  4. javascript engine - Fehlermeldung bei der Installation
    6.5k
javascript engine
50 Beiträge 10 Kommentatoren 6.1k Aufrufe 10 Beobachtet
  • sigi234S sigi234
    @jb_sullivan sagte in javascript engine - Fehlermeldung bei der Installation:
    Die 5.1.3 ist ja jetzt draußen, aber das Problem mit der Fehlermeldung während des Update Prozess ist immer noch da. Scripte Seite ist aber OK und sichtbar.
    Dito:
    $ ./iobroker upgrade javascript
    Update javascript from @5.1.2 to @5.1.3
    NPM version: 6.14.11
    npm install iobroker.javascript@5.1.3 --loglevel error (System call)
    gyp ERR! find VS
    gyp ERR! find VS msvs_version not set from command line or npm config
    gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
    gyp ERR! find VS checking VS2019 (16.6.30114.105) found at:
    gyp ERR! find VS "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools"
    gyp ERR! find VS - "Visual Studio C++ core features" missing
    gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
    gyp ERR! find VS looking for Visual Studio 2015
    gyp ERR! find VS - not found
    gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
    gyp ERR! find VS
    gyp ERR! find VS **************************************************************
    gyp ERR! find VS You need to install the latest version of Visual Studio
    gyp ERR! find VS including the "Desktop development with C++" workload.
    gyp ERR! find VS For more information consult the documentation at:
    gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
    gyp ERR! find VS
    gyp ERR! configure error
    gyp ERR! stack Error: Could not find any Visual Studio installation to use
    gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\iobroker\Home\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
    gyp ERR! stack at C:\Program Files\iobroker\Home\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
    gyp ERR! stack at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\iobroker\Home\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
    gyp ERR! stack at C:\Program Files\iobroker\Home\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
    gyp ERR! stack at C:\Program Files\iobroker\Home\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
    gyp ERR! stack at C:\Program Files\iobroker\Home\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
    gyp ERR! stack at C:\Program Files\iobroker\Home\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
    gyp ERR! stack at ChildProcess.exithandler (child_process.js:315:5)
    gyp ERR! stack at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack at maybeClose (internal/child_process.js:1022:16)
    gyp ERR! System Windows_NT 10.0.19042
    gyp ERR! command "C:\Program Files\iobroker\Home\nodejs\node.exe" "C:\Program Files\iobroker\Home\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
    gyp ERR! cwd C:\Program Files\iobroker\Home\node_modules\mdns
    gyp ERR! node -v v12.21.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    Could not install NodeJS typings. This is not critical.
    Reason:
    Error: double-loading config "C:\Program Files\iobroker\Home\env\etc\npmrc" as "global", previously loaded as "user"
    at Config.[loadObject] (C:\Program Files\iobroker\Home\node_modules\npm\node_modules@npmcli\config\lib\index.js:417:13)
    at C:\Program Files\iobroker\Home\node_modules\npm\node_modules@npmcli\config\lib\index.js:446:30
    at async Config.[loadFile] (C:\Program Files\iobroker\Home\node_modules\npm\node_modules@npmcli\config\lib\index.js:444:5)
    at async Config.load (C:\Program Files\iobroker\Home\node_modules\npm\node_modules@npmcli\config\lib\index.js:233:5)
    at async Object.[_load] (C:\Program Files\iobroker\Home\node_modules\npm\lib\npm.js:172:5)
    Error: call config.load() before reading values
    at Config.get (C:\Program Files\iobroker\Home\node_modules\npm\node_modules@npmcli\config\lib\index.js:163:13)
    at errorHandler (C:\Program Files\iobroker\Home\node_modules\npm\lib\utils\error-handler.js:179:32)
    at Object.<anonymous> (C:\Program Files\iobroker\Home\node_modules\npm\lib\cli.js:42:14)
    at Object.onceWrapper (events.js:421:26)
    at Object.emit (events.js:314:20)
    at C:\Program Files\iobroker\Home\node_modules\npm\lib\npm.js:147:12
    at process.errorHandler (C:\Program Files\iobroker\Home\node_modules\npm\lib\utils\error-handler.js:179:32)
    at process.emit (events.js:314:20)
    at processPromiseRejections (internal/process/promises.js:209:33)
    at processTicksAndRejections (internal/process/task_queues.js:98:32)
    throw new Error('call config.load() before reading values')
    at process._fatalException (internal/process/execution.js:165:25)
    Update "system.adapter.javascript.0"
    upload [100] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
    upload [90] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
    upload [80] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/vs/basic-languages/javascript/javascript.js vs/basic-languages/javascript/javascript.js application/javascript
