  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
2.5k Beiträge 163 Kommentatoren 1.3m Aufrufe 150 Beobachtet
  • M Michaelnorge
    Hab den Adapter eine ganze Nacht am Laufen gehabt und bekomme regelmässig alle 30 Minuten diese Fehlermeldungen:
    bluelink.0	2021-03-29 04:05:51.036	error	(10840) @EuropeVehicle.Fullstatus: [401] Unauthorized on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/location - {"error":"Key not authorized:
    bluelink.0	2021-03-29 04:05:51.035	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    bluelink.0	2021-03-29 04:05:51.035	error	at P (/opt/iobroker/node_modules/kuvork/dist/index.js:17:136)
    bluelink.0	2021-03-29 04:05:51.035	error	at Generator.throw (<anonymous>)
    bluelink.0	2021-03-29 04:05:51.035	error	at NN.<anonymous> (/opt/iobroker/node_modules/kuvork/dist/index.js:17:154415)
    bluelink.0	2021-03-29 04:05:51.035	error	at o.manageBluelinkyError (/opt/iobroker/node_modules/kuvork/dist/index.js:17:12327)
    bluelink.0	2021-03-29 04:05:51.035	error	at new h (/opt/iobroker/node_modules/kuvork/dist/index.js:17:12108)
    bluelink.0	2021-03-29 04:05:51.035	error	(10840) ManagedBluelinkyError: @EuropeVehicle.Fullstatus: [401] Unauthorized on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/location - {"error
    bluelink.0	2021-03-29 04:05:51.032	error	(10840) unhandled promise rejection: @EuropeVehicle.Fullstatus: [401] Unauthorized on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/location - {
    bluelink.0	2021-03-29 04:05:51.031	error	(10840) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    NewanN Offline
    NewanN Offline
    Newan
    @michaelnorge sieht so aus als würde der api tocken ausgelaufen sein. Läuft aber weiter?
    M 2 Antworten Letzte Antwort
    • NewanN Newan
      Michaelnorge
      @newan Ja kein Problem, läuft weiter.
      • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
      • NewanN Newan
        Michaelnorge
        @newan said in Adapter Hyundai (Bluelink) oder KIA (UVO):
        Jetzt hat er sich der Adapter doch aufgehängt, allerdings ist der Fehler ein Anderer:
        host.raspberrypi	2021-03-29 08:23:00.781	warn	Do not restart adapter system.adapter.bluelink.0 because restart loop detected
        host.raspberrypi	2021-03-29 08:23:00.781	info	Restart adapter system.adapter.bluelink.0 because enabled
        host.raspberrypi	2021-03-29 08:23:00.780	error	instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        bluelink.0	2021-03-29 08:23:00.145	warn	(23677) Terminated (UNCAUGHT_EXCEPTION): Without reason
        bluelink.0	2021-03-29 08:23:00.144	info	(23677) terminating
        bluelink.0	2021-03-29 08:23:00.143	info	(23677) Adapter bluelink cleaned up everything...
        bluelink.0	2021-03-29 08:23:00.014	error	(23677) @EuropeVehicle.Fullstatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-x-xxxxxxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","
        bluelink.0	2021-03-29 08:23:00.014	error	at process._tickCallback (internal/process/next_tick.js:68:7)
        bluelink.0	2021-03-29 08:23:00.014	error	at P (/opt/iobroker/node_modules/kuvork/dist/index.js:17:136)
        bluelink.0	2021-03-29 08:23:00.014	error	at Generator.throw (<anonymous>)
        bluelink.0	2021-03-29 08:23:00.014	error	at NN.<anonymous> (/opt/iobroker/node_modules/kuvork/dist/index.js:17:154415)
        bluelink.0	2021-03-29 08:23:00.014	error	at o.manageBluelinkyError (/opt/iobroker/node_modules/kuvork/dist/index.js:17:12327)
        bluelink.0	2021-03-29 08:23:00.014	error	at new h (/opt/iobroker/node_modules/kuvork/dist/index.js:17:12108)
        bluelink.0	2021-03-29 08:23:00.014	error	(23677) ManagedBluelinkyError: @EuropeVehicle.Fullstatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode"
        bluelink.0	2021-03-29 08:23:00.013	error	(23677) unhandled promise rejection: @EuropeVehicle.Fullstatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"re
        bluelink.0	2021-03-29 08:23:00.012	error	(23677) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        bluelink.0	2021-03-29 08:22:59.101	info	(23677) Read new status from api
        bluelink.0	2021-03-29 08:22:59.055	info	(23677) Vehicles found
        bluelink.0	2021-03-29 08:22:55.118	info	(23677) Login to ap
        Jetzt scheint allerdings das System selbst einen Loop entdeckt zu haben und weigert sich, bluelink.0 neu zu starten.
