  4. [Projekt] Integr. Cubinote - Alexa Sprache drucken - Listen
65 Beiträge 8 Kommentatoren 13.4k Aufrufe 12 Beobachtet
  • Sebastian IOS Sebastian IO
    @mcchickents Hast du alle scripte eingebunden? als bsp für die alexa listen nochmal:
    Wird ein Fehler im javascript Protokoll ausgeworfen?
    const moment = require('moment');
    const fs = require('fs');
    var aApiSettings = {
        //Echo Gerät für Sprachausgabe
        'echodevice': 'YOUR ECHO DEVICE',
        'url': getState("0_userdata.0.cubinote.apiurl").val,
        'action': {
            'print': 'printpaper',
            'devicestatus': 'getdeviceinfo',
            'printstatus': 'getprintstat',
            'requestbind': 'requestbind',
            'requestbindstatus': 'getbindrequeststatus'
        'appid': '?appID=' + getState("0_userdata.0.cubinote.appid").val,
        'accesskey': '&ak=' + getState("0_userdata.0.cubinote.accesskey").val,
        'deviceid': '&deviceID=' + getState("0_userdata.0.cubinote.deviceid").val,
        'bindid': '&bindID=' + getState("0_userdata.0.cubinote.bindid").val,
        'userid': '&useridentifying' + getState("0_userdata.0.cubinote.userid").val,
        'liststates': {
            '0_userdata.0.cubinote.actionStates.print_shoppinglist_state': 'alexa2.0.Lists.SHOPPING_LIST.json',
            '0_userdata.0.cubinote.actionStates.print_todolist_state': 'alexa2.0.Lists.TO_DO.json'
    /**Print States */
    for (const [state, list] of Object.entries(aApiSettings.liststates)) {
        on({ id: state, val: true }, function (obj) {
            var value = obj.state.val;
            moment.locale('de');         // de
            var TimeStamp = moment().format('YYYY-MM-DD hh:mm:ss');
            var sTimestamp = '&timestamp=' + TimeStamp;
            var apiUrl = aApiSettings.url + aApiSettings.action.print + aApiSettings.appid + aApiSettings.accesskey + sTimestamp + aApiSettings.deviceid + aApiSettings.bindid;
            apiUrl += '&printcontent=T:';
            var aLists = JSON.parse(getState(list).val);
            var printList = '';
            var TimeStampList = moment().format('DD.MM.YYYY HH:mm');
            if(list == 'alexa2.0.Lists.SHOPPING_LIST.json'){
                printList = 'Einkaufsliste '+TimeStampList+'\n\r';
                printList += '================================\n\n\r';
            if(list == 'alexa2.0.Lists.TO_DO.json'){
                printList = 'TODO Liste '+TimeStampList+'\n\r';
             printList += aLists.map(function (val) {
                var item = val.value
                item = item[0].toUpperCase() + item.substring(1);
                return (val.completed ? '[X] ' : '[ ] ') + item;
            }).join('\n\n\r');
          //es sind keine Umlaute zulässig somit müssen diese ersetzt werden
            printList = printList.replace(/Ä/g, 'Ae');
            printList = printList.replace(/ä/g, 'ae');
            printList = printList.replace(/Ö/g, 'Oe');
            printList = printList.replace(/ö/g, 'oe');
            printList = printList.replace(/Ü/g, 'Ue');
            printList = printList.replace(/ü/g, 'ue');
            printList = printList.replace(/ß/g, 'ss');
            var base64 = new Buffer(printList).toString('base64');
            apiUrl += base64;
            //console.log(apiUrl);
            const request = require('request');
            request({ 'uri': apiUrl}, function (error, response, json) {
                if (!error && response.statusCode === 200) {
                    var aReturn = JSON.parse(json);
                    //{"showapi_res_code":1,"showapi_res_error":"ok","result":2,"printcontentid":52476}
                    if (aReturn.result == 2) {
                        var statusUrl = aApiSettings.url + aApiSettings.action.printstatus + aApiSettings.appid + aApiSettings.accesskey + sTimestamp;
                        statusUrl += '&printcontentid=' + aReturn.printcontentid;
                        request({ 'uri': statusUrl }, function (err, resp, jsonStatus) {
                            //{"showapi_res_code":1,"showapi_res_error":"ok","printflag":1,"printcontentid":52476}
                            var outputDevice = aApiSettings.echodevice;
                            setState(outputDevice + ".Commands.speak", '50; Drucken Liste erfolgreich');
            setStateDelayed(state, false, 2000, false);
    mcchickents
    schrieb am zuletzt editiert von mcchickents
    @sebastian-io 75) You are assigning a number to the state "0_userdata.0.cubinote.bindid" which expects a string. Please fix your code to use a string or change the state type to number. This warning might becom
    habe 4 javascripte von dir am laufen. habe aber lediglich die alexa eingebunden sonst habe ich an den scripten nix gemacht.