    upload [70] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/static/js/main.305439ec.chunk.js static/js/main.305439ec.chunk.js application/javascript
    upload [60] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
    upload [50] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
    upload [40] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
    upload [30] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
    upload [20] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
    upload [19] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
    upload [18] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
    upload [17] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
    upload [16] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
    upload [15] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
    upload [14] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
    upload [13] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
    upload [12] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
    upload [11] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
    upload [10] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
    upload [9] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
    upload [8] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
    upload [7] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
    upload [6] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
    upload [5] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
    upload [4] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
    upload [3] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
    upload [2] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [1] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
    upload [0] javascript.admin C:/Program Files/iobroker/Home/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    Adapter "javascript" updated
    process exited with code 0
    Platform: Windows
    RAM: 16 GB
    Node.js: 12.21.0
    NPM: 6.14.11
    JS Controler: 3.2.16
    Admin: 4.2.1
    Web: 3.3.0
    Socket.io: 3.1.4
    Script Engine: 5.1.3
    @sigi234 Und wenn die geforderte Version von VS installiert wird? Oder ist sie das schon?
      sigi234S Online
      sigi234S Online
      @thomas-braun sagte in javascript engine - Fehlermeldung bei der Installation:
      Unter Windows? Die wurde damals mit dem Installer mit installiert.
      • sigi234S sigi234
        @sigi234
        Offenbar ist die aber ja nicht mehr ausreichend, wenn man den Meldungen trauen darf. Würde ich jetzt als Linux-User und Windows-Noob mal so interpretieren.
          @sigi234
          sigi234S Online
          sigi234S Online
          @sigi234
          Habe mal den Installer gestartet, da wird die Version 2017 ja installiert bzw. erkannt. Denke da hat NPN ein Problem, diese Meldungen hatte ich vorher ja auch nicht.
          StabilostickS 1 Antwort Letzte Antwort
          • sigi234S sigi234
            @sigi234
            StabilostickS Offline
            Stabilostick
            @sigi234
            Soll ich mal Remote kucken? Jetzt?
            • StabilostickS Stabilostick
              @sigi234
              sigi234S Online
              sigi234S Online
              @stabilostick sagte in javascript engine - Fehlermeldung bei der Installation:
              @sigi234
              Jupp
              • sigi234S sigi234
                @sigi234
                Jupp
                Stabilostick
                @sigi234
                Grund gefunden
                npm beschwert sich, dass sowohl npm-userconfig als auch die npm-globalconfig aus der gleichen Datei kommen. (Das macht der ioBroker-Installer so und es hat bislang gut funktioniert.)
                Lösung (?Workaround?)
                Nehmen wir an, der ioBroker wurde vorher nach "C:\Program Files\iobroker\Home" installiert.
                Bitte diesen Pfad in der folgenden Sequenz jeweils an euren individuellen Installationspfad anpassen!
                1. Den Ordner C:\Program Files\iobroker\Home\env\etc erstellen.
                2. Die Datei npmrc im Ordner C:\Program Files\iobroker\Home\nodejs\node_modules\npm editieren. Bei dem Eintrag globalconfig anstatt npmrc jetzt am Ende neu die Datei npmrc-global referenzieren; gleiches für den Eintrag userconfig - jetzt mit npmrc-user am Ende:
                globalconfig=C:\Program Files\iobroker\Home\env\etc\npmrc-global
                python=C:\Program Files\iobroker\Home\python27\python.exe
                prefix=C:\Program Files\iobroker\Home\env\npm
                cache=C:\Program Files\iobroker\Home\env\npm-cache
                globalignorefile=C:\Program Files\iobroker\Home\env\npm\etc\npmignore
                init-module=C:\Program Files\iobroker\Home\env\npm-init.js
                userconfig=C:\Program Files\iobroker\Home\env\etc\npmrc-user
                1. Die gerade editierte Datei npmrc aus dem Ordner C:\Program Files\iobroker\Home\nodejs\node_modules\npm einmal als neue Datei mit dem Namen npmrc-global und einmal als Datei npmrc-user in den Ordner C:\Program Files\iobroker\Home\env\etc kopieren.
