  4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
    6.6k
xiaomiviomi
108 Beiträge 19 Kommentatoren 22.7k Aufrufe 26 Beobachtet
  • A audi1503
    @Meistertr
    Hier die angeforderten Antworten auf den Kommandos:
    "battery": {"siid": 3, "piid": 1},                = [{"did":"334314795","siid":3,"piid":1,"code":0,"value":100}]
    "charge_state": {"siid": 3, "piid": 2},           = [{"did":"334314795","siid":3,"piid":2,"code":0,"value":2}]
    "error": {"siid": 2, "piid": 2},                  = [{"did":"334314795","siid":2,"piid":2,"code":0,"value":0}]
    "state": {"siid": 2, "piid": 1},                  = [{"did":"334314795","siid":2,"piid":1,"code":0,"value":5}]
    "fan_speed": {"siid": 2, "piid": 6},              = [{"did":"334314795","siid":2,"piid":6,"code":0,"value":1}]
    "operating_mode": {"siid": 2, "piid": 4},         = [{"did":"334314795","siid":2,"piid":4,"code":0,"value":1}]
    "mop_state": {"siid": 16, "piid": 1},             = [{"did":"334314795","siid":16,"piid":1,"code":0,"value":0}]
    "water_level": {"siid": 2, "piid": 5},            = [{"did":"334314795","siid":2,"piid":5,"code":0,"value":2}]
    "brush_life_level": {"siid": 14, "piid": 1},      = [{"did":"334314795","siid":14,"piid":1,"code":0,"value":58}]
    #  "brush_life_time": {"siid": 14, "piid": 2},    = [{"did":"334314795","siid":14,"piid":2,"code":0,"value":10504}]
    "brush_life_level2": {"siid": 15, "piid": 1},     = [{"did":"334314795","siid":15,"piid":1,"code":0,"value":14}]
    #  "brush_life_time2": {"siid": 15, "piid": 2},   = [{"did":"334314795","siid":15,"piid":2,"code":0,"value":1280}]
    "filter_life_level": {"siid": 11, "piid": 1},     = [{"did":"334314795","siid":11,"piid":1,"code":0,"value":16}]
    #  "filter_life_time": {"siid": 11, "piid": 2},   = [{"did":"334314795","siid":11,"piid":2,"code":0,"value":1504}]
    "clean_area": {"siid": 9, "piid": 1},             = [{"did":"334314795","siid":9,"piid":1,"code":0,"value":0}]
    "clean_time": {"siid": 18, "piid": 5},            = [{"did":"334314795","siid":18,"piid":5,"code":-4003}]
    "total_clean_count": {"siid": 9, "piid": 5},      = [{"did":"334314795","siid":9,"piid":5,"code":0,"value":0}]
    #   "total_clean_area": {"siid": 9, "piid": 3},   = [{"did":"334314795","siid":9,"piid":3,"code":0,"value":0}]
    #  "dnd_enabled": {"siid": 12, "piid": 2},        = [{"did":"334314795","siid":12,"piid":2,"code":0,"value":false}]
    #  "audio_volume": {"siid": 4, "piid": 2},        = [MESSAGE TIMEOUT]
    #  "direction_key": {"siid": 8, "piid": 1}        = [{"did":"334314795","siid":8,"piid":1,"code":-4003}]
    Habe im Log auch noch Model mijia.vacuum.v2 not supported stehen
    MeistertrM Offline
    MeistertrM Offline
    Meistertr
    #93
    @audi1503 sehr cool, damit kann ich ihn einbinden, dauert aber noch ein paar tage bis den adapter umgeschrieben habe
    • MeistertrM Meistertr
      audi1503
      #94
      @meistertr 👍 Kein Stress
        @audi1503 sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
        mijia.vacuum.v2
        bitte den Adapter installieren (rebulid3) einloggen und devices abrufen, Sauger auswählen eigene Kommandos aktivieren in config, speichern (nicht schließen) auf der ersten Seite oben rechts config downloaden2021-04-04_20h20_46.png
        deviceId in ein leeres Textfile speichern
        folgende Kommandos in untenstehender Form unter Objekten2021-04-04_19h53_04.png
        bei send_command eingeben
        Antworten bitte in ein Textfile kopieren, neben die Kommandos und posten
        Kommandos (PIID und SIID)
            # https://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:vacuum:0000A006:mijia-v1:1
        das ist die form wie es in das Objekt muss:
        get_properties;[{"did":"AUSCONFIG","siid":3,"piid":1}]
        Bitte einmal durchtesten
        kakacs
        #95
        @meistertr Screenshot_2021-04-04 objects - ioBroker(3).png Screenshot_2021-04-04 logs - ioBroker.png
        • K kakacs
          kakacs
          #96
          @Meistertr @audi1503 ich habe es geschaft eine szene zu erstellen im iobroker und sie wird auch in alexa erkannt über iobroker.io. aber leider kann ich den staubsauger nicht starten. ich denke es liegt daran das der status unter objekten der xiaomi adapter sich nicht aktualiesiert. auch wenn ich den sauger über die app starte aktualiesiert sich da kein wert. kann man was da machen ??
