  4. [gelöst] Fehler bei Adapter Installation
12 Beiträge 3 Kommentatoren 375 Aufrufe 3 Beobachtet
    Dragon
    schrieb am zuletzt editiert von Dragon
    Habe bei Adapter install einen Fehler...
    npm install iobroker.cec2@0.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.0/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~In file included from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’ NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.10.17-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.22.0
    gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    hier ist der komplette log bei install:
    $ ./iobroker add cec2  --host ioBroker
    NPM version: 6.14.11
    host.ioBroker install adapter cec2
    upload [4] cec2.admin /opt/iobroker/node_modules/iobroker.cec2/admin/words.js words.js application/javascript
    upload [3] cec2.admin /opt/iobroker/node_modules/iobroker.cec2/admin/style.css style.css text/css
    upload [2] cec2.admin /opt/iobroker/node_modules/iobroker.cec2/admin/index_m.html index_m.html text/html
    upload [1] cec2.admin /opt/iobroker/node_modules/iobroker.cec2/admin/cec2.png cec2.png image/png
    upload [0] cec2.admin /opt/iobroker/node_modules/iobroker.cec2/admin/admin.d.ts admin.d.ts video/mp2t
    host.ioBroker object system.adapter.cec2 created/updated
    host.ioBroker create instance cec2
    host.ioBroker object cec2.0.info.connection created
    host.ioBroker object cec2.0.info created
    host.ioBroker object system.adapter.cec2.0.logLevel created
    host.ioBroker object system.adapter.cec2.0.sigKill created
    host.ioBroker object system.adapter.cec2.0.eventLoopLag created
    host.ioBroker object system.adapter.cec2.0.outputCount created
    host.ioBroker object system.adapter.cec2.0.inputCount created
    host.ioBroker object system.adapter.cec2.0.uptime created
    host.ioBroker object system.adapter.cec2.0.memRss created
    host.ioBroker object system.adapter.cec2.0.memHeapTotal created
    host.ioBroker object system.adapter.cec2.0.memHeapUsed created
    host.ioBroker object system.adapter.cec2.0.cputime created
    host.ioBroker object system.adapter.cec2.0.cpu created
    host.ioBroker object system.adapter.cec2.0.compactMode created
    host.ioBroker object system.adapter.cec2.0.connected created
    host.ioBroker object system.adapter.cec2.0.alive created
    host.ioBroker Set default value of cec2.0.info.connection: false
    host.ioBroker object system.adapter.cec2.0 created
    process exited with code 0
    Die Installation ist neu. Beim einspielen des Backups hat er mit diesem Fehler nach ca 20 Adaptern begonnen und ich habe ihn nicht wieder wegbekommen... npm rebuild und fix Skript sind durch ändern aber nichts.
    O Thomas BraunT 2 Antworten Letzte Antwort
    • D Dragon
      O Offline
      O Offline
      oFbEQnpoLKKl6mbY5e13
      @dragon
      Wer hat den Fehler nicht?!
      Kannst du ignorieren. Oder funktioniert etwas nicht?
      • D Dragon
        @dragon
        Terminal-Adapter installiert?
        Schmeiß den mal raus.
        • O oFbEQnpoLKKl6mbY5e13
          @dragon
          Dragon
          @ofbeqnpolkkl6mby5e13
          Wenn dem so ist bin ich beruhigt. Hatte nur im Forum mal gesucht und es wurden zumindest Lösungsvorschläge angeboten, welche bei mir nicht halfen. Wenn es einfach zu ignorieren ist werde ich das natürlich tun...
            @dragon
            Dragon
            @thomas-braun Ja habe ich. Und versuche ich natürlich
            O 1 Antwort Letzte Antwort
            • D Dragon
              O Offline
              O Offline
              @dragon
              node-gyp ist ein Klassiker.
                @dragon
                @oFbEQnpoLKKl6mbY5e13
                Was meinst du mit Klassiker? Node-gyp wird bei jedem Bau von Modulen verwendet.
                  O Offline
                  O Offline
                  Dass es einen Fehler bei bestimmten Modulen gibt. Zum Beispiel Unix-dgram usw.
                  D Thomas BraunT 2 Antworten Letzte Antwort
                    Dragon
                    Hattest recht. Problem gelöst
                    • D Dragon
                      @dragon Was löste dein Problem?
                        Dragon
                        @thomas-braun Deinstallieren vom Terminal Adapter
                          @ofbeqnpolkkl6mby5e13 Was ist mit unix-dgram? Und wo ist der Bezug zu diesem Thread?