                Jetzt sollte die Fehlermeldung von npm nicht mehr erscheinen.
                Viele Grüße!
                  @sigi234
                  Grund gefunden
                  Viele Grüße!
                  JB_SullivanJ Offline
                  JB_Sullivan
                  schrieb am zuletzt editiert von JB_Sullivan
                  Bezieht sich das nur auf den Teil von sigi234 bzgl. Visual Studio oder eher auf den Rest der Fehlermeldungen?
                  Ich habe ja auch die restlichen Fehlermeldungen, aber NICHT die mit Visual Studio, obwohl ich damals auch über den Installer ioB installiert hatte.
                  ...... ich habe aber auch ganz andere Installationspfade wie man oben am LOG sehen kann.
                  • JB_SullivanJ JB_Sullivan
                    sigi234S Online
                    sigi234S Online
                    Nein, diese Meldung hast du ja auch!
                    Error: double-loading config "C:\iobroker\GLT\env\etc\npmrc" as "global", previously loaded as "user"
                    • sigi234S sigi234
                      JB_Sullivan
                      @sigi234
                      Der Work around hat also erst einmal nichts mit deinen Fehlern von Visual Studio zu tun sondern bezieht sich auf das double-loading - OK, dann werde ich die Änderungen mal vornehmen und anschließend ein Down/ -> Upgrade probieren.
                      EDIT: Downgrade geht nicht mehr.
                      $ ./iobroker upgrade javascript@5.1.0
                      Update javascript from @5.1.3 to @5.1.0
                      npm install iobroker.javascript@5.1.0 --loglevel error (System call)
                      npm ERR! code ETARGET
                      npm ERR! notarget No matching version found for iobroker.javascript@5.1.0.
                      npm ERR! notarget In most cases you or one of your dependencies are requesting
                      npm ERR! notarget a package version that doesn't exist.
                      npm ERR!     C:\iobroker\GLT\env\npm-cache\_logs\2021-03-24T14_17_16_678Z-debug.log
                      EDIT2: Die 5.1.0 scheint eine Leiche zu sein. Downgrade auf die 5.0.15 funktioniert und auch das erneute Upgrade auf 5.1.3 funktioniert mit dem Work Around Fehlerfrei 👍 👍 👍 👍
                      DANKE an @Stabilostick - die Windows Gemeinde kann nicht (nix) ohne dich ;)
                        @sigi234
                        Stabilostick
                        @JB_Sullivan
                        Was wären wir ohne Anwender? Nix. 🤗
                        Gerne geschehen.
                          Sali84
                          Weiss zufällig jemand ob ich die Version 5.0.14 mit dem JS Controller 3.1.4 laufen lassen kann?
                          Vielen Dank
                          • S Sali84
                            Vielen Dank
                            @sali84
                            iobroker -v
                            3.2.16
                              @sali84
                              iobroker -v
                              3.2.16
                              Sali84
                              @thomas-braun ich glaube ich verstehe Dich nicht ganz. Heisst das, das die script engine 5.0.14 nur mit dem JS Controller 3.2.16 läuft und nicht mit 3.1.4?
                              • S Sali84
                                @sali84
                                Das heißt das die ganz wunderbar mit der aktuellen Version vom js-controller zusammenarbeitet. Warum soll denn da die alte 3.1.4 genutzt werden?
                                  @sali84
                                  Sali84
                                  @thomas-braun Weil ich noch nicht auf 3.2.16 umgestellt habe. Und meine Script engine version ist echt alt 4.6.17... und da wollte ich nun mal auf die neue Version, aber eben noch mit der älteren JS Version... Geht das?
                                  • S Sali84
                                    @sali84
                                    Du bastelst dir da gerade ein unwartbares 'System-from-hell'.
                                    Zieh das alles auf die letzten Versionen aus 'stable' hoch.
                                    P 1 Antwort Letzte Antwort
                                      @sali84
                                      Pino72
                                      schrieb am zuletzt editiert von Pino72
                                      Hat sich erledigt....
