  4. MieleCloudService Adapter
    1.0k
    6.1k
mielemieleathomemielecloudservice
888 Beiträge 93 Kommentatoren 375.4k Aufrufe 99 Beobachtet
  • M MarkA
    Hallo Grizzelbee,
    leider ein anderer Fehler...
    2021-04-07 11:37:35.727 - info: host.iobroker "system.adapter.mielecloudservice.0" enabled
    2021-04-07 11:37:36.072 - info: host.iobroker instance system.adapter.mielecloudservice.0 started with pid 21267
    2021-04-07 11:37:37.575 - info: mielecloudservice.0 (21267) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v12.21.0, js-controller: 3.2.16
    2021-04-07 11:37:38.056 - info: mielecloudservice.0 (21267) Access-Token expires at: [Fri May 07 2021 11:37:00 GMT+0200 (GMT+02:00)]
    2021-04-07 11:37:38.059 - info: mielecloudservice.0 (21267) Setting up devices ...
    2021-04-07 11:37:40.594 - error: mielecloudservice.0 (21267) [APISendRequest] {"message":"Request failed with status code 404","name":"Error","stack":"Error: Request failed with status code 404\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/000000000000/actions","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_a7c7eb85fe2599f38c3cf46b3f31c8b4","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"json":true,"dataType":"json"}} | [Stack]: Error: Request failed with status code 404
    2021-04-07 11:37:40.595 - error: mielecloudservice.0 (21267) Request made and server responded:
    2021-04-07 11:37:40.595 - error: mielecloudservice.0 (21267) Response.status:404
    2021-04-07 11:37:40.596 - error: mielecloudservice.0 (21267) Response.headers: {"date":"Wed, 07 Apr 2021 09:37:40 GMT","content-type":"application/json","content-length":"23","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains, max-age=15724800; includeSubDomains","access-control-allow-credentials":"true","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-origin":"*","x-environment":"mcs-eu-prod-std, mcs-eu-prod-default"}
    2021-04-07 11:37:40.596 - error: mielecloudservice.0 (21267) Response.data: {"message":"Not found"}
    2021-04-07 11:37:40.597 - error: mielecloudservice.0 (21267) [main] :Bullshit!Not found, Stacktrace:Error: Bullshit!Not found
    at APISendRequest (/opt/iobroker/node_modules/iobroker.mielecloudservice/miele-apiTools.js:347:19)
    at runMicrotasks ()
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    @MarkA: An die Lüfterstufe machen wir uns, wenn der Adapter wieder soweit läuft. Also hoffentlich in der V4.0.3 oder V4.0.4
    Das ist kein Problem!
    GrizzelbeeG Offline
    GrizzelbeeG Offline
    Grizzelbee
    #239
    @marka
    Ich könnte ******! Im dicken Strahl!
    Wie kann es sein, dass die API bei der Statusabfrage Geräte meldet und wenn man dann nach deren Fähigkeiten fragt sagt: Kenne ich nicht???
    Kannst Du mir bitte ein komplettes Debug-Log des Adapters vom Start bis zum Crash zur Verfügung stellen? (Log-Herunterladen!)
    • GrizzelbeeG Grizzelbee
      @marka
      MarkA
      schrieb am zuletzt editiert von MarkA
      #240
      @grizzelbee
      ich fürchte, dass hängt mit meinem Kochfeld zusammen, welches keine Seriennummer ausgibt. Wie oben weiter geschrieben auch nicht in dem Gateway oder der App.