    Gruss Julian
    Agria4800A 1 Antwort Letzte Antwort
    • M mcchickents
      Gruss Julian
      Agria4800A Offline
      Agria4800A Offline
      Agria4800
      schrieb am zuletzt editiert von Agria4800
      @mcchickents :
      So, vielleicht kann ich helfen, nochmal auf Anfang: Führe mal bitte die Punkte im Spoiler aus:
      Im oberen Bereich (Das wird benötigt) alle Info´s sammeln und eintragen (aufschreiben) --Jeweils aus der App, Developer Seite, A=Anwtort der links, Printer Zettel) kommen die Info´s her
      Bitte in den Links die XXX jeweils mit deinen gesammelten Info´s ersetzten!
      /Cubinote task....
      ///Das wird benötigt !
      // APP ID: 10X
      // Access Key AK: XXXXXXXXXXX
      // Device ID: XXXXXXXX
      // Cubinote ID: XXXXX
      // App name: XXX
      // Developer: XXX
      // Verification Code: z.b.:XXX
      // Bind ID: XXX
      // useridentifying: XXXXX
      // printcontentid“: XXXXX
      //1.) http://api.cubinote.com/home/requestbind?appID=XXX&ak=XXX&timestamp=2014-11-14 14:22:39&deviceID=XXX&useridentifying=108XX
      //A: {"showapi_res_code":1,"showapi_res_error":"ok","showapi_devicetype":602,"showapi_bindid“:XXXXXX}
      //2.) http://api.cubinote.com/home/getbindrequeststatus?appID=XX&ak=XXXtimestamp=2014-11-14 14:22:39&deviceID=XX&bindID=XXXXX
      //A: {"showapi_res_code":0,"showapi_res_error":"ok","showapi_devicetype":602}
      //(3.) http://api.cubinote.com/home/verifybind?appID=XXX&ak=XXX&timestamp=2014-11-14 14:22:39&deviceID=9XXX&bindID=807XXX&verifyCode=XXX&enablePush=1
      //A: {"showapi_res_code":1,"showapi_res_error":"ok"}
      //4.) http://api.cubinote.com/home/getbindlist?appID=XXX&ak=XXX&timestamp=2021-04-04 21:20:39
      //A: {"showapi_res_code":1,"showapi_res_error":"ok","showapi_bindlist":"{"ds":[{"bindID\“:XXX,\“deviceID\“:\“XXX\“,\“useridentifying\“:\“XXXXX\“,\“deviceType":602,"enablePush":true}]}"}
      //5.) http://api.cubinote.com/home/getbindlistbyuseridentifying?appID=XXX&ak=XXX&timestamp=2014-11-14 14:22:39&useridentifying=1
      //A: {"showapi_res_code":1,"showapi_res_error":"ok","showapi_bindlist":"{"ds":[]}"}
      //7.) http://api.cubinote.com/home/getdeviceinfo?appID=XXX&ak=XXX&timestamp=2014-11-14 14:22:39&deviceID=XXX&bindID=XXXXX
      //A: {"showapi_res_code":1,"showapi_res_error":"ok","showapi_devicetype":602,"showapi_state":3,"showapi_isOnline":1}
      //8.) http://api.cubinote.com/home/printpaper?appID=XXX&ak=XXX&timestamp=2017-11-20 14:43:56&deviceID=XXX&bindID=XXXXXX&printcontent=T:dGVzdA==
      //A: {"showapi_res_code":1,"showapi_res_error":"ok","result":2,"printcontentid“:XXXX}
      //9.) http://api.cubinote.com/home/getprintstatus?appID=XXX&ak=XXX&timestamp=2017-11-20 14:43:56&printcontentid=XXX
      //A: {"showapi_res_code":1,"showapi_res_error":"ok","printflag":1,"printcontentid“:XXX}
      //10.) http://api.cubinote.com/home/getSignalBase64Pic?appID=XXX&ak=XXX&imgBase64String=xxx
      //A: —— {"showapi_res_code":0,"showapi_res_error":"pic change error"}
