  4. Umzug Tinkerboard ->Raspberry 4 InfluxDB schreibt Log voll
influxdblograspberry 4
4 Beiträge 2 Kommentatoren 415 Aufrufe 1 Beobachtet
  • HALH Offline
    HALH Offline
    HAL
    Nach meinem Umzug vom Tinkerboard auf einen Rapsberry 4 habe ich die InfluxDB manuell restored. Alles läuft soweit, aber im LOG tauchen extrem viele warn Einträge vom influxdb Adapter auf. Was könnte die Ursache dafür sein ?
    021-03-11 16:16:03.430 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.battery.SoC to buffer again, error-count=1
    2021-03-11 16:16:03.432 - warn: influxdb.0 (2110) Error on writePoint("{"value":432.8534240723,"time":"2021-03-11T15:15:52.304Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    / "{\"error\":\"timeout\"}\n"
    2021-03-11 16:16:03.432 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.battery.U to buffer again, error-count=1
    2021-03-11 16:16:03.433 - warn: influxdb.0 (2110) Error on writePoint("{"value":0.7878777385,"time":"2021-03-11T15:15:52.304Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.433 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv1.I to buffer again, error-count=1
    2021-03-11 16:16:03.434 - warn: influxdb.0 (2110) Error on writePoint("{"value":528.9320068359,"time":"2021-03-11T15:15:52.304Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.434 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv1.U to buffer again, error-count=1
    2021-03-11 16:16:03.435 - warn: influxdb.0 (2110) Error on writePoint("{"value":415.453338623,"time":"2021-03-11T15:15:52.304Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.436 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv1.P to buffer again, error-count=1
    2021-03-11 16:16:03.437 - warn: influxdb.0 (2110) Error on writePoint("{"value":0.4489355385,"time":"2021-03-11T15:15:52.305Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.437 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv2.I to buffer again, error-count=1
    2021-03-11 16:16:03.438 - warn: influxdb.0 (2110) Error on writePoint("{"value":232.0570831299,"time":"2021-03-11T15:15:52.305Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.439 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv2.P to buffer again, error-count=1
    2021-03-11 16:16:03.440 - warn: influxdb.0 (2110) Error on writePoint("{"value":516.2076416016,"time":"2021-03-11T15:15:52.305Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.440 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.pv2.U to buffer again, error-count=1
    2021-03-11 16:16:03.462 - warn: influxdb.0 (2110) Error on writePoint("{"value":923.2266973253,"time":"2021-03-11T15:15:52.309Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.462 - info: influxdb.0 (2110) Add point that had error for plenticore.0.scb.statistic.EnergyFlow.EnergyHomeGridDay to buffer again, error-count=1
    2021-03-11 16:16:03.537 - warn: influxdb.0 (2110) Error on writePoint("{"value":254,"time":"2021-03-11T15:15:52.524Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.537 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.battery.Discharge_P to buffer again, error-count=6
    2021-03-11 16:16:03.543 - warn: influxdb.0 (2110) Error on writePoint("{"value":647.5104217529,"time":"2021-03-11T15:15:52.536Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.543 - info: influxdb.0 (2110) Add point that had error for Gesamt_PV to buffer again, error-count=1
    2021-03-11 16:16:03.836 - warn: influxdb.0 (2110) Error on writePoint("{"value":424.95,"time":"2021-03-11T15:15:52.828Z","from":"system.adapter.hm-rpc.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:03.837 - info: influxdb.0 (2110) Add point that had error for hm-rpc.0.OEQ1976857.2.POWER to buffer again, error-count=2
    2021-03-11 16:16:04.469 - warn: influxdb.0 (2110) Error on writePoint("{"value":10,"time":"2021-03-11T15:15:53.440Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:06.910 - info: powerfox.0 (5787) starting. Version 0.0.2-4 in /opt/iobroker/node_modules/iobroker.powerfox, node: v12.21.0, js-controller: 3.2.16
    2021-03-11 16:16:04.470 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.battery.MinSoc to buffer again, error-count=3
    2021-03-11 16:16:12.046 - info: host.raspberrypi instance system.adapter.powerfox.0 terminated with code 0 (NO_ERROR)
    2021-03-11 16:16:12.383 - warn: influxdb.0 (2110) Error on writePoint("{"value":825,"time":"2021-03-11T15:15:30.168Z","from":"system.adapter.plenticore.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2021-03-11 16:16:12.384 - info: influxdb.0 (2110) Add point that had error for plenticore.0.devices.local.ac.P to buffer again, error-count=3
    Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
    (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
    • HALH HAL
      @hal sagte in Umzug Tinkerboard ->Raspberry 4 InfluxDB schreibt Log voll:
      hatten wir das nicht schon?
      https://forum.iobroker.net/topic/42901/nach-umzug-tinkerboard-raspberry-4-probleme-mit-influxdb?_=1615475988162
      HALH 1 Antwort Letzte Antwort
        HALH Offline
        HALH Offline
        HAL
        schrieb am zuletzt editiert von HAL
        @homoran Ja/nein, ich habe ja danach den Raspberry komplett neu installiert ( iobrocker, influxdb und garafana) und gehofft damit würden diese Fehler beseitigt sein.
        War aber ein Trugschluss
        Ich habe den restore der DB im Verdacht und werde mald die DB löschen und neu anlegen. Dann sind halt die gespeicherten Werte weg.
        Den Fixer hatte ich schon laufen gelassen
        • HALH HAL
          HALH Offline
          HALH Offline
          HAL
          Eine neue / leere iobroker Datenbank brachte auch keine Verbesserung. Ich versuche den Fehler weiter einzugrenzen.
          Auf dem Tinkerboard mit der gleichen Konfiguration besteht der Fehler nicht