      2021-04-07 12:24:56.596 - debug: mielecloudservice.0 (26158) addMieleDevice: NewPath = [Hobs.000000000000]
      2021-04-07 12:24:56.597 - debug: mielecloudservice.0 (26158) addMieleDevice:ident
      2021-04-07 12:24:56.597 - debug: mielecloudservice.0 (26158) addMieleDeviceIdent: Path = [Hobs.000000000000.IDENT]
      2021-04-07 12:24:56.598 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.ComModFirmware] Value[V1.30]
      2021-04-07 12:24:56.598 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.ComModTechType] Value[XKS 3000 Z]
      2021-04-07 12:24:56.598 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.DeviceSerial] Value[000000000000]
      2021-04-07 12:24:56.599 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.DeviceTechType] Value[KM X]
      2021-04-07 12:24:56.599 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.IDENT.DeviceMatNumber] Value[00000000]
      2021-04-07 12:24:56.599 - debug: mielecloudservice.0 (26158) addMieleDevice:state
      2021-04-07 12:24:56.600 - debug: mielecloudservice.0 (26158) createStateDeviceMainState: Path[Hobs.000000000000.Status], setup: [true], path: [Hobs.000000000000.Status], value: [Aus]
      2021-04-07 12:24:56.600 - debug: mielecloudservice.0 (26158) [createNumber]: Path[Hobs.000000000000.Status_raw] Value[1] Unit[]
      2021-04-07 12:24:56.702 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.Status] Value[Aus]
      2021-04-07 12:24:56.703 - debug: mielecloudservice.0 (26158) createStateSignalFailure: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: [false]
      2021-04-07 12:24:56.704 - debug: mielecloudservice.0 (26158) createBool: Path[Hobs.000000000000.signalFailure] Value[false]
      2021-04-07 12:24:56.705 - debug: mielecloudservice.0 (26158) createStateConnected: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: [true]
      2021-04-07 12:24:56.705 - debug: mielecloudservice.0 (26158) createBool: Path[Hobs.000000000000.Connected] Value[true]
      2021-04-07 12:24:56.706 - debug: mielecloudservice.0 (26158) createStateSignalInUse: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: [false]
      2021-04-07 12:24:56.706 - debug: mielecloudservice.0 (26158) createBool: Path[Hobs.000000000000.signalInUse] Value[false]
      2021-04-07 12:24:56.707 - debug: mielecloudservice.0 (26158) createStateActionsInformation: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: []
      2021-04-07 12:24:56.707 - debug: mielecloudservice.0 (26158) createString: Path[Hobs.000000000000.ACTIONS.Action_Information] Value[]
      2021-04-07 12:24:56.708 - debug: mielecloudservice.0 (26158) addDeviceNicknameAction: Path:[Hobs.000000000000], mieleDevice:[{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":27,"value_localized":"Kochfeld"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000000000000","fabIndex":"00","techType":"KM X","matNumber":"00000000","swids":["12869","0"]},"xkmIdentLabel":{"techType":"XKS 3000 Z","releaseVersion":"V1.30"}},"state":{"ProgramID":{"value_raw":2600468480,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":0,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"}],"ecoFeedback":null,"batteryLevel":null}}]
      2021-04-07 12:24:56.709 - debug: mielecloudservice.0 (26158) APISendRequest: Awaiting requested data.
      2021-04-07 12:24:57.004 - debug: mielecloudservice.0 (26158) Given parameters:
      2021-04-07 12:24:57.005 - debug: mielecloudservice.0 (26158) Auth: [{"access_token":"DE_888854539921b0fa76130f94a693c63f","refresh_token":"DE_6ac5e0f47f8d421e508dc166c1c20227","token_type":"Bearer","expires_in":2592000}]
      2021-04-07 12:24:57.005 - debug: mielecloudservice.0 (26158) Endpoint: [v1/devices/000000000000/actions]
      2021-04-07 12:24:57.006 - debug: mielecloudservice.0 (26158) Method: [GET]
      2021-04-07 12:24:57.006 - debug: mielecloudservice.0 (26158) Payload: [""]
      2021-04-07 12:24:57.008 - error: mielecloudservice.0 (26158) [APISendRequest] {"message":"Request failed with status code 404","name":"Error","stack":"Error: Request failed with status code 404\n at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:326:22)\n at endReadableNT (_stream_readable.js:1241:12)\n at processTicksAndRejections (internal/process/task_queues.js:84:21)","config":{"url":"https://api.mcs3.miele.com/v1/devices/000000000000/actions","method":"get","data":"","headers":{"Accept":"application/json","Authorization":"Bearer DE_888854539921b0fa76130f94a693c63f","Content-Type":"application/json","User-Agent":"axios/0.21.1"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"json":true,"dataType":"json"}} | [Stack]: Error: Request failed with status code 404
      2021-04-07 12:24:57.008 - error: mielecloudservice.0 (26158) Request made and server responded:
      2021-04-07 12:24:57.009 - error: mielecloudservice.0 (26158) Response.status:404
      2021-04-07 12:24:57.009 - error: mielecloudservice.0 (26158) Response.headers: {"date":"Wed, 07 Apr 2021 10:24:56 GMT","content-type":"application/json","content-length":"23","connection":"close","strict-transport-security":"max-age=15724800; includeSubDomains, max-age=15724800; includeSubDomains","access-control-allow-credentials":"true","access-control-allow-headers":"DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Authorization","access-control-allow-methods":"PUT, GET, POST, OPTIONS","access-control-allow-origin":"*","x-environment":"mcs-eu-prod-std, mcs-eu-prod-default"}
      2021-04-07 12:24:57.010 - error: mielecloudservice.0 (26158) Response.data: {"message":"Not found"}
      2021-04-07 12:24:57.010 - error: mielecloudservice.0 (26158) [main] :Bullshit!Not found, Stacktrace:Error: Bullshit!Not found
      at runMicrotasks ()
      Reicht das soweit?