          MeistertrM 1 Antwort Letzte Antwort
          • K kakacs
            MeistertrM Offline
            MeistertrM Offline
            Meistertr
            #97
            @kakacs nein daran liegt es nicht, du musst im iot Adapter sagen dass es ein Button ist. Versuch mal die Nachrichten mit siid und piid zu senden vll ist der robo mit miot erreichbar
            K 2 Antworten Letzte Antwort
              kakacs
              #98
              @meistertr hi guten morgen wie meinst du das mit den nachrichten mit siid und pid zu senden ??
                kakacs
                #99
                @meistertr hab es hin bekommen super danke für die tolle hilfe
                • K kakacs
                  kakacs
                  #100
                  @kakacs ich bekomm in jetzt gestartet aber macht er auch dann die karte die in der app ist. weil in objekten wo clean/home steht in werten steht da nix kann ich irgend wie die karte in den iobroker intregrieren??
                  • K kakacs
                    MeistertrM Offline
                    MeistertrM Offline
                    Meistertr
                    #101
                    @kakacs ein paar Nachrichten weiter oben
                      mijia.vacuum.v2
                      kakacs
                      #102
                      @meistertr meinst du das hier ???ß
                      • K kakacs
                        MeistertrM Offline
                        MeistertrM Offline
                        Meistertr
                        #103
                        @kakacs jep
                          @kakacs jep
                          kakacs
                          #104
                          @meistertr ok aber irgendwie verstehe ich nicht wo ich das eingeben soll kanns tdu mir noch mal da helfen bitte
                          • K kakacs
                            MeistertrM Offline
                            MeistertrM Offline
                            Meistertr
                            #105
                            @kakacs die Kommunikation besteht aus Frage und Antwort. Wenn man ihm eine Frage sendet, denkt der Roboter eine Antwort. Wie oben im Beitrag beschrieben. Die Frage in sendcommand eingeben und die Antwort vom Roboter kommt dann in dem Response Objekt an, und wird auch im log angezeigt
                              kakacs
                              schrieb am zuletzt editiert von kakacs
                              #106
                              @meistertr wenn ich in send command get_status schreibe kommt als antwort Message_Timeout
                              und wenn ich send command get_prob;["all"] kommt das gleiche Message_Timeout Screenshot_2021-04-05 logs - ioBroker(1).png
                              Screenshot_2021-04-05 objects - ioBroker(1).png Screenshot_2021-04-05 objects - ioBroker.png
                              • K kakacs
                                MeistertrM Offline
                                MeistertrM Offline
                                Meistertr
                                #107
                                @kakacs tut mir leid, genauer kann ich es nicht erklären. Ich versuche es automatisch im Adapter zu integrieren.
                                  MeistertrM Offline
                                  MeistertrM Offline
                                  Meistertr
                                  #108
                                  hier gehts weiter https://forum.iobroker.net/topic/44077/test-adapter-mihome-vacuum-v3-x-x-next-generarition?_=1618125097897