      //A {„showapi_res_code":1,"showapi_res_error":"ok","result":"xxx"}
      Wenn du alle Info´s hast, dann die DP, die vom Script angelegt wurden per Hand füllen und wie sebastion-io geschrieben hat vorgehen
      write & check binding state script:
      0_userdata.0.cubinote.actionStates.write_binding_state (einmal auf true setzen) deine binding id bekommen, diese wird dann in den definierten Datenpunkt geschrieben.
      0_userdata.0.cubinote.actionStates.check_binding_state (einmal auf true setzen) hier bekommst du dann eine Sprachausgabe ob die Verbindung erfolgreich war. Beide Datenpunkte brauchst du nur einmal ausführen, letztlich brauchen wir ja nur die bindid.
        @agria4800 danke für den coolen Tip,
        hab es jetzt für mich angepasst sodass es mit dem DP 0_userdata.0.cubinote.Notizen.notizenText zusammenarbeitet,
        hier ist ja auch schon das parsing für umlaute integriert und setzt den Text automatisch zurück!
        on({id: "alexa2.0.History.answerText", change: "ne"}, async function (obj) {
         if (getState("alexa2.0.History.summary").val.indexOf('sprich mir nach') !== -1 && getState("alexa2.0.History.answerText").val.indexOf('Wenn ich etwas nachsprechen') === -1 ) {
            setStateDelayed('0_userdata.0.cubinote.Notizen.notizenText', getState("alexa2.0.History.answerText").val, 1000, false);
        Agria4800A Offline
        Agria4800A Offline
        Agria4800
        @sebastian-io: Ich hab´s nochmal etwas optimiert, da doch einige Drucke im laufe des Tages kamen... daher habe ich einen seperaten DP zum drucken genommen... und mal ne schnelle Vis zusammen gebastelt...
        So wird der gesprochene Text geschrieben und erst gedruckt, wenn ich (IOT) sagen, Fax an Oma Ella senden :-)
        Hintergrund ist der, das der Drucker als Fax für meine Oma gedacht ist, da die Corona Zeit doch sehr einsam macht und mit 91 Jahren Whatsapp doch zu komplex für sie ist, dachte ich mir, mit einem guten Zettel kann man sie doch glücklich stimmen..die gute Oma Ella 😀 da spreche ich kurz mit Alexa, oder schreibe per App, oder per Computer, oder nehme vordefinierte Texte per VIS...ist egal, geht ja alles... und die Frau ist happy, wenn der Drucker brummt....
        Maximal komfortabel !!! Dank deine Idee... daher, nochmals vielen Dank für deine Hilfe zu meinem Projekt "Mach Oma Ella glücklich" 👍 👍 👍
        • Agria4800A Agria4800
          @mcchickents :
          /Cubinote task....
          // APP ID: 10X
          // App name: XXX
          // Developer: XXX
          // Bind ID: XXX
          mcchickents
          @agria4800 said in [Projekt] Integr. Cubinote - Alexa Sprache drucken - Listen:
          bei Punkt 8 bekomme ich
          {"showapi_res_code":0,"showapi_res_error":"Not a valid bind device"}
          • M mcchickents
            Agria4800A Offline
            Agria4800A Offline
            Agria4800
            @mcchickents :
            Du hast du bindid aus link nr. 1 benutzt, oder ?