      Gruß Mark
      M GrizzelbeeG 2 Antworten Letzte Antwort
      • M MarkA
        @grizzelbee
        at runMicrotasks ()
        Reicht das soweit?
        Gruß Mark
        MarkA
        #241
        @marka said in MieleCloudService Adapter:
        @grizzelbee
        at runMicrotasks ()
        Reicht das soweit?
        Gruß Mark
        Nachtrag:
        Das Kochfeld hat natürlich eine Fabrikationsnummer, die wird nur offensichtlich nicht von dem Kommunikationsmodul erkannt. Kann man die ggfls. in einem Datenpunkt manuell setzen?
        • M MarkA
          @grizzelbee
          at runMicrotasks ()
          Reicht das soweit?
          Gruß Mark
          GrizzelbeeG Offline
          GrizzelbeeG Offline
          Grizzelbee
          schrieb am zuletzt editiert von Grizzelbee
          #242
          @marka sagte in MieleCloudService Adapter:
          Reicht das soweit?
          Leider nicht.
          Bei Start des Adapters logge ich ein großes JSON raus, das die Antwort von Miele auf die Frage nach dem Status aller Geräte enthält.
          Beispiel:
          2021-03-19 11:22:04.887 - info: mielecloudservice.0 (3953) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v12.20.2, js-controller: 3.2.16
          2021-03-19 11:22:04.912 - debug: mielecloudservice.0 (3953) function APIGetAccessToken
          2021-03-19 11:22:04.914 - debug: mielecloudservice.0 (3953) Awaiting OAuth2 Token.
          2021-03-19 11:22:04.915 - debug: mielecloudservice.0 (3953) OAuth2 grant_type: [password]
          2021-03-19 11:22:04.915 - debug: mielecloudservice.0 (3953) options OAuth2-VG: [de-DE]
          2021-03-19 11:22:04.915 - debug: mielecloudservice.0 (3953) config API Language: [de]
          2021-03-19 11:22:05.256 - info: mielecloudservice.0 (3953) Access-Token expires at: [Sun Apr 18 2021 11:22:00 GMT+0200 (GMT+02:00)]
          2021-03-19 11:22:05.257 - info: mielecloudservice.0 (3953) Setting up devices ...
          2021-03-19 11:22:05.257 - debug: mielecloudservice.0 (3953) refreshMieleData: get data from API
          2021-03-19 11:22:05.258 - debug: mielecloudservice.0 (3953) APISendRequest: Awaiting requested data.
          2021-03-19 11:22:05.481 - debug: mielecloudservice.0 (3953) API returned Status: [200]
          2021-03-19 11:22:05.481 - debug: mielecloudservice.0 (3953) refreshMieleData: handover all devices data to splitMieleDevices
          2021-03-19 11:22:05.482 - debug: mielecloudservice.0 (3953) refreshMieleData: data [ HIER STEHT DAS gesuchte JSON DRIN ]
          2021-03-19 11:22:05.482 - debug: mielecloudservice.0 (3953) [splitMieleDevices] Splitting JSON to single devices.
          Mir ging es darum dieses JSON zu sehen weil dort zum einen die ID steht über die ich das Gerät ansprechen kann und zum anderen die FabNummer. Im Beispiel die "000703167977". Hier sind sie identisch - die können aber auch abweichen. Und ich vermute das das hier der Fall ist.
          refreshMieleData: data [{"000703167977":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":17,"value_localized":"Kaffeevollautomat"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000703167977","fabIndex":"15"
          Nachtrag:
          Die Nummer manuell zu setzen würde leider nichts nützen - zumal die bei jedem Datenupdate überschrieben würde. Ich sehe erst einmal zu, dass ich die ID korrekt verwende. Ich vermute aktuell dort einen Bug.
          https://github.com/Grizzelbee/ioBroker.mielecloudservice/issues/109
            Reicht das soweit?
            Leider nicht.