        Das wäre im Übrigen keine schlechte Idee, direkt bei den Objekten ein "online-true" zu haben, dann sieht man immer auf den ersten Blick wenn der Adapter nicht läuft. Man kann sich dann warnen lassen oder es wird in der VIS angezeigt.
        • NewanN Newan
          @mmemme sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
          @newan super Adapter, hatte gestern bereits die erste Version installiert und konnte auch meinen Ladezustand in % (soc) sehen. Seitdem ich upgegraded habe ist der Wert Leer. Generell werden keine Werte für die Battery geladen. Ideen?
          Update, es gibt nun den Wert "Vehicle minutes to charged", schau mal bitte ob der für dich passt. Falls nicht gibt es im Debug log folgendes:
          bluelink.0	2021-03-28 23:10:52.261	debug	(6875) {"etc1":{"value":97,"unit":1},"etc2":{"value":1150,"unit":1},"etc3":{"value":340,"unit":1},"atc":{"value":335,"unit":1}}
          bluelink.0	2021-03-28 23:10:52.260	debug	(6875) Folgende Ladezeiten Moeglichkeiten wurden gefunden:
          Derzeit nutze ich atc!
          mmemme
          @newan vielen Dank, habe es gerade getestet und sehe als objekt "Vehicle minutes to charged" allerdings ist auch dieser Wert leer.
          Ich sehe auch viele error messages im Log:
          2021-03-29 12:37:00.713 - info: bluelink.0 (9873) Login to api
          2021-03-29 12:37:05.140 - info: bluelink.0 (9873) Vehicles found
          2021-03-29 12:37:05.204 - info: bluelink.0 (9873) Read new status from api
          2021-03-29 12:37:12.182 - info: bluelink.0 (9873) Set new status
          2021-03-29 12:37:12.200 - error: bluelink.0 (9873) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-03-29 12:37:12.201 - error: bluelink.0 (9873) unhandled promise rejection: Cannot read property '0' of undefined
          2021-03-29 12:37:12.201 - error: bluelink.0 (9873) TypeError: Cannot read property '0' of undefined
          at Bluelink.setNewStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:206:71)
          2021-03-29 12:37:12.202 - error: bluelink.0 (9873) Cannot read property '0' of undefined
          2021-03-29 12:37:12.215 - info: bluelink.0 (9873) Adapter bluelink cleaned up everything...
          2021-03-29 12:37:12.216 - info: bluelink.0 (9873) terminating
          NewanN 1 Antwort Letzte Antwort
          • M mmemme
            NewanN Offline
            NewanN Offline
            Newan
            @mmemme ok da scheint es wirklich andere Daten zu geben, erden den Debuglog erweitern.
            @Michaelnorge Danke, ich werde die lib aktualisieren und dann schauen wir uns das nochmal an, ok
            Melde mich!
            A M 2 Antworten Letzte Antwort
            • NewanN Newan
              Melde mich!
              Aiouh
              @newan Servus,
              Nachdem der 1.0.0 immer wieder mal rot war und hing, habe ich heute die V 1.0.0 gelöscht und V 1.0.1 installiert.
              Die Installation ging jetzt fehlerfrei durch.
              Es sind auch alle Objekte da, inkl. verbleibender Ladezeit. Super Job ! Gut wäre noch ein Zeitstempel für das last update.