            Dann scheint deine BindID vielleicht nicht zu passen... ist nur ein Versuch : erhöhe die Zahl mal um 1:
            zb.Bind ID: 806938 ---> 806939 und trage diese mal ein und teste erneut... Ich denke, es ist so wie @sebastian-io meinte, ist nur ne Kleinigkeit, die nicht passt.. aber den muss man erst mal finden
              @mcchickents :
              mcchickents
              @agria4800
              so fortschritt :-)
              Status vom Drucker ist hergestellt. Habe nochmal alles gelöscht. Iobroker neu gestartet und neu angefangen nun geht es.
              Text drucken aus variable geht auch schon^^
              Jetzt fehlt nur noch das Drucken der Listen. Ich ändere aktuell den Status manuell im Iobroker von false auf true. true bleibt stehen es wird nur leider noch nix gedruckt. Vieleicht habt ihr zwei auch noch eine idee an was das liegen kann. Ich sag schonmal vielen dank bis hier her:-)
              gruss Julian
                mcchickents
                Es geht alles.
                Vielen lieben dank euch zwei.
                Schönen abend euch noch.
                Gruss Julian
                • M mcchickents
                  Es geht alles.
                  Gruss Julian
                  Agria4800A Offline
                  Agria4800A Offline
                  Agria4800
                  @mcchickents: sauber, super, nie aufgeben und immer dran bleiben...👍
                  Für mich war das auch das erste "komplizierte Project als nicht programmiererfahrerner Laborant ;-) aber nach über 2 Jahren Iobroker traut man sich irgendwann immer mehr....
                  M T 2 Antworten Letzte Antwort
                    mcchickents
                    @agria4800 ja immer weiter machen irgentwann kalppt es schon^^.
                    ich habe noch das problem das er die einkaufliste und die doto liste zweimal hintereinader druckt^^. mal schauen wie ich das weg bekomme.
                      ThorstenStr
                      @agria4800
                      Hallo, ich klinke mich mal ein, habe die ganze Zeit im hintergrund still mit gelesen und bin gerade dabei das ganze auch um zu setzten.
                      Da ich leider mit den Skripten im ioBroker noch nicht viel gemacht habe, habe ich hier ein Paar verständnissfragen.
                      Das Sammel der Daten hat soweit geklappt, ich kann über die API (Link) auch Drucken. Die Datenpunkte sind angelegt und auch entsprechend gefüllt.
                      Jetzt zu den Skripten. Hier bin ich mir nicht sicher ob ich alles richtig gemacht habe, muss von den DP nicht irgendwo ein Bezug zu dem jeweiligen Script sein? ist die Namensgebung der Scripte wichtig?
                      Egal welche tests ich im ioBroker mache, der Drucker zuckt sich nicht. Könnt Ihr mir hier weiter helfen?
                      Hier ein Screenshot der DP und der angelegten Scripte:
                      dankeschön ;)
                      • T ThorstenStr
                        @agria4800
                        dankeschön ;)
                        Agria4800A Offline
                        Agria4800A Offline
                        Agria4800
                        @thorstenstr Eigentlich musst du nix einrichten, die Scripte von Sebastion-io sind einsatzbereit bis auf die Echo ID (aber nur für die Ansage durch Alexa)
                        Der Pfad ist bei dir auch so: alexa2.0.Lists.SHOPPING_LIST?
                        Geht der DP wieder zurück auf false nach 2 sek. ? 0_userdata.0.cubinote.actionStates.print_shoppinglist_state
                        Hast du das letzte Scritp von Ihm mal getestet --> Notizen drucken ?
                          ThorstenStr
                          @agria4800 Ja, der Pfad zur Shoppinglist passt bei mir.
                          der DP bleibt bei mir auf True stehen wenn ich ihn setze.
                          ich bin mir nicht sicher ob ich die Scripte richtig angelegt habe.
                          [+] Neues Script -> Javascript -> einen Namen vergeben (egal welcher?) -> Inhalt in das Script kopiert und aktiviert.
                          passt das so ?
                          • T ThorstenStr
                            passt das so ?