            Beispiel:
            Nachtrag:
            MarkA
            #243
            @grizzelbee
            Hier mehr vom Log:
            2021-04-07 12:24:51.891 - debug: mielecloudservice.0 (26158) refreshMieleData: handover all devices data to splitMieleDevices
            2021-04-07 12:24:51.892 - debug: mielecloudservice.0 (26158) refreshMieleData: data [{"000147896692":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":1,"value_localized":"Waschmaschine"},"deviceName":"Waschmaschine","deviceIdentLabel":{"fabNumber":"000147896692","fabIndex":"14","techType":"WMG823","matNumber":"10499030","swids":["3918","25204","25117","20163","3913","20199","25017","25036","2632","2971","20166"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.72"}},"state":{"ProgramID":{"value_raw":3,"value_localized":"Pflegeleicht","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":256,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[0,0],"spinningSpeed":{"unit":"U/min","value_raw":1100,"value_localized":"1100","key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}},"000139847422":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":2,"value_localized":"Trockner"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000139847422","fabIndex":"11","techType":"TMM843WP","matNumber":"10499110","swids":["3545","25027","25055","20228","3493","20199","25017","25026","3493","20199","25017","25026"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.72"}},"state":{"ProgramID":{"value_raw":20,"value_localized":"Baumwolle","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":2,"value_localized":"Automatikprogramm","key_localized":"Programmart"},"programPhase":{"value_raw":522,"value_localized":"Ende","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[0,0],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":1,"value_localized":"Schranktrocken plus","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}},"mac-00124B000E881998":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":18,"value_localized":"Dunstabzugshaube"},"deviceName":"","deviceIdentLabel":{"fabNumber":"","fabIndex":"","techType":"","matNumber":"","swids":[]},"xkmIdentLabel":{"techType":"","releaseVersion":""}},"state":{"ProgramID":{"value_raw":2449473536,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":271,"value_localized":"Auffrischen + Befeuchten","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":2,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":0,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}},"mac-00124B000E0C6D06":{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":27,"value_localized":"Kochfeld"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000000000000","fabIndex":"00","techType":"KM X","matNumber":"00000000","swids":["12869","0"]},"xkmIdentLabel":{"techType":"XKS 3000 Z","releaseVersion":"V1.30"}},"state":{"ProgramID":{"value_raw":2600468480,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":0,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"}],"ecoFeedback":null,"batteryLevel":null}}}]
            2021-04-07 12:24:51.893 - debug: mielecloudservice.0 (26158) [splitMieleDevices] Splitting JSON to single devices.
            2021-04-07 12:24:51.894 - debug: mielecloudservice.0 (26158) splitMieleDevices: 000147896692: [000147896692] *** Value: [{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":1,"value_localized":"Waschmaschine"},"deviceName":"Waschmaschine","deviceIdentLabel":{"fabNumber":"000147896692","fabIndex":"14","techType":"WMG823","matNumber":"10499030","swids":["3918","25204","25117","20163","3913","20199","25017","25036","2632","2971","20166"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.72"}},"state":{"ProgramID":{"value_raw":3,"value_localized":"Pflegeleicht","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":256,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[0,0],"spinningSpeed":{"unit":"U/min","value_raw":1100,"value_localized":"1100","key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}}]
            Gruß Mark
            GrizzelbeeG 1 Antwort Letzte Antwort
            • M MarkA
              @grizzelbee
              Hier mehr vom Log:
              Gruß Mark
              GrizzelbeeG Offline
              GrizzelbeeG Offline
              Grizzelbee
              #244
              @marka
              Perfekt! Danke schön! :)
              Und da haben wir das Problem auch direkt (wie befürchtet) gefunden:
              Ich frage die Fähigkeiten über die fabNummer (weil üblicherweise identisch mit der ID) ab, müsste aber halt die ID (mac-...) nehmen.
              Dann mache ich mich mal an einen Fix ...
                @marka
                GrizzelbeeG Offline
                GrizzelbeeG Offline
                Grizzelbee
                #245
                V4.0.3 (2021-04-07) (The raven child)
                • (grizzelbee) Fix: 109 fixes 404 error when querying possible actions for device.
                • (grizzelbee) Fix: fixes errors when executing actions on devices with API-Id!=fabNumber
                  MarkA
                  #246
                  @grizzelbee said in MieleCloudService Adapter:
                  Sieht sehr gut aus, keine Fehler mehr im Log!
                  Danke!
                  • M MarkA
                    Danke!
                    GrizzelbeeG Offline
                    GrizzelbeeG Offline
                    Grizzelbee
                    #247
                    BOO-Yaah! :)
                    Danke!
                    Sehr gerne! :) war ja quasi team-work. ;)
                    Was macht die Lüfterstufe?
                      BOO-Yaah! :)
                      Danke!
                      MarkA
                      #248
                      Ich kann leider nur Testen, aber wenn es hilft, dann gerne :D
                      Die Lüfterstufe hat leider noch ein leeres DropDown Feld.