              Und als Teaser, damit die Jungs und Mädels sehen was man bereits an Daten bekommt und auch steuern kann, hier mal ein Screenshot. Eine Spende für die tolle Arbeit lohnt also ;)
              • NewanN Newan
                Melde mich!
                mmemme
                @newan vielen Dank. Sobald ich was testen soll bitte melden :-)
                • M mmemme
                  NewanN Offline
                  NewanN Offline
                  Newan
                  Neue Version 1.0.2
                  Bitte das Fabrikat neu speichern!
                  Ich habe eine neue lib nun in den Abhängigkeiten, mal sehen wie stabil diese für die Hyundais läuft.
                  @mmemme Bitte mal ein Debuglog von einem Api Aufruf von der neuen Version von deinem Auto, danke! (Bitte persönliche Daten wie VIN etc entfernen!)
                    Michaelnorge
                    Ich habe bei soc-12v einen Wert von 255.
                    Sind das gar Prozentangaben (von 1-100) ?
                    Gestern hat meine 12v-Batterie versagt, da zeigte die einen wert von 23 an.
                    Gemessen hatte sie nur noch 4,5 Volt.
                    A NewanN 2 Antworten Letzte Antwort
                    • M Michaelnorge
                      Aiouh
                      @michaelnorge Meine 12V Batt. zeigte 67%, nach Volladen per externem Lader immer noch 67%. Erst nachdem ich ein paar Minuten rumgefahren bin, ging der Wert auf 84%. Sieht so aus als ob Kia die Batterie irgendwie während der Fahrt "vermisst". Die reine Spannung ist wohl nicht das Kriterium. (Das Versagen mit der 12V Batt hatte ich auch schon, wurde angeblich jetzt mit einem Update behoben - sagt "man".) Habe immer einen 12V booster im Auto...
                      • M Michaelnorge
                        NewanN Offline
                        NewanN Offline
                        Newan
                        @michaelnorge Möglich das es bis 255 geht, dann sind es Werte die noch in Prozent umgerechnet werden müssen. Habe deshalb bei den meisten Objekten noch keine Einheit hinter.
                        Könnten wir aber gemeinsam mal vervollständigen, wo welche Einheit hinkommt!
                        • NewanN Newan
                          Neue Version 1.0.2
                          mmemme
                          @newan Vielen Dank, und schon installiert :-)
                          Anbei das Logfile (die Daten kommen an):
                          2021-03-30 17:10:43.152 - info: host.raspberrypi "system.adapter.bluelink.0" enabled
                          2021-03-30 17:10:43.230 - info: host.raspberrypi instance system.adapter.bluelink.0 started with pid 12924
                          2021-03-30 17:10:45.089 - debug: bluelink.0 (12924) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2021-03-30 17:10:45.136 - debug: bluelink.0 (12924) Objects client ready ... initialize now
                          2021-03-30 17:10:45.140 - debug: bluelink.0 (12924) Objects create System PubSub Client
                          2021-03-30 17:10:45.141 - debug: bluelink.0 (12924) Objects create User PubSub Client
                          2021-03-30 17:10:45.142 - debug: bluelink.0 (12924) Objects client initialize lua scripts
                          2021-03-30 17:10:45.160 - debug: bluelink.0 (12924) Objects connected to redis: 127.0.0.1:9001
                          2021-03-30 17:10:45.172 - debug: bluelink.0 (12924) objectDB connected
                          2021-03-30 17:10:45.175 - debug: bluelink.0 (12924) Redis States: Use Redis connection: 127.0.0.1:9000
                          2021-03-30 17:10:45.197 - debug: bluelink.0 (12924) States create System PubSub Client
                          2021-03-30 17:10:45.198 - debug: bluelink.0 (12924) States create User PubSub Client
                          2021-03-30 17:10:45.204 - debug: bluelink.0 (12924) States connected to redis: 127.0.0.1:9000
                          2021-03-30 17:10:45.205 - debug: bluelink.0 (12924) statesDB connected
                          2021-03-30 17:10:45.387 - info: bluelink.0 (12924) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.bluelink, node: v10.24.0, js-controller: 3.2.16
                          2021-03-30 17:10:45.419 - info: bluelink.0 (12924) Login to api