                            Agria4800A Offline
                            Agria4800A Offline
                            Agria4800
                            @thorstenstr: Ja, das passt so.
                            Villeicht einen past & copy fehler, lege das Script nochmal neu an und kopiere es aus dem Forum neu.
                            Analog bitte auch mal das probieren aus dem post --> 7. Apr. 2021, 17:28
                            DP: 0_userdata.0.cubinote.Notizen.notizenText
                            Das hier kannst du noch in das script einfügen, dann erstellt er dir auch den DP
                            createState('0_userdata.0.cubinote.Notizen.notizenText', {name: 'Text drucken', type: 'string', def: '0',unit: '', desc: 'Beschreibung', role: 'value'});
                              ThorstenStr
                              @agria4800 Vielen Dank.
                              Ich weiss nicht was ich das erste mal falsch gemacht habe, aber nachdem ich die DP neu erstellt habe, stehen diese in den Objekten auch ganz oben und nicht mehr unter Javascript.
                              Auf jeden Fall funktioniert jetzt auch alles.
                              Dankeschön ;)
                                "Alexa, drucke Einkaufsliste"
                                "Alexa, drucke Aufgabenliste" ...
                                ... genau diese beiden Sprachbefehle haben mir gefehlt für einen schnellen Ausdruck in Notizgröße für obengenannte Listen!
                                Ich bin fündig geworden bei Cubinote, einem noch sehr jungen Produkt. Es ist ein kleiner Thermopapier Drucker für die Hosentasche mit eigener App zum Drucken von Notizen und auch Bildern im 1Bit monochrom Format! Also eine Spielerei für TechnikNerds!
                                Der große Vorteil, dieser Drucker bietet eine WepApi an, mit dieser kann man dann verschiedene Befehle absetzen und der kleine Drucker führt diese aus.
                                Das Projekt war geboren ...
                                Was wurde gemacht:
                                Es wurden Datenpunkte für die wichtigsten Daten wie (url,appid,accesskey,deviceid etc) angelegt, weitere Datenpunkte für die verschiedenen States zum Abfragen, Smartobjekte angelegt über iot zum Erstellen von Routinen mit Alexa, in meinem Fall drucken.
                                Noch ein paar Javascripte programmiert für die einzelnen Abfragen, wie Binding, Status und Drucken. Alles mit einander verknüpft, getestet und aktiviert.
                                Ich habe ein kurzes Video mit meinem Smartphone aufgenommen, leider ist der Ton sehr leise. Wer Interesse hat, kann sich das 1-minütige Video auf YT ansehen (Ton muss leider sehr laut gestellt werden, sorry):
                                Cubinote Integration Video YT
                                Viel Spass.
                                Für Ideen und Anregungen bin ich natürlich offen!
                                PS: Ich will mir eventuell dann auch andere Datenpunkte, wie Systeminformationen etc auch per Sprache zum Druck ausgeben lassen.
                                Legoracer70
                                schrieb am zuletzt editiert von Legoracer70
                                @sebastian-io Hallo, ich bin von deinem Projekt so begeistert, dass ich mir auch gleich einen Cubinote bestellt habe. Leider bevor ich richtig mit einsteigen kann, ist das Projekt vielleicht schon zu Ende, außer wenn du noch einen genialen Tipp für mich hast ?
                                Zum Problem: Heute ist der Cubinote geliefert wurden und ich kann mir die größte Mühe geben, ich bekomme den Cubinote nicht mit der Android-App zum Laufen. Ich habe das 5Ghz in meiner Fritzbox abgeschaltet und sogar das WLAN-Passwort auf ganz einfach ohne Sonderzeichen geändert. Ich habe den automatischen, wie auch den manuellen Weg probiert. Einmal kam sogar auf dem Ausdruck ein "connected" raus, aber trotzdem konnte ich nicht über die App einen Text drucken. Jedes mal wird der Drucker als Offline angezeigt. Langsam bin ich mit meinem Latein am Ende ...
                                Kann der Drucker auch ohne App auf Auslieferungszustand zurück gesetzt werden ?