                      Nachtrag:
                      Wenn ich den Adapter stoppe, die Datenpunkte für die Haube lösche, dann kommt noch der Fehler:
                       warn: mielecloudservice.0 (3387) State "mielecloudservice.0.Hoods.mac-IDhere.ACTIONS.VentilationStep" has no existing object, this might lead to an error in future versions
                      Nach einem weiteren Neustart kommt die Meldung nicht mehr - wird der vielleicht zur falschen Zeit erwartet / geprüft?
                      • M MarkA
                        Nachtrag:
                        GrizzelbeeG Offline
                        GrizzelbeeG Offline
                        Grizzelbee
                        #249
                        Okay. Was sagt denn das Debug-Log dazu? Da müsste es ein paar Einträge geben.
                          MarkA
                          #250
                          das sieht für mich so aus, als wenn der SP ohne Inhalt angelegt wird.
                          Bei dem "alten" Drop Down DP, der nicht im ACTIONS Pfad war, war die Auswahl vorhanden, aber ohne Funktion.
                          Auszug:
                          2021-04-07 16:03:53.498 - debug: mielecloudservice.0 (25477) Device: [mac-00124B000E881998] has no serial number/fabNumber. Taking DeviceNumber instead.
                          2021-04-07 16:03:53.498 - debug: mielecloudservice.0 (25477) This is a Dunstabzugshaube
                          2021-04-07 16:03:53.499 - debug: mielecloudservice.0 (25477) _knownDevices={"000147896692":{"deviceFolder":"Washing_machines","name":"Washing machines reported by Miele@Home API","icon":"icons/01_washingmachine.svg","API_Id":"000147896692"},"000139847422":{"deviceFolder":"Tumble_dryers","name":"Tumble dryers reported by Miele@Home API","icon":"icons/02_dryer.svg","API_Id":"000139847422"},"mac-00124B000E881998":{"deviceFolder":"Hoods","name":"Hoods reported by Miele@Home API","icon":"icons/18_hood.svg","API_Id":"mac-00124B000E881998"}}
                          2021-04-07 16:03:53.499 - debug: mielecloudservice.0 (25477) addMieleDevice: NewPath = [Hoods.mac-00124B000E881998]
                          2021-04-07 16:03:53.500 - debug: mielecloudservice.0 (25477) addMieleDevice:ident
                          2021-04-07 16:03:53.501 - debug: mielecloudservice.0 (25477) addMieleDeviceIdent: Path = [Hoods.mac-00124B000E881998.IDENT]
                          2021-04-07 16:03:53.501 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.ComModFirmware] Value[]
                          2021-04-07 16:03:53.502 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.ComModTechType] Value[]
                          2021-04-07 16:03:53.502 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.DeviceSerial] Value[mac-00124B000E881998]
                          2021-04-07 16:03:53.503 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.DeviceTechType] Value[]
                          2021-04-07 16:03:53.503 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.IDENT.DeviceMatNumber] Value[]
                          2021-04-07 16:03:53.504 - debug: mielecloudservice.0 (25477) addMieleDevice:state
                          2021-04-07 16:03:53.504 - debug: mielecloudservice.0 (25477) createStateDeviceMainState: Path[Hoods.mac-00124B000E881998.Status], setup: [true], path: [Hoods.mac-00124B000E881998.Status], value: [Aus]
                          2021-04-07 16:03:53.504 - debug: mielecloudservice.0 (25477) [createNumber]: Path[Hoods.mac-00124B000E881998.Status_raw] Value[1] Unit[]
                          2021-04-07 16:03:53.678 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.Status] Value[Aus]
                          2021-04-07 16:03:53.678 - debug: mielecloudservice.0 (25477) createStateSignalFailure: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                          2021-04-07 16:03:53.679 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.signalFailure] Value[false]
                          2021-04-07 16:03:53.679 - debug: mielecloudservice.0 (25477) createStateConnected: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [true]
                          2021-04-07 16:03:53.680 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.Connected] Value[true]
                          2021-04-07 16:03:53.680 - debug: mielecloudservice.0 (25477) createStateSignalInUse: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                          2021-04-07 16:03:53.680 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.signalInUse] Value[false]
                          2021-04-07 16:03:53.681 - debug: mielecloudservice.0 (25477) createStateActionsInformation: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: []
                          2021-04-07 16:03:53.681 - debug: mielecloudservice.0 (25477) createString: Path[Hoods.mac-00124B000E881998.ACTIONS.Action_Information] Value[]
                          2021-04-07 16:03:53.681 - debug: mielecloudservice.0 (25477) addDeviceNicknameAction: Path:[Hoods.mac-00124B000E881998], mieleDevice:[{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":18,"value_localized":"Dunstabzugshaube"},"deviceName":"","deviceIdentLabel":{"fabNumber":"mac-00124B000E881998","fabIndex":"","techType":"","matNumber":"","swids":[]},"xkmIdentLabel":{"techType":"","releaseVersion":""}},"state":{"ProgramID":{"value_raw":2449473536,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":271,"value_localized":"Auffrischen + Befeuchten","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":2,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":0,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[],"ecoFeedback":null,"batteryLevel":null}}]
                          2021-04-07 16:03:53.682 - debug: mielecloudservice.0 (25477) APISendRequest: Awaiting requested data.