                          2021-03-30 17:10:45.419 - debug: bluelink.0 (12924) {"username":"XXX","password":"XXX","pin":"XXX","brand":"kia","vin":"XXX","region":"EU"}
                          2021-03-30 17:10:48.778 - info: bluelink.0 (12924) Vehicles found
                          2021-03-30 17:10:48.804 - info: bluelink.0 (12924) Read new status from api
                          2021-03-30 17:10:54.792 - info: bluelink.0 (12924) Set new status
                          2021-03-30 17:10:54.793 - debug: bluelink.0 (12924) {"vehicleLocation":{"coord":{"lat":53.096422,"lon":6.833247,"alt":0,"type":0},"head":155,"speed":{"value":0,"unit":0},"accuracy":{"hdop":10,"pdop":10},"time":"20210330171053"},"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"01H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"evStatus":{"batteryCharge":false,"batteryStatus":84,"batteryPlugin":2,"remainTime2":{"etc2":{"value":125,"unit":1},"etc3":{"value":50,"unit":1},"atc":{"value":0,"unit":1}},"drvDistance":[{"rangeByFuel":{"gasModeRange":{"value":299,"unit":1},"evModeRange":{"value":35,"unit":1},"totalAvailableRange":{"value":334,"unit":1}},"type":2}],"reservChargeInfos":{"reservChargeInfo":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1270","timeSection":0}},"reservChargeSet":false}},"offpeakPowerInfo":{"offPeakPowerTime1":{"starttime":{"time":"1200","timeSection":0},"endtime":{"time":"1200","timeSection":0}},"offPeakPowerFlag":0},"reserveChargeInfo2":{"reservChargeInfoDetail":{"reservInfo":{"day":[9],"time":{"time":"1270","timeSection":0}},"reservChargeSet":false}},"reservFlag":0,"ect":{"start":{"day":0,"time":{"time":"0000","timeSection":0}},"end":{"day":0,"time":{"time":"0000","timeSection":0}}}}},"ign3":true,"hoodOpen":false,"transCond":true,"steerWheelHeat":0,"sideBackWindowHeat":0,"tirePressureLamp":{"tirePressureLampAll":0},"seatHeaterVentState":{"frSeatHeatState":2,"flSeatHeatState":2,"rlSeatHeatState":2,"rrSeatHeatState":2},"lampWireStatus":{"stopLamp":{"stopLampStatus":false,"leftLamp":false,"rightLamp":false},"headLamp":{"headLampStatus":false,"leftLowLamp":false,"rightLowLamp":false,"leftHighLamp":false,"rightHighLamp":false},"turnSignalLamp":{"turnSignalLampStatus":false,"leftFrontLamp":false,"rightFrontLamp":false,"leftRearLamp":false,"rightRearLamp":false}},"windowOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"smartKeyBatteryWarning":false,"fuelLevel":59,"washerFluidStatus":false,"breakOilStatus":false,"time":"20210330171052"},"odometer":{"value":501.2,"unit":1}}
                          2021-03-30 17:10:54.911 - error: bluelink.0 (12924) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2021-03-30 17:10:54.912 - error: bluelink.0 (12924) unhandled promise rejection: Cannot read property '0' of undefined
                          2021-03-30 17:10:54.912 - error: bluelink.0 (12924) TypeError: Cannot read property '0' of undefined
                          at Bluelink.setNewStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:208:77)
                          2021-03-30 17:10:54.913 - error: bluelink.0 (12924) Cannot read property '0' of undefined
                          2021-03-30 17:10:54.929 - info: bluelink.0 (12924) Adapter bluelink cleaned up everything...
                          2021-03-30 17:10:54.930 - info: bluelink.0 (12924) terminating
                          2021-03-30 17:10:54.931 - warn: bluelink.0 (12924) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2021-03-30 17:10:55.477 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2021-03-30 17:10:55.478 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabled
                          2021-03-30 17:10:55.478 - warn: host.raspberrypi Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                          2021-03-30 17:11:11.423 - info: host.raspberrypi "system.adapter.bluelink.0" disabled
                            Michaelnorge
                            @mmemme Genau so siehts bei mir auch aus.
                            • M mmemme
                              NewanN Offline
                              NewanN Offline
                              Newan
                              @mmemme Fehler gefunden, aber das Problem ist ich finde keine SocLimit für euch?