                                Ich bin so weit, dass der Drucker sonst wieder zurück geht. Vielleicht habe ich ja auch ein "Montagsmodell" erwischt 😖
                                Vielleicht hast du ja noch eine Idee ?
                                Gruß,
                                Legoracer
                                Sebastian IOS 1 Antwort Letzte Antwort
                                • L Legoracer70
                                  Gruß,
                                  Legoracer
                                  Sebastian IOS Offline
                                  Sebastian IO
                                  @legoracer70 moin ich kann dir da leider auch nicht so richtig weiterhelfen, mein glück war dass ich noch ein altes smartphone hatte und damit mich mit dem cubinote im 2,4Ghz WLAN verbinden konnte. Der Rest wie man einen Reset macht, müsste ja irgendwo in der Beschreibung/Handbuch stehen. Aber ich kann mich auch erinnern dass es nicht so einfach war den cubinote mit ins wlan zubringen. Evtl. mal im Router schauen ob der Cubinote auftaucht, aber wie gesagt, das kann an vielem liegen.
                                  Sorry!
                                  L 3 Antworten Letzte Antwort
                                    Sorry!
                                    Legoracer70
                                    @sebastian-io Moin, die Situation hat sich gerade gewandelt. Es lag wohl doch an meinen Sonderzeichen im WLAN-Passwort. Damit ich nicht alle WLAN-Geräte mit einem neuen Passwort versorgen muss, habe ich noch einen alten WLAN-Repeater als AP in mein Netz gebracht, wo definitiv kein Sonderzeichen im Passwort vorkommt. Über diesen AP kommt nur noch mein Cubinote ins Netz und was soll ich sagen, es funktioniert endlich. Jetzt kann ich mit der Umsetzung deines Projektes beginnen 😊
                                    Vielen Dank schonmal für dein Feedback.
                                    Gruß,
                                    Legoracer
                                      Sorry!
                                      Legoracer70
                                      @sebastian-io Hallo, die Umsetzung deines Projektes hat ganz gut funktioniert. Nur eins kann ich im Moment nicht nachvollziehen: Der Drucker druckt die Überschrift, z.B. Einkaufsliste, aber die Einträge aus der Liste werden nicht gedruckt. Ich kann in IO-Broker sehen, dass ich zur Zeit 5 Sachen auf meiner Einkaufsliste habe. Aber Keiner wird gedruckt.
                                      Hat jemand die rettende Idee ?
                                      Gruß,
                                      Legoracer
                                        Sorry!
                                        Legoracer70
                                        @sebastian-io Hallo, das leere "json-Feld" hat sich erledigt. Alexa-Instanz gelöscht und neu hinzugefügt und was soll ich sagen: Es funktioniert Alles wunderbar 😊
                                        Danke nochmal für dieses schöne Projekt ...
                                        Gruß,
                                        Legoracer
                                          @mcchickents ich habe das jetzt auch mal direkt in der url eingegeben und als rückgabe im Browser bekomme ich als json format folgende Ausgabe:
                                          showapi_res_code	1
                                          showapi_res_error	"ok"
                                          showapi_devicetype	602
                                          showapi_bindid	807927
                                          Und der Drucker printet:
                                          App name: iobroker-cubinote
                                          Developer: sebastian_io
                                          Verification-Code: .....
                                          Bei dir müsste also dein App Name, Developer etc drin stehen und wenn du das über iobroker machst und den Datenpunkt 0_userdata.0.cubinote.actionStates.check_binding_state auf true setzt, dann sollte eine Sprachausgabe über deine ausgewählte alexa kommen, aber ohne Ausdruck!
                                          ggansde
                                          schrieb am zuletzt editiert von ggansde
                                          @sebastian-io said in [Projekt] Integr. Cubinote - Alexa Sprache drucken - Listen:
                                          showapi_res_code	1
                                          Super interessantes Projekt. Vielen Dank für die ganzen Infos. Ich bin ziemlich ahnungslos, versuche mich aber von Schritt zu Schritt zu hangeln.
                                          VG, Markus
                                          G 1 Antwort Letzte Antwort