                          2021-04-07 16:03:53.980 - debug: mielecloudservice.0 (25477) API returned Status: [200]
                          2021-04-07 16:03:53.981 - debug: mielecloudservice.0 (25477) CurrentlyPermittedActions: {"processAction":[],"light":[1],"ambientLight":[],"startTime":[],"ventilationStep":[1,2,3,4],"programId":[],"targetTemperature":[],"deviceName":false,"powerOn":true,"powerOff":false,"colors":[],"modes":[]}
                          2021-04-07 16:03:53.982 - debug: mielecloudservice.0 (25477) addPowerSwitch: Path[Hoods.mac-00124B000E881998]
                          2021-04-07 16:03:53.982 - debug: mielecloudservice.0 (25477) [checkPowerAction]: Device [Hoods.mac-00124B000E881998]: PowerOn is permitted!
                          2021-04-07 16:03:53.982 - debug: mielecloudservice.0 (25477) addPowerSwitch: result from getPowerState: [Off]
                          2021-04-07 16:03:53.983 - debug: mielecloudservice.0 (25477) addLightSwitch: Path[Hoods.mac-00124B000E881998]
                          2021-04-07 16:03:53.984 - debug: mielecloudservice.0 (25477) [checkPowerAction]: Device [Hoods.mac-00124B000E881998]: PowerOn is permitted!
                          2021-04-07 16:03:53.984 - debug: mielecloudservice.0 (25477) addLightSwitch: result from getLightState: [Off]
                          2021-04-07 16:03:53.985 - debug: mielecloudservice.0 (25477) addStopButton: Path[Hoods.mac-00124B000E881998]
                          2021-04-07 16:03:53.986 - debug: mielecloudservice.0 (25477) addVentilationStepSwitch: Path[Hoods.mac-00124B000E881998]
                          2021-04-07 16:03:53.986 - debug: mielecloudservice.0 (25477) addColorsAction: Path[Hoods.mac-00124B000E881998]
                          2021-04-07 16:03:53.987 - debug: mielecloudservice.0 (25477) createStateSignalInfo: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                          2021-04-07 16:03:53.987 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.signalInfo] Value[false]
                          2021-04-07 16:03:53.988 - debug: mielecloudservice.0 (25477) createStateFullRemoteControl: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                          2021-04-07 16:03:53.988 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.fullRemoteControl] Value[false]
                          2021-04-07 16:03:53.988 - debug: mielecloudservice.0 (25477) createStateSmartGrid: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                          2021-04-07 16:03:53.989 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.smartGrid] Value[false]
                          2021-04-07 16:03:53.989 - debug: mielecloudservice.0 (25477) createStateMobileStart: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: [false]
                          2021-04-07 16:03:53.989 - debug: mielecloudservice.0 (25477) createBool: Path[Hoods.mac-00124B000E881998.mobileStart] Value[false]
                          2021-04-07 16:03:53.990 - debug: mielecloudservice.0 (25477) createStateVentilationStep: Path[Hoods.mac-00124B000E881998], setup: [true], path: [Hoods.mac-00124B000E881998], value: []
                          2021-04-07 16:03:53.990 - debug: mielecloudservice.0 (25477) addVentilationStepSwitch: Path[Hoods.mac-00124B000E881998]
                          2021-04-07 16:03:53.991 - debug: mielecloudservice.0 (25477) splitMieleDevices: mac-00124B000E0C6D06: [mac-00124B000E0C6D06] *** Value: [{"ident":{"type":{"key_localized":"Gerätetyp","value_raw":27,"value_localized":"Kochfeld"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000000000000","fabIndex":"00","techType":"KM X","matNumber":"00000000","swids":["12869","0"]},"xkmIdentLabel":{"techType":"XKS 3000 Z","releaseVersion":"V1.30"}},"state":{"ProgramID":{"value_raw":2600468480,"value_localized":"","key_localized":"Programmbezeichnung"},"status":{"value_raw":1,"value_localized":"Aus","key_localized":"Status"},"programType":{"value_raw":0,"value_localized":"Programm","key_localized":"Programmart"},"programPhase":{"value_raw":0,"value_localized":"","key_localized":"Programmphase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[],"temperature":[],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":false,"smartGrid":false,"mobileStart":false},"ambientLight":null,"light":null,"elapsedTime":[],"spinningSpeed":{"unit":"U/min","value_raw":null,"value_localized":null,"key_localized":"Schleuderdrehzahl"},"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Trockenstufe"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Lüfterstufe"},"plateStep":[{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"},{"value_raw":0,"value_localized":"0","key_localized":"Leistungsstufe"}],"ecoFeedback":null,"batteryLevel":null}}]