                              Könnt ihr das in der App einstellen? Bei Kia gibt es ja ein Slow und Fast Limit zum laden?
                              Ihr habt Hyundai oder?
                              Was sagt:
                              "fuelLevel":59,
                              Ist das deine Ladekapazität derzeit?
                              • NewanN Newan
                                Was sagt:
                                "fuelLevel":59,
                                mmemme
                                @newan Ich kann kein Limit in der App setzen, ich fahre einen Kia Sorento PHEV ich denke da kann mann dann auch kein Slow/Fast einstellen da ich auf max 3.3kW Ladeleistung komme. Ich vermute fuelLevel ist mein aktueller Benzinstand und "batteryStatus" ist die aktuelle Ladekapazität.
                                M NewanN 2 Antworten Letzte Antwort
                                • M mmemme
                                  mmemme
                                  @mmemme @Newan der "batteryStatus" Wert stimmt überein mit der UVO-App Ladestandsanzeige.
                                  • M mmemme
                                    NewanN Offline
                                    NewanN Offline
                                    Newan
                                    @mmemme AHHHH du hast einen PHEV :-)
                                    Na dann muss ich ja noch Reichweite Gas und Reichweite EV einbauen ^^
                                    • M mmemme
                                      NewanN Offline
                                      NewanN Offline
                                      Newan
                                      @mmemme Version 1.0.3 bitte testen!
                                        Michaelnorge
                                        schrieb am zuletzt editiert von Michaelnorge
                                        Ich bekomme häufig diese Fehlermeldung vom Adapter:
                                        2021-03-31 06:19:58.967 - info: bluelink.0 (2926) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.bluelink, node: v10.24.0, js-controller: 3.2.16
                                        2021-03-31 06:19:59.002 - info: bluelink.0 (2926) Login to api
                                        2021-03-31 06:20:03.277 - info: bluelink.0 (2926) Vehicles found
                                        2021-03-31 06:20:03.339 - info: bluelink.0 (2926) Read new status from api
                                        2021-03-31 06:20:04.259 - error: bluelink.0 (2926) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2021-03-31 06:20:04.261 - error: bluelink.0 (2926) unhandled promise rejection: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"26876f26-xxxx-xxxx-xxxx-e75b566a2483"}
                                        2021-03-31 06:20:04.263 - error: bluelink.0 (2926) ManagedBluelinkyError: @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"26876f26-xxxx-xxxx-xxxx-e75b566a2483"}
                                        at T (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:144032)
                                        at b. (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:152142)
                                        at Generator.throw ()
                                        at P (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:136)
                                        2021-03-31 06:20:04.264 - error: bluelink.0 (2926) @EuropeVehicle.fullStatus: [400] Bad Request on [GET] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/3dd4b153-xxxx-xxxx-xxxx-a4725ed30ace/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"26876f26-xxxx-xxxx-xxxx-e75b566a2483"}
                                        2021-03-31 06:20:04.290 - info: bluelink.0 (2926) Adapter bluelink cleaned up everything...
                                        2021-03-31 06:20:04.292 - info: bluelink.0 (2926) terminating
                                        Das deckt sich glaube ich mit der Aussage in meiner Bluelink-App:
                                        "Remote Service in process..
                                        Please try again later (4004)"
                                        Die Fehlermeldungen kommen ohne mein Zutun.
                                        Ich habe ioBroker neu gestartet, als die Logeinträge aufkamen.
                                        EDIT: Diese Fehlermeldung kam tatsächlich von einer leeren 12v-Bordbatterie!!
                                        Noch etwas: Komischer Weise ist meine App am Handy jetzt auf englisch, ich finde keine Möglichkeit mehr, sie auf Deutsch umzustellen.
                                        Kann das von jemandem bestätigt werden?
                                          Michaelnorge
                                          Hab den Adapter jetzt erstmal pausiert, der gibt nur noch Fehlermeldungen aus...
                                          EDIT: Ich wollte gerade losfahren, da war die 12v-Batterie schon wieder leer.
                                          Vielleicht ist das der Grund der Fehlermeldungen??
                                          Zieht die App irgendwie an der Batterie bei 100 Abfragen täglich?
                                          Ich werd das mal überprüfen und melde mich....
