09 20:46:34.571	info	500 files uploaded...
            web.0	2017-01-09 20:46:28.042	info	2017-01-09T19:46:28.041Z Connected system.user.admin
            vis.0	2017-01-09 20:46:25.336	info	400 files uploaded...
            web.0	2017-01-09 20:46:23.493	info	2017-01-09T19:46:23.493Z Connected system.user.admin
            vis.0	2017-01-09 20:46:18.193	info	300 files uploaded...
            wifilight.0	2017-01-09 20:46:17.239	info	starting. Version 0.0.33 in C:/IOBROKER/ioBroker/node_modules/iobroker.wifilight, node: v4.6.1
            node: 4.6.1
            • Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              Ich hab das Problem auch, das kommt wahrscheinlich vom upnp Adapter. Das hatte ich nach einem Adapter Absturz. Nachdem ich den Adapter deaktiviert hab war es weg.
              Am Tag darauf hab ich den Adapter wieder aktiviert und seit dem gehts.
              Bisher hab ich kein Lösung für das Problem, das dürfte gar nicht auftreten.
              Gesendet von meinem m8 mit Tapatalk
              Persönlicher Support
              Spenden -> paypal.me/J3YC33
              • PatrickP Offline
                PatrickP Offline
                Patrick
                hmm
                dann muss ich wohl damit leben
                • Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  Zumindest bis ich weiss was ich dagegen unternehmen kann.
                  Du hast geschrieben das es immer mal wieder auftritt. Kannst du mal beobachten ob es nach dem Start des Adapters auftritt oder auch dann wenn der Adapter länger als 60 Minuten gelaufen ist.
                  • PatrickP Offline
                    PatrickP Offline
                    Patrick
                    @Jey Cee:
                    Gesendet von meinem m8 mit Tapatalk `
                    nach dem Startet trit kein Problem auf
                    ob es länger wie 60 min durch hält denk ich schon werde es aber noch weiter beobachten
                    • PatrickP Offline
                      PatrickP Offline
                      Patrick
                      @Jey Cee:
                      läuft länger wie 2h ohne Störung
                      • Y Offline
                        Y Offline
                        ykuendig
                        Habe auch etwas mit upnp Adapter gespielt. Nun bekomme ich auch diese Range Fehler. Plus sowas im Log:
                        raspi3	2017-02-04 14:49:19.451	info	iobroker _restart
                        raspi3	2017-02-04 14:49:19.450	error	RangeError: Maximum call stack size exceeded at new Uint8Array (native) at Buffer.subarray (native) at Buffer.slice (buffer.js:688:23) at fromString (buffer.js:182:21) at new Buffe
                        raspi3	2017-02-04 14:49:19.448	error	uncaught exception: Maximum call stack size exceeded
                        upnp.0	2017-02-04 14:49:18.322	debug	inMem message upnp.0.* upnp.0.192_168_1_108_-_Sonos_PLAY:3.ZonePlayer.Alive
                        Vielleicht hilfts ja jemandem weiter.
                        Gruss Yves
                          BlueEssi
                          Ich habe das Problem auch. Der UPNP ist bei mir auch aktiv. Es tritt in unregelmäßigen Abständen auf. Manche Tage garnicht. Manche Tage 3-4 mal am Tag.
                          • Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            http://forum.iobroker.net/viewtopic.php … 030#p55030
                            32.7k
                            82.6k