                          2021-04-07 16:03:53.991 - debug: mielecloudservice.0 (25477) This is a Kochfeld
                          2021-04-07 16:03:53.991 - debug: mielecloudservice.0 (25477) _knownDevices={"000147896692":{"deviceFolder":"Washing_machines","name":"Washing machines reported by Miele@Home API","icon":"icons/01_washingmachine.svg","API_Id":"000147896692"},"000139847422":{"deviceFolder":"Tumble_dryers","name":"Tumble dryers reported by Miele@Home API","icon":"icons/02_dryer.svg","API_Id":"000139847422"},"mac-00124B000E881998":{"deviceFolder":"Hoods","name":"Hoods reported by Miele@Home API","icon":"icons/18_hood.svg","API_Id":"mac-00124B000E881998"},"000000000000":{"deviceFolder":"Hobs","name":"Hobs reported by Miele@Home API","icon":"icons/14_hobhighlight.svg","API_Id":"mac-00124B000E0C6D06"}}
                          2021-04-07 16:03:53.992 - debug: mielecloudservice.0 (25477) addMieleDevice: NewPath = [Hobs.000000000000]
                          2021-04-07 16:03:53.992 - debug: mielecloudservice.0 (25477) addMieleDevice:ident
                          2021-04-07 16:03:53.993 - debug: mielecloudservice.0 (25477) addMieleDeviceIdent: Path = [Hobs.000000000000.IDENT]
                          2021-04-07 16:03:53.993 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.ComModFirmware] Value[V1.30]
                          2021-04-07 16:03:53.993 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.ComModTechType] Value[XKS 3000 Z]
                          2021-04-07 16:03:53.994 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.DeviceSerial] Value[000000000000]
                          2021-04-07 16:03:53.994 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.DeviceTechType] Value[KM X]
                          2021-04-07 16:03:53.995 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.IDENT.DeviceMatNumber] Value[00000000]
                          2021-04-07 16:03:53.995 - debug: mielecloudservice.0 (25477) addMieleDevice:state
                          2021-04-07 16:03:53.995 - debug: mielecloudservice.0 (25477) createStateDeviceMainState: Path[Hobs.000000000000.Status], setup: [true], path: [Hobs.000000000000.Status], value: [Aus]
                          2021-04-07 16:03:53.995 - debug: mielecloudservice.0 (25477) [createNumber]: Path[Hobs.000000000000.Status_raw] Value[1] Unit[]
                          2021-04-07 16:03:54.007 - warn: mielecloudservice.0 (25477) State "mielecloudservice.0.Hoods.mac-00124B000E881998.ACTIONS.VentilationStep" has no existing object, this might lead to an error in future versions
                          2021-04-07 16:03:54.195 - debug: mielecloudservice.0 (25477) createString: Path[Hobs.000000000000.Status] Value[Aus]
                          2021-04-07 16:03:54.196 - debug: mielecloudservice.0 (25477) createStateSignalFailure: Path[Hobs.000000000000], setup: [true], path: [Hobs.000000000000], value: [false]
                          • M MarkA
                            Auszug:
                            GrizzelbeeG Offline
                            GrizzelbeeG Offline
                            Grizzelbee
                            #251
                            @marka
                            Hier mal ein Versuch dazu:
                            V4.0.4 (2021-04-07) (Wastelands)
                            • (grizzelbee) Fix: fixes ventilation step switch for hoods
                            M 2 Antworten Letzte Antwort
                              @marka
                              MarkA
                              #252
                              Es bleibt nach der Aktualisierung bei der 4.0.3 - ist das korrekt?
                              • M MarkA
                                GrizzelbeeG Offline
                                GrizzelbeeG Offline
                                Grizzelbee
                                #253
                                Ja. Das habe ich im Überschwang der Gefühle verbaselt. Habe das aber gerade noch schnell gefixed. Versionsnummer jetzt auch Ok - bleibt inhaltlich aber das Selbe.
                                  M-A-X
                                  #254
                                  Wenn ich über die Katze Update (auf 4.0.4) muss ich dann was ändern damit ich das nächste Release 'normal' updaten kann? Bzw wird mir das nächste Release automatisch bei Updates angezeigt? Oder muss ich ab dann immer über die Katze updaten?
                                  Hab etwas Respekt davor :)
                                  • M M-A-X
                                    #255
                                    @m-a-x
                                    Wenn die Versionsnummer über den regulären Zweig größer wird als die über git installierte wird die 'reguläre' dann bevorzugt werden.
                                      @marka
                                      MarkA
                                      #256
                                      @marka
                                      Die aktuelle Lüfterstufe wird jetzt angezeigt, soweit mehr als vorher.
                                      Das DropDown Feld ist leider immer noch leer. Ich kann über den Bleistift zwar eine 2 oder 3 eintragen, aber leider wird die dann rot und Action_Information auf {}
                                      Log:
                                      2021-04-07 17:42:25.000 - debug: mielecloudservice.0 (35850) ack is not set!
                                      2021-04-07 17:42:25.001 - debug: mielecloudservice.0 (35850) stateChange [mielecloudservice.0.Hoods.mac-00124B000E881998.ACTIONS.VentilationStep] [{"val":2,"ack":false,"ts":1617810144999,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1617810144999}]
                                      2021-04-07 17:42:25.001 - debug: mielecloudservice.0 (35850) APIStartAction: received Action: [VentilationStep] with value: [2] for device [mac-00124B000E881998] / path:[mielecloudservice.0.Hoods.mac-00124B000E881998.ACTIONS]
                                      2021-04-07 17:42:25.002 - debug: mielecloudservice.0 (35850) APIStartAction: Executing Action: [undefined]
                                      2021-04-07 17:42:25.002 - debug: mielecloudservice.0 (35850) createString: Path[mielecloudservice.0.Hoods.mac-00124B000E881998.ACTIONS.Action_Information] Value[{}]
                                      2021-04-07 17:42:25.003 - error: mielecloudservice.0 (35850) [APIStartAction] {}
                                      leider geht das Licht jetzt nicht mehr zu schalten. Log:
                                      2021-04-07 17:44:42.666 - debug: mielecloudservice.0 (35850) ack is not set!
                                      2021-04-07 17:44:42.668 - debug: mielecloudservice.0 (35850) stateChange [mielecloudservice.0.Hoods.mac-00124B000E881998.ACTIONS.Light] [{"val":"Off","ack":false,"ts":1617810282664,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1617810282664}]
                                      2021-04-07 17:44:42.668 - debug: mielecloudservice.0 (35850) APIStartAction: received Action: [Light] with value: [Off] for device [mac-00124B000E881998] / path:[mielecloudservice.0.Hoods.mac-00124B000E881998.ACTIONS]
                                      2021-04-07 17:44:42.669 - debug: mielecloudservice.0 (35850) APIStartAction: Executing Action: [{"light":2}]
                                      2021-04-07 17:44:42.669 - debug: mielecloudservice.0 (35850) createString: Path[mielecloudservice.0.Hoods.mac-00124B000E881998.ACTIONS.Action_Information] Value[{}]
                                      2021-04-07 17:44:42.670 - error: mielecloudservice.0 (35850) [APIStartAction] {}
                                        M-A-X
                                        #257
                                        4.0.4 funktioniert hier ohne Probleme. Ich hab aber nur eine Waschmaschine die gerade läuft :)
                                        • M MarkA
                                          @marka
                                          Log:
                                          GrizzelbeeG Offline
                                          GrizzelbeeG Offline
                                          Grizzelbee
                                          #258
                                          @marka
                                          Ich bin ja auch sehr für Datensparsamkeit, aber leider sind die Log-Ausschnitte wieder sehr knapp gefasst. Für mich sind eigentlich immer zwei bis drei Abschnitte interessant:
                                          1. Unmittelbar nach dem Start ist der Adapter einmalig im Setup-Modus. Da werden alle Datenpunkte angelegt.
                                          2. Das aktuelle Statusupdate.
                                          3. Der aktuelle Fehler. Von der Initialisierung (wenn Action) bis zum kompletten Stacktrace.
                                          Kannst Du mir das für die beiden aktuellen Themen (VentilationStep und Light) mal liefern?
